git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
Pull xfs and iomap fixes from Dave Chinner:
"Most of these changes are small regression fixes that address problems
introduced in the 4.8-rc1 window. The two fixes that aren't (IO
completion fix and superblock inprogress check) are fixes for problems
introduced some time ago and need to be pushed back to stable kernels.
Changes in this update:
- iomap FIEMAP_EXTENT_MERGED usage fix
- additional mount-time feature restrictions
- rmap btree query fixes
- freeze/unmount io completion workqueue fix
- memory corruption fix for deferred operations handling"
* tag 'xfs-iomap-for-linus-4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs:
xfs: track log done items directly in the deferred pending work item
iomap: don't set FIEMAP_EXTENT_MERGED for extent based filesystems
xfs: prevent dropping ioend completions during buftarg wait
xfs: fix superblock inprogress check
xfs: simple btree query range should look right if LE lookup fails
xfs: fix some key handling problems in _btree_simple_query_range
xfs: don't log the entire end of the AGF
xfs: disallow mounting of realtime + rmap filesystems
xfs: don't perform lookups on zero-height btrees
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto fixes from Herbert Xu:
"This fixes the following issues:
- Kconfig problem that prevented mxc-rnga from being enabled
- bogus key sizes in qat aes-xts
- buggy aes-xts code in vmx"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: vmx - fix null dereference in p8_aes_xts_crypt
crypto: qat - fix aes-xts key sizes
hwrng: mxc-rnga - Fix Kconfig dependency
We used to delay switching to the new credentials until after we had
mapped the executable (and possible elf interpreter). That was kind of
odd to begin with, since the new executable will actually then _run_
with the new creds, but whatever.
The bigger problem was that we also want to make sure that we turn off
prof events and tracing before we start mapping the new executable
state. So while this is a cleanup, it's also a fix for a possible
information leak.
Reported-by: Robert Święcki <robert@swiecki.net>
Tested-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: Willy Tarreau <w@1wt.eu>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull seccomp fix from Kees Cook:
"Fix fatal signal delivery after ptrace reordering"
* tag 'seccomp-v4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
seccomp: Fix tracer exit notifications during fatal signals
This fixes a ptrace vs fatal pending signals bug as manifested in
seccomp now that seccomp was reordered to happen after ptrace. The
short version is that seccomp should not attempt to call do_exit()
while fatal signals are pending under a tracer. The existing code was
trying to be as defensively paranoid as possible, but it now ends up
confusing ptrace. Instead, the syscall can just be skipped (which solves
the original concern that the do_exit() was addressing) and normal signal
handling, tracer notification, and process death can happen.
Paraphrasing from the original bug report:
If a tracee task is in a PTRACE_EVENT_SECCOMP trap, or has been resumed
after such a trap but not yet been scheduled, and another task in the
thread-group calls exit_group(), then the tracee task exits without the
ptracer receiving a PTRACE_EVENT_EXIT notification. Test case here:
https://gist.github.com/khuey/3c43ac247c72cef8c956ca73281c9be7
The bug happens because when __seccomp_filter() detects
fatal_signal_pending(), it calls do_exit() without dequeuing the fatal
signal. When do_exit() sends the PTRACE_EVENT_EXIT notification and
that task is descheduled, __schedule() notices that there is a fatal
signal pending and changes its state from TASK_TRACED to TASK_RUNNING.
That prevents the ptracer's waitpid() from returning the ptrace event.
A more detailed analysis is here:
https://github.com/mozilla/rr/issues/1762#issuecomment-237396255.
Reported-by: Robert O'Callahan <robert@ocallahan.org>
Reported-by: Kyle Huey <khuey@kylehuey.com>
Tested-by: Kyle Huey <khuey@kylehuey.com>
Fixes: 93e35efb8de4 ("x86/ptrace: run seccomp after ptrace")
Acked-by: James Morris <james.l.morris@oracle.com>
Pull MD fixes from Shaohua Li:
"This includes several bug fixes:
- Alexey Obitotskiy fixed a hang for faulty raid5 array with external
management
- Song Liu fixed two raid5 journal related bugs
- Tomasz Majchrzak fixed a bad block recording issue and an
accounting issue for raid10
- ZhengYuan Liu fixed an accounting issue for raid5
- I fixed a potential race condition and memory leak with DIF/DIX
enabled
- other trival fixes"
* tag 'md/4.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/shli/md:
raid5: avoid unnecessary bio data set
raid5: fix memory leak of bio integrity data
raid10: record correct address of bad block
md-cluster: fix error return code in join()
r5cache: set MD_JOURNAL_CLEAN correctly
md: don't print the same repeated messages about delayed sync operation
md: remove obsolete ret in md_start_sync
md: do not count journal as spare in GET_ARRAY_INFO
md: Prevent IO hold during accessing to faulty raid5 array
MD: hold mddev lock to change bitmap location
raid5: fix incorrectly counter of conf->empty_inactive_list_nr
raid10: increment write counter after bio is split
Pull NFS client bugfixes from Trond Myklebust:
"Highlights include:
Stable patches:
- Fix a refcount leak in nfs_callback_up_net
- Fix an Oopsable condition when the flexfile pNFS driver connection
to the DS fails
- Fix an Oopsable condition in NFSv4.1 server callback races
- Ensure pNFS clients stop doing I/O to the DS if their lease has
expired, as required by the NFSv4.1 protocol
Bugfixes:
- Fix potential looping in the NFSv4.x migration code
- Patch series to close callback races for OPEN, LAYOUTGET and
LAYOUTRETURN
- Silence WARN_ON when NFSv4.1 over RDMA is in use
- Fix a LAYOUTCOMMIT race in the pNFS/blocks client
- Fix pNFS timeout issues when the DS fails"
* tag 'nfs-for-4.8-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
NFSv4.x: Fix a refcount leak in nfs_callback_up_net
NFS4: Avoid migration loops
pNFS/flexfiles: Fix an Oopsable condition when connection to the DS fails
NFSv4.1: Remove obsolete and incorrrect assignment in nfs4_callback_sequence
NFSv4.1: Close callback races for OPEN, LAYOUTGET and LAYOUTRETURN
NFSv4.1: Defer bumping the slot sequence number until we free the slot
NFSv4.1: Delay callback processing when there are referring triples
NFSv4.1: Fix Oopsable condition in server callback races
SUNRPC: Silence WARN_ON when NFSv4.1 over RDMA is in use
pnfs/blocklayout: update last_write_offset atomically with extents
pNFS: The client must not do I/O to the DS if it's lease has expired
pNFS: Handle NFS4ERR_OLD_STATEID correctly in LAYOUTSTAT calls
pNFS/flexfiles: Set reasonable default retrans values for the data channel
NFS: Allow the mount option retrans=0
pNFS/flexfiles: Fix layoutstat periodic reporting
There are three usercopy warnings which are currently being silenced for
gcc 4.6 and newer:
1) "copy_from_user() buffer size is too small" compile warning/error
This is a static warning which happens when object size and copy size
are both const, and copy size > object size. I didn't see any false
positives for this one. So the function warning attribute seems to
be working fine here.
Note this scenario is always a bug and so I think it should be
changed to *always* be an error, regardless of
CONFIG_DEBUG_STRICT_USER_COPY_CHECKS.
2) "copy_from_user() buffer size is not provably correct" compile warning
This is another static warning which happens when I enable
__compiletime_object_size() for new compilers (and
CONFIG_DEBUG_STRICT_USER_COPY_CHECKS). It happens when object size
is const, but copy size is *not*. In this case there's no way to
compare the two at build time, so it gives the warning. (Note the
warning is a byproduct of the fact that gcc has no way of knowing
whether the overflow function will be called, so the call isn't dead
code and the warning attribute is activated.)
So this warning seems to only indicate "this is an unusual pattern,
maybe you should check it out" rather than "this is a bug".
I get 102(!) of these warnings with allyesconfig and the
__compiletime_object_size() gcc check removed. I don't know if there
are any real bugs hiding in there, but from looking at a small
sample, I didn't see any. According to Kees, it does sometimes find
real bugs. But the false positive rate seems high.
3) "Buffer overflow detected" runtime warning
This is a runtime warning where object size is const, and copy size >
object size.
All three warnings (both static and runtime) were completely disabled
for gcc 4.6 with the following commit:
2fb0815c9ee6 ("gcc4: disable __compiletime_object_size for GCC 4.6+")
That commit mistakenly assumed that the false positives were caused by a
gcc bug in __compiletime_object_size(). But in fact,
__compiletime_object_size() seems to be working fine. The false
positives were instead triggered by #2 above. (Though I don't have an
explanation for why the warnings supposedly only started showing up in
gcc 4.6.)
So remove warning #2 to get rid of all the false positives, and re-enable
warnings #1 and #3 by reverting the above commit.
Furthermore, since #1 is a real bug which is detected at compile time,
upgrade it to always be an error.
Having done all that, CONFIG_DEBUG_STRICT_USER_COPY_CHECKS is no longer
needed.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: "H . Peter Anvin" <hpa@zytor.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Nilay Vaish <nilayvaish@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"Two libata driver specific fixes for v4.8-rc4. Nothing too scary"
* 'for-4.8-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
pata_ninja32: Avoid corrupting status flags
ahci: disable correct irq for dummy ports
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fixes from Tejun Heo:
"Two fixes for cgroup.
- There still was a hole in enforcing cpuset rules, fixed by Li.
- The recent switch to global percpu_rwseom for threadgroup locking
revealed a couple issues in how percpu_rwsem is implemented and
used by cgroup. Balbir found that the read locking section was too
wide unnecessarily including operations which can often depend on
IOs. With percpu_rwsem updates (coming through a different tree)
and reduction of read locking section, all the reported locking
latency issues, including the android one, are resolved.
It looks like we can keep global percpu_rwsem locking for now. If
there actually are cases which can't be resolved, we can go back to
more complex per-signal_struct locking"
* 'for-4.8-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: reduce read locked section of cgroup_threadgroup_rwsem during fork
cpuset: make sure new tasks conform to the current config of the cpuset
Ninja32 needs to set some flags to indicate it does 32bit IO. However it currently assigns this which
loses the initializing flag and causes a warning spew. Fix it to use a logical or as is intended.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Tested-by: Ellmar Stelnberger <estellnb@elstel.org>
On error, the callers expect us to return without bumping
nn->cb_users[].
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Cc: stable@vger.kernel.org # v3.7+
If a server returns itself as a location while migrating, the client may
end up getting stuck attempting to migrate twice to the same server. Catch
this by checking if the nfs_client found is the same as the existing
client. For the other two callers to nfs4_set_client, the nfs_client will
always be ERR_PTR(-EINVAL).
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Christoph reports slab corruption when a deferred refcount update
aborts during _defer_finish(). The cause of this was broken log item
state tracking in xfs_defer_pending -- upon an abort,
_defer_trans_abort() will call abort_intent on all intent items,
including the ones that have already had a done item attached.
This is incorrect because each intent item has 2 refcount: the first
is released when the intent item is committed to the log; and the
second is released when the _done_ item is committed to the log, or
by the intent creator if there is no done item. In other words, once
we log the done item, responsibility for releasing the intent item's
second refcount is transferred to the done item and /must not/ be
performed by anything else.
The dfp_committed flag should have been tracking whether or not we had
a done item so that _defer_trans_abort could decide if it needs to
abort the intent item, but due to a thinko this was not the case. Rip
it out and track the done item directly so that we do the right thing
w.r.t. intent item freeing.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reported-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fix from Guenter Roeck:
"Add missing sysfs attribute group terminator to it87 driver"
* tag 'hwmon-for-linus-v4.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (it87) Add missing sysfs attribute group terminator
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 fixes from Ted Ts'o:
"Fix bugs that could cause kernel deadlocks or file system corruption
while moving xattrs to expand the extended inode.
Also add some sanity checks to the block group descriptors to make
sure we don't end up overwriting the superblock"
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: avoid deadlock when expanding inode size
ext4: properly align shifted xattrs when expanding inodes
ext4: fix xattr shifting when expanding inodes part 2
ext4: validate that metadata blocks do not overlap superblock
ext4: reserve xattr index for the Hurd
Pull networking fixes from David Miller:
1) Segregate namespaces properly in conntrack dumps, from Liping Zhang.
2) tcp listener refcount fix in netfilter tproxy, from Eric Dumazet.
3) Fix timeouts in qed driver due to xmit_more, from Yuval Mintz.
4) Fix use-after-free in tcp_xmit_retransmit_queue().
5) Userspace header fixups (use of __u32, missing includes, etc.) from
Mikko Rapeli.
6) Further refinements to fragmentation wrt gso and tunnels, from
Shmulik Ladkani.
7) Trigger poll correctly for zero length UDP packets, from Eric
Dumazet.
8) TCP window scaling fix, also from Eric Dumazet.
9) SLAB_DESTROY_BY_RCU is not relevant any more for UDP sockets.
10) Module refcount leak in qdisc_create_dflt(), from Eric Dumazet.
11) Fix deadlock in cp_rx_poll() of 8139cp driver, from Gao Feng.
12) Memory leak in rhashtable's alloc_bucket_locks(), from Eric Dumazet.
13) Add new device ID to alx driver, from Owen Lin.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (83 commits)
Add Killer E2500 device ID in alx driver.
net: smc91x: fix SMC accesses
Documentation: networking: dsa: Remove platform device TODO
net/mlx5: Increase number of ethtool steering priorities
net/mlx5: Add error prints when validate ETS failed
net/mlx5e: Fix memory leak if refreshing TIRs fails
net/mlx5e: Add ethtool counter for TX xmit_more
net/mlx5e: Fix ethtool -g/G rx ring parameter report with striding RQ
net/mlx5e: Don't wait for SQ completions on close
net/mlx5e: Don't post fragmented MPWQE when RQ is disabled
net/mlx5e: Don't wait for RQ completions on close
net/mlx5e: Limit UMR length to the device's limitation
rhashtable: fix a memory leak in alloc_bucket_locks()
sfc: fix potential stack corruption from running past stat bitmask
team: loadbalance: push lacpdus to exact delivery
net: hns: dereference ppe_cb->ppe_common_cb if it is non-null
8139cp: Fix one possible deadloop in cp_rx_poll
i40e: Change some init flow for the client
Revert "phy: IRQ cannot be shared"
net: dsa: bcm_sf2: Fix race condition while unmasking interrupts
If the attempt to connect to a DS fails inside ff_layout_pg_init_read or
ff_layout_pg_init_write, then we currently end up clearing the layout
segment carried by the struct nfs_pageio_descriptor, causing an Oops
when we later call into ff_layout_read_pagelist/ff_layout_write_pagelist.
The fix is to ensure we return the layout and then retry.
Fixes: 446ca2195303 ("pNFS/flexfiles: When initing reads or writes, we...")
Cc: stable@vger.kernel.org # v4.7+
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver fixes from Darren Hart:
"Remove module related code from two drivers that are only configurable
as built-in: intel_pmic_gpio and platform/olpc"
* tag 'platform-drivers-x86-v4.8-4' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86:
intel_pmic_gpio: Make explicitly non-modular
platform/olpc: Make ec explicitly non-modular
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc fixes from Ben Herrenschmidt:
"This was meant to be sent early last week, but I has a change pending
on one of the fixes and other things made me forget all about. Ugh.
We have some misc fixes for powerpc 4.8. Some trivial bits and some
regressions, and a trivial cleanup or two that I saw no point in
letting rot in patchwork"
* tag 'powerpc-4.8-4' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc: signals: Discard transaction state from signal frames
powerpc/powernv : Drop reference added by kset_find_obj()
powerpc/tm: do not use r13 for tabort_syscall
powerpc: move hmi.c to arch/powerpc/kvm/
powerpc: sysdev: cpm: fix gpio save_regs functions
powerpc/pseries: PACA save area fix for MCE vs MCE
powerpc/pseries: PACA save area fix for general exception vs MCE
powerpc/prom: Fix sub-processor option passed to ibm, client-architecture-support
powerpc, hotplug: Avoid to touch non-existent cpumasks.
powerpc: migrate exception table users off module.h and onto extable.h
powerpc/powernv/pci: fix iterator signedness
powerpc/pseries: use pci_host_bridge.release_fn() to kfree(phb)
cxl: use pcibios_free_controller_deferred() when removing vPHBs
powerpc: mpc8349emitx: Delete unnecessary assignment for the field "owner"
powerpc/512x: Delete unnecessary assignment for the field "owner"
drivers/macintosh: Delete owner assignment
powerpc: cputhreads: Add missing include file
Attribute array it87_attributes_in lacks its NULL terminator,
causing random behavior when operating on the attribute group.
Fixes: 52929715634a ("hwmon: (it87) Use is_visible for voltage sensors")
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
The Kconfig entry controlling compilation of this code is:
drivers/platform/x86/Kconfig:config GPIO_INTEL_PMIC
drivers/platform/x86/Kconfig: bool "Intel PMIC GPIO support"
...meaning that it currently is not being built as a module by anyone.
Lets remove the couple traces of modular infrastructure use, so that
when reading the driver there is no doubt it is builtin-only.
We delete the MODULE_LICENSE tag etc. since all that information
was (or is now) contained at the top of the file in the comments.
We don't replace module.h with init.h since the file already has that.
Cc: Alek Du <alek.du@intel.com>
Cc: platform-driver-x86@vger.kernel.org
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
arch/x86/Kconfig:config OLPC
arch/x86/Kconfig: bool "One Laptop Per Child support"
Acked-by: Andres Salomon <dilinger@queued.net>
Commit b70661c70830 ("net: smc91x: use run-time configuration on all ARM
machines") broke some ARM platforms through several mistakes. Firstly,
the access size must correspond to the following rule:
(a) at least one of 16-bit or 8-bit access size must be supported
(b) 32-bit accesses are optional, and may be enabled in addition to
the above.
Secondly, it provides no emulation of 16-bit accesses, instead blindly
making 16-bit accesses even when the platform specifies that only 8-bit
is supported.
Reorganise smc91x.h so we can make use of the existing 16-bit access
emulation already provided - if 16-bit accesses are supported, use
16-bit accesses directly, otherwise if 8-bit accesses are supported,
use the provided 16-bit access emulation. If neither, BUG(). This
exactly reflects the driver behaviour prior to the commit being fixed.
Since the conversion incorrectly cut down the available access sizes on
several platforms, we also need to go through every platform and fix up
the overly-restrictive access size: Arnd assumed that if a platform can
perform 32-bit, 16-bit and 8-bit accesses, then only a 32-bit access
size needed to be specified - not so, all available access sizes must
be specified.
This likely fixes some performance regressions in doing this: if a
platform does not support 8-bit accesses, 8-bit accesses have been
emulated by performing a 16-bit read-modify-write access.
Tested on the Intel Assabet/Neponset platform, which supports only 8-bit
accesses, which was broken by the original commit.
Fixes: b70661c70830 ("net: smc91x: use run-time configuration on all ARM machines")
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Since commit 83c0afaec7b7 ("net: dsa: Add new binding implementation"),
the shortcomings of the dsa platform device have been addressed, remove
that TODO item.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Saeed Mahameed says:
Mellanox 100G mlx5 fixes 2016-08-29
This series contains some bug fixes for the mlx5 core and mlx5
ethernet driver.
From Saeed, Fix UMR to consider hardware translation table field
size limitation when calculating the maximum number of MTTs required
by the driver. Three patches to speed-up netdevice close time by
serializing channel (SQs & RQs) destruction rather than issuing and
waiting for hardware interrupts to free them.
From Eran, Fix ethtool ring parameter reporting for striding RQ layout.
Add error prints on ETS validation failure.
From Kamal, Fix memory leak on error flow.
From Maor, Fix ethtool steering priorities number.
Ethtool has 11 flow tables, each flow table has its own priority.
Increase the number of priorities to be aligned with the number of flow
tables.
Fixes: 1174fce8d141 ('net/mlx5e: Support l3/l4 flow type specs in ethtool flow steering')
Signed-off-by: Maor Gottlieb <maorg@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
Upon set ETS failure due to user invalid input, add error prints to
specify the exact error to the user.
Fixes: cdcf11212b22 ('net/mlx5e: Validate BW weight values of ETS')
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Free 'in' command object also when mlx5_core_modify_tir fails.
Fixes: 724b2aa15126 ("net/mlx5e: TIRs management refactoring")
Signed-off-by: Kamal Heib <kamalh@mellanox.com>
Add a counter in ethtool for the number of times that
TX xmit_more was used.
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
The driver RQ has two possible configurations: striding RQ and
non-striding RQ. Until this patch, the driver always reported the
number of hardware WQEs (ring descriptors). For non striding RQ
configuration, this was OK since we have one WQE per pending packet
For striding RQ, multiple packets can fit into one WQE. For better
user experience we normalize the rx_pending parameter (size of wqe/mtu)
as the average ring size in case of striding RQ.
Fixes: 461017cb006a ('net/mlx5e: Support RX multi-packet WQE ...')
Instead of asking the firmware to flush the SQ (Send Queue) via
asynchronous completions when moved to error, we handle SQ flush
manually (mlx5e_free_tx_descs) same as we did when SQ flush got
timed out or on tx_timeout.
This will reduce SQs flush time and speedup interface down procedure.
Moved mlx5e_free_tx_descs to the end of en_tx.c for tx
critical code locality.
Fixes: 29429f3300a3 ('net/mlx5e: Timeout if SQ doesn't flush during close')
ICO (Internal control operations) SQ (Send Queue) is closed/disabled
after RQ (Receive Queue). After RQ is closed an ICO SQ completion
might post a fragmented MPWQE (Multi Packet Work Queue Element) into
that RQ.
As on regular RQ post, check if we are allowed to post to that
RQ (RQ is enabled). Cleanup in-progress UMR MPWQE on mlx5e_free_rx_descs
if needed.
Fixes: bc77b240b3c5 ('net/mlx5e: Add fragmented memory support for RX multi packet WQE')
This will significantly reduce receive queue flush time on interface
down.
Instead of asking the firmware to flush the RQ (Receive Queue) via
asynchronous completions when moved to error, we handle RQ flush
manually (mlx5e_free_rx_descs) same as we did when RQ flush got timed
out.
This will reduce RQs flush time and speedup interface down procedure
(ifconfig down) from 6 sec to 0.3 sec on a 48 cores system.
Moved mlx5e_free_rx_descs en_main.c where it is needed, to keep en_rx.c
free form non critical data path code for better code locality.
Fixes: 6cd392a082de ('net/mlx5e: Handle RQ flush in error cases')
ConnectX-4 UMR (User Memory Region) MTT translation table offset in WQE
is limited to U16_MAX, before this patch we ignored that limitation and
requested the maximum possible UMR translation length that the netdev
might need (MAX channels * MAX pages per channel).
In case of a system with #cores > 32 and when linear WQE allocation fails,
falling back to using UMR WQEs will cause the RQ (Receive Queue) to get
stuck.
Here we limit UMR length to min(U16_MAX, max required pages) (while
considering the required alignments) on driver load, by default U16_MAX is
sufficient since the default RX rings value guarantees that we are in
range, dynamically (on set_ringparam/set_channels) we will check if the
new required UMR length (num mtts) is still in range, if not, fail the
request.
Userspace can begin and suspend a transaction within the signal
handler which means they might enter sys_rt_sigreturn() with the
processor in suspended state.
sys_rt_sigreturn() wants to restore process context (which may have
been in a transaction before signal delivery). To do this it must
restore TM SPRS. To achieve this, any transaction initiated within the
signal frame must be discarded in order to be able to restore TM SPRs
as TM SPRs can only be manipulated non-transactionally..
>From the PowerPC ISA:
TM Bad Thing Exception [Category: Transactional Memory]
An attempt is made to execute a mtspr targeting a TM register in
other than Non-transactional state.
Not doing so results in a TM Bad Thing:
[12045.221359] Kernel BUG at c000000000050a40 [verbose debug info unavailable]
[12045.221470] Unexpected TM Bad Thing exception at c000000000050a40 (msr 0x201033)
[12045.221540] Oops: Unrecoverable exception, sig: 6 [#1]
[12045.221586] SMP NR_CPUS=2048 NUMA PowerNV
[12045.221634] Modules linked in: xt_CHECKSUM iptable_mangle ipt_MASQUERADE
nf_nat_masquerade_ipv4 iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4
xt_conntrack nf_conntrack ipt_REJECT nf_reject_ipv4 xt_tcpudp bridge stp llc ebtable_filter
ebtables ip6table_filter ip6_tables iptable_filter ip_tables x_tables kvm_hv kvm
uio_pdrv_genirq ipmi_powernv uio powernv_rng ipmi_msghandler autofs4 ses enclosure
scsi_transport_sas bnx2x ipr mdio libcrc32c
[12045.222167] CPU: 68 PID: 6178 Comm: sigreturnpanic Not tainted 4.7.0 #34
[12045.222224] task: c0000000fce38600 ti: c0000000fceb4000 task.ti: c0000000fceb4000
[12045.222293] NIP: c000000000050a40 LR: c0000000000163bc CTR: 0000000000000000
[12045.222361] REGS: c0000000fceb7ac0 TRAP: 0700 Not tainted (4.7.0)
[12045.222418] MSR: 9000000300201033 <SF,HV,ME,IR,DR,RI,LE,TM[SE]> CR: 28444280 XER: 20000000
[12045.222625] CFAR: c0000000000163b8 SOFTE: 0 PACATMSCRATCH: 900000014280f033
GPR00: 01100000b8000001 c0000000fceb7d40 c00000000139c100 c0000000fce390d0
GPR04: 900000034280f033 0000000000000000 0000000000000000 0000000000000000
GPR08: 0000000000000000 b000000000001033 0000000000000001 0000000000000000
GPR12: 0000000000000000 c000000002926400 0000000000000000 0000000000000000
GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR24: 0000000000000000 00003ffff98cadd0 00003ffff98cb470 0000000000000000
GPR28: 900000034280f033 c0000000fceb7ea0 0000000000000001 c0000000fce390d0
[12045.223535] NIP [c000000000050a40] tm_restore_sprs+0xc/0x1c
[12045.223584] LR [c0000000000163bc] tm_recheckpoint+0x5c/0xa0
[12045.223630] Call Trace:
[12045.223655] [c0000000fceb7d80] [c000000000026e74] sys_rt_sigreturn+0x494/0x6c0
[12045.223738] [c0000000fceb7e30] [c0000000000092e0] system_call+0x38/0x108
[12045.223806] Instruction dump:
[12045.223841] 7c800164 4e800020 7c0022a6 f80304a8 7c0222a6 f80304b0 7c0122a6 f80304b8
[12045.223955] 4e800020 e80304a8 7c0023a6 e80304b0 <7c0223a6> e80304b8 7c0123a6 4e800020
[12045.224074] ---[ end trace cb8002ee240bae76 ]---
It isn't clear exactly if there is really a use case for userspace
returning with a suspended transaction, however, doing so doesn't (on
its own) constitute a bad frame. As such, this patch simply discards
the transactional state of the context calling the sigreturn and
continues.
Reported-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Signed-off-by: Cyril Bur <cyrilbur@gmail.com>
Tested-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Reviewed-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Acked-by: Simon Guo <wei.guo.simon@gmail.com>
In a situation, where Linux kernel gets notified about duplicate error log
from OPAL, it is been observed that kernel fails to remove sysfs entries
(/sys/firmware/opal/elog/0xXXXXXXXX) of such error logs. This is because,
we currently search the error log/dump kobject in the kset list via
'kset_find_obj()' routine. Which eventually increment the reference count
by one, once it founds the kobject.
So, unless we decrement the reference count by one after it found the kobject,
we would not be able to release the kobject properly later.
This patch adds the 'kobject_put()' which was missing earlier.
Signed-off-by: Mukesh Ojha <mukesh02@linux.vnet.ibm.com>
Reviewed-by: Vasant Hegde <hegdevasant@linux.vnet.ibm.com>
tabort_syscall runs with RI=1, so a nested recoverable machine
check will load the paca into r13 and overwrite what we loaded
it with, because exceptions returning to privileged mode do not
restore r13.
Fixes: b4b56f9ecab4 (powerpc/tm: Abort syscalls in active transactions)
Signed-off-by: Nick Piggin <npiggin@gmail.com>
Filesystems like XFS that use extents should not set the
FIEMAP_EXTENT_MERGED flag in the fiemap extent structures. To allow
for both behaviors for the upcoming gfs2 usage split the iomap
type field into type and flags, and only set FIEMAP_EXTENT_MERGED if
the IOMAP_F_MERGED flag is set. The flags field will also come in
handy for future features such as shared extents on reflink-enabled
file systems.
Reported-by: Andreas Gruenbacher <agruenba@redhat.com>
Acked-by: Darrick J. Wong <darrick.wong@oracle.com>
Pull drm fixes from Dave Airlie:
"A bunch of fixes covering i915, amdgpu, one tegra and some core DRM
ones. Nothing too strange at this point"
* tag 'drm-fixes-for-4.8-rc4' of git://people.freedesktop.org/~airlied/linux: (21 commits)
drm/atomic: Don't potentially reset color_mgmt_changed on successive property updates.
drm: Protect fb_defio in drivers with CONFIG_KMS_FBDEV_EMULATION
drm/amdgpu: skip TV/CV in display parsing
drm/amdgpu: avoid a possible array overflow
drm/amdgpu: fix lru size grouping v2
drm/tegra: dsi: Enhance runtime power management
drm/i915: Fix botched merge that downgrades CSR versions.
drm/i915/skl: Ensure pipes with changed wms get added to the state
drm/i915/gen9: Only copy WM results for changed pipes to skl_hw
drm/i915/skl: Add support for the SAGV, fix underrun hangs
drm/i915/gen6+: Interpret mailbox error flags
drm/i915: Reattach comment, complete type specification
drm/i915: Unconditionally flush any chipset buffers before execbuf
drm/i915/gen9: Drop invalid WARN() during data rate calculation
drm/i915/gen9: Initialize intel_state->active_crtcs during WM sanitization (v2)
drm: Reject page_flip for !DRIVER_MODESET
drm/amdgpu: fix timeout value check in amd_sched_job_recovery
drm/amdgpu: fix sdma_v2_4_ring_test_ib
drm/amdgpu: fix amdgpu_move_blit on 32bit systems
drm/radeon: fix radeon_move_blit on 32bit systems
property updates.
Due to assigning the 'replaced' value instead of or'ing it,
if drm_atomic_crtc_set_property() gets called multiple times,
the last call will define the color_mgmt_changed flag, so
a non-updating call to a property can reset the flag and
prevent actual hw state updates required by preceding
property updates.
Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com>
Cc: Daniel Vetter <daniel.vetter@intel.com>
Cc: <stable@vger.kernel.org> # v4.6+
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Defer freeing the slot until after we have processed the results from
OPEN and LAYOUTGET. This means that the server can rely on the
mechanism in RFC5661 Section 2.10.6.3 to ensure that replies to an
OPEN or LAYOUTGET/RETURN RPC call don't race with the callbacks that
apply to them.
For operations like OPEN or LAYOUTGET, which return recallable state
(i.e. delegations and layouts) we want to enable the mechanism for
resolving recall races in RFC5661 Section 2.10.6.3.
To do so, we will want to defer bumping the slot's sequence number until
we have finished processing the RPC results.
If CB_SEQUENCE tells us that the processing of this request depends on
the completion of one or more referring triples (see RFC 5661 Section
2.10.6.3), delay the callback processing until after the RPC requests
being referred to have completed.
If we end up delaying for more than 1/2 second, then fall back to
returning NFS4ERR_DELAY in reply to the callback.
The slot table hasn't been an array since v3.7. Ensure that we
use nfs4_lookup_slot() to access the slot correctly.
Fixes: 87dda67e7386 ("NFSv4.1: Allow SEQUENCE to resize the slot table...")
Cc: stable@vger.kernel.org # v3.8+
Pull perf fixes from Thomas Gleixner:
"A few fixes from the perf departement
- prevent a imbalanced preemption disable in the events teardown code
- prevent out of bound acces in perf userspace
- make perf tools compile with UCLIBC again
- a fix for the userspace unwinder utility"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/core: Use this_cpu_ptr() when stopping AUX events
perf evsel: Do not access outside hw cache name arrays
tools lib: Reinstate strlcpy() header guard with __UCLIBC__
perf unwind: Use addr_location::addr instead of ip for entries
Pull x86 fix from Thomas Gleixner:
"A single bugfix to prevent irq remapping when the ioapic is disabled"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/apic: Do not init irq remapping if ioapic is disabled
