This is the 5.15.133 stable release
drivers/perf/fsl_imx8_ddr_perf.c
Used the stable fix
Revert the following commits before merging, the sources have been
heavely modified by NXP.
5a86ca588b3f9 Revert "perf/imx_ddr: don't enable counter0 if none of 4 counters are used"
56ad67babb7fb Revert "usb: phy: mxs: fix getting wrong state with mxs_phy_is_otg_host()"
50b3a42d82f07 Revert "USB: core: Unite old scheme and new scheme descriptor reads"
cdcf46014f5ca Revert "USB: core: Change usb_get_device_descriptor() API"
2f2af6028f201 Revert "USB: core: Fix race by not overwriting udev->descriptor in hub_port_init()"
9e168d3268f89 Revert "USB: core: Fix oversight in SuperSpeed initialization"
7e95107f9b664 Revert "PCI: dwc: Add start_link/stop_link inlines"
d0bec10a7f796 Revert "PCI: layerscape: Add the endpoint linkup notifier support"
aaf9dc6089bc3 Revert "PCI: layerscape: Add workaround for lost link capabilities during reset"
arch/arm/boot/dts/imx6qdl.dtsi
arch/arm/boot/dts/imx6sx.dtsi
Keep stable node name changes
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
Keep stable code change
drivers/media/i2c/ov5640.c
This is the 5.15.131 stable release
This is the 5.15.130 stable release
6.4.11_22Q2_NXP: IMX-3189: fix
the build error caused by conflicting types of "_QuerySignal" with gcc13.1.
Signed-off-by: IPD_SCM <IPD_SCM@verisilicon.com>
Signed-off-by: Yuan Tian <yuan.tian@nxp.com>
Upstream-Status: Inappropriate [other]
Upstream does not have the propriatery Vivante driver.
Cherry picked from NXP downstream commit 9b70e0e11b04c18545093bd6d172762f65709365.
This reverts commit c7802ff51adce9ae2e8392b926943342549de38c.
Downstream NXP and stable have deviated to far, do not pull this in.
This reverts commit 484ddaa90b7e8b40b0a479dfc24f0a1b9cd70e7d.
This reverts commit 56c49a3328e988c82981f4d098be22695d46fcf3.
This reverts commit eda9a296658203b1cc07d777c19c8c9eac6d0d17.
hub_port_init()"
This reverts commit 7fe9d87996062f5eb0ca476ad0257f79bf43aaf5.
This reverts commit 7e3ddbea87a92979fda4a9ddac37f423cb5a9d8a.
This reverts commit 69c712389e1f5e6761fc27fe39a36ca56b0c560c.
This reverts commit 4be323c73797bcebd0f9d1642e4705c13c3749d2.
This reverts commit cefcb002c5c9bc107daee807e25636a9afc7aba7.
Merge tag lf-5.15.71-2.2.2 with reverted upstream (sound/) commits
339ba37942c9d 6f668d2cbd2e2 d62dd3e291e06 416f4b7624040 1c23070f17c59
This reverts commit 1c23070f17c5934e31db5c2dda79c681eedea538.
This reverts commit 416f4b76240400260aaf0c4200565d63f49290d7.
This reverts commit d62dd3e291e061d66e088401e32f1119bcfdc7f3.
This reverts commit 6f668d2cbd2e2b87a3f347070704714453383712.
This reverts commit 339ba37942c9de7aeb7647b6a225c49cc3d7e0dc.
Link: https://lore.kernel.org/r/20230920112830.377666128@linuxfoundation.org
Tested-by: SeongJae Park <sj@kernel.org>
Tested-by: Shuah Khan <skhan@linuxfoundation.org>
Tested-by: Linux Kernel Functional Testing <lkft@linaro.org>
Tested-by: Joel Fernandes (Google) <joel@joelfernandes.org>
Tested-by: Ron Economos <re@w6rz.net>
commit 13619170303878e1dae86d9a58b039475c957fcf upstream.
Teach lockdep that icc_bw_lock is needed in code paths that could
deadlock if they trigger reclaim.
Signed-off-by: Rob Clark <robdclark@chromium.org>
Link: https://lore.kernel.org/r/20230807171148.210181-8-robdclark@gmail.com
Signed-off-by: Georgi Djakov <djakov@kernel.org>
Cc: Jon Hunter <jonathanh@nvidia.com>
commit 57a943ebfcdb4a97fbb409640234bdb44bfa1953 upstream.
For DRM legacy gamma, AMD display manager applies implicit sRGB degamma
using a pre-defined sRGB transfer function. It works fine for DCN2
family where degamma ROM and custom curves go to the same color block.
But, on DCN3+, degamma is split into two blocks: degamma ROM for
pre-defined TFs and `gamma correction` for user/custom curves and
degamma ROM settings doesn't apply to cursor plane. To get DRM legacy
gamma working as expected, enable cursor degamma ROM for implict sRGB
degamma on HW with this configuration.
Cc: stable@vger.kernel.org
Link: https://gitlab.freedesktop.org/drm/amd/-/issues/2803
Fixes: 96b020e2163f ("drm/amd/display: check attr flag before set cursor degamma on DCN3+")
Signed-off-by: Melissa Wen <mwen@igalia.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 265b4da82dbf5df04bee5a5d46b7474b1aaf326a upstream.
The rsvp classifier has served us well for about a quarter of a century but has
has not been getting much maintenance attention due to lack of known users.
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: Jiri Pirko <jiri@nvidia.com>
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Signed-off-by: Kyle Zeng <zengyhkyle@gmail.com>
commit 35588314e963938dfdcdb792c9170108399377d6 upstream.
The offset is just 32bits here so this can potentially overflow if
somebody specifies a large value. Instead reduce the size to calculate
the last possible offset.
The error handling path incorrectly drops the reference to the user
fence BO resulting in potential reference count underflow.
Signed-off-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit ef064187a9709393a981a56cce1e31880fd97107 upstream.
Dropping bit 31:4 of page table base is wrong, it makes page table
base points to wrong address if phys addr is beyond 64GB; dropping
page_table_start/end bit 31:4 is unnecessary since dcn20_vmid_setup
will do that. Also, while we are at it, cleanup the assignments using
upper_32_bits()/lower_32_bits() and AMDGPU_GPU_PAGE_SHIFT.
Link: https://gitlab.freedesktop.org/drm/amd/-/issues/2354
Fixes: 81d0bcf99009 ("drm/amdgpu: make display pinning more flexible (v2)")
Acked-by: Harry Wentland <harry.wentland@amd.com>
Signed-off-by: Yifan Zhang <yifan1.zhang@amd.com>
Co-developed-by: Hamza Mahfooz <hamza.mahfooz@amd.com>
Signed-off-by: Hamza Mahfooz <hamza.mahfooz@amd.com>
commit 7fda67e8c3ab6069f75888f67958a6d30454a9f6 upstream.
With the configuration PAGE_SIZE 64k and filesystem blocksize 64k,
a problem occurred when more than 13 million files were directly created
under a directory:
EXT4-fs error (device xx): ext4_dx_csum_set:492: inode #xxxx: comm xxxxx: dir seems corrupt? Run e2fsck -D.
EXT4-fs error (device xx): ext4_dx_csum_verify:463: inode #xxxx: comm xxxxx: dir seems corrupt? Run e2fsck -D.
EXT4-fs error (device xx): dx_probe:856: inode #xxxx: block 8188: comm xxxxx: Directory index failed checksum
When enough files are created, the fake_dirent->reclen will be 0xffff.
it doesn't equal to the blocksize 65536, i.e. 0x10000.
But it is not the same condition when blocksize equals to 4k.
when enough files are created, the fake_dirent->reclen will be 0x1000.
it equals to the blocksize 4k, i.e. 0x1000.
The problem seems to be related to the limitation of the 16-bit field
when the blocksize is set to 64k.
To address this, helpers like ext4_rec_len_{from,to}_disk has already
been introduced to complete the conversion between the encoded and the
plain form of rec_len.
So fix this one by using the helper, and all the other in this file too.
Cc: stable@kernel.org
Fixes: dbe89444042a ("ext4: Calculate and verify checksums for htree nodes")
Suggested-by: Andreas Dilger <adilger@dilger.ca>
Suggested-by: Darrick J. Wong <djwong@kernel.org>
Signed-off-by: Shida Zhang <zhangshida@kylinos.cn>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Reviewed-by: Darrick J. Wong <djwong@kernel.org>
Link: https://lore.kernel.org/r/20230803060938.1929759-1-zhangshida@kylinos.cn
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit c91774818b041ed290df29fb1dc0725be9b12e83 upstream.
The function pm8001_pci_resume() only calls pm8001_request_irq() without
calling pm8001_setup_irq(). This causes the IRQ allocation to fail, which
leads all drives being removed from the system.
Fix this issue by integrating the code for pm8001_setup_irq() directly
inside pm8001_request_irq() so that MSI-X setup is performed both during
normal initialization and resume operations.
Fixes: dbf9bfe61571 ("[SCSI] pm8001: add SAS/SATA HBA driver")
Signed-off-by: Damien Le Moal <dlemoal@kernel.org>
Link: https://lore.kernel.org/r/20230911232745.325149-2-dlemoal@kernel.org
Acked-by: Jack Wang <jinpu.wang@ionos.com>
commit 0b0747d507bffb827e40fc0f9fb5883fffc23477 upstream.
The following processes run into a deadlock. CPU 41 was waiting for CPU 29
to handle a CSD request while holding spinlock "crashdump_lock", but CPU 29
was hung by that spinlock with IRQs disabled.
PID: 17360 TASK: ffff95c1090c5c40 CPU: 41 COMMAND: "mrdiagd"
!# 0 [ffffb80edbf37b58] __read_once_size at ffffffff9b871a40 include/linux/compiler.h:185:0
!# 1 [ffffb80edbf37b58] atomic_read at ffffffff9b871a40 arch/x86/include/asm/atomic.h:27:0
!# 2 [ffffb80edbf37b58] dump_stack at ffffffff9b871a40 lib/dump_stack.c:54:0
# 3 [ffffb80edbf37b78] csd_lock_wait_toolong at ffffffff9b131ad5 kernel/smp.c:364:0
# 4 [ffffb80edbf37b78] __csd_lock_wait at ffffffff9b131ad5 kernel/smp.c:384:0
# 5 [ffffb80edbf37bf8] csd_lock_wait at ffffffff9b13267a kernel/smp.c:394:0
# 6 [ffffb80edbf37bf8] smp_call_function_many at ffffffff9b13267a kernel/smp.c:843:0
# 7 [ffffb80edbf37c50] smp_call_function at ffffffff9b13279d kernel/smp.c:867:0
# 8 [ffffb80edbf37c50] on_each_cpu at ffffffff9b13279d kernel/smp.c:976:0
# 9 [ffffb80edbf37c78] flush_tlb_kernel_range at ffffffff9b085c4b arch/x86/mm/tlb.c:742:0
#10 [ffffb80edbf37cb8] __purge_vmap_area_lazy at ffffffff9b23a1e0 mm/vmalloc.c:701:0
#11 [ffffb80edbf37ce0] try_purge_vmap_area_lazy at ffffffff9b23a2cc mm/vmalloc.c:722:0
#12 [ffffb80edbf37ce0] free_vmap_area_noflush at ffffffff9b23a2cc mm/vmalloc.c:754:0
#13 [ffffb80edbf37cf8] free_unmap_vmap_area at ffffffff9b23bb3b mm/vmalloc.c:764:0
#14 [ffffb80edbf37cf8] remove_vm_area at ffffffff9b23bb3b mm/vmalloc.c:1509:0
#15 [ffffb80edbf37d18] __vunmap at ffffffff9b23bb8a mm/vmalloc.c:1537:0
#16 [ffffb80edbf37d40] vfree at ffffffff9b23bc85 mm/vmalloc.c:1612:0
#17 [ffffb80edbf37d58] megasas_free_host_crash_buffer [megaraid_sas] at ffffffffc020b7f2 drivers/scsi/megaraid/megaraid_sas_fusion.c:3932:0
#18 [ffffb80edbf37d80] fw_crash_state_store [megaraid_sas] at ffffffffc01f804d drivers/scsi/megaraid/megaraid_sas_base.c:3291:0
#19 [ffffb80edbf37dc0] dev_attr_store at ffffffff9b56dd7b drivers/base/core.c:758:0
#20 [ffffb80edbf37dd0] sysfs_kf_write at ffffffff9b326acf fs/sysfs/file.c:144:0
#21 [ffffb80edbf37de0] kernfs_fop_write at ffffffff9b325fd4 fs/kernfs/file.c:316:0
#22 [ffffb80edbf37e20] __vfs_write at ffffffff9b29418a fs/read_write.c:480:0
#23 [ffffb80edbf37ea8] vfs_write at ffffffff9b294462 fs/read_write.c:544:0
#24 [ffffb80edbf37ee8] SYSC_write at ffffffff9b2946ec fs/read_write.c:590:0
#25 [ffffb80edbf37ee8] SyS_write at ffffffff9b2946ec fs/read_write.c:582:0
#26 [ffffb80edbf37f30] do_syscall_64 at ffffffff9b003ca9 arch/x86/entry/common.c:298:0
#27 [ffffb80edbf37f58] entry_SYSCALL_64 at ffffffff9ba001b1 arch/x86/entry/entry_64.S:238:0
PID: 17355 TASK: ffff95c1090c3d80 CPU: 29 COMMAND: "mrdiagd"
!# 0 [ffffb80f2d3c7d30] __read_once_size at ffffffff9b0f2ab0 include/linux/compiler.h:185:0
!# 1 [ffffb80f2d3c7d30] native_queued_spin_lock_slowpath at ffffffff9b0f2ab0 kernel/locking/qspinlock.c:368:0
# 2 [ffffb80f2d3c7d58] pv_queued_spin_lock_slowpath at ffffffff9b0f244b arch/x86/include/asm/paravirt.h:674:0
# 3 [ffffb80f2d3c7d58] queued_spin_lock_slowpath at ffffffff9b0f244b arch/x86/include/asm/qspinlock.h:53:0
# 4 [ffffb80f2d3c7d68] queued_spin_lock at ffffffff9b8961a6 include/asm-generic/qspinlock.h:90:0
# 5 [ffffb80f2d3c7d68] do_raw_spin_lock_flags at ffffffff9b8961a6 include/linux/spinlock.h:173:0
# 6 [ffffb80f2d3c7d68] __raw_spin_lock_irqsave at ffffffff9b8961a6 include/linux/spinlock_api_smp.h:122:0
# 7 [ffffb80f2d3c7d68] _raw_spin_lock_irqsave at ffffffff9b8961a6 kernel/locking/spinlock.c:160:0
# 8 [ffffb80f2d3c7d88] fw_crash_buffer_store [megaraid_sas] at ffffffffc01f8129 drivers/scsi/megaraid/megaraid_sas_base.c:3205:0
# 9 [ffffb80f2d3c7dc0] dev_attr_store at ffffffff9b56dd7b drivers/base/core.c:758:0
#10 [ffffb80f2d3c7dd0] sysfs_kf_write at ffffffff9b326acf fs/sysfs/file.c:144:0
#11 [ffffb80f2d3c7de0] kernfs_fop_write at ffffffff9b325fd4 fs/kernfs/file.c:316:0
#12 [ffffb80f2d3c7e20] __vfs_write at ffffffff9b29418a fs/read_write.c:480:0
#13 [ffffb80f2d3c7ea8] vfs_write at ffffffff9b294462 fs/read_write.c:544:0
#14 [ffffb80f2d3c7ee8] SYSC_write at ffffffff9b2946ec fs/read_write.c:590:0
#15 [ffffb80f2d3c7ee8] SyS_write at ffffffff9b2946ec fs/read_write.c:582:0
#16 [ffffb80f2d3c7f30] do_syscall_64 at ffffffff9b003ca9 arch/x86/entry/common.c:298:0
#17 [ffffb80f2d3c7f58] entry_SYSCALL_64 at ffffffff9ba001b1 arch/x86/entry/entry_64.S:238:0
The lock is used to synchronize different sysfs operations, it doesn't
protect any resource that will be touched by an interrupt. Consequently
it's not required to disable IRQs. Replace the spinlock with a mutex to fix
the deadlock.
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Link: https://lore.kernel.org/r/20230828221018.19471-1-junxiao.bi@oracle.com
Reviewed-by: Mike Christie <michael.christie@oracle.com>
commit 24e0e61db3cb86a66824531989f1df80e0939f26 upstream.
In AHCI 1.3.1, the register description for CAP.SSC:
"When cleared to ‘0’, software must not allow the HBA to initiate
transitions to the Slumber state via agressive link power management nor
the PxCMD.ICC field in each port, and the PxSCTL.IPM field in each port
must be programmed to disallow device initiated Slumber requests."
In AHCI 1.3.1, the register description for CAP.PSC:
transitions to the Partial state via agressive link power management nor
must be programmed to disallow device initiated Partial requests."
Ensure that we always set the corresponding bits in PxSCTL.IPM, such that
a device is not allowed to initiate transitions to power states which are
unsupported by the HBA.
DevSleep is always initiated by the HBA, however, for completeness, set the
corresponding bit in PxSCTL.IPM such that agressive link power management
cannot transition to DevSleep if DevSleep is not supported.
sata_link_scr_lpm() is used by libahci, ata_piix and libata-pmp.
However, only libahci has the ability to read the CAP/CAP2 register to see
if these features are supported. Therefore, in order to not introduce any
regressions on ata_piix or libata-pmp, create flags that indicate that the
respective feature is NOT supported. This way, the behavior for ata_piix
and libata-pmp should remain unchanged.
This change is based on a patch originally submitted by Runa Guo-oc.
Signed-off-by: Niklas Cassel <niklas.cassel@wdc.com>
Fixes: 1152b2617a6e ("libata: implement sata_link_scr_lpm() and make ata_dev_set_feature() global")
commit fee465150b458351b6d9b9f66084f3cc3022b88b upstream.
Reset the i2c controller when an i2c transfer timeout occurs.
The remaining interrupts and device should be reset to avoid
unpredictable controller behavior.
Fixes: 2e57b7cebb98 ("i2c: aspeed: Add multi-master use case support")
Cc: <stable@vger.kernel.org> # v5.1+
Signed-off-by: Tommy Huang <tommy_huang@aspeedtech.com>
Reviewed-by: Andi Shyti <andi.shyti@kernel.org>
Signed-off-by: Wolfram Sang <wsa@kernel.org>
commit 51aab5ffceb43e05119eb059048fd75765d2bc21 upstream.
The function tracefs_create_dir() was missing a lockdown check and was
called by the RV code. This gave an inconsistent behavior of this function
returning success while other tracefs functions failed. This caused the
inode being freed by the wrong kmem_cache.
Link: https://lkml.kernel.org/r/20230905182711.692687042@goodmis.org
Link: https://lore.kernel.org/all/202309050916.58201dc6-oliver.sang@intel.com/
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ajay Kaher <akaher@vmware.com>
Cc: Ching-lin Yu <chinglinyu@google.com>
Fixes: bf8e602186ec4 ("tracing: Do not create tracefs files if tracefs lockdown is in effect")
Reported-by: kernel test robot <oliver.sang@intel.com>
Signed-off-by: Steven Rostedt (Google) <rostedt@goodmis.org>
commit fdd2630a7398191e84822612e589062063bd4f3d upstream.
nfsd sends the transposed directory change info in the RENAME reply. The
source directory is in save_fh and the target is in current_fh.
Reported-by: Zhi Li <yieli@redhat.com>
Reported-by: Benjamin Coddington <bcodding@redhat.com>
Closes: https://bugzilla.redhat.com/show_bug.cgi?id=2218844
Signed-off-by: Jeff Layton <jlayton@kernel.org>
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit 7e2cfbd2d3c86afcd5c26b5c4b1dd251f63c5838 upstream.
The option files update the options for a given trace array. For an
instance, if the file is opened and the instance is deleted, reading or
writing to the file will cause a use after free.
Up the ref count of the trace_array when an option file is opened.
Link: https://lkml.kernel.org/r/20230907024804.086679464@goodmis.org
Link: https://lore.kernel.org/all/1cb3aee2-19af-c472-e265-05176fe9bd84@huawei.com/
Cc: Zheng Yejian <zhengyejian1@huawei.com>
Fixes: 8530dec63e7b4 ("tracing: Add tracing_check_open_get_tr()")
Tested-by: Naresh Kamboju <naresh.kamboju@linaro.org>
commit 9b37febc578b2e1ad76a105aab11d00af5ec3d27 upstream.
The current_trace updates the trace array tracer. For an instance, if the
file is opened and the instance is deleted, reading or writing to the file
Up the ref count of the trace array when current_trace is opened.
Link: https://lkml.kernel.org/r/20230907024803.877687227@goodmis.org
commit 7d660c9b2bc95107f90a9f4c4759be85309a6550 upstream.
The tracing_max_latency file points to the trace_array max_latency field.
For an instance, if the file is opened and the instance is deleted,
reading or writing to the file will cause a use after free.
Up the ref count of the trace_array when tracing_max_latency is opened.
Link: https://lkml.kernel.org/r/20230907024803.666889383@goodmis.org
commit ee34a82e890a7babb5585daf1a6dd7d4d1cf142a upstream.
During the ino lookup ioctl we can end up calling btrfs_iget() to get an
inode reference while we are holding on a root's btree. If btrfs_iget()
needs to lookup the inode from the root's btree, because it's not
currently loaded in memory, then it will need to lock another or the
same path in the same root btree. This may result in a deadlock and
trigger the following lockdep splat:
WARNING: possible circular locking dependency detected
6.5.0-rc7-syzkaller-00004-gf7757129e3de #0 Not tainted
syz-executor277/5012 is trying to acquire lock:
ffff88802df41710 (btrfs-tree-01){++++}-{3:3}, at: __btrfs_tree_read_lock+0x2f/0x220 fs/btrfs/locking.c:136
but task is already holding lock:
ffff88802df418e8 (btrfs-tree-00){++++}-{3:3}, at: __btrfs_tree_read_lock+0x2f/0x220 fs/btrfs/locking.c:136
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (btrfs-tree-00){++++}-{3:3}:
down_read_nested+0x49/0x2f0 kernel/locking/rwsem.c:1645
btrfs_search_slot+0x13a4/0x2f80 fs/btrfs/ctree.c:2302
btrfs_init_root_free_objectid+0x148/0x320 fs/btrfs/disk-io.c:4955
btrfs_init_fs_root fs/btrfs/disk-io.c:1128 [inline]
btrfs_get_root_ref+0x5ae/0xae0 fs/btrfs/disk-io.c:1338
btrfs_get_fs_root fs/btrfs/disk-io.c:1390 [inline]
open_ctree+0x29c8/0x3030 fs/btrfs/disk-io.c:3494
btrfs_fill_super+0x1c7/0x2f0 fs/btrfs/super.c:1154
btrfs_mount_root+0x7e0/0x910 fs/btrfs/super.c:1519
legacy_get_tree+0xef/0x190 fs/fs_context.c:611
vfs_get_tree+0x8c/0x270 fs/super.c:1519
fc_mount fs/namespace.c:1112 [inline]
vfs_kern_mount+0xbc/0x150 fs/namespace.c:1142
btrfs_mount+0x39f/0xb50 fs/btrfs/super.c:1579
do_new_mount+0x28f/0xae0 fs/namespace.c:3335
do_mount fs/namespace.c:3675 [inline]
__do_sys_mount fs/namespace.c:3884 [inline]
__se_sys_mount+0x2d9/0x3c0 fs/namespace.c:3861
do_syscall_x64 arch/x86/entry/common.c:50 [inline]
do_syscall_64+0x41/0xc0 arch/x86/entry/common.c:80
entry_SYSCALL_64_after_hwframe+0x63/0xcd
-> #0 (btrfs-tree-01){++++}-{3:3}:
check_prev_add kernel/locking/lockdep.c:3142 [inline]
check_prevs_add kernel/locking/lockdep.c:3261 [inline]
validate_chain kernel/locking/lockdep.c:3876 [inline]
__lock_acquire+0x39ff/0x7f70 kernel/locking/lockdep.c:5144
lock_acquire+0x1e3/0x520 kernel/locking/lockdep.c:5761
btrfs_tree_read_lock fs/btrfs/locking.c:142 [inline]
btrfs_read_lock_root_node+0x292/0x3c0 fs/btrfs/locking.c:281
btrfs_search_slot_get_root fs/btrfs/ctree.c:1832 [inline]
btrfs_search_slot+0x4ff/0x2f80 fs/btrfs/ctree.c:2154
btrfs_lookup_inode+0xdc/0x480 fs/btrfs/inode-item.c:412
btrfs_read_locked_inode fs/btrfs/inode.c:3892 [inline]
btrfs_iget_path+0x2d9/0x1520 fs/btrfs/inode.c:5716
btrfs_search_path_in_tree_user fs/btrfs/ioctl.c:1961 [inline]
btrfs_ioctl_ino_lookup_user+0x77a/0xf50 fs/btrfs/ioctl.c:2105
btrfs_ioctl+0xb0b/0xd40 fs/btrfs/ioctl.c:4683
vfs_ioctl fs/ioctl.c:51 [inline]
__do_sys_ioctl fs/ioctl.c:870 [inline]
__se_sys_ioctl+0xf8/0x170 fs/ioctl.c:856
Possible unsafe locking scenario:
CPU0 CPU1
rlock(btrfs-tree-00);
lock(btrfs-tree-01);
rlock(btrfs-tree-01);
*** DEADLOCK ***
1 lock held by syz-executor277/5012:
#0: ffff88802df418e8 (btrfs-tree-00){++++}-{3:3}, at: __btrfs_tree_read_lock+0x2f/0x220 fs/btrfs/locking.c:136
stack backtrace:
CPU: 1 PID: 5012 Comm: syz-executor277 Not tainted 6.5.0-rc7-syzkaller-00004-gf7757129e3de #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 07/26/2023
Call Trace:
<TASK>
__dump_stack lib/dump_stack.c:88 [inline]
dump_stack_lvl+0x1e7/0x2d0 lib/dump_stack.c:106
check_noncircular+0x375/0x4a0 kernel/locking/lockdep.c:2195
RIP: 0033:0x7f0bec94ea39
Fix this simply by releasing the path before calling btrfs_iget() as at
point we don't need the path anymore.
Reported-by: syzbot+bf66ad948981797d2f1d@syzkaller.appspotmail.com
Link: https://lore.kernel.org/linux-btrfs/00000000000045fa140603c4a969@google.com/
Fixes: 23d0b79dfaed ("btrfs: Add unprivileged version of ino_lookup ioctl")
CC: stable@vger.kernel.org # 4.19+
Reviewed-by: Josef Bacik <josef@toxicpanda.com>
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
delayed items
commit e110f8911ddb93e6f55da14ccbbe705397b30d0b upstream.
When running delayed items we are holding a delayed node's mutex and then
we will attempt to modify a subvolume btree to insert/update/delete the
delayed items. However if have an error during the insertions for example,
btrfs_insert_delayed_items() may return with a path that has locked extent
buffers (a leaf at the very least), and then we attempt to release the
delayed node at __btrfs_run_delayed_items(), which requires taking the
delayed node's mutex, causing an ABBA type of deadlock. This was reported
by syzbot and the lockdep splat is the following:
6.5.0-rc7-syzkaller-00024-g93f5de5f648d #0 Not tainted
syz-executor.2/13257 is trying to acquire lock:
ffff88801835c0c0 (&delayed_node->mutex){+.+.}-{3:3}, at: __btrfs_release_delayed_node+0x9a/0xaa0 fs/btrfs/delayed-inode.c:256
ffff88802a5ab8e8 (btrfs-tree-00){++++}-{3:3}, at: __btrfs_tree_lock+0x3c/0x2a0 fs/btrfs/locking.c:198
__lock_release kernel/locking/lockdep.c:5475 [inline]
lock_release+0x36f/0x9d0 kernel/locking/lockdep.c:5781
up_write+0x79/0x580 kernel/locking/rwsem.c:1625
btrfs_tree_unlock_rw fs/btrfs/locking.h:189 [inline]
btrfs_unlock_up_safe+0x179/0x3b0 fs/btrfs/locking.c:239
search_leaf fs/btrfs/ctree.c:1986 [inline]
btrfs_search_slot+0x2511/0x2f80 fs/btrfs/ctree.c:2230
btrfs_insert_empty_items+0x9c/0x180 fs/btrfs/ctree.c:4376
btrfs_insert_delayed_item fs/btrfs/delayed-inode.c:746 [inline]
btrfs_insert_delayed_items fs/btrfs/delayed-inode.c:824 [inline]
__btrfs_commit_inode_delayed_items+0xd24/0x2410 fs/btrfs/delayed-inode.c:1111
__btrfs_run_delayed_items+0x1db/0x430 fs/btrfs/delayed-inode.c:1153
flush_space+0x269/0xe70 fs/btrfs/space-info.c:723
btrfs_async_reclaim_metadata_space+0x106/0x350 fs/btrfs/space-info.c:1078
process_one_work+0x92c/0x12c0 kernel/workqueue.c:2600
worker_thread+0xa63/0x1210 kernel/workqueue.c:2751
kthread+0x2b8/0x350 kernel/kthread.c:389
ret_from_fork+0x2e/0x60 arch/x86/kernel/process.c:145
ret_from_fork_asm+0x11/0x20 arch/x86/entry/entry_64.S:304
-> #0 (&delayed_node->mutex){+.+.}-{3:3}:
__mutex_lock_common+0x1d8/0x2530 kernel/locking/mutex.c:603
__mutex_lock kernel/locking/mutex.c:747 [inline]
mutex_lock_nested+0x1b/0x20 kernel/locking/mutex.c:799
btrfs_release_delayed_node fs/btrfs/delayed-inode.c:281 [inline]
__btrfs_run_delayed_items+0x2b5/0x430 fs/btrfs/delayed-inode.c:1156
btrfs_commit_transaction+0x859/0x2ff0 fs/btrfs/transaction.c:2276
btrfs_sync_file+0xf56/0x1330 fs/btrfs/file.c:1988
vfs_fsync_range fs/sync.c:188 [inline]
vfs_fsync fs/sync.c:202 [inline]
do_fsync fs/sync.c:212 [inline]
__do_sys_fsync fs/sync.c:220 [inline]
__se_sys_fsync fs/sync.c:218 [inline]
__x64_sys_fsync+0x196/0x1e0 fs/sync.c:218
CPU0 CPU1
lock(&delayed_node->mutex);
*** DEADLOCK ***
3 locks held by syz-executor.2/13257:
#0: ffff88802c1ee370 (btrfs_trans_num_writers){++++}-{0:0}, at: spin_unlock include/linux/spinlock.h:391 [inline]
#0: ffff88802c1ee370 (btrfs_trans_num_writers){++++}-{0:0}, at: join_transaction+0xb87/0xe00 fs/btrfs/transaction.c:287
#1: ffff88802c1ee398 (btrfs_trans_num_extwriters){++++}-{0:0}, at: join_transaction+0xbb2/0xe00 fs/btrfs/transaction.c:288
#2: ffff88802a5ab8e8 (btrfs-tree-00){++++}-{3:3}, at: __btrfs_tree_lock+0x3c/0x2a0 fs/btrfs/locking.c:198
stack backtrace:
CPU: 0 PID: 13257 Comm: syz-executor.2 Not tainted 6.5.0-rc7-syzkaller-00024-g93f5de5f648d #0
Call Trace:
<TASK>
RIP: 0033:0x7f3ad047cae9
Code: 28 00 00 00 75 (...)
RSP: 002b:00007f3ad12510c8 EFLAGS: 00000246 ORIG_RAX: 000000000000004a
RAX: ffffffffffffffda RBX: 00007f3ad059bf80 RCX: 00007f3ad047cae9
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000005
RBP: 00007f3ad04c847a R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
R13: 000000000000000b R14: 00007f3ad059bf80 R15: 00007ffe56af92f8
</TASK>
Fix this by releasing the path before releasing the delayed node in the
error path at __btrfs_run_delayed_items().
Reported-by: syzbot+a379155f07c134ea9879@syzkaller.appspotmail.com
Link: https://lore.kernel.org/linux-btrfs/000000000000abba27060403b5bd@google.com/
CC: stable@vger.kernel.org # 4.14+
commit 724768a39374d35b70eaeae8dd87048a2ec7ae8e upstream.
ovl_{read,write}_iter() always call fdput(real) to put one or zero
refcounts of the real file, but for aio, whether it was submitted or not,
ovl_aio_put() also calls fdput(), which is not balanced. This is only a
problem in the less common case when FDPUT_FPUT flag is set.
To fix the problem use get_file() to take file refcount and use fput()
instead of fdput() in ovl_aio_put().
Fixes: 2406a307ac7d ("ovl: implement async IO routines")
Cc: <stable@vger.kernel.org> # v5.6
Reviewed-by: Miklos Szeredi <miklos@szeredi.hu>
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
commit ab048302026d7701e7fbd718917e0dbcff0c4223 upstream.
Some local filesystems support setting persistent fileattr flags
(e.g. FS_NOATIME_FL) on directories and regular files via ioctl.
Some of those persistent fileattr flags are reflected to vfs as
in-memory inode flags (e.g. S_NOATIME).
Overlayfs uses the in-memory inode flags (e.g. S_NOATIME) on a lower file
as an indication that a the lower file may have persistent inode fileattr
flags (e.g. FS_NOATIME_FL) that need to be copied to upper file.
However, in some cases, the S_NOATIME in-memory flag could be a false
indication for persistent FS_NOATIME_FL fileattr. For example, with NFS
and FUSE lower fs, as was the case in the two bug reports, the S_NOATIME
flag is set unconditionally for all inodes.
Users cannot set persistent fileattr flags on symlinks and special files,
but in some local fs, such as ext4/btrfs/tmpfs, the FS_NOATIME_FL fileattr
flag are inheritted to symlinks and special files from parent directory.
In both cases described above, when lower symlink has the S_NOATIME flag,
overlayfs will try to copy the symlink's fileattrs and fail with error
ENOXIO, because it could not open the symlink for the ioctl security hook.
To solve this failure, do not attempt to copyup fileattrs for anything
other than directories and regular files.
Reported-by: Ruiwen Zhao <ruiwen@google.com>
Closes: https://bugzilla.kernel.org/show_bug.cgi?id=217850
Fixes: 72db82115d2b ("ovl: copy up sync/noatime fileattr flags")
Cc: <stable@vger.kernel.org> # v5.15
commit 5d1f903f75a80daa4dfb3d84e114ec8ecbf29956 upstream.
Changing the mode of symlinks is meaningless as the vfs doesn't take the
mode of a symlink into account during path lookup permission checking.
However, the vfs doesn't block mode changes on symlinks. This however,
has lead to an untenable mess roughly classifiable into the following
two categories:
(1) Filesystems that don't implement a i_op->setattr() for symlinks.
Such filesystems may or may not know that without i_op->setattr()
defined, notify_change() falls back to simple_setattr() causing the
inode's mode in the inode cache to be changed.
That's a generic issue as this will affect all non-size changing
inode attributes including ownership changes.
Example: afs
(2) Filesystems that fail with EOPNOTSUPP but change the mode of the
symlink nonetheless.
Some filesystems will happily update the mode of a symlink but still
return EOPNOTSUPP. This is the biggest source of confusion for
userspace.
The EOPNOTSUPP in this case comes from POSIX ACLs. Specifically it
comes from filesystems that call posix_acl_chmod(), e.g., btrfs via
if (!err && attr->ia_valid & ATTR_MODE)
err = posix_acl_chmod(idmap, dentry, inode->i_mode);
Filesystems including btrfs don't implement i_op->set_acl() so
posix_acl_chmod() will report EOPNOTSUPP.
When posix_acl_chmod() is called, most filesystems will have
finished updating the inode.
Perversely, this has the consequences that this behavior may depend
on two kconfig options and mount options:
* CONFIG_POSIX_ACL={y,n}
* CONFIG_${FSTYPE}_POSIX_ACL={y,n}
* Opt_acl, Opt_noacl
Example: btrfs, ext4, xfs
The only way to change the mode on a symlink currently involves abusing
an O_PATH file descriptor in the following manner:
fd = openat(-1, "/path/to/link", O_CLOEXEC | O_PATH | O_NOFOLLOW);
char path[PATH_MAX];
snprintf(path, sizeof(path), "/proc/self/fd/%d", fd);
chmod(path, 0000);
But for most major filesystems with POSIX ACL support such as btrfs,
ext4, ceph, tmpfs, xfs and others this will fail with EOPNOTSUPP with
the mode still updated due to the aforementioned posix_acl_chmod()
nonsense.
So, given that for all major filesystems this would fail with EOPNOTSUPP
and that both glibc (cf. [1]) and musl (cf. [2]) outright block mode
changes on symlinks we should just try and block mode changes on
symlinks directly in the vfs and have a clean break with this nonsense.
If this causes any regressions, we do the next best thing and fix up all
filesystems that do return EOPNOTSUPP with the mode updated to not call
posix_acl_chmod() on symlinks.
But as usual, let's try the clean cut solution first. It's a simple
patch that can be easily reverted. Not marking this for backport as I'll
do that manually if we're reasonably sure that this works and there are
no strong objections.
We could block this in chmod_common() but it's more appropriate to do it
notify_change() as it will also mean that we catch filesystems that
change symlink permissions explicitly or accidently.
Similar proposals were floated in the past as in [3] and [4] and again
recently in [5]. There's also a couple of bugs about this inconsistency
as in [6] and [7].
Link: https://sourceware.org/git/?p=glibc.git;a=blob;f=sysdeps/unix/sysv/linux/fchmodat.c;h=99527a3727e44cb8661ee1f743068f108ec93979;hb=HEAD [1]
Link: https://git.musl-libc.org/cgit/musl/tree/src/stat/fchmodat.c [2]
Link: https://lore.kernel.org/all/20200911065733.GA31579@infradead.org [3]
Link: https://sourceware.org/legacy-ml/libc-alpha/2020-02/msg00518.html [4]
Link: https://lore.kernel.org/lkml/87lefmbppo.fsf@oldenburg.str.redhat.com [5]
Link: https://sourceware.org/legacy-ml/libc-alpha/2020-02/msg00467.html [6]
Link: https://sourceware.org/bugzilla/show_bug.cgi?id=14578#c17 [7]
Reviewed-by: Aleksa Sarai <cyphar@cyphar.com>
Cc: stable@vger.kernel.org # please backport to all LTSes but not before v6.6-rc2 is tagged
Suggested-by: Christoph Hellwig <hch@lst.de>
Suggested-by: Florian Weimer <fweimer@redhat.com>
Message-Id: <20230712-vfs-chmod-symlinks-v2-1-08cfb92b61dd@kernel.org>
Signed-off-by: Christian Brauner <brauner@kernel.org>
[ Upstream commit df203da47f4428bc286fc99318936416253a321c ]
There is a compile error when this commit is added:
md: raid1: fix potential OOB in raid1_remove_disk()
drivers/md/raid1.c: In function 'raid1_remove_disk':
drivers/md/raid1.c:1844:9: error: ISO C90 forbids mixed declarations
and code [-Werror=declaration-after-statement]
1844 | struct raid1_info *p = conf->mirrors + number;
That's because the new code was inserted before the struct.
The change is move the struct command above this commit.
Fixes: 8b0472b50bcf ("md: raid1: fix potential OOB in raid1_remove_disk()")
Signed-off-by: Nigel Croxon <ncroxon@redhat.com>
Signed-off-by: Song Liu <song@kernel.org>
Link: https://lore.kernel.org/r/46d929d0-2aab-4cf2-b2bf-338963e8ba5a@redhat.com
[ Upstream commit b9080468caeddc58a91edd1c3a7d212ea82b0d1d ]
__symbol_put() is really meant as an internal helper and is not available
when module unloading is disabled, unlike the previously used symbol_put():
samples/hw_breakpoint/data_breakpoint.c: In function 'hw_break_module_exit':
samples/hw_breakpoint/data_breakpoint.c:73:9: error: implicit declaration of function '__symbol_put'; did you mean '__symbol_get'? [-Werror=implicit-function-declaration]
The hw_break_module_exit() function is not actually used when module
unloading is disabled, but it still causes the build failure for an
undefined identifier. Enclose this one call in an appropriate #ifdef to
clarify what the requirement is. Leaving out the entire exit function
would also work but feels less clar in this case.
Fixes: 910e230d5f1bb ("samples/hw_breakpoint: Fix kernel BUG 'invalid opcode: 0000'")
Fixes: d8a84d33a4954 ("samples/hw_breakpoint: drop use of kallsyms_lookup_name()")
Reviewed-by: Petr Mladek <pmladek@suse.com>
Signed-off-by: Luis Chamberlain <mcgrof@kernel.org>
[ Upstream commit 75b2f7e4c9e0fd750a5a27ca9736d1daa7a3762a ]
-flto* implies -ffunction-sections. With LTO enabled, ld.lld generates
multiple .text sections for purgatory.ro:
$ readelf -S purgatory.ro | grep " .text"
[ 1] .text PROGBITS 0000000000000000 00000040
[ 7] .text.purgatory PROGBITS 0000000000000000 000020e0
[ 9] .text.warn PROGBITS 0000000000000000 000021c0
[13] .text.sha256_upda PROGBITS 0000000000000000 000022f0
[15] .text.sha224_upda PROGBITS 0000000000000000 00002be0
[17] .text.sha256_fina PROGBITS 0000000000000000 00002bf0
[19] .text.sha224_fina PROGBITS 0000000000000000 00002cc0
This causes WARNING from kexec_purgatory_setup_sechdrs():
WARNING: CPU: 26 PID: 110894 at kernel/kexec_file.c:919
kexec_load_purgatory+0x37f/0x390
Fix this by disabling LTO for purgatory.
[ AFAICT, x86 is the only arch that supports LTO and purgatory. ]
We could also fix this with an explicit linker script to rejoin .text.*
sections back into .text. However, given the benefit of LTOing purgatory
is small, simply disable the production of more .text.* sections for now.
Fixes: b33fff07e3e3 ("x86, build: allow LTO to be selected")
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Sami Tolvanen <samitolvanen@google.com>
Link: https://lore.kernel.org/r/20230914170138.995606-1-song@kernel.org
[ Upstream commit f530ee95b72e77b09c141c4b1a4b94d1199ffbd9 ]
The decompressor has a hard limit on the number of page tables it can
allocate. This limit is defined at compile-time and will cause boot
failure if it is reached.
The kernel is very strict and calculates the limit precisely for the
worst-case scenario based on the current configuration. However, it is
easy to forget to adjust the limit when a new use-case arises. The
worst-case scenario is rarely encountered during sanity checks.
In the case of enabling 5-level paging, a use-case was overlooked. The
limit needs to be increased by one to accommodate the additional level.
This oversight went unnoticed until Aaron attempted to run the kernel
via kexec with 5-level paging and unaccepted memory enabled.
Update wost-case calculations to include 5-level paging.
To address this issue, let's allocate some extra space for page tables.
128K should be sufficient for any use-case. The logic can be simplified
by using a single value for all kernel configurations.
[ Also add a warning, should this memory run low - by Dave Hansen. ]
Fixes: 34bbb0009f3b ("x86/boot/compressed: Enable 5-level paging during decompression stage")
Reported-by: Aaron Lu <aaron.lu@intel.com>
Link: https://lore.kernel.org/r/20230915070221.10266-1-kirill.shutemov@linux.intel.com
[ Upstream commit 7dcc683db3639eadd11bf0d59a09088a43de5e22 ]
Since debugfs_create_file() returns ERR_PTR and never NULL, use IS_ERR() to
check the return value.
Fixes: 2fcbc569b9f5 ("scsi: lpfc: Make debugfs ktime stats generic for NVME and SCSI")
Fixes: 4c47efc140fa ("scsi: lpfc: Move SCSI and NVME Stats to hardware queue structures")
Fixes: 6a828b0f6192 ("scsi: lpfc: Support non-uniform allocation of MSIX vectors to hardware queues")
Fixes: 95bfc6d8ad86 ("scsi: lpfc: Make FW logging dynamically configurable")
Fixes: 9f77870870d8 ("scsi: lpfc: Add debugfs support for cm framework buffers")
Fixes: c490850a0947 ("scsi: lpfc: Adapt partitioned XRI lists to efficient sharing")
Signed-off-by: Jinjie Ruan <ruanjinjie@huawei.com>
Link: https://lore.kernel.org/r/20230906030809.2847970-1-ruanjinjie@huawei.com
Reviewed-by: Justin Tee <justin.tee@broadcom.com>
[ Upstream commit 7e021da80f48582171029714f8a487347f29dddb ]
Fix to unmount the tracefs if the ftracetest mounted it for recovering
system environment. If the tracefs is already mounted, this does nothing.
Suggested-by: Mark Brown <broonie@kernel.org>
Link: https://lore.kernel.org/all/29fce076-746c-4650-8358-b4e0fa215cf7@sirena.org.uk/
Fixes: cbd965bde74c ("ftrace/selftests: Return the skip code when tracing directory not configured in kernel")
Signed-off-by: Masami Hiramatsu (Google) <mhiramat@kernel.org>
Reviewed-by: Steven Rostedt (Google) <rostedt@goodmis.org>
Reviewed-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Shuah Khan <skhan@linuxfoundation.org>
[ Upstream commit d0b0822e32dbae80bbcb3cc86f34d28539d913df ]
Since both debugfs_create_dir() and debugfs_create_file() return ERR_PTR
and never NULL, use IS_ERR() instead of checking for NULL.
Fixes: 1e98fb0f9208 ("scsi: qla2xxx: Setup debugfs entries for remote ports")
Link: https://lore.kernel.org/r/20230831140930.3166359-1-ruanjinjie@huawei.com
[ Upstream commit 7583028d359db3cd0072badcc576b4f9455fd27a ]
The timeout arg of usb_bulk_msg() is ms already, which has been converted
to jiffies by msecs_to_jiffies() in usb_start_wait_urb(). So fix the usage
by removing the redundant msecs_to_jiffies() in the macros.
And as Hans suggested, also remove msecs_to_jiffies() for the IDLE_TIMEOUT
macro to make it consistent here and so change IDLE_TIMEOUT to
msecs_to_jiffies(IDLE_TIMEOUT) where it is used.
Fixes: e4f86e437164 ("drm: Add Grain Media GM12U320 driver v2")
Suggested-by: Hans de Goede <hdegoede@redhat.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Thomas Zimmermann <tzimmermann@suse.de>
Link: https://patchwork.freedesktop.org/patch/msgid/20230904021421.1663892-1-ruanjinjie@huawei.com
[ Upstream commit 6bfe3959b0e7a526f5c64747801a8613f002f05a ]
The function btrfs_validate_super() should verify the metadata_uuid in
the provided superblock argument. Because, all its callers expect it to
do that.
Such as in the following stacks:
write_all_supers()
sb = fs_info->super_for_commit;
btrfs_validate_write_super(.., sb)
btrfs_validate_super(.., sb, ..)
scrub_one_super()
And
check_dev_super()
However, it currently verifies the fs_info::super_copy::metadata_uuid
instead. Fix this using the correct metadata_uuid in the superblock
argument.
CC: stable@vger.kernel.org # 5.4+
Reviewed-by: Johannes Thumshirn <johannes.thumshirn@wdc.com>
Tested-by: Guilherme G. Piccoli <gpiccoli@igalia.com>
Signed-off-by: Anand Jain <anand.jain@oracle.com>
