2020-09-14mmc: mmc_spi: Fix mmc_spi_dma_alloc() return type for !HAS_DMAGeert Uytterhoeven
If CONFIG_NO_DMA=y (e.g. Sun-3 allmodconfig): drivers/mmc/host/mmc_spi.c:1323:15: warning: return type defaults to ‘int’ [-Wreturn-type] static inline mmc_spi_dma_alloc(struct mmc_spi_host *host) { return 0; } ^~~~~~~~~~~~~~~~~ Fix this by adding the missing return type. Fixes: a395acf0f6dc6409 ("mmc: mmc_spi: Allow the driver to be built when CONFIG_HAS_DMA is unset") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Link: https://lore.kernel.org/r/20200914094243.3912-1-geert@linux-m68k.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2020-09-07mmc: sdio: Use mmc_pre_req() / mmc_post_req()Adrian Hunter
SDHCI changed from using a tasklet to finish requests, to using an IRQ thread i.e. commit c07a48c2651965 ("mmc: sdhci: Remove finish_tasklet"). Because this increased the latency to complete requests, a preparatory change was made to complete the request from the IRQ handler if possible i.e. commit 19d2f695f4e827 ("mmc: sdhci: Call mmc_request_done() from IRQ handler if possible"). That alleviated the situation for MMC block devices because the MMC block driver makes use of mmc_pre_req() and mmc_post_req() so that successful requests are completed in the IRQ handler and any DMA unmapping is handled separately in mmc_post_req(). However SDIO was still affected, and an example has been reported with up to 20% degradation in performance. Looking at SDIO I/O helper functions, sdio_io_rw_ext_helper() appeared to be a possible candidate for making use of asynchronous requests within its I/O loops, but analysis revealed that these loops almost never iterate more than once, so the complexity of the change would not be warrented. Instead, mmc_pre_req() and mmc_post_req() are added before and after I/O submission (mmc_wait_for_req) in mmc_io_rw_extended(). This still has the potential benefit of reducing the duration of interrupt handlers, as well as addressing the latency issue for SDHCI. It also seems a more reasonable solution than forcing drivers to do everything in the IRQ handler. Reported-by: Dmitry Osipenko <digetx@gmail.com> Fixes: c07a48c2651965 ("mmc: sdhci: Remove finish_tasklet") Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Dmitry Osipenko <digetx@gmail.com> Cc: stable@vger.kernel.org Link: https://lore.kernel.org/r/20200903082007.18715-1-adrian.hunter@intel.com Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2020-09-07mmc: sdhci-of-esdhc: Don't walk device-tree on every interruptChris Packham
Commit b214fe592ab7 ("mmc: sdhci-of-esdhc: add erratum eSDHC7 support") added code to check for a specific compatible string in the device-tree on every esdhc interrupat. Instead of doing this record the quirk in struct sdhci_esdhc and lookup the struct in esdhc_irq. Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Link: https://lore.kernel.org/r/20200903012029.25673-1-chris.packham@alliedtelesis.co.nz Fixes: b214fe592ab7 ("mmc: sdhci-of-esdhc: add erratum eSDHC7 support") Cc: stable@vger.kernel.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2020-09-07mmc: mmc_spi: Allow the driver to be built when CONFIG_HAS_DMA is unsetUlf Hansson
The commit cd57d07b1e4e ("sh: don't allow non-coherent DMA for NOMMU") made CONFIG_NO_DMA to be set for some platforms, for good reasons. Consequentially, CONFIG_HAS_DMA doesn't get set, which makes the DMA mapping interface to be built as stub functions, but also prevent the mmc_spi driver from being built as it depends on CONFIG_HAS_DMA. It turns out that for some odd cases, the driver still relied on the DMA mapping interface, even if the DMA was not actively being used. To fixup the behaviour, let's drop the build dependency for CONFIG_HAS_DMA. Moreover, as to allow the driver to succeed probing, let's move the DMA initializations behind "#ifdef CONFIG_HAS_DMA". Fixes: cd57d07b1e4e ("sh: don't allow non-coherent DMA for NOMMU") Reported-by: Rich Felker <dalias@libc.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Tested-by: Rich Felker <dalias@libc.org> Link: https://lore.kernel.org/r/20200901150438.228887-1-ulf.hansson@linaro.org
2020-09-07mmc: sdhci-msm: Add retries when all tuning phases are found validDouglas Anderson
As the comments in this patch say, if we tune and find all phases are valid it's _almost_ as bad as no phases being found valid. Probably all phases are not really reliable but we didn't detect where the unreliable place is. That means we'll essentially be guessing and hoping we get a good phase. This is not just a problem in theory. It was causing real problems on a real board. On that board, most often phase 10 is found as the only invalid phase, though sometimes 10 and 11 are invalid and sometimes just 11. Some percentage of the time, however, all phases are found to be valid. When this happens, the current logic will decide to use phase 11. Since phase 11 is sometimes found to be invalid, this is a bad choice. Sure enough, when phase 11 is picked we often get mmc errors later in boot. I have seen cases where all phases were found to be valid 3 times in a row, so increase the retry count to 10 just to be extra sure. Fixes: 415b5a75da43 ("mmc: sdhci-msm: Add platform_execute_tuning implementation") Signed-off-by: Douglas Anderson <dianders@chromium.org> Reviewed-by: Veerabhadrarao Badiganti <vbadigan@codeaurora.org> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Link: https://lore.kernel.org/r/20200827075809.1.If179abf5ecb67c963494db79c3bc4247d987419b@changeid Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2020-09-07mmc: sdhci-acpi: Clear amd_sdhci_host on resetRaul E Rangel
The commit 61d7437ed1390 ("mmc: sdhci-acpi: Fix HS400 tuning for AMDI0040") broke resume for eMMC HS400. When the system suspends the eMMC controller is powered down. So, on resume we need to reinitialize the controller. Although, amd_sdhci_host was not getting cleared, so the DLL was never re-enabled on resume. This results in HS400 being non-functional. To fix the problem, this change clears the tuned_clock flag, clears the dll_enabled flag and disables the DLL on reset. Fixes: 61d7437ed1390 ("mmc: sdhci-acpi: Fix HS400 tuning for AMDI0040") Signed-off-by: Raul E Rangel <rrangel@chromium.org> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Link: https://lore.kernel.org/r/20200831150517.1.I93c78bfc6575771bb653c9d3fca5eb018a08417d@changeid Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2020-09-06Linux 5.9-rc4Linus Torvalds
2020-09-06Merge tag 'io_uring-5.9-2020-09-06' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull more io_uring fixes from Jens Axboe: "Two followup fixes. One is fixing a regression from this merge window, the other is two commits fixing cancelation of deferred requests. Both have gone through full testing, and both spawned a few new regression test additions to liburing. - Don't play games with const, properly store the output iovec and assign it as needed. - Deferred request cancelation fix (Pavel)" * tag 'io_uring-5.9-2020-09-06' of git://git.kernel.dk/linux-block: io_uring: fix linked deferred ->files cancellation io_uring: fix cancel of deferred reqs with ->files io_uring: fix explicit async read/write mapping for large segments
2020-09-06Merge tag 'iommu-fixes-v5.9-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull iommu fixes from Joerg Roedel: - three Intel VT-d fixes to fix address handling on 32bit, fix a NULL pointer dereference bug and serialize a hardware register access as required by the VT-d spec. - two patches for AMD IOMMU to force AMD GPUs into translation mode when memory encryption is active and disallow using IOMMUv2 functionality. This makes the AMDGPU driver work when memory encryption is active. - two more fixes for AMD IOMMU to fix updating the Interrupt Remapping Table Entries. - MAINTAINERS file update for the Qualcom IOMMU driver. * tag 'iommu-fixes-v5.9-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: iommu/vt-d: Handle 36bit addressing for x86-32 iommu/amd: Do not use IOMMUv2 functionality when SME is active iommu/amd: Do not force direct mapping when SME is active iommu/amd: Use cmpxchg_double() when updating 128-bit IRTE iommu/amd: Restore IRTE.RemapEn bit after programming IRTE iommu/vt-d: Fix NULL pointer dereference in dev_iommu_priv_set() iommu/vt-d: Serialize IOMMU GCMD register modifications MAINTAINERS: Update QUALCOMM IOMMU after Arm SMMU drivers move
2020-09-06Merge tag 'x86-urgent-2020-09-06' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: - more generic entry code ABI fallout - debug register handling bugfixes - fix vmalloc mappings on 32-bit kernels - kprobes instrumentation output fix on 32-bit kernels - fix over-eager WARN_ON_ONCE() on !SMAP hardware - NUMA debugging fix - fix Clang related crash on !RETPOLINE kernels * tag 'x86-urgent-2020-09-06' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/entry: Unbreak 32bit fast syscall x86/debug: Allow a single level of #DB recursion x86/entry: Fix AC assertion tracing/kprobes, x86/ptrace: Fix regs argument order for i386 x86, fakenuma: Fix invalid starting node ID x86/mm/32: Bring back vmalloc faulting on x86_32 x86/cmdline: Disable jump tables for cmdline.c
2020-09-06Merge tag 'for-linus-5.9-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen updates from Juergen Gross: "A small series for fixing a problem with Xen PVH guests when running as backends (e.g. as dom0). Mapping other guests' memory is now working via ZONE_DEVICE, thus not requiring to abuse the memory hotplug functionality for that purpose" * tag 'for-linus-5.9-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen: add helpers to allocate unpopulated memory memremap: rename MEMORY_DEVICE_DEVDAX to MEMORY_DEVICE_GENERIC xen/balloon: add header guard
2020-09-05io_uring: fix linked deferred ->files cancellationPavel Begunkov
While looking for ->files in ->defer_list, consider that requests there may actually be links. Signed-off-by: Pavel Begunkov <asml.silence@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2020-09-05io_uring: fix cancel of deferred reqs with ->filesPavel Begunkov
While trying to cancel requests with ->files, it also should look for requests in ->defer_list, otherwise it might end up hanging a thread. Cancel all requests in ->defer_list up to the last request there with matching ->files, that's needed to follow drain ordering semantics. Signed-off-by: Pavel Begunkov <asml.silence@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2020-09-05Merge tags 'auxdisplay-for-linus-v5.9-rc4', ↵Linus Torvalds
'clang-format-for-linus-v5.9-rc4' and 'compiler-attributes-for-linus-v5.9-rc4' of git://github.com/ojeda/linux Pull misc fixes from Miguel Ojeda: "A trivial patch for auxdisplay: - Replace HTTP links with HTTPS ones (Alexander A. Klimov) The usual clang-format trivial update: - Update with the latest for_each macro list (Miguel Ojeda) And Luc requested me to pick a sparse fix on my queue, so here it goes along with other two trivial Compiler Attributes ones (also from Luc). - sparse: use static inline for __chk_{user,io}_ptr() (Luc Van Oostenryck) - Compiler Attributes: fix comment concerning GCC 4.6 (Luc Van Oostenryck) - Compiler Attributes: remove comment about sparse not supporting __has_attribute (Luc Van Oostenryck)" * tag 'auxdisplay-for-linus-v5.9-rc4' of git://github.com/ojeda/linux: auxdisplay: Replace HTTP links with HTTPS ones * tag 'clang-format-for-linus-v5.9-rc4' of git://github.com/ojeda/linux: clang-format: Update with the latest for_each macro list * tag 'compiler-attributes-for-linus-v5.9-rc4' of git://github.com/ojeda/linux: sparse: use static inline for __chk_{user,io}_ptr() Compiler Attributes: fix comment concerning GCC 4.6 Compiler Attributes: remove comment about sparse not supporting __has_attribute
2020-09-05Merge tag 'arc-5.9-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fixes from Vineet Gupta: - HSDK-4xd Dev system: perf driver updates for sampling interrupt - HSDK* Dev System: Ethernet broken [Evgeniy Didin] - HIGHMEM broken (2 memory banks) [Mike Rapoport] - show_regs() rewrite once and for all - Other minor fixes * tag 'arc-5.9-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: [plat-hsdk]: Switch ethernet phy-mode to rgmii-id arc: fix memory initialization for systems with two memory banks irqchip/eznps: Fix build error for !ARC700 builds ARC: show_regs: fix r12 printing and simplify ARC: HSDK: wireup perf irq ARC: perf: don't bail setup if pct irq missing in device-tree ARC: pgalloc.h: delete a duplicated word + other fixes
2020-09-05Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "19 patches. Subsystems affected by this patch series: MAINTAINERS, ipc, fork, checkpatch, lib, and mm (memcg, slub, pagemap, madvise, migration, hugetlb)" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: include/linux/log2.h: add missing () around n in roundup_pow_of_two() mm/khugepaged.c: fix khugepaged's request size in collapse_file mm/hugetlb: fix a race between hugetlb sysctl handlers mm/hugetlb: try preferred node first when alloc gigantic page from cma mm/migrate: preserve soft dirty in remove_migration_pte() mm/migrate: remove unnecessary is_zone_device_page() check mm/rmap: fixup copying of soft dirty and uffd ptes mm/migrate: fixup setting UFFD_WP flag mm: madvise: fix vma user-after-free checkpatch: fix the usage of capture group ( ... ) fork: adjust sysctl_max_threads definition to match prototype ipc: adjust proc_ipc_sem_dointvec definition to match prototype mm: track page table modifications in __apply_to_page_range() MAINTAINERS: IA64: mark Status as Odd Fixes only MAINTAINERS: add LLVM maintainers MAINTAINERS: update Cavium/Marvell entries mm: slub: fix conversion of freelist_corrupted() mm: memcg: fix memcg reclaim soft lockup memcg: fix use-after-free in uncharge_batch
2020-09-05include/linux/log2.h: add missing () around n in roundup_pow_of_two()Jason Gunthorpe
Otherwise gcc generates warnings if the expression is complicated. Fixes: 312a0c170945 ("[PATCH] LOG2: Alter roundup_pow_of_two() so that it can use a ilog2() on a constant") Signed-off-by: Jason Gunthorpe <jgg@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Link: https://lkml.kernel.org/r/0-v1-8a2697e3c003+41165-log_brackets_jgg@nvidia.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm/khugepaged.c: fix khugepaged's request size in collapse_fileDavid Howells
collapse_file() in khugepaged passes PAGE_SIZE as the number of pages to be read to page_cache_sync_readahead(). The intent was probably to read a single page. Fix it to use the number of pages to the end of the window instead. Fixes: 99cb0dbd47a1 ("mm,thp: add read-only THP support for (non-shmem) FS") Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org> Acked-by: Song Liu <songliubraving@fb.com> Acked-by: Yang Shi <shy828301@gmail.com> Acked-by: Pankaj Gupta <pankaj.gupta.linux@gmail.com> Cc: Eric Biggers <ebiggers@google.com> Link: https://lkml.kernel.org/r/20200903140844.14194-2-willy@infradead.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm/hugetlb: fix a race between hugetlb sysctl handlersMuchun Song
There is a race between the assignment of `table->data` and write value to the pointer of `table->data` in the __do_proc_doulongvec_minmax() on the other thread. CPU0: CPU1: proc_sys_write hugetlb_sysctl_handler proc_sys_call_handler hugetlb_sysctl_handler_common hugetlb_sysctl_handler table->data = &tmp; hugetlb_sysctl_handler_common table->data = &tmp; proc_doulongvec_minmax do_proc_doulongvec_minmax sysctl_head_finish __do_proc_doulongvec_minmax unuse_table i = table->data; *i = val; // corrupt CPU1's stack Fix this by duplicating the `table`, and only update the duplicate of it. And introduce a helper of proc_hugetlb_doulongvec_minmax() to simplify the code. The following oops was seen: BUG: kernel NULL pointer dereference, address: 0000000000000000 #PF: supervisor instruction fetch in kernel mode #PF: error_code(0x0010) - not-present page Code: Bad RIP value. ... Call Trace: ? set_max_huge_pages+0x3da/0x4f0 ? alloc_pool_huge_page+0x150/0x150 ? proc_doulongvec_minmax+0x46/0x60 ? hugetlb_sysctl_handler_common+0x1c7/0x200 ? nr_hugepages_store+0x20/0x20 ? copy_fd_bitmaps+0x170/0x170 ? hugetlb_sysctl_handler+0x1e/0x20 ? proc_sys_call_handler+0x2f1/0x300 ? unregister_sysctl_table+0xb0/0xb0 ? __fd_install+0x78/0x100 ? proc_sys_write+0x14/0x20 ? __vfs_write+0x4d/0x90 ? vfs_write+0xef/0x240 ? ksys_write+0xc0/0x160 ? __ia32_sys_read+0x50/0x50 ? __close_fd+0x129/0x150 ? __x64_sys_write+0x43/0x50 ? do_syscall_64+0x6c/0x200 ? entry_SYSCALL_64_after_hwframe+0x44/0xa9 Fixes: e5ff215941d5 ("hugetlb: multiple hstates for multiple page sizes") Signed-off-by: Muchun Song <songmuchun@bytedance.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/20200828031146.43035-1-songmuchun@bytedance.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm/hugetlb: try preferred node first when alloc gigantic page from cmaLi Xinhai
Since commit cf11e85fc08c ("mm: hugetlb: optionally allocate gigantic hugepages using cma"), the gigantic page would be allocated from node which is not the preferred node, although there are pages available from that node. The reason is that the nid parameter has been ignored in alloc_gigantic_page(). Besides, the __GFP_THISNODE also need be checked if user required to alloc only from the preferred node. After this patch, the preferred node is tried first before other allowed nodes, and don't try to allocate from other nodes if __GFP_THISNODE is specified. If user don't specify the preferred node, the current node will be used as preferred node, which makes sure consistent behavior of allocating gigantic and non-gigantic hugetlb page. Fixes: cf11e85fc08c ("mm: hugetlb: optionally allocate gigantic hugepages using cma") Signed-off-by: Li Xinhai <lixinhai.lxh@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Roman Gushchin <guro@fb.com> Link: https://lkml.kernel.org/r/20200902025016.697260-1-lixinhai.lxh@gmail.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm/migrate: preserve soft dirty in remove_migration_pte()Ralph Campbell
The code to remove a migration PTE and replace it with a device private PTE was not copying the soft dirty bit from the migration entry. This could lead to page contents not being marked dirty when faulting the page back from device private memory. Signed-off-by: Ralph Campbell <rcampbell@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Alistair Popple <apopple@nvidia.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Jason Gunthorpe <jgg@nvidia.com> Cc: Bharata B Rao <bharata@linux.ibm.com> Link: https://lkml.kernel.org/r/20200831212222.22409-3-rcampbell@nvidia.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm/migrate: remove unnecessary is_zone_device_page() checkRalph Campbell
Patch series "mm/migrate: preserve soft dirty in remove_migration_pte()". I happened to notice this from code inspection after seeing Alistair Popple's patch ("mm/rmap: Fixup copying of soft dirty and uffd ptes"). This patch (of 2): The check for is_zone_device_page() and is_device_private_page() is unnecessary since the latter is sufficient to determine if the page is a device private page. Simplify the code for easier reading. Signed-off-by: Ralph Campbell <rcampbell@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Alistair Popple <apopple@nvidia.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Jason Gunthorpe <jgg@nvidia.com> Cc: Bharata B Rao <bharata@linux.ibm.com> Link: https://lkml.kernel.org/r/20200831212222.22409-1-rcampbell@nvidia.com Link: https://lkml.kernel.org/r/20200831212222.22409-2-rcampbell@nvidia.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm/rmap: fixup copying of soft dirty and uffd ptesAlistair Popple
During memory migration a pte is temporarily replaced with a migration swap pte. Some pte bits from the existing mapping such as the soft-dirty and uffd write-protect bits are preserved by copying these to the temporary migration swap pte. However these bits are not stored at the same location for swap and non-swap ptes. Therefore testing these bits requires using the appropriate helper function for the given pte type. Unfortunately several code locations were found where the wrong helper function is being used to test soft_dirty and uffd_wp bits which leads to them getting incorrectly set or cleared during page-migration. Fix these by using the correct tests based on pte type. Fixes: a5430dda8a3a ("mm/migrate: support un-addressable ZONE_DEVICE page in migration") Fixes: 8c3328f1f36a ("mm/migrate: migrate_vma() unmap page from vma while collecting pages") Fixes: f45ec5ff16a7 ("userfaultfd: wp: support swap and page migration") Signed-off-by: Alistair Popple <alistair@popple.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Peter Xu <peterx@redhat.com> Cc: Jérôme Glisse <jglisse@redhat.com> Cc: John Hubbard <jhubbard@nvidia.com> Cc: Ralph Campbell <rcampbell@nvidia.com> Cc: Alistair Popple <alistair@popple.id.au> Cc: <stable@vger.kernel.org> Link: https://lkml.kernel.org/r/20200825064232.10023-2-alistair@popple.id.au Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm/migrate: fixup setting UFFD_WP flagAlistair Popple
Commit f45ec5ff16a75 ("userfaultfd: wp: support swap and page migration") introduced support for tracking the uffd wp bit during page migration. However the non-swap PTE variant was used to set the flag for zone device private pages which are a type of swap page. This leads to corruption of the swap offset if the original PTE has the uffd_wp flag set. Fixes: f45ec5ff16a75 ("userfaultfd: wp: support swap and page migration") Signed-off-by: Alistair Popple <alistair@popple.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Peter Xu <peterx@redhat.com> Cc: Jérôme Glisse <jglisse@redhat.com> Cc: John Hubbard <jhubbard@nvidia.com> Cc: Ralph Campbell <rcampbell@nvidia.com> Link: https://lkml.kernel.org/r/20200825064232.10023-1-alistair@popple.id.au Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm: madvise: fix vma user-after-freeYang Shi
The syzbot reported the below use-after-free: BUG: KASAN: use-after-free in madvise_willneed mm/madvise.c:293 [inline] BUG: KASAN: use-after-free in madvise_vma mm/madvise.c:942 [inline] BUG: KASAN: use-after-free in do_madvise.part.0+0x1c8b/0x1cf0 mm/madvise.c:1145 Read of size 8 at addr ffff8880a6163eb0 by task syz-executor.0/9996 CPU: 0 PID: 9996 Comm: syz-executor.0 Not tainted 5.9.0-rc1-syzkaller #0 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x18f/0x20d lib/dump_stack.c:118 print_address_description.constprop.0.cold+0xae/0x497 mm/kasan/report.c:383 __kasan_report mm/kasan/report.c:513 [inline] kasan_report.cold+0x1f/0x37 mm/kasan/report.c:530 madvise_willneed mm/madvise.c:293 [inline] madvise_vma mm/madvise.c:942 [inline] do_madvise.part.0+0x1c8b/0x1cf0 mm/madvise.c:1145 do_madvise mm/madvise.c:1169 [inline] __do_sys_madvise mm/madvise.c:1171 [inline] __se_sys_madvise mm/madvise.c:1169 [inline] __x64_sys_madvise+0xd9/0x110 mm/madvise.c:1169 do_syscall_64+0x2d/0x70 arch/x86/entry/common.c:46 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Allocated by task 9992: kmem_cache_alloc+0x138/0x3a0 mm/slab.c:3482 vm_area_alloc+0x1c/0x110 kernel/fork.c:347 mmap_region+0x8e5/0x1780 mm/mmap.c:1743 do_mmap+0xcf9/0x11d0 mm/mmap.c:1545 vm_mmap_pgoff+0x195/0x200 mm/util.c:506 ksys_mmap_pgoff+0x43a/0x560 mm/mmap.c:1596 do_syscall_64+0x2d/0x70 arch/x86/entry/common.c:46 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Freed by task 9992: kmem_cache_free.part.0+0x67/0x1f0 mm/slab.c:3693 remove_vma+0x132/0x170 mm/mmap.c:184 remove_vma_list mm/mmap.c:2613 [inline] __do_munmap+0x743/0x1170 mm/mmap.c:2869 do_munmap mm/mmap.c:2877 [inline] mmap_region+0x257/0x1780 mm/mmap.c:1716 do_mmap+0xcf9/0x11d0 mm/mmap.c:1545 vm_mmap_pgoff+0x195/0x200 mm/util.c:506 ksys_mmap_pgoff+0x43a/0x560 mm/mmap.c:1596 do_syscall_64+0x2d/0x70 arch/x86/entry/common.c:46 entry_SYSCALL_64_after_hwframe+0x44/0xa9 It is because vma is accessed after releasing mmap_lock, but someone else acquired the mmap_lock and the vma is gone. Releasing mmap_lock after accessing vma should fix the problem. Fixes: 692fe62433d4c ("mm: Handle MADV_WILLNEED through vfs_fadvise()") Reported-by: syzbot+b90df26038d1d5d85c97@syzkaller.appspotmail.com Signed-off-by: Yang Shi <shy828301@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: <stable@vger.kernel.org> [5.4+] Link: https://lkml.kernel.org/r/20200816141204.162624-1-shy828301@gmail.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05checkpatch: fix the usage of capture group ( ... )Mrinal Pandey
The usage of "capture group (...)" in the immediate condition after `&&` results in `$1` being uninitialized. This issues a warning "Use of uninitialized value $1 in regexp compilation at ./scripts/checkpatch.pl line 2638". I noticed this bug while running checkpatch on the set of commits from v5.7 to v5.8-rc1 of the kernel on the commits with a diff content in their commit message. This bug was introduced in the script by commit e518e9a59ec3 ("checkpatch: emit an error when there's a diff in a changelog"). It has been in the script since then. The author intended to store the match made by capture group in variable `$1`. This should have contained the name of the file as `[\w/]+` matched. However, this couldn't be accomplished due to usage of capture group and `$1` in the same regular expression. Fix this by placing the capture group in the condition before `&&`. Thus, `$1` can be initialized to the text that capture group matches thereby setting it to the desired and required value. Fixes: e518e9a59ec3 ("checkpatch: emit an error when there's a diff in a changelog") Signed-off-by: Mrinal Pandey <mrinalmni@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Tested-by: Lukas Bulwahn <lukas.bulwahn@gmail.com> Reviewed-by: Lukas Bulwahn <lukas.bulwahn@gmail.com> Cc: Joe Perches <joe@perches.com> Link: https://lkml.kernel.org/r/20200714032352.f476hanaj2dlmiot@mrinalpandey Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05fork: adjust sysctl_max_threads definition to match prototypeTobias Klauser
Commit 32927393dc1c ("sysctl: pass kernel pointers to ->proc_handler") changed ctl_table.proc_handler to take a kernel pointer. Adjust the definition of sysctl_max_threads to match its prototype in linux/sysctl.h which fixes the following sparse error/warning: kernel/fork.c:3050:47: warning: incorrect type in argument 3 (different address spaces) kernel/fork.c:3050:47: expected void * kernel/fork.c:3050:47: got void [noderef] __user *buffer kernel/fork.c:3036:5: error: symbol 'sysctl_max_threads' redeclared with different type (incompatible argument 3 (different address spaces)): kernel/fork.c:3036:5: int extern [addressable] [signed] [toplevel] sysctl_max_threads( ... ) kernel/fork.c: note: in included file (through include/linux/key.h, include/linux/cred.h, include/linux/sched/signal.h, include/linux/sched/cputime.h): include/linux/sysctl.h:242:5: note: previously declared as: include/linux/sysctl.h:242:5: int extern [addressable] [signed] [toplevel] sysctl_max_threads( ... ) Fixes: 32927393dc1c ("sysctl: pass kernel pointers to ->proc_handler") Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Link: https://lkml.kernel.org/r/20200825093647.24263-1-tklauser@distanz.ch Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05ipc: adjust proc_ipc_sem_dointvec definition to match prototypeTobias Klauser
Commit 32927393dc1c ("sysctl: pass kernel pointers to ->proc_handler") changed ctl_table.proc_handler to take a kernel pointer. Adjust the signature of proc_ipc_sem_dointvec to match ctl_table.proc_handler which fixes the following sparse error/warning: ipc/ipc_sysctl.c:94:47: warning: incorrect type in argument 3 (different address spaces) ipc/ipc_sysctl.c:94:47: expected void *buffer ipc/ipc_sysctl.c:94:47: got void [noderef] __user *buffer ipc/ipc_sysctl.c:194:35: warning: incorrect type in initializer (incompatible argument 3 (different address spaces)) ipc/ipc_sysctl.c:194:35: expected int ( [usertype] *proc_handler )( ... ) ipc/ipc_sysctl.c:194:35: got int ( * )( ... ) Fixes: 32927393dc1c ("sysctl: pass kernel pointers to ->proc_handler") Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Link: https://lkml.kernel.org/r/20200825105846.5193-1-tklauser@distanz.ch Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm: track page table modifications in __apply_to_page_range()Joerg Roedel
__apply_to_page_range() is also used to change and/or allocate page-table pages in the vmalloc area of the address space. Make sure these changes get synchronized to other page-tables in the system by calling arch_sync_kernel_mappings() when necessary. The impact appears limited to x86-32, where apply_to_page_range may miss updating the PMD. That leads to explosions in drivers like BUG: unable to handle page fault for address: fe036000 #PF: supervisor write access in kernel mode #PF: error_code(0x0002) - not-present page *pde = 00000000 Oops: 0002 [#1] SMP CPU: 3 PID: 1300 Comm: gem_concurrent_ Not tainted 5.9.0-rc1+ #16 Hardware name: /NUC6i3SYB, BIOS SYSKLi35.86A.0024.2015.1027.2142 10/27/2015 EIP: __execlists_context_alloc+0x132/0x2d0 [i915] Code: 31 d2 89 f0 e8 2f 55 02 00 89 45 e8 3d 00 f0 ff ff 0f 87 11 01 00 00 8b 4d e8 03 4b 30 b8 5a 5a 5a 5a ba 01 00 00 00 8d 79 04 <c7> 01 5a 5a 5a 5a c7 81 fc 0f 00 00 5a 5a 5a 5a 83 e7 fc 29 f9 81 EAX: 5a5a5a5a EBX: f60ca000 ECX: fe036000 EDX: 00000001 ESI: f43b7340 EDI: fe036004 EBP: f6389cb8 ESP: f6389c9c DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 EFLAGS: 00010286 CR0: 80050033 CR2: fe036000 CR3: 2d361000 CR4: 001506d0 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: fffe0ff0 DR7: 00000400 Call Trace: execlists_context_alloc+0x10/0x20 [i915] intel_context_alloc_state+0x3f/0x70 [i915] __intel_context_do_pin+0x117/0x170 [i915] i915_gem_do_execbuffer+0xcc7/0x2500 [i915] i915_gem_execbuffer2_ioctl+0xcd/0x1f0 [i915] drm_ioctl_kernel+0x8f/0xd0 drm_ioctl+0x223/0x3d0 __ia32_sys_ioctl+0x1ab/0x760 __do_fast_syscall_32+0x3f/0x70 do_fast_syscall_32+0x29/0x60 do_SYSENTER_32+0x15/0x20 entry_SYSENTER_32+0x9f/0xf2 EIP: 0xb7f28559 Code: 03 74 c0 01 10 05 03 74 b8 01 10 06 03 74 b4 01 10 07 03 74 b0 01 10 08 03 74 d8 01 00 00 00 00 00 51 52 55 89 e5 0f 34 cd 80 <5d> 5a 59 c3 90 90 90 90 8d 76 00 58 b8 77 00 00 00 cd 80 90 8d 76 EAX: ffffffda EBX: 00000005 ECX: c0406469 EDX: bf95556c ESI: b7e68000 EDI: c0406469 EBP: 00000005 ESP: bf9554d8 DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 007b EFLAGS: 00000296 Modules linked in: i915 x86_pkg_temp_thermal intel_powerclamp crc32_pclmul crc32c_intel intel_cstate intel_uncore intel_gtt drm_kms_helper intel_pch_thermal video button autofs4 i2c_i801 i2c_smbus fan CR2: 00000000fe036000 It looks like kasan, xen and i915 are vulnerable. Actual impact is "on thinkpad X60 in 5.9-rc1, screen starts blinking after 30-or-so minutes, and machine is unusable" [sfr@canb.auug.org.au: ARCH_PAGE_TABLE_SYNC_MASK needs vmalloc.h] Link: https://lkml.kernel.org/r/20200825172508.16800a4f@canb.auug.org.au [chris@chris-wilson.co.uk: changelog addition] [pavel@ucw.cz: changelog addition] Fixes: 2ba3e6947aed ("mm/vmalloc: track which page-table levels were modified") Fixes: 86cf69f1d893 ("x86/mm/32: implement arch_sync_kernel_mappings()") Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Tested-by: Chris Wilson <chris@chris-wilson.co.uk> [x86-32] Tested-by: Pavel Machek <pavel@ucw.cz> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@vger.kernel.org> [5.8+] Link: https://lkml.kernel.org/r/20200821123746.16904-1-joro@8bytes.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05MAINTAINERS: IA64: mark Status as Odd Fixes onlyRandy Dunlap
IA64 isn't really being maintained, so mark it as Odd Fixes only. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Link: http://lkml.kernel.org/r/7e719139-450f-52c2-59a2-7964a34eda1f@infradead.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05MAINTAINERS: add LLVM maintainersNick Desaulniers
Nominate Nathan and myself to be point of contact for clang/LLVM related support, after a poll at the LLVM BoF at Linux Plumbers Conf 2020. While corporate sponsorship is beneficial, its important to not entrust the keys to the nukes with any one entity. Should Nathan and I find ourselves at the same employer, I would gladly step down. Signed-off-by: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Sedat Dilek <sedat.dilek@gmail.com> Acked-by: Nathan Chancellor <natechancellor@gmail.com> Acked-by: Lukas Bulwahn <lukas.bulwahn@gmail.com> Acked-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com> Acked-by: Masahiro Yamada <masahiroy@kernel.org> Link: https://lkml.kernel.org/r/20200825143540.2948637-1-ndesaulniers@google.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05MAINTAINERS: update Cavium/Marvell entriesRobert Richter
I am leaving Marvell and already do not have access to my @marvell.com email address. So switching over to my korg mail address or removing my address there another maintainer is already listed. For the entries there no other maintainer is listed I will keep looking into patches for Cavium systems for a while until someone from Marvell takes it over. Since I might have limited access to hardware and also limited time I changed state to 'Odd Fixes' for those entries. Signed-off-by: Robert Richter <rric@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ganapatrao Kulkarni <gkulkarni@marvell.com> Cc: Sunil Goutham <sgoutham@marvell.com> CC: Borislav Petkov <bp@alien8.de> Cc: Marc Zyngier <maz@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Wolfram Sang <wsa@kernel.org>, Link: https://lkml.kernel.org/r/20200824122050.31164-1-rric@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm: slub: fix conversion of freelist_corrupted()Eugeniu Rosca
Commit 52f23478081ae0 ("mm/slub.c: fix corrupted freechain in deactivate_slab()") suffered an update when picked up from LKML [1]. Specifically, relocating 'freelist = NULL' into 'freelist_corrupted()' created a no-op statement. Fix it by sticking to the behavior intended in the original patch [1]. In addition, make freelist_corrupted() immune to passing NULL instead of &freelist. The issue has been spotted via static analysis and code review. [1] https://lore.kernel.org/linux-mm/20200331031450.12182-1-dongli.zhang@oracle.com/ Fixes: 52f23478081ae0 ("mm/slub.c: fix corrupted freechain in deactivate_slab()") Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Dongli Zhang <dongli.zhang@oracle.com> Cc: Joe Jin <joe.jin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: <stable@vger.kernel.org> Link: https://lkml.kernel.org/r/20200824130643.10291-1-erosca@de.adit-jv.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05mm: memcg: fix memcg reclaim soft lockupXunlei Pang
We've met softlockup with "CONFIG_PREEMPT_NONE=y", when the target memcg doesn't have any reclaimable memory. It can be easily reproduced as below: watchdog: BUG: soft lockup - CPU#0 stuck for 111s![memcg_test:2204] CPU: 0 PID: 2204 Comm: memcg_test Not tainted 5.9.0-rc2+ #12 Call Trace: shrink_lruvec+0x49f/0x640 shrink_node+0x2a6/0x6f0 do_try_to_free_pages+0xe9/0x3e0 try_to_free_mem_cgroup_pages+0xef/0x1f0 try_charge+0x2c1/0x750 mem_cgroup_charge+0xd7/0x240 __add_to_page_cache_locked+0x2fd/0x370 add_to_page_cache_lru+0x4a/0xc0 pagecache_get_page+0x10b/0x2f0 filemap_fault+0x661/0xad0 ext4_filemap_fault+0x2c/0x40 __do_fault+0x4d/0xf9 handle_mm_fault+0x1080/0x1790 It only happens on our 1-vcpu instances, because there's no chance for oom reaper to run to reclaim the to-be-killed process. Add a cond_resched() at the upper shrink_node_memcgs() to solve this issue, this will mean that we will get a scheduling point for each memcg in the reclaimed hierarchy without any dependency on the reclaimable memory in that memcg thus making it more predictable. Suggested-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Xunlei Pang <xlpang@linux.alibaba.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Chris Down <chris@chrisdown.name> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Link: http://lkml.kernel.org/r/1598495549-67324-1-git-send-email-xlpang@linux.alibaba.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05memcg: fix use-after-free in uncharge_batchMichal Hocko
syzbot has reported an use-after-free in the uncharge_batch path BUG: KASAN: use-after-free in instrument_atomic_write include/linux/instrumented.h:71 [inline] BUG: KASAN: use-after-free in atomic64_sub_return include/asm-generic/atomic-instrumented.h:970 [inline] BUG: KASAN: use-after-free in atomic_long_sub_return include/asm-generic/atomic-long.h:113 [inline] BUG: KASAN: use-after-free in page_counter_cancel mm/page_counter.c:54 [inline] BUG: KASAN: use-after-free in page_counter_uncharge+0x3d/0xc0 mm/page_counter.c:155 Write of size 8 at addr ffff8880371c0148 by task syz-executor.0/9304 CPU: 0 PID: 9304 Comm: syz-executor.0 Not tainted 5.8.0-syzkaller #0 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x1f0/0x31e lib/dump_stack.c:118 print_address_description+0x66/0x620 mm/kasan/report.c:383 __kasan_report mm/kasan/report.c:513 [inline] kasan_report+0x132/0x1d0 mm/kasan/report.c:530 check_memory_region_inline mm/kasan/generic.c:183 [inline] check_memory_region+0x2b5/0x2f0 mm/kasan/generic.c:192 instrument_atomic_write include/linux/instrumented.h:71 [inline] atomic64_sub_return include/asm-generic/atomic-instrumented.h:970 [inline] atomic_long_sub_return include/asm-generic/atomic-long.h:113 [inline] page_counter_cancel mm/page_counter.c:54 [inline] page_counter_uncharge+0x3d/0xc0 mm/page_counter.c:155 uncharge_batch+0x6c/0x350 mm/memcontrol.c:6764 uncharge_page+0x115/0x430 mm/memcontrol.c:6796 uncharge_list mm/memcontrol.c:6835 [inline] mem_cgroup_uncharge_list+0x70/0xe0 mm/memcontrol.c:6877 release_pages+0x13a2/0x1550 mm/swap.c:911 tlb_batch_pages_flush mm/mmu_gather.c:49 [inline] tlb_flush_mmu_free mm/mmu_gather.c:242 [inline] tlb_flush_mmu+0x780/0x910 mm/mmu_gather.c:249 tlb_finish_mmu+0xcb/0x200 mm/mmu_gather.c:328 exit_mmap+0x296/0x550 mm/mmap.c:3185 __mmput+0x113/0x370 kernel/fork.c:1076 exit_mm+0x4cd/0x550 kernel/exit.c:483 do_exit+0x576/0x1f20 kernel/exit.c:793 do_group_exit+0x161/0x2d0 kernel/exit.c:903 get_signal+0x139b/0x1d30 kernel/signal.c:2743 arch_do_signal+0x33/0x610 arch/x86/kernel/signal.c:811 exit_to_user_mode_loop kernel/entry/common.c:135 [inline] exit_to_user_mode_prepare+0x8d/0x1b0 kernel/entry/common.c:166 syscall_exit_to_user_mode+0x5e/0x1a0 kernel/entry/common.c:241 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Commit 1a3e1f40962c ("mm: memcontrol: decouple reference counting from page accounting") reworked the memcg lifetime to be bound the the struct page rather than charges. It also removed the css_put_many from uncharge_batch and that is causing the above splat. uncharge_batch() is supposed to uncharge accumulated charges for all pages freed from the same memcg. The queuing is done by uncharge_page which however drops the memcg reference after it adds charges to the batch. If the current page happens to be the last one holding the reference for its memcg then the memcg is OK to go and the next page to be freed will trigger batched uncharge which needs to access the memcg which is gone already. Fix the issue by taking a reference for the memcg in the current batch. Fixes: 1a3e1f40962c ("mm: memcontrol: decouple reference counting from page accounting") Reported-by: syzbot+b305848212deec86eabe@syzkaller.appspotmail.com Reported-by: syzbot+b5ea6fb6f139c8b9482b@syzkaller.appspotmail.com Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Shakeel Butt <shakeelb@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Roman Gushchin <guro@fb.com> Cc: Hugh Dickins <hughd@google.com> Link: https://lkml.kernel.org/r/20200820090341.GC5033@dhcp22.suse.cz Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05Merge tag 'xfs-5.9-fixes-2' of git://git.kernel.org/pub/scm/fs/xfs/xfs-linuxLinus Torvalds
Pull xfs fix from Darrick Wong: "Fix a broken metadata verifier that would incorrectly validate attr fork extents of a realtime file against the realtime volume" * tag 'xfs-5.9-fixes-2' of git://git.kernel.org/pub/scm/fs/xfs/xfs-linux: xfs: fix xfs_bmap_validate_extent_raw when checking attr fork of rt files
2020-09-05xfs: don't update mtime on COW faultsMikulas Patocka
When running in a dax mode, if the user maps a page with MAP_PRIVATE and PROT_WRITE, the xfs filesystem would incorrectly update ctime and mtime when the user hits a COW fault. This breaks building of the Linux kernel. How to reproduce: 1. extract the Linux kernel tree on dax-mounted xfs filesystem 2. run make clean 3. run make -j12 4. run make -j12 at step 4, make would incorrectly rebuild the whole kernel (although it was already built in step 3). The reason for the breakage is that almost all object files depend on objtool. When we run objtool, it takes COW page fault on its .data section, and these faults will incorrectly update the timestamp of the objtool binary. The updated timestamp causes make to rebuild the whole tree. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05ext2: don't update mtime on COW faultsMikulas Patocka
When running in a dax mode, if the user maps a page with MAP_PRIVATE and PROT_WRITE, the ext2 filesystem would incorrectly update ctime and mtime when the user hits a COW fault. This breaks building of the Linux kernel. How to reproduce: 1. extract the Linux kernel tree on dax-mounted ext2 filesystem 2. run make clean 3. run make -j12 4. run make -j12 at step 4, make would incorrectly rebuild the whole kernel (although it was already built in step 3). The reason for the breakage is that almost all object files depend on objtool. When we run objtool, it takes COW page fault on its .data section, and these faults will incorrectly update the timestamp of the objtool binary. The updated timestamp causes make to rebuild the whole tree. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2020-09-05io_uring: fix explicit async read/write mapping for large segmentsJens Axboe
If we exceed UIO_FASTIOV, we don't handle the transition correctly between an allocated vec for requests that are queued with IOSQE_ASYNC. Store the iovec appropriately and re-set it in the iter iov in case it changed. Fixes: ff6165b2d7f6 ("io_uring: retain iov_iter state over io_read/io_write calls") Reported-by: Nick Hill <nick@nickhill.org> Tested-by: Norman Maurer <norman.maurer@googlemail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2020-09-04Merge tag 's390-5.9-5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Vasily Gorbik: - Fix GENERIC_LOCKBREAK dependency on PREEMPTION in Kconfig broken because of a typo - Update defconfigs * tag 's390-5.9-5' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390: update defconfigs s390: fix GENERIC_LOCKBREAK dependency typo in Kconfig
2020-09-04Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - Fix the loading of modules built with binutils-2.35. This version produces writable and executable .text.ftrace_trampoline section which is rejected by the kernel. - Remove the exporting of cpu_logical_map() as the Tegra driver has now been fixed and no longer uses this function. * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64/module: set trampoline section flags regardless of CONFIG_DYNAMIC_FTRACE arm64: Remove exporting cpu_logical_map symbol
2020-09-04Merge tag 'mips_fixes_5.9_1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux Pull MIPS fixes from Thomas Bogendoerfer: "A few MIPS fixes: - fallthrough fallout fix - BMIPS fixes - MSA fix to avoid leaking MSA register contents - Loongson perf and cpu feature fix - SNI interrupt fix" * tag 'mips_fixes_5.9_1' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux: MIPS: SNI: Fix SCSI interrupt MIPS: add missing MSACSR and upper MSA initialization MIPS: perf: Fix wrong check condition of Loongson event IDs mips/oprofile: Fix fallthrough placement MIPS: Loongson64: Remove unnecessary inclusion of boot_param.h MIPS: BMIPS: Also call bmips_cpu_setup() for secondary cores MIPS: mm: BMIPS5000 has inclusive physical caches MIPS: Loongson64: Do not override watch and ejtag feature
2020-09-04Merge tag 'kbuild-fixes-v5.9-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull Kbuild fixes from Masahiro Yamada: - fix documents - fix warning in 'make localmodconfig' * tag 'kbuild-fixes-v5.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: kconfig: remove redundant assignment prompt = prompt kbuild: Documentation: clean up makefiles.rst kconfig: streamline_config.pl: check defined(ENV variable) before using it Documentation/llvm: Improve formatting of commands, variables, and arguments
2020-09-04Merge tag 'pm-5.9-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management fixes from Rafael Wysocki: "These fix reference counting in the operating performance points (OPP) framework and address a few intel_pstate driver issues, mostly related to switching driver operation modes and similar with hardware-managed P-states (HWP) enabled. Specifics: - Fix reference counting of operating performance points (OPP) tables (Viresh Kumar). - Address intel_pstate driver interface issues, mostly related to switching operation modes and handling CPU offline and online and system-wide suspend/resume with hardware-managed P-states (HWP) enabled (Rafael Wysocki). - Fix the maximum frequency computation in the intel_pstate driver with turbo P-states disabled by the platform firmware and HWP enabled (Francisco Jerez)" * tag 'pm-5.9-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpufreq: intel_pstate: Fix intel_pstate_get_hwp_max() for turbo disabled cpufreq: intel_pstate: Free memory only when turning off cpufreq: intel_pstate: Add ->offline and ->online callbacks cpufreq: intel_pstate: Tweak the EPP sysfs interface cpufreq: intel_pstate: Update cached EPP in the active mode cpufreq: intel_pstate: Refuse to turn off with HWP enabled opp: Don't drop reference for an OPP table that was never parsed
2020-09-04Merge tag 'libata-5.9-2020-09-04' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull libata fixes from Jens Axboe: - improve Sandisks ATA_HORKAGE on NCQ (Tejun) - link printk cleanup (Xu) * tag 'libata-5.9-2020-09-04' of git://git.kernel.dk/linux-block: libata: implement ATA_HORKAGE_MAX_TRIM_128M and apply to Sandisks ata: ahci: use ata_link_info() instead of ata_link_printk()
2020-09-04Merge tag 'block-5.9-2020-09-04' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "A bit larger than usual this week, mostly due to the NVMe fixes arriving late for -rc3 and hence didn't make last weeks pull request. - NVMe: - instance leak and io boundary fixes from Keith - fc locking fix from Christophe - various tcp/rdma reset during traffic fixes from Sagi - pci use-after-free fix from Tong - tcp target null deref fix from Ziye - Locking fix for partition removal (Christoph) - Ensure bdi->io_pages is always set (me) - Fixup for hd struct reference (Ming) - Fix for zero length bvecs (Ming) - Two small blk-iocost fixes (Tejun)" * tag 'block-5.9-2020-09-04' of git://git.kernel.dk/linux-block: block: allow for_each_bvec to support zero len bvec blk-stat: make q->stats->lock irqsafe blk-iocost: ioc_pd_free() shouldn't assume irq disabled block: fix locking in bdev_del_partition block: release disk reference in hd_struct_free_work block: ensure bdi->io_pages is always initialized nvme-pci: cancel nvme device request before disabling nvme: only use power of two io boundaries nvme: fix controller instance leak nvmet-fc: Fix a missed _irqsave version of spin_lock in 'nvmet_fc_fod_op_done()' nvme: Fix NULL dereference for pci nvme controllers nvme-rdma: fix reset hang if controller died in the middle of a reset nvme-rdma: fix timeout handler nvme-rdma: serialize controller teardown sequences nvme-tcp: fix reset hang if controller died in the middle of a reset nvme-tcp: fix timeout handler nvme-tcp: serialize controller teardown sequences nvme: have nvme_wait_freeze_timeout return if it timed out nvme-fabrics: don't check state NVME_CTRL_NEW for request acceptance nvmet-tcp: Fix NULL dereference when a connect data comes in h2cdata pdu
2020-09-04Merge tag 'io_uring-5.9-2020-09-04' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull io_uring fixes from Jens Axboe: - EAGAIN with O_NONBLOCK retry fix - Two small fixes for registered files (Jiufei) * tag 'io_uring-5.9-2020-09-04' of git://git.kernel.dk/linux-block: io_uring: no read/write-retry on -EAGAIN error and O_NONBLOCK marked file io_uring: set table->files[i] to NULL when io_sqe_file_register failed io_uring: fix removing the wrong file in __io_sqe_files_update()
2020-09-04Merge tag 'thermal-v5.9-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thermal/linux Pull thermal fixes from Daniel Lezcano: - Fix bogus thermal shutdowns for omap4430 where bogus values resulting from an incorrect ADC conversion are too high and fire an emergency shutdown (Tony Lindgren) - Don't suppress negative temp for qcom spmi as they are valid and userspace needs them (Veera Vegivada) - Fix use-after-free in thermal_zone_device_unregister reported by Kasan (Dmitry Osipenko) * tag 'thermal-v5.9-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/thermal/linux: thermal: core: Fix use-after-free in thermal_zone_device_unregister() thermal: qcom-spmi-temp-alarm: Don't suppress negative temp thermal: ti-soc-thermal: Fix bogus thermal shutdowns for omap4430
2020-09-04Merge tag 'dmaengine-fix-5.9-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vkoul/dmaengine Pull dmaengine fixes from Vinod Koul: "A couple of core fixes and odd driver fixes for dmaengine subsystem: Core: - drop ACPI CSRT table reference after using it - fix of_dma_router_xlate() error handling Drivers fixes in idxd, at_hdmac, pl330, dw-edma and jz478" * tag 'dmaengine-fix-5.9-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/vkoul/dmaengine: dmaengine: ti: k3-udma: Update rchan_oes_offset for am654 SYSFW ABI 3.0 drivers/dma/dma-jz4780: Fix race condition between probe and irq handler dmaengine: dw-edma: Fix scatter-gather address calculation dmaengine: ti: k3-udma: Fix the TR initialization for prep_slave_sg dmaengine: pl330: Fix burst length if burst size is smaller than bus width dmaengine: at_hdmac: add missing kfree() call in at_dma_xlate() dmaengine: at_hdmac: add missing put_device() call in at_dma_xlate() dmaengine: at_hdmac: check return value of of_find_device_by_node() in at_dma_xlate() dmaengine: of-dma: Fix of_dma_router_xlate's of_dma_xlate handling dmaengine: idxd: reset states after device disable or reset dmaengine: acpi: Put the CSRT table after using it
2020-09-04Merge tag 'sound-5.9-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A collection of small changes, nothing intrusive: - remaining tasklet API conversions, now all sound stuff have been converted - a few HD-audio and USB-audio quirks and minor fixes - FireWire Tascam and Digi00xx fixes - drop a kernel WARNING from PCM OSS for syzkaller" * tag 'sound-5.9-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (29 commits) ALSA: hda/realtek - Improved routing for Thinkpad X1 7th/8th Gen ALSA: hda: use consistent HDAudio spelling in comments/docs ALSA: hda: add dev_dbg log when driver is not selected ALSA: hda: fix a runtime pm issue in SOF when integrated GPU is disabled ALSA: hda: hdmi - add Rocketlake support ALSA: ua101: convert tasklets to use new tasklet_setup() API ALSA: usb-audio: convert tasklets to use new tasklet_setup() API ASoC: txx9: convert tasklets to use new tasklet_setup() API ASoC: siu: convert tasklets to use new tasklet_setup() API ASoC: fsl_esai: convert tasklets to use new tasklet_setup() API ALSA: hdsp: convert tasklets to use new tasklet_setup() API ALSA: riptide: convert tasklets to use new tasklet_setup() API ALSA: pci/asihpi: convert tasklets to use new tasklet_setup() API ALSA: firewire: convert tasklets to use new tasklet_setup() API ALSA: core: convert tasklets to use new tasklet_setup() API ALSA: pcm: oss: Remove superfluous WARN_ON() for mulaw sanity check ALSA: hda - Fix silent audio output and corrupted input on MSI X570-A PRO ALSA: hda/hdmi: always check pin power status in i915 pin fixup ALSA: hda/realtek: Add quirk for Samsung Galaxy Book Ion NT950XCJ-X716A ALSA: usb-audio: Add basic capture support for Pioneer DJ DJM-250MK2 ...
