This original code in nfsd4_get_drc_mem() would hand out 30
slots (approximately NFSD_MAX_MEM_PER_SESSION bytes at slightly
over 2K per slot) to each requesting client until it ran out
of space, then it would possibly give one last client a reduced
allocation, then fail the allocation.
Since commit de766e570413 ("nfsd: give out fewer session slots as
limit approaches") the last 90 slots to be given to about 12
clients with quickly reducing slot counts (better than just 3
clients). This still seems unnecessarily hasty.
A subsequent patch allows over-allocation so every client gets
at least one slot, but that might be a bit restrictive.
The requested number of nfsd threads is the best guide we have to the
expected number of clients, so use that - if it is at least 8.
256 threads on a 256Meg machine - which is a lot for a tiny machine -
would result in nfsd_drc_max_mem being 2Meg, so 8K (3 slots) would be
available for the first client, and over 200 clients would get more
than 1 slot. So I don't think this change will be too debilitating on
poorly configured machines, though it does mean that a sensible
configuration is a little more important.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Currently, if there are more clients than allowed for by the
space allocation in set_max_drc(), we fail a SESSION_CREATE
request with NFS4ERR_DELAY.
This means that the client retries indefinitely, which isn't
a user-friendly response.
The RFC requires NFS4ERR_NOSPC, but that would at best result in a
clean failure on the client, which is not much more friendly.
The current space allocation is a best-guess and doesn't provide any
guarantees, we could still run out of space when trying to allocate
drc space.
So fail more gracefully - always give out at least one slot.
If all clients used all the space in all slots, we might start getting
memory pressure, but that is possible anyway.
So ensure 'num' is always at least 1, and remove the test for it
being zero.
Version 2 upcalls will allow the nfsd to include a hash of the kerberos
principal string in the Cld_Create upcall. If a principal is present in
the svc_cred, then the hash will be included in the Cld_Create upcall.
We attempt to use the svc_cred.cr_raw_principal (which is returned by
gssproxy) first, and then fall back to using the svc_cred.cr_principal
(which is returned by both gssproxy and rpc.svcgssd). Upon a subsequent
restart, the hash will be returned in the Cld_Gracestart downcall and
stored in the reclaim_str_hashtbl so it can be used when handling
reclaim opens.
Signed-off-by: Scott Mayhew <smayhew@redhat.com>
Add a "GetVersion" upcall to allow nfsd to determine the maximum upcall
version that the nfsdcld userspace daemon supports. If the daemon
responds with -EOPNOTSUPP, then we know it only supports v1.
If multiple clients are writing to the same file, then due to the fact
we share a single file descriptor between all NFSv3 clients writing
to the file, we have a situation where clients can miss the fact that
their file data was not persisted. While this should be rare, it
could cause silent data loss in situations where multiple clients
are using NLM locking or O_DIRECT to write to the same file.
Unfortunately, the stateless nature of NFSv3 and the fact that we
can only identify clients by their IP address means that we cannot
trivially cache errors; we would not know when it is safe to
release them from the cache.
So the solution is to declare a reboot. We understand that this
should be a rare occurrence, since disks are usually stable. The
most frequent occurrence is likely to be ENOSPC, at which point
all writes to the given filesystem are likely to fail anyway.
So the expectation is that clients will be forced to retry their
writes until they hit the fatal error.
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
If a file may contain unstable writes that can error out, then we want
to avoid garbage collecting the struct nfsd_file that may be
tracking those errors.
So in the garbage collector, we try to avoid collecting files that aren't
clean. Furthermore, we avoid immediately kicking off the garbage collector
in the case where the reference drops to zero for the case where there
is a write error that is being tracked.
If the file is unhashed while an error is pending, then declare a
reboot, to ensure the client resends any unstable writes.
Add support to allow the server to reset the boot verifier in order to
force clients to resend I/O after a timeout failure.
Signed-off-by: Lance Shelton <lance.shelton@hammerspace.com>
Ensure that we can safely clear out the file cache entries when the
nfs server is shut down on a container. Otherwise, the file cache
may end up pinning the mounts.
We're unnecessarily limiting the size of an ACL to less than what most
filesystems will support. Some users do hit the limit and it's
confusing and unnecessary.
It still seems prudent to impose some limit on the number of ACEs the
client gives us before passing it straight to kmalloc(). So, let's just
limit it to the maximum number that would be possible given the amount
of data left in the argument buffer.
That will still leave one limit beyond whatever the filesystem imposes:
the client and server negotiate a limit on the size of a request, which
we have to respect.
But we're no longer imposing any additional arbitrary limit.
struct nfs4_ace is 20 bytes on my system and the maximum call size we'll
negotiate is about a megabyte, so in practice this is limiting the
allocation here to about a megabyte.
Reported-by: "de Vandiere, Louis" <louis.devandiere@atos.net>
This is only useful for client testing. I haven't really maintained it,
and reference counting and locking are wrong at this point. You can get
some of the same functionality now from nfsd/clients/.
It was a good idea but I think its time has passed.
In the unlikely event of users, hopefully the BROKEN dependency will
prompt them to speak up. Otherwise I expect to remove it soon.
Reported-by: Alex Lyakas <alex@zadara.com>
Remove duplicated include.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
It's not uncommon for some workloads to do a bunch of I/O to a file and
delete it just afterward. If knfsd has a cached open file however, then
the file may still be open when the dentry is unlinked. If the
underlying filesystem is nfs, then that could trigger it to do a
sillyrename.
On a REMOVE or RENAME scan the nfsd_file cache for open files that
correspond to the inode, and proactively unhash and put their
references. This should prevent any delete-on-last-close activity from
occurring, solely due to knfsd's open file cache.
This must be done synchronously though so we use the variants that call
flush_delayed_fput. There are deadlock possibilities if you call
flush_delayed_fput while holding locks, however. In the case of
nfsd_rename, we don't even do the lookups of the dentries to be renamed
until we've locked for rename.
Once we've figured out what the target dentry is for a rename, check to
see whether there are cached open files associated with it. If there
are, then unwind all of the locking, close them all, and then reattempt
the rename.
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
The raparms cache was set up in order to ensure that we carry readahead
information forward from one RPC call to the next. In other words, it
was set up because each RPC call was forced to open a struct file, then
close it, causing the loss of readahead information that is normally
cached in that struct file, and used to keep the page cache filled when
a user calls read() multiple times on the same file descriptor.
Now that we cache the struct file, and reuse it for all the I/O calls
to a given file by a given user, we no longer have to keep a separate
readahead cache.
Have nfs4_preprocess_stateid_op pass back a nfsd_file instead of a filp.
Since we now presume that the struct file will be persistent in most
cases, we can stop fiddling with the raparms in the read code. This
also means that we don't really care about the rd_tmp_file field
anymore.
Have them keep an nfsd_file reference instead of a struct file.
Use cached filps if possible instead of opening a new one every time.
Currently, NFSv2/3 reads and writes have to open a file, do the read or
write and then close it again for each RPC. This is highly inefficient,
especially when the underlying filesystem has a relatively slow open
routine.
This patch adds a new open file cache to knfsd. Rather than doing an
open for each RPC, the read/write handlers can call into this cache to
see if there is one already there for the correct filehandle and
NFS_MAY_READ/WRITE flags.
If there isn't an entry, then we create a new one and attempt to
perform the open. If there is, then we wait until the entry is fully
instantiated and return it if it is at the end of the wait. If it's
not, then we attempt to take over construction.
Since the main goal is to speed up NFSv2/3 I/O, we don't want to
close these files on last put of these objects. We need to keep them
around for a little while since we never know when the next READ/WRITE
will come in.
Cache entries have a hardcoded 1s timeout, and we have a recurring
workqueue job that walks the cache and purges any entries that have
expired.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
Signed-off-by: Richard Sharpe <richard.sharpe@primarydata.com>
Allow knfsd to flush the delayed fput list so that it can ensure the
cached struct file is closed before it is unlinked.
The knfsd file cache will need to detect when files are unlinked, so that
it can close the associated cached files. Export a minimal set of notifier
functions to allow it to do so.
With the new file caching infrastructure in nfsd, we can end up holding
files open for an indefinite period of time, even when they are still
idle. This may prevent the kernel from handing out leases on the file,
which is something we don't want to block.
Fix this by running a SRCU notifier call chain whenever on any
lease attempt. nfsd can then purge the cache for that inode before
returning.
Since SRCU is only conditionally compiled in, we must only define the
new chain if it's enabled, and users of the chain must ensure that
SRCU is enabled.
When the exports table is changed, exportfs will usually write a new
time to the "flush" file in the nfsd.export cache procfile. This tells
the kernel to flush any entries that are older than that value.
This gives us a mechanism to tell whether an unexport might have
occurred. Add a new ->flush cache_detail operation that is called after
flushing the cache whenever someone writes to a "flush" file.
Use a wait-free mechanism for managing the svc_rdma_recv_ctxts free
list. Subsequently, sc_recv_lock can be eliminated.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Clean up: the system workqueue will work just as well.
"cb" is never actually NULL in these functions.
On a quick skim of the history, they seem to have been there from the
beginning. I'm not sure if they originally served a purpose.
Reported-by: Jia-Ju Bai <baijiaju1990@gmail.com>
These are some nfsd bugfixes that I also want in the main branch that
will be submitted for the 5.4 merge window.
reply_cache_stats uses wrong parameter as seq file private structure and
thus causes the following kernel crash when users read
/proc/fs/nfsd/reply_cache_stats
BUG: kernel NULL pointer dereference, address: 00000000000001f9
PGD 0 P4D 0
Oops: 0000 [#3] SMP PTI
CPU: 6 PID: 1502 Comm: cat Tainted: G D 5.3.0-rc3+ #1
Hardware name: Intel Corporation Broadwell Client platform/Basking Ridge, BIOS BDW-E2R1.86C.0118.R01.1503110618 03/11/2015
RIP: 0010:nfsd_reply_cache_stats_show+0x3b/0x2d0
Code: 41 54 49 89 f4 48 89 fe 48 c7 c7 b3 10 33 88 53 bb e8 03 00 00 e8 88 82 d1 ff bf 58 89 41 00 e8 eb c5 85 00 48 83 eb 01 75 f0 <41> 8b 94 24 f8 01 00 00 48 c7 c6 be 10 33 88 4c 89 ef bb e8 03 00
RSP: 0018:ffffaa520106fe08 EFLAGS: 00010246
RAX: 000000cfe1a77123 RBX: 0000000000000000 RCX: 0000000000291b46
RDX: 000000cf00000000 RSI: 0000000000000006 RDI: 0000000000291b28
RBP: ffffaa520106fe20 R08: 0000000000000006 R09: 000000cfe17e55dd
R10: ffffa424e47c0000 R11: 000000000000030b R12: 0000000000000001
R13: ffffa424e5697000 R14: 0000000000000001 R15: ffffa424e5697000
FS: 00007f805735f580(0000) GS:ffffa424f8f80000(0000) knlGS:0000000000000000
CR2: 00000000000001f9 CR3: 00000000655ce005 CR4: 00000000003606e0
Call Trace:
seq_read+0x194/0x3e0
__vfs_read+0x1b/0x40
vfs_read+0x95/0x140
ksys_read+0x61/0xe0
__x64_sys_read+0x1a/0x20
do_syscall_64+0x4d/0x120
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x7f805728b861
Code: fe ff ff 50 48 8d 3d 86 b4 09 00 e8 79 e0 01 00 66 0f 1f 84 00 00 00 00 00 48 8d 05 d9 19 0d 00 8b 00 85 c0 75 13 31 c0 0f 05 <48> 3d 00 f0 ff ff 77 57 c3 66 0f 1f 44 00 00 48 83 ec 28 48 89 54
RSP: 002b:00007ffea1ce3c38 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
RAX: ffffffffffffffda RBX: 0000000000020000 RCX: 00007f805728b861
RDX: 0000000000020000 RSI: 00007f8057183000 RDI: 0000000000000003
RBP: 00007f8057183000 R08: 00007f8057182010 R09: 0000000000000000
R10: 0000000000000022 R11: 0000000000000246 R12: 0000559a60e8ff10
R13: 0000000000000003 R14: 0000000000020000 R15: 0000000000020000
Modules linked in:
---[ end trace 01613595153f0cba ]---
RSP: 0018:ffffaa52004b3e08 EFLAGS: 00010246
RAX: 0000002bab45a7c6 RBX: 0000000000000000 RCX: 0000000000291b4c
RDX: 0000002b00000000 RSI: 0000000000000004 RDI: 0000000000291b28
RBP: ffffaa52004b3e20 R08: 0000000000000004 R09: 0000002bab1c8c7a
R10: ffffa424e5500000 R11: 00000000000002a9 R12: 0000000000000001
R13: ffffa424e4475000 R14: 0000000000000001 R15: ffffa424e4475000
Killed
Fixes: 3ba75830ce17 ("nfsd4: drc containerization")
Signed-off-by: He Zhe <zhe.he@windriver.com>
A process could race in an open and attempt to read one of these files
before i_private is initialized, and get a spurious error.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
synchronize_rcu() gets called multiple times each time a client is
destroyed. If the laundromat thread has a lot of clients to destroy,
the delay can be noticeable. This was causing pynfs test RENEW3 to
fail.
We could embed an rcu_head in each inode and do the kref_put in an rcu
callback. But simplest is just to take a lock here.
(I also wonder if the laundromat thread would be better replaced by a
bunch of scheduled work or timers or something.)
syzbot is reporting that nfsd_mkdir() forgot to remove dentry created by
d_alloc_name() when __nfsd_mkdir() failed (due to memory allocation fault
injection) [1].
[1] https://syzkaller.appspot.com/bug?id=ce41a1f769ea4637ebffedf004a803e8405b4674
Reported-by: syzbot <syzbot+2c95195d5d433f6ed6cb@syzkaller.appspotmail.com>
Fixes: e8a79fb14f6b76b5 ("nfsd: add nfsd/clients directory")
[bfields: clean up in nfsd_mkdir instead of __nfsd_mkdir]
The sunrpc cache interface is susceptible to being fooled by a rogue
process just reading a 'channel' file. If this happens the kernel
may think a valid daemon exists to service the cache when it does not.
For example, the following may fool the kernel:
cat /proc/net/rpc/auth.unix.gid/channel
Change the tracking of readers to writers when considering whether a
listener exists as all valid daemon processes either open a channel
file O_RDWR or O_WRONLY. While this does not prevent a rogue process
from "stealing" a message from the kernel, it does at least improve
the kernels perception of whether a valid process servicing the cache
exists.
Signed-off-by: Dave Wysochanski <dwysocha@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull structleak fix from Kees Cook:
"Disable gcc-based stack variable auto-init under KASAN (Arnd
Bergmann).
This fixes a bunch of build warnings under KASAN and the
gcc-plugin-based stack auto-initialization features (which are
arguably redundant, so better to let KASAN control this)"
* tag 'meminit-v5.3-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
structleak: disable STRUCTLEAK_BYREF in combination with KASAN_STACK
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild fixes from Masahiro Yamada:
- add compile_commands.json to .gitignore
- fix false-positive warning from gen_compile_commands.py after
allnoconfig build
- remove unused code
* tag 'kbuild-fixes-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kbuild: remove unused single-used-m
gen_compile_commands: lower the entry count threshold
.gitignore: Add compilation database file
kbuild: remove unused objectify macro
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are some small char and misc driver fixes for 5.3-rc2 to resolve
some reported issues.
Nothing major at all, some binder bugfixes for issues found, some new
mei device ids, firmware building warning fixes, habanalabs fixes, a
few other build fixes, and a MAINTAINERS update.
All of these have been in linux-next with no reported issues"
* tag 'char-misc-5.3-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
test_firmware: fix a memory leak bug
hpet: Fix division by zero in hpet_time_div()
eeprom: make older eeprom drivers select NVMEM_SYSFS
vmw_balloon: Remove Julien from the maintainers list
fpga-manager: altera-ps-spi: Fix build error
mei: me: add mule creek canyon (EHL) device ids
binder: prevent transactions to context manager from its own process.
binder: Set end of SG buffer area properly.
firmware: Fix missing inline
firmware: fix build errors in paged buffer handling code
habanalabs: don't reset device when getting VRHOT
habanalabs: use %pad for printing a dma_addr_t
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty fixes from Greg KH:
"Here are two tty/vt fixes:
- delete the netx-serial driver as the arch has been removed, no need
to keep the serial driver for it around either.
- vt console_lock fix to resolve a reported noisy warning at runtime
Both of these have been in linux-next with no reported issues"
* tag 'tty-5.3-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
vt: Grab console_lock around con_is_bound in show_bind
tty: serial: netx: Delete driver
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/spdx
Pull SPDX fixes from Greg KH:
"Here are some small SPDX fixes for 5.3-rc2 for things that came in
during the 5.3-rc1 merge window that we previously missed.
Only three small patches here:
- two uapi patches to resolve some SPDX tags that were not correct
- fix an invalid SPDX tag in the iomap Makefile file
All have been properly reviewed on the public mailing lists"
* tag 'spdx-5.3-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/spdx:
iomap: fix Invalid License ID
treewide: remove SPDX "WITH Linux-syscall-note" from kernel-space headers again
treewide: add "WITH Linux-syscall-note" to SPDX tag of uapi headers
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some small fixes for 5.3-rc2. All of these resolve some
reported issues, some more than others :)
Included in here is:
- xhci fix for an annoying issue with odd devices
- reversion of some usb251xb patches that should not have been merged
- usb pci quirk additions and fixups
- usb storage fix
- usb host controller error test fix
* tag 'usb-5.3-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
xhci: Fix crash if scatter gather is used with Immediate Data Transfer (IDT).
usb: usb251xb: Reallow swap-dx-lanes to apply to the upstream port
Revert "usb: usb251xb: Add US port lanes inversion property"
Revert "usb: usb251xb: Add US lanes inversion dts-bindings"
usb: wusbcore: fix unbalanced get/put cluster_id
usb/hcd: Fix a NULL vs IS_ERR() bug in usb_hcd_setup_local_mem()
usb-storage: Add a limitation for blk_queue_max_hw_sectors()
usb: pci-quirks: Minor cleanup for AMD PLL quirk
usb: pci-quirks: Correct AMD PLL quirk detection
git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc
Pull ARM SoC fixes from Olof Johansson:
"Here's the first batch of fixes for this release cycle.
Main diffstat here is the re-deletion of netx. I messed up and most
likely didn't remove the files from the index when I test-merged this
and saw conflicts, and from there on out 'git rerere' remembered the
mistake and I missed checking it. Here it's done again as expected.
Besides that:
- A defconfig refresh + enabling of new drivers for u8500
- i.MX fixlets for i2c/SAI/pinmux
- sleep.S build fix for Davinci
- Broadcom devicetree build/warning fix"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc:
ARM: defconfig: u8500: Add new drivers
ARM: defconfig: u8500: Refresh defconfig
ARM: dts: bcm: bcm47094: add missing #cells for mdio-bus-mux
ARM: davinci: fix sleep.S build error on ARMv4
arm64: dts: imx8mq: fix SAI compatible
arm64: dts: imx8mm: Correct SAI3 RXC/TXFS pin's mux option #1
ARM: dts: imx6ul: fix clock frequency property name of I2C buses
ARM: Delete netx a second time
ARM: dts: imx7ulp: Fix usb-phy unit address format
Pull x86 fixes from Thomas Gleixner:
"A set of x86 fixes and functional updates:
- Prevent stale huge I/O TLB mappings on 32bit. A long standing bug
which got exposed by KPTI support for 32bit
- Prevent bogus access_ok() warnings in arch_stack_walk_user()
- Add display quirks for Lenovo devices which have height and width
swapped
- Add the missing CR2 fixup for 32 bit async pagefaults. Fallout of
the CR2 bug fix series.
- Unbreak handling of force enabled HPET by moving the 'is HPET
counting' check back to the original place.
- A more accurate check for running on a hypervisor platform in the
MDS mitigation code. Not perfect, but more accurate than the
previous one.
- Update a stale and confusing comment vs. IRQ stacks"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/speculation/mds: Apply more accurate check on hypervisor platform
x86/hpet: Undo the early counter is counting check
x86/entry/32: Pass cr2 to do_async_page_fault()
x86/irq/64: Update stale comment
x86/sysfb_efi: Add quirks for some devices with swapped width and height
x86/stacktrace: Prevent access_ok() warnings in arch_stack_walk_user()
mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()
x86/mm: Sync also unmappings in vmalloc_sync_all()
x86/mm: Check for pfn instead of page in vmalloc_sync_one()
Pull scheduler fixes from Thomas Gleixner:
"Two fixes for the fair scheduling class:
- Prevent freeing memory which is accessible by concurrent readers
- Make the RCU annotations for numa groups consistent"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/fair: Use RCU accessors consistently for ->numa_group
sched/fair: Don't free p->numa_faults with concurrent readers
Pull perf fixes from Thomas Gleixner:
"A pile of perf related fixes:
Kernel:
- Fix SLOTS PEBS event constraints for Icelake CPUs
- Add the missing mask bit to allow counting hardware generated
prefetches on L3 for Icelake CPUs
- Make the test for hypervisor platforms more accurate (as far as
possible)
- Handle PMUs correctly which override event->cpu
- Yet another missing fallthrough annotation
Tools:
perf.data:
- Fix loading of compressed data split across adjacent records
- Fix buffer size setting for processing CPU topology perf.data
header.
perf stat:
- Fix segfault for event group in repeat mode
- Always separate "stalled cycles per insn" line, it was being
appended to the "instructions" line.
perf script:
- Fix --max-blocks man page description.
- Improve man page description of metrics.
- Fix off by one in brstackinsn IPC computation.
perf probe:
- Avoid calling freeing routine multiple times for same pointer.
perf build:
- Do not use -Wshadow on gcc < 4.8, avoiding too strict warnings
treated as errors, breaking the build"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel: Mark expected switch fall-throughs
perf/core: Fix creating kernel counters for PMUs that override event->cpu
perf/x86: Apply more accurate check on hypervisor platform
perf/x86/intel: Fix invalid Bit 13 for Icelake MSR_OFFCORE_RSP_x register
perf/x86/intel: Fix SLOTS PEBS event constraint
perf build: Do not use -Wshadow on gcc < 4.8
perf probe: Avoid calling freeing routine multiple times for same pointer
perf probe: Set pev->nargs to zero after freeing pev->args entries
perf session: Fix loading of compressed data split across adjacent records
perf stat: Always separate stalled cycles per insn
perf stat: Fix segfault for event group in repeat mode
perf tools: Fix proper buffer size for feature processing
perf script: Fix off by one in brstackinsn IPC computation
perf script: Improve man page description of metrics
perf script: Fix --max-blocks man page description
Pull locking fixes from Thomas Gleixner:
"A set of locking fixes:
- Address the fallout of the rwsem rework. Missing ACQUIREs and a
sanity check to prevent a use-after-free
- Add missing checks for unitialized mutexes when mutex debugging is
enabled.
- Remove the bogus code in the generic SMP variant of
arch_futex_atomic_op_inuser()
- Fixup the #ifdeffery in lockdep to prevent compile warnings"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking/mutex: Test for initialized mutex
locking/lockdep: Clean up #ifdef checks
locking/lockdep: Hide unused 'class' variable
locking/rwsem: Add ACQUIRE comments
tty/ldsem, locking/rwsem: Add missing ACQUIRE to read_failed sleep loop
lcoking/rwsem: Add missing ACQUIRE to read_slowpath sleep loop
locking/rwsem: Add missing ACQUIRE to read_slowpath exit when queue is empty
locking/rwsem: Don't call owner_on_cpu() on read-owner
futex: Cleanup generic SMP variant of arch_futex_atomic_op_inuser()
Pull objtool fix from Thomas Gleixner:
"A single robustness fix for objtool to handle unbalanced CLAC
invocations under all circumstances"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
objtool: Improve UACCESS coverage
git://git.kernel.org/pub/scm/linux/kernel/git/gustavoars/linux
Pull Wimplicit-fallthrough enablement from Gustavo A. R. Silva:
"This marks switch cases where we are expecting to fall through, and
globally enables the -Wimplicit-fallthrough option in the main
Makefile.
Finally, some missing-break fixes that have been tagged for -stable:
- drm/amdkfd: Fix missing break in switch statement
- drm/amdgpu/gfx10: Fix missing break in switch statement
With these changes, we completely get rid of all the fall-through
warnings in the kernel"
* tag 'Wimplicit-fallthrough-5.3-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gustavoars/linux:
Makefile: Globally enable fall-through warning
drm/i915: Mark expected switch fall-throughs
drm/amd/display: Mark expected switch fall-throughs
drm/amdkfd/kfd_mqd_manager_v10: Avoid fall-through warning
mtd: onenand_base: Mark expected switch fall-through
afs: fsclient: Mark expected switch fall-throughs
afs: yfsclient: Mark expected switch fall-throughs
can: mark expected switch fall-throughs
firewire: mark expected switch fall-throughs
