Commit 98dc070373 ("Input: synaptics - add quirk for Thinkpad E440") had
a typo in ymax, this changes the value to the one reported by
touchpad-edge-detector and mentioned in the commit.
Signed-off-by: Filip Ayazi <filipayazi@gmail.com>
Its ClickPad shares PNP ID "LEN2006" with the one in model E540 which is
already handled by the driver (both are Haswell iterations of the Edge
line, launched in 2014) but the dimensions it reports are different:
$ sudo ./touchpad-edge-detector /dev/input/event3
Touchpad SynPS/2 Synaptics TouchPad on /dev/input/event3
Move one finger around the touchpad to detect the actual edges
Kernel says: x [1472..5044], y [1408..3398]
Touchpad sends: x [1024..5045], y [2457..4832] /^C
Fortunately we can use the board ID, which is also different, to
distinguish among them.
$ dmesg | grep -i synaptics
psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1,
caps: 0xd001a3/0x940300/0x127c00, board id: 2691, fw id: 1494646
psmouse serio1: synaptics: serio: Synaptics pass-through port at
isa0060/serio1/input0
input: SynPS/2 Synaptics TouchPad as
/devices/platform/i8042/serio1/input/input4
Board ID in E540 is 2722:
caps: 0xd001a3/0x940300/0x127c00, board id: 2722, fw id: 1484859
(from https://launchpadlibrarian.net/179702965/BootDmesg.txt)
Signed-off-by: Ramiro Morales <cramm0@gmail.com>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Commit 3296f71cd2fde7a2ad52e66a27eae419f6328066 ("Input: ALPS - consolidate
setting protocol parameters") inadvertently moved call to
alps_dolphin_get_device_area() from v5 to v7 protocol, causing both
protocols report incorrect maximum values for X and Y axes which resulted
in crash in Synaptics X driver.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=94801
Reported-by: Santiago Gala <sgala@apache.org>
Reported-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Acked-by: Pali Rohár <pali.rohar@gmail.com>
Currently there are only two "tools" that can be specified by a multi-touch
driver: MT_TOOL_FINGER and MT_TOOL_PEN. In working with Elan (The touch
vendor) and discussing their next-gen devices it seems that it will be
useful to have more tools so that their devices can give the upper layers
of the stack hints as to what is touching the sensor.
In particular they have new experimental firmware that can better
differentiate between palms vs fingertips and would like to plumb a patch
so that we can use their hints in higher-level gesture soft- ware. The
firmware on the device can reasonably do a better job of palm detection
because it has access to all of the raw sensor readings as opposed to just
the width/pressure/etc that are exposed by the driver. As such, the
firmware can characterize what a palm looks like in much finer-grained
detail and this change would allow such a device to share its findings with
the kernel.
Signed-off-by: Charlie Mooney <charliemooney@chromium.org>
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
This reverts commit 6ab17a8484f03c188a93713369912f1545eb26e9 since it,
according to Benjamin, causes issues with slot assignment:
E: 15.669119 0000 0000 0000 # ------------ SYN_REPORT (0) ----------
E: 15.954242 0003 002f 0000 # EV_ABS / ABS_MT_SLOT 0
E: 15.954242 0003 0039 0505 # EV_ABS / ABS_MT_TRACKING_ID 505
E: 15.954242 0003 0035 3851 # EV_ABS / ABS_MT_POSITION_X 3851
E: 15.954242 0003 0036 4076 # EV_ABS / ABS_MT_POSITION_Y 4076
E: 15.954242 0003 003a 0034 # EV_ABS / ABS_MT_PRESSURE 34
E: 15.954242 0001 014a 0001 # EV_KEY / BTN_TOUCH 1
E: 15.954242 0003 0000 3851 # EV_ABS / ABS_X 3851
E: 15.954242 0003 0001 4076 # EV_ABS / ABS_Y 4076
E: 15.954242 0003 0018 0034 # EV_ABS / ABS_PRESSURE 34
E: 15.954242 0001 0145 0001 # EV_KEY / BTN_TOOL_FINGER 1
E: 15.954242 0000 0000 0000 # ------------ SYN_REPORT (0) ----------
... (bunch of regular events)...
E: 16.020614 0000 0000 0000 # ------------ SYN_REPORT (0) ----------
E: 16.043601 0003 0035 3873 # EV_ABS / ABS_MT_POSITION_X 3873
E: 16.043601 0003 0036 3903 # EV_ABS / ABS_MT_POSITION_Y 3903
E: 16.043601 0003 003a 0050 # EV_ABS / ABS_MT_PRESSURE 50
E: 16.043601 0003 0035 3032 # EV_ABS / ABS_MT_POSITION_X 3032
E: 16.043601 0003 0036 3832 # EV_ABS / ABS_MT_POSITION_Y 3832
E: 16.043601 0003 003a 0044 # EV_ABS / ABS_MT_PRESSURE 44
E: 16.043601 0003 0000 3032 # EV_ABS / ABS_X 3032
E: 16.043601 0003 0001 3832 # EV_ABS / ABS_Y 3832
E: 16.043601 0003 0018 0044 # EV_ABS / ABS_PRESSURE 44
E: 16.043601 0001 0145 0000 # EV_KEY / BTN_TOOL_FINGER 0
E: 16.043601 0001 014d 0001 # EV_KEY / BTN_TOOL_DOUBLETAP 1
E: 16.043601 0000 0000 0000 # ------------ SYN_REPORT (0) ----------
E: 16.068837 0003 002f 0001 # EV_ABS / ABS_MT_SLOT 1
E: 16.068837 0003 0039 0506 # EV_ABS / ABS_MT_TRACKING_ID 506
E: 16.068837 0003 0035 3912 # EV_ABS / ABS_MT_POSITION_X 3912
E: 16.068837 0003 0036 3743 # EV_ABS / ABS_MT_POSITION_Y 3743
E: 16.068837 0003 003a 0056 # EV_ABS / ABS_MT_PRESSURE 56
E: 16.068837 0003 002f 0000 # EV_ABS / ABS_MT_SLOT 0
E: 16.068837 0003 0035 3026 # EV_ABS / ABS_MT_POSITION_X 3026
E: 16.068837 0003 0036 3708 # EV_ABS / ABS_MT_POSITION_Y 3708
E: 16.068837 0003 003a 0052 # EV_ABS / ABS_MT_PRESSURE 52
E: 16.068837 0003 0000 3026 # EV_ABS / ABS_X 3026
E: 16.068837 0003 0001 3708 # EV_ABS / ABS_Y 3708
E: 16.068837 0003 0018 0052 # EV_ABS / ABS_PRESSURE 52
E: 16.068837 0000 0000 0000 # ------------ SYN_REPORT (0) ----------
Slot 0 and 1 gets inverted in the second report above, which
introduces a cursor jump. The problem is that this cursor jump is
often enough to leave the current widget, and X sends the
scrolling events to whoever is now under the cursor.
Reported-by: Benjamin Tissoires <btissoir@redhat.com>
Reported-by: Hans de Goede <hdegoede@redhat.com>
Bring in changes needed to properly handle Lenovo 2015 lineup.
Lenovo X250 has a PnpID of LEN0046, but it does not have the top software
button requirement.
For the record, Lenovo T450s and W541 have a PnpID of LEN200f and LEN004a,
so they are not on the top software button list.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Reviewed-by: Daniel Martin <consume.noise@gmail.com>
Lenovo decided to switch back to physical buttons for the trackstick on
their latest series. The PNPId list was provided before they reverted back
to physical buttons, so it contains the new models too. We can know from
the touchpad capabilities that the touchpad has physical buttons, so
removing the ids from the list is not mandatory. It is still nicer to
remove the wrong ids, so start by removing the X1 Carbon 3rd gen, with the
PNPId of LEN0048.
The 2015 series of the Lenovo thinkpads added back the hardware buttons on
top of the touchpad for the trackstick.
Unfortunately, they are wired to the touchpad, and not the trackstick.
Thus, they are seen as extra buttons from the kernel point of view.
This leads to a problem in user space because extra buttons on synaptics
devices used to be used as scroll up/down buttons. So in the end, the
experience for the user is scroll events for buttons left and right when
using the trackstick. Yay!
Fortunately, the firmware advertises such behavior in the extended
capability $10, and so we can re-route the buttons through the pass-through
interface.
Hallelujah-expressed-by: Peter Hutterer <peter.hutterer@who-t.net>
Unfortunately, Lenovo used the PNPIDs that are supposed to be "5 buttons"
touchpads, so the new laptops also have the INPUT_PROP_TOPBUTTONPAD. Yay!
Instead of manually removing each of the new ones, or hoping that we know
all the current ones, we can consider that the PNPIDs list that were given
contains touchpads that have the trackstick buttons, either physically
wired to them, or emulated with the top software button property.
Thanks to the extra buttons capability in query $10, we can reliably detect
the physical buttons from the software ones, and so we can remove the
TOPBUTTONPAD property even if it was declared as such.
Newer Synaptics touchpads need to get information from the query $10.
Retrieve it if available.
The board id capability has been added in firmware 7.5.
Cc: stable@vger.kernel.org
The Fimware 8.1 has a bug in which the extra buttons are only sent when the
ExtBit is 1. This should be fixed in a future FW update which should have
a bump of the minor version.
On the X1 Carbon 3rd gen (with a 2015 broadwell cpu), the physical middle
button of the trackstick (attached to the touchpad serio device, of course)
seems to get lost.
Actually, the touchpads reports 3 extra buttons, which falls in the switch
below to the '2' case. Let's handle the case of odd numbers also, so that
the middle button finds its way back.
Post-2013 Lenovo laptops provide correct min/max dimensions, which are
different with the ones currently quirked. According to
https://bugzilla.kernel.org/show_bug.cgi?id=91541 the following board ids
are assigned in the post-2013 touchpads:
t440p/t440s: LEN0036 -> 2964/2962
t540p: LEN0034 -> 2964
Using 2961 as the common minimum makes these 3 laptops OK. We may need
to update those values later if other pnp_ids has a lower board_id.
Add a min/max range for board ids to the min/max coordinates quirk. This
makes it possible to restrict quirks to specific models based upon their
board id. The define ANY_BOARD_ID (0) serves as a wild card.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=91541
Signed-off-by: Daniel Martin <daniel.martin@secunet.com>
The firmware of the X240 (LEN0035, 2013/12) exposes the same values
x [1232..5710], y [1156..4696]
as the quirk applies.
Signed-off-by: Daniel Martin <consume.noise@gmail.com>
Query the min dimensions even if the check
SYN_EXT_CAP_REQUESTS(priv->capabilities) >= 7 fails, but we know that the
firmware version 8.1 is safe.
With that we don't need quirks for post-2013 models anymore as they expose
correct min and max dimensions.
re-order the tests to check SYN_CAP_MIN_DIMENSIONS even on FW 8.1
Logging the dimension values we queried and the values we use from a quirk
to overwrite can be helpful for debugging.
This partly relates to bug:
Split the function synaptics_resolution() into synaptics_resolution() and
synaptics_quirks(). synaptics_resolution() will be called before
synaptics_quirks() to query dimensions and resolutions before overwriting
them with quirks.
Apparently, the threshold for large contact area seems to be rather low on
some devices, causing the touchpad to frequently freeze during normal
usage. Because we do now know how we are supposed to use the value in
question, this commit just drops the related code completely.
Signed-off-by: Mathias Gottschlag <mgottschlag@gmail.com>
These PS/2 commands make some touchpads stop responding, so this commit
adds some dummy functions to replace the generic implementation. Because
scale changes were not encapsulated in a method of struct psmouse yet, this
commit adds a method set_scale to psmouse.
We don't know whether x_max or y_max really hold the maximum possible
coordinates, and we don't know for sure whether we correctly interpret the
coordinates sent by the touchpad, so we clamp the reported values to
prevent confusion in userspace code.
The size has in most cases already been fetched from the touchpad, the
hardcoded values should have been removed.
Since commit 1c6c69525b40eb76de8adf039409722015927dc3 ("genirq: Reject
bogus threaded irq requests") threaded IRQs without a primary handler
need to be requested with IRQF_ONESHOT, otherwise the request will fail.
Currently, plat->irqtype is only set to IRQF_TRIGGER_FALLING. This
patch sets the ONESHOT flag directly in request_threaded_irq() to
enforce the flag without being affected by future changes to
plat->irqtype.
Generated by: scripts/coccinelle/misc/irqf_oneshot.cocci
Signed-off-by: Valentin Rothberg <Valentin.Rothberg@lip6.fr>
This fixes memory leak introduced by commit
a09221e83e13e09a33109b9b037484eade901cea
The sun4i-ts driver has had a dependency on the thermal code
with the addition of the thermal zone sensor support, but this
is not currently enforced in Kconfig, so with TOUCHSCREEN_SUN4I=y,
THERMAL=m and THERMAL_OF=y we get
drivers/built-in.o: In function `sun4i_ts_remove':
:(.text+0x2376f4): undefined reference to `thermal_zone_of_sensor_unregister'
drivers/built-in.o: In function `sun4i_ts_probe':
:(.text+0x237a94): undefined reference to `thermal_zone_of_sensor_register'
:(.text+0x237c00): undefined reference to `thermal_zone_of_sensor_unregister'
We need the dependency on THERMAL in order to ensure that this
driver becomes a loadable module if the thermal support itself
is modular, while the dependency on THERMAL_OF is a runtime
dependency and the driver will still build if it is missing.
It is entirely possible to build sun4i-ts without THERMAL_OF
just to use the hwmon sensors and/or touchscreen.
Fixes: 223697107949 ("Input: sun4i-ts - add thermal zone sensor support")
[wens@csie.org: Fix description and Kconfig dependencies]
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
drivers/input/mouse/cyapa_gen5.c: In function ‘cyapa_gen5_read_idac_data’:
drivers/input/mouse/cyapa_gen5.c:1876: warning: ‘max_element_cnt’ may be used uninitialized in this function
drivers/input/mouse/cyapa_gen5.c:1873: warning: ‘offset’ may be used uninitialized in this function
If *data_size is non-zero, and idac_data_type contains an unknown type,
max_element_cnt and offset will be uninitialized, and the loop will
process non-existing data.
However, this cannot happen (for now), as there's a test for unknown
types at the top of cyapa_gen5_read_idac_data().
As no "if ... else if ..." is used in other places, remove the
superfluous "if" to silence the compiler warning.
Acked-by: Dudley Du <dudl@cypress.com>
Use asm/unaligned.h instead of linux/unaligned/access_ok.h header file to
fix compiling issues such as following while doing cross platform
compiling:
"include/linux/unaligned/access_ok.h:7:19: error: redefinition of
'get_unaligned_le16'
include/linux/unaligned/le_struct.h:6:19: note: previous definition of
'get_unaligned_le16' was here".
Reported-by: kbuild test robot <kbuild-all@01.org>
Signed-off-by: Dudley Du <dudl@cypress.com>
Add the parent device so that udev can show the full hierarchy. This avoids
the device showing up under /devices/virtual/input instead of the i2c bus
it is actually attached to.
Signed-off-by: Stefan Sauer <ensonic@google.com>
Second round of updates for 3.20.
Instead of having various protocols provide <protocol>_supported()
functions, let's use IS_ENABLED() macro that works well in "if" statements.
Merge bfin_rotary driver changes from Sonic Zhang.
Introduce open and close methods for the input device to postpone enabling
the device until it is needed.
Acked-by: Sonic Zhang <sonic.zhang@analog.com>
Use of managed resources simplifies error handling.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Instead of using arch-specific accessors remap rotary register physical
address into kernel space in probe and use standard readw and writew to
access rotary MMRs.
Newer Blackfin boards use pinctrl API to manage pins and the legacy
peripherial lists are not useful on them. Let's move pin lists into
platform data so older boards can still use them and newer boards can use
the modern API.
The platform data definition of the rotary driver should be generic for all
architectures.
Instead of using #ifdef to guard potentially unused suspend and resume code
let's mark them as __maybe_unused so they still get discarded if they are
not used but we do not get warning. This allows for better compile coverage.
The interrupt handler in the driver tries to fetch driver data from
platform device, unfortunately it is only set up after interrupt handler
is registered. Since interrupt handler does not really need to access
the platform device itself let's change it to get the driver data
instance instead.
This patch move all packet info from driver source code to documentation
and adds info about v6 packet format (from driver source code).
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
The comment about suspicions entry 0x20, 0x02, 0x0e has over time drifted
away and it become hard to figure out what it meant. Let's move it back so
it is clear.
Previously dev2 device was used for both external PS/2 mouse and internal
trackstick device (if available). This change introduces dev3 device which
is used for external PS/2 mouse data and dev2 is now used only for
trackstick.
In case that trackstick is not present dev2 is not created, so userspace
does not see non existent device in system.
Because laptops with ALPS devices often do not use i8042 active
multiplexing all data (from touchpad, trackstick and external PS/2 mouse)
come to one port. So it is not possible to know if external PS/2 mouse is
connected or not. In most cases external PS/2 mouse is not connected so
driver will create dev3 input device after first bare PS/2 packet will be
received. So there will not be "ghost" input device.
This change also helps in identifying possible problems in future if driver
decides to report 6-bytes trackstick packets as 3-bytes bare PS/2 (data
will be reported to dev3 instead dev2).
On some Dell Latitudes we fail to identify presence of trackstick unless we
reset the device. The issue is quite benign as we do perform reset in
alps_init(), so the trackstick ends up working, but mouse name reported to
userspace is not accurate.
In order to fix the issue while avoiding the additional lengthy reset we
move the resrt to alps_detect() and keep the discovered state to be used
later in alps_init().
Tested-by: Pali Rohár <pali.rohar@gmail.com>
Move setting of all protocol properties into alps_set_protocol (former
alps_set_defaults) instead of having it split between several functions.
In preparation of reworking the way we set protocol parameters let's
split certain protocol items from alps_model_info into a separate
structure.
Even though Rushmore is very close to V3 protocol it is sufficiently
different to warrant it's own protocol name.
In order to accommodate new protocol number for Rushmore touchpads
let's shift protocol numbers by 8 bits (i.e. 1 -> 0x100) - this way
we keep protocol version reported in input device id the same as it
was, but add some holes in numbering.
The input_free_device() function tests whether its argument is NULL and
then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Static checkers complain about this NULL check because we dereference it
without checking a couple lines later. This function is only called
when "keypad->pdata" is non-NULL so we can just delete the NULL test.
[Dmitry: remove the variable altogether given that it is used just once and
dereference directly.]
