This is a respin with a wider audience (all that get_maintainer returned)
and I know this spams a *lot* of people. Not sure what would be the correct
way, so my apologies for ruining your inbox.
The 00-INDEX files are supposed to give a summary of all files present
in a directory, but these files are horribly out of date and their
usefulness is brought into question. Often a simple "ls" would reveal
the same information as the filenames are generally quite descriptive as
a short introduction to what the file covers (it should not surprise
anyone what Documentation/sched/sched-design-CFS.txt covers)
A few years back it was mentioned that these files were no longer really
needed, and they have since then grown further out of date, so perhaps
it is time to just throw them out.
A short status yields the following _outdated_ 00-INDEX files, first
counter is files listed in 00-INDEX but missing in the directory, last
is files present but not listed in 00-INDEX.
List of outdated 00-INDEX:
Documentation: (4/10)
Documentation/sysctl: (0/1)
Documentation/timers: (1/0)
Documentation/blockdev: (3/1)
Documentation/w1/slaves: (0/1)
Documentation/locking: (0/1)
Documentation/devicetree: (0/5)
Documentation/power: (1/1)
Documentation/powerpc: (0/5)
Documentation/arm: (1/0)
Documentation/x86: (0/9)
Documentation/x86/x86_64: (1/1)
Documentation/scsi: (4/4)
Documentation/filesystems: (2/9)
Documentation/filesystems/nfs: (0/2)
Documentation/cgroup-v1: (0/2)
Documentation/kbuild: (0/4)
Documentation/spi: (1/0)
Documentation/virtual/kvm: (1/0)
Documentation/scheduler: (0/2)
Documentation/fb: (0/1)
Documentation/block: (0/1)
Documentation/networking: (6/37)
Documentation/vm: (1/3)
Then there are 364 subdirectories in Documentation/ with several files that
are missing 00-INDEX alltogether (and another 120 with a single file and no
00-INDEX).
I don't really have an opinion to whether or not we /should/ have 00-INDEX,
but the above 00-INDEX should either be removed or be kept up to date. If
we should keep the files, I can try to keep them updated, but I rather not
if we just want to delete them anyway.
As a starting point, remove all index-files and references to 00-INDEX and
see where the discussion is going.
Signed-off-by: Henrik Austad <henrik@austad.us>
Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Just-do-it-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Jens Axboe <axboe@kernel.dk>
Acked-by: Paul Moore <paul@paul-moore.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: [Almost everybody else]
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
I'll handle these myself but thanks for providing the fallback!
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Helps reading and hopefully avoids duplicates. Also, consistently add
the trailing '/' to make clear those are directories.
The dtb= parameter is no longer the primary mechanism for providing a
devicetree to the kernel. Now either firmware or the boot selector (ex.
Grub) should provide the devicetree and dtb= should only be used for
debug or when using firmware that doesn't understand DT.
Update the EFI stub documentation to reflect the current usage.
Signed-off-by: Grant Likely <grant.likely@arm.com>
Reviewed-by: Alexander Graf <agraf@suse.de>
Acked-by: Leif Lindholm <leif.lindholm@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Replace the Introduction section's TBD with some useful overview text.
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Cc: linux-doc@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Add a basic Firewire/IEEE 1394 driver API chapter to the Linux
kernel documentation.
Clean up kernel-doc warnings in <drivers/firewire/core-transaction.c>
so that it can be added to a Firewire/IEEE 1394 driver-api chapter
without adding lots of noisy warnings to the documentation build.
Clean up kernel-doc warnings in <drivers/firewire/core-iso.c> so that
Clean up kernel-doc warnings in <linux/firewire-cdev.h> so that
* Fix install instruction by adding `./autogen` command
before `./configure`.
* Add link to a more detailed installation instruction.
* Add link to SmPL grammar documentation.
* Add single space after ',' to slightly improve readability.
Signed-off-by: Himanshu Jha <himanshujha199640@gmail.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
The documentation and TOCs are organized in a manner of a tree. Adding a TOC to
the root, which refers to a file which is located in a subfolder forms a
grid. Those TOCs are a bit confusing and thats why we get additional error
messages while building partial documentation::
$ make SPHINXDIRS=process htmldocs
checking consistency... Documentation/process/license-rules.rst: \
WARNING: document isn't included in any toctree
To fix it, the *root-license-TOC* is replaced by a reference and the
'license-roles.txt' is added to the Documentation/process/index.rst TOC.
BTW: there was an old licences remark in Documentation/process/howto.rst which
is also updated, mentioning SPDX and pointing to the license-rules.rst
Signed-off-by: Markus Heiser <markus.heiser@darmarit.de>
Fix small typo (wiil -> will) in the "3.4. Nested virtual machines"
section.
Fixes: 5b76a3cff011 ("KVM: VMX: Tell the nested hypervisor to skip L1D flush on vmentry")
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: trivial@kernel.org
Signed-off-by: Salvatore Bonaccorso <carnil@debian.org>
Add a description of stacktrace filter command.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Spell the vesafb "inverse" option correctly and tell what it does.
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: dri-devel@lists.freedesktop.org
Cc: linux-fbdev@vger.kernel.org
Cc: Antonino A. Daplas <adaplas@gmail.com>
Fix s/4.17/4.16/ typo.
Fixes: 8962e40c1993 ("docs: update kernel versions and dates in tables")
Cc: Tim Bird <tim.bird@sony.com>
Config fragment files should be placed in
tools/testing/selftests/<testdir>/config
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
Acked-by: Shuah Khan (Samsung OSG) <shuah@kernel.org>
This space missing caused the colour scheme in vim editor messy
after that line. Add it to fix.
Signed-off-by: Baoquan He <bhe@redhat.com>
[ jc: fixed alignment after the changed line ]
Pull timer update from Thomas Gleixner:
"New defines for the compat time* types so they can be shared between
32bit and 64bit builds. Not used yet, but merging them now allows the
actual conversions to be merged through different maintainer trees
without dependencies
We still have compat interfaces for 32bit on 64bit even with the new
2038 safe timespec/val variants because pointer size is different. And
for the old style timespec/val interfaces we need yet another 'compat'
interface for both 32bit native and 32bit on 64bit"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
y2038: Provide aliases for compat helpers
Pull IDA updates from Matthew Wilcox:
"A better IDA API:
id = ida_alloc(ida, GFP_xxx);
ida_free(ida, id);
rather than the cumbersome ida_simple_get(), ida_simple_remove().
The new IDA API is similar to ida_simple_get() but better named. The
internal restructuring of the IDA code removes the bitmap
preallocation nonsense.
I hope the net -200 lines of code is convincing"
* 'ida-4.19' of git://git.infradead.org/users/willy/linux-dax: (29 commits)
ida: Change ida_get_new_above to return the id
ida: Remove old API
test_ida: check_ida_destroy and check_ida_alloc
test_ida: Convert check_ida_conv to new API
test_ida: Move ida_check_max
test_ida: Move ida_check_leaf
idr-test: Convert ida_check_nomem to new API
ida: Start new test_ida module
target/iscsi: Allocate session IDs from an IDA
iscsi target: fix session creation failure handling
drm/vmwgfx: Convert to new IDA API
dmaengine: Convert to new IDA API
ppc: Convert vas ID allocation to new IDA API
media: Convert entity ID allocation to new IDA API
ppc: Convert mmu context allocation to new IDA API
Convert net_namespace to new IDA API
cb710: Convert to new IDA API
rsxx: Convert to new IDA API
osd: Convert to new IDA API
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull gcc plugin fix from Kees Cook:
"Lift gcc test into Kconfig. This is for better behavior when the
kernel is built with Clang, reported by Stefan Agner"
* tag 'gcc-plugins-v4.19-rc1-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
gcc-plugins: Disable when building under Clang
Pull perf updates from Thomas Gleixner:
"Kernel:
- Improve kallsyms coverage
- Add x86 entry trampolines to kcore
- Fix ARM SPE handling
- Correct PPC event post processing
Tools:
- Make the build system more robust
- Small fixes and enhancements all over the place
- Update kernel ABI header copies
- Preparatory work for converting libtraceevnt to a shared library
- License cleanups"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (100 commits)
tools arch: Update arch/x86/lib/memcpy_64.S copy used in 'perf bench mem memcpy'
tools arch x86: Update tools's copy of cpufeatures.h
perf python: Fix pyrf_evlist__read_on_cpu() interface
perf mmap: Store real cpu number in 'struct perf_mmap'
perf tools: Remove ext from struct kmod_path
perf tools: Add gzip_is_compressed function
perf tools: Add lzma_is_compressed function
perf tools: Add is_compressed callback to compressions array
perf tools: Move the temp file processing into decompress_kmodule
perf tools: Use compression id in decompress_kmodule()
perf tools: Store compression id into struct dso
perf tools: Add compression id into 'struct kmod_path'
perf tools: Make is_supported_compression() static
perf tools: Make decompress_to_file() function static
perf tools: Get rid of dso__needs_decompress() call in __open_dso()
perf tools: Get rid of dso__needs_decompress() call in symbol__disassemble()
perf tools: Get rid of dso__needs_decompress() call in read_object_code()
tools lib traceevent: Change to SPDX License format
perf llvm: Allow passing options to llc in addition to clang
perf parser: Improve error message for PMU address filters
Pull x86 fixes from Thomas Gleixner:
- Correct the L1TF fallout on 32bit and the off by one in the 'too much
RAM for protection' calculation.
- Add a helpful kernel message for the 'too much RAM' case
- Unbreak the VDSO in case that the compiler desides to use indirect
jumps/calls and emits retpolines which cannot be resolved because the
kernel uses its own thunks, which does not work for the VDSO. Make it
use the builtin thunks.
- Re-export start_thread() which was unexported when the 32/64bit
implementation was unified. start_thread() is required by modular
binfmt handlers.
- Trivial cleanups
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/speculation/l1tf: Suggest what to do on systems with too much RAM
x86/speculation/l1tf: Fix off-by-one error when warning that system has too much RAM
x86/kvm/vmx: Remove duplicate l1d flush definitions
x86/speculation/l1tf: Fix overflow in l1tf_pfn_limit() on 32bit
x86/process: Re-export start_thread()
x86/mce: Add notifier_block forward declaration
x86/vdso: Fix vDSO build if a retpoline is emitted
Pull irq update from Thomas Gleixner:
"A small set of updats/fixes for the irq subsystem:
- Allow GICv3 interrupts to be configured as wake-up sources to
enable wakeup from suspend
- Make the error handling of the STM32 irqchip init function work
- A set of small cleanups and improvements"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip/gic-v3: Allow interrupt to be configured as wake-up sources
irqchip/tango: Set irq handler and data in one go
dt-bindings: irqchip: renesas-irqc: Document r8a774a1 support
irqchip/s3c24xx: Remove unneeded comparison of unsigned long to 0
irqchip/stm32: Fix init error handling
irqchip/bcm7038-l1: Hide cpu offline callback when building for !SMP
Pull licking update from Thomas Gleixner:
"Mark the switch cases which fall through to the next case with the
proper comment so the fallthrough compiler checks can be enabled"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
futex: Mark expected switch fall-throughs
gitolite.kernel.org:pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm memory-failure update from Dave Jiang:
"As it stands, memory_failure() gets thoroughly confused by dev_pagemap
backed mappings. The recovery code has specific enabling for several
possible page states and needs new enabling to handle poison in dax
mappings.
In order to support reliable reverse mapping of user space addresses:
1/ Add new locking in the memory_failure() rmap path to prevent races
that would typically be handled by the page lock.
2/ Since dev_pagemap pages are hidden from the page allocator and the
"compound page" accounting machinery, add a mechanism to determine
the size of the mapping that encompasses a given poisoned pfn.
3/ Given pmem errors can be repaired, change the speculatively
accessed poison protection, mce_unmap_kpfn(), to be reversible and
otherwise allow ongoing access from the kernel.
A side effect of this enabling is that MADV_HWPOISON becomes usable
for dax mappings, however the primary motivation is to allow the
system to survive userspace consumption of hardware-poison via dax.
Specifically the current behavior is:
mce: Uncorrected hardware memory error in user-access at af34214200
{1}[Hardware Error]: It has been corrected by h/w and requires no further action
mce: [Hardware Error]: Machine check events logged
{1}[Hardware Error]: event severity: corrected
Memory failure: 0xaf34214: reserved kernel page still referenced by 1 users
Memory failure: 0xaf34214: recovery action for reserved kernel page: Failed
mce: Memory error not recovered
<reboot>
...and with these changes:
Injecting memory failure for pfn 0x20cb00 at process virtual address 0x7f763dd00000
Memory failure: 0x20cb00: Killing dax-pmd:5421 due to hardware memory corruption
Memory failure: 0x20cb00: recovery action for dax page: Recovered
Given all the cross dependencies I propose taking this through
nvdimm.git with acks from Naoya, x86/core, x86/RAS, and of course dax
folks"
* tag 'libnvdimm-for-4.19_dax-memory-failure' of gitolite.kernel.org:pub/scm/linux/kernel/git/nvdimm/nvdimm:
libnvdimm, pmem: Restore page attributes when clearing errors
x86/memory_failure: Introduce {set, clear}_mce_nospec()
x86/mm/pat: Prepare {reserve, free}_memtype() for "decoy" addresses
mm, memory_failure: Teach memory_failure() about dev_pagemap pages
filesystem-dax: Introduce dax_lock_mapping_entry()
mm, memory_failure: Collect mapping size in collect_procs()
mm, madvise_inject_error: Let memory_failure() optionally take a page reference
mm, dev_pagemap: Do not clear ->mapping on final put
mm, madvise_inject_error: Disable MADV_SOFT_OFFLINE for ZONE_DEVICE pages
filesystem-dax: Set page->index
device-dax: Set page->index
device-dax: Enable page_mapping()
device-dax: Convert to vmf_insert_mixed and vm_fault_t
Pull libnvdimm updates from Dave Jiang:
"Collection of misc libnvdimm patches for 4.19 submission:
- Adding support to read locked nvdimm capacity.
- Change test code to make DSM failure code injection an override.
- Add support for calculate maximum contiguous area for namespace.
- Add support for queueing a short ARS when there is on going ARS for
nvdimm.
- Allow NULL to be passed in to ->direct_access() for kaddr and pfn
params.
- Improve smart injection support for nvdimm emulation testing.
- Fix test code that supports for emulating controller temperature.
- Fix hang on error before devm_memremap_pages()
- Fix a bug that causes user memory corruption when data returned to
user for ars_status.
- Maintainer updates for Ross Zwisler emails and adding Jan Kara to
fsdax"
* tag 'libnvdimm-for-4.19_misc' of gitolite.kernel.org:pub/scm/linux/kernel/git/nvdimm/nvdimm:
libnvdimm: fix ars_status output length calculation
device-dax: avoid hang on error before devm_memremap_pages()
tools/testing/nvdimm: improve emulation of smart injection
filesystem-dax: Do not request kaddr and pfn when not required
md/dm-writecache: Don't request pointer dummy_addr when not required
dax/super: Do not request a pointer kaddr when not required
tools/testing/nvdimm: kaddr and pfn can be NULL to ->direct_access()
s390, dcssblk: kaddr and pfn can be NULL to ->direct_access()
libnvdimm, pmem: kaddr and pfn can be NULL to ->direct_access()
acpi/nfit: queue issuing of ars when an uc error notification comes in
libnvdimm: Export max available extent
libnvdimm: Use max contiguous area for namespace size
MAINTAINERS: Add Jan Kara for filesystem DAX
MAINTAINERS: update Ross Zwisler's email address
tools/testing/nvdimm: Fix support for emulating controller temperature
tools/testing/nvdimm: Make DSM failure code injection an override
acpi, nfit: Prefer _DSM over _LSR for namespace label reads
libnvdimm: Introduce locked DIMM capacity support
Pull ARM SoC late updates from Olof Johansson:
"A couple of late-merged changes that would be useful to get in this
merge window:
- Driver support for reset of audio complex on Meson platforms. The
audio driver went in this merge window, and these changes have been
in -next for a while (just not in our tree).
- Power management fixes for IOMMU on Rockchip platforms, getting
closer to kexec working on them, including Chromebooks.
- Another pass updating "arm,psci" -> "psci" for some properties that
have snuck in since last time it was done"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
iommu/rockchip: Move irq request past pm_runtime_enable
iommu/rockchip: Handle errors returned from PM framework
arm64: rockchip: Force CONFIG_PM on Rockchip systems
ARM: rockchip: Force CONFIG_PM on Rockchip systems
arm64: dts: Fix various entry-method properties to reflect documentation
reset: imx7: Fix always writing bits as 0
reset: meson: add meson audio arb driver
reset: meson: add dt-bindings for meson-axg audio arb
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- add build_{menu,n,g,x}config targets for compile-testing Kconfig
- fix and improve recursive dependency detection in Kconfig
- fix parallel building of menuconfig/nconfig
- fix syntax error in clang-version.sh
- suppress distracting log from syncconfig
- remove obsolete "rpm" target
- remove VMLINUX_SYMBOL(_STR) macro entirely
- fix microblaze build with CONFIG_DYNAMIC_FTRACE
- move compiler test for dead code/data elimination to Kconfig
- rename well-known LDFLAGS variable to KBUILD_LDFLAGS
- misc fixes and cleanups
* tag 'kbuild-v4.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kbuild: rename LDFLAGS to KBUILD_LDFLAGS
kbuild: pass LDFLAGS to recordmcount.pl
kbuild: test dead code/data elimination support in Kconfig
initramfs: move gen_initramfs_list.sh from scripts/ to usr/
vmlinux.lds.h: remove stale <linux/export.h> include
export.h: remove VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR()
Coccinelle: remove pci_alloc_consistent semantic to detect in zalloc-simple.cocci
kbuild: make sorting initramfs contents independent of locale
kbuild: remove "rpm" target, which is alias of "rpm-pkg"
kbuild: Fix LOADLIBES rename in Documentation/kbuild/makefiles.txt
kconfig: suppress "configuration written to .config" for syncconfig
kconfig: fix "Can't open ..." in parallel build
kbuild: Add a space after `!` to prevent parsing as file pattern
scripts: modpost: check memory allocation results
kconfig: improve the recursive dependency report
kconfig: report recursive dependency involving 'imply'
kconfig: error out when seeing recursive dependency
kconfig: add build-only configurator targets
scripts/dtc: consolidate include path options in Makefile
Pull block fixes from Jens Axboe:
"A few small fixes for this merge window:
- Locking imbalance fix for bcache (Shan Hai)
- A few small fixes for wbt. One is a cleanup/prep, one is a fix for
an existing issue, and the last two are fixes for changes that went
into this merge window (me)"
* tag 'for-linus-20180825' of git://git.kernel.dk/linux-block:
blk-wbt: don't maintain inflight counts if disabled
blk-wbt: fix has-sleeper queueing check
blk-wbt: use wq_has_sleeper() for wq active check
blk-wbt: move disable check into get_limit()
bcache: release dc->writeback_lock properly in bch_writeback_thread()
Pull UBIFS fix from Richard Weinberger:
"Remove an empty file from UBIFS source"
* tag 'upstream-4.19-rc1-fix' of git://git.infradead.org/linux-ubifs:
ubifs: Remove empty file.h
Pull cifs fixes from Steve French:
"Three small SMB3 fixes, one for stable"
* tag '4.19-rc-smb3' of git://git.samba.org/sfrench/cifs-2.6:
cifs: update internal module version number for cifs.ko to 2.12
cifs: check kmalloc before use
cifs: check if SMB2 PDU size has been padded and suppress the warning
cifs: create a define for how many iovs we need for an SMB2_open()
This is not normally noticeable, but repeated forks are unnecessarily
expensive because they repeatedly dirty the parent page tables during
the page table copy operation.
It's trivial to just avoid write protecting the page table entry if it
was already not writable.
This patch was inspired by
https://bugzilla.kernel.org/show_bug.cgi?id=200447
which points to an ancient "waste time re-doing fork" issue in the
presence of lots of signals.
That bug was fixed by Eric Biederman's signal handling series
culminating in commit c3ad2c3b02e9 ("signal: Don't restart fork when
signals come in"), but the unnecessary work for repeated forks is still
work just fixing, particularly since the fix is trivial.
Cc: Eric Biederman <ebiederm@xmission.com>
At the point where r is being checked for different values, r is always
going to be equal to 2 as the previous if statements jump to end or end1
if r is not 2. Hence the assignment to err can be simplified to just
err an assignment without any checks on the value or r.
Detected by CoverityScan, CID#1226737 ("Logically dead code")
Reviewed-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Tejun Heo wrote:
> I asked Jens whether he could take care of the libata tree and he
> thankfully agreed, so, from now on, Jens will be the libata
> maintainer.
> Thanks a lot!
Thanks for your work in this area. I still remember the first linux
storage summit we did in Vancouver 2001, Tejun was invited to talk about
his libata error handling work. Before that, it was basically a crap
shoot if we recovered properly or not... A lot of water has flown under
the bridge since then!
Here's an "official" patch. Linus, can you apply it?
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
"Nothing too interesting. Mostly ahci and ahci_platform changes, many
around power management"
* 'for-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (22 commits)
ata: ahci_platform: enable to get and control reset
ata: libahci_platform: add reset control support
ata: add an extra argument to ahci_platform_get_resources()
ata: sata_rcar: Add r8a77965 support
ata: sata_rcar: exclude setting of PHY registers in Gen3
ata: sata_rcar: really mask all interrupts on Gen2 and later
Revert "ata: ahci_platform: allow disabling of hotplug to save power"
ata: libahci: Allow reconfigure of DEVSLP register
ata: libahci: Correct setting of DEVSLP register
ata: ahci: Enable DEVSLP by default on x86 with SLP_S0
ata: ahci: Support state with min power but Partial low power state
Revert "ata: ahci_platform: convert kcalloc to devm_kcalloc"
ata: sata_rcar: Add rudimentary Runtime PM support
ata: sata_rcar: Provide a short-hand for &pdev->dev
ata: Only output sg element mapped number in verbose debug
ata: Guard ata_scsi_dump_cdb() by ATA_VERBOSE_DEBUG
ata: ahci_platform: convert kzallloc to kcalloc
ata: ahci_platform: correct parameter documentation for ahci_platform_shutdown
libata: remove ata_sff_data_xfer_noirq()
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"Just one commit from Steven to take out spin lock from trace event
handlers"
* 'for-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup/tracing: Move taking of spin lock out of trace event handlers
Pull workqueue updates from Tejun Heo:
"Over the lockdep cross-release churn, workqueue lost some of the
existing annotations. Johannes Berg restored it and also improved
them"
* 'for-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: re-add lockdep dependencies for flushing
workqueue: skip lockdep wq dependency in cancel_work_sync()
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
- PASID table handling updates for the Intel VT-d driver. It implements
a global PASID space now so that applications usings multiple devices
will just have one PASID.
- A new config option to make iommu passthroug mode the default.
- New sysfs attribute for iommu groups to export the type of the
default domain.
- A debugfs interface (for debug only) usable by IOMMU drivers to
export internals to user-space.
- R-Car Gen3 SoCs support for the ipmmu-vmsa driver
- The ARM-SMMU now aborts transactions from unknown devices and devices
not attached to any domain.
- Various cleanups and smaller fixes all over the place.
* tag 'iommu-updates-v4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (42 commits)
iommu/omap: Fix cache flushes on L2 table entries
iommu: Remove the ->map_sg indirection
iommu/arm-smmu-v3: Abort all transactions if SMMU is enabled in kdump kernel
iommu/arm-smmu-v3: Prevent any devices access to memory without registration
iommu/ipmmu-vmsa: Don't register as BUS IOMMU if machine doesn't have IPMMU-VMSA
iommu/ipmmu-vmsa: Clarify supported platforms
iommu/ipmmu-vmsa: Fix allocation in atomic context
iommu: Add config option to set passthrough as default
iommu: Add sysfs attribyte for domain type
iommu/arm-smmu-v3: sync the OVACKFLG to PRIQ consumer register
iommu/arm-smmu: Error out only if not enough context interrupts
iommu/io-pgtable-arm-v7s: Abort allocation when table address overflows the PTE
iommu/io-pgtable-arm: Fix pgtable allocation in selftest
iommu/vt-d: Remove the obsolete per iommu pasid tables
iommu/vt-d: Apply per pci device pasid table in SVA
iommu/vt-d: Allocate and free pasid table
iommu/vt-d: Per PCI device pasid table interfaces
iommu/vt-d: Add for_each_device_domain() helper
iommu/vt-d: Move device_domain_info to header
iommu/vt-d: Apply global PASID in SVA
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management updates from Zhang Rui:
- Add Daniel Lezcano as the reviewer of thermal framework and SoC
driver changes (Daniel Lezcano).
- Fix a bug in intel_dts_soc_thermal driver, which does not translate
IO-APIC GSI (Global System Interrupt) into Linux irq number (Hans de
Goede).
- For device tree bindings, allow cooling devices sharing same trip
point with same contribution value to share cooling map (Viresh
Kumar).
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
dt-bindings: thermal: Allow multiple devices to share cooling map
MAINTAINERS: Add Daniel Lezcano as designated reviewer for thermal
Thermal: Intel SoC DTS: Translate IO-APIC GSI number to linux irq number
git://git.kernel.org/pub/scm/linux/kernel/git/jj/linux-apparmor
Pull apparmor updates from John Johansen:
"There is nothing major this time just four bug fixes and a patch to
remove some dead code:
Cleanups:
- remove no-op permission check in policy_unpack
Bug fixes:
- fix an error code in __aa_create_ns()
- fix failure to audit context info in build_change_hat
- check buffer bounds when mapping permissions mask
- fully initialize aa_perms struct when answering userspace query"
* tag 'apparmor-pr-2018-08-23' of git://git.kernel.org/pub/scm/linux/kernel/git/jj/linux-apparmor:
apparmor: remove no-op permission check in policy_unpack
apparmor: fix an error code in __aa_create_ns()
apparmor: Fix failure to audit context info in build_change_hat
apparmor: Fully initialize aa_perms struct when answering userspace query
apparmor: Check buffer bounds when mapping permissions mask
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc fixes from Michael Ellerman:
- An implementation for the newly added hv_ops->flush() for the OPAL
hvc console driver backends, I forgot to apply this after merging the
hvc driver changes before the merge window.
- Enable all PCI bridges at boot on powernv, to avoid races when
multiple children of a bridge try to enable it simultaneously. This
is a workaround until the PCI core can be enhanced to fix the races.
- A fix to query PowerVM for the correct system topology at boot before
initialising sched domains, seen in some configurations to cause
broken scheduling etc.
- A fix for pte_access_permitted() on "nohash" platforms.
- Two commits to fix SIGBUS when using remap_pfn_range() seen on Power9
due to a workaround when using the nest MMU (GPUs, accelerators).
- Another fix to the VFIO code used by KVM, the previous fix had some
bugs which caused guests to not start in some configurations.
- A handful of other minor fixes.
Thanks to: Aneesh Kumar K.V, Benjamin Herrenschmidt, Christophe Leroy,
Hari Bathini, Luke Dashjr, Mahesh Salgaonkar, Nicholas Piggin, Paul
Mackerras, Srikar Dronamraju.
* tag 'powerpc-4.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc/mce: Fix SLB rebolting during MCE recovery path.
KVM: PPC: Book3S: Fix guest DMA when guest partially backed by THP pages
powerpc/mm/radix: Only need the Nest MMU workaround for R -> RW transition
powerpc/mm/books3s: Add new pte bit to mark pte temporarily invalid.
powerpc/nohash: fix pte_access_permitted()
powerpc/topology: Get topology for shared processors at boot
powerpc64/ftrace: Include ftrace.h needed for enable/disable calls
powerpc/powernv/pci: Work around races in PCI bridge enabling
powerpc/fadump: cleanup crash memory ranges support
powerpc/powernv: provide a console flush operation for opal hvc driver
powerpc/traps: Avoid rate limit messages from show unhandled signals
powerpc/64s: Fix PACA_IRQ_HARD_DIS accounting in idle_power4()
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
- A couple of patches for the zcrypt driver:
+ Add two masks to determine which AP cards and queues are host
devices, this will be useful for KVM AP device passthrough
+ Add-on patch to improve the parsing of the new apmask and aqmask
+ Some code beautification
- Second try to reenable the GCC plugins, the first patch set had a
patch to do this but the merge somehow missed this
- Remove the s390 specific GCC version check and use the generic one
- Three patches for kdump, two bug fixes and one cleanup
- Three patches for the PCI layer, one bug fix and two cleanups
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390: remove gcc version check (4.3 or newer)
s390/zcrypt: hex string mask improvements for apmask and aqmask.
s390/zcrypt: AP bus support for alternate driver(s)
s390/zcrypt: code beautify
s390/zcrypt: switch return type to bool for ap_instructions_available()
s390/kdump: Remove kzalloc_panic
s390/kdump: Fix memleak in nt_vmcoreinfo
s390/kdump: Make elfcorehdr size calculation ABI compliant
s390/pci: remove fmb address from debug output
s390/pci: remove stale rc
s390/pci: fix out of bounds access during irq setup
s390/zcrypt: fix ap_instructions_available() returncodes
s390: reenable gcc plugins for real
Pull ACPI Kconfig fix from Rafael Wysocki:
"Fix recent menuconfig breakage causing it to present ACPI-specific
options incorrectly (Arnd Bergmann)"
* tag 'acpi-4.19-rc1-3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI: fix menuconfig presentation of ACPI submenu
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace fixes from Eric Biederman:
"This is a set of four fairly obvious bug fixes:
- a switch from d_find_alias to d_find_any_alias because the xattr
code perversely takes a dentry
- two mutex vs copy_to_user fixes from Jann Horn
- a fix to use a sanitized size not the size userspace passed in from
Christian Brauner"
* 'userns-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
getxattr: use correct xattr length
sys: don't hold uts_sem while accessing userspace memory
userns: move user access out of the mutex
cap_inode_getsecurity: use d_find_any_alias() instead of d_find_alias()
Pull drm fixes from Dave Airlie:
"Just a couple of fixes"
One MAINTAINERS address change, two panels fixes, and set of amdgpu
fixes (build fixes, display fixes and some others)"
* tag 'drm-next-2018-08-24' of git://anongit.freedesktop.org/drm/drm:
drm/edid: Add 6 bpc quirk for SDC panel in Lenovo B50-80
drm/amd/display: Don't build DCN1 when kcov is enabled
Revert "drm/amdgpu/display: Replace CONFIG_DRM_AMD_DC_DCN1_0 with CONFIG_X86"
drm/amdgpu/display: disable eDP fast boot optimization on DCE8
drm/amdgpu: fix amdgpu_amdkfd_remove_eviction_fence v3
drm/amdgpu: fix incorrect use of drm_file->pid
drm/amdgpu: fix incorrect use of fcheck
drm/powerplay: enable dpm under pass-through
drm/amdgpu: access register without KIQ
drm/amdgpu: set correct base for THM/NBIF/MP1 IP
drm/amd/display: fix dentist did ranges
drm/amd/display: make dp_ss_off optional
drm/amd/display: fix dp_ss_control vbios flag parsing
drm/amd/display: Do not retain link settings
MAINTAINERS: drm-misc: Change seanpaul's email address
drm/panel: simple: tv123wam: Add unprepare delay
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull second i2c update from Wolfram Sang:
"As promised, here is my 2nd pull request for I2C, containing:
- removal of the attach_adapter callback, converting its last user
- removal of any __deprecated usage within I2C
- one email address update
- some SPDX conversion"
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: don't use any __deprecated handling anymore
i2c: use SPDX identifier for Renesas drivers
i2c: ocores: update my email address
i2c: remove deprecated attach_adapter callback
macintosh: therm_windtunnel: drop using attach_adapter
Enabling the interrupt early, before power has been applied to the
device, can result in an interrupt being delivered too early if:
- the IOMMU shares an interrupt with a VOP
- the VOP has a pending interrupt (after a kexec, for example)
In these conditions, we end-up taking the interrupt without
the IOMMU being ready to handle the interrupt (not powered on).
Moving the interrupt request past the pm_runtime_enable() call
makes sure we can at least access the IOMMU registers. Note that
this is only a partial fix, and that the VOP interrupt will still
be screaming until the VOP driver kicks in, which advocates for
a more synchronized interrupt enabling/disabling approach.
Fixes: 0f181d3cf7d98 ("iommu/rockchip: Add runtime PM support")
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
pm_runtime_get_if_in_use can fail: either PM has been disabled
altogether (-EINVAL), or the device hasn't been enabled yet (0).
Sadly, the Rockchip IOMMU driver tends to conflate the two things
by considering a non-zero return value as successful.
This has the consequence of hiding other bugs, so let's handle this
case throughout the driver, with a WARN_ON_ONCE so that we can try
and work out what happened.
A number of the Rockchip-specific drivers (IOMMU, display controllers)
are now assuming that CONFIG_PM is set, and may completely misbehave
if that's not the case.
Since there is hardly any reason for this configuration option not
to be selected anyway, let's require it (in the same way Tegra already
does).
