commit 1a88f809ccb5db1509a7514b187c00b3a995fc82 upstream.
The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus
width declared in the Device Tree being considered as a 16 bits bus
width when configuring the hardware.
This bug in mvebu-devbus driver was compensated by a symetric mistake
in the Armada XP GP Device Tree: a 8 bits bus width was declared, even
though the hardware actually has a 16 bits bus width connection with
the NOR flash.
Now that we have fixed the mvebu-devbus driver to behave according to
its Device Tree binding, this commit fixes the problematic Device Tree
files as well.
This bug was introduced in commit
da8d1b38356853c37116f9afa29f15648d7fb159 ('ARM: mvebu: Add support for
NOR flash device on Armada XP-GP board') which was merged in v3.10.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1397489361-5833-3-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: da8d1b383568 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board')
Cc: stable@vger.kernel.org # v3.10+
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit c98235cb8584a72e95786e17d695a8e5fafcd766 upstream.
The mlx4 driver is triggering schedules while atomic inside
mlx4_en_netpoll:
spin_lock_irqsave(&cq->lock, flags);
napi_synchronize(&cq->napi);
^^^^^ msleep here
mlx4_en_process_rx_cq(dev, cq, 0);
spin_unlock_irqrestore(&cq->lock, flags);
This was part of a patch by Alexander Guller from Mellanox in 2011,
but it still isn't upstream.
Signed-off-by: Chris Mason <clm@fb.com>
Acked-By: Amir Vadai <amirv@mellanox.com>
Cc: Masoud Sharbiani <msharbiani@twitter.com>
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream.
The kernel has no concept of capabilities with respect to inodes; inodes
exist independently of namespaces. For example, inode_capable(inode,
CAP_LINUX_IMMUTABLE) would be nonsense.
This patch changes inode_capable to check for uid and gid mappings and
renames it to capable_wrt_inode_uidgid, which should make it more
obvious what it does.
Fixes CVE-2014-4014.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
commit a8951d5814e1373807a94f79f7ccec7041325470 upstream.
Dst is released one line before we access it again with dst->error.
Fixes: 58e35d147128 netfilter: ipv6: propagate routing errors from
ip6_route_me_harder()
Signed-off-by: Sergey Popovich <popovich_sergei@mail.ru>
commit 5f5092e72cc25a6a5785308270e0085b2b2772cc upstream.
Since we indirect all of our PMU IRQ handling through a dispatcher, it's
trivial to hook up perf_sample_event_took to prevent applications such
as oprofile from generating interrupt storms due to an unrealisticly
low sample period.
Reported-by: Robert Richter <rric@kernel.org>
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
commit 723478c8a471403c53cf144999701f6e0c4bbd11 upstream.
/proc/sys/kernel/perf_event_max_sample_rate will accept
negative values as well as 0.
Negative values are unreasonable, and 0 causes a
divide by zero exception in perf_proc_update_handler.
This patch enforces a lower limit of 1.
Signed-off-by: Knut Petersen <Knut_Petersen@t-online.de>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/5242DB0C.4070005@t-online.de
commit e5302920da9ef23f9d19d4e9ac85704cc25bee7a upstream.
This patch fixes a serious bug in:
14c63f17b1fd perf: Drop sample rate when sampling is too slow
There was an misunderstanding on the API of the do_div()
macro. It returns the remainder of the division and this
was not what the function expected leading to disabling the
interrupt latency watchdog.
This patch also remove a duplicate assignment in
perf_sample_event_took().
Signed-off-by: Stephane Eranian <eranian@google.com>
Cc: peterz@infradead.org
Cc: dave.hansen@linux.intel.com
Cc: ak@linux.intel.com
Cc: jolsa@redhat.com
Link: http://lkml.kernel.org/r/20130704223010.GA30625@quad
commit 14c63f17b1fde5a575a28e96547a22b451c71fb5 upstream.
This patch keeps track of how long perf's NMI handler is taking,
and also calculates how many samples perf can take a second. If
the sample length times the expected max number of samples
exceeds a configurable threshold, it drops the sample rate.
This way, we don't have a runaway sampling process eating up the
CPU.
This patch can tend to drop the sample rate down to level where
perf doesn't work very well. *BUT* the alternative is that my
system hangs because it spends all of its time handling NMIs.
I'll take a busted performance tool over an entire system that's
busted and undebuggable any day.
BTW, my suspicion is that there's still an underlying bug here.
Using the HPET instead of the TSC is definitely a contributing
factor, but I suspect there are some other things going on.
But, I can't go dig down on a bug like that with my machine
hanging all the time.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: paulus@samba.org
Cc: acme@ghostprotocols.net
Cc: Dave Hansen <dave@sr71.net>
[ Prettified it a bit. ]
commit 6cc44a6fb46e1ecc1c28125aa8fa34d317aa9ea7 upstream.
This patch addresses a bug where an early exception for SCSI WRITE
with ImmediateData=Yes was missing the target_put_sess_cmd() call
to drop the extra se_cmd->cmd_kref reference obtained during the
normal iscsit_setup_scsi_cmd() codepath execution.
This bug was manifesting itself during session shutdown within
isert_cq_rx_comp_err() where target_wait_for_sess_cmds() would
end up waiting indefinately for the last se_cmd->cmd_kref put to
occur for the failed SCSI WRITE + ImmediateData descriptors.
This fix follows what traditional iscsi-target code already does
for the same failure case within iscsit_get_immediate_data().
Reported-by: Sagi Grimberg <sagig@dev.mellanox.co.il>
Cc: Sagi Grimberg <sagig@dev.mellanox.co.il>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
commit 624483f3ea82598ab0f62f1bdb9177f531ab1892 upstream.
While working address sanitizer for kernel I've discovered
use-after-free bug in __put_anon_vma.
For the last anon_vma, anon_vma->root freed before child anon_vma.
Later in anon_vma_free(anon_vma) we are referencing to already freed
anon_vma->root to check rwsem.
This fixes it by freeing the child anon_vma before freeing
anon_vma->root.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit 8ef42ddd9a53b73e6fc3934278710c27f80f324f upstream.
Not all host controller drivers have bus-suspend and bus-resume
methods. When one doesn't, it will cause problems if runtime PM is
enabled in the kernel. The PM core will attempt to suspend the
controller's root hub, the suspend will fail because there is no
bus-suspend routine, and a -EBUSY error code will be returned to the
PM core. This will cause the suspend attempt to be repeated shortly
thereafter, in a never-ending loop.
Part of the problem is that the original error code -ENOENT gets
changed to -EBUSY in usb_runtime_suspend(), on the grounds that the PM
core will interpret -ENOENT as meaning that the root hub has gotten
into a runtime-PM error state. While this change is appropriate for
real USB devices, it's not such a good idea for a root hub. In fact,
considering the root hub to be in a runtime-PM error state would not
be far from the truth. Therefore this patch updates
usb_runtime_suspend() so that it adjusts error codes only for
non-root-hub devices.
Furthermore, the patch attempts to prevent the problem from occurring
in the first place by not enabling runtime PM by default for root hubs
whose host controller driver doesn't have bus_suspend and bus_resume
methods.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Will Deacon <will.deacon@arm.com>
Tested-by: Will Deacon <will.deacon@arm.com>
commit c03890ff5e24a4bf59059f2d179f427559b7330a upstream.
A recent patch that purported to fix firmware download on big-endian
machines failed to add the corresponding sparse annotation to the
i2c-header. This was reported by the kbuild test robot.
Adding the appropriate annotation revealed another endianess bug related
to the i2c-header Size-field in a code path that is exercised when the
firmware is actually being downloaded (and not just verified and left
untouched unless older than the firmware at hand).
This patch adds the required sparse annotation to the i2c-header and
makes sure that the Size-field is sent in little-endian byte order
during firmware download also on big-endian machines.
Note that this patch is only compile-tested, but that there is no
functional change for little-endian systems.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Cc: Ludovic Drolez <ldrolez@debian.org>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 8a61ba3a47ac39f660702aa66a172185dd605a86 upstream.
Adds product ID for the Novatel E371 PCI Express Mini Card.
$ lsusb
Bus 001 Device 024: ID 1410:9011 Novatel Wireless
$ usb-devices
T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 24 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1410 ProdID=9011 Rev=00.03
S: Manufacturer=Novatel Wireless, Inc.
S: Product=Novatel Wireless HSPA
S: SerialNumber=012773002115811
C: #Ifs= 6 Cfg#= 1 Atr=e0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 6 Alt= 0 #EPs= 1 Cls=02(commc) Sub=06 Prot=00 Driver=cdc_ether
I: If#= 7 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
Tested with kernel 3.2.0.
Signed-off-by: Alexej Starschenko <starschenko@gmail.com>
commit 7ac3764fcafc06e72e1a79a9d998b9fdd900b2a6 upstream.
The file include/uapi/linux/usb/cdc-wdm.h uses a __u16 so it needs to
include types.h as well to make the build system happy.
Fixes: 3edce1cf813a ("USB: cdc-wdm: implement IOCTL_WDM_MAX_COMMAND")
Cc: Bjørn Mork <bjorn@mork.no>
commit 7d1896360f4d055d68565ef8ed56a677580f1a39 upstream.
The include/uapi/linux/usb/cdc-wdm.h header defines cdc-wdm
userspace APIs and should be exported by make headers_install.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit d0839d757e6294921c31b1c4ca4f1dcc5df63bcd upstream.
The NovaTech OrionLXm uses an onboard FTDI serial converter for JTAG and
console access.
Here is the lsusb output:
Bus 004 Device 123: ID 0403:7c90 Future Technology Devices
International, Ltd
Signed-off-by: George McCollister <george.mccollister@gmail.com>
commit 192a98e280e560510a62aca8cfa83b4ae7c095bb upstream.
The conversion to a fixup table for Replacer model with ALC260 in
commit 20f7d928 took the wrong widget NID for COEF setups. Namely,
NID 0x1a should have been used instead of NID 0x20, which is the
common node for all Realtek codecs but ALC260.
Fixes: 20f7d928fa6e ('ALSA: hda/realtek - Replace ALC260 model=replacer with the auto-parser')
commit e30cf2d2bed3aed74a651c64de323ba26e4ff7d0 upstream.
Correcion of wrong fixup entries add in commit ca8f0424 to replace
static model quirk for PB V7900 laptop (will model).
[note: the removal of ALC260_FIXUP_HP_PIN_0F chain is also needed as a
part of the fix; otherwise the pin is set up wrongly as a headphone,
and user-space (PulseAudio) may be wrongly trying to detect the jack
state -- tiwai]
Fixes: ca8f04247eaa ('ALSA: hda/realtek - Add the fixup codes for ALC260 model=will')
Signed-off-by: Ronan Marquet <ronan.marquet@orange.fr>
commit ffed54dced86723f352323f15789d9ad6bee25e1 upstream.
I got a patch from the original author, Fred Brooks, to add a small
settling delay after setting the AI channel multiplexor. The lack of
delay resulted in unstable or scrambled data on faster processors.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Reported-by: Fred Brooks <nsaspook@nsaspook.com>
commit d7500135802ca55b3f4e01a16544e8b34082f8c3 upstream.
Input is handled in softirq context, but when pasting we may
need to sleep. speakup_paste_selection() currently tries to
bodge this by busy-waiting if in_atomic(), but that doesn't
help because the ldisc may also sleep.
For bonus breakage, speakup_paste_selection() changes the
state of current, even though it's not running in process
context.
Move it into a work item and make sure to cancel it on exit.
References: https://bugs.debian.org/735202
References: https://bugs.debian.org/744015
Reported-by: Paul Gevers <elbrus@debian.org>
Reported-and-tested-by: Jarek Czekalski <jarekczek@poczta.onet.pl>
commit 5dc2808c4729bf080487e61b80ee04e0fdb12a37 upstream.
Lists of endpoints are stored for bandwidth calculation for roothub ports.
Make sure we remove all endpoints from the list before the whole device,
containing its endpoints list_head stuctures, is freed.
This used to be done in the wrong order in xhci_mem_cleanup(),
and triggered an oops in resume from S4 (hibernate).
Tested-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 2ac295a544dcae9299cba13ce250419117ae7fd1 upstream.
Commit 8313b8e57f55b15e5b7f7fc5d1630bbf686a9a97
md: fix problem when adding device to read-only array with bitmap.
added a called to md_reap_sync_thread() which cause a reshape thread
to be interrupted (in particular, it could cause md_thread() to never even
call md_do_sync()).
However it didn't set MD_RECOVERY_INTR so ->finish_reshape() would not
know that the reshape didn't complete.
This only happens when mddev->ro is set and normally reshape threads
don't run in that situation. But raid5 and raid10 can start a reshape
thread during "run" is the array is in the middle of a reshape.
They do this even if ->ro is set.
So it is best to set MD_RECOVERY_INTR before abortingg the
sync thread, just in case.
Though it rare for this to trigger a problem it can cause data corruption
because the reshape isn't finished properly.
So it is suitable for any stable which the offending commit was applied to.
(3.2 or later)
Fixes: 8313b8e57f55b15e5b7f7fc5d1630bbf686a9a97
Signed-off-by: NeilBrown <neilb@suse.de>
commit 3991b31ea072b070081ca3bfa860a077eda67de5 upstream.
If mddev->ro is set, md_to_sync will (correctly) abort.
However in that case MD_RECOVERY_INTR isn't set.
If a RESHAPE had been requested, then ->finish_reshape() will be
called and it will think the reshape was successful even though
nothing happened.
Normally a resync will not be requested if ->ro is set, but if an
array is stopped while a reshape is on-going, then when the array is
started, the reshape will be restarted. If the array is also set
read-only at this point, the reshape will instantly appear to success,
resulting in data corruption.
Consequently, this patch is suitable for any -stable kernel.
commit 9aab8bff7aa3bee567213ad3c1fdfb217bb980a2 upstream.
We only want to modifiy a single field in the userspace view of the
execbuffer command buffer, so explicitly change that rather than copy
everything back again.
This serves two purposes:
1. The single fields are much cheaper to copy (constant size so the
copy uses special case code) and much smaller than the whole array.
2. We modify the array for internal use that need to be masked from
the user.
Note: We need this backported since without it the next bugfix will
blow up when userspace recycles batchbuffers and relocations.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 6acbfb96976fc3350e30d964acb1dbbdf876d55e upstream.
Lai found that:
WARNING: CPU: 1 PID: 13 at arch/x86/kernel/smp.c:124 native_smp_send_reschedule+0x2d/0x4b()
migration_cpu_stop+0x1d/0x22
was caused by set_cpus_allowed_ptr() assuming that cpu_active_mask is
always a sub-set of cpu_online_mask.
This isn't true since 5fbd036b552f ("sched: Cleanup cpu_active madness").
So set active and online at the same time to avoid this particular
problem.
Fixes: 5fbd036b552f ("sched: Cleanup cpu_active madness")
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Gautham R. Shenoy <ego@linux.vnet.ibm.com>
Cc: Michael wang <wangyun@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Link: http://lkml.kernel.org/r/53758B12.8060609@cn.fujitsu.com
commit f1daa838e861ae1a0fb7cd9721a21258430fcc8c upstream.
The DM cache target cannot cope with discards that span multiple cache
blocks, so each discard bio that spans more than one cache block must
get split by the DM core.
Signed-off-by: Heinz Mauelshagen <heinzm@redhat.com>
Acked-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 537094b64b229bf3ad146042f83e74cf6abe59df upstream.
According to arm procedure call standart r2 register is call-cloberred.
So after the result of x expression was put into r2 any following
function call in p may overwrite r2. To fix this, the result of p
expression must be saved to the temporary variable before the
assigment x expression to __r2.
Reviewed-by: Nicolas Pitre <nico@linaro.org>
commit 4b353a706a86598ba47307c47301c3c428b79e09 upstream.
On OMAP4 panda board, there have been several bug reports about boot
hang and lock-ups with CPU_IDLE enabled. The root cause of the issue
is missing interrupts while in idle state. Commit cb7094e8 {cpuidle / omap4 :
use CPUIDLE_FLAG_TIMER_STOP flag} moved the broadcast notifiers to common
code for right reasons but on OMAP4 which suffers from a nasty ROM code
bug with GIC, commit ff999b8a {ARM: OMAP4460: Workaround for ROM bug ..},
we loose interrupts which leads to issues like lock-up, hangs etc.
Patch reverts commit cb7094 {cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP
flag} and 54769d6 {cpuidle: OMAP4: remove timer broadcast initialization} to
avoid the issue. With this change, OMAP4 panda boards, the mentioned
issues are getting fixed. We no longer loose interrupts which was the cause
of the regression.
Fixes: cb7094e8 (cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP flag)
Fixes: ff999b8a (cpuidle: OMAP4: remove timer broadcast initialization)
Cc: Roger Quadros <rogerq@ti.com>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Reported-tested-by: Roger Quadros <rogerq@ti.com>
Reported-tested-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
all OMAP3 platforms
commit 98d7e1aee6dd534f468993f8c6a1bc730d4cfa81 upstream.
Commit 7b2e1277598e4187c9be3e61fd9b0f0423f97986 ("ARM: OMAP3: clock:
Back-propagate rate change from cam_mclk to dpll4_m5") enabled clock
rate back-propagation from cam_mclk do dpll4_m5 on OMAP3630 only.
Perform back-propagation on other OMAP3 platforms as well.
Reported-by: Jean-Philippe François <jp.francois@cynove.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
commit d1d70e5dc2cfa9047bb935c41ba808ebb8135696 upstream.
If we fail to allocate struct platform_device pdev we
dereference it after the goto label err.
This bug was found using coccinelle.
Fixes: afa77ef (ARM: mx3: dynamically allocate "ipu-core" devices)
Signed-off-by: Emil Goode <emilgoode@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
commit d8ade3526b2aa0505132c404c05a38b73ea15490 upstream.
Newer PX systems have non-VGA pci class dGPUs. Update
the ATRM fetch method to handle those cases.
bug:
https://bugzilla.kernel.org/show_bug.cgi?id=75401
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Christian König <christian.koenig@amd.com>
commit 544092596e8ac269f70e70961b5e9381909c9b1e upstream.
Placing them exclusively into VRAM might not work all the time.
Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=78297
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit 0f1d360b2ee3a2a0f510d3f1bcd3f5ebe5d41265 upstream.
Fixes a LVDS bleed issue on Lenovo W530 that can occur under a
number of circumstances.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit ead82d6792ef5c600d535bca6ec50a4da14ff7c7 upstream.
The mapping from OF device IDs to platform device IDs is wrong.
TYPE_NCPXXWB473 is 0, TYPE_NCPXXWL333 is 1, so
ntc_thermistor_id[TYPE_NCPXXWB473] is { "ncp15wb473", TYPE_NCPXXWB473 }
while
ntc_thermistor_id[TYPE_NCPXXWL333] is { "ncp18wb473", TYPE_NCPXXWB473 }.
So the name is wrong for all but the "ntc,ncp15wb473" entry, and the
type is wrong for the "ntc,ncp15wl333" entry.
So map the entries by index, it is neither elegant nor robust but at
least it is correct.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Fixes: 9e8269de hwmon: (ntc_thermistor) Add DT with IIO support to NTC thermistor driver
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Cc: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
Cc: Doug Anderson <dianders@chromium.org>
commit 59cf4243e557aa64ab2ef51280454aa1f3828e14 upstream.
In commit 9e8269de, support was added for ntc_thermistor devices being
declared in the device tree and implemented on top of IIO. With that
change, a dependency was added to the ntc_thermistor driver:
depends on (!OF && !IIO) || (OF && IIO)
This construct has the drawback that the driver can no longer be
selected when OF is set and IIO isn't, nor when IIO is set and OF is
not. This is a regression for the original users of the driver.
As the new code depends on IIO and is useless without OF, include it
only if both are enabled, and set the dependencies accordingly. This
is clearer, more simple and more correct.
commit e60cbeedc48d80689c249ab5dcc3c31ad0452dea upstream.
Prior to commit 4266129964b8 ("[media] DocBook: Move all media docbook
stuff into its own directory") it was possible to build only a single
(or more) book(s) by calling, for example
make htmldocs DOCBOOKS=80211.xml
This now fails:
cp: target `.../Documentation/DocBook//media_api' is not a directory
Ignore errors from that copy to make this possible again.
Fixes: 4266129964b8 ("[media] DocBook: Move all media docbook stuff into its own directory")
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
commit 3e030ecc0fc7de10fd0da10c1c19939872a31717 upstream.
When a memory error happens on an in-use page or (free and in-use)
hugepage, the victim page is isolated with its refcount set to one.
When you try to unpoison it later, unpoison_memory() calls put_page()
for it twice in order to bring the page back to free page pool (buddy or
free hugepage list). However, if another memory error occurs on the
page which we are unpoisoning, memory_failure() returns without
releasing the refcount which was incremented in the same call at first,
which results in memory leak and unconsistent num_poisoned_pages
statistics. This patch fixes it.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit b69e63a45f2d96a0dfe930ed20385058d4574d2f upstream.
message is currently shown as:
Error:
You may not have permission to collect %sstats.
Consider tweaking /proc/sys/kernel/perf_event_paranoid:
Note the %sstats. With patch this becomes:
Error:
You may not have permission to collect stats.
Signed-off-by: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1369526040-1368-1-git-send-email-dsahern@gmail.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: xiakaixu <xiakaixu@huawei.com>
commit 46ce0fe97a6be7532ce6126bb26ce89fed81528c upstream.
When removing a (sibling) event we do:
raw_spin_lock_irq(&ctx->lock);
perf_group_detach(event);
raw_spin_unlock_irq(&ctx->lock);
<hole>
perf_remove_from_context(event);
Now, assuming the event is a sibling, it will be 'unreachable' for
things like ctx_sched_out() because that iterates the
groups->siblings, and we just unhooked the sibling.
So, if during <hole> we get ctx_sched_out(), it will miss the event
and not call event_sched_out() on it, leaving it programmed on the
PMU.
The subsequent perf_remove_from_context() call will find the ctx is
inactive and only call list_del_event() to remove the event from all
other lists.
Hereafter we can proceed to free the event; while still programmed!
Close this hole by moving perf_group_detach() inside the same
ctx->lock region(s) perf_remove_from_context() has.
The condition on inherited events only in __perf_event_exit_task() is
likely complete crap because non-inherited events are part of groups
too and we're tearing down just the same. But leave that for another
patch.
Most-likely-Fixes: e03a9a55b4e ("perf: Change close() semantics for group events")
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Much-staring-at-traces-by: Vince Weaver <vincent.weaver@maine.edu>
Much-staring-at-traces-by: Thomas Gleixner <tglx@linutronix.de>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/20140505093124.GN17778@laptop.programming.kicks-ass.net
commit 0819b2e30ccb93edf04876237b6205eef84ec8d2 upstream.
Vince reported that using a large sample_period (one with bit 63 set)
results in wreckage since while the sample_period is fundamentally
unsigned (negative periods don't make sense) the way we implement
things very much rely on signed logic.
So limit sample_period to 63 bits to avoid tripping over this.
Link: http://lkml.kernel.org/n/tip-p25fhunibl4y3qi0zuqmyf4b@git.kernel.org
commit 39af6b1678afa5880dda7e375cf3f9d395087f6d upstream.
The perf cpu offline callback takes down all cpu context
events and releases swhash->swevent_hlist.
This could race with task context software event being just
scheduled on this cpu via perf_swevent_add while cpu hotplug
code already cleaned up event's data.
The race happens in the gap between the cpu notifier code
and the cpu being actually taken down. Note that only cpu
ctx events are terminated in the perf cpu hotplug code.
It's easily reproduced with:
$ perf record -e faults perf bench sched pipe
while putting one of the cpus offline:
# echo 0 > /sys/devices/system/cpu/cpu1/online
Console emits following warning:
WARNING: CPU: 1 PID: 2845 at kernel/events/core.c:5672 perf_swevent_add+0x18d/0x1a0()
Modules linked in:
CPU: 1 PID: 2845 Comm: sched-pipe Tainted: G W 3.14.0+ #256
Hardware name: Intel Corporation Montevina platform/To be filled by O.E.M., BIOS AMVACRB1.86C.0066.B00.0805070703 05/07/2008
0000000000000009 ffff880077233ab8 ffffffff81665a23 0000000000200005
0000000000000000 ffff880077233af8 ffffffff8104732c 0000000000000046
ffff88007467c800 0000000000000002 ffff88007a9cf2a0 0000000000000001
Call Trace:
[<ffffffff81665a23>] dump_stack+0x4f/0x7c
[<ffffffff8104732c>] warn_slowpath_common+0x8c/0xc0
[<ffffffff8104737a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8110fb3d>] perf_swevent_add+0x18d/0x1a0
[<ffffffff811162ae>] event_sched_in.isra.75+0x9e/0x1f0
[<ffffffff8111646a>] group_sched_in+0x6a/0x1f0
[<ffffffff81083dd5>] ? sched_clock_local+0x25/0xa0
[<ffffffff811167e6>] ctx_sched_in+0x1f6/0x450
[<ffffffff8111757b>] perf_event_sched_in+0x6b/0xa0
[<ffffffff81117a4b>] perf_event_context_sched_in+0x7b/0xc0
[<ffffffff81117ece>] __perf_event_task_sched_in+0x43e/0x460
[<ffffffff81096f1e>] ? put_lock_stats.isra.18+0xe/0x30
[<ffffffff8107b3c8>] finish_task_switch+0xb8/0x100
[<ffffffff8166a7de>] __schedule+0x30e/0xad0
[<ffffffff81172dd2>] ? pipe_read+0x3e2/0x560
[<ffffffff8166b45e>] ? preempt_schedule_irq+0x3e/0x70
[<ffffffff8166b464>] preempt_schedule_irq+0x44/0x70
[<ffffffff816707f0>] retint_kernel+0x20/0x30
[<ffffffff8109e60a>] ? lockdep_sys_exit+0x1a/0x90
[<ffffffff812a4234>] lockdep_sys_exit_thunk+0x35/0x67
[<ffffffff81679321>] ? sysret_check+0x5/0x56
Fixing this by tracking the cpu hotplug state and displaying
the WARN only if current cpu is initialized properly.
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1396861448-10097-1-git-send-email-jolsa@redhat.com
commit 2d513868e2a33e1d5315490ef4c861ee65babd65 upstream.
Russell reported, that irqtime_account_idle_ticks() takes ages due to:
for (i = 0; i < ticks; i++)
irqtime_account_process_tick(current, 0, rq);
It's sad, that this code was written way _AFTER_ the NOHZ idle
functionality was available. I charge myself guitly for not paying
attention when that crap got merged with commit abb74cefa ("sched:
Export ns irqtimes through /proc/stat")
So instead of looping nr_ticks times just apply the whole thing at
once.
As a side note: The whole cputime_t vs. u64 business in that context
wants to be cleaned up as well. There is no point in having all these
back and forth conversions. Lets standardise on u64 nsec for all
kernel internal accounting and be done with it. Everything else does
not make sense at all for fine grained accounting. Frederic, can you
please take care of that?
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Venkatesh Pallipadi <venki@google.com>
Cc: Shaun Ruffell <sruffell@digium.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1405022307000.6261@ionos.tec.linutronix.de
commit 6227cb00cc120f9a43ce8313bb0475ddabcb7d01 upstream.
The check at the beginning of cpupri_find() makes sure that the task_pri
variable does not exceed the cp->pri_to_cpu array length. But that length
is CPUPRI_NR_PRIORITIES not MAX_RT_PRIO, where it will miss the last two
priorities in that array.
As task_pri is computed from convert_prio() which should never be bigger
than CPUPRI_NR_PRIORITIES, if the check should cause a panic if it is
hit.
Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com>
Link: http://lkml.kernel.org/r/1397015410.5212.13.camel@marge.simpson.net
commit 54a217887a7b658e2650c3feff22756ab80c7339 upstream.
The current implementation of lookup_pi_state has ambigous handling of
the TID value 0 in the user space futex. We can get into the kernel
even if the TID value is 0, because either there is a stale waiters bit
or the owner died bit is set or we are called from the requeue_pi path
or from user space just for fun.
The current code avoids an explicit sanity check for pid = 0 in case
that kernel internal state (waiters) are found for the user space
address. This can lead to state leakage and worse under some
circumstances.
Handle the cases explicit:
Waiter | pi_state | pi->owner | uTID | uODIED | ?
[1] NULL | --- | --- | 0 | 0/1 | Valid
[2] NULL | --- | --- | >0 | 0/1 | Valid
[3] Found | NULL | -- | Any | 0/1 | Invalid
[4] Found | Found | NULL | 0 | 1 | Valid
[5] Found | Found | NULL | >0 | 1 | Invalid
[6] Found | Found | task | 0 | 1 | Valid
[7] Found | Found | NULL | Any | 0 | Invalid
[8] Found | Found | task | ==taskTID | 0/1 | Valid
[9] Found | Found | task | 0 | 0 | Invalid
[10] Found | Found | task | !=taskTID | 0/1 | Invalid
[1] Indicates that the kernel can acquire the futex atomically. We
came came here due to a stale FUTEX_WAITERS/FUTEX_OWNER_DIED bit.
[2] Valid, if TID does not belong to a kernel thread. If no matching
thread is found then it indicates that the owner TID has died.
[3] Invalid. The waiter is queued on a non PI futex
[4] Valid state after exit_robust_list(), which sets the user space
value to FUTEX_WAITERS | FUTEX_OWNER_DIED.
[5] The user space value got manipulated between exit_robust_list()
and exit_pi_state_list()
[6] Valid state after exit_pi_state_list() which sets the new owner in
the pi_state but cannot access the user space value.
[7] pi_state->owner can only be NULL when the OWNER_DIED bit is set.
[8] Owner and user space value match
[9] There is no transient state which sets the user space TID to 0
except exit_robust_list(), but this is indicated by the
FUTEX_OWNER_DIED bit. See [4]
[10] There is no transient state which leaves owner and user space
TID out of sync.
Cc: Will Drewry <wad@chromium.org>
Cc: Darren Hart <dvhart@linux.intel.com>
commit 13fbca4c6ecd96ec1a1cfa2e4f2ce191fe928a5e upstream.
If the owner died bit is set at futex_unlock_pi, we currently do not
cleanup the user space futex. So the owner TID of the current owner
(the unlocker) persists. That's observable inconsistant state,
especially when the ownership of the pi state got transferred.
Clean it up unconditionally.
commit b3eaa9fc5cd0a4d74b18f6b8dc617aeaf1873270 upstream.
We need to protect the atomic acquisition in the kernel against rogue
user space which sets the user space futex to 0, so the kernel side
acquisition succeeds while there is existing state in the kernel
associated to the real owner.
Verify whether the futex has waiters associated with kernel state. If
it has, return -EINVAL. The state is corrupted already, so no point in
cleaning it up. Subsequent calls will fail as well. Not our problem.
[ tglx: Use futex_top_waiter() and explain why we do not need to try
restoring the already corrupted user space state. ]
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
in futex_requeue(..., requeue_pi=1)
commit e9c243a5a6de0be8e584c604d353412584b592f8 upstream.
If uaddr == uaddr2, then we have broken the rule of only requeueing from
a non-pi futex to a pi futex with this call. If we attempt this, then
dangling pointers may be left for rt_waiter resulting in an exploitable
condition.
This change brings futex_requeue() in line with futex_wait_requeue_pi()
which performs the same check as per commit 6f7b0a2a5c0f ("futex: Forbid
uaddr == uaddr2 in futex_wait_requeue_pi()")
[ tglx: Compare the resulting keys as well, as uaddrs might be
different depending on the mapping ]
Fixes CVE-2014-3153.
Reported-by: Pinkie Pie
Signed-off-by: Will Drewry <wad@chromium.org>
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
[ Upstream commit 21f8aaee0c62708654988ce092838aa7df4d25d8 ]
We check tid->sched without a lock taken on ath_tx_aggr_sleep(). That
is race condition which can result of doing list_del(&tid->list) twice
(second time with poisoned list node) and cause crash like shown below:
[424271.637220] BUG: unable to handle kernel paging request at 00100104
[424271.637328] IP: [<f90fc072>] ath_tx_aggr_sleep+0x62/0xe0 [ath9k]
[424271.639953] Call Trace:
[424271.639998] [<f90f6900>] ? ath9k_get_survey+0x110/0x110 [ath9k]
[424271.640083] [<f90f6942>] ath9k_sta_notify+0x42/0x50 [ath9k]
[424271.640177] [<f809cfef>] sta_ps_start+0x8f/0x1c0 [mac80211]
[424271.640258] [<c10f730e>] ? free_compound_page+0x2e/0x40
[424271.640346] [<f809e915>] ieee80211_rx_handlers+0x9d5/0x2340 [mac80211]
[424271.640437] [<c112f048>] ? kmem_cache_free+0x1d8/0x1f0
[424271.640510] [<c1345a84>] ? kfree_skbmem+0x34/0x90
[424271.640578] [<c10fc23c>] ? put_page+0x2c/0x40
[424271.640640] [<c1345a84>] ? kfree_skbmem+0x34/0x90
[424271.640706] [<c1345a84>] ? kfree_skbmem+0x34/0x90
[424271.640787] [<f809dde3>] ? ieee80211_rx_handlers_result+0x73/0x1d0 [mac80211]
[424271.640897] [<f80a07a0>] ieee80211_prepare_and_rx_handle+0x520/0xad0 [mac80211]
[424271.641009] [<f809e22d>] ? ieee80211_rx_handlers+0x2ed/0x2340 [mac80211]
[424271.641104] [<c13846ce>] ? ip_output+0x7e/0xd0
[424271.641182] [<f80a1057>] ieee80211_rx+0x307/0x7c0 [mac80211]
[424271.641266] [<f90fa6ee>] ath_rx_tasklet+0x88e/0xf70 [ath9k]
[424271.641358] [<f80a0f2c>] ? ieee80211_rx+0x1dc/0x7c0 [mac80211]
[424271.641445] [<f90f82db>] ath9k_tasklet+0xcb/0x130 [ath9k]
Bug report:
https://bugzilla.kernel.org/show_bug.cgi?id=70551
Reported-and-tested-by: Max Sydorenko <maxim.stargazer@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
[ xl: backported to 3.10: adjusted context ]
Signed-off-by: Xiangyu Lu <luxiangyu@huawei.com>
