The ->onofflock field in the rcu_state structure at one time synchronized
CPU-hotplug operations for RCU. However, its scope has decreased over time
so that it now only protects the lists of orphaned RCU callbacks. This
commit therefore renames it to ->orphan_lock to reflect its current use.
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
This commit causes rcutorture to print the errno if cpu_down() fails
when the rcutorture "verbose" module parameter is specified.
In the old days, _rcu_barrier() acquired ->onofflock to exclude
rcu_send_cbs_to_orphanage(), which allowed the latter to avoid memory
barriers in callback handling. However, _rcu_barrier() recently started
doing get_online_cpus() to lock out CPU-hotplug operations entirely, which
means that the comment in rcu_send_cbs_to_orphanage() that talks about
->onofflock is now obsolete. This commit therefore fixes the comment.
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64
Pull arm64 fixes from Catalin Marinas:
"Main changes:
- AArch64 Linux compilation fixes following 3.7-rc1 changes
(MODULES_USE_ELF_RELA, update_vsyscall() prototype)
- Unnecessary register setting in start_thread() (thanks to Al Viro)
- ptrace fixes"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64:
arm64: fix alignment padding in assembly code
arm64: ptrace: use HW_BREAKPOINT_EMPTY type for disabled breakpoints
arm64: ptrace: make structure padding explicit for debug registers
arm64: No need to set the x0-x2 registers in start_thread()
arm64: Ignore memory blocks below PHYS_OFFSET
arm64: Fix the update_vsyscall() prototype
arm64: Select MODULES_USE_ELF_RELA
arm64: Remove duplicate inclusion of mmu_context.h in smp.c
An interesting effect of using the generic version of linkage.h
is that the padding is defined in terms of x86 NOPs, which can have
even more interesting effects when the assembly code looks like this:
ENTRY(func1)
mov x0, xzr
ENDPROC(func1)
// fall through
ENTRY(func2)
mov x0, #1
ret
ENDPROC(func2)
Admittedly, the code is not very nice. But having code from another
architecture doesn't look completely sane either.
The fix is to add arm64's version of linkage.h, which causes the insertion
of proper AArch64 NOPs.
The min/max call needed to have explicit types on some architectures
(e.g. mn10300). Use clamp_t instead to avoid the warning:
kernel/sys.c: In function 'override_release':
kernel/sys.c:1287:10: warning: comparison of distinct pointer types lacks a cast [enabled by default]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Pull perf fixes from Ingo Molnar:
"Assorted small fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf python: Properly link with libtraceevent
perf hists browser: Add back callchain folding symbol
perf tools: Fix build on sparc.
perf python: Link with libtraceevent
perf python: Initialize 'page_size' variable
tools lib traceevent: Fix missed freeing of subargs in free_arg() in filter
lib tools traceevent: Add back pevent assignment in __pevent_parse_format()
perf hists browser: Fix off-by-two bug on the first column
perf tools: Remove warnings on JIT samples for srcline sort key
perf tools: Fix segfault when using srcline sort key
perf: Require exclude_guest to use PEBS - kernel side enforcement
perf tool: Precise mode requires exclude_guest
Namhyung Kim reported that the build fails with:
GEN python/perf.so
gcc: error: python_ext_build/tmp//../../libtraceevent.a: No such file or directory
error: command 'gcc' failed with exit status 1
cp: cannot stat `python_ext_build/lib/perf.so': No such file or directory
make: *** [python/perf.so] Error 1
We need to propagate the TE_PATH variable to the setup.py file.
Reported-by: Namhyung Kim <namhyung@kernel.org>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/n/tip-8umiPbm4sxpknKivbjgykhut@git.kernel.org
[ Fixed superfluous variable build error. ]
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Pull perf/urgent fixes from Arnaldo Carvalho de Melo:
* The python binding needs to link with libtraceevent and to initialize
the 'page_size' variable so that mmaping works again.
* The callchain folding character that appears on the TUI just before
the overhead had disappeared due to recent changes, add it back.
* Intel PEBS in VT-x context uses the DS address as a guest linear address,
even though its programmed by the host as a host linear address. This either
results in guest memory corruption and or the hardware faulting and 'crashing'
the virtual machine. Therefore we have to disable PEBS on VT-x enter and
re-enable on VT-x exit, enforcing a strict exclude_guest.
Kernel side enforcement fix by Peter Zijlstra, tooling side fix by David Ahern.
* Fix build on sparc due to UAPI, fix from David Miller.
* Fixes for the srclike sort key for unresolved symbols and when processing
samples in JITted code, where we don't have an ELF file, just an special
symbol table, fixes from Namhyung Kim.
* Fix some leaks in libtraceevent, from Steven Rostedt.
Pull ARM soc fixes from Olof Johansson:
"A set of fixes and some minor cleanups for -rc2:
- A series from Arnd that fixes warnings in drivers and other code
included by ARM defconfigs. Most have been acked by corresponding
maintainers (and seem quite hard to argue not picking up anyway in
the few exception cases).
- A few misc patches from the list for integrator/vt8500/i.MX
- A batch of fixes to OMAP platforms, fixing:
- boot problems on beaglebone,
- regression fixes for local timers
- clockdomain locking fixes
- a few boot/sparse warnings
- For Tegra:
- Clock rate calculation overflow fix
- Revert a change that removed timer clocks and a fix for symbol
name clashes
- For Renesas:
- IO accessor / annotation cleanups to remove warnings
- For Kirkwood/Dove/mvebu:
- Fixes for device trees for Dove (some minor cleanups, some fixes)
- Fixes for the mvebu gpio driver
- Fix build problem for Feroceon due to missing ifdefs
- Fix lsxl DTS files"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (31 commits)
ARM: kirkwood: fix buttons on lsxl boards
ARM: kirkwood: fix LEDs names for lsxl boards
ARM: Kirkwood: fix disabling CACHE_FEROCEON_L2
gpio: mvebu: Add missing breaks in mvebu_gpio_irq_set_type
ARM: dove: Add crypto engine to DT
ARM: dove: Remove watchdog from DT
ARM: dove: Restructure SoC device tree descriptor
ARM: dove: Fix clock names of sata and gbe
ARM: dove: Fix tauros2 device tree init
ARM: dove: Add pcie clock support
ARM: OMAP2+: Allow kernel to boot even if GPMC fails to reserve memory
ARM: OMAP: clockdomain: Fix locking on _clkdm_clk_hwmod_enable / disable
ARM: s3c: mark s3c2440_clk_add as __init_refok
spi/s3c64xx: use correct dma_transfer_direction type
ARM: OMAP4: devices: fixup OMAP4 DMIC platform device error message
ARM: OMAP2+: clock data: Add dev-id for the omap-gpmc dummy fck
ARM: OMAP: resolve sparse warning concerning debug_card_init()
ARM: OMAP4: Fix twd_local_timer_register regression
ARM: tegra: add tegra_timer clock
ARM: tegra: rename tegra system timer
Emit the magic string that indicates a module has a signature after the
signature data instead of before it. This allows module_sig_check() to
be made simpler and faster by the elimination of the search for the
magic string. Instead we just need to do a single memcmp().
This works because at the end of the signature data there is the
fixed-length signature information block. This block then falls
immediately prior to the magic number.
From the contents of the information block, it is trivial to calculate
the size of the signature data and thus the size of the actual module
data.
git://git.infradead.org/users/jcooper/linux into fixes
From Jason Cooper:
- improve #ifdef logic to prevent linker errors with CACHE_FEROCEON_L2
- lsxl board dts fixes
* tag 'kirkwood_fixes_for_v3.7' of git://git.infradead.org/users/jcooper/linux:
The module build process no longer creates intermediate files for module
signing, so remove them from .gitignore.
Turn sign-file into perl and merge in x509keyid. The latter doesn't
need to be a separate script as it doesn't actually need to work out the
SHA1 sum of the X.509 certificate itself, since it can get that from the
X.509 certificate.
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into fixes
A collection of warning fixes on non-ARM code from Arnd Bergmann:
* 'testing/driver-warnings' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
pcmcia: sharpsl: don't discard sharpsl_pcmcia_ops
USB: EHCI: mark ehci_orion_conf_mbus_windows __devinit
mm/slob: use min_t() to compare ARCH_SLAB_MINALIGN
SCSI: ARM: make fas216_dumpinfo function conditional
SCSI: ARM: ncr5380/oak uses no interrupts
/proc/<pid>/numa_maps scans vma and show mempolicy under
mmap_sem. It sometimes accesses task->mempolicy which can
be freed without mmap_sem and numa_maps can show some
garbage while scanning.
This patch tries to take reference count of task->mempolicy at reading
numa_maps before calling get_vma_policy(). By this, task->mempolicy
will not be freed until numa_maps reaches its end.
V2->v3
- updated comments to be more verbose.
- removed task_lock() in numa_maps code.
V1->V2
- access task->mempolicy only once and remember it. Becase kernel/exit.c
can overwrite it.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Pull miscellaneous x86 fixes from Peter Anvin:
"The biggest ones are fixing suspend/resume breakage on 32 bits, and an
interrim fix for mapping over holes that allows AMD kit with more than
1 TB.
A final solution for the latter is in the works, but involves some
fairly invasive changes that will probably mean it will only be
appropriate for 3.8."
* 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, MCE: Remove bios_cmci_threshold sysfs attribute
x86, amd, mce: Avoid NULL pointer reference on CPU northbridge lookup
x86: Exclude E820_RESERVED regions and memory holes above 4 GB from direct mapping.
x86/cache_info: Use ARRAY_SIZE() in amd_l3_attrs()
x86/reboot: Remove quirk entry for SBC FITPC
x86, suspend: Correct the restore of CR4, EFER; skip computing EFLAGS.ID
Merge misc fixes from Andrew Morton:
"Seven fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (7 patches)
lib/dma-debug.c: fix __hash_bucket_find()
mm: compaction: correct the nr_strict va isolated check for CMA
firmware/memmap: avoid type conflicts with the generic memmap_init()
pidns: remove recursion from free_pid_ns()
drivers/video/backlight/lm3639_bl.c: return proper error in lm3639_bled_mode_store() error paths
kernel/sys.c: fix stack memory content leak via UNAME26
linux/coredump.h needs asm/siginfo.h
If there is only one match, the unique matched entry should be returned.
Without the fix, the upcoming dma debug interfaces ("dma-debug: new
interfaces to debug dma mapping errors") can't work reliably because
only device and dma_addr are passed to dma_mapping_error().
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Joerg Roedel <joerg.roedel@amd.com>
Tested-by: Shuah Khan <shuah.khan@hp.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jakub Kicinski <kubakici@wp.pl>
Thierry reported that the "iron out" patch for isolate_freepages_block()
had problems due to the strict check being too strict with "mm:
compaction: Iron out isolate_freepages_block() and
isolate_freepages_range() -fix1". It's possible that more pages than
necessary are isolated but the check still fails and I missed that this
fix was not picked up before RC1. This same problem has been identified
in 3.7-RC1 by Tony Prisk and should be addressed by the following patch.
Tested-by: Tony Prisk <linux@prisktech.co.nz>
Reported-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: Richard Davies <richard@arachsys.com>
Cc: Shaohua Li <shli@kernel.org>
Cc: Avi Kivity <avi@redhat.com>
Fix this build error:
drivers/firmware/memmap.c:240:19: error: conflicting types for 'memmap_init'
arch/ia64/include/asm/pgtable.h:565:17: note: previous declaration of 'memmap_init' was here
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Bernhard Walle <bwalle@suse.de>
Cc: Glauber Costa <glommer@parallels.com>
free_pid_ns() operates in a recursive fashion:
free_pid_ns(parent)
put_pid_ns(parent)
kref_put(&ns->kref, free_pid_ns);
free_pid_ns
thus if there was a huge nesting of namespaces the userspace may trigger
avalanche calling of free_pid_ns leading to kernel stack exhausting and a
panic eventually.
This patch turns the recursion into an iterative loop.
Based on a patch by Andrew Vagin.
[akpm@linux-foundation.org: export put_pid_ns() to modules]
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Greg KH <greg@kroah.com>
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Calling uname() with the UNAME26 personality set allows a leak of kernel
stack contents. This fixes it by defensively calculating the length of
copy_to_user() call, making the len argument unsigned, and initializing
the stack buffer to zero (now technically unneeded, but hey, overkill).
CVE-2012-0957
Reported-by: PaX Team <pageexec@freemail.hu>
Cc: PaX Team <pageexec@freemail.hu>
Cc: Brad Spengler <spender@grsecurity.net>
Cc: <stable@vger.kernel.org>
Commit 5ab1c309b344 ("coredump: pass siginfo_t* to do_coredump() and
below, not merely signr") added siginfo_t to linux/coredump.h but forgot
to include asm/siginfo.h. This breaks the build for UML/i386. (And any
other arch where asm/siginfo.h is not magically preincluded...)
In file included from arch/x86/um/elfcore.c:2:0: include/linux/coredump.h:15:25: error: unknown type name 'siginfo_t'
make[1]: *** [arch/x86/um/elfcore.o] Error 1
Signed-off-by: Richard Weinberger <richard@nod.at>
Cc: Denys Vlasenko <vda.linux@googlemail.com>
Cc: Amerigo Wang <amwang@redhat.com>
Cc: "Jonathan M. Foote" <jmfoote@cert.org>
Cc: Roland McGrath <roland@hack.frob.com>
Cc: Pedro Alves <palves@redhat.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
In commit 0b173bc4daa8 ("mm: kill vma flag VM_CAN_NONLINEAR") we
replaced the VM_CAN_NONLINEAR test with checking whether the mapping has
a '->remap_pages()' vm operation, but there is no guarantee that there
it even has a vm_ops pointer at all.
Add the appropriate test for NULL vm_ops.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
Pull Xtensa patchset from Chris Zankel:
"These are all limited to the xtensa subtree and include some important
changes (adding long missing system calls for newer libc versions and
other fixes) and the UAPI changes"
* tag 'xtensa-next-20121018' of git://github.com/czankel/xtensa-linux:
xtensa: add missing system calls to the syscall table
xtensa: minor compiler warning fix
xtensa: Use Kbuild infrastructure to handle asm-generic headers
UAPI: (Scripted) Disintegrate arch/xtensa/include/asm
xtensa: fix unaligned usermode access
xtensa: reorganize SR referencing
xtensa: fix boot parameters parsing
xtensa: fix missing return in do_page_fault for SIGBUS case
xtensa: copy_thread with CLONE_VM must not copy live parent AR windows
xtensa: fix memmove(), bcopy(), and memcpy().
xtensa: ISS: fix rs_put_char
xtensa: ISS: fix specific simcalls
Rusty had clearly not actually tested his module signing changes that I
(trustingly) applied as commit e2a666d52b48 ("kbuild: sign the modules
at install time"). That commit had multiple bugs:
- using "${#VARIABLE}" to get the number of characters in a shell
variable may look clever, but it's locale-dependent: it returns the
number of *characters*, not bytes. And we do need bytes.
So don't use "${#..}" expansion, do the stupid "wc -c" thing instead
(where "c" stands for "bytes", not "characters", despite the letter.
- Rusty had confused "siglen" and "signerlen", and his conversion
didn't set "signerlen" at all, and incorrectly set "siglen" to the
size of the signer, not the size of the signature.
End result: the modified sign-file script did create something that
superficially *looked* like a signature, but didn't actually work at
all, and would fail the signature check. Oops.
Tssk, tssk, Rusty.
But Rusty was definitely right that this whole thing should be rewritten
in perl by somebody who has the perl-fu to do so. That is not me,
though - I'm just doing an emergency fix for the shell script.
Commit cb6b6df111e4 ("xen/pv-on-hvm kexec: add quirk for Xen 3.4 and
shutdown watches.") added the xen_strict_xenbus_quirk() function with an
old K&R-style declaration without proper typing, causing gcc to rightly
complain:
drivers/xen/xenbus/xenbus_xs.c:628:13: warning: function declaration isn’t a prototype [-Wstrict-prototypes]
because we really don't live in caves using stone-age tools any more,
and the kernel has always used properly typed ANSI C function
declarations.
So if a function doesn't take arguments, we tell the compiler so
explicitly by adding the proper "void" in the prototype.
I'm sure there are tons of other examples of this kind of stuff in the
tree, but this is the one that hits my workstation config, so..
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
"Drop some leftover dependencies on CONFIG_EXPERIMENTAL, and add
support for Intel Atom CE4110/4150/4170."
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (coretemp) Add support for Atom CE4110/4150/4170
Documentation/hwmon: remove CONFIG_EXPERIMENTAL
hwmon: (pmbus) remove CONFIG_EXPERIMENTAL
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull TTY fixes from Greg Kroah-Hartman:
"Here are some tty and serial driver fixes for your 3.7-rc1 tree.
Again, the UABI header file fixes, and a number of build and runtime
serial driver bugfixes that solve problems people have been reporting
(the staging driver is a tty driver, hence the fixes coming in through
this tree.)
All of these have been in the linux-next tree for a while.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'tty-3.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
staging: dgrp: check return value of alloc_tty_driver
staging: dgrp: check for NULL pointer in (un)register_proc_table
serial/8250_hp300: Missing 8250 register interface conversion bits
UAPI: (Scripted) Disintegrate include/linux/hsi
tty: serial: sccnxp: Fix bug with unterminated platform_id list
staging: serial: dgrp: Add missing #include <linux/uaccess.h>
serial: sccnxp: Allows the driver to be compiled as a module
tty: Fix bogus "callbacks suppressed" messages
net, TTY: initialize tty->driver_data before usage
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg Kroah-Hartman:
"Here are the USB patches against your 3.7-rc1 tree.
There are the usual UABI header file movements, and we finally are now
able to remove the dbg() macro that is over 15 years old (that had to
wait for after some other trees got merged into yours during the big
3.7-rc1 merge window.)
Other than that, nothing major, just a number of bugfixes and new
device ids. It turns out that almost all of the usb-serial drivers
had bugs in how they were handling their internal data, leaking
memory, hence all of those fixups.
* tag 'usb-3.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (42 commits)
USB: option: add more ZTE devices
USB: option: blacklist net interface on ZTE devices
usb: host: xhci: New system added for Compliance Mode Patch on SN65LVPE502CP
USB: io_ti: fix sysfs-attribute creation
USB: iuu_phoenix: fix sysfs-attribute creation
USB: spcp8x5: fix port-data memory leak
USB: ssu100: fix port-data memory leak
USB: ti_usb_3410_5052: fix port-data memory leak
USB: oti6858: fix port-data memory leak
USB: iuu_phoenix: fix port-data memory leak
USB: kl5kusb105: fix port-data memory leak
USB: io_ti: fix port-data memory leak
USB: keyspan_pda: fix port-data memory leak
USB: f81232: fix port-data memory leak
USB: io_edgeport: fix port-data memory leak
USB: kobil_sct: fix port-data memory leak
USB: cypress_m8: fix port-data memory leak
usb: acm: fix the computation of the number of data bits
usb: Missing dma_mask in ehci-vt8500.c when probed from device-tree
usb: Missing dma_mask in uhci-platform.c when probed from device-tree
git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel
Pull hexagon updates from Richard Kuo:
"It includes the Hexagon UAPI changes from David Howells and some CR
marking changes for the transition from Code Aurora to Linux
Foundation."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel:
Hexagon: Copyright marking changes
UAPI: (Scripted) Disintegrate arch/hexagon/include/asm
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6
Pull PARISC changes from James Bottomley:
"This is a couple of high code motion patches (all within arch/parisc)
I'd like to apply at -rc1 to avoid conflicts with anything else. One
moves us on to the generated instead of included asm file model and
the other is a pull request from David Howells for UAPI
disintegration.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>"
* tag 'parisc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6:
UAPI: (Scripted) Disintegrate arch/parisc/include/asm
[PARISC] asm: redo generic includes
Since I will be maintaining ACPI together with Len from now on, add my
address to the ACPI maintainers list in the MAINTAINERS file (this is
the address to send patches to).
Acked-by: Len Brown <len.brown@intel.com>
Pull nfsd bugfixes from J Bruce Fields.
* 'for-3.7' of git://linux-nfs.org/~bfields/linux:
SUNRPC: Prevent kernel stack corruption on long values of flush
NLM: nlm_lookup_file() may return NLMv4-specific error codes
ehci_fsl_setup_phy is supposed to return an int, but had a void return
value in the case of controller_ver being invalid.
Introduced by commit 3735ba8db8e6 ("powerpc/usb: fix bug of CPU hang
when missing USB PHY clock"), which missed one return.
Signed-off-by: Ben Collins <ben.c@servergy.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Add the following system calls to the syscall table:
fallocate
sendmmsg
umount2
syncfs
epoll_create1
inotify_init1
signalfd4
dup3
pipe2
timerfd_create
timerfd_settime
timerfd_gettime
eventfd2
preadv
pwritev
fanotify_init
fanotify_mark
process_vm_readv
process_vm_writev
name_to_handle_at
open_by_handle_at
sync_file_range
perf_event_open
rt_tgsigqueueinfo
clock_adjtime
prlimit64
kcmp
Note that we have to use the 'sys_sync_file_range2' version, so that
the 64-bit arguments are aligned correctly to the argument registers.
Signed-off-by: Chris Zankel <chris@zankel.net>
UAPI Disintegration 2012-10-16
Fix two compiler warnings complaining about truncating a value on
a 64-bit host, and about declaring an unused variable that is only
used for a specific configuration.
Linus deleted the old code and put signing on the install command,
I fixed it to extract the keyid and signer-name within sign-file
and cleaned up that script now it always signs in-place.
Some enthusiast should convert sign-key to perl and pull
x509keyid into it.
From Borislav Petkov <bp@amd64.org>:
Below is a RAS fix which reverts the addition of a sysfs attribute
which we agreed is not needed, post-factum. And this should go in now
because that sysfs attribute is going to end up in 3.7 otherwise and
thus exposed to userspace; removing it then would be a lot harder.
This is done as a merge rather than a simple patch/cherry-pick since
the baseline for this patch was not in the previous x86/urgent.
450cc201038f3 ("x86/mce: Provide boot argument to honour bios-set CMCI
threshold") added the bios_cmci_threshold sysfs attribute which was
supposed to communicate to userspace tools that BIOS CMCI threshold has
been honoured.
However, this info is not of any importance to userspace - it should
rather get the actual error count it has been thresholded already from
MCi_STATUS[38:52].
So drop this before it becomes a used interface (good thing we caught
this early in 3.7-rc1, right after the merge window closed).
Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/20121017105940.GA14590@x1.osrc.amd.com
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"Media fixes for:
- one Kconfig fix patch;
- one patch fixing DocBook breakage due to the drivers/media UAPI
changes;
- the remaining UAPI media changes (DVB API).
I'm aware that is is a little late for the UAPI renames for the DVB
API, but IMHO, it is better to merge it for 3.7, due to two reasons:
1) There is a major rename at 3.7 (not only uapi changes, but also
the entire media drivers were reorganized on 3.7, in order to
simplify the Kconfig logic, and easy drivers selection, especially
for hybrid devices). By confining all those renames there at 3.7
it will cause all the harm at for media developers on just one
shot. Stable backports upstream and at distros will likely
welcome it as well, as they won't need to check what changed on
3.7 and what was postponed for on 3.8.
2) The V4L2 DocBook Makefile creates a cross-reference between the
media API headers and the specs. This helps us _a_lot_ to be sure
that all API improvements are properly documented. Every time a
header changes from one place to another, DocBook/media/Makefile
needs to be patched. Currently, the DocBook breakage patch
depends on the DVB UAPI."
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] Kconfig: Fix dependencies for driver autoselect options
DocBook/media/Makefile: Fix build due to uapi breakage
UAPI: (Scripted) Disintegrate include/linux/dvb
Code Aurora Forum (CAF) is becoming a part of Linux Foundation Labs.
Signed-off-by: Richard Kuo <rkuo@codeaurora.org>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
aesni_enc()
Calling convention for internal functions and 'asmlinkage' functions is
different on x86-32. Therefore do not directly cast aesni_enc as XTS tweak
function, but use wrapper function in between. Fixes crash with "XTS +
aesni_intel + x86-32" combination.
Cc: stable@vger.kernel.org
Reported-by: Krzysztof Kolasa <kkolasa@winsoft.pl>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Commit 38f38657444d ("xattr: extract simple_xattr code from tmpfs") moved
some code from tmpfs but introduced a subtle bug along the way.
If the name passed to simple_xattr_remove() does not exist in the list of
xattrs, then it is possible to call kfree(new_xattr) when new_xattr is
actually initialized to itself on the stack via uninitialized_var().
This causes a BUG() since the memory was not allocated via the slab
allocator and was not bypassed through to the page allocator because it
was too large.
Initialize the local variable to NULL so the kfree() never takes place.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Aristeu Rozanski <aris@redhat.com>
If a debugger tries to zero a hardware debug control register, the
kernel will try to infer both the type and length of the breakpoint
in order to sanity-check against the requested regset type. This will
fail because the encoding will appear as a zero-length breakpoint.
This patch changes the control register setting so that disabled
breakpoints are treated as HW_BREAKPOINT_EMPTY and no further
sanity-checking is required.
