While accounting memcg page stat, it's not worth to use
MEMCG_NR_FILE_MAPPED as an extra layer of indirection because of the
complexity and presumed performance overhead. We can use
MEM_CGROUP_STAT_FILE_MAPPED directly.
Signed-off-by: Sha Zhengju <handai.szj@taobao.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Fengguang Wu <fengguang.wu@intel.com>
Reviewed-by: Greg Thelen <gthelen@google.com>
This function dereferences res far too often, so optimize it.
Signed-off-by: Qiang Huang <h.huangqiang@huawei.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Jeff Liu <jeff.liu@oracle.com>
Since PAGE_ALIGN is aligning up(the next page boundary), so after
PAGE_ALIGN, the value might be overflow, such as write the MAX value to
*.limit_in_bytes.
$ cat /cgroup/memory/memory.limit_in_bytes
18446744073709551615
# echo 18446744073709551615 > /cgroup/memory/memory.limit_in_bytes
bash: echo: write error: Invalid argument
Some user programs might depend on such behaviours(like libcg, we read
the value in snapshot, then use the value to reset cgroup later), and
that will cause confusion. So we need to fix it.
RESOURCE_MAX is far too general name, change it to RES_COUNTER_MAX.
Current RESOURCE_MAX is ULONG_MAX, but the value we used to set resource
limit is unsigned long long, so we can set bigger value than that which is
strange. The XXX_MAX should be reasonable max value, bigger than that
should be overflow.
Notice that this change will affect user output of default *.limit_in_bytes:
before change:
9223372036854775807
after change:
But it doesn't alter the API in term of input - we can still use "echo -1
> *.limit_in_bytes" to reset the numbers to "unlimited".
The memcg OOM handling is incredibly fragile and can deadlock. When a
task fails to charge memory, it invokes the OOM killer and loops right
there in the charge code until it succeeds. Comparably, any other task
that enters the charge path at this point will go to a waitqueue right
then and there and sleep until the OOM situation is resolved. The problem
is that these tasks may hold filesystem locks and the mmap_sem; locks that
the selected OOM victim may need to exit.
For example, in one reported case, the task invoking the OOM killer was
about to charge a page cache page during a write(), which holds the
i_mutex. The OOM killer selected a task that was just entering truncate()
and trying to acquire the i_mutex:
OOM invoking task:
mem_cgroup_handle_oom+0x241/0x3b0
mem_cgroup_cache_charge+0xbe/0xe0
add_to_page_cache_locked+0x4c/0x140
add_to_page_cache_lru+0x22/0x50
grab_cache_page_write_begin+0x8b/0xe0
ext3_write_begin+0x88/0x270
generic_file_buffered_write+0x116/0x290
__generic_file_aio_write+0x27c/0x480
generic_file_aio_write+0x76/0xf0 # takes ->i_mutex
do_sync_write+0xea/0x130
vfs_write+0xf3/0x1f0
sys_write+0x51/0x90
system_call_fastpath+0x18/0x1d
OOM kill victim:
do_truncate+0x58/0xa0 # takes i_mutex
do_last+0x250/0xa30
path_openat+0xd7/0x440
do_filp_open+0x49/0xa0
do_sys_open+0x106/0x240
sys_open+0x20/0x30
The OOM handling task will retry the charge indefinitely while the OOM
killed task is not releasing any resources.
A similar scenario can happen when the kernel OOM killer for a memcg is
disabled and a userspace task is in charge of resolving OOM situations.
In this case, ALL tasks that enter the OOM path will be made to sleep on
the OOM waitqueue and wait for userspace to free resources or increase
the group's limit. But a userspace OOM handler is prone to deadlock
itself on the locks held by the waiting tasks. For example one of the
sleeping tasks may be stuck in a brk() call with the mmap_sem held for
writing but the userspace handler, in order to pick an optimal victim,
may need to read files from /proc/<pid>, which tries to acquire the same
mmap_sem for reading and deadlocks.
This patch changes the way tasks behave after detecting a memcg OOM and
makes sure nobody loops or sleeps with locks held:
1. When OOMing in a user fault, invoke the OOM killer and restart the
fault instead of looping on the charge attempt. This way, the OOM
victim can not get stuck on locks the looping task may hold.
2. When OOMing in a user fault but somebody else is handling it
(either the kernel OOM killer or a userspace handler), don't go to
sleep in the charge context. Instead, remember the OOMing memcg in
the task struct and then fully unwind the page fault stack with
-ENOMEM. pagefault_out_of_memory() will then call back into the
memcg code to check if the -ENOMEM came from the memcg, and then
either put the task to sleep on the memcg's OOM waitqueue or just
restart the fault. The OOM victim can no longer get stuck on any
lock a sleeping task may hold.
Debugged by Michal Hocko.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: azurIt <azurit@pobox.sk>
The memcg OOM handler open-codes a sleeping lock for OOM serialization
(trylock, wait, repeat) because the required locking is so specific to
memcg hierarchies. However, it would be nice if this construct would be
clearly recognizable and not be as obfuscated as it is right now. Clean
up as follows:
1. Remove the return value of mem_cgroup_oom_unlock()
2. Rename mem_cgroup_oom_lock() to mem_cgroup_oom_trylock().
3. Pull the prepare_to_wait() out of the memcg_oom_lock scope. This
makes it more obvious that the task has to be on the waitqueue
before attempting to OOM-trylock the hierarchy, to not miss any
wakeups before going to sleep. It just didn't matter until now
because it was all lumped together into the global memcg_oom_lock
spinlock section.
4. Pull the mem_cgroup_oom_notify() out of the memcg_oom_lock scope.
It is proctected by the hierarchical OOM-lock.
5. The memcg_oom_lock spinlock is only required to propagate the OOM
lock in any given hierarchy atomically. Restrict its scope to
mem_cgroup_oom_(trylock|unlock).
6. Do not wake up the waitqueue unconditionally at the end of the
function. Only the lockholder has to wake up the next in line
after releasing the lock.
Note that the lockholder kicks off the OOM-killer, which in turn
leads to wakeups from the uncharges of the exiting task. But a
contender is not guaranteed to see them if it enters the OOM path
after the OOM kills but before the lockholder releases the lock.
Thus there has to be an explicit wakeup after releasing the lock.
7. Put the OOM task on the waitqueue before marking the hierarchy as
under OOM as that is the point where we start to receive wakeups.
No point in listening before being on the waitqueue.
8. Likewise, unmark the hierarchy before finishing the sleep, for
symmetry.
Cc: azurIt <azurit@pobox.sk>
System calls and kernel faults (uaccess, gup) can handle an out of memory
situation gracefully and just return -ENOMEM.
Enable the memcg OOM killer only for user faults, where it's really the
only option available.
The x86 fault handler bails in the middle of error handling when the
task has a fatal signal pending. For a subsequent patch this is a
problem in OOM situations because it relies on pagefault_out_of_memory()
being called even when the task has been killed, to perform proper
per-task OOM state unwinding.
Shortcutting the fault like this is a rather minor optimization that
saves a few instructions in rare cases. Just remove it for
user-triggered faults.
Use the opportunity to split the fault retry handling from actual fault
errors and add locking documentation that reads suprisingly similar to
ARM's.
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Kernel faults are expected to handle OOM conditions gracefully (gup,
uaccess etc.), so they should never invoke the OOM killer. Reserve this
for faults triggered in user context when it is the only option.
Most architectures already do this, fix up the remaining few.
The memcg code can trap tasks in the context of the failing allocation
until an OOM situation is resolved. They can hold all kinds of locks
(fs, mm) at this point, which makes it prone to deadlocking.
This series converts memcg OOM handling into a two step process that is
started in the charge context, but any waiting is done after the fault
stack is fully unwound.
Patches 1-4 prepare architecture handlers to support the new memcg
requirements, but in doing so they also remove old cruft and unify
out-of-memory behavior across architectures.
Patch 5 disables the memcg OOM handling for syscalls, readahead, kernel
faults, because they can gracefully unwind the stack with -ENOMEM. OOM
handling is restricted to user triggered faults that have no other
option.
Patch 6 reworks memcg's hierarchical OOM locking to make it a little
more obvious wth is going on in there: reduce locked regions, rename
locking functions, reorder and document.
Patch 7 implements the two-part OOM handling such that tasks are never
trapped with the full charge stack in an OOM situation.
This patch:
Back before smart OOM killing, when faulting tasks were killed directly on
allocation failures, the arch-specific fault handlers needed special
protection for the init process.
Now that all fault handlers call into the generic OOM killer (see commit
609838cfed97: "mm: invoke oom-killer from remaining unconverted page
fault handlers"), which already provides init protection, the
arch-specific leftovers can be removed.
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits]
Clean up some mess made by the "Soft limit rework" series, and a few other
things.
shrink_zone starts with soft reclaim pass first and then falls back to
regular reclaim if nothing has been scanned. This behavior is natural
but there is a catch. Memcg iterators, when used with the reclaim
cookie, are designed to help to prevent from over reclaim by
interleaving reclaimers (per node-zone-priority) so the tree walk might
miss many (even all) nodes in the hierarchy e.g. when there are direct
reclaimers racing with each other or with kswapd in the global case or
multiple allocators reaching the limit for the target reclaim case. To
make it even more complicated, targeted reclaim doesn't do the whole
tree walk because it stops reclaiming once it reclaims sufficient pages.
As a result groups over the limit might be missed, thus nothing is
scanned, and reclaim would fall back to the reclaim all mode.
This patch checks for the incomplete tree walk in shrink_zone. If no
group has been visited and the hierarchy is soft reclaimable then we
must have missed some groups, in which case the __shrink_zone is called
again. This doesn't guarantee there will be some progress of course
because the current reclaimer might be still racing with others but it
would at least give a chance to start the walk without a big risk of
reclaim latencies.
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Glauber Costa <glommer@openvz.org>
Cc: Michel Lespinasse <walken@google.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Ying Han <yinghan@google.com>
Children in soft limit excess are currently tracked up the hierarchy in
memcg->children_in_excess. Nevertheless there still might exist tons of
groups that are not in hierarchy relation to the root cgroup (e.g. all
first level groups if root_mem_cgroup->use_hierarchy == false).
As the whole tree walk has to be done when the iteration starts at
root_mem_cgroup the iterator should be able to skip the walk if there is
no child above the limit without iterating them. This can be done
easily if the root tracks all children rather than only hierarchical
children. This is done by this patch which updates root_mem_cgroup
children_in_excess if root_mem_cgroup->use_hierarchy == false so the
root knows about all children in excess.
Please note that this is not an issue for inner memcgs which have
use_hierarchy == false because then only the single group is visited so
no special optimization is necessary.
mem_cgroup_should_soft_reclaim controls whether soft reclaim pass is
done and it always says yes currently. Memcg iterators are clever to
skip nodes that are not soft reclaimable quite efficiently but
mem_cgroup_should_soft_reclaim can be more clever and do not start the
soft reclaim pass at all if it knows that nothing would be scanned
anyway.
In order to do that, simply reuse mem_cgroup_soft_reclaim_eligible for
the target group of the reclaim and allow the pass only if the whole
subtree wouldn't be skipped.
Soft limit reclaim has to check the whole reclaim hierarchy while doing
the first pass of the reclaim. This leads to a higher system time which
can be visible especially when there are many groups in the hierarchy.
This patch adds a per-memcg counter of children in excess. It also
restores MEM_CGROUP_TARGET_SOFTLIMIT into mem_cgroup_event_ratelimit for a
proper batching.
If a group crosses soft limit for the first time it increases parent's
children_in_excess up the hierarchy. The similarly if a group gets below
the limit it will decrease the counter. The transition phase is recorded
in soft_contributed flag.
mem_cgroup_soft_reclaim_eligible then uses this information to better
decide whether to skip the node or the whole subtree. The rule is simple.
Skip the node with a children in excess or skip the whole subtree
otherwise.
This has been tested by a stream IO (dd if=/dev/zero of=file with
4*MemTotal size) which is quite sensitive to overhead during reclaim. The
load is running in a group with soft limit set to 0 and without any limit.
Apart from that there was a hierarchy with ~500, 2k and 8k groups (two
groups on each level) without any pages in them. base denotes to the
kernel on which the whole series is based on, rework is the kernel before
this patch and reworkoptim is with this patch applied:
* Run with soft limit set to 0
Elapsed
0-0-limit/base: min: 88.21 max: 94.61 avg: 91.73 std: 2.65 runs: 3
0-0-limit/rework: min: 76.05 [86.2%] max: 79.08 [83.6%] avg: 77.84 [84.9%] std: 1.30 runs: 3
0-0-limit/reworkoptim: min: 77.98 [88.4%] max: 80.36 [84.9%] avg: 78.92 [86.0%] std: 1.03 runs: 3
System
0.5k-0-limit/base: min: 34.86 max: 36.42 avg: 35.89 std: 0.73 runs: 3
0.5k-0-limit/rework: min: 43.26 [124.1%] max: 48.95 [134.4%] avg: 46.09 [128.4%] std: 2.32 runs: 3
0.5k-0-limit/reworkoptim: min: 46.98 [134.8%] max: 50.98 [140.0%] avg: 48.49 [135.1%] std: 1.77 runs: 3
Elapsed
0.5k-0-limit/base: min: 88.50 max: 97.52 avg: 93.92 std: 3.90 runs: 3
0.5k-0-limit/rework: min: 75.92 [85.8%] max: 78.45 [80.4%] avg: 77.34 [82.3%] std: 1.06 runs: 3
0.5k-0-limit/reworkoptim: min: 75.79 [85.6%] max: 79.37 [81.4%] avg: 77.55 [82.6%] std: 1.46 runs: 3
System
2k-0-limit/base: min: 34.57 max: 37.65 avg: 36.34 std: 1.30 runs: 3
2k-0-limit/rework: min: 64.17 [185.6%] max: 68.20 [181.1%] avg: 66.21 [182.2%] std: 1.65 runs: 3
2k-0-limit/reworkoptim: min: 49.78 [144.0%] max: 52.99 [140.7%] avg: 51.00 [140.3%] std: 1.42 runs: 3
Elapsed
2k-0-limit/base: min: 92.61 max: 97.83 avg: 95.03 std: 2.15 runs: 3
2k-0-limit/rework: min: 78.33 [84.6%] max: 84.08 [85.9%] avg: 81.09 [85.3%] std: 2.35 runs: 3
2k-0-limit/reworkoptim: min: 75.72 [81.8%] max: 78.57 [80.3%] avg: 76.73 [80.7%] std: 1.30 runs: 3
System
8k-0-limit/base: min: 39.78 max: 42.09 avg: 41.09 std: 0.97 runs: 3
8k-0-limit/rework: min: 200.86 [504.9%] max: 265.42 [630.6%] avg: 241.80 [588.5%] std: 29.06 runs: 3
8k-0-limit/reworkoptim: min: 53.70 [135.0%] max: 54.89 [130.4%] avg: 54.43 [132.5%] std: 0.52 runs: 3
Elapsed
8k-0-limit/base: min: 95.11 max: 98.61 avg: 96.81 std: 1.43 runs: 3
8k-0-limit/rework: min: 246.96 [259.7%] max: 331.47 [336.1%] avg: 301.32 [311.2%] std: 38.52 runs: 3
8k-0-limit/reworkoptim: min: 76.79 [80.7%] max: 81.71 [82.9%] avg: 78.97 [81.6%] std: 2.05 runs: 3
System time is increased by 30-40% but it is reduced a lot comparing to
kernel without this patch. The higher time can be explained by the fact
that the original soft reclaim scanned at priority 0 so it was much more
effective for this workload (which is basically touch once and writeback).
The Elapsed time looks better though (~20%).
* Run with no soft limit set
System
0-no-limit/base: min: 42.18 max: 50.38 avg: 46.44 std: 3.36 runs: 3
0-no-limit/rework: min: 40.57 [96.2%] max: 47.04 [93.4%] avg: 43.82 [94.4%] std: 2.64 runs: 3
0-no-limit/reworkoptim: min: 40.45 [95.9%] max: 45.28 [89.9%] avg: 42.10 [90.7%] std: 2.25 runs: 3
Elapsed
0-no-limit/base: min: 75.97 max: 78.21 avg: 76.87 std: 0.96 runs: 3
0-no-limit/rework: min: 75.59 [99.5%] max: 80.73 [103.2%] avg: 77.64 [101.0%] std: 2.23 runs: 3
0-no-limit/reworkoptim: min: 77.85 [102.5%] max: 82.42 [105.4%] avg: 79.64 [103.6%] std: 1.99 runs: 3
System
0.5k-no-limit/base: min: 44.54 max: 46.93 avg: 46.12 std: 1.12 runs: 3
0.5k-no-limit/rework: min: 42.09 [94.5%] max: 46.16 [98.4%] avg: 43.92 [95.2%] std: 1.69 runs: 3
0.5k-no-limit/reworkoptim: min: 42.47 [95.4%] max: 45.67 [97.3%] avg: 44.06 [95.5%] std: 1.31 runs: 3
Elapsed
0.5k-no-limit/base: min: 78.26 max: 81.49 avg: 79.65 std: 1.36 runs: 3
0.5k-no-limit/rework: min: 77.01 [98.4%] max: 80.43 [98.7%] avg: 78.30 [98.3%] std: 1.52 runs: 3
0.5k-no-limit/reworkoptim: min: 76.13 [97.3%] max: 77.87 [95.6%] avg: 77.18 [96.9%] std: 0.75 runs: 3
System
2k-no-limit/base: min: 62.96 max: 69.14 avg: 66.14 std: 2.53 runs: 3
2k-no-limit/rework: min: 76.01 [120.7%] max: 81.06 [117.2%] avg: 78.17 [118.2%] std: 2.12 runs: 3
2k-no-limit/reworkoptim: min: 62.57 [99.4%] max: 66.10 [95.6%] avg: 64.53 [97.6%] std: 1.47 runs: 3
Elapsed
2k-no-limit/base: min: 76.47 max: 84.22 avg: 79.12 std: 3.60 runs: 3
2k-no-limit/rework: min: 89.67 [117.3%] max: 93.26 [110.7%] avg: 91.10 [115.1%] std: 1.55 runs: 3
2k-no-limit/reworkoptim: min: 76.94 [100.6%] max: 79.21 [94.1%] avg: 78.45 [99.2%] std: 1.07 runs: 3
System
8k-no-limit/base: min: 104.74 max: 151.34 avg: 129.21 std: 19.10 runs: 3
8k-no-limit/rework: min: 205.23 [195.9%] max: 285.94 [188.9%] avg: 258.98 [200.4%] std: 38.01 runs: 3
8k-no-limit/reworkoptim: min: 161.16 [153.9%] max: 184.54 [121.9%] avg: 174.52 [135.1%] std: 9.83 runs: 3
Elapsed
8k-no-limit/base: min: 125.43 max: 181.00 avg: 154.81 std: 22.80 runs: 3
8k-no-limit/rework: min: 254.05 [202.5%] max: 355.67 [196.5%] avg: 321.46 [207.6%] std: 47.67 runs: 3
8k-no-limit/reworkoptim: min: 193.77 [154.5%] max: 222.72 [123.0%] avg: 210.18 [135.8%] std: 12.13 runs: 3
Both System and Elapsed are in stdev with the base kernel for all
configurations except for 8k where both System and Elapsed are up by 35%.
I do not have a good explanation for this because there is no soft reclaim
pass going on as no group is above the limit which is checked in
mem_cgroup_should_soft_reclaim.
Then I have tested kernel build with the same configuration to see the
behavior with a more general behavior.
* Soft limit set to 0 for the build
System
0-0-limit/base: min: 242.70 max: 245.17 avg: 243.85 std: 1.02 runs: 3
0-0-limit/rework min: 237.86 [98.0%] max: 240.22 [98.0%] avg: 239.00 [98.0%] std: 0.97 runs: 3
0-0-limit/reworkoptim: min: 241.11 [99.3%] max: 243.53 [99.3%] avg: 242.01 [99.2%] std: 1.08 runs: 3
Elapsed
0-0-limit/base: min: 348.48 max: 360.86 avg: 356.04 std: 5.41 runs: 3
0-0-limit/rework min: 286.95 [82.3%] max: 290.26 [80.4%] avg: 288.27 [81.0%] std: 1.43 runs: 3
0-0-limit/reworkoptim: min: 286.55 [82.2%] max: 289.00 [80.1%] avg: 287.69 [80.8%] std: 1.01 runs: 3
System
0.5k-0-limit/base: min: 251.77 max: 254.41 avg: 252.70 std: 1.21 runs: 3
0.5k-0-limit/rework min: 286.44 [113.8%] max: 289.30 [113.7%] avg: 287.60 [113.8%] std: 1.23 runs: 3
0.5k-0-limit/reworkoptim: min: 252.18 [100.2%] max: 253.16 [99.5%] avg: 252.62 [100.0%] std: 0.41 runs: 3
Elapsed
0.5k-0-limit/base: min: 347.83 max: 353.06 avg: 350.04 std: 2.21 runs: 3
0.5k-0-limit/rework min: 290.19 [83.4%] max: 295.62 [83.7%] avg: 293.12 [83.7%] std: 2.24 runs: 3
0.5k-0-limit/reworkoptim: min: 293.91 [84.5%] max: 294.87 [83.5%] avg: 294.29 [84.1%] std: 0.42 runs: 3
System
2k-0-limit/base: min: 263.05 max: 271.52 avg: 267.94 std: 3.58 runs: 3
2k-0-limit/rework min: 458.99 [174.5%] max: 468.31 [172.5%] avg: 464.45 [173.3%] std: 3.97 runs: 3
2k-0-limit/reworkoptim: min: 267.10 [101.5%] max: 279.38 [102.9%] avg: 272.78 [101.8%] std: 5.05 runs: 3
Elapsed
2k-0-limit/base: min: 372.33 max: 379.32 avg: 375.47 std: 2.90 runs: 3
2k-0-limit/rework min: 334.40 [89.8%] max: 339.52 [89.5%] avg: 337.44 [89.9%] std: 2.20 runs: 3
2k-0-limit/reworkoptim: min: 301.47 [81.0%] max: 319.19 [84.1%] avg: 307.90 [82.0%] std: 8.01 runs: 3
System
8k-0-limit/base: min: 320.50 max: 332.10 avg: 325.46 std: 4.88 runs: 3
8k-0-limit/rework min: 1115.76 [348.1%] max: 1165.66 [351.0%] avg: 1132.65 [348.0%] std: 23.34 runs: 3
8k-0-limit/reworkoptim: min: 403.75 [126.0%] max: 409.22 [123.2%] avg: 406.16 [124.8%] std: 2.28 runs: 3
Elapsed
8k-0-limit/base: min: 475.48 max: 585.19 avg: 525.54 std: 45.30 runs: 3
8k-0-limit/rework min: 616.25 [129.6%] max: 625.90 [107.0%] avg: 620.68 [118.1%] std: 3.98 runs: 3
8k-0-limit/reworkoptim: min: 420.18 [88.4%] max: 428.28 [73.2%] avg: 423.05 [80.5%] std: 3.71 runs: 3
Apart from 8k the system time is comparable with the base kernel while
Elapsed is up to 20% better with all configurations.
* No soft limit set
System
0-no-limit/base: min: 234.76 max: 237.42 avg: 236.25 std: 1.11 runs: 3
0-no-limit/rework min: 233.09 [99.3%] max: 238.65 [100.5%] avg: 236.09 [99.9%] std: 2.29 runs: 3
0-no-limit/reworkoptim: min: 236.12 [100.6%] max: 240.53 [101.3%] avg: 237.94 [100.7%] std: 1.88 runs: 3
Elapsed
0-no-limit/base: min: 288.52 max: 295.42 avg: 291.29 std: 2.98 runs: 3
0-no-limit/rework min: 283.17 [98.1%] max: 284.33 [96.2%] avg: 283.78 [97.4%] std: 0.48 runs: 3
0-no-limit/reworkoptim: min: 288.50 [100.0%] max: 290.79 [98.4%] avg: 289.78 [99.5%] std: 0.95 runs: 3
System
0.5k-no-limit/base: min: 286.51 max: 293.23 avg: 290.21 std: 2.78 runs: 3
0.5k-no-limit/rework min: 291.69 [101.8%] max: 294.38 [100.4%] avg: 292.97 [101.0%] std: 1.10 runs: 3
0.5k-no-limit/reworkoptim: min: 277.05 [96.7%] max: 288.76 [98.5%] avg: 284.17 [97.9%] std: 5.11 runs: 3
Elapsed
0.5k-no-limit/base: min: 294.94 max: 298.92 avg: 296.47 std: 1.75 runs: 3
0.5k-no-limit/rework min: 292.55 [99.2%] max: 294.21 [98.4%] avg: 293.55 [99.0%] std: 0.72 runs: 3
0.5k-no-limit/reworkoptim: min: 294.41 [99.8%] max: 301.67 [100.9%] avg: 297.78 [100.4%] std: 2.99 runs: 3
System
2k-no-limit/base: min: 443.41 max: 466.66 avg: 457.66 std: 10.19 runs: 3
2k-no-limit/rework min: 490.11 [110.5%] max: 516.02 [110.6%] avg: 501.42 [109.6%] std: 10.83 runs: 3
2k-no-limit/reworkoptim: min: 435.25 [98.2%] max: 458.11 [98.2%] avg: 446.73 [97.6%] std: 9.33 runs: 3
Elapsed
2k-no-limit/base: min: 330.85 max: 333.75 avg: 332.52 std: 1.23 runs: 3
2k-no-limit/rework min: 343.06 [103.7%] max: 349.59 [104.7%] avg: 345.95 [104.0%] std: 2.72 runs: 3
2k-no-limit/reworkoptim: min: 330.01 [99.7%] max: 333.92 [100.1%] avg: 332.22 [99.9%] std: 1.64 runs: 3
System
8k-no-limit/base: min: 1175.64 max: 1259.38 avg: 1222.39 std: 34.88 runs: 3
8k-no-limit/rework min: 1226.31 [104.3%] max: 1241.60 [98.6%] avg: 1233.74 [100.9%] std: 6.25 runs: 3
8k-no-limit/reworkoptim: min: 1023.45 [87.1%] max: 1056.74 [83.9%] avg: 1038.92 [85.0%] std: 13.69 runs: 3
Elapsed
8k-no-limit/base: min: 613.36 max: 619.60 avg: 616.47 std: 2.55 runs: 3
8k-no-limit/rework min: 627.56 [102.3%] max: 642.33 [103.7%] avg: 633.44 [102.8%] std: 6.39 runs: 3
8k-no-limit/reworkoptim: min: 545.89 [89.0%] max: 555.36 [89.6%] avg: 552.06 [89.6%] std: 4.37 runs: 3
and these numbers look good as well. System time is around 100%
(suprisingly better for the 8k case) and Elapsed is copies that trend.
The caller of the iterator might know that some nodes or even subtrees
should be skipped but there is no way to tell iterators about that so the
only choice left is to let iterators to visit each node and do the
selection outside of the iterating code. This, however, doesn't scale
well with hierarchies with many groups where only few groups are
interesting.
This patch adds mem_cgroup_iter_cond variant of the iterator with a
callback which gets called for every visited node. There are three
possible ways how the callback can influence the walk. Either the node is
visited, it is skipped but the tree walk continues down the tree or the
whole subtree of the current group is skipped.
[hughd@google.com: fix memcg-less page reclaim]
Soft reclaim has been done only for the global reclaim (both background
and direct). Since "memcg: integrate soft reclaim tighter with zone
shrinking code" there is no reason for this limitation anymore as the soft
limit reclaim doesn't use any special code paths and it is a part of the
zone shrinking code which is used by both global and targeted reclaims.
From the semantic point of view it is natural to consider soft limit
before touching all groups in the hierarchy tree which is touching the
hard limit because soft limit tells us where to push back when there is a
memory pressure. It is not important whether the pressure comes from the
limit or imbalanced zones.
This patch simply enables soft reclaim unconditionally in
mem_cgroup_should_soft_reclaim so it is enabled for both global and
targeted reclaim paths. mem_cgroup_soft_reclaim_eligible needs to learn
about the root of the reclaim to know where to stop checking soft limit
state of parents up the hierarchy. Say we have
A (over soft limit)
B (below s.l., hit the hard limit)
C D (below s.l.)
B is the source of the outside memory pressure now for D but we shouldn't
soft reclaim it because it is behaving well under B subtree and we can
still reclaim from C (pressumably it is over the limit).
mem_cgroup_soft_reclaim_eligible should therefore stop climbing up the
hierarchy at B (root of the memory pressure).
Reviewed-by: Glauber Costa <glommer@openvz.org>
Reviewed-by: Tejun Heo <tj@kernel.org>
Now that the soft limit is integrated to the reclaim directly the whole
soft-limit tree infrastructure is not needed anymore. Rip it out.
This patchset is sitting out of tree for quite some time without any
objections. I would be really happy if it made it into 3.12. I do not
want to push it too hard but I think this work is basically ready and
waiting more doesn't help.
The basic idea is quite simple. Pull soft reclaim into shrink_zone in the
first step and get rid of the previous soft reclaim infrastructure.
shrink_zone is done in two passes now. First it tries to do the soft
limit reclaim and it falls back to reclaim-all mode if no group is over
the limit or no pages have been scanned. The second pass happens at the
same priority so the only time we waste is the memcg tree walk which has
been updated in the third step to have only negligible overhead.
As a bonus we will get rid of a _lot_ of code by this and soft reclaim
will not stand out like before when it wasn't integrated into the zone
shrinking code and it reclaimed at priority 0 (the testing results show
that some workloads suffers from such an aggressive reclaim). The clean
up is in a separate patch because I felt it would be easier to review that
way.
The second step is soft limit reclaim integration into targeted reclaim.
It should be rather straight forward. Soft limit has been used only for
the global reclaim so far but it makes sense for any kind of pressure
coming from up-the-hierarchy, including targeted reclaim.
The third step (patches 4-8) addresses the tree walk overhead by enhancing
memcg iterators to enable skipping whole subtrees and tracking number of
over soft limit children at each level of the hierarchy. This information
is updated same way the old soft limit tree was updated (from
memcg_check_events) so we shouldn't see an additional overhead. In fact
mem_cgroup_update_soft_limit is much simpler than tree manipulation done
previously.
__shrink_zone uses mem_cgroup_soft_reclaim_eligible as a predicate for
mem_cgroup_iter so the decision whether a particular group should be
visited is done at the iterator level which allows us to decide to skip
the whole subtree as well (if there is no child in excess). This reduces
the tree walk overhead considerably.
* TEST 1
My primary test case was a parallel kernel build with 2 groups (make is
running with -j8 with a distribution .config in a separate cgroup without
any hard limit) on a 32 CPU machine booted with 1GB memory and both builds
run taskset to Node 0 cpus.
I was mostly interested in 2 setups. Default - no soft limit set and -
and 0 soft limit set to both groups. The first one should tell us whether
the rework regresses the default behavior while the second one should show
us improvements in an extreme case where both workloads are always over
the soft limit.
/usr/bin/time -v has been used to collect the statistics and each
configuration had 3 runs after fresh boot without any other load on the
system.
base is mmotm-2013-07-18-16-40
rework all 8 patches applied on top of base
* No-limit
User
no-limit/base: min: 651.92 max: 672.65 avg: 664.33 std: 8.01 runs: 6
no-limit/rework: min: 657.34 [100.8%] max: 668.39 [99.4%] avg: 663.13 [99.8%] std: 3.61 runs: 6
System
no-limit/base: min: 69.33 max: 71.39 avg: 70.32 std: 0.79 runs: 6
no-limit/rework: min: 69.12 [99.7%] max: 71.05 [99.5%] avg: 70.04 [99.6%] std: 0.59 runs: 6
Elapsed
no-limit/base: min: 398.27 max: 422.36 avg: 408.85 std: 7.74 runs: 6
no-limit/rework: min: 386.36 [97.0%] max: 438.40 [103.8%] avg: 416.34 [101.8%] std: 18.85 runs: 6
The results are within noise. Elapsed time has a bigger variance but the
average looks good.
* 0-limit
User
0-limit/base: min: 573.76 max: 605.63 avg: 585.73 std: 12.21 runs: 6
0-limit/rework: min: 645.77 [112.6%] max: 666.25 [110.0%] avg: 656.97 [112.2%] std: 7.77 runs: 6
System
0-limit/base: min: 69.57 max: 71.13 avg: 70.29 std: 0.54 runs: 6
0-limit/rework: min: 68.68 [98.7%] max: 71.40 [100.4%] avg: 69.91 [99.5%] std: 0.87 runs: 6
Elapsed
0-limit/base: min: 1306.14 max: 1550.17 avg: 1430.35 std: 90.86 runs: 6
0-limit/rework: min: 404.06 [30.9%] max: 465.94 [30.1%] avg: 434.81 [30.4%] std: 22.68 runs: 6
The improvement is really huge here (even bigger than with my previous
testing and I suspect that this highly depends on the storage). Page
fault statistics tell us at least part of the story:
Minor
0-limit/base: min: 37180461.00 max: 37319986.00 avg: 37247470.00 std: 54772.71 runs: 6
0-limit/rework: min: 36751685.00 [98.8%] max: 36805379.00 [98.6%] avg: 36774506.33 [98.7%] std: 17109.03 runs: 6
Major
0-limit/base: min: 170604.00 max: 221141.00 avg: 196081.83 std: 18217.01 runs: 6
0-limit/rework: min: 2864.00 [1.7%] max: 10029.00 [4.5%] avg: 5627.33 [2.9%] std: 2252.71 runs: 6
Same as with my previous testing Minor faults are more or less within
noise but Major fault count is way bellow the base kernel.
While this looks as a nice win it is fair to say that 0-limit
configuration is quite artificial. So I was playing with 0-no-limit
loads as well.
* TEST 2
The following results are from 2 groups configuration on a 16GB machine
(single NUMA node).
- A running stream IO (dd if=/dev/zero of=local.file bs=1024) with
2*TotalMem with 0 soft limit.
- B running a mem_eater which consumes TotalMem-1G without any limit. The
mem_eater consumes the memory in 100 chunks with 1s nap after each
mmap+poppulate so that both loads have chance to fight for the memory.
The expected result is that B shouldn't be reclaimed and A shouldn't see
a big dropdown in elapsed time.
User
base: min: 2.68 max: 2.89 avg: 2.76 std: 0.09 runs: 3
rework: min: 3.27 [122.0%] max: 3.74 [129.4%] avg: 3.44 [124.6%] std: 0.21 runs: 3
System
base: min: 86.26 max: 88.29 avg: 87.28 std: 0.83 runs: 3
rework: min: 81.05 [94.0%] max: 84.96 [96.2%] avg: 83.14 [95.3%] std: 1.61 runs: 3
Elapsed
base: min: 317.28 max: 332.39 avg: 325.84 std: 6.33 runs: 3
rework: min: 281.53 [88.7%] max: 298.16 [89.7%] avg: 290.99 [89.3%] std: 6.98 runs: 3
System time improved slightly as well as Elapsed. My previous testing
has shown worse numbers but this again seem to depend on the storage
speed.
My theory is that the writeback doesn't catch up and prio-0 soft reclaim
falls into wait on writeback page too often in the base kernel. The
patched kernel doesn't do that because the soft reclaim is done from the
kswapd/direct reclaim context. This can be seen on the following graph
nicely. The A's group usage_in_bytes regurarly drops really low very often.
All 3 runs
http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/stream.png
resp. a detail of the single run
http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/stream-one-run.png
mem_eater seems to be doing better as well. It gets to the full
allocation size faster as can be seen on the following graph:
http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/mem_eater-one-run.png
/proc/meminfo collected during the test also shows that rework kernel
hasn't swapped that much (well almost not at all):
base: max: 123900 K avg: 56388.29 K
rework: max: 300 K avg: 128.68 K
kswapd and direct reclaim statistics are of no use unfortunatelly because
soft reclaim is not accounted properly as the counters are hidden by
global_reclaim() checks in the base kernel.
* TEST 3
Another test was the same configuration as TEST2 except the stream IO was
replaced by a single kbuild (16 parallel jobs bound to Node0 cpus same as
in TEST1) and mem_eater allocated TotalMem-200M so kbuild had only 200MB
left.
Kbuild did better with the rework kernel here as well:
User
base: min: 860.28 max: 872.86 avg: 868.03 std: 5.54 runs: 3
rework: min: 880.81 [102.4%] max: 887.45 [101.7%] avg: 883.56 [101.8%] std: 2.83 runs: 3
System
base: min: 84.35 max: 85.06 avg: 84.79 std: 0.31 runs: 3
rework: min: 85.62 [101.5%] max: 86.09 [101.2%] avg: 85.79 [101.2%] std: 0.21 runs: 3
Elapsed
base: min: 135.36 max: 243.30 avg: 182.47 std: 45.12 runs: 3
rework: min: 110.46 [81.6%] max: 116.20 [47.8%] avg: 114.15 [62.6%] std: 2.61 runs: 3
Minor
base: min: 36635476.00 max: 36673365.00 avg: 36654812.00 std: 15478.03 runs: 3
rework: min: 36639301.00 [100.0%] max: 36695541.00 [100.1%] avg: 36665511.00 [100.0%] std: 23118.23 runs: 3
Major
base: min: 14708.00 max: 53328.00 avg: 31379.00 std: 16202.24 runs: 3
rework: min: 302.00 [2.1%] max: 414.00 [0.8%] avg: 366.33 [1.2%] std: 47.22 runs: 3
Again we can see a significant improvement in Elapsed (it also seems to
be more stable), there is a huge dropdown for the Major page faults and
much more swapping:
base: max: 583736 K avg: 112547.43 K
rework: max: 4012 K avg: 124.36 K
Graphs from all three runs show the variability of the kbuild quite
nicely. It even seems that it took longer after every run with the base
kernel which would be quite surprising as the source tree for the build is
removed and caches are dropped after each run so the build operates on a
freshly extracted sources everytime.
http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/kbuild-mem_eater.png
My other testing shows that this is just a matter of timing and other runs
behave differently the std for Elapsed time is similar ~50. Example of
other three runs:
http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/kbuild-mem_eater2.png
So to wrap this up. The series is still doing good and improves the soft
limit.
The testing results for bunch of cgroups with both stream IO and kbuild
loads can be found in "memcg: track children in soft limit excess to
improve soft limit".
This patch:
Memcg soft reclaim has been traditionally triggered from the global
reclaim paths before calling shrink_zone. mem_cgroup_soft_limit_reclaim
then picked up a group which exceeds the soft limit the most and reclaimed
it with 0 priority to reclaim at least SWAP_CLUSTER_MAX pages.
The infrastructure requires per-node-zone trees which hold over-limit
groups and keep them up-to-date (via memcg_check_events) which is not cost
free. Although this overhead hasn't turned out to be a bottle neck the
implementation is suboptimal because mem_cgroup_update_tree has no idea
which zones consumed memory over the limit so we could easily end up
having a group on a node-zone tree having only few pages from that
node-zone.
This patch doesn't try to fix node-zone trees management because it seems
that integrating soft reclaim into zone shrinking sounds much easier and
more appropriate for several reasons. First of all 0 priority reclaim was
a crude hack which might lead to big stalls if the group's LRUs are big
and hard to reclaim (e.g. a lot of dirty/writeback pages). Soft reclaim
should be applicable also to the targeted reclaim which is awkward right
now without additional hacks. Last but not least the whole infrastructure
eats quite some code.
After this patch shrink_zone is done in 2 passes. First it tries to do
the soft reclaim if appropriate (only for global reclaim for now to keep
compatible with the original state) and fall back to ignoring soft limit
if no group is eligible to soft reclaim or nothing has been scanned during
the first pass. Only groups which are over their soft limit or any of
their parents up the hierarchy is over the limit are considered eligible
during the first pass.
Soft limit tree which is not necessary anymore will be removed in the
follow up patch to make this patch smaller and easier to review.
Cc: Glauber Costa <glommer@gmail.com>
vfs guarantees the cgroup won't be destroyed, so it's redundant to get a
css reference.
Signed-off-by: Li Zefan <lizefan@huawei.com>
This reverts the Linux for Workgroups thing. And no, before somebody
asks, we're not doing Linux95. Not for a few years, at least.
Sure, the flag added some color to the logo, and could have remained as
a testament to my leet gimp skills. But no. And I'll do this early, to
avoid the chance of forgetting when I'm doing the actual rc1 release on
the road.
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs
Pull eCryptfs fixes from Tyler Hicks:
"Two small fixes to the code that initializes the per-file crypto
contexts"
* tag 'ecryptfs-3.12-rc1-crypt-ctx' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs:
ecryptfs: avoid ctx initialization race
ecryptfs: remove check for if an array is NULL
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull DMA-mapping fix from Marek Szyprowski:
"A build bugfix for the device tree support for reserved memory
regions. Due to superfluous include the common code failed to build
on ARM64 and MIPS architectures.
The patch that caused the build break has lived at linux-next for
about two weeks and noone noticed the issue, what convinced me that
everything was ok"
* 'for-v3.12-fix' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
drivers: of: fix build break if asm/dma-contiguous.h is missing
Pull dma-buf updates from Sumit Semwal:
"Yet another small one - dma-buf framework now supports size discovery
of the buffer via llseek"
* tag 'for-3.12' of git://git.linaro.org/people/sumitsemwal/linux-dma-buf:
dma-buf: Expose buffer size to userspace (v2)
dma-buf: Check return value of anon_inode_getfile
Merge first patch-bomb from Andrew Morton:
- Some pidns/fork/exec tweaks
- OCFS2 updates
- Most of MM - there remain quite a few memcg parts which depend on
pending core cgroups changes. Which might have been already merged -
I'll check tomorrow...
- Various misc stuff all over the place
- A few block bits which I never got around to sending to Jens -
relatively minor things.
- MAINTAINERS maintenance
- A small number of lib/ updates
- checkpatch updates
- epoll
- firmware/dmi-scan
- Some kprobes work for S390
- drivers/rtc updates
- hfsplus feature work
- vmcore feature work
- rbtree upgrades
- AOE updates
- pktcdvd cleanups
- PPS
- memstick
- w1
- New "inittmpfs" feature, which does the obvious
- More IPC work from Davidlohr.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (303 commits)
lz4: fix compression/decompression signedness mismatch
ipc: drop ipc_lock_check
ipc, shm: drop shm_lock_check
ipc: drop ipc_lock_by_ptr
ipc, shm: guard against non-existant vma in shmdt(2)
ipc: document general ipc locking scheme
ipc,msg: drop msg_unlock
ipc: rename ids->rw_mutex
ipc,shm: shorten critical region for shmat
ipc,shm: cleanup do_shmat pasta
ipc,shm: shorten critical region for shmctl
ipc,shm: make shmctl_nolock lockless
ipc,shm: introduce shmctl_nolock
ipc: drop ipcctl_pre_down
ipc,shm: shorten critical region in shmctl_down
ipc,shm: introduce lockless functions to obtain the ipc object
initmpfs: use initramfs if rootfstype= or root= specified
initmpfs: make rootfs use tmpfs when CONFIG_TMPFS enabled
initmpfs: move rootfs code from fs/ramfs/ to init/
initmpfs: move bdi setup from init_rootfs to init_ramfs
LZ4 compression and decompression functions require different in
signedness input/output parameters: unsigned char for compression and
signed char for decompression.
Change decompression API to require "(const) unsigned char *".
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Kyungsik Lee <kyungsik.lee@lge.com>
Cc: Yann Collet <yann.collet.73@gmail.com>
No remaining users, we now use ipc_obtain_object_check().
Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
This function was replaced by a the lockless shm_obtain_object_check(),
and no longer has any users.
After previous cleanups and optimizations, this function is no longer
heavily used and we don't have a good reason to keep it. Update the few
remaining callers and get rid of it.
When !CONFIG_MMU there's a chance we can derefence a NULL pointer when the
VM area isn't found - check the return value of find_vma().
Also, remove the redundant -EINVAL return: retval is set to the proper
return code and *only* changed to 0, when we actually unmap the segments.
As suggested by Andrew, add a generic initial locking scheme used
throughout all sysv ipc mechanisms. Documenting the ids rwsem, how rcu
can be enough to do the initial checks and when to actually acquire the
kern_ipc_perm.lock spinlock.
I found that adding it to util.c was generic enough.
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
There is only one user left, drop this function and just call
ipc_unlock_object() and rcu_read_unlock().
Since in some situations the lock can be shared for readers, we shouldn't
be calling it a mutex, rename it to rwsem.
Similar to other system calls, acquire the kern_ipc_perm lock after doing
the initial permission and security checks.
[sasha.levin@oracle.com: dont leave do_shmat with rcu lock held]
Clean up some of the messy do_shmat() spaghetti code, getting rid of
out_free and out_put_dentry labels. This makes shortening the critical
region of this function in the next patch a little easier to do and read.
With the *_INFO, *_STAT, IPC_RMID and IPC_SET commands already optimized,
deal with the remaining SHM_LOCK and SHM_UNLOCK commands. Take the
shm_perm lock after doing the initial auditing and security checks. The
rest of the logic remains unchanged.
While the INFO cmd doesn't take the ipc lock, the STAT commands do acquire
it unnecessarily. We can do the permissions and security checks only
holding the rcu lock.
Similar to semctl and msgctl, when calling msgctl, the *_INFO and *_STAT
commands can be performed without acquiring the ipc object.
Add a shmctl_nolock() function and move the logic of *_INFO and *_STAT out
of msgctl(). Since we are just moving functionality, this change still
takes the lock and it will be properly lockless in the next patch.
Now that sem, msgque and shm, through *_down(), all use the lockless
variant of ipcctl_pre_down(), go ahead and delete it.
[akpm@linux-foundation.org: fix function name in kerneldoc, cleanups]
Instead of holding the ipc lock for the entire function, use the
ipcctl_pre_down_nolock and only acquire the lock for specific commands:
RMID and SET.
This is the third and final patchset that deals with reducing the amount
of contention we impose on the ipc lock (kern_ipc_perm.lock). These
changes mostly deal with shared memory, previous work has already been
done for semaphores and message queues:
http://lkml.org/lkml/2013/3/20/546 (sems)
http://lkml.org/lkml/2013/5/15/584 (mqueues)
With these patches applied, a custom shm microbenchmark stressing shmctl
doing IPC_STAT with 4 threads a million times, reduces the execution
time by 50%. A similar run, this time with IPC_SET, reduces the
execution time from 3 mins and 35 secs to 27 seconds.
Patches 1-8: replaces blindly taking the ipc lock for a smarter
combination of rcu and ipc_obtain_object, only acquiring the spinlock
when updating.
Patch 9: renames the ids rw_mutex to rwsem, which is what it already was.
Patch 10: is a trivial mqueue leftover cleanup
Patch 11: adds a brief lock scheme description, requested by Andrew.
This patch:
Add shm_obtain_object() and shm_obtain_object_check(), which will allow us
to get the ipc object without acquiring the lock. Just as with other
forms of ipc, these functions are basically wrappers around
ipc_obtain_object*().
Command line option rootfstype=ramfs to obtain old initramfs behavior, and
use ramfs instead of tmpfs for stub when root= defined (for cosmetic
reasons).
Signed-off-by: Rob Landley <rob@landley.net>
Cc: Jeff Layton <jlayton@redhat.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Jim Cromie <jim.cromie@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Conditionally call the appropriate fs_init function and fill_super
functions. Add a use once guard to shmem_init() to simply succeed on a
second call.
(Note that IS_ENABLED() is a compile time constant so dead code
elimination removes unused function calls when CONFIG_TMPFS is disabled.)
When the rootfs code was a wrapper around ramfs, having them in the same
file made sense. Now that it can wrap another filesystem type, move it in
with the init code instead.
This also allows a subsequent patch to access rootfstype= command line
arg.
Even though ramfs hasn't got a backing device, commit e0bf68ddec4f ("mm:
bdi init hooks") added one anyway, and put the initialization in
init_rootfs() since that's the first user, leaving it out of init_ramfs()
to avoid duplication.
But initmpfs uses init_tmpfs() instead, so move the init into the
filesystem's init function, add a "once" guard to prevent duplicate
initialization, and call the filesystem init from rootfs init.
This goes part of the way to allowing ramfs to be built as a module.
[akpm@linux-foundation.org; using bit 1 was odd]
Mounting MS_NOUSER prevents --bind mounts from rootfs. Prevent new rootfs
mounts with a different mechanism that doesn't affect bind mounts.
With users of radix_tree_preload() run from interrupt (block/blk-ioc.c is
one such possible user), the following race can happen:
radix_tree_insert()
radix_tree_node_alloc()
if (rtp->nr) {
ret = rtp->nodes[rtp->nr - 1];
<interrupt>
radix_tree_insert()
if (rtp->nr) {
And we give out one radix tree node twice. That clearly results in radix
tree corruption with different results (usually OOPS) depending on which
two users of radix tree race.
We fix the problem by making radix_tree_node_alloc() always allocate fresh
radix tree nodes when in interrupt. Using preloading when in interrupt
doesn't make sense since all the allocations have to be atomic anyway and
we cannot steal nodes from process-context users because some users rely
on radix_tree_insert() succeeding after radix_tree_preload().
in_interrupt() check is somewhat ugly but we cannot simply key off passed
gfp_mask as that is acquired from root_gfp_mask() and thus the same for
all preload users.
Another part of the fix is to avoid node preallocation in
radix_tree_preload() when passed gfp_mask doesn't allow waiting. Again,
preallocation in such case doesn't make sense and when preallocation would
happen in interrupt we could possibly leak some allocated nodes. However,
some users of radix_tree_preload() require following radix_tree_insert()
to succeed. To avoid unexpected effects for these users,
radix_tree_preload() only warns if passed gfp mask doesn't allow waiting
and we provide a new function radix_tree_maybe_preload() for those users
which get different gfp mask from different call sites and which are
prepared to handle radix_tree_insert() failure.
Cc: Jens Axboe <jaxboe@fusionio.com>
The driver core clears the driver data to NULL after device_release or on
probe failure. Thus, it is not needed to manually clear the device driver
data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Cc: Evgeniy Polyakov <zbr@ioremap.net>
Cc: Greg KH <greg@kroah.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
