To avoid the below build warning message,
use new generate_load() checking the return value.
ignoring return value of ‘system’, declared with attribute warn_unused_result
And it also refactors the duplicate code of both
test_perf_event_all_cpu() and test_perf_event_task()
Cc: Teng Qin <qinteng@fb.com>
Signed-off-by: Taeung Song <treeze.taeung@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
This fixes build error regarding redefinition:
CLANG-bpf samples/bpf/parse_varlen.o
samples/bpf/parse_varlen.c:111:8: error: redefinition of 'vlan_hdr'
struct vlan_hdr {
./include/linux/if_vlan.h:38:8: note: previous definition is here
So remove duplicate 'struct vlan_hdr' in sample code and include if_vlan.h
Decrement the number of elements in the map in case the allocation
of a new node fails.
Fixes: 6c9059817432 ("bpf: pre-allocate hash map elements")
Signed-off-by: Mauricio Vasquez B <mauricio.vasquez@polito.it>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Magnus Karlsson says:
This patch set fixes three bugs in the SKB TX path of AF_XDP.
Details in the individual commits.
The structure of the patch set is as follows:
Patch 1: Fix for lost completion message
Patch 2-3: Fix for possible multiple completions of single packet
Patch 4: Fix potential race during error
Changes from v1:
* Added explanation of race in commit message of patch 4.
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
There is a potential race in the TX completion code for the SKB
case. One process enters the sendmsg code of an AF_XDP socket in order
to send a frame. The execution eventually trickles down to the driver
that is told to send the packet. However, it decides to drop the
packet due to some error condition (e.g., rings full) and frees the
SKB. This will trigger the SKB destructor and a completion will be
sent to the AF_XDP user space through its
single-producer/single-consumer queues.
At the same time a TX interrupt has fired on another core and it
dispatches the TX completion code in the driver. It does its HW
specific things and ends up freeing the SKB associated with the
transmitted packet. This will trigger the SKB destructor and a
completion will be sent to the AF_XDP user space through its
single-producer/single-consumer queues. With a pseudo call stack, it
would look like this:
Core 1:
sendmsg() being called in the application
netdev_start_xmit()
Driver entered through ndo_start_xmit
Driver decides to free the SKB for some reason (e.g., rings full)
Destructor of SKB called
xskq_produce_addr() is called to signal completion to user space
Core 2:
TX completion irq
NAPI loop
Driver irq handler for TX completions
Frees the SKB
We now have a violation of the single-producer/single-consumer
principle for our queues as there are two threads trying to produce at
the same time on the same queue.
Fixed by introducing a spin_lock in the destructor. In regards to the
performance, I get around 1.74 Mpps for txonly before and after the
introduction of the spinlock. There is of course some impact due to
the spin lock but it is in the less significant digits that are too
noisy for me to measure. But let us say that the version without the
spin lock got 1.745 Mpps in the best case and the version with 1.735
Mpps in the worst case, then that would mean a maximum drop in
performance of 0.5%.
Fixes: 35fcde7f8deb ("xsk: support for Tx")
Signed-off-by: Magnus Karlsson <magnus.karlsson@intel.com>
Sendmsg in the SKB path of AF_XDP can now return EBUSY when a packet
was discarded and completed by the driver. Just ignore this message
in the sample application.
Fixes: b4b8faa1ded7 ("samples/bpf: sample application and documentation for AF_XDP sockets")
Reported-by: Pavel Odintsov <pavel@fastnetmon.com>
Fixed a bug in which a frame could be completed more than once
when an error was returned from dev_direct_xmit(). The code
erroneously retried sending the message leading to multiple
calls to the SKB destructor and therefore multiple completions
of the same buffer to user space.
The error code in this case has been changed from EAGAIN to EBUSY
in order to tell user space that the sending of the packet failed
and the buffer has been return to user space through the completion
queue.
The code in xskq_produce_addr erroneously checked if there
was up to LAZY_UPDATE_THRESHOLD amount of space in the completion
queue. It only needs to check if there is one slot left in the
queue. This bug could under some circumstances lead to a WARN_ON_ONCE
being triggered and the completion message to user space being lost.
Pull MD fixes from Shaohua Li:
"Two small fixes for MD:
- an error handling fix from me
- a recover bug fix for raid10 from BingJing"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/shli/md:
md/raid10: fix that replacement cannot complete recovery after reassemble
MD: cleanup resources in failure
Pull OpenRISC fixes from Stafford Horne:
"Two fixes for issues which were breaking OpenRISC boot:
- Fix bug in __pte_free_tlb() exposed in 4.18 by Matthew Wilcox's
page table flag addition.
- Fix issue booting on real hardware if delay slot detection
emulation is disabled"
* tag 'for-linus' of git://github.com/stffrdhrn/linux:
openrisc: entry: Fix delay slot exception detection
openrisc: Call destructor during __pte_free_tlb
Pull networking fixes from David Miller:
1) Verify netlink attributes properly in nf_queue, from Eric Dumazet.
2) Need to bump memory lock rlimit for test_sockmap bpf test, from
Yonghong Song.
3) Fix VLAN handling in lan78xx driver, from Dave Stevenson.
4) Fix uninitialized read in nf_log, from Jann Horn.
5) Fix raw command length parsing in mlx5, from Alex Vesker.
6) Cleanup loopback RDS connections upon netns deletion, from Sowmini
Varadhan.
7) Fix regressions in FIB rule matching during create, from Jason A.
Donenfeld and Roopa Prabhu.
8) Fix mpls ether type detection in nfp, from Pieter Jansen van Vuuren.
9) More bpfilter build fixes/adjustments from Masahiro Yamada.
10) Fix XDP_{TX,REDIRECT} flushing in various drivers, from Jesper
Dangaard Brouer.
11) fib_tests.sh file permissions were broken, from Shuah Khan.
12) Make sure BH/preemption is disabled in data path of mac80211, from
Denis Kenzior.
13) Don't ignore nla_parse_nested() return values in nl80211, from
Johannes berg.
14) Properly account sock objects ot kmemcg, from Shakeel Butt.
15) Adjustments to setting bpf program permissions to read-only, from
Daniel Borkmann.
16) TCP Fast Open key endianness was broken, it always took on the host
endiannness. Whoops. Explicitly make it little endian. From Yuching
Cheng.
17) Fix prefix route setting for link local addresses in ipv6, from
David Ahern.
18) Potential Spectre v1 in zatm driver, from Gustavo A. R. Silva.
19) Various bpf sockmap fixes, from John Fastabend.
20) Use after free for GRO with ESP, from Sabrina Dubroca.
21) Passing bogus flags to crypto_alloc_shash() in ipv6 SR code, from
Eric Biggers.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits)
qede: Adverstise software timestamp caps when PHC is not available.
qed: Fix use of incorrect size in memcpy call.
qed: Fix setting of incorrect eswitch mode.
qed: Limit msix vectors in kdump kernel to the minimum required count.
ipvlan: call dev_change_flags when ipvlan mode is reset
ipv6: sr: fix passing wrong flags to crypto_alloc_shash()
net: fix use-after-free in GRO with ESP
tcp: prevent bogus FRTO undos with non-SACK flows
bpf: sockhash, add release routine
bpf: sockhash fix omitted bucket lock in sock_close
bpf: sockmap, fix smap_list_map_remove when psock is in many maps
bpf: sockmap, fix crash when ipv6 sock is added
net: fib_rules: bring back rule_exists to match rule during add
hv_netvsc: split sub-channel setup into async and sync
net: use dev_change_tx_queue_len() for SIOCSIFTXQLEN
atm: zatm: Fix potential Spectre v1
s390/qeth: consistently re-enable device features
s390/qeth: don't clobber buffer on async TX completion
s390/qeth: avoid using is_multicast_ether_addr_64bits on (u8 *)[6]
s390/qeth: fix race when setting MAC address
Sudarsana Reddy Kalluru says:
qed*: Fix series.
The patch series addresses few issues in the qed* drivers.
Please consider applying it to 'net' branch.
When ptp clock is not available for a PF (e.g., higher PFs in NPAR mode),
get-tsinfo() callback should return the software timestamp capabilities
instead of returning the error.
Fixes: 4c55215c ("qede: Add driver support for PTP")
Signed-off-by: Sudarsana Reddy Kalluru <Sudarsana.Kalluru@cavium.com>
Signed-off-by: Michal Kalderon <Michal.Kalderon@cavium.com>
Use the correct size value while copying chassis/port id values.
Fixes: 6ad8c632e ("qed: Add support for query/config dcbx.")
By default, driver sets the eswitch mode incorrectly as VEB (virtual
Ethernet bridging).
Need to set VEB eswitch mode only when sriov is enabled, and it should be
to set NONE by default. The patch incorporates this change.
Fixes: 0fefbfbaa ("qed*: Management firmware - notifications and defaults")
Memory size is limited in the kdump kernel environment. Allocation of more
msix-vectors (or queues) consumes few tens of MBs of memory, which might
lead to the kdump kernel failure.
This patch adds changes to limit the number of MSI-X vectors in kdump
kernel to minimum required value (i.e., 2 per engine).
Fixes: fe56b9e6a ("qed: Add module with basic common support")
After we change the ipvlan mode from l3 to l2, or vice versa, we only
reset IFF_NOARP flag, but don't flush the ARP table cache, which will
cause eth->h_dest to be equal to eth->h_source in ipvlan_xmit_mode_l2().
Then the message will not come out of host.
Here is the reproducer on local host:
ip link set eth1 up
ip addr add 192.168.1.1/24 dev eth1
ip link add link eth1 ipvlan1 type ipvlan mode l3
ip netns add net1
ip link set ipvlan1 netns net1
ip netns exec net1 ip link set ipvlan1 up
ip netns exec net1 ip addr add 192.168.2.1/24 dev ipvlan1
ip route add 192.168.2.0/24 via 192.168.1.2
ping 192.168.2.2 -c 2
ip netns exec net1 ip link set ipvlan1 type ipvlan mode l2
Add the same configuration on remote host. After we set the mode to l2,
we could find that the src/dst MAC addresses are the same on eth1:
21:26:06.648565 00:b7:13:ad:d3:05 > 00:b7:13:ad:d3:05, ethertype IPv4 (0x0800), length 98: (tos 0x0, ttl 64, id 58356, offset 0, flags [DF], proto ICMP (1), length 84)
192.168.2.1 > 192.168.2.2: ICMP echo request, id 22686, seq 1, length 64
Fix this by calling dev_change_flags(), which will call netdevice notifier
with flag change info.
v2:
a) As pointed out by Wang Cong, check return value for dev_change_flags() when
change dev flags.
b) As suggested by Stefano and Sabrina, move flags setting before l3mdev_ops.
So we don't need to redo ipvlan_{, un}register_nf_hook() again in err path.
Reported-by: Jianlin Shi <jishi@redhat.com>
Reviewed-by: Stefano Brivio <sbrivio@redhat.com>
Reviewed-by: Sabrina Dubroca <sd@queasysnail.net>
Fixes: 2ad7bf3638411 ("ipvlan: Initial check-in of the IPVLAN driver.")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
The 'mask' argument to crypto_alloc_shash() uses the CRYPTO_ALG_* flags,
not 'gfp_t'. So don't pass GFP_KERNEL to it.
Fixes: bf355b8d2c30 ("ipv6: sr: add core files for SR HMAC support")
Since the addition of GRO for ESP, gro_receive can consume the skb and
return -EINPROGRESS. In that case, the lower layer GRO handler cannot
touch the skb anymore.
Commit 5f114163f2f5 ("net: Add a skb_gro_flush_final helper.") converted
some of the gro_receive handlers that can lead to ESP's gro_receive so
that they wouldn't access the skb when -EINPROGRESS is returned, but
missed other spots, mainly in tunneling protocols.
This patch finishes the conversion to using skb_gro_flush_final(), and
adds a new helper, skb_gro_flush_final_remcsum(), used in VXLAN and
GUE.
Fixes: 5f114163f2f5 ("net: Add a skb_gro_flush_final helper.")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux
Pull btrfs fixes from David Sterba:
"We have a few regression fixes for qgroup rescan status tracking and
the vm_fault_t conversion that mixed up the error values"
* tag 'for-4.18-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux:
Btrfs: fix mount failure when qgroup rescan is in progress
Btrfs: fix regression in btrfs_page_mkwrite() from vm_fault_t conversion
btrfs: quota: Set rescan progress to (u64)-1 if we hit last leaf
Pull vfs fix from Al Viro:
"Followup to procfs-seq_file series this window"
This fixes a memory leak by making sure that proc seq files release any
private data on close. The 'proc_seq_open' has to be properly paired
with 'proc_seq_release' that releases the extra private data.
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
proc: add proc_seq_release
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging/IIO fixes from Greg KH:
"Here are a few small staging and IIO driver fixes for 4.18-rc3.
Nothing major or big, all just fixes for reported problems since
4.18-rc1. All of these have been in linux-next this week with no
reported problems"
* tag 'staging-4.18-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: android: ion: Return an ERR_PTR in ion_map_kernel
staging: comedi: quatech_daqp_cs: fix no-op loop daqp_ao_insn_write()
iio: imu: inv_mpu6050: Fix probe() failure on older ACPI based machines
iio: buffer: fix the function signature to match implementation
iio: mma8452: Fix ignoring MMA8452_INT_DRDY
iio: tsl2x7x/tsl2772: avoid potential division by zero
iio: pressure: bmp280: fix relative humidity unit
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg KH:
"Here are five fixes for the tty core and some serial drivers.
The tty core ones fix some security and other issues reported by the
syzbot that I have taken too long in responding to (sorry Tetsuo!).
The 8350 serial driver fix resolves an issue of devices that used to
work properly stopping working as they shouldn't have been added to a
blacklist.
All of these have been in linux-next for a few days with no reported
issues"
* tag 'tty-4.18-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
vt: prevent leaking uninitialized data to userspace via /dev/vcs*
serdev: fix memleak on module unload
serial: 8250_pci: Remove stalled entries in blacklist
n_tty: Access echo_* variables carefully.
n_tty: Fix stall at n_tty_receive_char_special().
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here is a number of USB gadget and other driver fixes for 4.18-rc3.
There's a bunch of them here, most of them being gadget driver and
xhci host controller fixes for reported issues (as normal), but there
are also some new device ids, and some fixes for the typec code.
There is an acpi core patch in here that was acked by the acpi
maintainer as it is needed for the typec fixes in order to properly
solve a problem in that driver.
All of these have been in linux-next this week with no reported
issues"
* tag 'usb-4.18-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (33 commits)
usb: chipidea: host: fix disconnection detect issue
usb: typec: tcpm: fix logbuffer index is wrong if _tcpm_log is re-entered
typec: tcpm: Fix a msecs vs jiffies bug
NFC: pn533: Fix wrong GFP flag usage
usb: cdc_acm: Add quirk for Uniden UBC125 scanner
staging/typec: fix tcpci_rt1711h build errors
usb: typec: ucsi: Fix for incorrect status data issue
usb: typec: ucsi: acpi: Workaround for cache mode issue
acpi: Add helper for deactivating memory region
usb: xhci: increase CRS timeout value
usb: xhci: tegra: fix runtime PM error handling
usb: xhci: remove the code build warning
xhci: Fix kernel oops in trace_xhci_free_virt_device
xhci: Fix perceived dead host due to runtime suspend race with event handler
dwc2: gadget: Fix ISOC IN DDMA PID bitfield value calculation
usb: gadget: dwc2: fix memory leak in gadget_init()
usb: gadget: composite: fix delayed_status race condition when set_interface
usb: dwc2: fix isoc split in transfer with no data
usb: dwc2: alloc dma aligned buffer for isoc split in
usb: dwc2: fix the incorrect bitmaps for the ports of multi_tt hub
Pull dma mapping fixlet from Christoph Hellwig:
"Add a missing export required by riscv and unicore"
* tag 'dma-mapping-4.18-2' of git://git.infradead.org/users/hch/dma-mapping:
swiotlb: export swiotlb_dma_ops
If SACK is not enabled and the first cumulative ACK after the RTO
retransmission covers more than the retransmitted skb, a spurious
FRTO undo will trigger (assuming FRTO is enabled for that RTO).
The reason is that any non-retransmitted segment acknowledged will
set FLAG_ORIG_SACK_ACKED in tcp_clean_rtx_queue even if there is
no indication that it would have been delivered for real (the
scoreboard is not kept with TCPCB_SACKED_ACKED bits in the non-SACK
case so the check for that bit won't help like it does with SACK).
Having FLAG_ORIG_SACK_ACKED set results in the spurious FRTO undo
in tcp_process_loss.
We need to use more strict condition for non-SACK case and check
that none of the cumulatively ACKed segments were retransmitted
to prove that progress is due to original transmissions. Only then
keep FLAG_ORIG_SACK_ACKED set, allowing FRTO undo to proceed in
non-SACK case.
(FLAG_ORIG_SACK_ACKED is planned to be renamed to FLAG_ORIG_PROGRESS
to better indicate its purpose but to keep this change minimal, it
will be done in another patch).
Besides burstiness and congestion control violations, this problem
can result in RTO loop: When the loss recovery is prematurely
undoed, only new data will be transmitted (if available) and
the next retransmission can occur only after a new RTO which in case
of multiple losses (that are not for consecutive packets) requires
one RTO per loss to recover.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Tested-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Originally in patch e6d20c55a4 ("openrisc: entry: Fix delay slot
detection") I fixed delay slot detection, but only for QEMU. We missed
that hardware delay slot detection using delay slot exception flag (DSX)
was still broken. This was because QEMU set the DSX flag in both
pre-exception supervision register (ESR) and supervision register (SR)
register, but on real hardware the DSX flag is only set on the SR
register during exceptions.
Fix this by carrying the DSX flag into the SR register during exception.
We also update the DSX flag read locations to read the value from the SR
register not the pt_regs SR register which represents ESR. The ESR
should never have the DSX flag set.
In the process I updated/removed a few comments to match the current
state. Including removing a comment saying that the DSX detection logic
was inefficient and needed to be rewritten.
I have tested this on QEMU with a patch ensuring it matches the hardware
specification.
Link: https://lists.gnu.org/archive/html/qemu-devel/2018-07/msg00000.html
Fixes: e6d20c55a4 ("openrisc: entry: Fix delay slot detection")
Signed-off-by: Stafford Horne <shorne@gmail.com>
Daniel Borkmann says:
pull-request: bpf 2018-07-01
The following pull-request contains BPF updates for your *net* tree.
The main changes are:
1) A bpf_fib_lookup() helper fix to change the API before freeze to
return an encoding of the FIB lookup result and return the nexthop
device index in the params struct (instead of device index as return
code that we had before), from David.
2) Various BPF JIT fixes to address syzkaller fallout, that is, do not
reject progs when set_memory_*() fails since it could still be RO.
Also arm32 JIT was not using bpf_jit_binary_lock_ro() API which was
an issue, and a memory leak in s390 JIT found during review, from
Daniel.
3) Multiple fixes for sockmap/hash to address most of the syzkaller
triggered bugs. Usage with IPv6 was crashing, a GPF in bpf_tcp_close(),
a missing sock_map_release() routine to hook up to callbacks, and a
fix for an omitted bucket lock in sock_close(), from John.
4) Two bpftool fixes to remove duplicated error message on program load,
and another one to close the libbpf object after program load. One
additional fix for nfp driver's BPF offload to avoid stopping offload
completely if replace of program failed, from Jakub.
5) Couple of BPF selftest fixes that bail out in some of the test
scripts if the user does not have the right privileges, from Jeffrin.
6) Fixes in test_bpf for s390 when CONFIG_BPF_JIT_ALWAYS_ON is set
where we need to set the flag that some of the test cases are expected
to fail, from Kleber.
7) Fix to detangle BPF_LIRC_MODE2 dependency from CONFIG_CGROUP_BPF
since it has no relation to it and lirc2 users often have configs
without cgroups enabled and thus would not be able to use it, from Sean.
8) Fix a selftest failure in sockmap by removing a useless setrlimit()
call that would set a too low limit where at the same time we are
already including bpf_rlimit.h that does the job, from Yonghong.
9) Fix BPF selftest config with missing missing NET_SCHED, from Anders.
John Fastabend says:
This addresses two syzbot issues that lead to identifying (by Eric and
Wei) a class of bugs where we don't correctly check for IPv4/v6
sockets and their associated state. The second issue was a locking
omission in sockhash.
The first patch addresses IPv6 socks and fixing an error where
sockhash would overwrite the prot pointer with IPv4 prot. To fix
this build similar solution to TLS ULP. Although we continue to
allow socks in all states not just ESTABLISH in this patch set
because as Martin points out there should be no issue with this
on the sockmap ULP because we don't use the ctx in this code. Once
multiple ULPs coexist we may need to revisit this. However we
can do this in *next trees.
The other issue syzbot found that the tcp_close() handler missed
locking the hash bucket lock which could result in corrupting the
sockhash bucket list if delete and close ran at the same time.
And also the smap_list_remove() routine was not working correctly
at all. This was not caught in my testing because in general my
tests (to date at least lets add some more robust selftest in
bpf-next) do things in the "expected" order, create map, add socks,
delete socks, then tear down maps. The tests we have that do the
ops out of this order where only working on single maps not multi-
maps so we never saw the issue. Thanks syzbot. The fix is to
restructure the tcp_close() lock handling. And fix the obvious
bug in smap_list_remove().
Finally, during review I noticed the release handler was omitted
from the upstream code (patch 4) due to an incorrect merge conflict
fix when I ported the code to latest bpf-next before submitting.
This would leave references to the map around if the user never
closes the map.
v3: rework patches, dropping ESTABLISH check and adding rcu
annotation along with the smap_list_remove fix
v4: missed one more case where maps was being accessed without
the sk_callback_lock, spoted by Martin as well.
v5: changed to use a specific lock for maps and reduced callback
lock so that it is only used to gaurd sk callbacks. I think
this makes the logic a bit cleaner and avoids confusion
ovoer what each lock is doing.
Also big thanks to Martin for thorough review he caught at least
one case where I missed a rcu_call().
Add map_release_uref pointer to hashmap ops. This was dropped when
original sockhash code was ported into bpf-next before initial
commit.
Fixes: 81110384441a ("bpf: sockmap, add hash map support")
Acked-by: Martin KaFai Lau <kafai@fb.com>
Signed-off-by: John Fastabend <john.fastabend@gmail.com>
First the sk_callback_lock() was being used to protect both the
sock callback hooks and the psock->maps list. This got overly
convoluted after the addition of sockhash (in sockmap it made
some sense because masp and callbacks were tightly coupled) so
lets split out a specific lock for maps and only use the callback
lock for its intended purpose. This fixes a couple cases where
we missed using maps lock when it was in fact needed. Also this
makes it easier to follow the code because now we can put the
locking closer to the actual code its serializing.
Next, in sock_hash_delete_elem() the pattern was as follows,
spin_lock(bucket_lock)
l = lookup_elem_raw()
if (l)
hlist_del_rcu()
write_lock(sk_callback_lock)
.... destroy psock ...
write_unlock(sk_callback_lock)
spin_unlock(bucket_lock)
The ordering is necessary because we only know the {p}sock after
dereferencing the hash table which we can't do unless we have the
bucket lock held. Once we have the bucket lock and the psock element
it is deleted from the hashmap to ensure any other path doing a lookup
will fail. Finally, the refcnt is decremented and if zero the psock
is destroyed.
In parallel with the above (or free'ing the map) a tcp close event
may trigger tcp_close(). Which at the moment omits the bucket lock
altogether (oops!) where the flow looks like this,
bpf_tcp_close()
for each psock->maps // list of maps this sock is part of
hlist_del_rcu(ref_hash_node);
Obviously, and demonstrated by syzbot, this is broken because
we can have multiple threads deleting entries via hlist_del_rcu().
To fix this we might be tempted to wrap the hlist operation in a
bucket lock but that would create a lock inversion problem. In
summary to follow locking rules the psocks maps list needs the
sk_callback_lock (after this patch maps_lock) but we need the bucket
lock to do the hlist_del_rcu.
To resolve the lock inversion problem pop the head of the maps list
repeatedly and remove the reference until no more are left. If a
delete happens in parallel from the BPF API that is OK as well because
it will do a similar action, lookup the lock in the map/hash, delete
it from the map/hash, and dec the refcnt. We check for this case
before doing a destroy on the psock to ensure we don't have two
threads tearing down a psock. The new logic is as follows,
bpf_tcp_close()
e = psock_map_pop(psock->maps) // done with map lock
bucket_lock() // lock hash list bucket
l = lookup_elem_raw(head, hash, key, key_size);
if (l) {
//only get here if elmnt was not already removed
hlist_del_rcu()
... destroy psock...
bucket_unlock()
And finally for all the above to work add missing locking around map
operations per above. Then add RCU annotations and use
rcu_dereference/rcu_assign_pointer to manage values relying on RCU so
that the object is not free'd from sock_hash_free() while it is being
referenced in bpf_tcp_close().
Reported-by: syzbot+0ce137753c78f7b6acc1@syzkaller.appspotmail.com
If a hashmap is free'd with open socks it removes the reference to
the hash entry from the psock. If that is the last reference to the
psock then it will also be free'd by the reference counting logic.
However the current logic that removes the hash reference from the
list of references is broken. In smap_list_remove() we first check
if the sockmap entry matches and then check if the hashmap entry
matches. But, the sockmap entry sill always match because its NULL in
this case which causes the first entry to be removed from the list.
If this is always the "right" entry (because the user adds/removes
entries in order) then everything is OK but otherwise a subsequent
bpf_tcp_close() may reference a free'd object.
To fix this create two list handlers one for sockmap and one for
sockhash.
This fixes a crash where we assign tcp_prot to IPv6 sockets instead
of tcpv6_prot.
Previously we overwrote the sk->prot field with tcp_prot even in the
AF_INET6 case. This patch ensures the correct tcp_prot and tcpv6_prot
are used.
Tested with 'netserver -6' and 'netperf -H [IPv6]' as well as
'netperf -H [IPv4]'. The ESTABLISHED check resolves the previously
crashing case here.
Fixes: 174a79ff9515 ("bpf: sockmap with sk redirect support")
Reported-by: syzbot+5c063698bdbfac19f363@syzkaller.appspotmail.com
Signed-off-by: Wei Wang <weiwan@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc fixes and cleanups from Helge Deller:
"Nothing exiting in this patchset, just
- small cleanups of header files
- default to 4 CPUs when building a SMP kernel
- mark 16kB and 64kB page sizes broken
- addition of the new io_pgetevents syscall"
* 'parisc-4.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Build kernel without -ffunction-sections
parisc: Reduce debug output in unwind code
parisc: Wire up io_pgetevents syscall
parisc: Default to 4 SMP CPUs
parisc: Convert printk(KERN_LEVEL) to pr_lvl()
parisc: Mark 16kB and 64kB page sizes BROKEN
parisc: Drop struct sigaction from not exported header file
Pull ARM SoC fixes from Olof Johansson:
"A smaller batch for the end of the week (let's see if I can keep the
weekly cadence going for once).
All medium-grade fixes here, nothing worrisome:
- Fixes for some fairly old bugs around SD card write-protect
detection and GPIO interrupt assignments on Davinci.
- Wifi module suspend fix for Hikey.
- Minor DT tweaks to fix inaccuracies for Amlogic platforms, one
of which solves booting with third-party u-boot"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arm64: dts: hikey960: Define wl1837 power capabilities
arm64: dts: hikey: Define wl1835 power capabilities
ARM64: dts: meson-gxl: fix Mali GPU compatible string
ARM64: dts: meson-axg: fix ethernet stability issue
ARM64: dts: meson-gx: fix ATF reserved memory region
ARM64: dts: meson-gxl-s905x-p212: Add phy-supply for usb0
ARM64: dts: meson: fix register ranges for SD/eMMC
ARM64: dts: meson: disable sd-uhs modes on the libretech-cc
ARM: dts: da850: Fix interrups property for gpio
ARM: davinci: board-da850-evm: fix WP pin polarity for MMC/SD
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild fixes from Masahiro Yamada:
- introduce __diag_* macros and suppress -Wattribute-alias warnings
from GCC 8
- fix stack protector test script for x86_64
- fix line number handling in Kconfig
- document that '#' starts a comment in Kconfig
- handle P_SYMBOL property in dump debugging of Kconfig
- correct help message of LD_DEAD_CODE_DATA_ELIMINATION
- fix occasional segmentation faults in Kconfig
* tag 'kbuild-fixes-v4.18' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kconfig: loop boundary condition fix
kbuild: reword help of LD_DEAD_CODE_DATA_ELIMINATION
kconfig: handle P_SYMBOL in print_symbol()
kconfig: document Kconfig source file comments
kconfig: fix line numbers for if-entries in menu tree
stack-protector: Fix test with 32-bit userland and CONFIG_64BIT=y
powerpc: Remove -Wattribute-alias pragmas
disable -Wattribute-alias warning for SYSCALL_DEFINEx()
kbuild: add macro for controlling warnings to linux/compiler.h
Pull x86 fixes from Ingo Molnar:
"The biggest diffstat comes from self-test updates, plus there's entry
code fixes, 5-level paging related fixes, console debug output fixes,
and misc fixes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm: Clean up the printk()s in show_fault_oops()
x86/mm: Drop unneeded __always_inline for p4d page table helpers
x86/efi: Fix efi_call_phys_epilog() with CONFIG_X86_5LEVEL=y
selftests/x86/sigreturn: Do minor cleanups
selftests/x86/sigreturn/64: Fix spurious failures on AMD CPUs
x86/entry/64/compat: Fix "x86/entry/64/compat: Preserve r8-r11 in int $0x80"
x86/mm: Don't free P4D table when it is folded at runtime
x86/entry/32: Add explicit 'l' instruction suffix
x86/mm: Get rid of KERN_CONT in show_fault_oops()
Pull perf fixes from Ingo Molnar:
"Tooling fixes mostly, plus a build warning fix"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
perf/core: Move inline keyword at the beginning of declaration
tools/headers: Pick up latest kernel ABIs
perf tools: Fix crash caused by accessing feat_ops[HEADER_LAST_FEATURE]
perf script: Fix crash because of missing evsel->priv
perf script: Add missing output fields in a hint
perf bench: Fix numa report output code
perf stat: Remove duplicate event counting
perf alias: Rebuild alias expression string to make it comparable
perf alias: Remove trailing newline when reading sysfs files
perf tools: Fix a clang 7.0 compilation error
tools include uapi: Synchronize bpf.h with the kernel
tools include uapi: Update if_link.h to pick IFLA_{BRPORT_ISOLATED,VXLAN_TTL_INHERIT}
tools include powerpc: Update arch/powerpc/include/uapi/asm/unistd.h copy to get 'rseq' syscall
perf tools: Update x86's syscall_64.tbl, adding 'io_pgetevents' and 'rseq'
tools headers uapi: Synchronize drm/drm.h
perf intel-pt: Fix packet decoding of CYC packets
perf tests: Add valid callback for parse-events test
perf tests: Add event parsing error handling to parse events test
perf report powerpc: Fix crash if callchain is empty
perf test session topology: Fix test on s390
git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/selinux
Pull selinux fix from Paul Moore:
"One fairly straightforward patch to fix a longstanding issue where a
process could stall while accessing files in selinuxfs and block
everyone else due to a held mutex.
The patch passes all our tests and looks to apply cleanly to your
current tree"
* tag 'selinux-pr-20180629' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/selinux:
selinux: move user accesses in selinuxfs out of locked regions
Pull block fixes from Jens Axboe:
"Small set of fixes for this series. Mostly just minor fixes, the only
oddball in here is the sg change.
The sg change came out of the stall fix for NVMe, where we added a
mempool and limited us to a single page allocation. CONFIG_SG_DEBUG
sort-of ruins that, since we'd need to account for that. That's
actually a generic problem, since lots of drivers need to allocate SG
lists. So this just removes support for CONFIG_SG_DEBUG, which I added
back in 2007 and to my knowledge it was never useful.
Anyway, outside of that, this pull contains:
- clone of request with special payload fix (Bart)
- drbd discard handling fix (Bart)
- SATA blk-mq stall fix (me)
- chunk size fix (Keith)
- double free nvme rdma fix (Sagi)"
* tag 'for-linus-20180629' of git://git.kernel.dk/linux-block:
sg: remove ->sg_magic member
drbd: Fix drbd_request_prepare() discard handling
blk-mq: don't queue more if we get a busy return
block: Fix cloning of requests with a special payload
nvme-rdma: fix possible double free of controller async event buffer
block: Fix transfer when chunk sectors exceeds max
After commit f9d4b0c1e969 ("fib_rules: move common handling of newrule
delrule msgs into fib_nl2rule"), rule_exists got replaced by rule_find
for existing rule lookup in both the add and del paths. While this
is good for the delete path, it solves a few problems but opens up
a few invalid key matches in the add path.
$ip -4 rule add table main tos 10 fwmark 1
RTNETLINK answers: File exists
The problem here is rule_find does not check if the key masks in
the new and old rule are the same and hence ends up matching a more
secific rule. Rule key masks cannot be easily compared today without
an elaborate if-else block. Its best to introduce key masks for easier
and accurate rule comparison in the future. Until then, due to fear of
regressions this patch re-introduces older loose rule_exists during add.
Also fixes both rule_exists and rule_find to cover missing attributes.
Fixes: f9d4b0c1e969 ("fib_rules: move common handling of newrule delrule msgs into fib_nl2rule")
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
When doing device hotplug the sub channel must be async to avoid
deadlock issues because device is discovered in softirq context.
When doing changes to MTU and number of channels, the setup
must be synchronous to avoid races such as when MTU and device
settings are done in a single ip command.
Reported-by: Thomas Walker <Thomas.Walker@twosigma.com>
Fixes: 8195b1396ec8 ("hv_netvsc: fix deadlock on hotplug")
Fixes: 732e49850c5e ("netvsc: fix race on sub channel creation")
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
As noticed by Eric, we need to switch to the helper
dev_change_tx_queue_len() for SIOCSIFTXQLEN call path too,
otheriwse still miss dev_qdisc_change_tx_queue_len().
Fixes: 6a643ddb5624 ("net: introduce helper dev_change_tx_queue_len()")
Reported-by: Eric Dumazet <edumazet@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
pool can be indirectly controlled by user-space, hence leading to
a potential exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
drivers/atm/zatm.c:1491 zatm_ioctl() warn: potential spectre issue
'zatm_dev->pool_info' (local cap)
Fix this by sanitizing pool before using it to index
zatm_dev->pool_info
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Julian Wiedmann says:
s390/qeth: fixes 2018-06-29
please apply a few qeth fixes for -net and your 4.17 stable queue.
Patches 1-3 fix several issues wrt to MAC address management that were
introduced during the 4.17 cycle.
Patch 4 tackles a long-standing issue with busy multi-connection workloads
on devices in af_iucv mode.
Patch 5 makes sure to re-enable all active HW offloads, after a card was
previously set offline and thus lost its HW context.
commit e830baa9c3f0 ("qeth: restore device features after recovery") and
commit ce3443564145 ("s390/qeth: rely on kernel for feature recovery")
made sure that the HW functions for device features get re-programmed
after recovery.
But we missed that the same handling is also required when a card is
first set offline (destroying all HW context), and then online again.
Fix this by moving the re-enable action out of the recovery-only path.
Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com>
If qeth_qdio_output_handler() detects that a transmit requires async
completion, it replaces the pending buffer's metadata object
(qeth_qdio_out_buffer) so that this queue buffer can be re-used while
the data is pending completion.
Later when the CQ indicates async completion of such a metadata object,
qeth_qdio_cq_handler() tries to free any data associated with this
object (since HW has now completed the transfer). By calling
qeth_clear_output_buffer(), it erronously operates on the queue buffer
that _previously_ belonged to this transfer ... but which has been
potentially re-used several times by now.
This results in double-free's of the buffer's data, and failing
transmits as the buffer descriptor is scrubbed in mid-air.
The correct way of handling this situation is to
1. scrub the queue buffer when it is prepared for re-use, and
2. later obtain the data addresses from the async-completion notifier
(ie. the AOB), instead of the queue buffer.
All this only affects qeth devices used for af_iucv HiperTransport.
Fixes: 0da9581ddb0f ("qeth: exploit asynchronous delivery of storage blocks")
*ether_addr*_64bits functions have been introduced to optimize
performance critical paths, which access 6-byte ethernet address as u64
value to get "nice" assembly. A harmless hack works nicely on ethernet
addresses shoved into a structure or a larger buffer, until busted by
Kasan on smth like plain (u8 *)[6].
qeth_l2_set_mac_address calls qeth_l2_remove_mac passing
u8 old_addr[ETH_ALEN] as an argument.
Adding/removing macs for an ethernet adapter is not that performance
critical. Moreover is_multicast_ether_addr_64bits itself on s390 is not
faster than is_multicast_ether_addr:
is_multicast_ether_addr(%r2) -> %r2
llc %r2,0(%r2)
risbg %r2,%r2,63,191,0
is_multicast_ether_addr_64bits(%r2) -> %r2
llgc %r2,0(%r2)
So, let's just use is_multicast_ether_addr instead of
is_multicast_ether_addr_64bits.
Fixes: bcacfcbc82b4 ("s390/qeth: fix MAC address update sequence")
Reviewed-by: Julian Wiedmann <jwi@linux.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
When qeth_l2_set_mac_address() finds the card in a non-reachable state,
it merely copies the new MAC address into dev->dev_addr so that
__qeth_l2_set_online() can later register it with the HW.
But __qeth_l2_set_online() may very well be running concurrently, so we
can't trust the card state without appropriate locking:
If the online sequence is past the point where it registers
dev->dev_addr (but not yet in SOFTSETUP state), any address change needs
to be properly programmed into the HW. Otherwise the netdevice ends up
with a different MAC address than what's set in the HW, and inbound
traffic is not forwarded as expected.
This is most likely to occur for OSD in LPAR, where
commit 21b1702af12e ("s390/qeth: improve fallback to random MAC address")
now triggers eg. systemd to immediately change the MAC when the netdevice
is registered with a NET_ADDR_RANDOM address.
