The tx_curr_frame_payload field is u32. When we try to calculate a
small negative delta based on it, we end up with a positive integer
close to 2^32 instead. So the tx_bytes pointer increases by about
2^32 for every transmitted frame.
Fix by calculating the delta as a signed long.
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
Reported-by: Florian Bruhin <me@the-compiler.org>
Fixes: 7a1e890e2168 ("usbnet: Fix tx_bytes statistic running backward in cdc_ncm")
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contain Netfilter fixes for your net tree, they are:
1) Fix a race in nfnetlink_log and nfnetlink_queue that can lead to a crash.
This problem is due to wrong order in the per-net registration and netlink
socket events. Patch from Francesco Ruggeri.
2) Make sure that counters that userspace pass us are higher than 0 in all the
x_tables frontends. Discovered via Trinity, patch from Dave Jones.
3) Revert a patch for br_netfilter to rely on the conntrack status bits. This
breaks stateless IPv6 NAT transformations. Patch from Florian Westphal.
ip_error does not check if in_dev is NULL before dereferencing it.
IThe following sequence of calls is possible:
CPU A CPU B
ip_rcv_finish
ip_route_input_noref()
ip_route_input_slow()
inetdev_destroy()
dst_input()
With the result that a network device can be destroyed while processing
an input packet.
A crash was triggered with only unicast packets in flight, and
forwarding enabled on the only network device. The error condition
was created by the removal of the network device.
As such it is likely the that error code was -EHOSTUNREACH, and the
action taken by ip_error (if in_dev had been accessible) would have
been to not increment any counters and to have tried and likely failed
to send an icmp error as the network device is going away.
Therefore handle this weird case by just dropping the packet if
!in_dev. It will result in dropping the packet sooner, and will not
result in an actual change of behavior.
Fixes: 251da4130115b ("ipv4: Cache ip_error() routes even when not forwarding.")
Reported-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Tested-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Signed-off-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Taking socket spinlock in tcp_get_info() can deadlock, as
inet_diag_dump_icsk() holds the &hashinfo->ehash_locks[i],
while packet processing can use the reverse locking order.
We could avoid this locking for TCP_LISTEN states, but lockdep would
certainly get confused as all TCP sockets share same lockdep classes.
[ 523.722504] ======================================================
[ 523.728706] [ INFO: possible circular locking dependency detected ]
[ 523.734990] 4.1.0-dbg-DEV #1676 Not tainted
[ 523.739202] -------------------------------------------------------
[ 523.745474] ss/18032 is trying to acquire lock:
[ 523.750002] (slock-AF_INET){+.-...}, at: [<ffffffff81669d44>] tcp_get_info+0x2c4/0x360
[ 523.758129]
[ 523.758129] but task is already holding lock:
[ 523.763968] (&(&hashinfo->ehash_locks[i])->rlock){+.-...}, at: [<ffffffff816bcb75>] inet_diag_dump_icsk+0x1d5/0x6c0
[ 523.774661]
[ 523.774661] which lock already depends on the new lock.
[ 523.774661]
[ 523.782850]
[ 523.782850] the existing dependency chain (in reverse order) is:
[ 523.790326]
-> #1 (&(&hashinfo->ehash_locks[i])->rlock){+.-...}:
[ 523.796599] [<ffffffff811126bb>] lock_acquire+0xbb/0x270
[ 523.802565] [<ffffffff816f5868>] _raw_spin_lock+0x38/0x50
[ 523.808628] [<ffffffff81665af8>] __inet_hash_nolisten+0x78/0x110
[ 523.815273] [<ffffffff816819db>] tcp_v4_syn_recv_sock+0x24b/0x350
[ 523.822067] [<ffffffff81684d41>] tcp_check_req+0x3c1/0x500
[ 523.828199] [<ffffffff81682d09>] tcp_v4_do_rcv+0x239/0x3d0
[ 523.834331] [<ffffffff816842fe>] tcp_v4_rcv+0xa8e/0xc10
[ 523.840202] [<ffffffff81658fa3>] ip_local_deliver_finish+0x133/0x3e0
[ 523.847214] [<ffffffff81659a9a>] ip_local_deliver+0xaa/0xc0
[ 523.853440] [<ffffffff816593b8>] ip_rcv_finish+0x168/0x5c0
[ 523.859624] [<ffffffff81659db7>] ip_rcv+0x307/0x420
Lets use u64_sync infrastructure instead. As a bonus, 64bit
arches get optimized, as these are nop for them.
Fixes: 0df48c26d841 ("tcp: add tcpi_bytes_acked to tcp_info")
Vijay reported that a loop as simple as ...
while true; do
tc qdisc add dev foo root handle 1: prio
tc filter add dev foo parent 1: u32 match u32 0 0 flowid 1
tc qdisc del dev foo root
rmmod cls_u32
done
... will panic the kernel. Moreover, he bisected the change
apparently introducing it to 78fd1d0ab072 ("netlink: Re-add
locking to netlink_lookup() and seq walker").
The removal of synchronize_net() from the netlink socket
triggering the qdisc to be removed, seems to have uncovered
an RCU resp. module reference count race from the tc API.
Given that RCU conversion was done after e341694e3eb5 ("netlink:
Convert netlink_lookup() to use RCU protected hash table")
which added the synchronize_net() originally, occasion of
hitting the bug was less likely (not impossible though):
When qdiscs that i) support attaching classifiers and,
ii) have at least one of them attached, get deleted, they
invoke tcf_destroy_chain(), and thus call into ->destroy()
handler from a classifier module.
After RCU conversion, all classifier that have an internal
prio list, unlink them and initiate freeing via call_rcu()
deferral.
Meanhile, tcf_destroy() releases already reference to the
tp->ops->owner module before the queued RCU callback handler
has been invoked.
Subsequent rmmod on the classifier module is then not prevented
since all module references are already dropped.
By the time, the kernel invokes the RCU callback handler from
the module, that function address is then invalid.
One way to fix it would be to add an rcu_barrier() to
unregister_tcf_proto_ops() to wait for all pending call_rcu()s
to complete.
synchronize_rcu() is not appropriate as under heavy RCU
callback load, registered call_rcu()s could be deferred
longer than a grace period. In case we don't have any pending
call_rcu()s, the barrier is allowed to return immediately.
Since we came here via unregister_tcf_proto_ops(), there
are no users of a given classifier anymore. Further nested
call_rcu()s pointing into the module space are not being
done anywhere.
Only cls_bpf_delete_prog() may schedule a work item, to
unlock pages eventually, but that is not in the range/context
of cls_bpf anymore.
Fixes: 25d8c0d55f24 ("net: rcu-ify tcf_proto")
Fixes: 9888faefe132 ("net: sched: cls_basic use RCU")
Reported-by: Vijay Subramanian <subramanian.vijay@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Cc: John Fastabend <john.r.fastabend@intel.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Tested-by: Vijay Subramanian <subramanian.vijay@gmail.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
This is an alternative way of fixing:
commit db9683fb412d ("net: phy: Make sure PHY_RESUMING state change
is always processed")
When the PHY state transitions from PHY_HALTED to PHY_RESUMING, there are
two things we need to do:
1). Re-enable interrupts (and power up the physical link, if powered down)
2). Update the PHY state and net-device based on the link status.
There's no strict reason why #1 has to be done from within the main
phy_state_machine() function. There is a risk that other changes to the
PHY (e.g. setting speed/duplex, which calls phy_start_aneg()) could cause
a subsequent state transition before phy_state_machine() has processed
the PHY_RESUMING state change. This would leave the PHY with interrupts
disabled and/or still in the BMCR_PDOWN/low-power mode.
Moving enabling the interrupts and phy_resume() into phy_start() will
guarantee this work always gets done. As the PHY is already in the HALTED
state and interrupts are disabled, it shouldn't conflict with any work
being done in phy_state_machine(). The downside of this change is that if
the PHY_RESUMING state is ever entered from anywhere else, it'll also have
to repeat this work.
Signed-off-by: Tim Beale <tim.beale@alliedtelesis.co.nz>
Michal Kubecek says:
IPv6 ECMP route add/replace fixes
(1) When adding a nexthop of a multipath route fails (e.g. because of a
conflict with an existing route), we are supposed to delete nexthops
already added. However, currently we try to also delete all nexthops we
haven't even tried to add yet so that a "ip route add" command can
actually remove pre-existing routes if it fails.
(2) Attempt to replace a multipath route results in a broken siblings
linked list. Following commands (like "ip route del") can then either
follow a link into freed memory or end in an infinite loop (if the slab
object has been reused).
v2: fix an omission in first patch
v3: change the semantics of replace operation to better match IPv4
When replacing an IPv6 multipath route with "ip route replace", i.e.
NLM_F_CREATE | NLM_F_REPLACE, fib6_add_rt2node() replaces only first
matching route without fixing its siblings, resulting in corrupted
siblings linked list; removing one of the siblings can then end in an
infinite loop.
IPv6 ECMP implementation is a bit different from IPv4 so that route
replacement cannot work in exactly the same way. This should be a
reasonable approximation:
1. If the new route is ECMP-able and there is a matching ECMP-able one
already, replace it and all its siblings (if any).
2. If the new route is ECMP-able and no matching ECMP-able route exists,
replace first matching non-ECMP-able (if any) or just add the new one.
3. If the new route is not ECMP-able, replace first matching
non-ECMP-able route (if any) or add the new route.
We also need to remove the NLM_F_REPLACE flag after replacing old
route(s) by first nexthop of an ECMP route so that each subsequent
nexthop does not replace previous one.
Fixes: 51ebd3181572 ("ipv6: add support of equal cost multipath (ECMP)")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
If adding a nexthop of an IPv6 multipath route fails, comment in
ip6_route_multipath() says we are going to delete all nexthops already
added. However, current implementation deletes even the routes it
hasn't even tried to add yet. For example, running
ip route add 1234:5678::/64 \
nexthop via fe80::aa dev dummy1 \
nexthop via fe80::bb dev dummy1 \
nexthop via fe80::cc dev dummy1
twice results in removing all routes first command added.
Limit the second (delete) run to nexthops that succeeded in the first
(add) run.
This reverts commit c055d5b03bb4cb69d349d787c9787c0383abd8b2.
There are two issues:
'dnat_took_place' made me think that this is related to
-j DNAT/MASQUERADE.
But thats only one part of the story. This is also relevant for SNAT
when we undo snat translation in reverse/reply direction.
Furthermore, I originally wanted to do this mainly to avoid
storing ipv6 addresses once we make DNAT/REDIRECT work
for ipv6 on bridges.
However, I forgot about SNPT/DNPT which is stateless.
So we can't escape storing address for ipv6 anyway. Might as
well do it for ipv4 too.
Reported-and-tested-by: Bernhard Thaler <bernhard.thaler@wvnet.at>
After improving setsockopt() coverage in trinity, I started triggering
vmalloc failures pretty reliably from this code path:
warn_alloc_failed+0xe9/0x140
__vmalloc_node_range+0x1be/0x270
vzalloc+0x4b/0x50
__do_replace+0x52/0x260 [ip_tables]
do_ipt_set_ctl+0x15d/0x1d0 [ip_tables]
nf_setsockopt+0x65/0x90
ip_setsockopt+0x61/0xa0
raw_setsockopt+0x16/0x60
sock_common_setsockopt+0x14/0x20
SyS_setsockopt+0x71/0xd0
It turns out we don't validate that the num_counters field in the
struct we pass in from userspace is initialized.
The same problem also exists in ebtables, arptables, ipv6, and the
compat variants.
Signed-off-by: Dave Jones <davej@codemonkey.org.uk>
nfnetlink_{log,queue}_init() register the netlink callback nf*_rcv_nl_event
before registering the pernet_subsys, but the callback relies on data
structures allocated by pernet init functions.
When nfnetlink_{log,queue} is loaded, if a netlink message is received after
the netlink callback is registered but before the pernet_subsys is registered,
the kernel will panic in the sequence
nfulnl_rcv_nl_event
nfnl_log_pernet
net_generic
BUG_ON(id == 0) where id is nfnl_log_net_id.
The panic can be easily reproduced in 4.0.3 by:
while true ;do modprobe nfnetlink_log ; rmmod nfnetlink_log ; done &
while true ;do ip netns add dummy ; ip netns del dummy ; done &
This patch moves register_pernet_subsys to earlier in nfnetlink_log_init.
Notice that the BUG_ON hit in 4.0.3 was recently removed in 2591ffd308
["netns: remove BUG_ONs from net_generic()"].
Signed-off-by: Francesco Ruggeri <fruggeri@arista.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Johannes Berg says:
This has just a single fix, for a WEP tailroom check
problem that leads to dropped frames.
After sending the new data packets to probe (step 2), F-RTO may
incorrectly send more probes if the next ACK advances SND_UNA and
does not sack new packet. However F-RTO RFC 5682 probes at most
once. This bug may cause sender to always send new data instead of
repairing holes, inducing longer HoL blocking on the receiver for
the application.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Undo based on TCP timestamps should only happen on ACKs that advance
SND_UNA, according to the Eifel algorithm in RFC 3522:
Section 3.2:
(4) If the value of the Timestamp Echo Reply field of the
acceptable ACK's Timestamps option is smaller than the
value of RetransmitTS, then proceed to step (5),
Section Terminology:
We use the term 'acceptable ACK' as defined in [RFC793]. That is an
ACK that acknowledges previously unacknowledged data.
This is because upon receiving an out-of-order packet, the receiver
returns the last timestamp that advances RCV_NXT, not the current
timestamp of the packet in the DUPACK. Without checking the flag,
the DUPACK will cause tcp_packet_delayed() to return true and
tcp_try_undo_loss() will revert cwnd reduction.
Note that we check the condition in CA_Recovery already by only
calling tcp_try_undo_partial() if FLAG_SND_UNA_ADVANCED is set or
tcp_try_undo_recovery() if snd_una crosses high_seq.
Commit <5cf3d46192fc> ("udp: Simplify__udp*_lib_mcast_deliver")
simplified the filter for incoming IPv6 multicast but removed
the check of the local socket address and the UDP destination
address.
This patch restores the filter to prevent sockets bound to a IPv6
multicast IP to receive other UDP traffic link unicast.
Signed-off-by: Henning Rogge <hrogge@gmail.com>
Fixes: 5cf3d46192fc ("udp: Simplify__udp*_lib_mcast_deliver")
tcp_illinois and upcoming tcp_cdg require 64bit alignment of
icsk_ca_priv
x86 does not care, but other architectures might.
Fixes: 05cbc0db03e82 ("ipv4: Create probe timer for tcp PMTU as per RFC4821")
Cc: Fan Du <fan.du@intel.com>
Acked-by: Fan Du <fan.du@intel.com>
By inspection, this appears to be a typo. The gating comparison
involves vxlan->dev rather than dev. In fact, dev is the iterator in
the preceding loop above but it is actually constant in the 2nd loop.
Use of dev seems to be a bad cut-n-paste from the prior call to
unregister_netdevice_queue. Change dev to vxlan->dev, since that is
what is actually being checked.
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
Johan Hedberg says:
pull request: bluetooth 2015-05-17
A couple more Bluetooth updates for 4.1:
- New USB IDs for ath3k & btusb
- Fix for remote name resolving during device discovery
Please let me know if there are any issues pulling. Thanks.
commit 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages
send from TIME_WAIT") added the flow label in the last TCP packets.
Unfortunately, it was not casted properly.
This patch replace the buggy shift with be32_to_cpu/cpu_to_be32.
Fixes: 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages")
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
Before the patch, the command 'ip link add bond2 type bond mode 802.3ad'
causes the kernel to send a rtnl message for the bond2 interface, with an
ifindex 0.
'ip monitor' shows:
0: bond2: <BROADCAST,MULTICAST,MASTER> mtu 1500 state DOWN group default
link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
9: bond2@NONE: <BROADCAST,MULTICAST,MASTER> mtu 1500 qdisc noop state DOWN group default
link/ether ea:3e:1f:53:92:7b brd ff:ff:ff:ff:ff:ff
[snip]
The patch fixes the spotted bug by checking in bond driver if the interface
is registered before calling the notifier chain.
It also adds a check in rtmsg_ifinfo() to prevent this kind of bug in the
future.
Fixes: d4261e565000 ("bonding: create netlink event when bonding option is changed")
CC: Jiri Pirko <jiri@resnulli.us>
Reported-by: Julien Meunier <julien.meunier@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
We currently have no limit on the number of elements in a hash table.
This is a problem because some users (tipc) set a ceiling on the
maximum table size and when that is reached the hash table may
degenerate. Others may encounter OOM when growing and if we allow
insertions when that happens the hash table perofrmance may also
suffer.
This patch adds a new paramater insecure_max_entries which becomes
the cap on the table. If unset it defaults to max_size * 2. If
it is also zero it means that there is no cap on the number of
elements in the table. However, the table will grow whenever the
utilisation hits 100% and if that growth fails, you will get ENOMEM
on insertion.
As allowing oversubscription is potentially dangerous, the name
contains the word insecure.
Note that the cap is not a hard limit. This is done for performance
reasons as enforcing a hard limit will result in use of atomic ops
that are heavier than the ones we currently use.
The reasoning is that we're only guarding against a gross over-
subscription of the table, rather than a small breach of the limit.
If phy_start_aneg() was called while the phydev is in the PHY_RESUMING
state, then its state would immediately transition to PHY_AN (or
PHY_FORCING). This meant the phy_state_machine() never processed the
PHY_RESUMING state change, which meant interrupts weren't enabled for the
PHY. If the PHY used low-power mode (i.e. using BMCR_PDOWN), then the
physical link wouldn't get powered up again.
There seems no point for phy_start_aneg() to make the PHY_RESUMING -->
PHY_AN transition, as the state machine will do this anyway. I'm not sure
about the case where autoneg is disabled, as my patch will change
behaviour so that the PHY goes to PHY_NOLINK instead of PHY_FORCING. An
alternative solution would be to move the phy_config_interrupt() and
phy_resume() work out of the state machine and into phy_start().
The background behind this: we're running linux v3.16.7 and from user-space
we want to enable the eth port (i.e. do a SIOCSIFFLAGS ioctl with the
IFF_UP flag) and immediately afterward set the interface's speed/duplex.
Enabling the interface calls .ndo_open() then phy_start() and the PHY
transitions PHY_HALTED --> PHY_RESUMING. Setting the speed/duplex ends up
calling phy_ethtool_sset(), which calls phy_start_aneg() (meanwhile the
phy_state_machine() hasn't processed the PHY_RESUMING state change yet).
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
The commit c5adde9468b0714a051eac7f9666f23eb10b61f7 ("netlink:
eliminate nl_sk_hash_lock") breaks the autobind retry mechanism
because it doesn't reset portid after a failed netlink_insert.
This means that should autobind fail the first time around, then
the socket will be stuck in limbo as it can never be bound again
since it already has a non-zero portid.
Fixes: c5adde9468b0 ("netlink: eliminate nl_sk_hash_lock")
The following patchset contains Netfilter fixes for your net tree, they are:
1) Fix a leak in IPVS, the sysctl table is not released accordingly when
destroying a netns, patch from Tommi Rantala.
2) Fix a build error when TPROXY and socket are built-in but IPv6 defrag is
compiled as module, from Florian Westphal.
3) Fix TCP tracket wrt. RFC5961 challenge ACK when in LAST_ACK state, patch
from Jesper Dangaard Brouer.
4) Fix a bogus WARN_ON() in nf_tables when deleting a set element that stores
a map, from Mirek Kratochvil.
RGMII interfaces come in multiple flavors: RGMII with transmit or
receive internal delay, no delays at all, or delays in both direction.
This change extends the initial check for PHY_INTERFACE_MODE_RGMII to
cover all of these variants since EEE should be allowed for any of these
modes, since it is a property of the RGMII, hence Gigabit PHY capability
more than the RGMII electrical interface and its delays.
Fixes: a59a4d192166 ("phy: add the EEE support and the way to access to the MMD registers")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Once we get a neighbour through looking up arp cache or creating a
new one in rocker_port_ipv4_resolve(), the neighbour's refcount is
already taken. But as we don't put the refcount again after it's
used, this makes the neighbour entry leaked.
Suggested-by: Eric Dumazet <edumazet@google.com>
Acked-by: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
The values 0x00000000-0xfffffeff are reserved for userspace datatype. When,
deleting set elements with maps, a bogus warning is triggered.
WARNING: CPU: 0 PID: 11133 at net/netfilter/nf_tables_api.c:4481 nft_data_uninit+0x35/0x40 [nf_tables]()
This fixes the check accordingly to enum definition in
include/linux/netfilter/nf_tables.h
Fixes: https://bugzilla.netfilter.org/show_bug.cgi?id=1013
Signed-off-by: Mirek Kratochvil <exa.exa@gmail.com>
In compliance with RFC5961, the network stack send challenge ACK in
response to spurious SYN packets, since commit 0c228e833c88 ("tcp:
Restore RFC5961-compliant behavior for SYN packets").
This pose a problem for netfilter conntrack in state LAST_ACK, because
this challenge ACK is (falsely) seen as ACKing last FIN, causing a
false state transition (into TIME_WAIT).
The challenge ACK is hard to distinguish from real last ACK. Thus,
solution introduce a flag that tracks the potential for seeing a
challenge ACK, in case a SYN packet is let through and current state
is LAST_ACK.
When conntrack transition LAST_ACK to TIME_WAIT happens, this flag is
used for determining if we are expecting a challenge ACK.
Scapy based reproducer script avail here:
https://github.com/netoptimizer/network-testing/blob/master/scapy/tcp_hacks_3WHS_LAST_ACK.py
Fixes: 0c228e833c88 ("tcp: Restore RFC5961-compliant behavior for SYN packets")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
With TPROXY=y but DEFRAG_IPV6=m we get build failure:
net/built-in.o: In function `tproxy_tg_init':
net/netfilter/xt_TPROXY.c:588: undefined reference to `nf_defrag_ipv6_enable'
If DEFRAG_IPV6 is modular, TPROXY must be too.
(or both must be builtin).
This enforces =m for both.
Reported-and-tested-by: Liu Hua <liusdu@126.com>
Describe the handler for RXUBR better with a new comment.
Signed-off-by: Nathan Sullivan <nathan.sullivan@ni.com>
Reviewied-by: Josh Cartwright <joshc@ni.com>
Reviewied-by: Ben Shelton <ben.shelton@ni.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
RTNH_F_EXTERNAL today is printed as "offload" in iproute2 output.
This patch renames the flag to be consistent with what the user sees.
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
With a cross-compiler based on gcc-4.9, I see warnings like the following:
drivers/net/ethernet/mellanox/mlx4/resource_tracker.c: In function 'mlx4_SW2HW_CQ_wrapper':
drivers/net/ethernet/mellanox/mlx4/resource_tracker.c:3048:10: error: 'cq' may be used uninitialized in this function [-Werror=maybe-uninitialized]
cq->mtt = mtt;
I think the warning is spurious because we only use cq when
cq_res_start_move_to() returns zero, and it always initializes *cq in that
case. The srq case is similar. But maybe gcc isn't smart enough to figure
that out.
Initialize cq and srq explicitly to avoid the warnings.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
It was reported that trancerout6 would cause
a kernel to crash when trying to compute checksums
on raw UDP packets. The cause was the check in
__ip6_append_data that would attempt to use
partial checksums on the packet. However,
raw sockets do not initialize partial checksum
fields so partial checksums can't be used.
Solve this the same way IPv4 does it. raw sockets
pass transhdrlen value of 0 to ip_append_data which
causes the checksum to be computed in software. Use
the same check in ip6_append_data (check transhdrlen).
Reported-by: Wolfgang Walter <linux@stwm.de>
CC: Wolfgang Walter <linux@stwm.de>
CC: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
netlink sockets creation and deletion heavily modify nl_table_users
and nl_table_lock.
If nl_table is sharing one cache line with one of them, netlink
performance is really bad on SMP.
ffffffff81ff5f00 B nl_table
ffffffff81ff5f0c b nl_table_users
Putting nl_table in read_mostly section increased performance
of my open/delete netlink sockets test by about 80 %
This came up while diagnosing a getaddrinfo() problem.
This patch fixes hci_remote_name_evt dose not resolve name during
discovery status is RESOLVING. Before simultaneous dual mode scan enabled,
hci_check_pending_name will set discovery status to STOPPED eventually.
Signed-off-by: Wesley Kuo <wesley.kuo@intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Currently vlan notifier handler will try to update all vlans
for a device when that device comes up. A problem occurs,
however, when the vlan device was set to promiscuous, but not
by the user (ex: a bridge). In that case, dev->gflags are
not updated. What results is that the lower device ends
up with an extra promiscuity count. Here are the
backtraces that prove this:
[62852.052179] [<ffffffff814fe248>] __dev_set_promiscuity+0x38/0x1e0
[62852.052186] [<ffffffff8160bcbb>] ? _raw_spin_unlock_bh+0x1b/0x40
[62852.052188] [<ffffffff814fe4be>] ? dev_set_rx_mode+0x2e/0x40
[62852.052190] [<ffffffff814fe694>] dev_set_promiscuity+0x24/0x50
[62852.052194] [<ffffffffa0324795>] vlan_dev_open+0xd5/0x1f0 [8021q]
[62852.052196] [<ffffffff814fe58f>] __dev_open+0xbf/0x140
[62852.052198] [<ffffffff814fe88d>] __dev_change_flags+0x9d/0x170
[62852.052200] [<ffffffff814fe989>] dev_change_flags+0x29/0x60
The above comes from the setting the vlan device to IFF_UP state.
[62852.053569] [<ffffffff814fe248>] __dev_set_promiscuity+0x38/0x1e0
[62852.053571] [<ffffffffa032459b>] ? vlan_dev_set_rx_mode+0x2b/0x30
[8021q]
[62852.053573] [<ffffffff814fe8d5>] __dev_change_flags+0xe5/0x170
[62852.053645] [<ffffffff814fe989>] dev_change_flags+0x29/0x60
[62852.053647] [<ffffffffa032334a>] vlan_device_event+0x18a/0x690
[8021q]
[62852.053649] [<ffffffff8161036c>] notifier_call_chain+0x4c/0x70
[62852.053651] [<ffffffff8109d456>] raw_notifier_call_chain+0x16/0x20
[62852.053653] [<ffffffff814f744d>] call_netdevice_notifiers+0x2d/0x60
[62852.053654] [<ffffffff814fe1a3>] __dev_notify_flags+0x33/0xa0
[62852.053656] [<ffffffff814fe9b2>] dev_change_flags+0x52/0x60
[62852.053657] [<ffffffff8150cd57>] do_setlink+0x397/0xa40
And this one comes from the notification code. What we end
up with is a vlan with promiscuity count of 1 and and a physical
device with a promiscuity count of 2. They should both have
a count 1.
To resolve this issue, vlan code can use dev_get_flags() api
which correctly masks promiscuity and allmulti flags.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
BugLink: https://bugs.launchpad.net/bugs/1449730
T: Bus=01 Lev=01 Prnt=01 Port=04 Cnt=02 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=04ca ProdID=300f Rev=00.01
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
Signed-off-by: Dmitry Tunin <hanipouspilot@gmail.com>
Device 0cf3:e007 is one of the QCA ROME family.
T: Bus=01 Lev=01 Prnt=01 Port=05 Cnt=02 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.01 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0cf3 ProdID=e007 Rev= 0.01
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Signed-off-by: Wen-chien Jesse Sung <jesse.sung@canonical.com>
Device info in /sys/kernel/debug/usb/devices:
P: Vendor=0cf3 ProdID=e006 Rev= 0.01
Pull networking fixes from David Miller:
1) Handle max TX power properly wrt VIFs and the MAC in iwlwifi, from
Avri Altman.
2) Use the correct FW API for scan completions in iwlwifi, from Avraham
Stern.
3) FW monitor in iwlwifi accidently uses unmapped memory, fix from Liad
Kaufman.
4) rhashtable conversion of mac80211 station table was buggy, the
virtual interface was not taken into account. Fix from Johannes
Berg.
5) Fix deadlock in rtlwifi by not using a zero timeout for
usb_control_msg(), from Larry Finger.
6) Update reordering state before calculating loss detection, from
Yuchung Cheng.
7) Fix off by one in bluetooth firmward parsing, from Dan Carpenter.
8) Fix extended frame handling in xiling_can driver, from Jeppe
Ledet-Pedersen.
9) Fix CODEL packet scheduler behavior in the presence of TSO packets,
from Eric Dumazet.
10) Fix NAPI budget testing in fm10k driver, from Alexander Duyck.
11) macvlan needs to propagate promisc settings down the the lower
device, from Vlad Yasevich.
12) igb driver can oops when changing number of rings, from Toshiaki
Makita.
13) Source specific default routes not handled properly in ipv6, from
Markus Stenberg.
14) Use after free in tc_ctl_tfilter(), from WANG Cong.
15) Use softirq spinlocking in netxen driver, from Tony Camuso.
16) Two ARM bpf JIT fixes from Nicolas Schichan.
17) Handle MSG_DONTWAIT properly in ring based AF_PACKET sends, from
Mathias Kretschmer.
18) Fix x86 bpf JIT implementation of FROM_{BE16,LE16,LE32}, from Alexei
Starovoitov.
19) ll_temac driver DMA maps TX packet header with incorrect length, fix
from Michal Simek.
20) We removed pm_qos bits from netdevice.h, but some indirect
references remained. Kill them. From David Ahern.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
net: Remove remaining remnants of pm_qos from netdevice.h
e1000e: Add pm_qos header
net: phy: micrel: Fix regression in kszphy_probe
net: ll_temac: Fix DMA map size bug
x86: bpf_jit: fix FROM_BE16 and FROM_LE16/32 instructions
netns: return RTM_NEWNSID instead of RTM_GETNSID on a get
Update be2net maintainers' email addresses
net_sched: gred: use correct backlog value in WRED mode
pppoe: drop pppoe device in pppoe_unbind_sock_work
net: qca_spi: Fix possible race during probe
net: mdio-gpio: Allow for unspecified bus id
af_packet / TX_RING not fully non-blocking (w/ MSG_DONTWAIT).
bnx2x: limit fw delay in kdump to 5s after boot
ARM: net: delegate filter to kernel interpreter when imm_offset() return value can't fit into 12bits.
ARM: net fix emit_udiv() for BPF_ALU | BPF_DIV | BPF_K intruction.
mpls: Change reserved label names to be consistent with netbsd
usbnet: avoid integer overflow in start_xmit
netxen_nic: use spin_[un]lock_bh around tx_clean_lock (2)
net: xgene_enet: Set hardware dependency
net: amd-xgbe: Add hardware dependency
Commit e2c6544829f removed pm_qos from struct net_device but left the
comment and header file. Remove those.
Signed-off-by: David Ahern <dsahern@gmail.com>
Commit e2c6544829f moved pm_qos_req to e1000_adapter. Add the header file
that defines the struct.
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Don't do clock-mode-select if clk == NULL,
since when building without CONFIG_HAVE_CLK,
clk_get returns NULL and clk_get_rate returns 0.
Doing clock-mode-select in this cause causes kszphy_probe to
return -EINVAL and thus prevents the device from being probed.
The original code (before regression) would return 0
when building without CONFIG_HAVE_CLK.
Cc: stable <stable@vger.kernel.org> # 3.18+
Fixes: 1fadee0c3645 ("net/phy: micrel: Add clock support for
KSZ8021/KSZ8031")
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Reviewed-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Niklas Cassel <niklass@axis.com>
DMA allocates skb->len instead of headlen
which is used for DMA.
FROM_BE16:
'ror %reg, 8' doesn't clear upper bits of the register,
so use additional 'movzwl' insn to zero extend 16 bits into 64
FROM_LE16:
should zero extend lower 16 bits into 64 bit
FROM_LE32:
should zero extend lower 32 bits into 64 bit
Fixes: 89aa075832b0 ("net: sock: allow eBPF programs to be attached to sockets")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Pull MIPS fixes from Ralf Baechle:
"One build fix for build breakage of all MIPS SMP kernels caused by
Rusty's fix of obsolete use of cpu mask helpers, another to fix the FP
ABI selection when loading an ELF binary"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: fix FP mode selection in lieu of .MIPS.abiflags data
MIPS: SMP: Fix build error.
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull rdma fixes from Doug Ledford:
- update MAINTAINERS git repo pointer
- printk garbage fix
- fix for qib and iw_cxgb4 bugs introduced in 4.1 window
- fix for an older iWARP netlink bug
- fix a memcpy issue in ehca driver
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma:
infiniband: Remove duplicated KERN_<LEVEL> from pr_<level> uses
IB/qib: fix test of unsigned variable
RDMA/core: Fix for parsing netlink string attribute
MAINTAINERS: update the official rdma git repo
iw_cxgb4: use wildcard mapping for getting remote addr info
IB/ehca: use correct destination for memcpy
Usually, RTM_NEWxxx is returned on a get (same as a dump).
Fixes: 0c7aecd4bde4 ("netns: add rtnl cmd to add and get peer netns ids")
Pull power supply and reset fixes from Sebastian Reichel:
"misc fixes"
* tag 'for-v4.1-rc' of git://git.infradead.org/battery-2.6:
power: bq27x00_battery: Add missing MODULE_ALIAS
power: reset: Add MFD_SYSCON depends for brcmstb
power: reset: ltc2952: Remove bogus hrtimer_start() return value checks
power_supply: fix oops in collie_battery driver
power/reset: at91: fix return value check in at91_reset_platform_probe()
MAINTAINERS: Add me as maintainer of Nokia N900 power supply drivers
axp288_fuel_gauge: Add original author details
