2012-03-29Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull more ARM updates from Russell King. This got a fair number of conflicts with the <asm/system.h> split, but also with some other sparse-irq and header file include cleanups. They all looked pretty trivial, though. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits) ARM: fix Kconfig warning for HAVE_BPF_JIT ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds ARM: 7349/1: integrator: convert to sparse irqs ARM: 7259/3: net: JIT compiler for packet filters ARM: 7334/1: add jump label support ARM: 7333/2: jump label: detect %c support for ARM ARM: 7338/1: add support for early console output via semihosting ARM: use set_current_blocked() and block_sigmask() ARM: exec: remove redundant set_fs(USER_DS) ARM: 7332/1: extract out code patch function from kprobes ARM: 7331/1: extract out insn generation code from ftrace ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format ARM: 7351/1: ftrace: remove useless memory checks ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path ARM: Versatile Express: add NO_IOPORT ARM: get rid of asm/irq.h in asm/prom.h ARM: 7319/1: Print debug info for SIGBUS in user faults ARM: 7318/1: gic: refactor irq_start assignment ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop ARM: 7315/1: perf: add support for the Cortex-A7 PMU ...
2012-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutilsLinus Torvalds
Pull cpupower updates from Dominik Brodowski. * git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutils: cpupower tools: add install target to the debug tools' makefiles cpupower tools: allow to build debug tools in a separate directory too cpupower: Fix broken mask values cpupower tool: allow to build in a separate directory cpupower tool: makefile: simplify the recipe used to generate cpupower.pot target cpupower tool: remove use of undefined variables from the clean target of the top makefile cpupower: Fix linking with --as-needed cpupower: Remove unneeded code and by that fix a memleak cpupower: Fix number of idle states cpupower: Unify cpupower-frequency-* manpages cpupower: Add cpupower-idle-info manpage cpupower: AMD fam14h/Ontario monitor can also be used by fam12h cpus cpupower: Better interface for accessing AMD pci registers
2012-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmciaLinus Torvalds
Pull a few PCMCIA updates from Dominik Brodowski. Fix up trivial conflict (modified code in question had been removed) in drivers/pcmcia/soc_common.c. * git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia: pcmcia at91_cf: fix raw gpio number usage ARM: pxa: fix error handling in pxa2xx_drv_pcmcia_probe pcmcia: Convert to DEFINE_PCI_DEVICE_TABLE pcmcia: convert drivers/pcmcia/* to use module_platform_driver() pcmcia: irq: Remove IRQF_DISABLED
2012-03-29Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine update from Vinod Koul: "This includes the cookie cleanup by Russell, the addition of context parameter for dmaengine APIs, more arm dmaengine driver cleanup by moving code to dmaengine, this time for imx by Javier and pl330 by Boojin along with the usual driver fixes." Fix up some fairly trivial conflicts with various other cleanups. * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (67 commits) dmaengine: imx: fix the build failure on x86_64 dmaengine: i.MX: Fix merge of cookie branch. dmaengine: i.MX: Add support for interleaved transfers. dmaengine: imx-dma: use 'dev_dbg' and 'dev_warn' for messages. dmaengine: imx-dma: remove 'imx_dmav1_baseaddr' and 'dma_clk'. dmaengine: imx-dma: remove unused arg of imxdma_sg_next. dmaengine: imx-dma: remove internal structure. dmaengine: imx-dma: remove 'resbytes' field of 'internal' structure. dmaengine: imx-dma: remove 'in_use' field of 'internal' structure. dmaengine: imx-dma: remove sg member from internal structure. dmaengine: imx-dma: remove 'imxdma_setup_sg_hw' function. dmaengine: imx-dma: remove 'imxdma_config_channel_hw' function. dmaengine: imx-dma: remove 'imxdma_setup_mem2mem_hw' function. dmaengine: imx-dma: remove dma_mode member of internal structure. dmaengine: imx-dma: remove data member from internal structure. dmaengine: imx-dma: merge old dma-v1.c with imx-dma.c dmaengine: at_hdmac: add slave config operation dmaengine: add context parameter to prep_slave_sg and prep_dma_cyclic dmaengine/dma_slave: introduce inline wrappers dma: imx-sdma: Treat firmware messages as warnings instead of erros ...
2012-03-29Merge branch 'for-3.4' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from Bruce Fields: Highlights: - Benny Halevy and Tigran Mkrtchyan implemented some more 4.1 features, moving us closer to a complete 4.1 implementation. - Bernd Schubert fixed a long-standing problem with readdir cookies on ext2/3/4. - Jeff Layton performed a long-overdue overhaul of the server reboot recovery code which will allow us to deprecate the current code (a rather unusual user of the vfs), and give us some needed flexibility for further improvements. - Like the client, we now support numeric uid's and gid's in the auth_sys case, allowing easier upgrades from NFSv2/v3 to v4.x. Plus miscellaneous bugfixes and cleanup. Thanks to everyone! There are also some delegation fixes waiting on vfs review that I suppose will have to wait for 3.5. With that done I think we'll finally turn off the "EXPERIMENTAL" dependency for v4 (though that's mostly symbolic as it's been on by default in distro's for a while). And the list of 4.1 todo's should be achievable for 3.5 as well: http://wiki.linux-nfs.org/wiki/index.php/Server_4.0_and_4.1_issues though we may still want a bit more experience with it before turning it on by default. * 'for-3.4' of git://linux-nfs.org/~bfields/linux: (55 commits) nfsd: only register cld pipe notifier when CONFIG_NFSD_V4 is enabled nfsd4: use auth_unix unconditionally on backchannel nfsd: fix NULL pointer dereference in cld_pipe_downcall nfsd4: memory corruption in numeric_name_to_id() sunrpc: skip portmap calls on sessions backchannel nfsd4: allow numeric idmapping nfsd: don't allow legacy client tracker init for anything but init_net nfsd: add notifier to handle mount/unmount of rpc_pipefs sb nfsd: add the infrastructure to handle the cld upcall nfsd: add a header describing upcall to nfsdcld nfsd: add a per-net-namespace struct for nfsd sunrpc: create nfsd dir in rpc_pipefs nfsd: add nfsd4_client_tracking_ops struct and a way to set it nfsd: convert nfs4_client->cl_cb_flags to a generic flags field NFSD: Fix nfs4_verifier memory alignment NFSD: Fix warnings when NFSD_DEBUG is not defined nfsd: vfs_llseek() with 32 or 64 bit offsets (hashes) nfsd: rename 'int access' to 'int may_flags' in nfsd_open() ext4: return 32/64-bit dir name hash according to usage type fs: add new FMODE flags: FMODE_32bithash and FMODE_64bithash ...
2012-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull arch/tile (really asm-generic) update from Chris Metcalf: "These are a couple of asm-generic changes that apply to tile." * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: compat: use sys_sendfile64() implementation for sendfile syscall [PATCH v3] ipc: provide generic compat versions of IPC syscalls
2012-03-29Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar. * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: cpusets: Remove an unused variable sched/rt: Improve pick_next_highest_task_rt() sched: Fix select_fallback_rq() vs cpu_active/cpu_online sched/x86/smp: Do not enable IRQs over calibrate_delay() sched: Fix compiler warning about declared inline after use MAINTAINERS: Update email address for SCHEDULER and PERF EVENTS
2012-03-29Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 updates from Ingo Molnar. This touches some non-x86 files due to the sanitized INLINE_SPIN_UNLOCK config usage. Fixed up trivial conflicts due to just header include changes (removing headers due to cpu_idle() merge clashing with the <asm/system.h> split). * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/apic/amd: Be more verbose about LVT offset assignments x86, tls: Off by one limit check x86/ioapic: Add io_apic_ops driver layer to allow interception x86/olpc: Add debugfs interface for EC commands x86: Merge the x86_32 and x86_64 cpu_idle() functions x86/kconfig: Remove CONFIG_TR=y from the defconfigs x86: Stop recursive fault in print_context_stack after stack overflow x86/io_apic: Move and reenable irq only when CONFIG_GENERIC_PENDING_IRQ=y x86/apic: Add separate apic_id_valid() functions for selected apic drivers locking/kconfig: Simplify INLINE_SPIN_UNLOCK usage x86/kconfig: Update defconfigs x86: Fix excessive MSR print out when show_msr is not specified
2012-03-29Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core updates from Thomas Gleixner. * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ia64: vsyscall: Add missing paranthesis alarmtimer: Don't call rtc_timer_init() when CONFIG_RTC_CLASS=n x86: vdso: Put declaration before code x86-64: Inline vdso clock_gettime helpers x86-64: Simplify and optimize vdso clock_gettime monotonic variants kernel-time: fix s/then/than/ spelling errors time: remove no_sync_cmos_clock time: Avoid scary backtraces when warning of > 11% adj alarmtimer: Make sure we initialize the rtctimer ntp: Fix leap-second hrtimer livelock x86, tsc: Skip refined tsc calibration on systems with reliable TSC rtc: Provide flag for rtc devices that don't support UIE ia64: vsyscall: Use seqcount instead of seqlock x86: vdso: Use seqcount instead of seqlock x86: vdso: Remove bogus locking in update_vsyscall_tz() time: Remove bogus comments time: Fix change_clocksource locking time: x86: Fix race switching from vsyscall to non-vsyscall clock
2012-03-29Fix ia64 build errors (fallout from system.h disintegration)Luck, Tony
Fix this build error on ia64: In file included from include/linux/sched.h:92, from arch/ia64/kernel/asm-offsets.c:9: include/linux/llist.h:59:25: error: asm/cmpxchg.h: No such file or directory make[1]: *** [arch/ia64/kernel/asm-offsets.s] Error 1 Right now we don't seem to need any actual contents for the asm/cmpxchg.h to make the build work ... so leave the migration of xchg() and cmpxchg() to this new header file for a future patch. Also process.c needs <asm/switch_to.h> (for definition of pfm_syst_info). Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29Merge branch 'irqdomain/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull the code to generalize the powerpc VIRQ_DEBUG code from Grant Likely. That code had been moved into generic irqdomain code, but still had powerpc-specific code and could only be enabled on powerpc. * 'irqdomain/merge' of git://git.secretlab.ca/git/linux-2.6: irqdomain/powerpc: updated defconfigs for VIRQ_DEBUG rename irqdomain: Remove powerpc dependency from debugfs file
2012-03-29Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Single fix for a commit from the first batch of patches through Andrew. * emailed from Andrew Morton <akpm@linux-foundation.org>: pagemap: remove remaining unneeded spin_lock()
2012-03-29pagemap: remove remaining unneeded spin_lock()Naoya Horiguchi
Commit 025c5b2451e4 ("thp: optimize away unnecessary page table locking") moves spin_lock() into pmd_trans_huge_lock() in order to avoid locking unless pmd is for thp. So this spin_lock() is a bug. Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29irqdomain/powerpc: updated defconfigs for VIRQ_DEBUG renameGrant Likely
2012-03-29irqdomain: Remove powerpc dependency from debugfs fileGrant Likely
The debugfs code is really generic for all platforms. This patch removes the powerpc-specific directory reference and makes it available to all architectures. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-29Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull the intel i915 hibernation memory corruption fix from Dave Airlie: "I tracked down the misc memory corruption after i915 hibernate to the blinking fbcon cursor, and realised the i915 driver wasn't doing the fbdev suspend/resume calls at all. nouveau and radeon have done these calls for a long time. This has been fairly well tested and is definitely the main culprit in hibernate not working." Yay. * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/i915: suspend fbdev device around suspend/hibernate
2012-03-29nfsd: only register cld pipe notifier when CONFIG_NFSD_V4 is enabledJeff Layton
Otherwise, we get a warning or error similar to this when building with CONFIG_NFSD_V4 disabled: ERROR: "nfsd4_cld_block" [fs/nfsd/nfsd.ko] undefined! Fix this by wrapping the calls to rpc_pipefs_notifier_register and ..._unregister in another function and providing no-op replacements when CONFIG_NFSD_V4 is disabled. Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-03-29drm/i915: suspend fbdev device around suspend/hibernateDave Airlie
Looking at hibernate overwriting I though it looked like a cursor, so I tracked down this missing piece to stop the cursor blink timer. I've no idea if this is sufficient to fix the hibernate problems people are seeing, but please test it. Both radeon and nouveau have done this for a long time. I've run this personally all night hib/resume cycles with no fails. Reviewed-by: Keith Packard <keithp@keithp.com> Reported-by: Petr Tesarik <kernel@tesarici.cz> Reported-by: Stanislaw Gruszka <sgruszka@redhat.com> Reported-by: Lots of misc segfaults after hibernate across the world. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=37142 Tested-by: Dave Airlie <airlied@redhat.com> Tested-by: Bojan Smojver <bojan@rexursive.com> Tested-by: Andreas Hartmann <andihartmann@01019freenet.de> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-28Merge tag 'mmc-merge-for-3.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: Core: * Support for MMC 4.5 Data Tag feature -- we tag REQ_META, so devices that support Data Tag will provide increased throughput for metadata. * Faster detection of card removal on I/O errors. Drivers: * dw_mmc now supports eMMC Power Off Notify, has PCI support, and implements pre_req and post_req for asynchronous requests. * omap_hsmmc now supports device tree. * esdhc now has power management support. * sdhci-tegra now supports Tegra30 devices. * sdhci-spear now supports hibernation. * tmio_mmc now supports using a GPIO for card detection. * Intel PCH now supports 8-bit bus transfers. * tag 'mmc-merge-for-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (53 commits) mmc: sh_mmcif: simplify bitmask macros mmc: sh_mobile_sdhi: support modular mmc-core with non-standard hotplug mmc: sh_mobile_sdhi: add a callback for board specific init code mmc: tmio: cosmetic: prettify the tmio_mmc_set_ios() function mmc: sh_mobile_sdhi: do not manage PM clocks manually mmc: tmio_mmc: remove unused sdio_irq_enabled flag mmc: tmio_mmc: power status flag doesn't have to be exposed in platform data mmc: sh_mobile_sdhi: pass card hotplug GPIO number to TMIO MMC mmc: tmio_mmc: support the generic MMC GPIO card hotplug helper mmc: tmio: calculate the native hotplug condition only once mmc: simplify mmc_cd_gpio_request() by removing two parameters mmc: sdhci-pci: allow 8-bit bus width for Intel PCH mmc: sdhci: check interrupt flags in ISR again mmc: sdhci-pci: Add MSI support mmc: core: warn when card doesn't support HPI mmc: davinci: Poll status for small size transfers mmc: davinci: Eliminate spurious interrupts mmc: omap_hsmmc: Avoid a regulator voltage change with dt mmc: omap_hsmmc: Convert hsmmc driver to use device tree mmc: sdhci-pci: add SDHCI_QUIRK2_HOST_OFF_CARD_ON for Medfield SDIO ...
2012-03-28Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
Pull trivial exofs changes from Boaz Harrosh: "Just nothingness really. The big exofs changes are reserved for the next merge window." * 'for-linus' of git://git.open-osd.org/linux-open-osd: exofs: Cap on the memcpy() size exofs: (trivial) Fix typo in super.c exofs: fix endian conversion in exofs_sync_fs()
2012-03-28Merge tag 'nfs-for-3.4-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes for Linux 3.4 from Trond Myklebust Highlights include: - Fix infinite loops in the mount code - Fix a userspace buffer overflow in __nfs4_get_acl_uncached - Fix a memory leak due to a double reference count in rpcb_getport_async() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> * tag 'nfs-for-3.4-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4: Minor cleanups for nfs4_handle_exception and nfs4_async_handle_error NFSv4.1: Fix layoutcommit error handling NFSv4: Fix two infinite loops in the mount code SUNRPC: Use the already looked-up xprt in rpcb_getport_async() NFS4.1: remove duplicate variable declaration in filelayout_clear_request_commit Fix length of buffer copied in __nfs4_get_acl_uncached
2012-03-28Merge tag 'squashfs-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next Pull squashfs updates from Phillip Lougher: "Add an extra mount time sanity check, plus some code cleanups and bug fixes." * tag 'squashfs-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next: Squashfs: add mount time sanity check for block_size and block_log match Squashfs: fix f_pos check in get_dir_index_using_offset Squashfs: get rid of obsolete definitions in header file Squashfs: remove redundant length initialisation in squashfs_lookup Squashfs: remove redundant length initialisation in squashfs_readdir Squashfs: update comment removing reference to zlib only Squashfs: use define instead of constant
2012-03-28Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge third batch of patches from Andrew Morton: - Some MM stragglers - core SMP library cleanups (on_each_cpu_mask) - Some IPI optimisations - kexec - kdump - IPMI - the radix-tree iterator work - various other misc bits. "That'll do for -rc1. I still have ~10 patches for 3.4, will send those along when they've baked a little more." * emailed from Andrew Morton <akpm@linux-foundation.org>: (35 commits) backlight: fix typo in tosa_lcd.c crc32: add help text for the algorithm select option mm: move hugepage test examples to tools/testing/selftests/vm mm: move slabinfo.c to tools/vm mm: move page-types.c from Documentation to tools/vm selftests/Makefile: make `run_tests' depend on `all' selftests: launch individual selftests from the main Makefile radix-tree: use iterators in find_get_pages* functions radix-tree: rewrite gang lookup using iterator radix-tree: introduce bit-optimized iterator fs/proc/namespaces.c: prevent crash when ns_entries[] is empty nbd: rename the nbd_device variable from lo to nbd pidns: add reboot_pid_ns() to handle the reboot syscall sysctl: use bitmap library functions ipmi: use locks on watchdog timeout set on reboot ipmi: simplify locking ipmi: fix message handling during panics ipmi: use a tasklet for handling received messages ipmi: increase KCS timeouts ipmi: decrease the IPMI message transaction time in interrupt mode ...
2012-03-28backlight: fix typo in tosa_lcd.cMasanari Iida
Fix typo in drivers/video/backlight/tosa_lcd.c "tosa_lcd_reume" should be "tosa_lcd_resume". Signed-off-by: Masanari Iida <standby24x7@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28crc32: add help text for the algorithm select optionDarrick J. Wong
Add help text to the crc32 algorithm selection option in Kconfig. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm: move hugepage test examples to tools/testing/selftests/vmDave Young
hugepage-mmap.c, hugepage-shm.c and map_hugetlb.c in Documentation/vm are simple pass/fail tests, It's better to promote them to tools/testing/selftests. Thanks suggestion of Andrew Morton about this. They all need firstly setting up proper nr_hugepages and hugepage-mmap need to mount hugetlbfs. So I add a shell script run_vmtests to do such work which will call the three test programs and check the return value of them. Changes to original code including below: a. add run_vmtests script b. return error when read_bytes mismatch with writed bytes. c. coding style fixes: do not use assignment in if condition [akpm@linux-foundation.org: build the targets before trying to execute them] [akpm@linux-foundation.org: Documentation/vm/ no longer has a Makefile. Fixes "make clean"] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm: move slabinfo.c to tools/vmDave Young
We have tools/vm/ folder for vm tools, so move slabinfo.c from tools/slub/ to tools/vm/ Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm: move page-types.c from Documentation to tools/vmDave Young
tools/ is the better place for vm tools which are used by many people. Moving them to tools also make them open to more users instead of hide in Documentation folder. This patch moves page-types.c to tools/vm/page-types.c. Also add a Makefile in tools/vm and fix two coding style problems: a) change const arrary to 'const char * const', b) change a space to tab for indent. Signed-off-by: Dave Young <dyoung@redhat.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28selftests/Makefile: make `run_tests' depend on `all'Andrew Morton
So a "make run_tests" will build the tests before trying to run them. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28selftests: launch individual selftests from the main MakefileFrederic Weisbecker
Remove the run_tests script and launch the selftests by calling "make run_tests" from the selftests top directory instead. This delegates to the Makefile in each selftest directory, where it is decided how to launch the local test. This removes the need to add each selftest directory to the now removed "run_tests" top script. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Dave Young <dyoung@redhat.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28radix-tree: use iterators in find_get_pages* functionsKonstantin Khlebnikov
Replace radix_tree_gang_lookup_slot() and radix_tree_gang_lookup_tag_slot() in page-cache lookup functions with brand-new radix-tree direct iterating. This avoids the double-scanning and pointer copying. Iterator don't stop after nr_pages page-get fails in a row, it continue lookup till the radix-tree end. Thus we can safely remove these restart conditions. Unfortunately, old implementation didn't forbid nr_pages == 0, this corner case does not fit into new code, so the patch adds an extra check at the beginning. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Tested-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28radix-tree: rewrite gang lookup using iteratorKonstantin Khlebnikov
Rewrite radix_tree_gang_lookup_* functions using the new radix-tree iterator. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Tested-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28radix-tree: introduce bit-optimized iteratorKonstantin Khlebnikov
A series of radix tree cleanups, and usage of them in the core pagecache code. Micro-benchmark: lookup 14 slots (typical page-vector size) in radix-tree there earch <step> slot filled and tagged before/after - nsec per full scan through tree * Intel Sandy Bridge i7-2620M 4Mb L3 New code always faster * AMD Athlon 6000+ 2x1Mb L2, without L3 New code generally faster, Minor degradation (marked with "*") for huge sparse trees * i386 on Sandy Bridge New code faster for common cases: tagged and dense trees. Some degradations for non-tagged lookup on sparse trees. Ideally, there might help __ffs() analog for searching first non-zero long element in array, gcc sometimes cannot optimize this loop corretly. Numbers: CPU: Intel Sandy Bridge i7-2620M 4Mb L3 radix-tree with 1024 slots: tagged lookup step 1 before 7156 after 3613 step 2 before 5399 after 2696 step 3 before 4779 after 1928 step 4 before 4456 after 1429 step 5 before 4292 after 1213 step 6 before 4183 after 1052 step 7 before 4157 after 951 step 8 before 4016 after 812 step 9 before 3952 after 851 step 10 before 3937 after 732 step 11 before 4023 after 709 step 12 before 3872 after 657 step 13 before 3892 after 633 step 14 before 3720 after 591 step 15 before 3879 after 578 step 16 before 3561 after 513 normal lookup step 1 before 4266 after 3301 step 2 before 2695 after 2129 step 3 before 2083 after 1712 step 4 before 1801 after 1534 step 5 before 1628 after 1313 step 6 before 1551 after 1263 step 7 before 1475 after 1185 step 8 before 1432 after 1167 step 9 before 1373 after 1092 step 10 before 1339 after 1134 step 11 before 1292 after 1056 step 12 before 1319 after 1030 step 13 before 1276 after 1004 step 14 before 1256 after 987 step 15 before 1228 after 992 step 16 before 1247 after 999 radix-tree with 1024*1024*128 slots: tagged lookup step 1 before 1086102841 after 674196409 step 2 before 816839155 after 498138306 step 7 before 599728907 after 240676762 step 15 before 555729253 after 185219677 step 63 before 606637748 after 128585664 step 64 before 608384432 after 102945089 step 65 before 596987114 after 123996019 step 128 before 304459225 after 56783056 step 256 before 158846855 after 31232481 step 512 before 86085652 after 18950595 step 12345 before 6517189 after 1674057 normal lookup step 1 before 626064869 after 544418266 step 2 before 418809975 after 336321473 step 7 before 242303598 after 207755560 step 15 before 208380563 after 176496355 step 63 before 186854206 after 167283638 step 64 before 176188060 after 170143976 step 65 before 185139608 after 167487116 step 128 before 88181865 after 86913490 step 256 before 45733628 after 45143534 step 512 before 24506038 after 23859036 step 12345 before 2177425 after 2018662 * AMD Athlon 6000+ 2x1Mb L2, without L3 radix-tree with 1024 slots: tag-lookup step 1 before 8164 after 5379 step 2 before 5818 after 5581 step 3 before 4959 after 4213 step 4 before 4371 after 3386 step 5 before 4204 after 2997 step 6 before 4950 after 2744 step 7 before 4598 after 2480 step 8 before 4251 after 2288 step 9 before 4262 after 2243 step 10 before 4175 after 2131 step 11 before 3999 after 2024 step 12 before 3979 after 1994 step 13 before 3842 after 1929 step 14 before 3750 after 1810 step 15 before 3735 after 1810 step 16 before 3532 after 1660 normal-lookup step 1 before 7875 after 5847 step 2 before 4808 after 4071 step 3 before 4073 after 3462 step 4 before 3677 after 3074 step 5 before 4308 after 2978 step 6 before 3911 after 3807 step 7 before 3635 after 3522 step 8 before 3313 after 3202 step 9 before 3280 after 3257 step 10 before 3166 after 3083 step 11 before 3066 after 3026 step 12 before 2985 after 2982 step 13 before 2925 after 2924 step 14 before 2834 after 2808 step 15 before 2805 after 2803 step 16 before 2647 after 2622 radix-tree with 1024*1024*128 slots: tag-lookup step 1 before 1288059720 after 951736580 step 2 before 961292300 after 884212140 step 7 before 768905140 after 547267580 step 15 before 771319480 after 456550640 step 63 before 504847640 after 242704304 step 64 before 392484800 after 177920786 step 65 before 491162160 after 246895264 step 128 before 208084064 after 97348392 step 256 before 112401035 after 51408126 step 512 before 75825834 after 29145070 step 12345 before 5603166 after 2847330 normal-lookup step 1 before 1025677120 after 861375100 step 2 before 647220080 after 572258540 step 7 before 505518960 after 484041813 step 15 before 430483053 after 444815320 * step 63 before 388113453 after 404250546 * step 64 before 374154666 after 396027440 * step 65 before 381423973 after 396704853 * step 128 before 190078700 after 202619384 * step 256 before 100886756 after 102829108 * step 512 before 64074505 after 56158720 step 12345 before 4237289 after 4422299 * * i686 on Sandy bridge radix-tree with 1024 slots: tagged lookup step 1 before 7990 after 4019 step 2 before 5698 after 2897 step 3 before 5013 after 2475 step 4 before 4630 after 1721 step 5 before 4346 after 1759 step 6 before 4299 after 1556 step 7 before 4098 after 1513 step 8 before 4115 after 1222 step 9 before 3983 after 1390 step 10 before 4077 after 1207 step 11 before 3921 after 1231 step 12 before 3894 after 1116 step 13 before 3840 after 1147 step 14 before 3799 after 1090 step 15 before 3797 after 1059 step 16 before 3783 after 745 normal lookup step 1 before 5103 after 3499 step 2 before 3299 after 2550 step 3 before 2489 after 2370 step 4 before 2034 after 2302 * step 5 before 1846 after 2268 * step 6 before 1752 after 2249 * step 7 before 1679 after 2164 * step 8 before 1627 after 2153 * step 9 before 1542 after 2095 * step 10 before 1479 after 2109 * step 11 before 1469 after 2009 * step 12 before 1445 after 2039 * step 13 before 1411 after 2013 * step 14 before 1374 after 2046 * step 15 before 1340 after 1975 * step 16 before 1331 after 2000 * radix-tree with 1024*1024*128 slots: tagged lookup step 1 before 1225865377 after 667153553 step 2 before 842427423 after 471533007 step 7 before 609296153 after 276260116 step 15 before 544232060 after 226859105 step 63 before 519209199 after 141343043 step 64 before 588980279 after 141951339 step 65 before 521099710 after 138282060 step 128 before 298476778 after 83390628 step 256 before 149358342 after 43602609 step 512 before 76994713 after 22911077 step 12345 before 5328666 after 1472111 normal lookup step 1 before 819284564 after 533635310 step 2 before 512421605 after 364956155 step 7 before 271443305 after 305721345 * step 15 before 223591630 after 273960216 * step 63 before 190320247 after 217770207 * step 64 before 178538168 after 267411372 * step 65 before 186400423 after 215347937 * step 128 before 88106045 after 140540612 * step 256 before 44812420 after 70660377 * step 512 before 24435438 after 36328275 * step 12345 before 2123924 after 2148062 * bloat-o-meter delta for this patchset + patchset with related shmem cleanups bloat-o-meter: x86_64 add/remove: 4/3 grow/shrink: 5/6 up/down: 928/-939 (-11) function old new delta radix_tree_next_chunk - 499 +499 shmem_unuse 428 554 +126 shmem_radix_tree_replace 131 227 +96 find_get_pages_tag 354 419 +65 find_get_pages_contig 345 407 +62 find_get_pages 362 396 +34 __kstrtab_radix_tree_next_chunk - 22 +22 __ksymtab_radix_tree_next_chunk - 16 +16 __kcrctab_radix_tree_next_chunk - 8 +8 radix_tree_gang_lookup_slot 204 203 -1 static.shmem_xattr_set 384 381 -3 radix_tree_gang_lookup_tag_slot 208 191 -17 radix_tree_gang_lookup 231 187 -44 radix_tree_gang_lookup_tag 247 199 -48 shmem_unlock_mapping 278 190 -88 __lookup 217 - -217 __lookup_tag 242 - -242 radix_tree_locate_item 279 - -279 bloat-o-meter: i386 add/remove: 3/3 grow/shrink: 8/9 up/down: 1075/-1275 (-200) function old new delta radix_tree_next_chunk - 757 +757 shmem_unuse 352 449 +97 find_get_pages_contig 269 322 +53 shmem_radix_tree_replace 113 154 +41 find_get_pages_tag 277 318 +41 dcache_dir_lseek 426 458 +32 __kstrtab_radix_tree_next_chunk - 22 +22 vc_do_resize 968 977 +9 snd_pcm_lib_read1 725 733 +8 __ksymtab_radix_tree_next_chunk - 8 +8 netlbl_cipsov4_list 1120 1127 +7 find_get_pages 293 291 -2 new_slab 467 459 -8 bitfill_unaligned_rev 425 417 -8 radix_tree_gang_lookup_tag_slot 177 146 -31 blk_dump_cmd 267 229 -38 radix_tree_gang_lookup_slot 212 134 -78 shmem_unlock_mapping 221 128 -93 radix_tree_gang_lookup_tag 275 162 -113 radix_tree_gang_lookup 255 126 -129 __lookup 227 - -227 __lookup_tag 271 - -271 radix_tree_locate_item 277 - -277 This patch: Implement a clean, simple and effective radix-tree iteration routine. Iterating divided into two phases: * lookup next chunk in radix-tree leaf node * iterating through slots in this chunk Main iterator function radix_tree_next_chunk() returns pointer to first slot, and stores in the struct radix_tree_iter index of next-to-last slot. For tagged-iterating it also constuct bitmask of tags for retunted chunk. All additional logic implemented as static-inline functions and macroses. Also adds radix_tree_find_next_bit() static-inline variant of find_next_bit() optimized for small constant size arrays, because find_next_bit() too heavy for searching in an array with one/two long elements. [akpm@linux-foundation.org: rework comments a bit] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Tested-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28fs/proc/namespaces.c: prevent crash when ns_entries[] is emptyAndrew Morton
If CONFIG_NET_NS, CONFIG_UTS_NS and CONFIG_IPC_NS are disabled, ns_entries[] becomes empty and things like ns_entries[ARRAY_SIZE(ns_entries) - 1] will explode. Reported-by: Richard Weinberger <richard@nod.at> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28nbd: rename the nbd_device variable from lo to nbdWanlong Gao
rename the nbd_device variable from "lo" to "nbd", since "lo" is just a name copied from loop.c. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28pidns: add reboot_pid_ns() to handle the reboot syscallDaniel Lezcano
In the case of a child pid namespace, rebooting the system does not really makes sense. When the pid namespace is used in conjunction with the other namespaces in order to create a linux container, the reboot syscall leads to some problems. A container can reboot the host. That can be fixed by dropping the sys_reboot capability but we are unable to correctly to poweroff/ halt/reboot a container and the container stays stuck at the shutdown time with the container's init process waiting indefinitively. After several attempts, no solution from userspace was found to reliabily handle the shutdown from a container. This patch propose to make the init process of the child pid namespace to exit with a signal status set to : SIGINT if the child pid namespace called "halt/poweroff" and SIGHUP if the child pid namespace called "reboot". When the reboot syscall is called and we are not in the initial pid namespace, we kill the pid namespace for "HALT", "POWEROFF", "RESTART", and "RESTART2". Otherwise we return EINVAL. Returning EINVAL is also an easy way to check if this feature is supported by the kernel when invoking another 'reboot' option like CAD. By this way the parent process of the child pid namespace knows if it rebooted or not and can take the right decision. Test case: ========== #include <alloca.h> #include <stdio.h> #include <sched.h> #include <unistd.h> #include <signal.h> #include <sys/reboot.h> #include <sys/types.h> #include <sys/wait.h> #include <linux/reboot.h> static int do_reboot(void *arg) { int *cmd = arg; if (reboot(*cmd)) printf("failed to reboot(%d): %m\n", *cmd); } int test_reboot(int cmd, int sig) { long stack_size = 4096; void *stack = alloca(stack_size) + stack_size; int status; pid_t ret; ret = clone(do_reboot, stack, CLONE_NEWPID | SIGCHLD, &cmd); if (ret < 0) { printf("failed to clone: %m\n"); return -1; } if (wait(&status) < 0) { printf("unexpected wait error: %m\n"); return -1; } if (!WIFSIGNALED(status)) { printf("child process exited but was not signaled\n"); return -1; } if (WTERMSIG(status) != sig) { printf("signal termination is not the one expected\n"); return -1; } return 0; } int main(int argc, char *argv[]) { int status; status = test_reboot(LINUX_REBOOT_CMD_RESTART, SIGHUP); if (status < 0) return 1; printf("reboot(LINUX_REBOOT_CMD_RESTART) succeed\n"); status = test_reboot(LINUX_REBOOT_CMD_RESTART2, SIGHUP); if (status < 0) return 1; printf("reboot(LINUX_REBOOT_CMD_RESTART2) succeed\n"); status = test_reboot(LINUX_REBOOT_CMD_HALT, SIGINT); if (status < 0) return 1; printf("reboot(LINUX_REBOOT_CMD_HALT) succeed\n"); status = test_reboot(LINUX_REBOOT_CMD_POWER_OFF, SIGINT); if (status < 0) return 1; printf("reboot(LINUX_REBOOT_CMD_POWERR_OFF) succeed\n"); status = test_reboot(LINUX_REBOOT_CMD_CAD_ON, -1); if (status >= 0) { printf("reboot(LINUX_REBOOT_CMD_CAD_ON) should have failed\n"); return 1; } printf("reboot(LINUX_REBOOT_CMD_CAD_ON) has failed as expected\n"); return 0; } [akpm@linux-foundation.org: tweak and add comments] [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Tested-by: Serge Hallyn <serge.hallyn@canonical.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28sysctl: use bitmap library functionsAkinobu Mita
Use bitmap_set() instead of using set_bit() for each bit. This conversion is valid because the bitmap is private in the function call and atomic bitops were unnecessary. This also includes minor change. - Use bitmap_copy() for shorter typing Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: use locks on watchdog timeout set on rebootCorey Minyard
The IPMI watchdog timer clears or extends the timer on reboot/shutdown. It was using the non-locking routine for setting the watchdog timer, but this was causing race conditions. Instead, use the locking version to avoid the races. It seems to work fine. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: simplify lockingCorey Minyard
Now that the the IPMI driver is using a tasklet, we can simplify the locking in the driver and get rid of the message lock. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: fix message handling during panicsCorey Minyard
The part of the IPMI driver that delivered panic information to the event log and extended the watchdog timeout during a panic was not properly handling the messages. It used static messages to avoid allocation, but wasn't properly waiting for these, or wasn't properly handling the refcounts. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: use a tasklet for handling received messagesCorey Minyard
The IPMI driver would release a lock, deliver a message, then relock. This is obviously ugly, and this patch converts the message handler interface to use a tasklet to schedule work. This lets the receive handler be called from an interrupt handler with interrupts enabled. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: increase KCS timeoutsMatthew Garrett
We currently time out and retry KCS transactions after 1 second of waiting for IBF or OBF. This appears to be too short for some hardware. The IPMI spec says "All system software wait loops should include error timeouts. For simplicity, such timeouts are not shown explicitly in the flow diagrams. A five-second timeout or greater is recommended". Change the timeout to five seconds to satisfy the slow hardware. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28ipmi: decrease the IPMI message transaction time in interrupt modeSrinivas_Gowda
Call the event handler immediately after starting the next message. This change considerably decreases the IPMI transaction time (cuts off ~9ms for a single ipmitool transaction). Signed-off-by: Srinivas_Gowda <srinivas_g_gowda@dell.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28kdump x86: fix total mem size calculation for reservationDave Young
crashkernel reservation need know the total memory size. Current get_total_mem simply use max_pfn - min_low_pfn. It is wrong because it will including memory holes in the middle. Especially for kvm guest with memory > 0xe0000000, there's below in qemu code: qemu split memory as below: if (ram_size >= 0xe0000000 ) { above_4g_mem_size = ram_size - 0xe0000000; below_4g_mem_size = 0xe0000000; } else { below_4g_mem_size = ram_size; } So for 4G mem guest, seabios will insert a 512M usable region beyond of 4G. Thus in above case max_pfn - min_low_pfn will be more than original memsize. Fixing this issue by using memblock_phys_mem_size() to get the total memsize. Signed-off-by: Dave Young <dyoung@redhat.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28kexec: add further check to crashkernelZhenzhong Duan
When using crashkernel=2M-256M, the kernel doesn't give any warning. This is misleading sometimes. Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28kexec: crash: don't save swapper_pg_dir for !CONFIG_MMU configurationsWill Deacon
nommu platforms don't have very interesting swapper_pg_dir pointers and usually just #define them to NULL, meaning that we can't include them in the vmcoreinfo on the kexec crash path. This patch only saves the swapper_pg_dir if we have an MMU. Signed-off-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Simon Horman <horms@verge.net.au> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28arch/ia64: remove references to cpu_*_mapSrivatsa S. Bhat
This was marked as obsolete for quite a while now.. Now it is time to remove it altogether. And while doing this, get rid of first_cpu() as well. Also, remove the redundant setting of cpu_online_mask in smp_prepare_cpus() because the generic code would have already set cpu 0 in cpu_online_mask. Reported-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28lib/cpumask.c: remove __any_online_cpu()Srivatsa S. Bhat
__any_online_cpu() is not optimal and also unnecessary. So, replace its use by faster cpumask_* operations. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Venkatesh Pallipadi <venki@google.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm: only IPI CPUs to drain local pages if they existGilad Ben-Yossef
Calculate a cpumask of CPUs with per-cpu pages in any zone and only send an IPI requesting CPUs to drain these pages to the buddy allocator if they actually have pages when asked to flush. This patch saves 85%+ of IPIs asking to drain per-cpu pages in case of severe memory pressure that leads to OOM since in these cases multiple, possibly concurrent, allocation requests end up in the direct reclaim code path so when the per-cpu pages end up reclaimed on first allocation failure for most of the proceeding allocation attempts until the memory pressure is off (possibly via the OOM killer) there are no per-cpu pages on most CPUs (and there can easily be hundreds of them). This also has the side effect of shortening the average latency of direct reclaim by 1 or more order of magnitude since waiting for all the CPUs to ACK the IPI takes a long time. Tested by running "hackbench 400" on a 8 CPU x86 VM and observing the difference between the number of direct reclaim attempts that end up in drain_all_pages() and those were more then 1/2 of the online CPU had any per-cpu page in them, using the vmstat counters introduced in the next patch in the series and using proc/interrupts. In the test sceanrio, this was seen to save around 3600 global IPIs after trigerring an OOM on a concurrent workload: $ cat /proc/vmstat | tail -n 2 pcp_global_drain 0 pcp_global_ipi_saved 0 $ cat /proc/interrupts | grep CAL CAL: 1 2 1 2 2 2 2 2 Function call interrupts $ hackbench 400 [OOM messages snipped] $ cat /proc/vmstat | tail -n 2 pcp_global_drain 3647 pcp_global_ipi_saved 3642 $ cat /proc/interrupts | grep CAL CAL: 6 13 6 3 3 3 1 2 7 Function call interrupts Please note that if the global drain is removed from the direct reclaim path as a patch from Mel Gorman currently suggests this should be replaced with an on_each_cpu_cond invocation. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Pekka Enberg <penberg@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Michal Nazarewicz <mina86@mina86.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28fs: only send IPI to invalidate LRU BH when neededGilad Ben-Yossef
In several code paths, such as when unmounting a file system (but not only) we send an IPI to ask each cpu to invalidate its local LRU BHs. For multi-cores systems that have many cpus that may not have any LRU BH because they are idle or because they have not performed any file system accesses since last invalidation (e.g. CPU crunching on high perfomance computing nodes that write results to shared memory or only using filesystems that do not use the bh layer.) This can lead to loss of performance each time someone switches the KVM (the virtual keyboard and screen type, not the hypervisor) if it has a USB storage stuck in. This patch attempts to only send an IPI to cpus that have LRU BH. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
