2009-01-08NOMMU: Make VMAs per MM as for MMU-mode linuxDavid Howells
Make VMAs per mm_struct as for MMU-mode linux. This solves two problems: (1) In SYSV SHM where nattch for a segment does not reflect the number of shmat's (and forks) done. (2) In mmap() where the VMA's vm_mm is set to point to the parent mm by an exec'ing process when VM_EXECUTABLE is specified, regardless of the fact that a VMA might be shared and already have its vm_mm assigned to another process or a dead process. A new struct (vm_region) is introduced to track a mapped region and to remember the circumstances under which it may be shared and the vm_list_struct structure is discarded as it's no longer required. This patch makes the following additional changes: (1) Regions are now allocated with alloc_pages() rather than kmalloc() and with no recourse to __GFP_COMP, so the pages are not composite. Instead, each page has a reference on it held by the region. Anything else that is interested in such a page will have to get a reference on it to retain it. When the pages are released due to unmapping, each page is passed to put_page() and will be freed when the page usage count reaches zero. (2) Excess pages are trimmed after an allocation as the allocation must be made as a power-of-2 quantity of pages. (3) VMAs are added to the parent MM's R/B tree and mmap lists. As an MM may end up with overlapping VMAs within the tree, the VMA struct address is appended to the sort key. (4) Non-anonymous VMAs are now added to the backing inode's prio list. (5) Holes may be punched in anonymous VMAs with munmap(), releasing parts of the backing region. The VMA and region structs will be split if necessary. (6) sys_shmdt() only releases one attachment to a SYSV IPC shared memory segment instead of all the attachments at that addresss. Multiple shmat()'s return the same address under NOMMU-mode instead of different virtual addresses as under MMU-mode. (7) Core dumping for ELF-FDPIC requires fewer exceptions for NOMMU-mode. (8) /proc/maps is now the global list of mapped regions, and may list bits that aren't actually mapped anywhere. (9) /proc/meminfo gains a line (tagged "MmapCopy") that indicates the amount of RAM currently allocated by mmap to hold mappable regions that can't be mapped directly. These are copies of the backing device or file if not anonymous. These changes make NOMMU mode more similar to MMU mode. The downside is that NOMMU mode requires some extra memory to track things over NOMMU without this patch (VMAs are no longer shared, and there are now region structs). Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2009-01-08NOMMU: Delete askedalloc and realalloc variablesDavid Howells
Delete the askedalloc and realalloc variables as nothing actually uses the value calculated. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2009-01-08NOMMU: Rename ARM's struct vm_regionDavid Howells
Rename ARM's struct vm_region so that I can introduce my own global version for NOMMU. It's feasible that the ARM version may wish to use my global one instead. The NOMMU vm_region struct defines areas of the physical memory map that are under mmap. This may include chunks of RAM or regions of memory mapped devices, such as flash. It is also used to retain copies of file content so that shareable private memory mappings of files can be made. As such, it may be compatible with what is described in the banner comment for ARM's vm_region struct. Signed-off-by: David Howells <dhowells@redhat.com>
2009-01-08NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()David Howells
Fix cleanup handling in ramfs_nommu_get_umapped_area() by only freeing the number of pages that find_get_pages() said it had returned (nr) rather than attempting to free the number of pages we asked for (lpages) - thus avoiding the situation whereby put_page() may be handed NULL pointers if find_get_pages() returned fewer pages that were requested. Also avoid a warning about nr being uninitialised and the need for an if-statement in the cleanup path by using appropriate gotos. Signed-off-by: David Howells <dhowells@redhat.com>
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Work around branch tracer warning. sparc64: Fix unsigned long long warnings in drivers. sparc64: Use unsigned long long for u64. sparc: refactor code in fault_32.c sparc64: refactor code in init_64.c sparc64: refactor code in viohs.c sparc: make proces_ver_nack a bit more readable
2009-01-07Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: V4L/DVB (10191a): Update MAINTAINERS entries on media drivers V4L/DVB (10190): cx88: Fix some Kbuild troubles V4L/DVB (10189): dm1105: Fix build with INPUT=m and DVB_DM1105=y V4L/DVB (10185): Use negated usb_endpoint_xfer_control, etc V4L/DVB (10182): tda8290: fix TDA8290 + TDA18271 initialization V4L/DVB (10181): v4l2-device: Fix some sparse warnings V4L/DVB (10180): drivers/media: Fix a number of sparse warnings V4L/DVB (10179): tda8290: Fix two sparse warnings V4L/DVB (10178): dvb_frontend: Fix some sparse warnings due to static symbols V4L/DVB (10177): Fix sparse warnings on em28xx V4L/DVB (10176b): pxa-camera: fix redefinition warnings and missing DMA definitions V4L/DVB (10176a): Switch remaining clear_user_page users over to clear_user_highpage
2009-01-07Merge branch 'for-2.6.29' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.29' of git://linux-nfs.org/~bfields/linux: (67 commits) nfsd: get rid of NFSD_VERSION nfsd: last_byte_offset nfsd: delete wrong file comment from nfsd/nfs4xdr.c nfsd: git rid of nfs4_cb_null_ops declaration nfsd: dprint each op status in nfsd4_proc_compound nfsd: add etoosmall to nfserrno NFSD: FIDs need to take precedence over UUIDs SUNRPC: The sunrpc server code should not be used by out-of-tree modules svc: Clean up deferred requests on transport destruction nfsd: fix double-locks of directory mutex svc: Move kfree of deferral record to common code CRED: Fix NFSD regression NLM: Clean up flow of control in make_socks() function NLM: Refactor make_socks() function nfsd: Ensure nfsv4 calls the underlying filesystem on LOCKT SUNRPC: Ensure the server closes sockets in a timely fashion NFSD: Add documenting comments for nfsctl interface NFSD: Replace open-coded integer with macro NFSD: Fix a handful of coding style issues in write_filehandle() NFSD: clean up failover sysctl function naming ...
2009-01-07sparc64: Work around branch tracer warning.David S. Miller
As reported by Sam Ravnborg, Gcc-3.4.5 does not handle: if (get_user() || get_user()) with the new branch tracer enabled. Just seperate it out into seperate statements for now so people can get work done. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07V4L/DVB (10191a): Update MAINTAINERS entries on media driversMauro Carvalho Chehab
This patch updates the MAINTAINERS entries for the media drivers. We are doing a few changes during 2009 to improve patch handling for drivers/media stuff. Currently, v4l-dvb-maintainer list at linuxtv.org were used to to be v4l/dvb driver maintainers ML, in order to keep track of patch merge requests and to receive bug fixes. This list allows posting for everybody, but, in order to avoid spam, the user subscribe/unsubscribe at the ML is moderated. Other development discussions and end-user forums happened on two separated ML (one for V4L and another for DVB). At the beginning of 2009, we've created linux-media@vger.kernel.org, meaning to be the main upstream development mailing list for drivers/media, including V4L and DVB core and drivers. The choice for vger.kernel.org were due to the fact that most of upstream lists are there. Also, its anti-spam filtering rules are better than what we currently have at linuxtv.org. For now, both video4linux-list and linux-dvb ML will remain active, but more focused on end users. It is expected that those lists will gradually be replaced also by linux-media@vger.kernel.org. This patch reflect those changes at linux MAINTAINERS file. Since the development and bug fix discussions will now happen at linux-media@vger.kernel.org, this patch does the following changes - replaces v4l-dvb-maintainer ML for the new linux-media@vger.kernel.org; - replaces video4linux ML for the new linux-media@vger.kernel.org; While here, it also: - Fixes the existing -git tree entries for drivers/media (since the repository name changed); - Adds the missing drivers/media -git tree entry on a few maintainers entries that don't point to a tree. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10190): cx88: Fix some Kbuild troublesMauro Carvalho Chehab
As Randy Dunlap <randy.dunlap@oracle.com> reported, cx88 has some compilation issues: drivers/built-in.o: In function `cx88_call_i2c_clients': (.text+0x20af17): undefined reference to `videobuf_dvb_get_frontend' drivers/built-in.o: In function `cx8802_probe': cx88-mpeg.c:(.devinit.text+0x268c4): undefined reference to `videobuf_dvb_alloc_frontend' cx88-mpeg.c:(.devinit.text+0x268ea): undefined reference to `videobuf_dvb_dealloc_frontends' With those configs: CONFIG_VIDEO_CX88=y CONFIG_VIDEO_CX88_BLACKBIRD=y CONFIG_VIDEO_CX88_DVB=m CONFIG_DVB_CORE=m After carefully examining the code, with the current code, several cx88 drivers (cx8800, cx8802, cx88_dvb and cx88_blackbird) should be compiled as a module, if one of them is marked as such. Just fixing Kconfig could create a very complex set of rules. Also, this hides a problem with the current approach where the dvb functionality weren't confined inside dvb module. What happens is that: - cx88-i2c (part of cx8800) has some special rules if DVB; - cx88-mpeg (cx8802 module) has also part of DVB init code; - cx88-dvb has the rest of the dvb code; - cx88-blackbird can be used with cx88-mpeg, having cx88-dvb or not. So, instead of doing some tricks at Kconfig and wait for a next breakage, this patch moves the dvb code inside cx88-i2c and cx88-mpeg into cx88-dvb. Another problem is that cx8802 were being compiled, even without cx88-dvb and cx88-blackbird modules. While on this code, let's fix also a reported problem: http://www.linuxtv.org/pipermail/linux-dvb/2009-January/031225.html A solution for the issue were proposed here: http://www.mail-archive.com/linux-media@vger.kernel.org/msg00021.html Thanks to Randy, Andy, Gregoire and Thomas for helping us to detect and solve the issues. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10189): dm1105: Fix build with INPUT=m and DVB_DM1105=yMauro Carvalho Chehab
As reported by Randy Dunlap <randy.dunlap@oracle.com>: With CONFIG_INPUT=m and CONFIG_DVB_DM1105=y: drivers/built-in.o: In function `input_sync': dm1105.c:(.text+0x120c33): undefined reference to `input_event' drivers/built-in.o: In function `dm1105_emit_key': dm1105.c:(.text+0x120c6c): undefined reference to `input_event' dm1105.c:(.text+0x120c82): undefined reference to `input_event' dm1105.c:(.text+0x120cb2): undefined reference to `input_event' dm1105.c:(.text+0x120cd1): undefined reference to `input_event' drivers/built-in.o: In function `dm1105_ir_init': (.devinit.text+0xd8ae): undefined reference to `input_allocate_device' drivers/built-in.o: In function `dm1105_ir_init': (.devinit.text+0xd9f6): undefined reference to `input_register_device' drivers/built-in.o: In function `dm1105_ir_init': (.devinit.text+0xda09): undefined reference to `input_free_device' drivers/built-in.o: In function `dm1105_ir_exit': (.devexit.text+0xcde): undefined reference to `input_unregister_device' This is due to the lack of a dependency between dm1105 and CONFIG_INPUT Cc: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10185): Use negated usb_endpoint_xfer_control, etcJulia Lawall
This patch extends 134179823b3ca9c8b98e0631906459dbb022ff9b by using usb_endpoint_xfer_control, usb_endpoint_xfer_isoc, usb_endpoint_xfer_bulk, and usb_endpoint_xfer_int in the negated case as well. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_CONTROL\|0\)) + !usb_endpoint_xfer_control(epd) @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_ISOC\|1\)) + !usb_endpoint_xfer_isoc(epd) @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_BULK\|2\)) + !usb_endpoint_xfer_bulk(epd) @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_INT\|3\)) + !usb_endpoint_xfer_int(epd) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10182): tda8290: fix TDA8290 + TDA18271 initializationMichael Krufky
Don't call tda8290_init_tuner unless we have either a TDA8275 or TDA8275A present. Calling this function will cause a TDA18271 to get sick, so we should only call it when needed. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10181): v4l2-device: Fix some sparse warningsMauro Carvalho Chehab
/home/v4l/master/v4l/v4l2-device.c:32:2: warning: Using plain integer as NULL pointer /home/v4l/master/v4l/v4l2-device.c:64:2: warning: Using plain integer as NULL pointer Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10180): drivers/media: Fix a number of sparse warningsMauro Carvalho Chehab
anysee.c:44:5: warning: symbol 'dvb_usb_anysee_delsys' was not declared. Should it be static? cx24116.c:378:3: warning: symbol 'CX24116_MODFEC_MODES' was not declared. Should it be static? stb0899_algo.c:57:5: warning: symbol 'stb0899_get_srate' was not declared. Should it be static? stb0899_algo.c:766:6: warning: symbol 'Log2Int' was not declared. Should it be static? stb0899_drv.c:137:20: warning: symbol 'stb0899_quant_tab' was not declared. Should it be static? stb0899_drv.c:180:20: warning: symbol 'stb0899_est_tab' was not declared. Should it be static? stb0899_drv.c:220:5: warning: symbol '_stb0899_read_reg' was not declared. Should it be static? budget-ci.c:1348:23: warning: symbol 'tt3200_stb6100_config' was not declared. Should it be static? /home/v4l/master/v4l/cx25840-core.c:190:6: warning: symbol 'cx25840_work_handler' was not declared. Should it be static? /home/v4l/master/v4l/m5602_s5k83a.c:116:6: warning: symbol 's5k83a_dump_registers' was not declared. Should it be static? Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10179): tda8290: Fix two sparse warningsMauro Carvalho Chehab
/home/v4l/master/v4l/tda8290.c:233:7: warning: symbol 'i' shadows an earlier one /home/v4l/master/v4l/tda8290.c:178:3: warning: symbol 'fm_mode' was not declared. Should it be static? Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10178): dvb_frontend: Fix some sparse warnings due to static symbolsMauro Carvalho Chehab
/home/v4l/master/v4l/dvb_frontend.c:838:19: warning: symbol 'dtv_cmds' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1035:6: warning: symbol 'dtv_property_dump' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1066:5: warning: symbol 'is_legacy_delivery_system' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1080:6: warning: symbol 'dtv_property_cache_sync' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1132:6: warning: symbol 'dtv_property_legacy_params_sync' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1187:6: warning: symbol 'dtv_property_adv_params_sync' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1222:6: warning: symbol 'dtv_property_cache_submit' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1253:5: warning: symbol 'dtv_property_process_get' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1362:5: warning: symbol 'dtv_property_process_set' was not declared. Should it be static? Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10177): Fix sparse warnings on em28xxMauro Carvalho Chehab
/home/v4l/master/v4l/em28xx-core.c:396:25: warning: symbol 'outputs' was not declared. Should it be static? /home/v4l/master/v4l/em28xx-input.c:324:6: warning: symbol 'em28xx_ir_start' was not declared. Should it be static? /home/v4l/master/v4l/em28xx-cards.c:1925:5: warning: symbol 'em28xx_init_dev' was not declared. Should it be static? Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10176b): pxa-camera: fix redefinition warnings and missing DMA ↵Eric Miao
definitions 1. now pxa_camera.c uses ioremap() for register access, pxa_camera.h is totally useless. Remove it. 2. <asm/dma.h> does no longer include <mach/dma.h>, include the latter file explicitly delete mode 100644 drivers/media/video/pxa_camera.h Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10176a): Switch remaining clear_user_page users over to ↵Guennadi Liakhovetski
clear_user_highpage Not all architectures provide clear_user_page(), but clear_user_highpage() is available everywhere at least via the compatibility inline function. Is this the "trivial patch" that's required for these two drivers? Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07staging: __FUNCTION__ is gcc-specific, use __func__Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07trivial: replace last usages of __FUNCTION__ in kernelHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: fix possible recursive rq->lock
2009-01-07Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (98 commits) PCI PM: Put PM callbacks in the order of execution PCI PM: Run default PM callbacks for all devices using new framework PCI PM: Register power state of devices during initialization PCI PM: Call pci_fixup_device from legacy routines PCI PM: Rearrange code in pci-driver.c PCI PM: Avoid touching devices behind bridges in unknown state PCI PM: Move pci_has_legacy_pm_support PCI PM: Power-manage devices without drivers during suspend-resume PCI PM: Add suspend counterpart of pci_reenable_device PCI PM: Fix poweroff and restore callbacks PCI: Use msleep instead of cpu_relax during ASPM link retraining PCI: PCIe portdrv: Add kerneldoc comments to remining core funtions PCI: PCIe portdrv: Rearrange code so that related things are together PCI: PCIe portdrv: Fix suspend and resume of PCI Express port services PCI: PCIe portdrv: Add kerneldoc comments to some core functions x86/PCI: Do not use interrupt links for devices using MSI-X net: sfc: Use pci_clear_master() to disable bus mastering PCI: Add pci_clear_master() as opposite of pci_set_master() PCI hotplug: remove redundant test in cpq hotplug PCI: pciehp: cleanup register and field definitions ...
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (123 commits) wimax/i2400m: add CREDITS and MAINTAINERS entries wimax: export linux/wimax.h and linux/wimax/i2400m.h with headers_install i2400m: Makefile and Kconfig i2400m/SDIO: TX and RX path backends i2400m/SDIO: firmware upload backend i2400m/SDIO: probe/disconnect, dev init/shutdown and reset backends i2400m/SDIO: header for the SDIO subdriver i2400m/USB: TX and RX path backends i2400m/USB: firmware upload backend i2400m/USB: probe/disconnect, dev init/shutdown and reset backends i2400m/USB: header for the USB bus driver i2400m: debugfs controls i2400m: various functions for device management i2400m: RX and TX data/control paths i2400m: firmware loading and bootrom initialization i2400m: linkage to the networking stack i2400m: Generic probe/disconnect, reset and message passing i2400m: host/device procotol and core driver definitions i2400m: documentation and instructions for usage wimax: Makefile, Kconfig and docbook linkage for the stack ...
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-asyncLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-async: async: don't do the initcall stuff post boot bootchart: improve output based on Dave Jones' feedback async: make the final inode deletion an asynchronous event fastboot: Make libata initialization even more async fastboot: make the libata port scan asynchronous fastboot: make scsi probes asynchronous async: Asynchronous function calls to speed up kernel boot
2009-01-07topology: Fix sparc64 build.David Miller
Due to changeset ba84be2338d3a2b6020d39279335bb06fcd332e1 ("remove linux/hardirq.h from asm-generic/local.h") the sparc64 build started failing on drivers/base/topology.c: drivers/base/topology.c: In function ‘show_physical_package_id’: drivers/base/topology.c:103: error: implicit declaration of function ‘cpu_data’ drivers/base/topology.c:103: error: request for member ‘proc_id’ in something not a structure or union drivers/base/topology.c: In function ‘show_core_id’: drivers/base/topology.c:106: error: request for member ‘core_id’ in something not a structure or union Adding the obvious fix of including asm/cpudata.h into asm/topology.h on sparc64 doesn't fix it, in fact it makes things worse because of the header file dependency chain: linux/gfp.h --> linux/mmzone.h --> linux/topology.h --> asm/topology.h --> asm/cpudata.h --> linux/percpu.h --> linux/slab.h which results in: include/linux/slub_def.h: In function ‘kmalloc_large’: include/linux/slub_def.h:209: error: implicit declaration of function ‘__get_free_pages’ include/linux/slub_def.h:209: error: ‘__GFP_COMP’ undeclared (first use in this function) include/linux/slub_def.h:209: error: (Each undeclared identifier is reported only once include/linux/slub_def.h:209: error: for each function it appears in.) include/linux/slub_def.h:209: warning: cast to pointer from integer of different size The simplest thing to do is to add yet another one-off hack like parts of the guilty changeset did, by putting an explicit linux/hardirq.h include into drivers/base/topology.c Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07nfsd: get rid of NFSD_VERSIONBenny Halevy
Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07nfsd: last_byte_offsetBenny Halevy
refactor the nfs4 server lock code to use last_byte_offset to compute the last byte covered by the lock. Check for overflow so that the last byte is set to NFS4_MAX_UINT64 if offset + len wraps around. Also, use NFS4_MAX_UINT64 for ~(u64)0 where appropriate. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07nfsd: delete wrong file comment from nfsd/nfs4xdr.cMarc Eshel
2009-01-07nfsd: git rid of nfs4_cb_null_ops declarationBenny Halevy
There's no use for nfs4_cb_null_ops's declaration in fs/nfsd/nfs4callback.c Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07nfsd: dprint each op status in nfsd4_proc_compoundBenny Halevy
2009-01-07nfsd: add etoosmall to nfserrnoDean Hildebrand
Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07NFSD: FIDs need to take precedence over UUIDsSteve Dickson
When determining the fsid_type in fh_compose(), the setting of the FID via fsid= export option needs to take precedence over using the UUID device id. Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07SUNRPC: The sunrpc server code should not be used by out-of-tree modulesTrond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07svc: Clean up deferred requests on transport destructionTom Tucker
A race between svc_revisit and svc_delete_xprt can result in deferred requests holding references on a transport that can never be recovered because dead transports are not enqueued for subsequent processing. Check for XPT_DEAD in revisit to clean up completing deferrals on a dead transport and sweep a transport's deferred queue to do the same for queued but unprocessed deferrals. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: fix typos (s/bin_shipped/bin.o_shipped/) in Documentation kbuild: add a symlink to the source for separate objdirs kconfig: add script to manipulate .config files on the command line kbuild: reintroduce ALLSOURCE_ARCHS support for tags/cscope bootchart: improve output based on Dave Jones' feedback fix modules_install via NFS qnx: include <linux/types.h> for definitions of __[us]{8,16,32,64} types
2009-01-07kbuild: fix typos (s/bin_shipped/bin.o_shipped/) in DocumentationWolfram Sang
The text always mentions ...bin.o_shipped, just the example makefiles actually use ...bin_shipped. It was corrected in one place some time ago, these ones seem to have been forgotten. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07kbuild: add a symlink to the source for separate objdirsAndi Kleen
I have some scripts which need to map back to the source directory from an objdir. This was so far done by parsing the Makefile, but the Makefile format changes occasionally and breaks my scripts then. To make this more reliable add a "source" symlink back. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07kconfig: add script to manipulate .config files on the command lineAndi Kleen
I often change single options in .config files. Instead of using an editor or one of the frontends it's convenient to do this from the command line. It's also useful to do from automated build scripts when building different variants from a base config file. I extracted most of the CONFIG manipulation code from one of my build scripts into a new shell script scripts/config The script is not integrated with the normal Kconfig machinery and doesn't do any checking against Kconfig files, but just manipulates that text format. This is always done at make time anyways. I believe this script would be a useful standard addition for scripts/* Sample usage: ./scripts/config --disable smp Disable SMP in .config file ./scripts/config --file otherdir/.config --module e1000e Enable E1000E as module in otherdir/.config ./scripts/config --state smp y Check state of config option CONFIG_SMP After merging into git please make scripts/config executable Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07kbuild: reintroduce ALLSOURCE_ARCHS support for tags/cscopeJike Song
This patch reintroduce the ALLSOURCE_ARCHS support for tags/TAGS/ cscope targets. The Kbuild previously has this feature, but after moving the targets into scripts/tags.sh, ALLSOURCE_ARCHS disappears. It's something like this: $ make ALLSOURCE_ARCHS="x86 mips arm" tags cscope Signed-off-by: Jike Song <albcamus@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07bootchart: improve output based on Dave Jones' feedbackArjan van de Ven
Dave Jones, in his blog, had some feedback about the bootchart script: Primarily his complaint was that shorter delays weren't visualized. The reason for that was that too small delays will have their labels mixed up in the graph in an unreadable mess. This patch has a fix for this; for one, it makes the output wider, so more will fit. The second part is that smaller delays are now shown with a much smaller font for the label; while this isn't per se readable at a 1:1 zoom, at least you can zoom in with most SVG viewing applications and see what it is you are looking at. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07fix modules_install via NFSSam Ravnborg
Rafael reported: I get the following error from 'make modules_install' on my test boxes: HOSTCC firmware/ihex2fw /home/rafael/src/linux-2.6/firmware/ihex2fw.c:268: fatal error: opening dependency file firmware/.ihex2fw.d: Read-only file system compilation terminated. make[3]: *** [firmware/ihex2fw] Error 1 make[2]: *** [_modinst_post] Error 2 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 where the configuration is that the kernel is compiled on a build box with 'make O=<destdir> -j5' and then <destdir> is mounted over NFS read-only by each test box (full path to this directory is the same on the build box and on the test boxes). Then, I cd into <destdir>, run 'make modules_install' and get the error above. The issue turns out to be that we when we install firmware pick up the list of firmware blobs from firmware/Makefile. And this triggers the Makefile rules to update ihex2fw. There were two solutions for this issue: 1) Move the list of firmware blobs to a separate file 2) Avoid ihex2fw rebuild by moving it to scripts As I seriously beleive that the list of firmware blobs should be done in a fundamental different way solution 2) was selected. Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org>
2009-01-07qnx: include <linux/types.h> for definitions of __[us]{8,16,32,64} typesAnders Larsen
On 2008-12-30 11:32:33, Sam Ravnborg wrote: > We have added a few additional validation checks of the userspace headers: ... > 3) We should include <linux/types.h> and not <asm/types.h> > 4) If we use a __[us]{8,16,32,64} type then we must include <linux/types.h> Satisfy these requirements for the linux/qnx*.h headers. Signed-off-by: Anders Larsen <al@alarsen.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07nfsd: fix double-locks of directory mutexJ. Bruce Fields
A number of nfsd operations depend on the i_mutex to cover more code than just the fsync, so the approach of 4c728ef583b3d8 "add a vfs_fsync helper" doesn't work for nfsd. Revert the parts of those patches that touch nfsd. Note: we can't, however, remove the logic from vfs_fsync that was needed only for the special case of nfsd, because a vfs_fsync(NULL,...) call can still result indirectly from a stackable filesystem that was called by nfsd. (Thanks to Christoph Hellwig for pointing this out.) Reported-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07svc: Move kfree of deferral record to common codeTom Tucker
The rqstp structure has a pointer to a svc_deferred_req record that is allocated when requests are deferred. This record is common to all transports and can be freed in common code. Move the kfree of the rq_deferred to the common svc_xprt_release function. This also fixes a memory leak in the RDMA transport which does not kfree the dr structure in it's version of the xpo_release_rqst callback. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07CRED: Fix NFSD regressionDavid Howells
Fix a regression in NFSD's permission checking introduced by the credentials patches. There are two parts to the problem, both in nfsd_setuser(): (1) The return value of set_groups() is -ve if in error, not 0, and should be checked appropriately. 0 indicates success. (2) The UID to use for fs accesses is in new->fsuid, not new->uid (which is 0). This causes CAP_DAC_OVERRIDE to always be set, rather than being cleared if the UID is anything other than 0 after squashing. Reported-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07NLM: Clean up flow of control in make_socks() functionChuck Lever
Clean up: Use Bruce's preferred control flow style in make_socks(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07NLM: Refactor make_socks() functionChuck Lever
Clean up: extract common logic in NLM's make_socks() function into a helper. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07nfsd: Ensure nfsv4 calls the underlying filesystem on LOCKTJ. Bruce Fields
Since nfsv4 allows LOCKT without an open, but the ->lock() method is a file method, we fake up a struct file in the nfsv4 code with just the fields we need initialized. But we forgot to initialize the file operations, with the result that LOCKT never results in a call to the filesystem's ->lock() method (if it exists). We could just add that one more initialization. But this hack of faking up a struct file with only some fields initialized seems the kind of thing that might cause more problems in the future. We should either do an open and get a real struct file, or make lock-testing an inode (not a file) method. This patch does the former. Reported-by: Marc Eshel <eshel@almaden.ibm.com> Tested-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
