Make calculation of the size of the inline name in struct proc_dir_entry
automatic, rather than having to manually encode the numbers and failing to
allow for lockdep.
Require a minimum inline name size of 33+1 to allow for names that look
like two hex numbers with a dash between.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
backmerge AFS fixes that went into mainline and deal with
the conflict in fs/afs/fsclient.c
Implement network namespacing within AFS, but don't yet let mounts occur
outside the init namespace. An additional patch will be required propagate
the network namespace across automounts.
The afs_net::ws_cell member is sometimes used under RCU conditions from
within an seq-readlock. It isn't, however, marked __rcu and it isn't set
using the proper RCU barrier-imposing functions.
Fix this by annotating it with __rcu and using appropriate barriers to
make sure accesses are correctly ordered.
Without this, the code can produce the following warning:
>> fs/afs/proc.c:151:24: sparse: incompatible types in comparison expression (different address spaces)
Fixes: f044c8847bb6 ("afs: Lay the groundwork for supporting network namespaces")
Reported-by: kbuild test robot <lkp@intel.com>
Sparse doesn't appear able to handle the conditionally-taken locks in
xdr_decode_AFSFetchStatus(), even though the lock and unlock are both
contingent on the same unvarying function argument.
Deal with this by interpolating a wrapper function that takes the lock if
needed and calls xdr_decode_AFSFetchStatus() on two separate branches, one
with the lock held and one without.
This allows Sparse to work out the locking.
Provide two extra functions, proc_create_net_data_write() and
proc_create_net_single_write() that act like their non-write versions but
also set a write method in the proc_dir_entry struct.
An internal simple write function is provided that will copy its buffer and
hand it to the pde->write() method if available (or give an error if not).
The buffer may be modified by the write method.
Rearrange fs/afs/proc.c to get rid of all the remaining predeclarations.
Rearrange fs/afs/proc.c to move the show routines up to the top of each
block so the order is show, iteration, ops, file ops, fops.
Rearrange fs/afs/proc.c by moving fops and open functions down so as to
remove predeclarations.
In fs/afs/proc.c, move functions that create and remove /proc files to the
end of the source file as a first stage in getting rid of all the forward
declarations.
Fixes: 2cd1f0ddbb56 ("isdn: replace ->proc_fops with ->proc_show")
This makes Alexey happy and Al groan. Based on a patch from
Alexey Dobriyan.
Just set up the show callback in the tty_operations, and use
proc_create_single_data to create the file without additional
boilerplace code.
boilerplace code.
The driver proc file hasn't been writeable for a long time, so this is
just dead code.
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
And switch to proc_create_single_data.
And remove proc boilerplate code.
Use remove_proc_subtree to remove the whole subtree on cleanup, and
unwind the registration loop into individual calls. Switch to use
proc_create_seq where applicable.
Also don't bother handling proc_create* failures - the driver works
perfectly fine without the proc files, and the cleanup will handle
missing files gracefully.
And use proc private data directly instead of doing a detour
through seq->private and private state.
through seq->private.
And stop trying to get a reference on the submodule, procfs code deals
with release after an unloaded module and thus removed proc entry.
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
And stop messing with try_module_get on THIS_MODULE, which doesn't make
any sense here.
And use the root resource directly from the proc private data.
Unwind the registration loop into individual calls. Switch to use
proc_create_single where applicable.
proc_create_single.
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Variant of proc_create_data that directly take a seq_file show
callback and deals with network namespaces in ->open and ->release.
All callers of proc_create + single_open_net converted over, and
single_{open,release}_net are removed entirely.
Variants of proc_create{,_data} that directly take a struct seq_operations
and deal with network namespaces in ->open and ->release. All callers of
proc_create + seq_open_net converted over, and seq_{open,release}_net are
removed entirely.
This helper deals with single_{open,release}_net internals and thus
belongs here.
Just use the address family from the proc private data instead of copying
it into per-file data.
Remove a couple indirections to make the code look like most other
protocols.
The code should be using the pid namespace from the procfs mount
instead of trying to look it up during open.
Suggested-by: Eric W. Biederman <ebiederm@xmission.com>
Pass the hashtable to the proc private data instead of copying
it into the per-file private data.
Remove the pointless ping_seq_afinfo indirection and make the code look
like most other protocols.
Avoid most of the afinfo indirections and just call the proc helpers
directly.
protocols.
Variants of proc_create{,_data} that directly take a seq_file show
callback and drastically reduces the boilerplate code in the callers.
All trivial callers converted over.
Variant of proc_create_data that directly take a struct seq_operations
argument + a private state size and drastically reduces the boilerplate
argument and drastically reduces the boilerplate code in the callers.
Common code for creating a regular file. Factor out of proc_create_data, to
be reused by other functions soon.
Return registered entry on success, return NULL on failure and free the
passed in entry. Also expose it in internal.h as we'll start using it
in proc_net.c soon.
