2006-12-08[PATCH] struct path: convert ipcJosef Sipek
2006-12-08[PATCH] struct path: convert infinibandJosef Sipek
2006-12-08[PATCH] struct path: convert ieee1394Josef Sipek
2006-12-08[PATCH] struct path: convert ia64Josef Sipek
2006-12-08[PATCH] struct path: convert i2c-driversJosef Sipek
2006-12-08[PATCH] struct path: convert hugetlbfsJosef Sipek
2006-12-08[PATCH] struct path: convert hppfsJosef Sipek
2006-12-08[PATCH] struct path: convert hpfsJosef Sipek
2006-12-08[PATCH] struct path: convert hostfsJosef Sipek
2006-12-08[PATCH] struct path: convert hfsplusJosef Sipek
2006-12-08[PATCH] struct path: convert hfsJosef Sipek
2006-12-08[PATCH] struct path: convert gfs2Josef Sipek
2006-12-08[PATCH] struct path: convert fuseJosef Sipek
2006-12-08[PATCH] struct path: convert frvJosef Sipek
2006-12-08[PATCH] struct path: convert freevxfsJosef Sipek
2006-12-08[PATCH] struct path: convert efsJosef Sipek
2006-12-08[PATCH] struct path: convert drmJosef Sipek
2006-12-08[PATCH] struct path: convert crisJosef Sipek
2006-12-08[PATCH] struct path: convert cramfsJosef Sipek
2006-12-08[PATCH] struct path: convert cosaJosef Sipek
2006-12-08[PATCH] struct path: convert codaJosef Sipek
2006-12-08[PATCH] struct path: convert char-driversJosef Sipek
2006-12-08[PATCH] struct path: convert block_driversJosef Sipek
2006-12-08[PATCH] struct path: convert blockJosef Sipek
2006-12-08[PATCH] struct path: convert bfsJosef Sipek
2006-12-08[PATCH] struct path: convert befsJosef Sipek
2006-12-08[PATCH] struct path: convert atmJosef Sipek
2006-12-08[PATCH] struct path: convert alphaJosef Sipek
2006-12-08[PATCH] struct path: convert afsJosef Sipek
2006-12-08[PATCH] struct path: convert adfsJosef Sipek
2006-12-08[PATCH] xfs: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the xfs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] ecryptfs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ecryptfs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] cifs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the cifs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] configfs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the configfs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] autofs4: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the autofs4 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] autofs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the autofs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] affs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the affs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] 9p: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the 9p filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] mm: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in linux/mm/. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] kernel: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in linux/kernel/. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] x86_64: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the x86_64 arch code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] i386: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the i386 arch code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] ntfs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ntfs filesystem code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] nfsd: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs server code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] nfs: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs client code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] isofs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the isofs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fat: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the fat filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] ext4: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ext4 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] ext3: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ext3 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] ext2: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ext2 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
