The SoC-specific devfreq and devfreq-event drivers can be build tested
on all architectures.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
for_each_child_of_node() performs an of_node_put() on each iteration, so
putting an of_node_put() before a continue results in a double put.
Generated by: scripts/coccinelle/iterators/device_node_continue.cocci
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Pull x86 fix from Thomas Gleixner:
"A single fix for an AMD erratum so machines without a BIOS fix work"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/AMD: Apply erratum 665 on machines without a BIOS fix
Pull timer fixes from Thomas Gleixner:
"Two fixlet from the timers departement:
- A fix for scheduler stalls in the tick idle code affecting
NOHZ_FULL kernels
- A trivial compile fix"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tick/nohz: Fix softlockup on scheduler stalls in kvm guest
clocksource/drivers/atmel-pit: Fix compilation error
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper fixes from Mike Snitzer:
- a stable fix in both DM crypt and DM log-writes for too large bios
(as generated by bcache)
- two other stable fixes for DM log-writes
- a stable fix for a DM crypt bug that could result in freeing pointers
from uninitialized memory in the tfm allocation error path
- a DM bufio cleanup to discontinue using create_singlethread_workqueue()
* tag 'dm-4.8-fixes-4' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm bufio: remove use of deprecated create_singlethread_workqueue()
dm crypt: fix free of bad values after tfm allocation failure
dm crypt: fix error with too large bios
dm log writes: fix check of kthread_run() return value
dm log writes: fix bug with too large bios
dm log writes: move IO accounting earlier to fix error path
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"I'm still prepping a set of fixes for btrfs fsync, just nailing down a
hard to trigger memory corruption. For now, these are tested and ready."
* 'for-linus-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
btrfs: fix one bug that process may endlessly wait for ticket in wait_reserve_ticket()
Btrfs: fix endless loop in balancing block groups
Btrfs: kill invalid ASSERT() in process_all_refs()
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Catalin Marinas:
"arm64 and arm/perf fixes:
- arm64 fix: debug exception unmasking on the CPU resume path
- ARM PMU fixes: memory leak on error path and NULL pointer
dereference"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: kernel: Fix unmasked debug exceptions when restoring mdscr_el1
drivers/perf: arm_pmu: Fix NULL pointer dereference during probe
drivers/perf: arm_pmu: Fix leak in error path
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are a number of small driver fixes for 4.8-rc5.
The largest thing here is deleting an obsolete driver,
drivers/misc/bh1780gli.c, as the functionality of it was replaced by
an iio driver a while ago.
The other fixes are things that have been reported, or reverts of
broken stuff (the binder change). All of these changes have been in
linux-next for a while with no reported issues"
* tag 'char-misc-4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
thunderbolt: Don't declare Falcon Ridge unsupported
thunderbolt: Add support for INTEL_FALCON_RIDGE_2C controller.
thunderbolt: Fix resume quirk for Falcon Ridge 4C.
lkdtm: Mark lkdtm_rodata_do_nothing() notrace
mei: me: disable driver on SPT SPS firmware
Revert "android: binder: fix dangling pointer comparison"
drivers/iio/light/Kconfig: SENSORS_BH1780 cleanup
misc: delete bh1780 driver
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fixes from Greg KH:
"Here are three small fixes for 4.8-rc5.
One for sysfs, one for kernfs, and one documentation fix, all for
reported issues. All of these have been in linux-next for a while"
* tag 'driver-core-4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
sysfs: correctly handle read offset on PREALLOC attrs
documentation: drivers/core/of: fix name of of_node symlink
kernfs: don't depend on d_find_any_alias() when generating notifications
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging/IIO driver fixes from Greg KH:
"Here are a number of small fixes for staging and IIO drivers that
resolve reported problems.
Full details are in the shortlog. All of these have been in
linux-next with no reported issues"
* tag 'staging-4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (35 commits)
arm: dts: rockchip: add reset node for the exist saradc SoCs
arm64: dts: rockchip: add reset saradc node for rk3368 SoCs
iio: adc: rockchip_saradc: reset saradc controller before programming it
iio: accel: kxsd9: Fix raw read return
iio: adc: ti_am335x_adc: Increase timeout value waiting for ADC sample
iio: adc: ti_am335x_adc: Protect FIFO1 from concurrent access
include/linux: fix excess fence.h kernel-doc notation
staging: wilc1000: correctly check if associatedsta has not been found
staging: wilc1000: NULL dereference on error
staging: wilc1000: txq_event: Fix coding error
MAINTAINERS: Add file patterns for ion device tree bindings
MAINTAINERS: Update maintainer entry for wilc1000
iio: chemical: atlas-ph-sensor: fix typo in val assignment
iio: fix sched WARNING "do not call blocking ops when !TASK_RUNNING"
staging: comedi: ni_mio_common: fix AO inttrig backwards compatibility
staging: comedi: dt2811: fix a precedence bug
staging: comedi: adv_pci1760: Do not return EINVAL for CMDF_ROUND_DOWN.
staging: comedi: ni_mio_common: fix wrong insn_write handler
staging: comedi: comedi_test: fix timer race conditions
staging: comedi: daqboard2000: bug fix board type matching code
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull serial driver fixes from Greg KH:
"Here are some small serial driver fixes for 4.8-rc5. One fixes an
oft-reported build issue with the fintek driver, another reverts a
patch that was causing problems, one fixes a crash, and some new
device ids were added.
* tag 'tty-4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
serial: 8250: added acces i/o products quad and octal serial cards
serial: 8250_mid: fix divide error bug if baud rate is 0
Revert "tty/serial/8250: use mctrl_gpio helpers"
8250/fintek: rename IRQ_MODE macro
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB/PHY fixes from Greg KH:
"Here are some USB and PHY driver fixes for 4.8-rc5
Nothing major, lots of little fixes for reported bugs, and a build fix
for a missing .h file that the phy drivers needed. All of these have
been in linux-next for a while with no reported issues"
* tag 'usb-4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (24 commits)
usb: musb: Fix locking errors for host only mode
usb: dwc3: gadget: always decrement by 1
usb: dwc3: debug: fix ep name on trace output
usb: gadget: udc: core: don't starve DMA resources
USB: serial: option: add WeTelecom 0x6802 and 0x6803 products
USB: avoid left shift by -1
USB: fix typo in wMaxPacketSize validation
usb: gadget: Add the gserial port checking in gs_start_tx()
usb: dwc3: gadget: don't rely on jiffies while holding spinlock
usb: gadget: fsl_qe_udc: signedness bug in qe_get_frame()
usb: gadget: function: f_rndis: socket buffer may be NULL
usb: gadget: function: f_eem: socket buffer may be NULL
usb: renesas_usbhs: gadget: fix return value check in usbhs_mod_gadget_probe()
usb: dwc2: Add reset control to dwc2
usb: dwc3: core: allow device to runtime_suspend several times
usb: dwc3: pci: runtime_resume child device
USB: serial: option: add WeTelecom WM-D200
usb: chipidea: udc: don't touch DP when controller is in host mode
USB: serial: mos7840: fix non-atomic allocation in write path
USB: serial: mos7720: fix non-atomic allocation in write path
In commit 8ead9dd54716 ("devpts: more pty driver interface cleanups") I
made devpts_get_priv() just return the dentry->fs_data directly. And
because I thought it wouldn't happen, I added a warning if you ever saw
a pts node that wasn't on devpts.
And no, that warning never triggered under any actual real use, but you
can trigger it by creating nonsensical pts nodes by hand.
So just revert the warning, and make devpts_get_priv() return NULL for
that case like it used to.
Cc: stable@vger.kernel.org # 4.6+
Cc: Eric W Biederman" <ebiederm@xmission.com>
Pull block fixes from Jens Axboe:
"A collection of fixes for the nvme over fabrics code"
* 'for-linus' of git://git.kernel.dk/linux-block:
nvme-rdma: Get rid of redundant defines
nvme-rdma: Get rid of duplicate variable
nvme: fabrics drivers don't need the nvme-pci driver
nvme-fabrics: get a reference when reusing a nvme_host structure
nvme-fabrics: change NQN UUID to big-endian format
nvme-loop: set sqsize to 0-based value, per spec
nvme-rdma: fix sqsize/hsqsize per spec
fabrics: define admin sqsize min default, per spec
nvmet-rdma: +1 to *queue_size from hsqsize/hrqsize
nvmet-rdma: Fix use after free
nvme-rdma: initialize ret to zero to avoid returning garbage
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull TPM bugfix from James Morris.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
tpm: invalid self test error message
The driver emits invalid self test error message even though the init
succeeds.
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Fixes: cae8b441fc20 ("tpm: Factor out common startup code")
Reviewed-by: James Morris <james.l.morris@oracle.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Pull ACPI fixes ffrom Rafael Wysocki:
"Two stable-candidate fixes for the ACPI early device probing code
added during the 4.4 cycle, one fixing a typo in a stub macro used
when CONFIG_ACPI is unset and one that prevents sleeping functions
from being called under a spinlock (Lorenzo Pieralisi)"
* tag 'acpi-4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / drivers: replace acpi_probe_lock spinlock with mutex
ACPI / drivers: fix typo in ACPI_DECLARE_PROBE_ENTRY macro
Pull power management fixes from Rafael Wysocki:
"This includes a stable-candidate cpufreq-dt driver problem fix and
annotations of tracepoints in the runtime PM framework.
Specifics:
- Fix the definition of the cpufreq-dt driver's machines table
introduced during the 4.7 cycle that should be NULL-terminated, but
the termination entry is missing from it (Wei Yongjun).
- Annotate tracepoints in the runtime PM framework's core so as to
allow the functions containing them to be called from the idle code
path without causing RCU to complain about illegal usage (Paul
McKenney)"
* tag 'pm-4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM / runtime: Add _rcuidle suffix to allow rpm_idle() use from idle
PM / runtime: Add _rcuidle suffix to allow rpm_resume() to be called from idle
cpufreq: dt: Add terminate entry for of_device_id tables
* pm-cpufreq-fixes:
* pm-core-fixes:
Commit e647b532275b ("ACPI: Add early device probing infrastructure")
introduced code that allows inserting driver specific
struct acpi_probe_entry probe entries into ACPI linker sections
(one per-subsystem, eg irqchip, clocksource) that are then walked
to retrieve the data and function hooks required to probe the
respective kernel components.
Probing for all entries in a section is triggered through
the __acpi_probe_device_table() function, that in turn, according
to the table ID a given probe entry reports parses the table
with the function retrieved from the respective section structures
(ie struct acpi_probe_entry). Owing to the current ACPI table
parsing implementation, the __acpi_probe_device_table() function
has to share global variables with the acpi_match_madt() function, so
in order to guarantee mutual exclusion locking is required
between the two functions.
Current kernel code implements the locking through the acpi_probe_lock
spinlock; this has the side effect of requiring all code called
within the lock (ie struct acpi_probe_entry.probe_{table/subtbl} hooks)
not to sleep.
However, kernel subsystems that make use of the early probing
infrastructure are relying on kernel APIs that may sleep (eg
irq_domain_alloc_fwnode(), among others) in the function calls
pointed at by struct acpi_probe_entry.{probe_table/subtbl} entries
(eg gic_v2_acpi_init()), which is a bug.
Since __acpi_probe_device_table() is called from context
that is allowed to sleep the acpi_probe_lock spinlock can be replaced
with a mutex; this fixes the issue whilst still guaranteeing
mutual exclusion.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Fixes: e647b532275b (ACPI: Add early device probing infrastructure)
Cc: 4.4+ <stable@vger.kernel.org> # 4.4+
When the ACPI_DECLARE_PROBE_ENTRY macro was added in
commit e647b532275b ("ACPI: Add early device probing infrastructure"),
a stub macro adding an unused entry was added for the !CONFIG_ACPI
Kconfig option case to make sure kernel code making use of the
macro did not require to be guarded within CONFIG_ACPI in order to
be compiled.
The stub macro was never used since all kernel code that defines
ACPI_DECLARE_PROBE_ENTRY entries is currently guarded within
CONFIG_ACPI; it contains a typo that should be nonetheless fixed.
Fix the typo in the stub (ie !CONFIG_ACPI) ACPI_DECLARE_PROBE_ENTRY()
macro so that it can actually be used if needed.
AMD F12h machines have an erratum which can cause DIV/IDIV to behave
unpredictably. The workaround is to set MSRC001_1029[31] but sometimes
there is no BIOS update containing that workaround so let's do it
ourselves unconditionally. It is simple enough.
[ Borislav: Wrote commit message. ]
Signed-off-by: Emanuel Czirai <icanrealizeum@gmail.com>
Cc: Yaowu Xu <yaowu@google.com>
Link: http://lkml.kernel.org/r/20160902053550.18097-1-bp@alien8.de
Łukasz Daniluk reported that on a RHEL kernel that his machine would lock up
after enabling function tracer. I asked him to bisect the functions within
available_filter_functions, which he did and it came down to three:
_paravirt_nop(), _paravirt_ident_32() and _paravirt_ident_64()
It was found that this is only an issue when noreplace-paravirt is added
to the kernel command line.
This means that those functions are most likely called within critical
sections of the funtion tracer, and must not be traced.
In newer kenels _paravirt_nop() is defined within gcc asm(), and is no
longer an issue. But both _paravirt_ident_{32,64}() causes the
following splat when they are traced:
mm/pgtable-generic.c:33: bad pmd ffff8800d2435150(0000000001d00054)
mm/pgtable-generic.c:33: bad pmd ffff8800d3624190(0000000001d00070)
mm/pgtable-generic.c:33: bad pmd ffff8800d36a5110(0000000001d00054)
mm/pgtable-generic.c:33: bad pmd ffff880118eb1450(0000000001d00054)
NMI watchdog: BUG: soft lockup - CPU#2 stuck for 22s! [systemd-journal:469]
Modules linked in: e1000e
CPU: 2 PID: 469 Comm: systemd-journal Not tainted 4.6.0-rc4-test+ #513
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012
task: ffff880118f740c0 ti: ffff8800d4aec000 task.ti: ffff8800d4aec000
RIP: 0010:[<ffffffff81134148>] [<ffffffff81134148>] queued_spin_lock_slowpath+0x118/0x1a0
RSP: 0018:ffff8800d4aefb90 EFLAGS: 00000246
RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff88011eb16d40
RDX: ffffffff82485760 RSI: 000000001f288820 RDI: ffffea0000008030
RBP: ffff8800d4aefb90 R08: 00000000000c0000 R09: 0000000000000000
R10: ffffffff821c8e0e R11: 0000000000000000 R12: ffff880000200fb8
R13: 00007f7a4e3f7000 R14: ffffea000303f600 R15: ffff8800d4b562e0
FS: 00007f7a4e3d7840(0000) GS:ffff88011eb00000(0000) knlGS:0000000000000000
CR2: 00007f7a4e3f7000 CR3: 00000000d3e71000 CR4: 00000000001406e0
Call Trace:
_raw_spin_lock+0x27/0x30
handle_pte_fault+0x13db/0x16b0
handle_mm_fault+0x312/0x670
__do_page_fault+0x1b1/0x4e0
do_page_fault+0x22/0x30
page_fault+0x28/0x30
__vfs_read+0x28/0xe0
vfs_read+0x86/0x130
SyS_read+0x46/0xa0
entry_SYSCALL_64_fastpath+0x1e/0xa8
Code: 12 48 c1 ea 0c 83 e8 01 83 e2 30 48 98 48 81 c2 40 6d 01 00 48 03 14 c5 80 6a 5d 82 48 89 0a 8b 41 08 85 c0 75 09 f3 90 8b 41 08 <85> c0 74 f7 4c 8b 09 4d 85 c9 74 08 41 0f 18 09 eb 02 f3 90 8b
Reported-by: Łukasz Daniluk <lukasz.daniluk@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull overlayfs fixes from Miklos Szeredi:
"Most of this is regression fixes for posix acl behavior introduced in
4.8-rc1 (these were caught by the pjd-fstest suite). The are also
miscellaneous fixes marked as stable material and cleanups.
Other than overlayfs code, it touches <linux/fs.h> to add a constant
with which to disable posix acl caching. No changes needed to the
actual caching code, it automatically does the right thing, although
later we may want to optimize this case.
I'm now testing overlayfs with the following test suites to catch
regressions:
- unionmount-testsuite
- xfstests
- pjd-fstest"
* 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ovl: update doc
ovl: listxattr: use strnlen()
ovl: Switch to generic_getxattr
ovl: copyattr after setting POSIX ACL
ovl: Switch to generic_removexattr
ovl: Get rid of ovl_xattr_noacl_handlers array
ovl: Fix OVL_XATTR_PREFIX
ovl: fix spelling mistake: "directries" -> "directories"
ovl: don't cache acl on overlay layer
ovl: use cached acl on underlying layer
ovl: proper cleanup of workdir
ovl: remove posix_acl_default from workdir
ovl: handle umask and posix_acl_default correctly on creation
ovl: don't copy up opaqueness
Changes to make the resume from cpu_suspend() code behave more like
secondary boot caused debug exceptions to be unmasked early by
__cpu_setup(). We then go on to restore mdscr_el1 in cpu_do_resume(),
potentially taking break or watch points based on uninitialised registers.
Mask debug exceptions in cpu_do_resume(), which is specific to resume
from cpu_suspend(). Debug exceptions will be restored to their original
state by local_dbg_restore() in cpu_suspend(), which runs after
hw_breakpoint_restore() has re-initialised the other registers.
Reported-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Fixes: cabe1c81ea5b ("arm64: Change cpu_resume() to enable mmu early then access sleep_sp by va")
Cc: <stable@vger.kernel.org> # 4.7+
Signed-off-by: James Morse <james.morse@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Patch 7f1d642fbb5c ("drivers/perf: arm-pmu: Fix handling of SPI lacking
interrupt-affinity property") unintended also fixes perf_event support
for bcm2835 which doesn't have PMU interrupts. Unfortunately this change
introduce a NULL pointer dereference on bcm2835, because irq_is_percpu
always expected to be called with a valid IRQ. So fix this regression
by validating the IRQ before.
Tested-by: Kevin Hilman <khilman@baylibre.com>
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Fixes: 7f1d642fbb5c ("drivers/perf: arm-pmu: Fix handling of SPI lacking "interrupt-affinity" property")
In case of a IRQ type mismatch in of_pmu_irq_cfg() the
device node for interrupt affinity isn't freed. So fix this
issue by calling of_node_put().
Fixes: fa8ad7889d83 ("arm: perf: factor arm_pmu core out to drivers")
git://git.infradead.org/users/vkoul/slave-dma
Pull dmaengine fixes from Vinod Koul:
"The fixes this time are all in drivers:
- possible NULL dereference in img-mdc
- correct device identity for free_irq in at_xdmac
- missing of_node_put() in fsl probe
- fix debug log and hotchain corner case for pxa-dma
- fix checking hardware bits in isr in usb dmac"
* tag 'dmaengine-fix-4.8-rc5' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: img-mdc: fix a possible NULL dereference
dmaengine: at_xdmac: fix to pass correct device identity to free_irq()
dmaengine: fsl_raid: add missing of_node_put() in fsl_re_probe()
dmaengine: pxa_dma: fix debug message
dmaengine: pxa_dma: fix hotchain corner case
dmaengine: usb-dmac: check CHCR.DE bit in usb_dmac_isr_channel()
Pull drm fixes from Dave Airlie:
"Contains fixes for imx, amdgpu, vc4, msm and one nouveau ACPI fix"
* tag 'drm-fixes-for-4.8-rc5' of git://people.freedesktop.org/~airlied/linux:
drm/amdgpu: record error code when ring test failed
drm/amd/amdgpu: compute ring test fail during S4 on CI
drm/amd/amdgpu: sdma resume fail during S4 on CI
drm/nouveau/acpi: use DSM if bridge does not support D3cold
drm/imx: fix crtc vblank state regression
drm/imx: Add active plane reconfiguration support
drm/msm: protect against faults from copy_from_user() in submit ioctl
drm/msm: fix use of copy_from_user() while holding spinlock
drm/vc4: Fix oops when userspace hands in a bad BO.
drm/vc4: Fix overflow mem unreferencing when the binner runs dry.
drm/vc4: Free hang state before destroying BO cache.
drm/vc4: Fix handling of a pm_runtime_get_sync() success case.
drm/vc4: Use drm_malloc_ab to fix large rendering jobs.
drm/vc4: Use drm_free_large() on handles to match its allocation.
tick_nohz_start_idle() is prevented to be called if the idle tick can't
be stopped since commit 1f3b0f8243cb934 ("tick/nohz: Optimize nohz idle
enter"). As a result, after suspend/resume the host machine, full dynticks
kvm guest will softlockup:
NMI watchdog: BUG: soft lockup - CPU#0 stuck for 26s! [swapper/0:0]
Call Trace:
default_idle+0x31/0x1a0
arch_cpu_idle+0xf/0x20
default_idle_call+0x2a/0x50
cpu_startup_entry+0x39b/0x4d0
rest_init+0x138/0x140
? rest_init+0x5/0x140
start_kernel+0x4c1/0x4ce
? set_init_arg+0x55/0x55
? early_idt_handler_array+0x120/0x120
x86_64_start_reservations+0x24/0x26
x86_64_start_kernel+0x142/0x14f
In addition, cat /proc/stat | grep cpu in guest or host:
cpu 398 16 5049 15754 5490 0 1 46 0 0
cpu0 206 5 450 0 0 0 1 14 0 0
cpu1 81 0 3937 3149 1514 0 0 9 0 0
cpu2 45 6 332 6052 2243 0 0 11 0 0
cpu3 65 2 328 6552 1732 0 0 11 0 0
The idle and iowait states are weird 0 for cpu0(housekeeping).
The bug is present in both guest and host kernels, and they both have
cpu0's idle and iowait states issue, however, host kernel's suspend/resume
path etc will touch watchdog to avoid the softlockup.
- The watchdog will not be touched in tick_nohz_stop_idle path (need be
touched since the scheduler stall is expected) if idle_active flags are
not detected.
- The idle and iowait states will not be accounted when exit idle loop
(resched or interrupt) if idle start time and idle_active flags are
not set.
This patch fixes it by reverting commit 1f3b0f8243cb934 since can't stop
idle tick doesn't mean can't be idle.
Fixes: 1f3b0f8243cb934 ("tick/nohz: Optimize nohz idle enter")
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Sanjeev Yadav<sanjeev.yadav@spreadtrum.com>
Cc: Gaurav Jindal<gaurav.jindal@spreadtrum.com>
Cc: kvm@vger.kernel.org
Cc: Radim Krčmář <rkrcmar@redhat.com>
Link: http://lkml.kernel.org/r/1472798303-4154-1-git-send-email-wanpeng.li@hotmail.com
drm-fixes
This pull request brings in fixes for VC4 3D in 4.8, most of which are
covered by testcases.
* tag 'drm-vc4-fixes-2016-08-29' of https://github.com/anholt/linux:
git://git.pengutronix.de/git/pza/linux into drm-fixes
imx-drm atomic modeset regression fixes
- add active plane reconfiguration support
- add back crtc vblank state reporting
* tag 'imx-drm-fixes-2016-08-30' of git://git.pengutronix.de/git/pza/linux:
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk fixes from Stephen Boyd:
"A collection of small fixes for various SoC vendor clk drivers"
* tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux:
clk: rockchip: mark aclk_emmc_noc as a critical clock on rk3399
clk: tegra: remove TEGRA_PLL_USE_LOCK for PLLD/PLLD2
clk: rockchip: fix incorrect GATE bits for {c, g}pll_aclk_perihp_src on rk3399
clk: rockchip: fix incorrect aclk_emmc source gate bits on rk3399
clk: renesas: r8a7795: Fix SD clocks
clk: rockchip: fix rk3399 aclk_vio gate bit
clk: sunxi-ng: Fix inverted test condition in ccu_helper_wait_for_lock
Merge fixes from Andrew Morton:
"14 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
rapidio/tsi721: fix incorrect detection of address translation condition
rapidio/documentation/mport_cdev: add missing parameter description
kernel/fork: fix CLONE_CHILD_CLEARTID regression in nscd
MAINTAINERS: Vladimir has moved
mm, mempolicy: task->mempolicy must be NULL before dropping final reference
printk/nmi: avoid direct printk()-s from __printk_nmi_flush()
treewide: remove references to the now unnecessary DEFINE_PCI_DEVICE_TABLE
drivers/scsi/wd719x.c: remove last declaration using DEFINE_PCI_DEVICE_TABLE
mm, vmscan: only allocate and reclaim from zones with pages managed by the buddy allocator
lib/test_hash.c: fix warning in preprocessor symbol evaluation
lib/test_hash.c: fix warning in two-dimensional array init
kconfig: tinyconfig: provide whole choice blocks to avoid warnings
kexec: fix double-free when failing to relocate the purgatory
mm, oom: prevent premature OOM killer invocation for high order request
Fix incorrect condition to identify involvment of a address translation
mechanism.
This bug results in NULL pointer kernel crash dump in cases when mapping
of inbound RapidIO address range is requested within existing aprture.
Link: http://lkml.kernel.org/r/20160901173144.2983-1-alexandre.bounine@idt.com
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com>
Cc: Barry Wood <barry.wood@idt.com>
Cc: <stable@vger.kernel.org> [4.6+]
Add missing description for rio_mport_cdev driver parameter
'dma_timeout'.
This patch is applicable to kernel versions starting from v4.6.
Link: http://lkml.kernel.org/r/20160901173104.2928-1-alexandre.bounine@idt.com
Commit fec1d0115240 ("[PATCH] Disable CLONE_CHILD_CLEARTID for abnormal
exit") has caused a subtle regression in nscd which uses
CLONE_CHILD_CLEARTID to clear the nscd_certainly_running flag in the
shared databases, so that the clients are notified when nscd is
restarted. Now, when nscd uses a non-persistent database, clients that
have it mapped keep thinking the database is being updated by nscd, when
in fact nscd has created a new (anonymous) one (for non-persistent
databases it uses an unlinked file as backend).
The original proposal for the CLONE_CHILD_CLEARTID change claimed
(https://lkml.org/lkml/2006/10/25/233):
: The NPTL library uses the CLONE_CHILD_CLEARTID flag on clone() syscalls
: on behalf of pthread_create() library calls. This feature is used to
: request that the kernel clear the thread-id in user space (at an address
: provided in the syscall) when the thread disassociates itself from the
: address space, which is done in mm_release().
: Unfortunately, when a multi-threaded process incurs a core dump (such as
: from a SIGSEGV), the core-dumping thread sends SIGKILL signals to all of
: the other threads, which then proceed to clear their user-space tids
: before synchronizing in exit_mm() with the start of core dumping. This
: misrepresents the state of process's address space at the time of the
: SIGSEGV and makes it more difficult for someone to debug NPTL and glibc
: problems (misleading him/her to conclude that the threads had gone away
: before the fault).
: The fix below is to simply avoid the CLONE_CHILD_CLEARTID action if a
: core dump has been initiated.
The resulting patch from Roland (https://lkml.org/lkml/2006/10/26/269)
seems to have a larger scope than the original patch asked for. It
seems that limitting the scope of the check to core dumping should work
for SIGSEGV issue describe above.
[Changelog partly based on Andreas' description]
Fixes: fec1d0115240 ("[PATCH] Disable CLONE_CHILD_CLEARTID for abnormal exit")
Link: http://lkml.kernel.org/r/1471968749-26173-1-git-send-email-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Tested-by: William Preston <wpreston@suse.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Roland McGrath <roland@hack.frob.com>
Cc: Andreas Schwab <schwab@suse.com>
vdavydov@{parallels,virtuozzo}.com will bounce from now on.
Link: http://lkml.kernel.org/r/20160831180752.GB10353@esperanza
Signed-off-by: Vladimir Davydov <vdavydov.dev@gmail.com>
KASAN allocates memory from the page allocator as part of
kmem_cache_free(), and that can reference current->mempolicy through any
number of allocation functions. It needs to be NULL'd out before the
final reference is dropped to prevent a use-after-free bug:
BUG: KASAN: use-after-free in alloc_pages_current+0x363/0x370 at addr ffff88010b48102c
CPU: 0 PID: 15425 Comm: trinity-c2 Not tainted 4.8.0-rc2+ #140
Call Trace:
dump_stack
kasan_object_err
kasan_report_error
__asan_report_load2_noabort
alloc_pages_current <-- use after free
depot_save_stack
save_stack
kasan_slab_free
kmem_cache_free
__mpol_put <-- free
do_exit
This patch sets current->mempolicy to NULL before dropping the final
reference.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1608301442180.63329@chino.kir.corp.google.com
Fixes: cd11016e5f52 ("mm, kasan: stackdepot implementation. Enable stackdepot for SLAB")
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
__printk_nmi_flush() can be called from nmi_panic(), therefore it has to
test whether it's executed in NMI context and thus must route the
messages through deferred printk() or via direct printk().
This is to avoid potential deadlocks, as described in commit
cf9b1106c81c ("printk/nmi: flush NMI messages on the system panic").
However there remain two places where __printk_nmi_flush() does
unconditional direct printk() calls:
- pr_err("printk_nmi_flush: internal error ...")
- pr_cont("\n")
Factor out print_nmi_seq_line() parts into a new printk_nmi_flush_line()
function, which takes care of in_nmi(), and use it in
__printk_nmi_flush() for printing and error-reporting.
Link: http://lkml.kernel.org/r/20160830161354.581-1-sergey.senozhatsky@gmail.com
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Jan Kara <jack@suse.cz>
It's been eliminated from the sources, remove it from everywhere else.
Link: http://lkml.kernel.org/r/076eff466fd7edb550c25c8b25d76924ca0eba62.1472660229.git.joe@perches.com
Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Andy Whitcroft <apw@canonical.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Convert it to the preferred const struct pci_device_id instead.
Link: http://lkml.kernel.org/r/95c5e4100c3cd4eda643624f5b70e8d7abceb86c.1472660229.git.joe@perches.com
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
buddy allocator
Firmware Assisted Dump (FA_DUMP) on ppc64 reserves substantial amounts
of memory when booting a secondary kernel. Srikar Dronamraju reported
that multiple nodes may have no memory managed by the buddy allocator
but still return true for populated_zone().
Commit 1d82de618ddd ("mm, vmscan: make kswapd reclaim in terms of
nodes") was reported to cause kswapd to spin at 100% CPU usage when
fadump was enabled. The old code happened to deal with the situation of
a populated node with zero free pages by co-incidence but the current
code tries to reclaim populated zones without realising that is
impossible.
We cannot just convert populated_zone() as many existing users really
need to check for present_pages. This patch introduces a managed_zone()
helper and uses it in the few cases where it is critical that the check
is made for managed pages -- zonelist construction and page reclaim.
Link: http://lkml.kernel.org/r/20160831195104.GB8119@techsingularity.net
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Some versions of gcc don't like tests for the value of an undefined
preprocessor symbol, even in the #else branch of an #ifndef:
lib/test_hash.c:224:7: warning: "HAVE_ARCH__HASH_32" is not defined [-Wundef]
#elif HAVE_ARCH__HASH_32 != 1
lib/test_hash.c:229:7: warning: "HAVE_ARCH_HASH_32" is not defined [-Wundef]
#elif HAVE_ARCH_HASH_32 != 1
lib/test_hash.c:234:7: warning: "HAVE_ARCH_HASH_64" is not defined [-Wundef]
#elif HAVE_ARCH_HASH_64 != 1
Seen with gcc 4.9, not seen with 4.1.2.
Change the logic to only check the value inside an #ifdef to fix this.
Fixes: 468a9428521e7d00 ("<linux/hash.h>: Add support for architecture-specific functions")
Link: http://lkml.kernel.org/r/20160829214952.1334674-4-arnd@arndb.de
Acked-by: George Spelvin <linux@sciencehorizons.net>
lib/test_hash.c: In function 'test_hash_init':
lib/test_hash.c:146:2: warning: missing braces around initializer [-Wmissing-braces]
Link: http://lkml.kernel.org/r/20160829214952.1334674-3-arnd@arndb.de
Using "make tinyconfig" produces a couple of annoying warnings that show
up for build test machines all the time:
.config:966:warning: override: NOHIGHMEM changes choice state
.config:965:warning: override: SLOB changes choice state
.config:963:warning: override: KERNEL_XZ changes choice state
.config:962:warning: override: CC_OPTIMIZE_FOR_SIZE changes choice state
.config:933:warning: override: SLOB changes choice state
.config:930:warning: override: CC_OPTIMIZE_FOR_SIZE changes choice state
.config:870:warning: override: SLOB changes choice state
.config:868:warning: override: KERNEL_XZ changes choice state
.config:867:warning: override: CC_OPTIMIZE_FOR_SIZE changes choice state
I've made a previous attempt at fixing them and we discussed a number of
alternatives.
I tried changing the Makefile to use "merge_config.sh -n
$(fragment-list)" but couldn't get that to work properly.
This is yet another approach, based on the observation that we do want
to see a warning for conflicting 'choice' options, and that we can
simply make them non-conflicting by listing all other options as
disabled. This is a trivial patch that we can apply independent of
plans for other changes.
Link: http://lkml.kernel.org/r/20160829214952.1334674-2-arnd@arndb.de
Link: https://storage.kernelci.org/mainline/v4.7-rc6/x86-tinyconfig/build.log
https://patchwork.kernel.org/patch/9212749/
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
If kexec_apply_relocations fails, kexec_load_purgatory frees pi->sechdrs
and pi->purgatory_buf. This is redundant, because in case of error
kimage_file_prepare_segments calls kimage_file_post_load_cleanup, which
will also free those buffers.
This causes two warnings like the following, one for pi->sechdrs and the
other for pi->purgatory_buf:
kexec-bzImage64: Loading purgatory failed
WARNING: CPU: 1 PID: 2119 at mm/vmalloc.c:1490 __vunmap+0xc1/0xd0
Trying to vfree() nonexistent vm area (ffffc90000e91000)
Modules linked in:
CPU: 1 PID: 2119 Comm: kexec Not tainted 4.8.0-rc3+ #5
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x4d/0x65
__warn+0xcb/0xf0
warn_slowpath_fmt+0x4f/0x60
? find_vmap_area+0x19/0x70
? kimage_file_post_load_cleanup+0x47/0xb0
__vunmap+0xc1/0xd0
vfree+0x2e/0x70
kimage_file_post_load_cleanup+0x5e/0xb0
SyS_kexec_file_load+0x448/0x680
? putname+0x54/0x60
? do_sys_open+0x190/0x1f0
entry_SYSCALL_64_fastpath+0x13/0x8f
---[ end trace 158bb74f5950ca2b ]---
Fix by setting pi->sechdrs an pi->purgatory_buf to NULL, since vfree
won't try to free a NULL pointer.
Link: http://lkml.kernel.org/r/1472083546-23683-1-git-send-email-bauerman@linux.vnet.ibm.com
Signed-off-by: Thiago Jung Bauermann <bauerman@linux.vnet.ibm.com>
Acked-by: Baoquan He <bhe@redhat.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Dave Young <dyoung@redhat.com>
There have been several reports about pre-mature OOM killer invocation
in 4.7 kernel when order-2 allocation request (for the kernel stack)
invoked OOM killer even during basic workloads (light IO or even kernel
compile on some filesystems). In all reported cases the memory is
fragmented and there are no order-2+ pages available. There is usually
a large amount of slab memory (usually dentries/inodes) and further
debugging has shown that there are way too many unmovable blocks which
are skipped during the compaction. Multiple reporters have confirmed
that the current linux-next which includes [1] and [2] helped and OOMs
are not reproducible anymore.
A simpler fix for the late rc and stable is to simply ignore the
compaction feedback and retry as long as there is a reclaim progress and
we are not getting OOM for order-0 pages. We already do that for
CONFING_COMPACTION=n so let's reuse the same code when compaction is
enabled as well.
[1] http://lkml.kernel.org/r/20160810091226.6709-1-vbabka@suse.cz
[2] http://lkml.kernel.org/r/f7a9ea9d-bb88-bfd6-e340-3a933559305a@suse.cz
Fixes: 0a0337e0d1d1 ("mm, oom: rework oom detection")
Link: http://lkml.kernel.org/r/20160823074339.GB23577@dhcp22.suse.cz
Tested-by: Olaf Hering <olaf@aepfle.de>
Tested-by: Ralf-Peter Rohbeck <Ralf-Peter.Rohbeck@quantum.com>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Cc: Ralf-Peter Rohbeck <Ralf-Peter.Rohbeck@quantum.com>
Cc: Jiri Slaby <jslaby@suse.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: <stable@vger.kernel.org> [4.7.x]
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux into for-linus-4.8
