Signed-off-by: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1370643734-9579-3-git-send-email-dsahern@gmail.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Header files of libtraceevent or no longer local headers. Thus, use
default path notation for them. Also removing extra traceevent include
path and instead handle this similar to liblk.
Signed-off-by: Robert Richter <robert.richter@linaro.org>
Signed-off-by: Robert Richter <rric@kernel.org>
Cc: Robert Richter <rric@kernel.org>
Link: http://lkml.kernel.org/r/1370964558-8599-1-git-send-email-rric@kernel.org
Making TEST_ASSERT_VAL global as it's used in multiple objects.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1370612223-19188-3-git-send-email-jolsa@redhat.com
Omitting end of the function check failure for test 1, since there's no
way to get exact symbol end via kallsyms.
Leaving the debug message.
Link: http://lkml.kernel.org/r/1370612223-19188-2-git-send-email-jolsa@redhat.com
Removing 'cwd' from perf_session struct as it's no longer needed.
Link: http://lkml.kernel.org/r/1370612223-19188-1-git-send-email-jolsa@redhat.com
perf: Add objdump option to 'perf top'
Like with 'perf annotate' add the --objdump option to perf top so users
can specify an alternate path to the /usr/bin/objdump binary.
Reported-by: David A. Gilbert <DavidAGilbert@uk.ibm.com>
Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Cc: DavidAGilbert@uk.ibm.com
Cc: Maynard Johnson <mpjohn@us.ibm.com>
Link: http://lkml.kernel.org/r/20130515055651.GA9985@us.ibm.com
The CPU map is in an "empty" (or not-applicable) state when monitoring
specific threads.
cpu_map__all() returns true if the CPU map is in this empty state (i.e
for the 'empty_cpu_map' or if we created the map via
cpu_map__dummy_new().
The name, cpu_map__all(), is misleading, because even when monitoring
all CPUs, (eg: perf record -a), cpu_map__all() returns false.
Rename cpu_map__all() to cpu_map__empty().
Link: http://lkml.kernel.org/r/20130523012620.GA27733@us.ibm.com
It gives the following benefits:
- only one function pointer is passed along the way
- the 'match' function is called within output function
and could be inlined by the compiler
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1373388991-9711-1-git-send-email-jolsa@redhat.com
Jiri managed to trigger this warning:
[] [ INFO: possible circular locking dependency detected ]
[] 3.10.0+ #228 Tainted: G W
[] p/6613 is trying to acquire lock:
[] (rcu_node_0){..-...}, at: [<ffffffff810ca797>] rcu_read_unlock_special+0xa7/0x250
[] but task is already holding lock:
[] (&ctx->lock){-.-...}, at: [<ffffffff810f2879>] perf_lock_task_context+0xd9/0x2c0
[] which lock already depends on the new lock.
[] the existing dependency chain (in reverse order) is:
[] -> #4 (&ctx->lock){-.-...}:
[] -> #3 (&rq->lock){-.-.-.}:
[] -> #2 (&p->pi_lock){-.-.-.}:
[] -> #1 (&rnp->nocb_gp_wq[1]){......}:
[] -> #0 (rcu_node_0){..-...}:
Paul was quick to explain that due to preemptible RCU we cannot call
rcu_read_unlock() while holding scheduler (or nested) locks when part
of the read side critical section was preemptible.
Therefore solve it by making the entire RCU read side non-preemptible.
Also pull out the retry from under the non-preempt to play nice with RT.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Helped-out-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: <stable@kernel.org>
The '!ctx->is_active' check has a valid scenario, so
there's no need for the warning.
The reason is that there's a time window between the
'ctx->is_active' check in the perf_event_enable() function
and the __perf_event_enable() function having:
- IRQs on
- ctx->lock unlocked
where the task could be killed and 'ctx' deactivated by
perf_event_exit_task(), ending up with the warning below.
So remove the WARN_ON_ONCE() check and add comments to
explain it all.
This addresses the following warning reported by Vince Weaver:
[ 324.983534] ------------[ cut here ]------------
[ 324.984420] WARNING: at kernel/events/core.c:1953 __perf_event_enable+0x187/0x190()
[ 324.984420] Modules linked in:
[ 324.984420] CPU: 19 PID: 2715 Comm: nmi_bug_snb Not tainted 3.10.0+ #246
[ 324.984420] Hardware name: Supermicro X8DTN/X8DTN, BIOS 4.6.3 01/08/2010
[ 324.984420] 0000000000000009 ffff88043fce3ec8 ffffffff8160ea0b ffff88043fce3f00
[ 324.984420] ffffffff81080ff0 ffff8802314fdc00 ffff880231a8f800 ffff88043fcf7860
[ 324.984420] 0000000000000286 ffff880231a8f800 ffff88043fce3f10 ffffffff8108103a
[ 324.984420] Call Trace:
[ 324.984420] <IRQ> [<ffffffff8160ea0b>] dump_stack+0x19/0x1b
[ 324.984420] [<ffffffff81080ff0>] warn_slowpath_common+0x70/0xa0
[ 324.984420] [<ffffffff8108103a>] warn_slowpath_null+0x1a/0x20
[ 324.984420] [<ffffffff81134437>] __perf_event_enable+0x187/0x190
[ 324.984420] [<ffffffff81130030>] remote_function+0x40/0x50
[ 324.984420] [<ffffffff810e51de>] generic_smp_call_function_single_interrupt+0xbe/0x130
[ 324.984420] [<ffffffff81066a47>] smp_call_function_single_interrupt+0x27/0x40
[ 324.984420] [<ffffffff8161fd2f>] call_function_single_interrupt+0x6f/0x80
[ 324.984420] <EOI> [<ffffffff816161a1>] ? _raw_spin_unlock_irqrestore+0x41/0x70
[ 324.984420] [<ffffffff8113799d>] perf_event_exit_task+0x14d/0x210
[ 324.984420] [<ffffffff810acd04>] ? switch_task_namespaces+0x24/0x60
[ 324.984420] [<ffffffff81086946>] do_exit+0x2b6/0xa40
[ 324.984420] [<ffffffff8161615c>] ? _raw_spin_unlock_irq+0x2c/0x30
[ 324.984420] [<ffffffff81087279>] do_group_exit+0x49/0xc0
[ 324.984420] [<ffffffff81096854>] get_signal_to_deliver+0x254/0x620
[ 324.984420] [<ffffffff81043057>] do_signal+0x57/0x5a0
[ 324.984420] [<ffffffff8161a164>] ? __do_page_fault+0x2a4/0x4e0
[ 324.984420] [<ffffffff8161665c>] ? retint_restore_args+0xe/0xe
[ 324.984420] [<ffffffff816166cd>] ? retint_signal+0x11/0x84
[ 324.984420] [<ffffffff81043605>] do_notify_resume+0x65/0x80
[ 324.984420] [<ffffffff81616702>] retint_signal+0x46/0x84
[ 324.984420] ---[ end trace 442ec2f04db3771a ]---
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/1373384651-6109-2-git-send-email-jolsa@redhat.com
Currently when the child context for inherited events is
created, it's based on the pmu object of the first event
of the parent context.
This is wrong for the following scenario:
- HW context having HW and SW event
- HW event got removed (closed)
- SW event stays in HW context as the only event
and its pmu is used to clone the child context
The issue starts when the cpu context object is touched
based on the pmu context object (__get_cpu_context). In
this case the HW context will work with SW cpu context
ending up with following WARN below.
Fixing this by using parent context pmu object to clone
from child context.
Addresses the following warning reported by Vince Weaver:
[ 2716.472065] ------------[ cut here ]------------
[ 2716.476035] WARNING: at kernel/events/core.c:2122 task_ctx_sched_out+0x3c/0x)
[ 2716.476035] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs locn
[ 2716.476035] CPU: 0 PID: 3164 Comm: perf_fuzzer Not tainted 3.10.0-rc4 #2
[ 2716.476035] Hardware name: AOpen DE7000/nMCP7ALPx-DE R1.06 Oct.19.2012, BI2
[ 2716.476035] 0000000000000000 ffffffff8102e215 0000000000000000 ffff88011fc18
[ 2716.476035] ffff8801175557f0 0000000000000000 ffff880119fda88c ffffffff810ad
[ 2716.476035] ffff880119fda880 ffffffff810af02a 0000000000000009 ffff880117550
[ 2716.476035] Call Trace:
[ 2716.476035] [<ffffffff8102e215>] ? warn_slowpath_common+0x5b/0x70
[ 2716.476035] [<ffffffff810ab2bd>] ? task_ctx_sched_out+0x3c/0x5f
[ 2716.476035] [<ffffffff810af02a>] ? perf_event_exit_task+0xbf/0x194
[ 2716.476035] [<ffffffff81032a37>] ? do_exit+0x3e7/0x90c
[ 2716.476035] [<ffffffff810cd5ab>] ? __do_fault+0x359/0x394
[ 2716.476035] [<ffffffff81032fe6>] ? do_group_exit+0x66/0x98
[ 2716.476035] [<ffffffff8103dbcd>] ? get_signal_to_deliver+0x479/0x4ad
[ 2716.476035] [<ffffffff810ac05c>] ? __perf_event_task_sched_out+0x230/0x2d1
[ 2716.476035] [<ffffffff8100205d>] ? do_signal+0x3c/0x432
[ 2716.476035] [<ffffffff810abbf9>] ? ctx_sched_in+0x43/0x141
[ 2716.476035] [<ffffffff810ac2ca>] ? perf_event_context_sched_in+0x7a/0x90
[ 2716.476035] [<ffffffff810ac311>] ? __perf_event_task_sched_in+0x31/0x118
[ 2716.476035] [<ffffffff81050dd9>] ? mmdrop+0xd/0x1c
[ 2716.476035] [<ffffffff81051a39>] ? finish_task_switch+0x7d/0xa6
[ 2716.476035] [<ffffffff81002473>] ? do_notify_resume+0x20/0x5d
[ 2716.476035] [<ffffffff813654f5>] ? retint_signal+0x3d/0x78
[ 2716.476035] ---[ end trace 827178d8a5966c3d ]---
Link: http://lkml.kernel.org/r/1373384651-6109-1-git-send-email-jolsa@redhat.com
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Pull perf/urgent fixes from Arnaldo Carvalho de Melo:
* Fix some freeing bugs on the parsing error paths, from Adrian Hunter.
* Update symbol_conf.nr_events when processing attribute events, fix from Adrian Hunter.
* Fix missing increment in sample parsing when PERF_SAMPLE_STACK_USER
is present, from Adrian Hunt.
* Fix count parameter to read call in event_format__new, from David Ahern.
* Remove -A/--append option, not working for a long time, from Jiri Olsa.
* Remove -f/--force option, was a no-op for quite some time, from Jiri Olsa.
* Fix -x/--exclude-other option for report command, from Jiri Olsa.
* Cross build fixes, at least one for Android, from Joonsoo Kim.
* Fix memory allocation fail check in mem{set,cpy} 'perf bench' workloads,
from Kirill A. Shutemov.
* Revert regression in configuration of Python support, from Michael Witten.
* Fix -ldw/-lelf link test when static linking, from Mike Frysinger.
* Fix issues with multiple children processing in perf_evlist__start_workload(),
from Namhyung Kim.
* Fix broken include in Context.xs ('perf script'), from Ramkumar Ramachandra.
* Fixes for build problems, from Robert Richter.
* Fix a typo of a Power7 event name, from Runzhen Wang.
* Avoid sending SIGTERM to random processes in 'perf stat', fix from Stephane Eranian.
* Fix per-socket output bug for uncore events in 'perf stat', from Stephane Eranian.
* Fix vdso list searching, from Waiman Long.
765532c8 (perf script: Finish the rename from trace to script,
2010-12-23) made a mistake during find-and-replace replacing
"../../../util/trace-event.h" with "../../../util/script-event.h", a
non-existent file. Fix this include.
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com>
Link: http://lkml.kernel.org/r/1373364033-7918-3-git-send-email-artagnon@gmail.com
Since libelf sometimes uses libpthread, we have to list that after -lelf
when someone tries to build statically. Else things go boom:
Makefile:479: *** No libelf.h/libelf found, please install \
libelf-dev/elfutils-libelf-devel. Stop.
Similarly, the -ldw test fails as it often uses -lz:
Makefile:462: No libdw.h found or old libdw.h found or elfutils is older \
than 0.138, disables dwarf support. Please install new elfutils-devel/libdw-dev
And if we add debugging to try-cc, we see:
+ echo '#include <dwarf.h>
int main(void)
Dwarf *dbg = dwarf_begin(0, DWARF_C_READ);
return (long)dbg;
+ i686-pc-linux-gnu-gcc -x c - -O2 -pipe -march=atom -mtune=atom -mfpmath=sse -g \
-D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_GNU_SOURCE \
-ldw -lelf -static -lpthread -lrt -lelf -lm -o .24368
/usr/lib/libdw.a(dwarf_begin_elf.o):function check_section.isra.1: error: undefined reference to 'inflateInit_'
/usr/lib/libdw.a(dwarf_begin_elf.o):function check_section.isra.1: error: undefined reference to 'inflate'
/usr/lib/libdw.a(dwarf_begin_elf.o):function check_section.isra.1: error: undefined reference to 'inflateReset'
/usr/lib/libdw.a(dwarf_begin_elf.o):function check_section.isra.1: error: undefined reference to 'inflateEnd'
+ echo '#include <libelf.h>
int main(void)
Elf *elf = elf_begin(0, ELF_C_READ, 0);
return (long)elf;
-static -lpthread -lrt -lelf -lm -o .19216
/usr/lib/libelf.a(elf_begin.o):function file_read_elf: error: undefined reference to 'pthread_rwlock_init'
/usr/lib/libelf.a(elf_begin.o):function __libelf_read_mmaped_file: error: undefined reference to 'pthread_rwlock_init'
/usr/lib/libelf.a(elf_begin.o):function read_file: error: undefined reference to 'pthread_rwlock_init'
/usr/lib/libelf.a(elf_begin.o):function lock_dup_elf.8072: error: undefined reference to 'pthread_rwlock_unlock'
/usr/lib/libelf.a(elf_begin.o):function lock_dup_elf.8072: error: undefined reference to 'pthread_rwlock_wrlock'
/usr/lib/libelf.a(elf_begin.o):function elf_begin: error: undefined reference to 'pthread_rwlock_rdlock'
/usr/lib/libelf.a(elf_begin.o):function elf_begin: error: undefined reference to 'pthread_rwlock_unlock'
Link: http://lkml.kernel.org/r/1368073064-18276-1-git-send-email-vapier@gentoo.org
Among other things, the following:
commit 31160d7feab786c991780d7f0ce2755a469e0e5e
Date: Tue Jan 8 16:22:36 2013 -0500
perf tools: Fix GNU make v3.80 compatibility issue
attempts to aid the user by tapping into an existing error message,
as described in the commit message:
... Also fix an issue where _get_attempt was called with only
one argument. This prevented the error message from printing
the name of the variable that can be used to fix the problem.
or more precisely:
-$(if $($(1)),$(call _ge_attempt,$($(1)),$(1)),$(call _ge_attempt,$(2)))
+$(if $($(1)),$(call _ge_attempt,$($(1)),$(1)),$(call _ge_attempt,$(2),$(1)))
However, The "missing" argument was in fact missing on purpose; it's
absence is a signal that the error message should be skipped, because
the failure would be due to the default value, not any user-supplied
value. This can be seen in how `_ge_attempt' uses `gea_err' (in the
config/utilities.mak file):
_ge_attempt = $(if $(get-executable),$(get-executable),$(_gea_warn)$(call _gea_err,$(2)))
_gea_warn = $(warning The path '$(1)' is not executable.)
_gea_err = $(if $(1),$(error Please set '$(1)' appropriately))
That is, because the argument is no longer missing, the value `$(1)'
(associated with `_gea_err') always evaluates to true, thus always
triggering the error condition that is meant to be reserved for
only the case when a user explicitly supplies an invalid value.
Concretely, the result is a regression in the Makefile's configuration
of python support; rather than gracefully disable support when the
relevant executables cannot be found according to default values, the
build process halts in error as though the user explicitly supplied
the values.
This new commit simply reverts the offending one-line change.
Reported-by: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/CAOJsxLHv17Ys3M7P5q25imkUxQW6LE_vABxh1N3Tt7Mv6Ho4iw@mail.gmail.com
Signed-off-by: Michael Witten <mfwitten@gmail.com>
The tag of the perf version is wrongly determined, always the latest tag
is taken regardless of the HEAD commit:
$ perf --version
perf version 3.9.rc8.gd7f5d3
$ git describe d7f5d3
v3.9-rc7-154-gd7f5d33
$ head -n 4 Makefile
VERSION = 3
PATCHLEVEL = 9
SUBLEVEL = 0
EXTRAVERSION = -rc7
In other cases no tag might be found.
This patch fixes this.
This new implementation handles also the case if there are no tags at
all found in the git repo but there is a commit id.
Signed-off-by: Robert Richter <robert.richter@calxeda.com>
Link: http://lkml.kernel.org/r/1368006214-12912-1-git-send-email-rric@kernel.org
This patch fixes a problem reported by Andi Kleen on perf
stat when measuring uncore events:
# perf stat --per-socket -e uncore_pcu/event=0x0/ -I1000 -a sleep 2
It would not report counts for the second socket. That was due to a
cpu mapping bug in print_aggr().
This patch also fixes the socket numbering bug for <not counted>
events.
Reported-by: Andi Kleen <ak@linux.intel.com>
Signed-off-by: Stephane Eranian <eranian@google.com>
Tested-by: Andi Kleen <ak@linux.intel.com>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Cc: zheng.z.yan@intel.com
Link: http://lkml.kernel.org/r/20130705170645.GA32519@quad
When "perf record" was used on a large machine with a lot of CPUs, the
perf post-processing time (the time after the workload was done until
the perf command itself exited) could take a lot of minutes and even
hours depending on how large the resulting perf.data file was.
While running AIM7 1500-user high_systime workload on a 80-core x86-64
system with a 3.9 kernel (with only the -s -a options used), the
workload itself took about 2 minutes to run and the perf.data file had a
size of 1108.746 MB. However, the post-processing step took more than 10
minutes.
With a gprof-profiled perf binary, the time spent by perf was as
follows:
% cumulative self self total
time seconds seconds calls s/call s/call name
96.90 822.10 822.10 192156 0.00 0.00 dsos__find
0.81 828.96 6.86 172089958 0.00 0.00 rb_next
0.41 832.44 3.48 48539289 0.00 0.00 rb_erase
So 97% (822 seconds) of the time was spent in a single dsos_find()
function. After analyzing the call-graph data below:
0.00 822.12 192156/192156 map__new [6]
[7] 96.9 0.00 822.12 192156 vdso__dso_findnew [7]
822.10 0.00 192156/192156 dsos__find [8]
0.01 0.00 192156/192156 dsos__add [62]
0.01 0.00 192156/192366 dso__new [61]
0.00 0.00 1/45282525 memdup [31]
0.00 0.00 192156/192230 dso__set_long_name [91]
822.10 0.00 192156/192156 vdso__dso_findnew [7]
[8] 96.9 822.10 0.00 192156 dsos__find [8]
It was found that the vdso__dso_findnew() function failed to locate
VDSO__MAP_NAME ("[vdso]") in the dso list and have to insert a new
entry at the end for 192156 times. This problem is due to the fact that
there are 2 types of name in the dso entry - short name and long name.
The initial dso__new() adds "[vdso]" to both the short and long names.
After that, vdso__dso_findnew() modifies the long name to something
like /tmp/perf-vdso.so-NoXkDj. The dsos__find() function only compares
the long name. As a result, the same vdso entry is duplicated many
time in the dso list. This bug increases memory consumption as well
as slows the symbol processing time to a crawl.
To resolve this problem, the dsos__find() function interface was
modified to enable searching either the long name or the short
name. The vdso__dso_findnew() will now search only the short name
while the other call sites search for the long name as before.
With this change, the cpu time of perf was reduced from 848.38s to
15.77s and dsos__find() only accounted for 0.06% of the total time.
0.06 15.73 0.01 192151 0.00 0.00 dsos__find
Signed-off-by: Waiman Long <Waiman.Long@hp.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: "Chandramouleeswaran, Aswin" <aswin@hp.com>
Cc: "Norton, Scott J" <scott.norton@hp.com>
Link: http://lkml.kernel.org/r/1368110568-64714-1-git-send-email-Waiman.Long@hp.com
[ replaced TRUE/FALSE with stdbool.h equivalents, fixing builds where
those macros are not present (NO_LIBPYTHON=1 NO_LIBPERL=1), fix from Jiri Olsa ]
The final sample format bit used to be PERF_SAMPLE_STACK_USER which
neglected to do a final increment of the array pointer. The result is
that the following parsing might start at the wrong place.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/r/1372944040-32690-16-git-send-email-adrian.hunter@intel.com
Link: http://lkml.kernel.org/r/1372944040-32690-11-git-send-email-adrian.hunter@intel.com
On the error path, newly allocated 'term' must be freed.
Acked-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1372944040-32690-6-git-send-email-adrian.hunter@intel.com
On the error path, 'data.terms' may not have been initialised.
Link: http://lkml.kernel.org/r/1372944040-32690-5-git-send-email-adrian.hunter@intel.com
per realloc above the length of the buffer is alloc_size, not BUFSIZ.
Adjust length per size as done for buf start.
Addresses some valgrind complaints:
==1870== Syscall param read(buf) points to unaddressable byte(s)
==1870== at 0x4E3F610: __read_nocancel (in /lib64/libpthread-2.14.90.so)
==1870== by 0x44AEE1: event_format__new (unistd.h:45)
==1870== by 0x44B025: perf_evsel__newtp (evsel.c:158)
==1870== by 0x451919: add_tracepoint_event (parse-events.c:395)
==1870== by 0x479815: parse_events_parse (parse-events.y:292)
==1870== by 0x45463A: parse_events_option (parse-events.c:861)
==1870== by 0x44FEE4: get_value (parse-options.c:113)
==1870== by 0x450767: parse_options_step (parse-options.c:192)
==1870== by 0x450C40: parse_options (parse-options.c:422)
==1870== by 0x42735F: cmd_record (builtin-record.c:918)
==1870== by 0x419D72: run_builtin (perf.c:319)
==1870== by 0x4195F2: main (perf.c:376)
==1870== Address 0xcffebf0 is 0 bytes after a block of size 8,192 alloc'd
==1870== at 0x4C2A62F: malloc (vg_replace_malloc.c:270)
==1870== by 0x4C2A7A3: realloc (vg_replace_malloc.c:662)
==1870== by 0x44AF07: event_format__new (evsel.c:121)
Link: http://lkml.kernel.org/r/1372793245-4136-2-git-send-email-dsahern@gmail.com
In the Power7 PMU guide:
https://www.power.org/documentation/commonly-used-metrics-for-performance-analysis/
PM_BRU_MPRED is referred to as PM_BR_MPRED.
It fixed the typo by changing the name of the event in kernel and
documentation accordingly.
This patch changes the ABI, there are some reasons I think it's ok:
- It is relatively new interface, specific to the Power7 platform.
- No tools that we know of actually use this interface at this point
(none are listed near the interface).
- Users of this interface (eg oprofile users migrating to perf)
would be more used to the "PM_BR_MPRED" rather than "PM_BRU_MPRED".
- These are in the ABI/testing at this point rather than ABI/stable,
so hoping we have some wiggle room.
Signed-off-by: Runzhen Wang <runzhen@linux.vnet.ibm.com>
Acked-by: Michael Ellerman <michael@ellerman.id.au>
Cc: icycoder@gmail.com
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: Runzhen Wang <runzhew@clemson.edu>
Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1372407297-6996-2-git-send-email-runzhen@linux.vnet.ibm.com
Currently we have symbol_conf.exclude_other being set as true every time
so the -x/--exclude-other has nothing to do.
Also we have no way to see the data with symbol_conf.exclude_other being
false which is useful sometimes.
Fixing it by making symbol_conf.exclude_other false by default.
1) Example without -x option:
$ perf report -i perf.data.delete -p perf_session__delete -s parent
+ 99.91% [other]
+ 0.08% perf_session__delete
+ 0.00% perf_session__delete_dead_threads
+ 0.00% perf_session__delete_threads
2) Example with -x option:
$ ./perf report -i perf.data.delete -p perf_session__delete -s parent -x
+ 96.22% perf_session__delete
+ 1.89% perf_session__delete_dead_threads
+ 1.89% perf_session__delete_threads
In Example 1) we get the sorted out data together with the rest
"[other]". This could help us estimate how much time we spent in the
sorted data.
In Example 2) the total is just the sorted data.
Link: http://lkml.kernel.org/n/tip-sg8fvu0fyqohf9ur9l38lhkw@git.kernel.org
When perf tries to start a workload, it relies on a pipe which the
workload was blocked for reading. After closing the pipe on the parent,
the workload (child) can start the actual work via exec().
However, if another process was forked after creating a workload, this
mechanism cannot work since the other process (child) also inherits the
pipe, so that closing the pipe in parent cannot unblock the workload.
Fix it by using explicit write call can then closing it.
For similar reason, the pipe fd on parent should be marked as CLOEXEC so
that it can be closed after another child exec'ed.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1372230862-15861-13-git-send-email-namhyung@kernel.org
It no longer have any affect on the processing and is marked as obsolete
anyway.
Link: http://lkml.kernel.org/n/tip-tvwyspiqr4getzfib2lw06ty@git.kernel.org
Link: http://lkml.kernel.org/r/1372307120-737-1-git-send-email-namhyung@kernel.org
[ combined patch removing the -f usage in various sub-commands, such as 'perf sched', etc, by Namhyung Kim ]
It's no longer working and needed.
Quite straightforward discussion/vote was in here:
http://marc.info/?t=137028288300004&r=1&w=2
Link: http://lkml.kernel.org/n/tip-8fgdva12hl8w3xzzpsvvg7nx@git.kernel.org
This patch fixes a problem with perf stat whereby on termination it may
send a SIGTERM signal to random processes on systems with high PID
recycling. I got some actual bug reports on this.
There is race between the SIGCHLD and sig_atexit() handlers. This patch
addresses this problem by clearing child_pid in the SIGCHLD handler.
Link: http://lkml.kernel.org/r/20130604154426.GA2928@quad
Currently, lib lk doesn't use CROSS_COMPILE environment variable, so
cross build always fails.
This is a quick fix for this problem.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Link: http://lkml.kernel.org/r/1371603750-15053-2-git-send-email-iamjoonsoo.kim@lge.com
Building perf for android fails because it can't find the definition of
struct winsize.
This definition is in termios.h, so I add this header to util.h to solve
the problem.
It is missed by commit '2c803e52' which moves get_term_dimensions() from
builtin-top.c to util.c, but missed to move termios.h header.
Acked-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1371603750-15053-3-git-send-email-iamjoonsoo.kim@lge.com
Addresses of allocated memory areas saved to '*src' and '*dst', so we
need to check them for NULL, not 'src' and 'dst'.
Acked-by: Hitoshi Mitake <mitake.hitoshi@lab.ntt.co.jp>
Cc: Hitoshi Mitake <h.mitake@gmail.com>
Link: http://lkml.kernel.org/r/1370518503-4230-1-git-send-email-kirill.shutemov@linux.intel.com
Fixing build errors with O and DESTDIR make vars set:
$ make prefix=/usr/local O=$builddir DESTDIR=$destdir -C tools/ perf
make[1]: Entering directory `.../.source/perf/tools/perf'
CC .../.build/perf/perf/util/parse-events.o
util/parse-events.c:14:32: fatal error: parse-events-bison.h: No such file or directory
compilation terminated.
make[1]: *** [.../.build/perf/perf/util/parse-events.o] Error 1
and:
LINK /.../.build/perf/perf/perf
gcc: error: /.../.build/perf/perf//.../.source/perf/tools/lib/lk/liblk.a: No such file or directory
Link: http://lkml.kernel.org/r/1370964158-4135-1-git-send-email-rric@kernel.org
The OUTPUT directory is wrongly determind leading to:
make[3]: *** No rule to make target `.../.build/perf/PERF-VERSION-FILE'. Stop.
Fixing this by using the generic approach in script/Makefile.include.
Link: http://lkml.kernel.org/r/1367865614-30876-1-git-send-email-rric@kernel.org
Fix having verbose build with V=0, e.g:
make V=0 -C tools/ perf
Link: http://lkml.kernel.org/r/20130503134953.GU8356@rric.localhost
This patch fixes a serious bug in:
14c63f17b1fd perf: Drop sample rate when sampling is too slow
There was an misunderstanding on the API of the do_div()
macro. It returns the remainder of the division and this
was not what the function expected leading to disabling the
interrupt latency watchdog.
This patch also remove a duplicate assignment in
perf_sample_event_took().
Cc: peterz@infradead.org
Cc: dave.hansen@linux.intel.com
Cc: ak@linux.intel.com
Cc: jolsa@redhat.com
Link: http://lkml.kernel.org/r/20130704223010.GA30625@quad
As Linus said its not an error to not have an AMD IOMMU; esp.
when you're not even running on an AMD platform.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Link: http://lkml.kernel.org/r/20130703075542.GF23916@twins.programming.kicks-ass.net
Pull x86 UV update from Ingo Molnar:
"There's a single commit in this tree, which adds support for a new SGI
UV GRU (Global Reference Unit - fast NUMA messaging ASIC) hardware
feature to scale up and beyond: an optional distributed mode that will
allow per-node address mapping of local GRU space, as opposed to
mapping all GRU hardware to the same contiguous high space"
* 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/UV: Add GRU distributed mode mappings
Pull x86 tracing updates from Ingo Molnar:
"This tree adds IRQ vector tracepoints that are named after the handler
and which output the vector #, based on a zero-overhead approach that
relies on changing the IDT entries, by Seiji Aguchi.
The new tracepoints look like this:
# perf list | grep -i irq_vector
irq_vectors:local_timer_entry [Tracepoint event]
irq_vectors:local_timer_exit [Tracepoint event]
irq_vectors:reschedule_entry [Tracepoint event]
irq_vectors:reschedule_exit [Tracepoint event]
irq_vectors:spurious_apic_entry [Tracepoint event]
irq_vectors:spurious_apic_exit [Tracepoint event]
irq_vectors:error_apic_entry [Tracepoint event]
irq_vectors:error_apic_exit [Tracepoint event]
* 'x86-tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/tracing: Add config option checking to the definitions of mce handlers
trace,x86: Do not call local_irq_save() in load_current_idt()
trace,x86: Move creation of irq tracepoints from apic.c to irq.c
x86, trace: Add irq vector tracepoints
x86: Rename variables for debugging
x86, trace: Introduce entering/exiting_irq()
tracing: Add DEFINE_EVENT_FN() macro
Pull x86 RAS update from Ingo Molnar:
"The changes in this tree are:
- ACPI APEI (ACPI Platform Error Interface) improvements, by Chen
Gong
- misc MCE fixes/cleanups"
* 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mce: Update MCE severity condition check
mce: acpi/apei: Add comments to clarify usage of the various bitfields in the MCA subsystem
ACPI/APEI: Update einj documentation for param1/param2
ACPI/APEI: Add parameter check before error injection
ACPI, APEI, EINJ: Fix error return code in einj_init()
x86, mce: Fix "braodcast" typo
Pull x86 platform updates from Ingo Molnar:
"Two changes:
- A Kconfig dependency fix/cleanup
- Introduce the 'make kvmconfig' KVM configuration helper utility
that turns the current .config into a KVM-bootable config. Useful
for debugging specific native kernel configs that have no KVM
config options enabled on VM setups."
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/platform: Make X86_GOLDFISH depend on X86_EXTENDED_PLATFORM
x86/platform: Add kvmconfig to the phony targets
x86, platform, kvm, kconfig: Turn existing .config's into KVM-capable configs
Pull x86 mm changes from Ingo Molnar:
"Misc improvements:
- Fix /proc/mtrr reporting
- Fix ioremap printout
- Remove the unused pvclock fixmap entry on 32-bit
- misc cleanups"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/ioremap: Correct function name output
x86: Fix /proc/mtrr with base/size more than 44bits
ix86: Don't waste fixmap entries
x86/mm: Drop unneeded include <asm/*pgtable, page*_types.h>
x86_64: Correct phys_addr in cleanup_highmap comment
Pull x86 microcode loading update from Ingo Molnar:
"Two main changes that improve microcode loading on AMD CPUs:
- Add support for all-in-one binary microcode files that concatenate
the microcode images of multiple processor families, by Jacob Shin
- Add early microcode loading (embedded in the initrd) support, also
by Jacob Shin"
* 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, microcode, amd: Another early loading fixup
x86, microcode, amd: Allow multiple families' bin files appended together
x86, microcode, amd: Make find_ucode_in_initrd() __init
x86, microcode, amd: Fix warnings and errors on with CONFIG_MICROCODE=m
x86, microcode, amd: Early microcode patch loading support for AMD
x86, microcode, amd: Refactor functions to prepare for early loading
x86, microcode: Vendor abstract out save_microcode_in_initrd()
x86, microcode, intel: Correct typo in printk
Pull x86 FPU changes from Ingo Molnar:
"There are two bigger changes in this tree:
- Add an [early-use-]safe static_cpu_has() variant and other
robustness improvements, including the new X86_DEBUG_STATIC_CPU_HAS
configurable debugging facility, motivated by recent obscure FPU
code bugs, by Borislav Petkov
- Reimplement FPU detection code in C and drop the old asm code, by
Peter Anvin."
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, fpu: Use static_cpu_has_safe before alternatives
x86: Add a static_cpu_has_safe variant
x86: Sanity-check static_cpu_has usage
x86, cpu: Add a synthetic, always true, cpu feature
x86: Get rid of ->hard_math and all the FPU asm fu
Pull x86 EFI changes from Ingo Molnar:
"Two fixes that should in principle increase robustness of our
interaction with the EFI firmware, and a cleanup"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, efi: retry ExitBootServices() on failure
efi: Convert runtime services function ptrs
UEFI: Don't pass boot services regions to SetVirtualAddressMap()
Pull x86 debug update from Ingo Molnar:
"Misc debuggability improvements:
- Optimize the x86 CPU register printout a bit
- Expose the tboot TXT log via debugfs
- Small do_debug() cleanup"
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/tboot: Provide debugfs interfaces to access TXT log
x86: Remove weird PTR_ERR() in do_debug
x86/debug: Only print out DR registers if they are not power-on defaults
Pull x86 cpu updates from Ingo Molnar:
"Two changes:
- Extend 32-bit double fault debugging aid to 64-bit
- Fix a build warning"
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/intel/cacheinfo: Shut up last long-standing warning
x86: Extend #DF debugging aid to 64-bit
Pull x86 cleanups from Ingo Molnar:
"Misc x86 cleanups"
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, reloc: Use xorl instead of xorq in relocate_kernel_64.S
x86, cleanups: Remove extra tab in __flush_tlb_one()
x86/mce: Remove check for CONFIG_X86_MCE_P4THERMAL
Pull x86 boot build fix from Ingo Molnar:
"Small fixlet for the build process"
* 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/boot: Close opened file descriptor
Pull asm/x86 changes from Ingo Molnar:
"Misc changes, with a bigger processor-flags cleanup/reorganization by
Peter Anvin"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, asm, cleanup: Replace open-coded control register values with symbolic
x86, processor-flags: Fix the datatypes and add bit number defines
x86: Rename X86_CR4_RDWRGSFS to X86_CR4_FSGSBASE
x86, flags: Rename X86_EFLAGS_BIT1 to X86_EFLAGS_FIXED
linux/const.h: Add _BITUL() and _BITULL()
x86/vdso: Convert use of typedef ctl_table to struct ctl_table
x86: __force_order doesn't need to be an actual variable
