2007-07-20[ALSA] hda-codec - Add model for Toshiba A135Takashi Iwai
Added model=lenovo for Toshiba A135 with ALC861VD codec. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add HP Pavillion quirk to Realtek codeTobin Davis
This patch adds the HP Pavillion a1589L desktop system to the ALC883 configuration table. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ali5451 warning fixAndrew Morton
sound/pci/ali5451/ali5451.c: In function 'snd_ali_prepare': sound/pci/ali5451/ali5451.c:716: warning: 'R2' may be used uninitialized in this function Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] emu10k1 - EMU 1212 with 16 capture channelsPavel Hofman
* adding 8 more 32-bit capture channels (total of 16) for emu1010 cards * adding some code comments and card details description Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Add the MCP73/77 support to hda_intel driverPeer Chen
Add the MCP73/MCP77 support to hda driver. The patch base on kernel 2.6.22-rc4 Signed-off-by: Peer Chen <peerchen@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix Thinkpad X61/T61 outputsTakashi Iwai
Enable EAPD bit on Thinkpad X61/T61. The recent model requires it explicitly to make any sounds. In future, it should be toggled automatically on demand. Also, added a beep volume/switch. Some people like it although I don't understand why :) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] soc/sh: let SND_SOC_PCM_SH7760 depend on SH_DMABRGManuel Lauss
Let SND_SOC_PCM_SH7760 depend on SH_DMABRG rather than select'ing it. Gets rid of the Kbuild warning about SH_DMABRG being undefined on non-sh builds. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add quirk for another MSI laptop to alc883_cfg_tbl[]Daniel T Chen
This hg commit adds the SSID of another MSI laptop to the alc883_cfg_tbl[] quirk list. Verified in #alsa/Freenode on Thu, Jun 7, 2007. Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Yet another Uniwill laptop with ALC861 codecDave Jones
From: Dave Jones <davej@redhat.com> Rediffed version of the patch from .. http://bugzilla.kernel.org/show_bug.cgi?id=8016 that seems to be lingering for some time. Original patch by: Andy Shevchenko <andy@smile.org.ua> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add support of ALC268 codecKailang Yang
Added the support of new ALC268 codec chip. Signed-off-by: Kailang Yang <kailang@realtek.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add proper model for HP xw seriesKailang Yang
Set the proper model for HP xw4550, xw4600, xw6600 and xw8600. Signed-off-by: Kailang Yang <kailang@realtek.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix AD1984 basic modelTakashi Iwai
Fix the amp direction of digital mic capture volume mixer, which resulted in -EINVAL. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] More description on duplex streams with OSS emulationAlan Horstmann
Add paragraph to the OSS document to clarify correct use of duplex streams. Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix Oops with AD1984 thinkpad modelTakashi Iwai
Fixed Oops with AD1984 thinkpad model. Also fixed the wrong init verbs for NID 0x03 and 0x04, which have apparently no mute bit. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] rme9652 - Fix the hw_pointer checkTakashi Iwai
The negative check in hw_pointer callback doesn't work because the value is unsigned. Cast to int in the comparison to fix this. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ali5451 - Fix invalid type of codec->irq fieldTakashi Iwai
The irq field of struct snd_ali shouldn't be unsigned since it's uninitialized value is -1. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix STAC922x capture boost levelTakashi Iwai
STAC922x provides the capture boost level up to 4, but actually it works only up to 2. Since the range of the mixer is automatically defined from amp-capability bits, we need to override the value beforehand. snd_hda_override_amp_caps() is introduced for this purpose. The function patch_stac922x() calls this for NID 0x12 (Mux Capture Volume). This should fix another recording problem on Intel Macs. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix pin configs for Intel MacsIvan N. Zlatev
* adds the pinconfigs for all 5 Apple boards and 14 Subsystem IDs (support for possibly all iMac, Mac, MacMini etc etc) * adds 'intel-mac-v1' to v5 models which replace the current * reflects changes in Alsa-Configuration.txt Signed-off-by: Ivan N. Zlatev <contact@i-nz.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Disable debugging output for the ALS300 driverAsh Willis
Disables debugging output in the ALS300 driver. Also contains a whitespace cleanup and a fix for a potential bug. Signed-off-by: Ash Willis <ashwillis@programmer.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Fix SB-module dependency with PCI driversTakashi Iwai
A few PCI drivers like ALS4000 and CS5530 require the SB16-codes. This patch fixes / improves the dependency between SB modules and PCI drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Add support for Cyrix/NatSemi Geode CS5530 (VSA1)Takashi Iwai
Add support for Cyrix/NatSemi Geode SC5530 (VSA1). The driver is snd-cs5530. Signed-off-by Ash Willis <ashwillis@programmer.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix wrong mixer controls for AD1984 thinkpad modelTakashi Iwai
Fixed the wrong mixer controls for AD1984 thinkpad model. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add support of newer version of Intel iMacTakashi Iwai
Added the pin configs for newer version of Intel iMac. The information provided by Ivan N. Zlatev <contact@i-nz.net>. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ice1724 - Add PCM Playback Switch to Revo 7.1Pavel Hofman
This patch adds the support of mute for front channels of M-Audio Revolution 7.1 (the DAC AK4381 features a mute bit). Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Add description about probe_mask option for snd-hda-intelTakashi Iwai
Added a brief description about probe_mask option for snd-hda-intel. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add AD1884 / AD1984 codec supportTakashi Iwai
Added the support of AD1884 and AD1984 codec chips. Also experimental quirks for Thinkpad T61/X61 laptops with AD1984. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Add ALSA support for the SEGA Dreamcast PCM deviceAdrian McMenamin
ALSA support for the SEGA Dreamcast Yamaha AICA sound device (pcm) This patch adds ALSA sound support for pcm playback on two channels on the SEGA Dreamcast built-in sound device (the Yamaha AICA) Add driver for the AICA sound device built into the SEGA Dreamcast Hook it all up with the build system. Signed-off-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] SH7760 ASoC supportManuel Lauss
ALSA ASoC support for SH7760 This patch adds ALSA ASoC drivers for the Audio interfaces of the SH7760 SoC: Add driver for the SH7760 DMA engine (dmabrg) Add AC97 driver for HAC unit(s) found on SH7760/SH7780 Add I2S driver for SSI unit(s) found on SH7760/SH7780 Add a generic SH7760-AC97 machine driver. Hook it all up with the build system. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ASoC S3C24xx machine drivers - KconfigGraeme Gregory
This patch adds Kconfig and build support for the Neo1973, SMDK2443 and S3C2443 AC97 ALSA audio drivers. Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ASoC S3C24xx machine drivers - I2C ID for LM4857Liam Girdwood
This patch adds I2C ID for the LM4857 audio amp and corrects the spacing of the WM8731, WM8750 and WM8753 ID's. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ASoC S3C24xx machine drivers - SMDK 2443Graeme Gregory
This patch adds ALSA support for the SMDK2443 reference board. Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ASoC S3C24xx machine drivers - Openmoko Neo1973Graeme Gregory
This patch adds ALSA support for the Openmoko Neo1973 phone. Features:- * HiFi Playback and capture. * Phone calls supported. * Support for BT PCM in WM8753 voice interface. * Support for LM4857 audio amp. Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ASoC S3C24xx machine drivers - s3c2443-AC97Graeme Gregory
This patch adds AC97 support to the Samsung S3C2443 CPU. Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] usbusx2yaudio: kfree(NULL) is validRichard Knutsson
if (!x) kfree(x); is not needed since kfree(NULL) is valid. Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] usb-audio: another Logitech QuickCam IDDaniel Drake
This patch adds the ID for another quickcam microphone, reported by freqmod on ALSA ticket #0003040 I'm going to submit a USB patch separately to provide a macro to simplify these entries, as suggested by Alan Stern. We could switch to using that in future. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Fix unfreed pnp driver in opti9xx ISA driverTakashi Iwai
- Added the missing pnp_unregister_card_driver() in the case ISA PnP isn't found, which caused an error at kobject_add with -EEXIST Jun 11 09:07:31 rain kernel: kobject_add failed for opti9xx with -EEXIST, don't try to register things with the same name in the same directory. Jun 11 09:07:31 rain kernel: [<c01c18fa>] kobject_shadow_add+0x12a/0x1c0 Jun 11 09:07:31 rain kernel: [<c01c1a81>] kobject_register+0x21/0x50 Jun 11 09:07:31 rain kernel: [<c01f09a2>] bus_add_driver+0x72/0x1b0 Jun 11 09:07:31 rain kernel: [<c01d3dff>] pnp_register_card_driver+0x4f/0xc0 Jun 11 09:07:31 rain kernel: [<c89bc00a>] alsa_card_opti9xx_init+0xa/0x25 [snd_opti92x_ad1848] Jun 11 09:07:31 rain kernel: [<c0136947>] sys_init_module+0x157/0x1610 Jun 11 09:07:31 rain kernel: [<c01029b4>] syscall_call+0x7/0xb - Fixed the probe behavior when no PnP is set up. Now it behaves like the former version. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-19Merge branch 'kmem_death' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'kmem_death' of master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6: mm: Remove slab destructors from kmem_cache_create().
2007-07-19fallout from kbuild changesAl Viro
Change in 'kbuild: do section mismatch check on full vmlinux' should've been replicated in arch/um/Makefile. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Merge master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6: (23 commits) ide: add support for SCSI ioctls to ide-floppy ide: remove stale changelog from setup-pci.c ide: remove stale changelog/comments/TODO from ide.c ide-cris: handle PIO auto-tuning in tune_cris_ide() ide: add PIO masks ide: remove ide_find_best_pio_mode() ide: drop "PIO data" argument from ide_get_best_pio_mode() ide: ide_find_best_pio_mode() fixes (take 2) ide: add ide_pio_cycle_time() helper (take 2) sc1200: remove stale Power Management code ide: ide_start_power_step() fix WRT disabling DMA serverworks: fix DMA serverworks: always tune PIO ide: add ide_pci_device_t.host_flags (take 2) ide: add ide_dev_has_iordy() helper (take 4) ide: make ide_get_best_pio_mode() print info if overriding PIO mode siimage: PIO mode setup fixes (take 2) atiixp: PIO mode setup fixes ide: Stop mapping ROMs IDE: Remove references to dead ETRAX-related variables. ...
2007-07-19coda breakageAl Viro
a) switch by loff_t == __cmpdi2 use. Replaced with a couple of obvious ifs; update of ->f_pos in the first one makes sure that we do the right thing in all cases. b) block_signals() and unblock_signals() are globals on UML. Renamed coda ones; in principle UML probably ought to do rename as well, but that's another story. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19missed cong_avoid() instanceAl Viro
Removal of rtt argument in ->cong_avoid() had missed tcp_htcp.c instance. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20ide: add support for SCSI ioctls to ide-floppyBartlomiej Zolnierkiewicz
Now that ide-floppy supports SG_IO we can add support for SCSI ioctls (except deprecated SCSI_IOCTL_SEND_COMMAND and legacy CDROM_SEND_PACKET ones - we can add them later iff really needed). While at it remove handling of CDROMEJECT and CDROMCLOSETRAY ioctls from generic_ide_ioctl(): - This prevents ide-{disk,tape,scsi} device drivers from obtaining REQ_TYPE_BLOCK_PC type requests which are currently unsupported by these drivers and which are potentially harmful (as reported by Andrew). - There is no functionality loss since aforementioned ioctls will now be handled by idefloppy_ioctl()->scsi_cmd_ioctl() (for devices using ide-floppy driver) and by idecd_ioctl->cdrom_ioctl()->scsi_cmd_ioctl() (for devices using ide-cd driver). Cc: Jens Axboe <jens.axboe@oracle.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: remove stale changelog from setup-pci.cBartlomiej Zolnierkiewicz
2007-07-20ide: remove stale changelog/comments/TODO from ide.cBartlomiej Zolnierkiewicz
2007-07-20ide-cris: handle PIO auto-tuning in tune_cris_ide()Bartlomiej Zolnierkiewicz
2007-07-20ide: add PIO masksBartlomiej Zolnierkiewicz
* Add ATA_PIO[0-6] defines to <linux/ata.h>. * Add ->pio_mask field to ide_pci_device_t and ide_hwif_t. * Add PIO masks to host drivers. <linux/ata.h> change ACK-ed by Jeff Garzik <jeff@garzik.org>. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: remove ide_find_best_pio_mode()Bartlomiej Zolnierkiewicz
* Add ->host_flags to ide_hwif_t to store ide_pci_device_t.host_flags, assign it in setup-pci.c:ide_pci_setup_ports(). * Add IDE_HFLAG_PIO_NO_{BLACKLIST,DOWNGRADE} to ide_pci_device_t.host_flags and teach ide_get_best_pio_mode() about them. Also remove needless !drive->id check while at it (drive->id is always present). * Convert amd74xx, via82cxxx and ide-timing.h to use ide_get_best_pio_mode() and then remove no longer needed ide_find_best_pio_mode(). There should be no functionality changes caused by this patch. Acked-by: Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: drop "PIO data" argument from ide_get_best_pio_mode()Bartlomiej Zolnierkiewicz
* Drop no longer needed "PIO data" argument from ide_get_best_pio_mode() and convert all users accordingly. * Remove no longer needed ide_pio_data_t. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: ide_find_best_pio_mode() fixes (take 2)Bartlomiej Zolnierkiewicz
* Check IORDY bit for PIO modes > 2. * Some devices claim maximum PIO mode > 2 in id->tPIO, they were punished too severly for this by being limited to PIO_SLOW. Limit them to PIO2 instead. v2: * Fix PIO number being returned incorrectly instead of PIO mode (Noticed by Sergei). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
