2010-01-30Input: Mac button emulation - implement as an input filterDmitry Torokhov
Current implementation of Mac mouse button emulation plugs into legacy keyboard driver, converts certain keys into button events on a separate device, and suppresses the real events from reaching tty. This worked well enough until user space started using evdev which was completely unaware of this arrangement and kept sending original key presses to its users. Change the implementation to use newly added input filter framework so that original key presses are not transmitted to any handlers. As a bonus remove SYSCTL dependencies from the code and use Kconfig instead; also do not create the emulated mouse device until user activates emulation. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-30Input: implement input filtersDmitry Torokhov
Sometimes it is desirable to suppress certain events from reaching input handlers and thus user space. One such example is Mac mouse button emulation code which catches certain key presses and converts them into button clicks as if they were emitted by a virtual mouse. The original key press events should be completely suppressed, otherwise user space will be confused, and while keyboard driver does it on its own evdev is blissfully unaware of this arrangement. This patch adds notion of 'filter' to the standard input handlers, which may flag event as filtered thus preventing it from reaching other input handlers. Filters don't (nor will they ever) have a notion of priority relative to each other, input core will run all of them first and any one of them may mark event as filtered. This patch is inspired by similar patch by Matthew Garret but the implementation and intended usage are quite different. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-29Input: uinput - remove BKL from uinput_open functionThadeu Lima de Souza Cascardo
Commit 8702965848ed4bee27486a3e3d2ae34ebba6dd83 pushed down the BKL into uinput open function. However, there's nothing that needs locking in there. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-28Input: wm97xx - provide coordinate logs for accelerated I/OMark Brown
This aids debug of problematic systems. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-24Input: xpad - add rumble support for original xbox controllerBenjamin Valentin
Signed-off-by: Benjamin Valentin <benpicco@zedat.fu-berlin.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-24Input: xilinx_ps2 - use resource_sizeTobias Klauser
Use the resource_size inline function instead of manually calculating the resource size. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: John Linn <john.linn@xilinx.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-21Merge commit 'v2.6.33-rc5' into nextDmitry Torokhov
2010-01-21Linux 2.6.33-rc5v2.6.33-rc5Linus Torvalds
2010-01-21Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: x86: Add support for the ANY bit perf: Change the is_software_event() definition perf: Honour event state for aux stream data perf: Fix perf_event_do_pending() fallback callsite perf kmem: Print usage help for unknown commands perf kmem: Increase "Hit" column length hw-breakpoints, perf: Fix broken mmiotrace due to dr6 by reference change perf timechart: Use tid not pid for COMM change
2010-01-21Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Reassign prev and switch_count when reacquire_kernel_lock() fail sched: Fix vmark regression on big machines
2010-01-21Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata: retry FS IOs even if it has failed with AC_ERR_INVALID
2010-01-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: tty: fix race in tty_fasync serial: serial_cs: oxsemi quirk breaks resume serial: imx: bit &/| confusion serial: Fix crash if the minimum rate of the device is > 9600 baud serial-core: resume serial hardware with no_console_suspend serial: 8250_pnp: use wildcard for serial Wacom tablets nozomi: quick fix for the close/close bug compat_ioctl: Supress "unknown cmd" message on serial /dev/console
2010-01-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: Staging: hv: fix smp problems in the hyperv core code Staging: et131x: Fix 2.6.33rc1 regression in et131x Staging: asus_oled: fix oops in 2.6.32.2
2010-01-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: Revert "sysdev: fix prototype for memory_sysdev_class show/store functions" driver-core: fix devtmpfs crash on s390
2010-01-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: isp1362: fix build failure on ARM systems via irq_flags cleanup USB: isp1362: better 64bit printf warning fixes USB: fix usbstorage for 2770:915d delivers no FAT USB: Fix level of isp1760 Reloading ptd error message USB: FHCI: avoid NULL pointer dereference USB: Fix duplicate sysfs problem after device reset. USB: add speed values for USB 3.0 and wireless controllers USB: add missing delay during remote wakeup USB: EHCI & UHCI: fix race between root-hub suspend and port resume USB: EHCI: fix handling of unusual interrupt intervals USB: Don't use GFP_KERNEL while we cannot reset a storage device USB: fix bitmask merge error usb: serial: fix memory leak in generic driver USB: serial: fix USB serial fix kfifo_len locking
2010-01-21Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: fs/bio.c: fix shadows sparse warning drbd: The kernel code is now equivalent to out of tree release 8.3.7 drbd: Allow online resizing of DRBD devices while peer not reachable (needs to be explicitly forced) drbd: Don't go into StandAlone mode when authentification failes because of network error drivers/block/drbd/drbd_receiver.c: correct NULL test cfq-iosched: Respect ioprio_class when preempting genhd: overlapping variable definition block: removed unused as_io_context DM: Fix device mapper topology stacking block: bdev_stack_limits wrapper block: Fix discard alignment calculation and printing block: Correct handling of bottom device misaligment drbd: check on CONFIG_LBDAF, not LBD drivers/block/drbd: Correct NULL test drbd: Silenced an assert that could triggered after changing write ordering method drbd: Kconfig fix drbd: Fix for a race between IO and a detach operation [Bugz 262] drbd: Use drbd_crypto_is_hash() instead of an open coded check
2010-01-21Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (23 commits) ACPI: delete acpi_processor_power_verify_c2() ACPI: allow C3 > 1000usec ACPI: enable C2 and Turbo-mode on Nehalem notebooks on A/C ACPI: power_meter: remove double kfree() ACPI: processor: restrict early _PDC to opt-in platforms ACPI: Fix unused variable warning in sbs.c acpi: make ACPI device id constant sony-laptop - fix using of uninitialized variable ACPI: Fix section mismatch error for acpi_early_processor_set_pdc() eeepc-laptop: disable wireless hotplug for 1201N eeepc-laptop: add hotplug_disable parameter eeepc-laptop: switch to using sparse keymap library eeepc-laptop: dmi blacklist to disable pci hotplug code eeepc-laptop: disable cpu speed control on EeePC 701 ACPI: don't cond_resched if irq is disabled ACPI: Remove unnecessary cast. ACPI: Advertise to BIOS in _OSC: _OST on _PPC changes ACPI: EC: Add wait for irq storm ACPI: SBS: Move SBS HC callback to faster Notify queue x86, ACPI: delete acpi_boot_table_init() return value ...
2010-01-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6: ecryptfs: use after free ecryptfs: Eliminate useless code ecryptfs: fix interpose/interpolate typos in comments ecryptfs: pass matching flags to interpose as defined and used there ecryptfs: remove unnecessary d_drop calls in ecryptfs_link ecryptfs: don't ignore return value from lock_rename ecryptfs: initialize private persistent file before dereferencing pointer eCryptfs: Remove mmap from directory operations eCryptfs: Add getattr function eCryptfs: Use notify_change for truncating lower inodes
2010-01-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix possible panic on unmount Btrfs: deal with NULL acl sent to btrfs_set_acl Btrfs: fix regression in orphan cleanup Btrfs: Fix race in btrfs_mark_extent_written Btrfs, fix memory leaks in error paths Btrfs: align offsets for btrfs_ordered_update_i_size btrfs: fix missing last-entry in readdir(3)
2010-01-21vmalloc: remove BUG_ON due to racy counting of VM_LAZY_FREEYongseok Koh
In free_unmap_area_noflush(), va->flags is marked as VM_LAZY_FREE first, and then vmap_lazy_nr is increased atomically. But, in __purge_vmap_area_lazy(), while traversing of vmap_are_list, nr is counted by checking VM_LAZY_FREE is set to va->flags. After counting the variable nr, kernel reads vmap_lazy_nr atomically and checks a BUG_ON condition whether nr is greater than vmap_lazy_nr to prevent vmap_lazy_nr from being negative. The problem is that, if interrupted right after marking VM_LAZY_FREE, increment of vmap_lazy_nr can be delayed. Consequently, BUG_ON condition can be met because nr is counted more than vmap_lazy_nr. It is highly probable when vmalloc/vfree are called frequently. This scenario have been verified by adding delay between marking VM_LAZY_FREE and increasing vmap_lazy_nr in free_unmap_area_noflush(). Even the vmap_lazy_nr is for checking high watermark, it never be the strict watermark. Although the BUG_ON condition is to prevent vmap_lazy_nr from being negative, vmap_lazy_nr is signed variable. So, it could go down to negative value temporarily. Consequently, removing the BUG_ON condition is proper. A possible BUG_ON message is like the below. kernel BUG at mm/vmalloc.c:517! invalid opcode: 0000 [#1] SMP EIP: 0060:[<c04824a4>] EFLAGS: 00010297 CPU: 3 EIP is at __purge_vmap_area_lazy+0x144/0x150 EAX: ee8a8818 EBX: c08e77d4 ECX: e7c7ae40 EDX: c08e77ec ESI: 000081fe EDI: e7c7ae60 EBP: e7c7ae64 ESP: e7c7ae3c DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Call Trace: [<c0482ad9>] free_unmap_vmap_area_noflush+0x69/0x70 [<c0482b02>] remove_vm_area+0x22/0x70 [<c0482c15>] __vunmap+0x45/0xe0 [<c04831ec>] vmalloc+0x2c/0x30 Code: 8d 59 e0 eb 04 66 90 89 cb 89 d0 e8 87 fe ff ff 8b 43 20 89 da 8d 48 e0 8d 43 20 3b 04 24 75 e7 fe 05 a8 a5 a3 c0 e9 78 ff ff ff <0f> 0b eb fe 90 8d b4 26 00 00 00 00 56 89 c6 b8 ac a5 a3 c0 31 EIP: [<c04824a4>] __purge_vmap_area_lazy+0x144/0x150 SS:ESP 0068:e7c7ae3c [ See also http://marc.info/?l=linux-kernel&m=126335856228090&w=2 ] Signed-off-by: Yongseok Koh <yongseok.koh@samsung.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-21Merge branch 'sh/for-2.6.33' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh/for-2.6.33' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh64: wire up sys_accept4. sh: unwire sys_recvmmsg. sh: ms7724: Correct sh-eth EEPROM polling timeout.
2010-01-21Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 5888/1: arm: Update comments in cacheflush.h and remove unnecessary V6 and V7 comments ARM: 5886/1: arm: Fix cpu_proc_fin() for proc-v7.S and make kexec work ARM: 5885/1: arm: Flush TLB entries in setup_mm_for_reboot() ARM: 5884/1: arm: Fix DCC console for v7 ARM: 5883/1: Revert "disable NX support for OABI-supporting kernels" ARM: 5882/1: ARM: Fix uncompress code compile for different defines of flush(void) ARM: fix badly placed mach/plat entries in Kconfig & Makefile
2010-01-21perf: x86: Add support for the ANY bitStephane Eranian
Propagate the ANY bit into the fixed counter config for v3 and higher. Signed-off-by: Stephane Eranian <eranian@google.com> [a.p.zijlstra@chello.nl: split from larger patch] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4b5430c6.0f975e0a.1bf9.ffff85fe@mx.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-21perf: Change the is_software_event() definitionPeter Zijlstra
The is_software_event() definition always confuses me because its an exclusive expression, make it an inclusive one. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-21perf: Honour event state for aux stream dataPeter Zijlstra
Anton reported that perf record kept receiving events even after calling ioctl(PERF_EVENT_IOC_DISABLE). It turns out that FORK,COMM and MMAP events didn't respect the disabled state and kept flowing in. Reported-by: Anton Blanchard <anton@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Anton Blanchard <anton@samba.org> LKML-Reference: <1263459187.4244.265.camel@laptop> CC: stable@kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-21perf: Fix perf_event_do_pending() fallback callsitePeter Zijlstra
Paul questioned the context in which we should call perf_event_do_pending(). After looking at that I found that it should be called from IRQ context these days, however the fallback call-site is placed in softirq context. Ammend this by placing the callback in the IRQ timer path. Reported-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1263374859.4244.192.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-21sched: Reassign prev and switch_count when reacquire_kernel_lock() failYong Zhang
Assume A->B schedule is processing, if B have acquired BKL before and it need reschedule this time. Then on B's context, it will go to need_resched_nonpreemptible for reschedule. But at this time, prev and switch_count are related to A. It's wrong and will lead to incorrect scheduler statistics. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <2674af741001102238w7b0ddcadref00d345e2181d11@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-21sched: Fix vmark regression on big machinesMike Galbraith
SD_PREFER_SIBLING is set at the CPU domain level if power saving isn't enabled, leading to many cache misses on large machines as we traverse looking for an idle shared cache to wake to. Change the enabler of select_idle_sibling() to SD_SHARE_PKG_RESOURCES, and enable same at the sibling domain level. Reported-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1262612696.15495.15.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-21Input: sh_keysc - add mode 4 and mode 5 supportMagnus Damm
Add Mode 4 and Mode 5 support to the SH_KEYSC driver. These modes allow slightly larger key pad matrixes. While at it, make use of resource_size(). Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-20USB: isp1362: fix build failure on ARM systems via irq_flags cleanupLothar Wassmann
There was some left over #ifdef ARM logic that is outdated but no one really noticed. So instead of relying on this tricky logic, properly load and utilize the platform irq_flags resources. Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Lothar Wassmann <LW@KARO-electronics.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: isp1362: better 64bit printf warning fixesLothar Wassmann
Some hosts that treat the return value of sizeof differently from unsigned long might still hit warnings. So use %zu for sizeof() values. This is a better version of the previous commit b0a9cf297e58721933. Signed-off-by: Lothar Wassmann <LW@KARO-electronics.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: fix usbstorage for 2770:915d delivers no FATRyan May
Resolves kernel.org bug 14914. Remove entry for 2770:915d (usb digital camera with mass storage support) from unusual_devs.h. The fix triggered by the entry causes the file system on the camera to be completely inaccessible (no partition table, the device is not mountable). The patch works, but let me clarify a few things about it. All the patch does is remove the entry for this device from the drivers/usb/storage/unusual_devs.h, which is supposed to help with a problem with the device's reported size (I think). I'm pretty sure it was originally added for a reason, so I'm not sure removing it won't cause other problems to reappear. Also, I should note that this unusual_devs.h entry was present (and activating workarounds) in 2.6.29, but in that version everything works fine. Starting with 2.6.30, things no longer work. Signed-off-by: Ryan May <rmay31@gmail.com> Cc: Rohan Hart <rohan.hart17@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: Fix level of isp1760 Reloading ptd error messageColin Tuckley
This error message is not actually an error, it's an information message. It is triggered when a transfer which ended in a NAQ is retried successfully by the hardware. Signed-off-by: Colin Tuckley <colin.tuckley@arm.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: FHCI: avoid NULL pointer dereferenceAlexander Beregalov
Assign fhci only if usb is not NULL. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: Fix duplicate sysfs problem after device reset.Sarah Sharp
Borislav Petkov reports issues with duplicate sysfs endpoint files after a resume from a hibernate. It turns out that the code to support alternate settings under xHCI has issues when a device with a non-default alternate setting is reset during the hibernate: [ 427.681810] Restarting tasks ... [ 427.681995] hub 1-0:1.0: state 7 ports 6 chg 0004 evt 0000 [ 427.682019] usb usb3: usb resume [ 427.682030] ohci_hcd 0000:00:12.0: wakeup root hub [ 427.682191] hub 1-0:1.0: port 2, status 0501, change 0000, 480 Mb/s [ 427.682205] usb 1-2: usb wakeup-resume [ 427.682226] usb 1-2: finish reset-resume [ 427.682886] done. [ 427.734658] ehci_hcd 0000:00:12.2: port 2 high speed [ 427.734663] ehci_hcd 0000:00:12.2: GetStatus port 2 status 001005 POWER sig=se0 PE CONNECT [ 427.746682] hub 3-0:1.0: hub_reset_resume [ 427.746693] hub 3-0:1.0: trying to enable port power on non-switchable hub [ 427.786715] usb 1-2: reset high speed USB device using ehci_hcd and address 2 [ 427.839653] ehci_hcd 0000:00:12.2: port 2 high speed [ 427.839666] ehci_hcd 0000:00:12.2: GetStatus port 2 status 001005 POWER sig=se0 PE CONNECT [ 427.847717] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [1] = 0x00010100 CSC PPS [ 427.915497] hub 1-2:1.0: remove_intf_ep_devs: if: ffff88022f9e8800 ->ep_devs_created: 1 [ 427.915774] hub 1-2:1.0: remove_intf_ep_devs: bNumEndpoints: 1 [ 427.915934] hub 1-2:1.0: if: ffff88022f9e8800: endpoint devs removed. [ 427.916158] hub 1-2:1.0: create_intf_ep_devs: if: ffff88022f9e8800 ->ep_devs_created: 0, ->unregistering: 0 [ 427.916434] hub 1-2:1.0: create_intf_ep_devs: bNumEndpoints: 1 [ 427.916609] ep_81: create, parent hub [ 427.916632] ------------[ cut here ]------------ [ 427.916644] WARNING: at fs/sysfs/dir.c:477 sysfs_add_one+0x82/0x96() [ 427.916649] Hardware name: System Product Name [ 427.916653] sysfs: cannot create duplicate filename '/devices/pci0000:00/0000:00:12.2/usb1/1-2/1-2:1.0/ep_81' [ 427.916658] Modules linked in: binfmt_misc kvm_amd kvm powernow_k8 cpufreq_ondemand cpufreq_powersave cpufreq_userspace freq_table cpufreq_conservative ipv6 vfat fat +8250_pnp 8250 pcspkr ohci_hcd serial_core k10temp edac_core [ 427.916694] Pid: 278, comm: khubd Not tainted 2.6.33-rc2-00187-g08d869a-dirty #13 [ 427.916699] Call Trace: The problem is caused by a mismatch between the USB core's view of the device state and the USB device and xHCI host's view of the device state. After the device reset and re-configuration, the device and the xHCI host think they are using alternate setting 0 of all interfaces. However, the USB core keeps track of the old state, which may include non-zero alternate settings. It uses intf->cur_altsetting to keep the endpoint sysfs files for the old state across the reset. The bandwidth allocation functions need to know what the xHCI host thinks the current alternate settings are, so original patch set intf->cur_altsetting to the alternate setting 0. This caused duplicate endpoint files to be created. The solution is to not set intf->cur_altsetting before calling usb_set_interface() in usb_reset_and_verify_device(). Instead, we add a new flag to struct usb_interface to tell usb_hcd_alloc_bandwidth() to use alternate setting 0 as the currently installed alternate setting. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Tested-by: Borislav Petkov <petkovbb@googlemail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: add speed values for USB 3.0 and wireless controllersGreg Kroah-Hartman
These controllers say "unknown" for their speed in sysfs, which obviously isn't correct. Reported-by: Kurt Garloff <garloff@novell.com> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: David Vrabel <david.vrabel@csr.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: add missing delay during remote wakeupAlan Stern
This patch (as1330) fixes a bug in khbud's handling of remote wakeups. When a device sends a remote-wakeup request, the parent hub (or the host controller driver, for directly attached devices) begins the resume sequence and notifies khubd when the sequence finishes. At this point the port's SUSPEND feature is automatically turned off. However the device needs an additional 10-ms resume-recovery time (TRSMRCY in the USB spec). Khubd does not wait for this delay if the SUSPEND feature is off, and as a result some devices fail to behave properly following a remote wakeup. This patch adds the missing delay to the remote-wakeup path. It also extends the resume-signalling delay used by ehci-hcd and uhci-hcd from 20 ms (the value in the spec) to 25 ms (the value we use for non-remote-wakeup resumes). The extra time appears to help some devices. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Cc: Rickard Bellini <rickard.bellini@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: EHCI & UHCI: fix race between root-hub suspend and port resumeAlan Stern
This patch (as1321) fixes a problem with EHCI and UHCI root-hub suspends: If the suspend occurs while a port is trying to resume, the resume doesn't finish and simply gets lost. When remote wakeup is enabled, this is undesirable behavior. The patch checks first to see if any port resumes are in progress, and if they are then it fails the root-hub suspend with -EBUSY. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: EHCI: fix handling of unusual interrupt intervalsAlan Stern
This patch (as1320) fixes two problems related to interrupt-URB scheduling in ehci-hcd. URBs with an interval of 2 or 4 microframes aren't handled. For the time being, the patch reduces to interval to 1 uframe. URBs are constrained to have an interval no larger than 1024 frames by usb_submit_urb(). But some EHCI controllers allow use of a schedule as short as 256 frames; for these controllers we may have to decrease the interval to the actual schedule length. The second problem isn't very significant since few devices expose interrupt endpoints with an interval larger than 256 frames. But the first problem is critical; it will prevent the kernel from working with devices having interrupt intervals of 2 or 4 uframes. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Tested-by: Glynn Farrow <farrowg@sg.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: Don't use GFP_KERNEL while we cannot reset a storage deviceOliver Neukum
Memory allocations with GFP_KERNEL can cause IO to a storage device which can fail resulting in a need to reset the device. Therefore GFP_KERNEL cannot be safely used between usb_lock_device() and usb_unlock_device(). Replace by GFP_NOIO. Signed-off-by: Oliver Neukum <oliver@neukum.org> Cc: stable <stable@kernel.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: fix bitmask merge errorAlan Stern
This patch adds a mask bit which was mistakenly omitted from the as1311 patch (usb-storage: add BAD_SENSE flag). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20usb: serial: fix memory leak in generic driverJohan Hovold
Fix a regression introduced by commit 715b1dc01fe44537e8fce9566e4bb48d6821d84b ("USB: usb_debug, usb_generic_serial: implement multi urb write"). URB transfer buffer was never freed when using multi-urb writes. Currently the only driver enabling multi-urb writes is usb_debug. Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: Greg KH <greg@kroah.com> Acked-by: Jason Wessel <jason.wessel@windriver.com> Cc: stable <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20USB: serial: fix USB serial fix kfifo_len lockingStefani Seibold
This patch fix a possible race bug in drivers/usb/serial/generic with the new kfifo API. Please apply it to the 2.6.33-rc* tree. Signed-off-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20Staging: hv: fix smp problems in the hyperv core codeGreg Kroah-Hartman
This fixes a number of SMP problems that were in the hyperv core code. Patch originally written by K. Y. Srinivasan <ksrinivasan@novell.com> but forward ported to the latest in-kernel code and tweaked slightly by me. Novell, Inc. hereby disclaims all copyright in any derivative work copyright associated with this patch. Signed-off-by: K. Y. Srinivasan <ksrinivasan@novell.com> Cc: Hank Janssen <hjanssen@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com>. Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20Staging: et131x: Fix 2.6.33rc1 regression in et131xAlan Cox
et131x: Fix 12bit wrapping From: Alan Cox <alan@linux.intel.com> The 12bit wrap logic conversion is wrong and this shows up for some memory sizes and layouts of card. Patch it up for now, once the kernel view of status is cleaned up it'll become two variables and a lot saner. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20Staging: asus_oled: fix oops in 2.6.32.2Eugeni Dodonov
After updating to 2.6.32 kernel, I started experiencing Oopses caused by the asus_oled module. After quick investigation, I wrapped this simple patch which fixes an Oops in by asus_oled module on 2.6.32.2 kernel, caused by incorrect usage of strict_strtoul function call within set_enabled and set_disabled functions. This can be triggered by simple running the userspace client for asus_old (e.g., 'asusoled -e' or 'asusoled -d'). Signed-off-by: Eugeni Dodonov <eugeni@mandriva.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20tty: fix race in tty_fasyncGreg Kroah-Hartman
We need to keep the lock held over the call to __f_setown() to prevent a PID race. Thanks to Al Viro for pointing out the problem, and to Travis for making us look here in the first place. Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Tavis Ormandy <taviso@google.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Julien Tinnes <jln@google.com> Cc: Matt Mackall <mpm@selenic.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20serial: serial_cs: oxsemi quirk breaks resumePavel Machek
Quirk is applied on all cards with given manfid (is it that correct?). Unfortunately, that quirk breaks resume on zaurus with billionton bluetooth card inserted: c950ctrl is 0 and outb() faults. I believe it is simply not a multiport card. (info->multi == 1). ... ... confirmed by printks. Signed-off-by: Pavel Machek <pavel@ucw.cz> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20serial: imx: bit &/| confusionRoel Kluin
Since UCR1_UARTEN is defined 1, the port was always treated as enabled. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Acked-by: Oskar Schirmer <os@emlix.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Fabian Godehardt <fg@emlix.com> Cc: Daniel Glöckner <dg@emlix.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-20serial: Fix crash if the minimum rate of the device is > 9600 baudAlan Cox
In that situation if the old rate is invalid and the new rate is invalid and the chip cannot do 9600 baud we report zero, which makes all the drivers explode. Instead force the rate based on min/max Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
