Now that the sh73a0 generic multiplatform case has the same feature set
as the kzm9g DT reference board code, we get rid of the latter.
DT reference code in the future shall make use of the sh73a0
multiplatform support code with the generic SoC machine vector.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Move the Ethernet node from the root of the device tree to the BSC node,
as it's connected to the Bus State Controller. This allows the system
to know the right position of the Ethernet node in the clock and PM
domain hierarchy, and manage the clock and PM domain appropriately.
Also rename the node's name from "lan9220" to "ethernet", to conform to
ePAPR generic name recomendations.
Add a node for the Bus State Controller (BSC) on sh73a0, to which
multiple external devices can be connected.
The BSC is driven by the ZB clock, and located in PM domain A4S.
A reference to the latter will be added later.
Build the sh73a0 KZM9G board DTB in case of Multiplatform.
The DT reference case will be removed in the future and
can be ignored for now.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Sync the two DTS for the KZM9G board. The target is the file
"sh73a0-kzm9g.dts" and it is made identical to the DT reference
case with the exception of the compatbile string. In the future
the DT reference file will go away.
[geert: Update for recent changes to sh73a0-kzm9g-reference.dts]
Enable sh73a0 Multiplatform support for the generic sh73a0
machine vector. No board support is enabled, and the board
code for KZM9G DT Reference is left by itself.
Add a generic sh73a0 machine setup callback for the upcoming
sh73a0 multiplatform case. Cache needs to be configured, and
legacy clocks must be omitted.
Define the generic R8A7794 parts of the SDHI[012] device nodes.
Based on the orginal patch by Shinobu Uehara <shinobu.uehara.xc@renesas.com>.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Add a driver for transparent busses that don't need a real driver, but
where the bus controller is part of a PM domain, or under the control of
a functional clock. Typically, the bus controller's PM domain and/or
clock must be enabled for child devices connected to the bus (either
on-SoC or externally) to function.
Hence the sole purpose of this driver is to enable its clock and PM
domain (if exist(s)), which are specified in the DT and managed from
platform and PM domain code, and to probe for child devices.
Due to the child-parent relationship with devices connected to the bus,
PM domain and clock state transitions are handled in the correct order.
Tested-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
The bindings for the BSC extend the bindings for "simple-pm-bus".
Add the ADSP clocks to the CPG and MSTP5 nodes of the R8A7790 device tree.
Based on the original patch by Konstantin Kozhevnikov
<konstantin.kozhevnikov@cogentembedded.com>.
Add the ADSP clocks to the CPG and MSTP5 nodes of the R8A7791 device tree.
Define the Henninger board dependent part of the CAN0 device node.
Define the generic R8A7791 parts of the CAN0/1 device nodes.
The R-Car CAN controllers can derive the CAN bus clock not only from their
peripheral clock input (clkp1) but also from the other internal clock (clkp2)
and external clock fed on CAN_CLK pin. Describe those clocks in the device
tree, along with the USB_EXTAL clock from which clkp2 is derived.
Define the generic R8A7790 parts of the CAN0/1 device nodes.
Configure the pinmux on kzm9d to use the serial connector for uart1.
Signed-off-by: Niklas Söderlund <niso@kth.se>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
With this information all GPIOs can make use of the PFC functionality.
Documentation says the last register is at 0x184 (CAxCPUCMCR), so use
proper length. Current APMU code accesses CAxCPUnCR which is currently
outside of the remapped area.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Add DT nodes for the ADV7511 HDMI encoder and its HDMI output connector
and configure the DISP pin group that drives the HDMI transmitter DE
pin.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
There appears to have been some inconsistency and confusion here as on
the r8a7790 these clocks are referred to as SD(HI)1 and SD(HI)2 while on
the r8a7791 and r8a7794 they are referred to as SD(HI)2 and SD(HI)3.
Fixes: 59e79895b95892863 ("ARM: shmobile: r8a7791: Add clocks")
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
* Correct base address of SD3 div6 clk.
* Update div6 clock node labels
This has no run-time affect as the clock nodes are not currently used.
Fixes: 8e181633e6ca96049 ("ARM: shmobile: r8a7794: Add SDHI clocks to device tree")
Reported-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Enable the ethernet controller for the Alt board. Pin muxing entries are
currently left out as r8a7794 pin control support isn't available yet.
We thus rely on the boot loader to configure ethernet pins for now.
Add a DT node for the on-SoC ethernet controller device.
Add the six IPMMU instances found in the r8a7794 to DT with a disabled
status.
Add the seven IPMMU instances found in the r8a7791 to DT with a disabled
status.
Add the six IPMMU instances found in the r8a7790 to DT with a disabled
status.
Instantiate the two system DMA controllers in the r8a7794 device tree.
Traditionally, the first 16 MiB of RAM was reserved for the RT
processor. However, this is incompatible with CONFIG_AUTO_ZRELADDR=y,
which requires that the start address of physical memory is a multiple
of 128 MiB.
As CONFIG_AUTO_ZRELADDR=y is enabled for multi-platform kernels, declare
RAM to start at 0x40000000.
While at it, reclaim the last 8 MiB of RAM, too, so the full 512 MiB is
available. Note that kzm9g_defconfig still has
CONFIG_MEMORY_START=0x41000000 and CONFIG_MEMORY_SIZE=0x1f000000, so
before the advent of DT we scribbled over the last 8 MiB, too.
of 128 MiB.
Specifies clock sources and register bits.
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
[geert: Drop renesas,src-shift/renesas,src-width, pad to 4 or 8 parents]
This clock drives the irqpin controller modules.
Before, it was assumed enabled by the bootloader or reset state.
By making it available to the driver, we make sure it gets enabled when
needed, and allow it to be managed by system or runtime PM.
Enable the kzm9g touchscreen controller in the board's DT file.
Add a DT node for the R2025D real-time clock, which is connected to
i2c0.
Add a DT node for the ADXL345 three-axis digital accelerometer sensor,
which is connected to i2c0.
As trivial i2c devices are matched against the first compatible entry
only, compatibility is declared with "adi,adxl34x" only for now.
The device needs an interrupt to operate properly. Specify the two
interrupts used on the board.
While at it rename the DT node to accelerometer@1d to describe the
device's function instead of its model.
Add a DT node for the AK8975 magnetometer sensor, which is connected to
i2c0.
Specify the device interrupt to avoid polling for end of conversion.
While at it rename the DT node to compass@c to describe the device's
While at it rename the ak4648 node to "codec" to describe the device's
function instead of its model, and move its device-specific property
after its generic properties.
The sh73a0 INTC can't mask interrupts properly most likely due to a
hardware bug. Set the control-parent property to delegate masking to the
parent interrupt controller.
This adds the remaining DIV6 clocks and all possible parents for the SUB
clock.
.. after extensive statistical analysis of my G+ polling, I've come to
the inescapable conclusion that internet polls are bad.
Big surprise.
But "Hurr durr I'ma sheep" trounced "I like online polls" by a 62-to-38%
margin, in a poll that people weren't even supposed to participate in.
Who can argue with solid numbers like that? 5,796 votes from people who
can't even follow the most basic directions?
In contrast, "v4.0" beat out "v3.20" by a slimmer margin of 56-to-44%,
but with a total of 29,110 votes right now.
Now, arguably, that vote spread is only about 3,200 votes, which is less
than the almost six thousand votes that the "please ignore" poll got, so
it could be considered noise.
But hey, I asked, so I'll honor the votes.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 fixes from Ted Ts'o:
"Ext4 bug fixes.
We also reserved code points for encryption and read-only images (for
which the implementation is mostly just the reserved code point for a
read-only feature :-)"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: fix indirect punch hole corruption
ext4: ignore journal checksum on remount; don't fail
ext4: remove duplicate remount check for JOURNAL_CHECKSUM change
ext4: fix mmap data corruption in nodelalloc mode when blocksize < pagesize
ext4: support read-only images
ext4: change to use setup_timer() instead of init_timer()
ext4: reserve codepoints used by the ext4 encryption feature
jbd2: complain about descriptor block checksum errors
Pull more vfs updates from Al Viro:
"Assorted stuff from this cycle. The big ones here are multilayer
overlayfs from Miklos and beginning of sorting ->d_inode accesses out
from David"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (51 commits)
autofs4 copy_dev_ioctl(): keep the value of ->size we'd used for allocation
procfs: fix race between symlink removals and traversals
debugfs: leave freeing a symlink body until inode eviction
Documentation/filesystems/Locking: ->get_sb() is long gone
trylock_super(): replacement for grab_super_passive()
fanotify: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions
Cachefiles: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions
VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)
SELinux: Use d_is_positive() rather than testing dentry->d_inode
Smack: Use d_is_positive() rather than testing dentry->d_inode
TOMOYO: Use d_is_dir() rather than d_inode and S_ISDIR()
Apparmor: Use d_is_positive/negative() rather than testing dentry->d_inode
Apparmor: mediated_filesystem() should use dentry->d_sb not inode->i_sb
VFS: Split DCACHE_FILE_TYPE into regular and special types
VFS: Add a fallthrough flag for marking virtual dentries
VFS: Add a whiteout dentry type
VFS: Introduce inode-getting helpers for layered/unioned fs environments
Infiniband: Fix potential NULL d_inode dereference
posix_acl: fix reference leaks in posix_acl_create
autofs4: Wrong format for printing dentry
Pull ARM fix from Russell King:
"Just one fix this time around. __iommu_alloc_buffer() can cause a
BUG() if dma_alloc_coherent() is called with either __GFP_DMA32 or
__GFP_HIGHMEM set. The patch from Alexandre addresses this"
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: 8305/1: DMA: Fix kzalloc flags in __iommu_alloc_buffer()
X-Coverup: just ask spender
Cc: stable@vger.kernel.org
