I suspect Christoph tested his code only in the NUMA configuration, for
the combination of SLAB+non-NUMA the zero-sized kmalloc's would not work.
Of course, this would only trigger in configurations where those zero-
sized allocations happen (not very common), so that may explain why it
wasn't more widely noticed.
Seen by by Andi Kleen under qemu, and there seems to be a report by
Michael Tsirkin on it too.
Cc: Andi Kleen <ak@suse.de>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Michael S. Tsirkin <mst@dev.mellanox.co.il>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Christoph Lameter <clameter@sgi.com>
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits)
[TG3]: Fix msi issue with kexec/kdump.
[NET] XFRM: Fix whitespace errors.
[NET] TIPC: Fix whitespace errors.
[NET] SUNRPC: Fix whitespace errors.
[NET] SCTP: Fix whitespace errors.
[NET] RXRPC: Fix whitespace errors.
[NET] ROSE: Fix whitespace errors.
[NET] RFKILL: Fix whitespace errors.
[NET] PACKET: Fix whitespace errors.
[NET] NETROM: Fix whitespace errors.
[NET] NETFILTER: Fix whitespace errors.
[NET] IPV4: Fix whitespace errors.
[NET] DCCP: Fix whitespace errors.
[NET] CORE: Fix whitespace errors.
[NET] BLUETOOTH: Fix whitespace errors.
[NET] AX25: Fix whitespace errors.
[PATCH] mac80211: remove rtnl locking in ieee80211_sta.c
[PATCH] mac80211: fix GCC warning on 64bit platforms
[GENETLINK]: Dynamic multicast groups.
[NETLIKN]: Allow removing multicast groups.
ide-disk calls
ide_end_request(drive, 0, 0);
to finish an unknown request, but this doesn't work so well for non-fs
requests, since ide_end_request() internally looks at ->hard_cur_sectors
to see how much data to end. Only file system requests store a transfer
value in there, pc requests fill out ->data_len as a byte based transfer
value instead.
Since we ask to end 0 bytes of that request, it will never be terminated
and ide-disk gets stuck in a loop "handling" that same request over and
over.
Switch __ide_end_request() to take a byte based transfer count, and
adjust ide_end_request() to look at the right field to determine how
much IO to end when it's being passed in 0.
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Tested-By: Giacomo Catenazzi <cate@debian.org>
Bruce and David's patches clashed.
fs/afs/flock.c: In function 'afs_do_getlk':
fs/afs/flock.c:459: error: void value not ignored as it ought to be
Cc: "J. Bruce Fields" <bfields@fieldses.org>
I've been chasing these comments around this file all week. Hopefully we're
straight now.
Updated the EDAC kernel documentation
Signed-off-by: Doug Thompson <dougthompson@xmission.com>
Cc: Greg KH <greg@kroah.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Some simple fixes to properly reference counter values from the block
attribute level of edac_device objects. Properly sequencing the array pointer
was added, resulting in correct identification of block level attributes from
their base class functions.
Added more verbose debug statement for event tracking.
Also during some corner testing, found a bug in the store/show sequence
of operations for the block attribute/controls management.
An old intermediate structure for 'blocks' was still in the processing
pipeline. This patch removes that old structure and correctly utilizes the
new struct edac_dev_sysfs_block_attribute for passing control from the sysfs
to the low level store/show function of the edac driver.
Now the proper kobj pointer to passed downward to the store/show
functions.
Update maintainer information on edac components
New EDAC driver for the i82975x memory controller chipset Used on ASUS
motherboards
[akpm@linux-foundation.org: fix multiple coding-style bloopers]
Signed-off-by: <arvind@acarlab.com>
Signed-off-by: Ranganathan Desikan <rdesikan@jetzbroadband.com>
Fix mutex locking deadlock on the device controller linked list. Was calling
a lock then a function that could call the same lock. Moved the cancel workq
function to outside the lock
Added some short circuit logic in the workq code
Added comments of description
Code tidying
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Change EXPORT_SYMBOLs to EXPORT_SYMBOLS_GPL
Tidy changes: blank lines, inline removal, add comment
With feedback, this patch corrects operation of the kobject release operation
on kobjects, attributes and controls for the edac_device.
Cc: Alan Cox alan@lxorguk.ukuu.org.uk
Acked-by: Greg KH <greg@kroah.com>
This patch refactors the 'releasing' of kobjects for the edac_mc type of
device. The correct pattern of kobject release is followed.
As internal kobjs are allocated they bump a ref count on the top level kobj.
It in turn has a module ref count on the edac_core module. When internal
kobjects are released, they dec the ref count on the top level kobj. When the
top level kobj reaches zero, it decrements the ref count on the edac_core
object, allow it to be unloaded, as all resources have all now been released.
Refactoring of sysfs code necessitated the refactoring of the
edac_device_alloc() and edac_device_add_device() apis, of moving the index
value to the alloc() function. This patch alters the in tree drivers to
utilize this new api signature.
Having the index value performed later created a chicken-and-the-egg issue.
Moving it to the alloc() function allows for creating the necessary sysfs
entries with the proper index number
Refactoring of sysfs code necessitated the refactoring of the edac_mc_alloc()
and edac_mc_add_mc() apis, of moving the index value to the alloc() function.
This patch alters the in tree drivers to utilize this new api signature.
This patch fixes and enhances the driver level set of sysfs attributes that
can be added to the 'block' level of an edac_device type of driver.
There is a controller information structure, which contains one or more
instances of device. Each instance will have one or more blocks of device
specific counters. This patch fixes the ability to have more detailed
attributes/controls for each of the 'blocks', providing for the addition of
controls/attributes from the low level driver to user space via sysfs.
Signed-off-by: Douglas Thompson <dougthompson@xmission.com>
NEW EDAC driver for the memory controllers on PA Semi PA6T-1682M.
Changes since last submission:
* Rebased on top of 2.6.22-rc4-mm2 with the EDAC changes merged there.
* Minor checkpatch.pl cleanups
* Renamed ctl_name
* Added dev_name
* edac_mc.h -> edac_core.h
[akpm@linux-foundation.org: make printk more informative]
Signed-off-by: Egor Martovetsky <egor@pasemi.com>
Found a 'reversal' decoding bug in the driver. This patch fixes that mapping
to correctly display the CSROW entries in their proper order. Users will be
enable to correctly identifiy the failing DIMM with this fix.
[akpm@linux-foundation.org: unneeded (and undesirable) cast of void*]
Signed-off-by: Mark Grondona <mgrondona@llnl.gov>
A previous patch changed the edac_mc src file from semaphore usage to mutex
This patch changes the edac_device src file as well, from semaphore use to
mutex operation.
Use a mutex primitive for mutex operations, as it does not require a
semaphore
Removed the no-longer-needed file edac_mc.h
Refactored the function edac_op_state_toString() to be edac_op_state_to_string()
for consistent style, and its callers
Refactor the edac_align_ptr() function to reduce the noise of casting the
aligned pointer to the various types of data objects and modified its callers
to its new signature
For the file edac_device.c perform some coding style enhancements
Add some function header comments
Made for better readability commands
Various code style conformance patches on the i5000 driver
Patches to conform to coding style, namely static don't need to be initialized
to NULL nor '0', as that is the default
Found a typo in one of the #defines in the driver
MTR_DIM_RANKS --> MTR_DIMM_RANK
Signed-off-by: Marisuz Kozlowski <m.kozlowski@tuxland.pl>
pci_ids.h needs two of the AMD NB device-ids namely, Addressmap and the Memory
Controller devices
This patch adds those to the pci_id.h include file
Compiling this module gave a warning that the return value of
'pci_bus_add_device()' was not checked.
This patch adds that check and an output message
If ERRSTS indicates that there's no error then we don't need to bother reading
the other registers.
In addition to making the common case faster, this actually fixes a small race
where we don't see an error but we clear the error bits anyway, potentially
wiping away info on an error that happened in the interim (or where a CE
arrives between the first and second read of ERRSTS, causing us to falsely
claim "UE overwrote CE").
Signed-off-by: Jason Uhlenkott <juhlenko@akamai.com>
1) Remove an old CVS ID string
2) change EDAC from a tristate option to a simple bool option
3) In addition to the X86 arch, PPC and MIPS also have drivers in the
submission queue. This patch turns on the EDAC flag for those archs. Each
driver will have its respective 'depends on ARCH' set.
This patch fixes some remnant spaces inserted by the use of Lindent.
Seems Lindent adds some spaces when it shoulded. These have been fixed.
In addition, goto targets have issues, these have been fixed
in this patch.
Added new maintainers for the new EDAC drivers.
Kconfig - modified the help of EDAC
The error handling output strings needed to be refactored for better
displaying of the error informaton.
Also needed to added offset_value for output as well
Added new controls for the edac_device and edac_mc sysfs folder.
These can be initialized by the low level driver to provide misc
controls into the low level driver for its use
Move x86 drivers to new pci controller setup
Signed-off-by: Dave Jiang <djiang@mvista.com>
Run r82600_edac.c file through Lindent for cleanup
Run i82443bxgx.c file through Lindent for cleanup
Run e752x_edac.c file through Lindent for cleanup
Lindent cleanup of i82875p_edac driver
Lindent cleanup of i82860 edac driver
Lindent cleanup of i3000_edac driver
Lindent cleanup of e7xxx_edac driver
Ran e752x_edac.c file through Lindent for cleanup
Ran this driver through Lindent for cleanup
The origin of this code comes from patches at sourceforge, that
allow EDAC to be updated to various kernels. With kernel version 2.6.20 a
new workq system was installed, thus the patches needed to be modified
based on the kernel version. For submitting to the latest kernel.org
those #ifdefs are removed
Removal of some old dead and disabled code from the edac_device sysfs code
Run the EDAC CORE files through Lindent for cleanup
Fixup poll values for MC and PCI.
Also make mc function names unique to mc.
Signed-off-by: Douglas Thompson <dougthompson@xmissin.com>
Change error check and clear variable from an atomic to an int
