Pull vfs pile 1 from Al Viro:
"Unfortunately, this merge window it'll have a be a lot of small piles -
my fault, actually, for not keeping #for-next in anything that would
resemble a sane shape ;-/
This pile: assorted fixes (the first 3 are -stable fodder, IMO) and
cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last
components) + several long-standing patches from various folks.
There definitely will be a lot more (starting with Miklos'
check_submount_and_drop() series)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
direct-io: Handle O_(D)SYNC AIO
direct-io: Implement generic deferred AIO completions
add formats for dentry/file pathnames
kvm eventfd: switch to fdget
powerpc kvm: use fdget
switch fchmod() to fdget
switch epoll_ctl() to fdget
switch copy_module_from_fd() to fdget
git simplify nilfs check for busy subtree
ibmasmfs: don't bother passing superblock when not needed
don't pass superblock to hypfs_{mkdir,create*}
don't pass superblock to hypfs_diag_create_files
don't pass superblock to hypfs_vm_create_files()
oprofile: get rid of pointless forward declarations of struct super_block
oprofilefs_create_...() do not need superblock argument
oprofilefs_mkdir() doesn't need superblock argument
don't bother with passing superblock to oprofile_create_stats_files()
oprofile: don't bother with passing superblock to ->create_files()
don't bother passing sb to oprofile_create_files()
coh901318: don't open-code simple_read_from_buffer()
Merge IPMI fixes from:
"A few things for 3.12 from various people"
* emailed patches from Corey Minyard <minyard@acm.org>:
BMC support for PARISC machines
Add MODULE_ALIAS for autoloading ipmi driver on ACPI systems
ipmi: Initialize locals to avoid warning
ipmi: info leak in compat_ipmi_ioctl()
The last line of PARISC machines (C8000, RP34x0, etc.) have a BMC for
controlling temperature, fan speed and other stuff. The BMC is
connected via a special bus and listed in the firmware device tree.
This change adds support for these BMCs to the IPMI driver.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
I'd submitted this about a year ago but it never made it upstream.
The latest versions of the kernel drivers for ipmi can use ACPI to
determine the type of BMC device used in the system. The following
patch adds a module alias so that udev will autoload the ipmi_si driver.
Signed-off-by: Jordan Hargrave <jordan_hargrave@dell.com>
A couple of variables were getting warnings about being uninitialized.
It was a false warning, but initialize them, anyway.
On x86_64 there is a 4 byte hole between ->recv_type and ->addr.
Pull KVM updates from Gleb Natapov:
"The highlights of the release are nested EPT and pv-ticketlocks
support (hypervisor part, guest part, which is most of the code, goes
through tip tree). Apart of that there are many fixes for all arches"
Fix up semantic conflicts as discussed in the pull request thread..
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (88 commits)
ARM: KVM: Add newlines to panic strings
ARM: KVM: Work around older compiler bug
ARM: KVM: Simplify tracepoint text
ARM: KVM: Fix kvm_set_pte assignment
ARM: KVM: vgic: Bump VGIC_NR_IRQS to 256
ARM: KVM: Bugfix: vgic_bytemap_get_reg per cpu regs
ARM: KVM: vgic: fix GICD_ICFGRn access
ARM: KVM: vgic: simplify vgic_get_target_reg
KVM: MMU: remove unused parameter
KVM: PPC: Book3S PR: Rework kvmppc_mmu_book3s_64_xlate()
KVM: PPC: Book3S PR: Make instruction fetch fallback work for system calls
KVM: PPC: Book3S PR: Don't corrupt guest state when kernel uses VMX
KVM: x86: update masterclock when kvmclock_offset is calculated (v2)
KVM: PPC: Book3S: Fix compile error in XICS emulation
KVM: PPC: Book3S PR: return appropriate error when allocation fails
arch: powerpc: kvm: add signed type cast for comparation
KVM: x86: add comments where MMIO does not return to the emulator
KVM: vmx: count exits to userspace during invalid guest emulation
KVM: rename __kvm_io_bus_sort_cmp to kvm_io_bus_cmp
kvm: optimize away THP checks in kvm_is_mmio_pfn()
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen updates from Konrad Rzeszutek Wilk:
"A couple of features and a ton of bug-fixes. There is also some
maintership changes. Jeremy is enjoying the full-time work at the
startup and as much as he would love to help - he can't find the time.
I have a bunch of other things that I promised to work on - paravirt
diet, get SWIOTLB working everywhere, etc, but haven't been able to
find the time.
As such both David Vrabel and Boris Ostrovsky have graciously
volunteered to help with the maintership role. They will keep the lid
on regressions, bug-fixes, etc. I will be in the background to help -
but eventually there will be less of me doing the Xen GIT pulls and
more of them. Stefano is still doing the ARM/ARM64 and will continue
on doing so.
Features:
- Xen Trusted Platform Module (TPM) frontend driver - with the
backend in MiniOS.
- Scalability improvements in event channel.
- Two extra Xen co-maintainers (David, Boris) and one going away (Jeremy)
Bug-fixes:
- Make the 1:1 mapping work during early bootup on selective regions.
- Add scratch page to balloon driver to deal with unexpected code
still holding on stale pages.
- Allow NMIs on PV guests (64-bit only)
- Remove unnecessary TLB flush in M2P code.
- Fixes duplicate callbacks in Xen granttable code.
- Fixes in PRIVCMD_MMAPBATCH ioctls to allow retries
- Fix for events being lost due to rescheduling on different VCPUs.
- More documentation"
* tag 'stable/for-linus-3.12-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (23 commits)
hvc_xen: Remove unnecessary __GFP_ZERO from kzalloc
drivers/xen-tpmfront: Fix compile issue with missing option.
xen/balloon: don't set P2M entry for auto translated guest
xen/evtchn: double free on error
Xen: Fix retry calls into PRIVCMD_MMAPBATCH*.
xen/pvhvm: Initialize xen panic handler for PVHVM guests
xen/m2p: use GNTTABOP_unmap_and_replace to reinstate the original mapping
xen: fix ARM build after 6efa20e4
MAINTAINERS: Remove Jeremy from the Xen subsystem.
xen/events: document behaviour when scanning the start word for events
x86/xen: during early setup, only 1:1 map the ISA region
x86/xen: disable premption when enabling local irqs
swiotlb-xen: replace dma_length with sg_dma_len() macro
swiotlb: replace dma_length with sg_dma_len() macro
xen/balloon: set a mapping for ballooned out pages
xen/evtchn: improve scalability by using per-user locks
xen/p2m: avoid unneccesary TLB flush in m2p_remove_override()
MAINTAINERS: Add in two extra co-maintainers of the Xen tree.
MAINTAINERS: Update the Xen subsystem's with proper mailing list.
xen: replace strict_strtoul() with kstrtoul()
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Minor fixes mainly, including a potential use-after-free on remove
found by CONFIG_DEBUG_KOBJECT_RELEASE which may be theoretical"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
module: Fix mod->mkobj.kobj potentially freed too early
kernel/params.c: use scnprintf() instead of sprintf()
kernel/module.c: use scnprintf() instead of sprintf()
module/lsm: Have apparmor module parameters work with no args
module: Add NOARG flag for ops with param_set_bool_enable_only() set function
module: Add flag to allow mod params to have no arguments
modules: add support for soft module dependencies
scripts/mod/modpost.c: permit '.cranges' secton for sh64 architecture.
module: fix sprintf format specifier in param_get_byte()
Pull PTR_RET() removal patches from Rusty Russell:
"PTR_RET() is a weird name, and led to some confusing usage. We ended
up with PTR_ERR_OR_ZERO(), and replacing or fixing all the usages.
This has been sitting in linux-next for a whole cycle"
[ There are still some PTR_RET users scattered about, with some of them
possibly being new, but most of them existing in Rusty's tree too. We
have that
#define PTR_RET(p) PTR_ERR_OR_ZERO(p)
thing in <linux/err.h>, so they continue to work for now - Linus ]
* tag 'PTR_RET-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
GFS2: Replace PTR_RET with PTR_ERR_OR_ZERO
Btrfs: volume: Replace PTR_RET with PTR_ERR_OR_ZERO
drm/cma: Replace PTR_RET with PTR_ERR_OR_ZERO
sh_veu: Replace PTR_RET with PTR_ERR_OR_ZERO
dma-buf: Replace PTR_RET with PTR_ERR_OR_ZERO
drivers/rtc: Replace PTR_RET with PTR_ERR_OR_ZERO
mm/oom_kill: remove weird use of ERR_PTR()/PTR_ERR().
staging/zcache: don't use PTR_RET().
remoteproc: don't use PTR_RET().
pinctrl: don't use PTR_RET().
acpi: Replace weird use of PTR_RET.
s390: Replace weird use of PTR_RET.
PTR_RET is now PTR_ERR_OR_ZERO(): Replace most.
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm
Pull dlm updates from David Teigland:
"This set includes a workqueue cleanup and the removal of incorrect and
unneeded signal blocking"
* tag 'dlm-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm:
dlm: remove signal blocking
dlm: WQ_NON_REENTRANT is meaningless and going away
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"New features for 3.12:
- Added aggressive extent caching using the extent status tree. This
can actually decrease memory usage in read-mostly workloads since
the information is much more compactly stored in the extent status
tree than if we had to keep the extent tree metadata blocks in the
buffer cache. This also improves Asynchronous I/O since it is it
makes much less likely that we need to do metadata I/O to lookup
the extent tree information.
- Improve the recovery after corrupted allocation bitmaps are found
when running in errors=ignore mode.
Also fixed some writeback vs truncate races when using a blocksize
less than the page size"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (25 commits)
ext4: allow specifying external journal by pathname mount option
ext4: mark group corrupt on group descriptor checksum
ext4: mark block group as corrupt on inode bitmap error
ext4: mark block group as corrupt on block bitmap error
ext4: fix type declaration of ext4_validate_block_bitmap
ext4: error out if verifying the block bitmap fails
jbd2: Fix endian mixing problems in the checksumming code
ext4: isolate ext4_extents.h file
ext4: Fix misspellings using 'codespell' tool
ext4: convert write_begin methods to stable_page_writes semantics
ext4: fix use of potentially uninitialized variables in debugging code
ext4: fix lost truncate due to race with writeback
ext4: simplify truncation code in ext4_setattr()
ext4: fix ext4_writepages() in presence of truncate
ext4: move test whether extent to map can be extended to one place
ext4: fix warning in ext4_da_update_reserve_space()
quota: provide interface for readding allocated space into reserved space
ext4: avoid reusing recently deleted inodes in no journal mode
ext4: allocate delayed allocation blocks before rename
ext4: start handle at least possible moment when renaming files
All the cool kids are doing this, join in the fun.
Signed-off-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"Changes are seen in a wide range of codes, mainly due to ASoC DAPM
requirements; HD-audio shows a high peak in diffstat, it's just a
removal of bunch of old static quirks.
Some highlights:
- HDPM: Updates for AIO/RayDAT support, TCO/sync support
- RME96: Add PCM sync support
- HD-audio:
* A few HDMI/DP audio updates (CA assignment fix, stream switching
fix, Intel DP device list support)
* Device specific fixes (ASUS/CXT HP mic support, Thinkpad mic
improvements, Chromebook fixes, STAC9228 Dell fixes)
* Replace the all static quirks for AD codecs with the generic
parser
* WAKEEN support for handling irqs in the power saving mode
- USB-audio: Clean up implicit fb handling and related codes
- DAPM is now mandatory for ASoC CODEC drivers; all existing drivers
have had some level of DAPM support added. In addition, a lot of
cleanups and improvements in DAPM.
- Support for ASoC cross-platform compile test
- New drivers and support for Analog Devices ADAU1702 and
ADAU1401(a), Asahi Kasei Microdevices AK4554, Atmel AT91ASM9x5 and
WM8904 based machines, Freescale S/PDIF and SSI AC'97, Renesas
R-Car SoCs, Samsung Exynos5420 SoCs, Texas Instruments PCM1681 and
PCM1792A and Wolfson Microelectronics WM8997
- DT bindings for kirkwood and i.MX S/PDIF
- Clean up and bug fixes: ssm2602, rt5640 and sgtl5000.
- Core helpers for bitbanged AC'97 reset"
* tag 'sound-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (375 commits)
ALSA: hda - Re-setup HDMI pin and audio infoframe on stream switches
ALSA: hda - hdmi: Fallback to ALSA allocation when selecting CA
ASoC: mxs-sgtl5000: Configure the dai_links as unidirectional
ASoC: soc-pcm: Allow to specify unidirectional dai_link
ASoC: fsl_spdif: Staticse non-exported symbols
ASoC: ssm2602: Fix cache sync
ASoC: Remove unused sysfs_registered field from snd_soc_codec struct
ASoC: Remove unused debugfs_dapm field from snd_soc_{platform,codec} struct
ASoC: Remove unused control_type field from snd_soc_codec struct
ASoC: fsl: Add one blank space after ':=' in Makefile
ASoC: fsl: Add wrapping for dev_dbg() in fsl_spdif.c
ASoC: rt5640: change widget sequence for depop
ASoC: dapm: Fix auto-disable for inverted controls
ASoC: fsl: Drop SND_SOC_FSL_UTILS from SND_SOC_IMX_SPDIF
ASoC: Samsung: Do not queue cyclic buffers multiple times
ASoC: ep93xx-i2s: Remove unnecessary dev_set_drvdata()
ASoC: designware_i2s: Remove unnecessary dev_set_drvdata()
ASoC: fsl_spdif: remove redundant dev_err call in fsl_spdif_probe()
ASoC: fsl: Add S/PDIF machine driver
ASoc: kirkwood: Use the Kirkwood audio driver in Dove boards
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control changes from Linus Walleij:
"Here is the bulk of pin control changes for the v3.12 series. Most of
the relevant information is in the tag.
I merged in v3.11-rc7 last week to get rid of a largeish conflict
within the sunxi (AllWinner) driver in linux-next and fix up the
non-trivial merge the right way. That driver had a rather large fix
adding locking late in the release cycle.
Overall the bulk changes this time is cleanups and refactorings and
not much new features, which is nice.
- Refactorings for generic pin config handling in the core.
- Factor out a set of device tree utilities for use in all drivers,
to parse and allocate maps from the device tree.
- Some fixes to the core such as more nitpicky locking.
- Pushed down config array iteration into the drivers.
This patch is necessary for drivers that want to iterate over
configs and pile up a stack of alterations to the same register(s),
or if the driver wants to take a local spinlock when committing the
configuration.
- A new driver for the Texas Instruments Palmas PMIC by Laxman
Dewangan. This is used on the Tegra systems.
- A major cleanup and modernization of the PFC (Super Hitachi and ARM
SHmobile) pin controller and subdrivers.
- Support for the A20 and A31 sunxi (AllWinner) SoCs.
- A huge pile of fixes and cleanups: Axel Lin, Jingoo Han Dan
Carpenter, Julia Lawall and Sachin Kamat did an excellent job here"
* tag 'pinctrl-v3.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (124 commits)
pinctrl: sunxi: Fix off-by-one for valid offset range checking
pinctrl: sunxi: drop lock on error path
pinctrl: pinconf-generic: Remove ti prefix in dev_err messages
pinctrl: rockchip: Implement .request() and .free() callbacks
pinctrl: at91: fix get_pullup/down function return
pinctrl: sh-pfc: remove unnecessary platform_set_drvdata()
pinctrl: Add s5pv210 support to pinctrl-exynos
pinctrl: utils: include export.h to avoid warnings
pinctrl: s3c24xx: off by one in s3c24xx_eint_init()
pinctrl: mvebu: testing the wrong variable
pinctrl: abx500: fix bitwise AND test
pinctrl: mvebu: Convert to use devm_ioremap_resource
pinctrl: Pass all configs to driver on pin_config_set()
pinctrl: tz1090-pdc: Convert to devm_ioremap_resource
pinctrl: tz1090: Convert to devm_ioremap_resource
pinctrl: tegra: Convert to devm_ioremap_resource
pinctrl: rockchip: Simplify pin_to_bank equation
pinctrl: spear: Convert to devm_ioremap_resource
pinctrl: rockchip: Remove of_match_ptr macro for DT only driver
pinctrl: palmas: PINCTRL_PALMAS needs to select PINMUX
Pull x86 spinlock changes from Ingo Molnar:
"The biggest change here are paravirtualized ticket spinlocks (PV
spinlocks), which bring a nice speedup on various benchmarks.
The KVM host side will come to you via the KVM tree"
* 'x86-spinlocks-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/kvm/guest: Fix sparse warning: "symbol 'klock_waiting' was not declared as static"
kvm: Paravirtual ticketlocks support for linux guests running on KVM hypervisor
kvm guest: Add configuration support to enable debug information for KVM Guests
kvm uapi: Add KICK_CPU and PV_UNHALT definition to uapi
xen, pvticketlock: Allow interrupts to be enabled while blocking
x86, ticketlock: Add slowpath logic
jump_label: Split jumplabel ratelimit
x86, pvticketlock: When paravirtualizing ticket locks, increment by 2
x86, pvticketlock: Use callee-save for lock_spinning
xen, pvticketlocks: Add xen_nopvspin parameter to disable xen pv ticketlocks
xen, pvticketlock: Xen implementation for PV ticket locks
xen: Defer spinlock setup until boot CPU setup
x86, ticketlock: Collapse a layer of functions
x86, ticketlock: Don't inline _spin_unlock when using paravirt spinlocks
x86, spinlock: Replace pv spinlocks with pv ticketlocks
Pull x86 SMAP fixes from Ingo Molnar:
"Fixes for Intel SMAP support, to fix SIGSEGVs during bootup"
* 'x86-smap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Introduce [compat_]save_altstack_ex() to unbreak x86 SMAP
x86, smap: Handle csum_partial_copy_*_user()
Pull x86 RAS changes from Ingo Molnar:
"[ The reason for drivers/ updates is that Boris asked for the
drivers/edac/ changes to go via x86/ras in this cycle ]
Main changes:
- AMD CPUs:
. Add ECC event decoding support for new F15h models
. Various erratum fixes
. Fix single-channel on dual-channel-controllers bug.
- Intel CPUs:
. UC uncorrectable memory error parsing fix
. Add support for CMC (Corrected Machine Check) 'FF' (Firmware
First) flag in the APEI HEST
- Various cleanups and fixes"
* 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
amd64_edac: Fix incorrect wraparounds
amd64_edac: Correct erratum 505 range
cpc925_edac: Use proper array termination
x86/mce, acpi/apei: Only disable banks listed in HEST if mce is configured
amd64_edac: Get rid of boot_cpu_data accesses
amd64_edac: Add ECC decoding support for newer F15h models
x86, amd_nb: Clarify F15h, model 30h GART and L3 support
pci_ids: Add PCI device ID functions 3 and 4 for newer F15h models.
x38_edac: Make a local function static
i3200_edac: Make a local function static
x86/mce: Pay no attention to 'F' bit in MCACOD when parsing 'UC' errors
APEI/ERST: Fix error message formatting
amd64_edac: Fix single-channel setups
EDAC: Replace strict_strtol() with kstrtol()
mce: acpi/apei: Soft-offline a page on firmware GHES notification
mce: acpi/apei: Add a boot option to disable ff mode for corrected errors
mce: acpi/apei: Honour Firmware First for MCA banks listed in APEI HEST CMC
Pull x86 platform documentation fix from Ingo Molnar.
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/acpi: Correct out-of-date comment of __acpi_map_table()
Pull x86 paravirt changes from Ingo Molnar:
"Hypervisor signature detection cleanup and fixes - the goal is to make
KVM guests run better on MS/Hyperv and to generalize and factor out
the code a bit"
* 'x86-paravirt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Correctly detect hypervisor
x86, kvm: Switch to use hypervisor_cpuid_base()
xen: Switch to use hypervisor_cpuid_base()
x86: Introduce hypervisor_cpuid_base()
Pull x86 mm changes from Ingo Molnar:
"Misc smaller fixes:
- a parse_setup_data() boot crash fix
- a memblock and an __early_ioremap cleanup
- turn the always-on CONFIG_ARCH_MEMORY_PROBE=y into a configurable
option and turn it off - it's an unrobust debug facility, it
shouldn't be enabled by default"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: avoid remapping data in parse_setup_data()
x86: Use memblock_set_current_limit() to set limit for memblock.
mm: Remove unused variable idx0 in __early_ioremap()
mm/hotplug, x86: Disable ARCH_MEMORY_PROBE by default
Pull x86 relocation changes from Ingo Molnar:
"This tree contains a single change, ELF relocation handling in C - one
of the kernel randomization patches that makes sense even without
randomization present upstream"
* 'x86-kaslr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, relocs: Move ELF relocation handling to C
Pull timers/nohz changes from Ingo Molnar:
"It mostly contains fixes and full dynticks off-case optimizations, by
Frederic Weisbecker"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
nohz: Include local CPU in full dynticks global kick
nohz: Optimize full dynticks's sched hooks with static keys
nohz: Optimize full dynticks state checks with static keys
nohz: Rename a few state variables
vtime: Always debug check snapshot source _before_ updating it
vtime: Always scale generic vtime accounting results
vtime: Optimize full dynticks accounting off case with static keys
vtime: Describe overriden functions in dedicated arch headers
m68k: hardirq_count() only need preempt_mask.h
hardirq: Split preempt count mask definitions
context_tracking: Split low level state headers
vtime: Fix racy cputime delta update
vtime: Remove a few unneeded generic vtime state checks
context_tracking: User/kernel broundary cross trace events
context_tracking: Optimize context switch off case with static keys
context_tracking: Optimize guest APIs off case with static key
context_tracking: Optimize main APIs off case with static key
context_tracking: Ground setup for static key use
context_tracking: Remove full dynticks' hacky dependency on wide context tracking
nohz: Only enable context tracking on full dynticks CPUs
Pull x86 fb changes from Ingo Molnar:
"This tree includes preparatory patches for SimpleDRM driver support,
by David Herrmann. They clean up x86 framebuffer support by creating
simplefb devices wherever possible. More background can be found at
http://lwn.net/Articles/558104/"
* 'x86-fb-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
fbdev: fbcon: select VT_HW_CONSOLE_BINDING
fbdev: efifb: bind to efi-framebuffer
fbdev: vesafb: bind to platform-framebuffer device
fbdev: simplefb: add common x86 RGB formats
x86: sysfb: move EFI quirks from efifb to sysfb
x86: provide platform-devices for boot-framebuffers
fbdev: simplefb: mark as fw and allocate apertures
fbdev: simplefb: add init through platform_data
Pull x86 cpu feature fixes from Ingo Molnar:
"Two small cpufeature support updates"
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Fix override new_cpu_data.x86 with 486
x86, cpufeature: Use new CC_HAVE_ASM_GOTO
Pull tiny x86 boot cleanups from Ingo Molnar.
* 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/boot: Fix a sanity check in printf.c
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, boot: Fix warning due to undeclared strlen()
Pull x86/asmlinkage changes from Ingo Molnar:
"As a preparation for Andi Kleen's LTO patchset (link time
optimizations using GCC's -flto which build time optimization has
steadily increased in quality over the past few years and might
eventually be usable for the kernel too) this tree includes a handful
of preparatory patches that make function calling convention
annotations consistent again:
- Mark every function without arguments (or 64bit only) that is used
by assembly code with asmlinkage()
- Mark every function with parameters or variables that is used by
assembly code as __visible.
For the vanilla kernel this has documentation, consistency and
debuggability advantages, for the time being"
* 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/asmlinkage: Fix warning in xen asmlinkage change
x86, asmlinkage, vdso: Mark vdso variables __visible
x86, asmlinkage, power: Make various symbols used by the suspend asm code visible
x86, asmlinkage: Make dump_stack visible
x86, asmlinkage: Make 64bit checksum functions visible
x86, asmlinkage, paravirt: Add __visible/asmlinkage to xen paravirt ops
x86, asmlinkage, apm: Make APM data structure used from assembler visible
x86, asmlinkage: Make syscall tables visible
x86, asmlinkage: Make several variables used from assembler/linker script visible
x86, asmlinkage: Make kprobes code visible and fix assembler code
x86, asmlinkage: Make various syscalls asmlinkage
x86, asmlinkage: Make 32bit/64bit __switch_to visible
x86, asmlinkage: Make _*_start_kernel visible
x86, asmlinkage: Make all interrupt handlers asmlinkage / __visible
x86, asmlinkage: Change dotraplinkage into __visible on 32bit
x86: Fix sys_call_table type in asm/syscall.h
Pull x86/asm changes from Ingo Molnar:
"Main changes:
- Apply low level mutex optimization on x86-64, by Wedson Almeida
Filho.
- Change bitops to be naturally 'long', by H Peter Anvin.
- Add TSX-NI opcodes support to the x86 (instrumentation) decoder, by
Masami Hiramatsu.
- Add clang compatibility adjustments/workarounds, by Jan-Simon
Möller"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, doc: Update uaccess.h comment to reflect clang changes
x86, asm: Fix a compilation issue with clang
x86, asm: Extend definitions of _ASM_* with a raw format
x86, insn: Add new opcodes as of June, 2013
x86/ia32/asm: Remove unused argument in macro
x86, bitops: Change bitops to be native operand size
x86: Use asm-goto to implement mutex fast path on x86-64
Pull x86/apic changes from Ingo Molnar:
"Smaller fixes"
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/ioapic: Check attr against the previous setting when programmed more than once
x86/ioapic/kcrash: Prevent crash_kexec() from deadlocking on ioapic_lock
x86/acpi: Fix incorrect sanity check in acpi_register_lapic()
Pull timer changes from Ingo Molnar:
"Various clocksource driver updates: extend the core with memory mapped
hardware (mmio) support and add new (ARM) Moxart SoC and sun4i
hardware support"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
clocksource: arch_timer: Add support for memory mapped timers
clocksource: arch_timer: Push the read/write wrappers deeper
Documentation: Add memory mapped ARM architected timer binding
clocksource: arch_timer: Pass clock event to set_mode callback
clocksource: arch_timer: Make register accessors less error-prone
ARM: clocksource: moxart: documentation: Update device tree bindings document
ARM: clocksource: moxart: Add bitops.h include
ARM: clocksource: moxart: documentation: Fix device tree bindings document
ARM: clocksource: Add support for MOXA ART SoCs
clocksource: cadence_ttc: Reuse clocksource as sched_clock
clocksource: cadence_ttc: Remove unused header
clocksource: sun4i: Fix bug when switching from periodic to oneshot modes
clocksource: sun4i: Cleanup parent clock setup
clocksource: sun4i: Remove TIMER_SCAL variable
clocksource: sun4i: Factor out some timer code
clocksource: sun4i: Fix the next event code
clocksource: sun4i: Don't forget to enable the clock we use
clocksource: sun4i: Add clocksource and sched clock drivers
clocksource: sun4i: rename AUTORELOAD define to RELOAD
clocksource: sun4i: Wrap macros arguments in parenthesis
Pull scheduler changes from Ingo Molnar:
"Various optimizations, cleanups and smaller fixes - no major changes
in scheduler behavior"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/fair: Fix the sd_parent_degenerate() code
sched/fair: Rework and comment the group_imb code
sched/fair: Optimize find_busiest_queue()
sched/fair: Make group power more consistent
sched/fair: Remove duplicate load_per_task computations
sched/fair: Shrink sg_lb_stats and play memset games
sched: Clean-up struct sd_lb_stat
sched: Factor out code to should_we_balance()
sched: Remove one division operation in find_busiest_queue()
sched/cputime: Use this_cpu_add() in task_group_account_field()
cpumask: Fix cpumask leak in partition_sched_domains()
sched/x86: Optimize switch_mm() for multi-threaded workloads
generic-ipi: Kill unnecessary variable - csd_flags
numa: Mark __node_set() as __always_inline
sched/fair: Cleanup: remove duplicate variable declaration
sched/__wake_up_sync_key(): Fix nr_exclusive tasks which lead to WF_SYNC clearing
Pull perf changes from Ingo Molnar:
"As a first remark I'd like to point out that the obsolete '-f'
(--force) option, which has not done anything for several releases,
has been removed from 'perf record' and related utilities. Everyone
please update muscle memory accordingly! :-)
Main changes on the perf kernel side:
- Performance optimizations:
. for trace events, by Steve Rostedt.
. for time values, by Peter Zijlstra
- New hardware support:
. for Intel Silvermont (22nm Atom) CPUs, by Zheng Yan
. for Intel SNB-EP uncore PMUs, by Zheng Yan
- Enhanced hardware support:
. for Intel uncore PMUs: add filter support for QPI boxes, by Zheng Yan
- Core perf events code enhancements and fixes:
. for full-nohz feature handling, by Frederic Weisbecker
. for group events, by Jiri Olsa
. for call chains, by Frederic Weisbecker
. for event stream parsing, by Adrian Hunter
- New ABI details:
. Add attr->mmap2 attribute, by Stephane Eranian
. Add PERF_EVENT_IOC_ID ioctl to return event ID, by Jiri Olsa
. Export u64 time_zero on the mmap header page to allow TSC
calculation, by Adrian Hunter
. Add dummy software event, by Adrian Hunter.
. Add a new PERF_SAMPLE_IDENTIFIER to make samples always
parseable, by Adrian Hunter.
. Make Power7 events available via sysfs, by Runzhen Wang.
- Code cleanups and refactorings:
. for nohz-full, by Frederic Weisbecker
- Documentation updates:
. for perf_event_type, by Peter Zijlstra
Main changes on the perf tooling side (some of these tooling changes
utilize the above kernel side changes):
- Lots of 'perf trace' enhancements:
. Make 'perf trace' command line arguments consistent with
'perf record', by David Ahern.
. Allow specifying syscalls a la strace, by Arnaldo Carvalho de Melo.
. Add --verbose and -o/--output options, by Arnaldo Carvalho de Melo.
. Support ! in -e expressions, to filter a list of syscalls,
. Arg formatting improvements to allow masking arguments in
syscalls such as futex and open, where the some arguments are
ignored and thus should not be printed depending on other args,
. Beautify futex open, openat, open_by_handle_at, lseek and futex
syscalls, by Arnaldo Carvalho de Melo.
. Add option to analyze events in a file versus live, so that
one can do:
[root@zoo ~]# perf record -a -e raw_syscalls:* sleep 1
[ perf record: Woken up 0 times to write data ]
[ perf record: Captured and wrote 25.150 MB perf.data (~1098836 samples) ]
[root@zoo ~]# perf trace -i perf.data -e futex --duration 1
17.799 ( 1.020 ms): 7127 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, ua
113.344 (95.429 ms): 7127 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, uaddr2: 0x7fff3f6c6648, val3: 4294967
133.778 ( 1.042 ms): 18004 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, uaddr2: 0x7fff3f6c6648, val3: 429496
[root@zoo ~]#
By David Ahern.
. Honor target pid / tid options when analyzing a file, by David Ahern.
. Introduce better formatting of syscall arguments, including so
far beautifiers for mmap, madvise, syscall return values,
. Handle HUGEPAGE defines in the mmap beautifier, by David Ahern.
- 'perf report/top' enhancements:
. Do annotation using /proc/kcore and /proc/kallsyms when
available, removing the forced need for a vmlinux file kernel
assembly annotation. This also improves this use case because
vmlinux has just the initial kernel image, not what is actually
in use after various code patchings by things like alternatives.
By Adrian Hunter.
. Add --ignore-callees=<regex> option to collapse undesired parts
of call graphs, by Greg Price.
. Simplify symbol filtering by doing it at machine class level,
by Adrian Hunter.
. Add support for callchains in the gtk UI, by Namhyung Kim.
. Add --objdump option to 'perf top', by Sukadev Bhattiprolu.
- 'perf kvm' enhancements:
. Add option to print only events that exceed a specified time
duration, by David Ahern.
. Improve stack trace printing, by David Ahern.
. Update documentation of the live command, by David Ahern
. Add perf kvm stat live mode that combines aspects of 'perf kvm
stat' record and report, by David Ahern.
. Add option to analyze specific VM in perf kvm stat report, by
David Ahern.
. Do not require /lib/modules/* on a guest, by Jason Wessel.
- 'perf script' enhancements:
. Fix symbol offset computation for some dsos, by David Ahern.
. Fix named threads support, by David Ahern.
. Don't install scripting files files when perl/python support
is disabled, by Arnaldo Carvalho de Melo.
- 'perf test' enhancements:
. Add various improvements and fixes to the "vmlinux matches
kallsyms" 'perf test' entry, related to the /proc/kcore
annotation feature. By Adrian Hunter.
. Add sample parsing test, by Adrian Hunter.
. Add test for reading object code, by Adrian Hunter.
. Add attr record group sampling test, by Jiri Olsa.
. Misc testing infrastructure improvements and other details,
by Jiri Olsa.
- 'perf list' enhancements:
. Skip unsupported hardware events, by Namhyung Kim.
. List pmu events, by Andi Kleen.
- 'perf diff' enhancements:
. Add support for more than two files comparison, by Jiri Olsa.
- 'perf sched' enhancements:
. Various improvements, including removing reliance on some
scheduler tracepoints that provide the same information as the
PERF_RECORD_{FORK,EXIT} events. By David Ahern.
. Remove odd build stall by moving a large struct initialization
from a local variable to a global one, by Namhyung Kim.
- 'perf stat' enhancements:
. Add --initial-delay option to skip measuring for a defined
startup phase, by Andi Kleen.
- Generic perf tooling infrastructure/plumbing changes:
. Tidy up sample parsing validation, by Adrian Hunter.
. Fix up jobserver setup in libtraceevent Makefile.
. Debug improvements, by Adrian Hunter.
. Fix correlation of samples coming after PERF_RECORD_EXIT event,
by David Ahern.
. Improve robustness of the topology parsing code,
by Stephane Eranian.
. Add group leader sampling, that allows just one event in a group
to sample while the other events have just its values read,
by Jiri Olsa.
. Add support for a new modifier "D", which requests that the
event, or group of events, be pinned to the PMU.
By Michael Ellerman.
. Support callchain sorting based on addresses, by Andi Kleen
. Prep work for multi perf data file storage, by Jiri Olsa.
. libtraceevent cleanups, by Namhyung Kim.
And lots and lots of other fixes and code reorganizations that did not
make it into the list, see the shortlog, diffstat and the Git log for
details!"
[ Also merge a leftover from the 3.11 cycle ]
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf: Prevent race in unthrottling code
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (237 commits)
perf trace: Tell arg formatters the arg index
perf trace: Add beautifier for open's flags arg
perf trace: Add beautifier for lseek's whence arg
perf tools: Fix symbol offset computation for some dsos
perf list: Skip unsupported events
perf tests: Add 'keep tracking' test
perf tools: Add support for PERF_COUNT_SW_DUMMY
perf: Add a dummy software event to keep tracking
perf trace: Add beautifier for futex 'operation' parm
perf trace: Allow syscall arg formatters to mask args
perf: Convert kmalloc_node(...GFP_ZERO...) to kzalloc_node()
perf: Export struct perf_branch_entry to userspace
perf: Add attr->mmap2 attribute to an event
perf/x86: Add Silvermont (22nm Atom) support
perf/x86: use INTEL_UEVENT_EXTRA_REG to define MSR_OFFCORE_RSP_X
perf trace: Handle missing HUGEPAGE defines
perf trace: Honor target pid / tid options when analyzing a file
perf trace: Add option to analyze events in a file versus live
perf evlist: Add tracepoint lookup by name
perf tests: Add a sample parsing test
Pull core/locking changes from Ingo Molnar:
"Main changes:
- another mutex optimization, from Davidlohr Bueso
- improved lglock lockdep tracking, from Michel Lespinasse
- [ assorted smaller updates, improvements, cleanups. ]"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
generic-ipi/locking: Fix misleading smp_call_function_any() description
hung_task debugging: Print more info when reporting the problem
mutex: Avoid label warning when !CONFIG_MUTEX_SPIN_ON_OWNER
mutex: Do not unnecessarily deal with waiters
mutex: Fix/document access-once assumption in mutex_can_spin_on_owner()
lglock: Update lockdep annotations to report recursive local locks
lockdep: Introduce lock_acquire_exclusive()/shared() helper macros
Pull RCU updates from Ingo Molnar:
"Main RCU changes this cycle were:
- Full-system idle detection. This is for use by Frederic
Weisbecker's adaptive-ticks mechanism. Its purpose is to allow the
timekeeping CPU to shut off its tick when all other CPUs are idle.
- Miscellaneous fixes.
- Improved rcutorture test coverage.
- Updated RCU documentation"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (30 commits)
nohz_full: Force RCU's grace-period kthreads onto timekeeping CPU
nohz_full: Add full-system-idle state machine
jiffies: Avoid undefined behavior from signed overflow
rcu: Simplify _rcu_barrier() processing
rcu: Make rcutorture emit online failures if verbose
rcu: Remove unused variable from rcu_torture_writer()
rcu: Sort rcutorture module parameters
rcu: Increase rcutorture test coverage
rcu: Add duplicate-callback tests to rcutorture
doc: Fix memory-barrier control-dependency example
rcu: Update RTFP documentation
nohz_full: Add full-system-idle arguments to API
nohz_full: Add full-system idle states and variables
nohz_full: Add per-CPU idle-state tracking
nohz_full: Add rcu_dyntick data for scalable detection of all-idle state
nohz_full: Add Kconfig parameter for scalable detection of all-idle state
nohz_full: Add testing information to documentation
rcu: Eliminate unused APIs intended for adaptive ticks
rcu: Select IRQ_WORK from TREE_PREEMPT_RCU
rculist: list_first_or_null_rcu() should use list_entry_rcu()
Call generic_write_sync() from the deferred I/O completion handler if
O_DSYNC is set for a write request. Also make sure various callers
don't call generic_write_sync if the direct I/O code returns
-EIOCBQUEUED.
Based on an earlier patch from Jan Kara <jack@suse.cz> with updates from
Jeff Moyer <jmoyer@redhat.com> and Darrick J. Wong <darrick.wong@oracle.com>.
Add support to the core direct-io code to defer AIO completions to user
context using a workqueue. This replaces opencoded and less efficient
code in XFS and ext4 (we save a memory allocation for each direct IO)
and will be needed to properly support O_(D)SYNC for AIO.
The communication between the filesystem and the direct I/O code requires
a new buffer head flag, which is a bit ugly but not avoidable until the
direct I/O code stops abusing the buffer_head structure for communicating
with the filesystems.
Currently this creates a per-superblock unbound workqueue for these
completions, which is taken from an earlier patch by Jan Kara. I'm
not really convinced about this use and would prefer a "normal" global
workqueue with a high concurrency limit, but this needs further discussion.
JK: Fixed ext4 part, dynamic allocation of the workqueue.
Pull pwm changes from Thierry Reding:
"A set of patches makes the device tree documentation for the various
PWM drivers more consistent. Device tree support is added to the
Renesas TPU driver. The sysfs interface now makes use of dev_groups.
Other than that there is a healthy assortment of fixes and
enhancements for minor issues that have shown up"
* tag 'for-3.12-rc1' of git://gitorious.org/linux-pwm/linux-pwm:
pwm: pxa: Use module_platform_driver
pwm: tiehrpwm: add missing __iomem annotation
pwm: tiecap: add CONFIG_PM_SLEEP to ecap_pwm_{save,restore}_context()
pwm: simplify use of devm_ioremap_resource
pwm: renesas-tpu: Add DT support
ARM: dts: Use the PWM polarity flags
pwm: Update DT bindings to reference pwm.txt for cells documentation
pwm: Use the DT macro directly when parsing PWM DT flags
pwm: Add PWM polarity flag macro for DT
pwm: mxs: Check the return value from stmp_reset_block()
pwm: convert class code to use dev_groups
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull pstore changes from Tony Luck:
"A big part of this is the addition of compression to the generic
pstore layer so that all backends can use the pitiful amounts of
storage they control more effectively. Three other small
fixes/cleanups too.
* tag 'please-pull-pstore' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
pstore/ram: (really) fix undefined usage of rounddown_pow_of_two
pstore/ram: Read and write to the 'compressed' flag of pstore
efi-pstore: Read and write to the 'compressed' flag of pstore
erst: Read and write to the 'compressed' flag of pstore
powerpc/pseries: Read and write to the 'compressed' flag of pstore
pstore: Add file extension to pstore file if compressed
pstore: Add decompression support to pstore
pstore: Introduce new argument 'compressed' in the read callback
pstore: Add compression support to pstore
pstore/Kconfig: Select ZLIB_DEFLATE and ZLIB_INFLATE when PSTORE is selected
pstore: Add new argument 'compressed' in pstore write callback
powerpc/pseries: Remove (de)compression in nvram with pstore enabled
pstore: d_alloc_name() doesn't return an ERR_PTR
acpi/apei/erst: Add missing iounmap() on error in erst_exec_move_data()
New formats: %p[dD][234]?. The next pointer is interpreted as struct dentry *
or struct file * resp. ('d' => dentry, 'D' => file) and the last component(s)
of pathname are printed (%pd => just the last one, %pd2 => the last two, etc.)
Reviewed-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
