2016-05-19Merge tag 'dmaengine-4.7-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time round the update brings in following changes: - new tegra driver for ADMA device - support for Xilinx AXI Direct Memory Access Engine and Xilinx AXI Central Direct Memory Access Engine and few updates to this driver - new cyclic capability to sun6i and few updates - slave-sg support in bcm2835 - updates to many drivers like designware, hsu, mv_xor, pxa, edma, qcom_hidma & bam" * tag 'dmaengine-4.7-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (84 commits) dmaengine: ioatdma: disable relaxed ordering for ioatdma dmaengine: of_dma: approximate an average distribution dmaengine: core: Use IS_ENABLED() instead of checking for built-in or module dmaengine: edma: Re-evaluate errors when ccerr is triggered w/o error event dmaengine: qcom_hidma: add support for object hierarchy dmaengine: qcom_hidma: add debugfs hooks dmaengine: qcom_hidma: implement lower level hardware interface dmaengine: vdma: Add clock support Documentation: DT: vdma: Add clock support for dmas dmaengine: vdma: Add config structure to differentiate dmas MAINTAINERS: Update Tegra DMA maintainers dmaengine: tegra-adma: Add support for Tegra210 ADMA Documentation: DT: Add binding documentation for NVIDIA ADMA dmaengine: vdma: Add Support for Xilinx AXI Central Direct Memory Access Engine Documentation: DT: vdma: update binding doc for AXI CDMA dmaengine: vdma: Add Support for Xilinx AXI Direct Memory Access Engine Documentation: DT: vdma: update binding doc for AXI DMA dmaengine: vdma: Rename xilinx_vdma_ prefix to xilinx_dma dmaengine: slave means at least one of DMA_SLAVE, DMA_CYCLIC dmaengine: mv_xor: Allow selecting mv_xor for mvebu only compatible SoC ...
2016-05-19Merge tag 'localmodconfig-v4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig Pull localmodconfig updates from Steven Rostedt. "Benjamin Poirier added some minor fixes and clean ups to localmodconfig. One is a fix for making sure that module signing still works when coming from a different environment. If original keys are not found it will warn and reset the keys to their default value" * tag 'localmodconfig-v4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig: localmodconfig: Fix whitespace repeat count after "tristate" localmodconfig: Reset certificate paths localmodconfig: Add missing $ to reference a variable localmodconfig: Fix parsing of "help" text localmodconfig: Recognize more keywords that end a menu entry localmodconfig: Fix parsing of Kconfig "source" statements
2016-05-19Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "Small release overall. x86: - miscellaneous fixes - AVIC support (local APIC virtualization, AMD version) s390: - polling for interrupts after a VCPU goes to halted state is now enabled for s390 - use hardware provided information about facility bits that do not need any hypervisor activity, and other fixes for cpu models and facilities - improve perf output - floating interrupt controller improvements. MIPS: - miscellaneous fixes PPC: - bugfixes only ARM: - 16K page size support - generic firmware probing layer for timer and GIC Christoffer Dall (KVM-ARM maintainer) says: "There are a few changes in this pull request touching things outside KVM, but they should all carry the necessary acks and it made the merge process much easier to do it this way." though actually the irqchip maintainers' acks didn't make it into the patches. Marc Zyngier, who is both irqchip and KVM-ARM maintainer, later acked at http://mid.gmane.org/573351D1.4060303@arm.com ('more formally and for documentation purposes')" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (82 commits) KVM: MTRR: remove MSR 0x2f8 KVM: x86: make hwapic_isr_update and hwapic_irr_update look the same svm: Manage vcpu load/unload when enable AVIC svm: Do not intercept CR8 when enable AVIC svm: Do not expose x2APIC when enable AVIC KVM: x86: Introducing kvm_x86_ops.apicv_post_state_restore svm: Add VMEXIT handlers for AVIC svm: Add interrupt injection via AVIC KVM: x86: Detect and Initialize AVIC support svm: Introduce new AVIC VMCB registers KVM: split kvm_vcpu_wake_up from kvm_vcpu_kick KVM: x86: Introducing kvm_x86_ops VCPU blocking/unblocking hooks KVM: x86: Introducing kvm_x86_ops VM init/destroy hooks KVM: x86: Rename kvm_apic_get_reg to kvm_lapic_get_reg KVM: x86: Misc LAPIC changes to expose helper functions KVM: shrink halt polling even more for invalid wakeups KVM: s390: set halt polling to 80 microseconds KVM: halt_polling: provide a way to qualify wakeups during poll KVM: PPC: Book3S HV: Re-enable XICS fast path for irqfd-generated interrupts kvm: Conditionally register IRQ bypass consumer ...
2016-05-19Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for MIPS for 4.7. Here's the summary of the changes: - ATH79: Support for DTB passuing using the UHI boot protocol - ATH79: Remove support for builtin DTB. - ATH79: Add zboot debug serial support. - ATH79: Add initial support for Dragino MS14 (Dragine 2), Onion Omega and DPT-Module. - ATH79: Update devicetree clock support for AR9132 and AR9331. - ATH79: Cleanup the DT code. - ATH79: Support newer SOCs in ath79_ddr_ctrl_init. - ATH79: Fix regression in PCI window initialization. - BCM47xx: Move SPROM driver to drivers/firmware/ - BCM63xx: Enable partition parser in defconfig. - BMIPS: BMIPS5000 has I cache filing from D cache - BMIPS: BMIPS: Add cpu-feature-overrides.h - BMIPS: Add Whirlwind support - BMIPS: Adjust mips-hpt-frequency for BCM7435 - BMIPS: Remove maxcpus from BCM97435SVMB DTS - BMIPS: Add missing 7038 L1 register cells to BCM7435 - BMIPS: Various tweaks to initialization code. - BMIPS: Enable partition parser in defconfig. - BMIPS: Cache tweaks. - BMIPS: Add UART, I2C and SATA devices to DT. - BMIPS: Add BCM6358 and BCM63268support - BMIPS: Add device tree example for BCM6358. - BMIPS: Improve Improve BCM6328 and BCM6368 device trees - Lantiq: Add support for device tree file from boot loader - Lantiq: Allow build with no built-in DT. - Loongson 3: Reserve 32MB for RS780E integrated GPU. - Loongson 3: Fix build error after ld-version.sh modification - Loongson 3: Move chipset ACPI code from drivers to arch. - Loongson 3: Speedup irq processing. - Loongson 3: Add basic Loongson 3A support. - Loongson 3: Set cache flush handlers to nop. - Loongson 3: Invalidate special TLBs when needed. - Loongson 3: Fast TLB refill handler. - MT7620: Fallback strategy for invalid syscfg0. - Netlogic: Fix CP0_EBASE redefinition warnings - Octeon: Initialization fixes - Octeon: Add DTS files for the D-Link DSR-1000N and EdgeRouter Lite - Octeon: Enable add Octeon-drivers in cavium_octeon_defconfig - Octeon: Correctly handle endian-swapped initramfs images. - Octeon: Support CN73xx, CN75xx and CN78xx. - Octeon: Remove dead code from cvmx-sysinfo. - Octeon: Extend number of supported CPUs past 32. - Octeon: Remove some code limiting NR_IRQS to 255. - Octeon: Simplify octeon_irq_ciu_gpio_set_type. - Octeon: Mark some functions __init in smp.c - Octeon: Octeon: Add Octeon III CN7xxx interface detection - PIC32: Add serial driver and bindings for it. - PIC32: Add PIC32 deadman timer driver and bindings. - PIC32: Add PIC32 clock timer driver and bindings. - Pistachio: Determine SoC revision during boot - Sibyte: Fix Kconfig dependencies of SIBYTE_BUS_WATCHER. - Sibyte: Strip redundant comments from bcm1480_regs.h. - Panic immediately if panic_on_oops is set. - module: fix incorrect IS_ERR_VALUE macro usage. - module: Make consistent use of pr_* - Remove no longer needed work_on_cpu() call. - Remove CONFIG_IPV6_PRIVACY from defconfigs. - Fix registers of non-crashing CPUs in dumps. - Handle MIPSisms in new vmcore_elf32_check_arch. - Select CONFIG_HANDLE_DOMAIN_IRQ and make it work. - Allow RIXI to be used on non-R2 or R6 cores. - Reserve nosave data for hibernation - Fix siginfo.h to use strict POSIX types. - Don't unwind user mode with EVA. - Fix watchpoint restoration - Ptrace watchpoints for R6. - Sync icache when it fills from dcache - I6400 I-cache fills from dcache. - Various MSA fixes. - Cleanup MIPS_CPU_* definitions. - Signal: Move generic copy_siginfo to signal.h - Signal: Fix uapi include in exported asm/siginfo.h - Timer fixes for sake of KVM. - XPA TLB refill fixes. - Treat perf counter feature - Update John Crispin's email address - Add PIC32 watchdog and bindings. - Handle R10000 LL/SC bug in set_pte() - cpufreq: Various fixes for Longson1. - R6: Fix R2 emulation. - mathemu: Cosmetic fix to ADDIUPC emulation, plenty of other small fixes - ELF: ABI and FP fixes. - Allow for relocatable kernel and use that to support KASLR. - Fix CPC_BASE_ADDR mask - Plenty fo smp-cps, CM, R6 and M6250 fixes. - Make reset_control_ops const. - Fix kernel command line handling of leading whitespace. - Cleanups to cache handling. - Add brcm, bcm6345-l1-intc device tree bindings. - Use generic clkdev.h header - Remove CLK_IS_ROOT usage. - Misc small cleanups. - CM: Fix compilation error when !MIPS_CM - oprofile: Fix a preemption issue - Detect DSP ASE v3 support:1" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (275 commits) MIPS: pic32mzda: fix getting timer clock rate. MIPS: ath79: fix regression in PCI window initialization MIPS: ath79: make ath79_ddr_ctrl_init() compatible for newer SoCs MIPS: Fix VZ probe gas errors with binutils <2.24 MIPS: perf: Fix I6400 event numbers MIPS: DEC: Export `ioasic_ssr_lock' to modules MIPS: MSA: Fix a link error on `_init_msa_upper' with older GCC MIPS: CM: Fix compilation error when !MIPS_CM MIPS: Fix genvdso error on rebuild USB: ohci-jz4740: Remove obsolete driver MIPS: JZ4740: Probe OHCI platform device via DT MIPS: JZ4740: Qi LB60: Remove support for AVT2 variant MIPS: pistachio: Determine SoC revision during boot MIPS: BMIPS: Adjust mips-hpt-frequency for BCM7435 mips: mt7620: fallback to SDRAM when syscfg0 does not have a valid value for the memory type MIPS: Prevent "restoration" of MSA context in non-MSA kernels MIPS: cevt-r4k: Dynamically calculate min_delta_ns MIPS: malta-time: Take seconds into account MIPS: malta-time: Start GIC count before syncing to RTC MIPS: Force CPUs to lose FP context during mode switches ...
2016-05-19Merge tag 'arc-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC updates from Vineet Gupta: "We have a relatively big changeset for ARC for 4.7. The highlight is support for EZChip (now Mellanox) NPS-400 network processor, a 400-Gb throughput C-programmable packet processor based on ARC700 cores from Synopsys. See http://www.mellanox.com/related-docs/prod_npu/PB_NPS-400.pdf Also present are irqchip and clocksource drivers for NPS as agreed with respective maintainers to go via ARC tree due to an soc header dependency. I have the needed ACKs from Jason, Marc, Daniel. You might run into a trivial merge conflict in drivers/irqchip/* This EZChip platform support required some deep changes in ARC architecture code and also opportunity to cleanup past sins (legacy irq domains, missing irq domain lookup, hard coded timer irqs...) Summary: - Support for EZChip (now Mellanox) NPS-400 Network processor based on ARC700 - NPS interrupt controller and clocksource drivers - ARC timers probed off DT - ARC iqrchips switching to linear domain (upgrade from legacy domains)" * tag 'arc-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (37 commits) arc: axs103_smp: Fix CPU frequency to 100MHz for dual-core arc: axs10x: Add DT bindings for I2S PLL Clock ARC: pae: STRICT_MM_TYPECHECKS was broken ARC: Add eznps platform to Kconfig and Makefile ARC: [plat-eznps] Use dedicated COMMAND_LINE_SIZE ARC: [plat-eznps] Use dedicated cpu_relax() ARC: [plat-eznps] Use dedicated identity auxiliary register. ARC: [plat-eznps] Use dedicated SMP barriers ARC: [plat-eznps] Use dedicated atomic/bitops/cmpxchg ARC: [plat-eznps] Use dedicated user stack top ARC: [plat-eznps] Add eznps platform ARC: [plat-eznps] Add eznps board defconfig and dts ARC: Mark secondary cpu online only after all HW setup is done ARC: rwlock: disable interrupts in !LLSC variant ARC: Make vmalloc size configurable ARC: clean out UAPI byteorder.h clean off Kconfig symbol irqchip: add nps Internal and external irqchips clocksource: Add NPS400 timers driver soc: Support for EZchip SoC Documentation: Add EZchip vendor to binding list ...
2016-05-19Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - A new LSM, "LoadPin", from Kees Cook is added, which allows forcing of modules and firmware to be loaded from a specific device (this is from ChromeOS, where the device as a whole is verified cryptographically via dm-verity). This is disabled by default but can be configured to be enabled by default (don't do this if you don't know what you're doing). - Keys: allow authentication data to be stored in an asymmetric key. Lots of general fixes and updates. - SELinux: add restrictions for loading of kernel modules via finit_module(). Distinguish non-init user namespace capability checks. Apply execstack check on thread stacks" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (48 commits) LSM: LoadPin: provide enablement CONFIG Yama: use atomic allocations when reporting seccomp: Fix comment typo ima: add support for creating files using the mknodat syscall ima: fix ima_inode_post_setattr vfs: forbid write access when reading a file into memory fs: fix over-zealous use of "const" selinux: apply execstack check on thread stacks selinux: distinguish non-init user namespace capability checks LSM: LoadPin for kernel file loading restrictions fs: define a string representation of the kernel_read_file_id enumeration Yama: consolidate error reporting string_helpers: add kstrdup_quotable_file string_helpers: add kstrdup_quotable_cmdline string_helpers: add kstrdup_quotable selinux: check ss_initialized before revalidating an inode label selinux: delay inode label lookup as long as possible selinux: don't revalidate an inode's label when explicitly setting it selinux: Change bool variable name to index. KEYS: Add KEYCTL_DH_COMPUTE command ...
2016-05-18Merge tag 'trace-v4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "This includes two new updates for the ftrace infrastructure. - With the changing of the code for filtering events by pid, from a list of pids to a bitmask, we can now easily implement following forks. With a new tracing option "event-fork" which, when set, will have tasks with pids in set_event_pid, when they fork, to have their child pids added to set_event_pid and the child will be traced as well. Note, if "event-fork" is set and a task with its pid in set_event_pid exits, its pid will be removed from set_event_pid - The addition of Tom Zanussi's hist triggers. This includes a very thorough documentatino on how to use the hist triggers with events. This introduces a quick and easy way to get histogram data from events and their fields. Some other cleanups and updates were added as well. Like Masami Hiramatsu added test cases for the event trigger and hist triggers. Also I added a speed up of filtering by using a temp buffer when filters are set" * tag 'trace-v4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (45 commits) tracing: Use temp buffer when filtering events tracing: Remove TRACE_EVENT_FL_USE_CALL_FILTER logic tracing: Remove unused function trace_current_buffer_lock_reserve() tracing: Remove one use of trace_current_buffer_lock_reserve() tracing: Have trace_buffer_unlock_commit() call the _regs version with NULL tracing: Remove unused function trace_current_buffer_discard_commit() tracing: Move trace_buffer_unlock_commit{_regs}() to local header tracing: Fold filter_check_discard() into its only user tracing: Make filter_check_discard() local tracing: Move event_trigger_unlock_commit{_regs}() to local header tracing: Don't use the address of the buffer array name in copy_from_user tracing: Handle tracing_map_alloc_elts() error path correctly tracing: Add check for NULL event field when creating hist field tracing: checking for NULL instead of IS_ERR() tracing: Do not inherit event-fork option for instances tracing: Fix unsigned comparison to zero in hist trigger code kselftests/ftrace: Add a test for log2 modifier of hist trigger tracing: Add hist trigger 'log2' modifier kselftests/ftrace: Add hist trigger testcases kselftests/ftrace : Add event trigger testcases ...
2016-05-18Merge branch 'stable-4.7' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Four small audit patches for 4.7. Two are simple cleanups around the audit thread management code, one adds a tty field to AUDIT_LOGIN events, and the final patch makes tty_name() usable regardless of CONFIG_TTY. Nothing controversial, and it all passes our regression test" * 'stable-4.7' of git://git.infradead.org/users/pcmoore/audit: tty: provide tty_name() even without CONFIG_TTY audit: add tty field to LOGIN event audit: we don't need to __set_current_state(TASK_RUNNING) audit: cleanup prune_tree_thread
2016-05-18Merge tag 'rproc-v4.7' of git://github.com/andersson/remoteprocLinus Torvalds
Pull remoteproc updates from Bjorn Andersson: "Introduce a synchronization point between the async firmware loading and clients requesting the remote processor to boot, as well as support for remote processors that are not interested in the resource table information" * tag 'rproc-v4.7' of git://github.com/andersson/remoteproc: remoteproc: Add additional crash reasons remoteproc: core: Make the loaded resource table optional remoteproc: core: Task sync during rproc_fw_boot()
2016-05-18Merge tag 'rpmsg-v4.7' of git://github.com/andersson/remoteprocLinus Torvalds
Pull rpmsg updates from Bjorn Andersson: "Refactor rpmsg module registration to follow other subsystems; by introduction of module_rpmsg_driver and hiding of THIS_MODULE from clients" * tag 'rpmsg-v4.7' of git://github.com/andersson/remoteproc: rpmsg: use module_rpmsg_driver in existing drivers and examples rpmsg: add helper macro module_rpmsg_driver rpmsg: drop owner assignment from rpmsg_drivers rpmsg: add THIS_MODULE to rpmsg_driver in rpmsg core
2016-05-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "First round of updates for the input subsystem. No new drivers here, just some driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: rotary-encoder - fix bare use of 'unsigned' Input: cm109 - spin_lock in complete() cleanup Input: cm109 - fix handling of volume and mute buttons Input: byd - don't wipe dynamically allocated memory twice Input: twl4030 - fix unsafe macro definition Input: twl6040-vibra - remove mutex Input: bcm_iproc_tsc - DT spelling s/clock-name/clock-names/ Input: bcm_iproc_tsc - use syscon to access shared registers Input: ti_am335x_tsc - use SIMPLE_DEV_PM_OPS Input: omap-keypad - remove set_col_gpio_val() and get_row_gpio_val() Input: omap-keypad - drop empty PM stubs Input: omap-keypad - remove adjusting of scan delay Input: gpio-keys - clean up device tree binding example Input: kbtab - stop saving struct usb_device Input: gtco - stop saving struct usb_device Input: aiptek - stop saving struct usb_device Input: acecad - stop saving struct usb_device
2016-05-18Merge tag 'media/v4.7-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - added support for Intersil/Techwell TW686x-based video capture cards - v4l PCI skeleton driver moved to samples directory - Documentation cleanups and improvements - RC: reduced the memory footprint for IR raw events - tpg: Export the tpg code from vivid as a module - adv7180: Add device tree binding documentation - lots of driver improvements and fixes * tag 'media/v4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (173 commits) [media] exynos-gsc: avoid build warning without CONFIG_OF [media] samples: v4l: from Documentation to samples directory [media] dib0700: add USB ID for another STK8096-PVR ref design based card [media] tvp5150: propagate I2C write error in .s_register callback [media] tvp5150: return I2C write operation failure to callers [media] em28xx: add support for Hauppauge WinTV-dualHD DVB tuner [media] em28xx: add missing USB IDs [media] update cx23885 and em28xx cardlists [media] media: au0828 fix au0828_v4l2_device_register() to not unlock and free [media] c8sectpfe: Rework firmware loading mechanism [media] c8sectpfe: Demote print to dev_dbg [media] c8sectpfe: Fix broken circular buffer wp management [media] media-device: Simplify compat32 logic [media] media: i2c: ths7303: remove redundant assignment on bt [media] dvb-usb: hide unused functions [media] xilinx-vipp: remove unnecessary of_node_put [media] drivers/media/media-devnode: clear private_data before put_device() [media] drivers/media/media-device: move debug log before _devnode_unregister() [media] drivers/media/rc: postpone kfree(rc_dev) [media] media/dvb-core: forward media_create_pad_links() return value ...
2016-05-18Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "First round of SCSI updates for the 4.6+ merge window. This batch includes the usual quota of driver updates (bnx2fc, mp3sas, hpsa, ncr5380, lpfc, hisi_sas, snic, aacraid, megaraid_sas). There's also a multiqueue update for scsi_debug, assorted bug fixes and a few other minor updates (refactor of scsi_sg_pools into generic code, alua and VPD updates, and struct timeval conversions)" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (138 commits) mpt3sas: Used "synchronize_irq()"API to synchronize timed-out IO & TMs mpt3sas: Set maximum transfer length per IO to 4MB for VDs mpt3sas: Updating mpt3sas driver version to 13.100.00.00 mpt3sas: Fix initial Reference tag field for 4K PI drives. mpt3sas: Handle active cable exception event mpt3sas: Update MPI header to 2.00.42 Revert "lpfc: Delete unnecessary checks before the function call mempool_destroy" eata_pio: missing break statement hpsa: Fix type ZBC conditional checks scsi_lib: Decode T10 vendor IDs scsi_dh_alua: do not fail for unknown VPD identification scsi_debug: use locally assigned naa scsi_debug: uuid for lu name scsi_debug: vpd and mode page work scsi_debug: add multiple queue support bfa: fix bfa_fcb_itnim_alloc() error handling megaraid_sas: Downgrade two success messages to info cxlflash: Fix to resolve dead-lock during EEH recovery scsi_debug: rework resp_report_luns scsi_debug: use pdt constants ...
2016-05-18Merge branch 'stable/for-linus-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft Pull iscsi_ibft updates from Konrad Rzeszutek Wilk: "The pull has two features - both of them expand the SysFS entries: - 'prefix-len' - which is subnet_mask_prefix of the iBFT header. - 'acpi_header' dir with: 'iBFT', OEM-ID (whatever it extracts from the iBFT header) and OEM_TABLE_ID (also whatever it extracts from the iBFT header). This is to help NIC drivers to figure out during bootup how to deal with BIOS created iBFT tables (like by TianoCore UEFI implemenation)" * 'stable/for-linus-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft: ibft: Expose iBFT acpi header via sysfs iscsi_ibft: Add prefix-len attr and display netmask
2016-05-18Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "Driver updates for ARM SoCs, these contain various things that touch the drivers/ directory but got merged through arm-soc for practical reasons. For the most part, this is now related to power management controllers, which have not yet been abstracted into a separate subsystem, and typically require some code in drivers/soc or arch/arm to control the power domains. Another large chunk here is a rework of the NVIDIA Tegra USB3.0 support, which was surprisingly tricky and took a long time to get done. Finally, reset controller handling as always gets merged through here as well" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits) arm-ccn: Enable building as module soc/tegra: pmc: Add generic PM domain support usb: xhci: tegra: Add Tegra210 support usb: xhci: Add NVIDIA Tegra XUSB controller driver dt-bindings: usb: xhci-tegra: Add Tegra210 XUSB controller support dt-bindings: usb: Add NVIDIA Tegra XUSB controller binding PCI: tegra: Support per-lane PHYs dt-bindings: pci: tegra: Update for per-lane PHYs phy: tegra: Add Tegra210 support phy: Add Tegra XUSB pad controller support dt-bindings: phy: tegra-xusb-padctl: Add Tegra210 support dt-bindings: phy: Add NVIDIA Tegra XUSB pad controller binding phy: core: Allow children node to be overridden clk: tegra: Add interface to enable hardware control of SATA/XUSB PLLs drivers: firmware: psci: make two helper functions inline soc: renesas: rcar-sysc: Add support for R-Car H3 power areas soc: renesas: rcar-sysc: Add support for R-Car E2 power areas soc: renesas: rcar-sysc: Add support for R-Car M2-N power areas soc: renesas: rcar-sysc: Add support for R-Car M2-W power areas soc: renesas: rcar-sysc: Add support for R-Car H2 power areas ...
2016-05-18Merge tag 'armsoc-defconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC defconfig updates from Arnd Bergmann: "As usual, a bunch of commits, mostly adding drivers and other options to defconfigs. We are adding three new defconfig files for the newly added 32-bit machines (aspeed and mps2), the rest is mainly housekeeping. The changes outside of arch/arm/config/ are for a Kconfig symbol that got renamed" * tag 'armsoc-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (63 commits) ARM: aspeed: adapt defconfigs for new CONFIG_PRINTK_TIME ARM: u8500_defconfig: update sensor config ARM: u8500_defconfig: remove staging from defconfig ARM: multi_v7_defconfig: Remove unused Kconfig option MACH_UX500_DT ARM: at91/defconfig: sama5: add CONFIG_FHANDLE arm/configs: Add Aspeed defconfig arm/configs/multi_v5: Add Aspeed ast2400 ARM: at91: sama5: Update defconfig ARM: imx_v6_v7_defconfig: add CONFIG_MICREL_PHY ARM: imx_v6_v7_defconfig: add CONFIG_I2C_GPIO ARM: multi_v7: Enable Tegra XUSB controller in defconfig ARM: tegra: Enable XUSB controller in defconfig ARM: omap2plus_defconfig: Enable PWM and ir-rx51 as loadable modules ARM: multi_v7_defconfig: add the Atmel sama5d2-compatible ADC driver ARM: multi_v7_defconfig: add the Atmel Audio microphone interface PDMIC ARM: multi_v7_defconfig: add Atmel ISI (Image Sensor Interface) driver ARM: multi_v7_defconfig: add Atmel watchdog timers ARM: multi_v7_defconfig: add HLCDC drivers as modules ARM: at91/defconfig: add PDMIC driver to sama5_defconfig ARM: at91/defconfig: add HLCDC driver to sama5_defconfig ...
2016-05-18Merge tag 'armsoc-dt64' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM 64-bit DT updates from Arnd Bergmann: "We continue ramping up platform support for 64-bit ARM machines, with 111 individual non-merge changesets touching 21 platforms. The LG1312 platform is completely new and is the first ARM platform by LG that we support in the mainline kernel. Two other SoCs got added that are updated versions of existing SoC families, so the port mainly consists of new dts files: - The Hisilicon Hip06/D03 is the latest server platform from Huawei/Hisilicon, and follows the Hip05/D02 platform. - Rockchip RK3399 follows the 32-bit RK3288 that is popular in low-end Chromebooks and the 64-bit RK3368 that is mainly found in chinese Android TV boxes. The 96Boards HiKey based on the Hisilicon Hi6220 (Kirin 620) gets a long-awaited overhaul with a lot of devices enabled in the DT, so it should be much more usable with a mainline kernel now. See also https://plus.google.com/111524780435806926688/posts/PeGb2VsNhJd A lot of work went into enabling new device drivers on existing machines, but we also have a couple of new commercially available machines: - Google Pixel C laptop based on Tegra210 - Hardkernel Odroid C2 Based on Amlogic Meson GXBB (S905) - Geekbuying GeekBox based on Rockchip RK3368 And finally, a couple of reference or development platforms that are not end-user platforms but are used for trying out the respective SoC platforms: - Amlogic Meson GXBB P200 and P201 development systems - NXP Layerscape 1043A QDS development board - Hisilicon Hip06 D03 server board, as mentioned above - LG1312 Reference Design - RK3399 Evaluation Board" * tag 'armsoc-dt64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (104 commits) arm64: dts: marvell: add XOR node for Armada 3700 SoC dt-bindings: document rockchip rk3399-evb board arm64: dts: rockchip: add dts file for RK3399 evaluation board arm64: dts: rockchip: add core dtsi file for RK3399 SoCs dt-bindings: rockchip-dw-mshc: add description for rk3399 arm64: dts: marvell: Use a SoC-specific compatible for xHCI on Armada37xx arm64: dts: marvell: Rename armada-37xx USB node arm64: dts: marvell: Clean up armada-3720-db Documentation: arm64: Add Hisilicon Hip06 D03 dts binding arm64: dts: Add initial dts for Hisilicon Hip06 D03 board arm64: dts: hip05: Add nor flash support arm64: dts: hip05: fix its node without msi-cells arm64: dts: r8a7795: Don't disable referenced optional clocks arm64: dts: salvator-x: populate EXTALR arm64: dts: r8a7795: enable PCIe on Salvator-X arm64: dts: r8a7795: Add PCIe nodes arm64: tegra: Add IOMMU node to GM20B on Tegra210 arm64: tegra: Add reference clock to GM20B on Tegra210 dt-bindings: Add documentation for GM20B GPU dt-bindings: gk20a: Document iommus property ...
2016-05-18Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Arnd Bergmann: "These are all the updates to device tree files for 32-bit platforms, which as usual makes up the bulk of the ARM SoC changes: 462 non-merge changesets, 450 files changed, 23340 insertions, 5216 deletions. The three platforms that are added with the "soc" branch are here as well, and we add some related machine files: - For Aspeed AST2400/AST2500, we get the evaluation platform and the Tyan Palmetto POWER8 mainboard that uses the AST2400 BMC - For Oxnas 810SE, the Western Digital "My Book World Edition" is added as the only platform at the moment. - For ARM MPS2, the AN385 (Cortex-M3) and AN399 (Cortex-M7) are supported On the ARM Realview development platform, we now support all machines with device tree, previously only the board files were supported, which in turn will likely be removed soon. Qualcomm IPQ4019 is the second generation ARM based "Internet Processor", following the IPQ806x that is used in many high-end WiFi routers. This one integrates two ath10k wifi radios that were previously on separate chips. Other boards that got added for existing chips are: Ti OMAP family: - Amazon Kindle Fire, first generation, tablet and ebook reader - OnRISC Baltos iR 2110 and 3220 embedded industrial PCs - TI AM5728 IDK, TI AM3359 ICE-V2, and TI DRA722 Rev C EVM development systems Samsung EXYNOS platform: - Samsung ARTIK5 evaluation board, see https://www.artik.io/modules/overview/artik-5/ NXP i.MX platforms: - Ka-Ro electronics TX6S-8034, TX6S-8035, TX6U-8033, TX6U-81xx, TX6Q-1036, TX6Q-1110/-1130, TXUL-0010 and TXUL-0011 industrial SoM modules - Embest MarS Board i.MX6Dual DIY platform - Boundary Devices i.MX6 Quad Plus Nitrogen6_MAX and SoloX Nitrogen6sx embedded boards - Technexion Pico i.MX6UL compute module - ZII VF610 Development Board Marvell embedded (mvebu, orion, kirkwood) platforms: - Linksys Viper (E4200v2 / EA4500) WiFi router - Buffalo Kurobox Pro NAS Qualcomm Snapdragon: - Arrow DragonBoard 600c (96boards) with APQ8064 Snapdragon 600 Rockchips platform: - mqmaker MiQi single-board computer Altera SoCFPGA: - samtec VIN|ING 1000 vehicle communication interface Allwinner Sunxi platforms: - Dserve DSRV9703C tablet - Difrnce DIT4350 tablet - Colorfly E708 Q1 tablet - Polaroid MID2809PXE04 tablet - Olimex A20 OLinuXino LIME2 single board computer - Xunlong Orange Pi 2, Orange Pi One, and Orange Pi PC single board computers Across many platforms, bug fixes went in to address warnings that dtc now emits with 'make dtbs W=1'. Further changes for device enablement went into Ti OMAP, bcm283x (Raspberry Pi), bcm47xx (wifi router), Ti Davinci, Samsung EXYNOS, Marvell mvebu/kirkwood/orion, NXP i.MX/Vybrid NXP LPC18xx, NXP LPC32xx, Renesas shmobile/r-mobile/r-car, Rockchips rk3xxx, ST Ux500, ST STi, Atmel AT91/SAMA5, Altera SoCFPGA, Allwinner Sunxi, Sigma Designs Tango, NVIDIA Tegra, Socionext Uniphier and ARM Versatile Express" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (458 commits) ARM: dts: tango4: Import watchdog node ARM: dts: tango4: Update cpus node for cpufreq ARM: dts: tango4: Update DT to match clk driver ARM: dts: tango4: Initial thermal support arm/dst: Add Aspeed ast2500 device tree arm/dts: Add Aspeed ast2400 device tree ARM: sun7i: dt: Add pll3 and pll7 clocks ARM: dts: sunxi: Add a olinuxino-lime2-emmc ARM: dts: at91: sama5d4: add trng node ARM: dts: at91: sama5d3: add trng node ARM: dts: at91: sama5d2: add trng node ARM: dts: at91: at91sam9g45 family: reduce the trng register map size ARM: sun4i: dt: Add pll3 and pll7 clocks ARM: sun5i: chip: Enable the TV Encoder ARM: sun5i: r8: Add display blocks to the DTSI ARM: sun5i: a13: Add display and TCON clocks ARM: dts: ux500: configure the accelerometers open drain ARM: mx5: dts: Enable USB OTG on M53EVK ARM: dts: imx6ul-14x14-evk: Add audio support ARM: dts: imx6qdl: Remove unneeded unit-addresses ...
2016-05-18Merge tag 'armsoc-arm64' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC 64-bit changes from Arnd Bergmann: "One new platform gets added this time: The Cortex-A53 based LG Electronics LG1K platform used in digital TVs. The other changes are mostly smaller updates to the defconfig files, to enable additional platform specific drivers, as they get merged through the subsystem trees" * tag 'armsoc-arm64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arm64: configs: add options useful for Armada 7K/8K support arm64: defconfig: Add Juno SATA controller arm64: defconfig: enable freescale/nxp config options arm64: defconfig: enable 48-bit virtual addresses arm64: defconfig: cleanup the defconfig MAINTAINERS: update entry for Marvell ARM platform maintainers arm64: marvell: enable AP806 and CP110 syscon driver arm64: Kconfig: select sp804 timer for ARCH_HISI arm64: defconfig: enable configs for WLAN and TI WL1835 as modules arm64: defconfig: enable several common USB network adapters arm64: defconfig: add CONFIG_SPI_SPIDEV as module arm64: defconfig: Enable the PMIC and regulator for Hi6220 and 96boards HiKey arm64: defconfig: Add Renesas R-Car USB 3.0 driver support MAINTAINERS: add Chanho Min as ARM/LG1K maintainer arm64: defconfig: enable ARCH_LG1K arm64: add Kconfig entry for LG1K SoC family arm64: defconfig: Enable PL330 DMA controller arm64: defconfig: enable basic boot for Amlogic meson
2016-05-18Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "We get support for three new 32-bit SoC platforms this time. The amount of changes in arch/arm for any of them is miniscule, as all the interesting code is in device driver subsystems (irqchip, clk, pinctrl, ...) these days. I'm listing them here, as the addition of the Kconfig statement is the main relevant milestone for a new platform. In each case, some drivers are are shared with existing platforms, while other drivers are added for v4.7 as well, or come in a later release. - The Aspeed platform is probably the most interesting one, this is what most whitebox servers use as their baseboard management controller. We get support for the very common ast2400 and ast2500 SoCs. The OpenBMC project focuses on this chip, and the LWN article about their ELC 2016 presentation at https://lwn.net/Articles/683320/ triggered the submission, but the code comes from IBM's OpenPOWER team rather than the team at Facebook. There are still a lot more drivers that need to get added over time, and I hope both teams can work together on that. - OXNAS is an old platform for Network Attached Storage devices from Oxford Semiconductor. There are models with ARM10 (!) and ARM11MPCore cores, but for now, we only support the original ARM9 based versions. The product lineup was subsequently part of PLX, Avago and now the new Broadcom Ltd. https://wiki.openwrt.org/doc/hardware/soc/soc.oxnas has some more information. - V2M-MPS2 is a prototyping platform from ARM for their Cortex-M cores and is related to the existing Realview / Versatile Express lineup, but without MMU. We now support various NOMMU platforms, so adding a new one is fairly straightforward. http://infocenter.arm.com/help/topic/com.arm.doc.100112_0100_03_en/ has detailed information about the platform. Other noteworthy updates: - Work on LPC32xx has resumed, and Vladimir Zapolskiy and Sylvain Lemieux are now maintaining the platform. This is an older ARM9 based platform from NXP (not Freescale), but it remains in use in embedded markets. - Kevin Hilman is now co-maintaining the Amlogic Meson platform for both 32-bit and 64-bit ARM, and started contributing some patches. - As is often the case, work on the OMAP platforms makes up the bulk of the actual SoC code changes in arch/arm, but there isn't a lot of that either" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits) MAINTAINERS: ARM/Amlogic: add co-maintainer, misc. updates MAINTAINERS: add ARM/NXP LPC32XX SoC specific drivers to the section MAINTAINERS: add new maintainers of NXP LPC32xx SoC MAINTAINERS: move ARM/NXP LPC32xx record to ARM section arm: Add Aspeed machine ARM: lpc32xx: remove duplicate const on lpc32xx_auxdata_lookup ARM: lpc32xx: remove leftovers of legacy clock source and provider drivers ARM: lpc32xx: remove reboot header file ARM: dove: Remove CLK_IS_ROOT ARM: orion5x: Remove CLK_IS_ROOT ARM: mv78xx0: Remove CLK_IS_ROOT ARM: davinci: da850: use clk->set_parent for async3 ARM: davinci: Move clock init after ioremap. MAINTAINERS: Update ARM Versatile Express platform entry ARM: vexpress/mps2: introduce MPS2 platform MAINTAINERS: add maintainer entry for ARM/OXNAS platform ARM: Add new mach-oxnas irqchip: versatile-fpga: add new compatible for OX810SE SoC ARM: uniphier: correct the call order of of_node_put() MAINTAINERS: fix stale TI DaVinci entries ...
2016-05-18Merge tag 'armsoc-cleanups-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups and fixes from Arnd Bergmann: "Traditionally we've had two separate branches for cleanups and non-critical bug fixes, but both of these got smaller with each release and the differences are rather unclear now, so it seems more appropriate to have a combined branch. The most notable change is for OMAP, which gets a small rework to simplify handling of the AUXDATA mechanism used on machines that are not completely DT based yet, along with other work that is used as preparation for dropping the legacy board files" * tag 'armsoc-cleanups-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: exynos: Add interrupt line to MAX8997 PMIC on exynos4210-trats ARM: dts: exynos: Fix regulator name to avoid forbidden character on exynos4210-trats ARM: dts: exynos: Add MFC memory banks for Peach boards ARM: OMAP2+: n900 needs MMC slot names for legacy user space ARM: OMAP2+: Add more functions to pwm pdata for ir-rx51 ARM: debug: remove extraneous DEBUG_HI3716_UART option ARM: OMAP2+: Simplify auxdata by using the generic match of/platform: Allow secondary compatible match in of_dev_lookup ARM: davinci: use IRQCHIP_DECLARE for cp_intc ARM: davinci: remove unused DA8XX_NUM_UARTS ARM: davinci: simplify call to of populate ARM: DaVinci USB: removed deprecated properties from MUSB config ARM: rockchip: Fix use of plain integer as NULL pointer ARM: realview: hide unused 'pmu_device' object soc: versatile: dynamically detect RealView HBI numbers
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "The s390 patches for the 4.7 merge window have the usual bug fixes and cleanups, and the following new features: - An interface for dasd driver to query if a volume is online to another operating system - A new ioctl for the dasd driver to verify the format for a range of tracks - Following the example of x86 the struct fpu is now allocated with the task_struct - The 'report_error' interface for the PCI bus to send an adapter-error notification from user space to the service element of the machine" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (29 commits) s390/vmem: remove unused function parameter s390/vmem: fix identity mapping s390: add missing include statements s390: add missing declarations s390: make couple of variables and functions static s390/cache: remove superfluous locking s390/cpuinfo: simplify locking and skip offline cpus early s390/3270: hangup the 3270 tty after a disconnect s390/3270: handle reconnect of a tty with a different size s390/3270: avoid endless I/O loop with disconnected 3270 terminals s390/3270: fix garbled output on 3270 tty view s390/3270: fix view reference counting s390/3270: add missing tty_kref_put s390/dumpstack: implement and use return_address() s390/cpum_sf: Remove superfluous SMP function call s390/cpum_cf: Remove superfluous SMP function call s390/Kconfig: make z196 the default processor type s390/sclp: avoid compile warning in sclp_pci_report s390/fpu: allocate 'struct fpu' with the task_struct s390/crypto: cleanup and move the header with the cpacf definitions ...
2016-05-18iwlwifi: fix mis-merge that breaks the driverLinus Torvalds
My laptop that uses the intel 7680 iwlwifi module would no longer connects to the network. It would fail with a "Microcode SW error detected." and spew out register state over and over again without ever connecting to the network. The cause is mis-merge in commit 909b27f70643, where David seems to have lost some of the changes to iwl_mvm_set_tx_cmd() from commit 5c08b0f5026f ("iwlwifi: mvm: don't override the rate with the AMSDU len"). The reason seems to be a conflict with commit d8fe484470dd ("iwlwifi: mvm: add support for new TX CMD API"), which touched a line adjacent to the changes in 909b27f70643. David missed the fact that "info->driver_data[0]" had become "skb_info->driver_data[0]". Then he removed the skb_info because it was unused. This just re-updates iwl_mvm_set_tx_cmd() with the lost two lines. Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org> Reported-by: Reinoud Koornstra <reinoudkoornstra@gmail.com> Cc: Luciano Coelho <luciano.coelho@intel.com> Cc: Kalle Valo <kvalo@codeaurora.org> Cc: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-18Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs cleanups from Al Viro: "Assorted cleanups and fixes all over the place" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coredump: only charge written data against RLIMIT_CORE coredump: get rid of coredump_params->written ecryptfs_lookup(): try either only encrypted or plaintext name ecryptfs: avoid multiple aliases for directories bpf: reject invalid names right in ->lookup() __d_alloc(): treat NULL name as QSTR("/", 1) mtd: switch ubi_open_volume_path() to vfs_stat() mtd: switch open_mtd_by_chdev() to use of vfs_stat()
2016-05-18Merge branch 'work.iov_iter' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull iov_iter cleanups from Al Viro. * 'work.iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fold checks into iterate_and_advance() rw_verify_area(): saner calling conventions aio: remove a pointless assignment
2016-05-18Merge branch 'work.lookups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull parallel lookup fixups from Al Viro: "Fix for xfs parallel readdir (turns out the cxfs exposure was not enough to catch all problems), and a reversion of btrfs back to ->iterate() until the fs/btrfs/delayed-inode.c gets fixed" * 'work.lookups' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: xfs: concurrent readdir hangs on data buffer locks Revert "btrfs: switch to ->iterate_shared()"
2016-05-18xfs: concurrent readdir hangs on data buffer locksDave Chinner
There's a three-process deadlock involving shared/exclusive barriers and inverted lock orders in the directory readdir implementation. It's a pre-existing problem with lock ordering, exposed by the VFS parallelisation code. process 1 process 2 process 3 --------- --------- --------- readdir iolock(shared) get_leaf_dents iterate entries ilock(shared) map, lock and read buffer iunlock(shared) process entries in buffer ..... readdir iolock(shared) get_leaf_dents iterate entries ilock(shared) map, lock buffer <blocks> finish ->iterate_shared file_accessed() ->update_time start transaction ilock(excl) <blocks> ..... finishes processing buffer get next buffer ilock(shared) <blocks> And that's the deadlock. Fix this by dropping the current buffer lock in process 1 before trying to map the next buffer. This means we keep the lock order of ilock -> buffer lock intact and hence will allow process 3 to make progress and drop it's ilock(shared) once it is done. Reported-by: Xiong Zhou <xzhou@redhat.com> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-18Revert "btrfs: switch to ->iterate_shared()"Al Viro
This reverts commit 972b241f8441dc37a3f89dcd7e71d7f013873d13. Quoth Chris: didn't take the delayed inode stuff into account it got an rbtree of items and it pulls things out so in shared mode, its hugely racey sorry, lets revert and fix it for real inside of btrfs Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-18Merge branch 'sendmsg.cifs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull cifs iovec cleanups from Al Viro. * 'sendmsg.cifs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: cifs: don't bother with kmap on read_pages side cifs_readv_receive: use cifs_read_from_socket() cifs: no need to wank with copying and advancing iovec on recvmsg side either cifs: quit playing games with draining iovecs cifs: merge the hash calculation helpers
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull remaining vfs xattr work from Al Viro: "The rest of work.xattr (non-cifs conversions)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: btrfs: Switch to generic xattr handlers ubifs: Switch to generic xattr handlers jfs: Switch to generic xattr handlers jfs: Clean up xattr name mapping gfs2: Switch to generic xattr handlers ceph: kill __ceph_removexattr() ceph: Switch to generic xattr handlers ceph: Get rid of d_find_alias in ceph_set_acl
2016-05-18Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs updates from Steve French: "Various small CIFS and SMB3 fixes (including some for stable)" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: remove directory incorrectly tries to set delete on close on non-empty directories Update cifs.ko version to 2.09 fs/cifs: correctly to anonymous authentication for the NTLM(v2) authentication fs/cifs: correctly to anonymous authentication for the NTLM(v1) authentication fs/cifs: correctly to anonymous authentication for the LANMAN authentication fs/cifs: correctly to anonymous authentication via NTLMSSP cifs: remove any preceding delimiter from prefix_path cifs: Use file_dentry()
2016-05-18KVM: MTRR: remove MSR 0x2f8Andy Honig
MSR 0x2f8 accessed the 124th Variable Range MTRR ever since MTRR support was introduced by 9ba075a664df ("KVM: MTRR support"). 0x2f8 became harmful when 910a6aae4e2e ("KVM: MTRR: exactly define the size of variable MTRRs") shrinked the array of VR MTRRs from 256 to 8, which made access to index 124 out of bounds. The surrounding code only WARNs in this situation, thus the guest gained a limited read/write access to struct kvm_arch_vcpu. 0x2f8 is not a valid VR MTRR MSR, because KVM has/advertises only 16 VR MTRR MSRs, 0x200-0x20f. Every VR MTRR is set up using two MSRs, 0x2f8 was treated as a PHYSBASE and 0x2f9 would be its PHYSMASK, but 0x2f9 was not implemented in KVM, therefore 0x2f8 could never do anything useful and getting rid of it is safe. This fixes CVE-2016-3713. Fixes: 910a6aae4e2e ("KVM: MTRR: exactly define the size of variable MTRRs") Cc: stable@vger.kernel.org Reported-by: David Matlack <dmatlack@google.com> Signed-off-by: Andy Honig <ahonig@google.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18KVM: x86: make hwapic_isr_update and hwapic_irr_update look the samePaolo Bonzini
Neither APICv nor AVIC actually need the first argument of hwapic_isr_update, but the vCPU makes more sense than passing the pointer to the whole virtual machine! In fact in the APICv case it's just happening that the vCPU is used implicitly, through the loaded VMCS. The second argument instead is named differently, make it consistent. Reviewed-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18svm: Manage vcpu load/unload when enable AVICSuravee Suthikulpanit
When a vcpu is loaded/unloaded to a physical core, we need to update host physical APIC ID information in the Physical APIC-ID table accordingly. Also, when vCPU is blocking/un-blocking (due to halt instruction), we need to make sure that the is-running bit in set accordingly in the physical APIC-ID table. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Reviewed-by: Radim Krčmář <rkrcmar@redhat.com> [Return void from new functions, add WARN_ON when they returned negative errno; split load and put into separate function as they have almost nothing in common. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18svm: Do not intercept CR8 when enable AVICSuravee Suthikulpanit
When enable AVIC: * Do not intercept CR8 since this should be handled by AVIC HW. * Also, we don't need to sync cr8/V_TPR and APIC backing page. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> [Rename svm_in_nested_interrupt_shadow to svm_nested_virtualize_tpr. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18svm: Do not expose x2APIC when enable AVICSuravee Suthikulpanit
Since AVIC only virtualizes xAPIC hardware for the guest, this patch disable x2APIC support in guest CPUID. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18KVM: x86: Introducing kvm_x86_ops.apicv_post_state_restoreSuravee Suthikulpanit
Adding kvm_x86_ops hooks to allow APICv to do post state restore. This is required to support VM save and restore feature. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18svm: Add VMEXIT handlers for AVICSuravee Suthikulpanit
This patch introduces VMEXIT handlers, avic_incomplete_ipi_interception() and avic_unaccelerated_access_interception() along with two trace points (trace_kvm_avic_incomplete_ipi and trace_kvm_avic_unaccelerated_access). Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18svm: Add interrupt injection via AVICSuravee Suthikulpanit
This patch introduces a new mechanism to inject interrupt using AVIC. Since VINTR is not supported when enable AVIC, we need to inject interrupt via APIC backing page instead. This patch also adds support for AVIC doorbell, which is used by KVM to signal a running vcpu to check IRR for injected interrupts. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18KVM: x86: Detect and Initialize AVIC supportSuravee Suthikulpanit
This patch introduces AVIC-related data structure, and AVIC initialization code. There are three main data structures for AVIC: * Virtual APIC (vAPIC) backing page (per-VCPU) * Physical APIC ID table (per-VM) * Logical APIC ID table (per-VM) Currently, AVIC is disabled by default. Users can manually enable AVIC via kernel boot option kvm-amd.avic=1 or during kvm-amd module loading with parameter avic=1. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> [Avoid extra indentation (Boris). - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18svm: Introduce new AVIC VMCB registersSuravee Suthikulpanit
Introduce new AVIC VMCB registers. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18KVM: split kvm_vcpu_wake_up from kvm_vcpu_kickRadim Krčmář
AVIC has a use for kvm_vcpu_wake_up. Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Tested-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18KVM: x86: Introducing kvm_x86_ops VCPU blocking/unblocking hooksSuravee Suthikulpanit
Adding new function pointer in struct kvm_x86_ops, and calling them from the kvm_arch_vcpu[blocking/unblocking]. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18KVM: x86: Introducing kvm_x86_ops VM init/destroy hooksSuravee Suthikulpanit
Adding function pointers in struct kvm_x86_ops for processor-specific layer to provide hooks for when KVM initialize and destroy VM. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18KVM: x86: Rename kvm_apic_get_reg to kvm_lapic_get_regSuravee Suthikulpanit
Rename kvm_apic_get_reg to kvm_lapic_get_reg to be consistent with the existing kvm_lapic_set_reg counterpart. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18KVM: x86: Misc LAPIC changes to expose helper functionsSuravee Suthikulpanit
Exporting LAPIC utility functions and macros for re-use in SVM code. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Reviewed-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18KVM: shrink halt polling even more for invalid wakeupsChristian Borntraeger
commit 3491caf2755e ("KVM: halt_polling: provide a way to qualify wakeups during poll") added more aggressive shrinking of the polling interval if the wakeup did not match some criteria. This still allows to keep polling enabled if the polling time was smaller that the current max poll time (block_ns <= vcpu->halt_poll_ns). Performance measurement shows that even more aggressive shrinking (shrink polling on any invalid wakeup) reduces absolute and relative (to the workload) CPU usage even further. Cc: David Matlack <dmatlack@google.com> Cc: Wanpeng Li <kernellwp@gmail.com> Cc: Radim Krčmář <rkrcmar@redhat.com> CC: Paolo Bonzini <pbonzini@redhat.com> CC: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-18arc: axs103_smp: Fix CPU frequency to 100MHz for dual-coreAlexey Brodkin
The most recent release of AXS103 [v1.1] is proven to work at 100 MHz in dual-core mode so this change uses mentioned feature. For that we: * Update axc003_idu.dtsi with mention of really-used CPU clock freq * Remove clock override in AXS platform code for dual-core HW Note we're still leaving a hack for clock "downgrade" on early boot for quad-core hardware. Also note this change will break functionality of AXS103 v1.0 hardware. That means all users of AXS103 __must__ upgrade their boards with the most recent firmware. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2016-05-17Merge branch 'fixes' into miscJames Bottomley
2016-05-17Merge branch 'for-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: "Trivial changes except for special case timeout bumping. I have two more libata branches which depend on SCSI and dmaengine tree respectively. I'll send pull requests for them once the prerequisite trees are pulled in" * 'for-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: libata-scsi: use %*ph to dump small buffers treewide: Fix typos in libata.xml libata-core: Allow longer timeout for drive spinup from PUIS libata: Fixup awkward whitespace in warning by removing line continuation.
