commit 0c0efbacab8d70700d13301e0ae7975783c0cb0a upstream.
handle_ir_buffer_fill() assumed that a completed descriptor would be
indicated by a non-zero transfer_status (as in most other descriptors).
However, this field is written by the controller as soon as (the end of)
the first packet has been written into the buffer. As a consequence, if
we happen to run into such a descriptor when the interrupt handler is
executed after such a packet has completed, the descriptor would be
taken out of the list of active descriptors as soon as the buffer had
been partially filled, so the event for the buffer being completely
filled would never be sent.
To fix this, handle descriptors only when they have been completely
filled, i.e., when res_count == 0. (This also matches the condition
that is reported by the controller with an interrupt.)
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
commit 9716387311c790de381214c03e7f1b72b91a8189 upstream.
According to the HT6560H datasheet, the recovery timing field is 4-bit wide,
with a value of 0 meaning 16 cycles. Correct obvious thinko in the recovery
field mask.
commit 6c30d5a53229aad22bb675e0bd6eb518ecaa4316 upstream.
Add support for the camera key. The hotkey for
Asus S.H.E(Super Hybrid Engine) mode is mapped to KEY_KEY_PROG1
just for notifying the userspace.
Signed-off-by: Keng-Yu Lin <kengyu@canonical.com>
commit 3596bb929f2abd3433c2eaa5755fad48ac207af1 upstream.
The Asus All-In-One PC has a wireless keyboard with wifi toggle,
brightness up, brightness down and display off hotkeys.
This patch adds suppoort for these hotkeys.
commit 6b6ba88b5bb8779156b21bb957520a448c3642e2 upstream.
The ID is found on Asus K54HR and K53U.
Blacklist the AR3011-based device ID [0489:e03d]
and add to ath3k.c for firmware loading.
Below is the output of usb-devices script:
Before the fiwmware loading:
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0489 ProdID=e03d Rev=00.01
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
After the fiwmware loading:
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=0cf3 ProdID=3005 Rev=00.01
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
commit 33395fb8a13731c7ef7b175dbf5a4d8a6738fe6c upstream.
The old code did (MSB << 8) & 0xff, which always evaluates to 0. Just use
get_unaligned_be16() so we don't have to worry about whether our open-coded
version is correct or not.
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 47f1b8803e1e358ebbf4f82bfdb98971c912a2c3 upstream.
transport_kmap_data_sg can return NULL. I never saw this trigger, but
returning -ENOMEM seems better than a crash. Also removes a pointless
case while at it.
Signed-off-by: Joern Engel <joern@logfs.org>
commit 382436f8804fe1cb20b9a2a811a10eb2d8554721 upstream.
Fix possible NULL pointer dereference in target_report_luns failure path.
commit effc6cc8828257c32c37635e737f14fd6e19ecd7 upstream.
SPC-4 says about the WBUS16 and SYNC bits:
The meanings of these fields are specific to SPI-5 (see 6.4.3).
For SCSI transport protocols other than the SCSI Parallel
Interface, these fields are reserved.
We don't have a SPI fabric module, so we should never set these bits.
(The comment was misleading, since it only mentioned Sync but the
actual code set WBUS16 too).
commit 4c1b2d2da3451f5c8dd59bd7e05bd9729d2aee05 upstream.
vbios lists DVI-I port as VGA and DVI-D.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=47007
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit e00e8b5e760cbbe9067daeae5454d67c44c8d035 upstream.
We digital encoders have a detect function as well (for
DP to VGA bridges), so we make sure we choose the analog
one here.
Fixes:
commit c4353016dac10133fa5d8535af83f0c4845a2915 upstream.
The hardware only takes 27 bits for the offset, so larger offsets are
truncated, and the hardware cursor shows random bits other than the intended
ones.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=46796
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit c501ae7f332cdaf42e31af30b72b4b66cbbb1604 upstream.
By clearing the GPU read domains before waiting upon the buffer, we run
the risk of the wait being interrupted and the domains prematurely
cleared. The next time we attempt to wait upon the buffer (after
userspace handles the signal), we believe that the buffer is idle and so
skip the wait.
There are a number of bugs across all generations which show signs of an
overly haste reuse of active buffers.
Such as:
https://bugs.freedesktop.org/show_bug.cgi?id=29046
https://bugs.freedesktop.org/show_bug.cgi?id=35863
https://bugs.freedesktop.org/show_bug.cgi?id=38952
https://bugs.freedesktop.org/show_bug.cgi?id=40282
https://bugs.freedesktop.org/show_bug.cgi?id=41098
https://bugs.freedesktop.org/show_bug.cgi?id=41102
https://bugs.freedesktop.org/show_bug.cgi?id=41284
https://bugs.freedesktop.org/show_bug.cgi?id=42141
A couple of those pre-date i915_gem_object_finish_gpu(), so may be
unrelated (such as a wild write from a userspace command buffer), but
this does look like a convincing cause for most of those bugs.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit d0962936bff659d20522555b517582a2715fd23f upstream.
In super_1_sync (the first hunk) we need to clear 'changed' before
checking read_seqretry(), otherwise we might race with other code
adding a bad block and so won't retry later.
In md_update_sb (the second hunk), in the case where there is no
metadata (neither persistent nor external), we treat any bad blocks as
an error. However we need to clear the 'changed' flag before calling
md_ack_all_badblocks, else it won't do anything.
This patch is suitable for -stable release 3.0 and later.
Signed-off-by: NeilBrown <neilb@suse.de>
commit d6b42dcb995e6acd7cc276774e751ffc9f0ef4bf upstream.
If RAID1 or RAID10 is used under LVM or some other stacking
block device, it is possible to enter a deadlock during
resync or recovery.
This can happen if the upper level block device creates
two requests to the RAID1 or RAID10. The first request gets
processed, blocks recovery and queue requests for underlying
requests in current->bio_list. A resync request then starts
which will wait for those requests and block new IO.
But then the second request to the RAID1/10 will be attempted
and it cannot progress until the resync request completes,
which cannot progress until the underlying device requests complete,
which are on a queue behind that second request.
So allow that second request to proceed even though there is
a resync request about to start.
This is suitable for any -stable kernel.
Reported-by: Ray Morris <support@bettercgi.com>
Tested-by: Ray Morris <support@bettercgi.com>
commit c744a65c1e2d59acc54333ce80a5b0702a98010b upstream.
It seems that with recent kernel, writeback can still be happening
while shutdown is happening, and consequently data can be written
after the md reboot notifier switches all arrays to read-only.
This causes a BUG.
So don't switch them to read-only - just mark them clean and
set 'safemode' to '2' which mean that immediately after any
write the array will be switch back to 'clean'.
This could result in the shutdown happening when array is marked
dirty, thus forcing a resync on reboot. However if you reboot
without performing a "sync" first, you get to keep both halves.
This is suitable for any stable kernel (though there might be some
conflicts with obvious fixes in earlier kernels).
commit 4474ca42e2577563a919fd3ed782e2ec55bf11a2 upstream.
When commit 69e51b449d383e (md/bitmap: separate out loading a bitmap...)
created bitmap_load, it missed calling it after bitmap_create when a
bitmap is created through the sysfs interface.
So if a bitmap is added this way, we don't allocate memory properly
and can crash.
This is suitable for any -stable release since 2.6.35.
commit 031ed4d565b31880a4136bb7366bc89f5b1dba7d upstream.
This patch fixes a bug in tcm_fc where fc_exch memory from fc_exch_mgr->ep_pool
is currently being leaked by ft_send_resp_status() usage. Following current
code in ft_queue_status() response path, using lport->tt.seq_send() needs to be
followed by a lport->tt.exch_done() in order to release fc_exch memory back into
libfc_em kmem_cache.
ft_send_resp_status() code is currently used in pre submit se_cmd ft_send_work()
error exceptions, TM request setup exceptions, and main TM response callback
path in ft_queue_tm_resp(). This bugfix addresses the leak in these cases.
Cc: Mark D Rustad <mark.d.rustad@intel.com>
Cc: Kiran Patil <kiran.patil@intel.com>
Cc: Robert Love <robert.w.love@intel.com>
Cc: Andy Grover <agrover@redhat.com>
commit ce880cb860f36694d2cdebfac9e6ae18176fe4c4 upstream.
The USB graphics card driver delays the unregistering of the framebuffer
device to a workqueue, which breaks the userspace visible remove uevent
sequence. Recent userspace tools started to support USB graphics card
hotplug out-of-the-box and rely on proper events sent by the kernel.
The framebuffer device is a direct child of the USB interface which is
removed immediately after the USB .disconnect() callback. But the fb device
in /sys stays around until its final cleanup, at a time where all the parent
devices have been removed already.
To work around that, we remove the sysfs fb device directly in the USB
.disconnect() callback and leave only the cleanup of the internal fb
data to the delayed work.
Before:
add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb)
add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb)
add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb0 (graphics)
remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb)
remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb)
remove /2-1.2:1.0/graphics/fb0 (graphics)
After:
add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb1 (graphics)
remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb1 (graphics)
Tested-by: Bernie Thompson <bernie@plugable.com>
Acked-by: Bernie Thompson <bernie@plugable.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
CONFIG_USB_FUNCTIONFS_ETH
commit 8d0698428822ce63f7269e7fe81fc4580807b9ac upstream.
commit 28824b18ac4705e876a282a15ea0de8fc957551f:
|Author: Michal Nazarewicz <m.nazarewicz@samsung.com>
|Date: Wed May 5 12:53:13 2010 +0200
| USB: gadget: __init and __exit tags removed
| __init, __initdata and __exit tags have have been removed from
| various files to make it possible for gadgets that do not use
| the __init/__exit tags to use those.
obviously missed (at least) this case leading to a section mismatch in
g_ffs.c when compiling with CONFIG_USB_FUNCTIONFS_ETH enabled.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
commit 25dc16f69892182192b1234594fd3cf342ad4195 upstream.
A previous commit af65cbf296 (ALSA: hdmi: fix printout of SAD sampling
rates) fixed the sample rates shown in /proc/asound/cardX/eldY and
kernel log to not be entirely wrong. However, a missing rate from the
array added in the patch causes HDMI rates 88.2 kHz, 96 kHz, 176.4 kHz,
and 192 kHz to be shown as 96 kHz, 176.4 kHz, 192 kHz, and 384 kHz,
respectively.
Fix the reporting by adding the ALSA rate 64 kHz into the conversion
array between 48 kHz and 88.2 kHz.
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
Cc: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
commit d06283341aee9e48eff1b068779d340785c635ce upstream.
This patch fixes a free after use in lio_target_make_nodeacl() where
iscsi_node_acl was referenced from the original se_nacl_new allocation,
instead of from core_tpg_add_initiator_node_acl() in the case of dynamic
-> explict NodeACL conversion.
commit d335e6054db616bce3f040e659fa38440518ad1d upstream.
Make iscsit_alloc_buffs() failure case for page_alloc_failed use correct
__free_page() SGL pointer, and return -ENOMEM for iscsit_allocate_iovecs
failure to push se_cmd->t_mem_sg release into iscsit_release_cmd()
callback during iscsit_add_reject_from_cmd() connection reset.
Also drop cmd->t_mem_sg = NULL assignment from page_alloc_failed
failure case.
Reported-by: Roland Dreier <roland@purestorage.com>
commit 6cf3fa6918baab0c447f1206f1cef9166ad04864 upstream.
If the target core signals an over- or under-run, tcm_loop should call
scsi_set_resid() to tell the SCSI midlayer about the residual data length.
The difference can be seen by doing something like
strace -eioctl sg_raw -r 1024 /dev/sda 8 0 0 0 1 0 > /dev/null
and looking at the "resid=" part of the SG_IO ioctl -- after this patch,
the field is correctly reported as 512.
commit 273b72c8ce6b28df6b49423d775c3e59072c73c5 upstream.
PXA's SSP engine fails to take its current channel phase into account
when enabling a stream while the engine is already running. This
results in randomly swapped left/right channels on either the record
or the playback side, depending on which one was enabled first.
The following patch fixes this by factoring out the bit field
modifications in question to a separate function that pauses the
engine temporarily, modifies the bits and kicks it off again
afterwards. Appearantly, a transition of SSCR0_SSE syncs both
directions properly.
The patch has been rolled out to quite a number of devices over the
last weeks and seems to fix the issue reliably.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Reported-and-tested-by: Sven Neumann <s.neumann@raumfeld.com>
commit 70ac07bb633dee75ac554195b9a4d69adfa7803c upstream.
The WM8776 codec driver requires the machine driver to set one of the
SND_SOC_DAIFMT_CBx_xxx values. The P1022DS machine driver should be setting
SND_SOC_DAIFMT_CBM_CFM, but since that value was zero, no one noticed.
Commit 75d9ac46 ("ASoC: Allow DAI formats to be specified in the
dai_link"), however, changed the value of SND_SOC_DAIFMT_CBM_CFM from zero
to a non-zero value, which means that it now needs to be specifically set
by the machine driver.
We also set SND_SOC_DAIFMT_NB_NF, for the same reason.
commit a05b0855fd15504972dba2358e5faa172a1e50ba upstream.
Taking i_mutex in hugetlbfs_read() can result in deadlock with mmap as
explained below
Thread A:
read() on hugetlbfs
hugetlbfs_read() called
i_mutex grabbed
hugetlbfs_read_actor() called
__copy_to_user() called
page fault is triggered
Thread B, sharing address space with A:
mmap() the same file
->mmap_sem is grabbed on task_B->mm->mmap_sem
hugetlbfs_file_mmap() is called
attempt to grab ->i_mutex and block waiting for A to give it up
Thread A:
pagefault handled blocked on attempt to grab task_A->mm->mmap_sem,
which happens to be the same thing as task_B->mm->mmap_sem. Block waiting
for B to give it up.
AFAIU the i_mutex locking was added to hugetlbfs_read() as per
http://lkml.indiana.edu/hypermail/linux/kernel/0707.2/3066.html to take
care of the race between truncate and read. This patch fixes this by
looking at page->mapping under lock_page() (find_lock_page()) to ensure
that the inode didn't get truncated in the range during a parallel read.
Ideally we can extend the patch to make sure we don't increase i_size in
mmap. But that will break userspace, because applications will now have
to use truncate(2) to increase i_size in hugetlbfs.
Based on the original patch from Hillf Danton.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Hillf Danton <dhillf@gmail.com>
commit f5bf18fa22f8c41a13eb8762c7373eb3a93a7333 upstream.
While testing AMS (Active Memory Sharing) / CMO (Cooperative Memory
Overcommit) on powerpc, we tripped the following:
kernel BUG at mm/bootmem.c:483!
cpu 0x0: Vector: 700 (Program Check) at [c000000000c03940]
pc: c000000000a62bd8: .alloc_bootmem_core+0x90/0x39c
lr: c000000000a64bcc: .sparse_early_usemaps_alloc_node+0x84/0x29c
sp: c000000000c03bc0
msr: 8000000000021032
current = 0xc000000000b0cce0
paca = 0xc000000001d80000
pid = 0, comm = swapper
enter ? for help
[c000000000c03c80] c000000000a64bcc
[c000000000c03d50] c000000000a64f10 .sparse_init+0x12c/0x28c
[c000000000c03e20] c000000000a474f4 .setup_arch+0x20c/0x294
[c000000000c03ee0] c000000000a4079c .start_kernel+0xb4/0x460
[c000000000c03f90] c000000000009670 .start_here_common+0x1c/0x2c
This is
BUG_ON(limit && goal + size > limit);
and after some debugging, it seems that
goal = 0x7ffff000000
limit = 0x80000000000
and sparse_early_usemaps_alloc_node ->
sparse_early_usemaps_alloc_pgdat_section calls
return alloc_bootmem_section(usemap_size() * count, section_nr);
This is on a system with 8TB available via the AMS pool, and as a quirk
of AMS in firmware, all of that memory shows up in node 0. So, we end
up with an allocation that will fail the goal/limit constraints.
In theory, we could "fall-back" to alloc_bootmem_node() in
sparse_early_usemaps_alloc_node(), but since we actually have HOTREMOVE
defined, we'll BUG_ON() instead. A simple solution appears to be to
unconditionally remove the limit condition in alloc_bootmem_section,
meaning allocations are allowed to cross section boundaries (necessary
for systems of this size).
Johannes Weiner pointed out that if alloc_bootmem_section() no longer
guarantees section-locality, we need check_usemap_section_nr() to print
possible cross-dependencies between node descriptors and the usemaps
allocated through it. That makes the two loops in
sparse_early_usemaps_alloc_node() identical, so re-factor the code a
bit.
[akpm@linux-foundation.org: code simplification]
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Anton Blanchard <anton@au1.ibm.com>
Cc: Ben Herrenschmidt <benh@kernel.crashing.org>
Cc: Robert Jennings <rcj@linux.vnet.ibm.com>
commit cc85b20780562d404e18a47b9b55b4a5102ae53e upstream.
During system suspend pm_genpd_suspend_noirq() checks if the given
device is in a wakeup path (i.e. it appears to be needed for one or
more wakeup devices to work or is a wakeup device itself) and if it
needs to be "active" for wakeup to work. If that is the case, the
function returns 0 without incrementing the device domain's counter
of suspended devices and without executing genpd_stop_dev() for the
device. In consequence, the device is not stopped (e.g. its clock
isn't disabled) and power is always supplied to its domain in the
resulting system sleep state.
However, pm_genpd_resume_noirq() doesn't repeat that check and it
runs genpd_start_dev() and decrements the domain's counter of
suspended devices even for the wakeup device that weren't stopped by
pm_genpd_suspend_noirq(). As a result, the start callback may be run
unnecessarily for them and their domains' counters of suspended
devices may become negative. Both outcomes aren't desirable, so fix
pm_genpd_resume_noirq() to look for wakeup devices that might not be
stopped by during system suspend.
Tested-by: Simon Horman <horms@verge.net.au>
commit 3ab1aff89477dafb1aaeafe8c8669114a02b7226 upstream.
Commit 3321c07ae5068568cd61ac9f4ba749006a7185c9 correctly clears the TPM
buffer if the user specified read length is >= the TPM buffer length. However,
if the user specified read length is < the TPM buffer length, then part of the
TPM buffer is left uncleared.
Reported-by: Seth Forshee <seth.forshee@canonical.com>
Cc: Debora Velarde <debora@linux.vnet.ibm.com>
Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
Cc: Marcel Selhorst <m.selhorst@sirrix.com>
Cc: tpmdd-devel@lists.sourceforge.net
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
commit 1a5a9906d4e8d1976b701f889d8f35d54b928f25 upstream.
In some cases it may happen that pmd_none_or_clear_bad() is called with
the mmap_sem hold in read mode. In those cases the huge page faults can
allocate hugepmds under pmd_none_or_clear_bad() and that can trigger a
false positive from pmd_bad() that will not like to see a pmd
materializing as trans huge.
It's not khugepaged causing the problem, khugepaged holds the mmap_sem
in write mode (and all those sites must hold the mmap_sem in read mode
to prevent pagetables to go away from under them, during code review it
seems vm86 mode on 32bit kernels requires that too unless it's
restricted to 1 thread per process or UP builds). The race is only with
the huge pagefaults that can convert a pmd_none() into a
pmd_trans_huge().
Effectively all these pmd_none_or_clear_bad() sites running with
mmap_sem in read mode are somewhat speculative with the page faults, and
the result is always undefined when they run simultaneously. This is
probably why it wasn't common to run into this. For example if the
madvise(MADV_DONTNEED) runs zap_page_range() shortly before the page
fault, the hugepage will not be zapped, if the page fault runs first it
will be zapped.
Altering pmd_bad() not to error out if it finds hugepmds won't be enough
to fix this, because zap_pmd_range would then proceed to call
zap_pte_range (which would be incorrect if the pmd become a
pmd_trans_huge()).
The simplest way to fix this is to read the pmd in the local stack
(regardless of what we read, no need of actual CPU barriers, only
compiler barrier needed), and be sure it is not changing under the code
that computes its value. Even if the real pmd is changing under the
value we hold on the stack, we don't care. If we actually end up in
zap_pte_range it means the pmd was not none already and it was not huge,
and it can't become huge from under us (khugepaged locking explained
above).
All we need is to enforce that there is no way anymore that in a code
path like below, pmd_trans_huge can be false, but pmd_none_or_clear_bad
can run into a hugepmd. The overhead of a barrier() is just a compiler
tweak and should not be measurable (I only added it for THP builds). I
don't exclude different compiler versions may have prevented the race
too by caching the value of *pmd on the stack (that hasn't been
verified, but it wouldn't be impossible considering
pmd_none_or_clear_bad, pmd_bad, pmd_trans_huge, pmd_none are all inlines
and there's no external function called in between pmd_trans_huge and
pmd_none_or_clear_bad).
if (pmd_trans_huge(*pmd)) {
if (next-addr != HPAGE_PMD_SIZE) {
VM_BUG_ON(!rwsem_is_locked(&tlb->mm->mmap_sem));
split_huge_page_pmd(vma->vm_mm, pmd);
} else if (zap_huge_pmd(tlb, vma, pmd, addr))
continue;
/* fall through */
if (pmd_none_or_clear_bad(pmd))
Because this race condition could be exercised without special
privileges this was reported in CVE-2012-1179.
The race was identified and fully explained by Ulrich who debugged it.
I'm quoting his accurate explanation below, for reference.
====== start quote =======
mapcount 0 page_mapcount 1
kernel BUG at mm/huge_memory.c:1384!
At some point prior to the panic, a "bad pmd ..." message similar to the
following is logged on the console:
mm/memory.c:145: bad pmd ffff8800376e1f98(80000000314000e7).
The "bad pmd ..." message is logged by pmd_clear_bad() before it clears
the page's PMD table entry.
143 void pmd_clear_bad(pmd_t *pmd)
144 {
-> 145 pmd_ERROR(*pmd);
146 pmd_clear(pmd);
147 }
After the PMD table entry has been cleared, there is an inconsistency
between the actual number of PMD table entries that are mapping the page
and the page's map count (_mapcount field in struct page). When the page
is subsequently reclaimed, __split_huge_page() detects this inconsistency.
1381 if (mapcount != page_mapcount(page))
1382 printk(KERN_ERR "mapcount %d page_mapcount %d\n",
1383 mapcount, page_mapcount(page));
-> 1384 BUG_ON(mapcount != page_mapcount(page));
The root cause of the problem is a race of two threads in a multithreaded
process. Thread B incurs a page fault on a virtual address that has never
been accessed (PMD entry is zero) while Thread A is executing an madvise()
system call on a virtual address within the same 2 MB (huge page) range.
virtual address space
| | |<-- B(fault)
2 MB | |/////////////////////|-.
huge < |/////////////////////| > A(range)
page | |/////////////////////|-'
- Thread A is executing an madvise(..., MADV_DONTNEED) system call
on the virtual address range "A(range)" shown in the picture.
sys_madvise
// Acquire the semaphore in shared mode.
down_read(¤t->mm->mmap_sem)
madvise_vma
switch (behavior)
case MADV_DONTNEED:
madvise_dontneed
zap_page_range
unmap_vmas
unmap_page_range
zap_pud_range
zap_pmd_range
// Assume that this huge page has never been accessed.
// I.e. content of the PMD entry is zero (not mapped).
// We don't get here due to the above assumption.
// Assume that Thread B incurred a page fault and
.---------> // sneaks in here as shown below.
| if (unlikely(pmd_bad(*pmd)))
| pmd_clear_bad
| pmd_ERROR
| // Log "bad pmd ..." message here.
| pmd_clear
| // Clear the page's PMD entry.
| // Thread B incremented the map count
| // in page_add_new_anon_rmap(), but
| // now the page is no longer mapped
| // by a PMD entry (-> inconsistency).
v
- Thread B is handling a page fault on virtual address "B(fault)" shown
in the picture.
do_page_fault
__do_page_fault
down_read_trylock(&mm->mmap_sem)
handle_mm_fault
if (pmd_none(*pmd) && transparent_hugepage_enabled(vma))
// We get here due to the above assumption (PMD entry is zero).
do_huge_pmd_anonymous_page
alloc_hugepage_vma
// Allocate a new transparent huge page here.
__do_huge_pmd_anonymous_page
spin_lock(&mm->page_table_lock)
// Here we increment the page's map count (starts at -1).
atomic_set(&page->_mapcount, 0)
set_pmd_at
// Here we set the page's PMD entry which will be cleared
// when Thread A calls pmd_clear_bad().
spin_unlock(&mm->page_table_lock)
The mmap_sem does not prevent the race because both threads are acquiring
it in shared mode (down_read). Thread B holds the page_table_lock while
the page's map count and PMD table entry are updated. However, Thread A
does not synchronize on that lock.
====== end quote =======
[akpm@linux-foundation.org: checkpatch fixes]
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Dave Jones <davej@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Cc: Mark Salter <msalter@redhat.com>
commit 73d63d038ee9f769f5e5b46792d227fe20e442c5 upstream.
With the recent changes to clear_IO_APIC_pin() which tries to
clear remoteIRR bit explicitly, some of the users started to see
"Unable to reset IRR for apic .." messages.
Close look shows that these are related to bogus IO-APIC entries
which return's all 1's for their io-apic registers. And the
above mentioned error messages are benign. But kernel should
have ignored such io-apic's in the first place.
Check if register 0, 1, 2 of the listed io-apic are all 1's and
ignore such io-apic.
Reported-by: Álvaro Castillo <midgoon@gmail.com>
Tested-by: Jon Dufresne <jon@jondufresne.org>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: yinghai@kernel.org
Cc: kernel-team@fedoraproject.org
Cc: Josh Boyer <jwboyer@redhat.com>
Link: http://lkml.kernel.org/r/1331577393.31585.94.camel@sbsiddha-desk.sc.intel.com
[ Performed minor cleanup of affected code. ]
commit f4a0391dfa91155bd961673b31eb42d9d45c799d upstream.
Fix the following build warning:
warning: (IMA) selects TCG_TPM which has unmet direct dependencies
(HAS_IOMEM && EXPERIMENTAL)
Suggested-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
commit 89e984e2c2cd14f77ccb26c47726ac7f13b70ae8 upstream.
An iser target may send iscsi NO-OP PDUs as soon as it marks the iSER
iSCSI session as fully operative. This means that there is window
where there are no posted receive buffers on the initiator side, so
it's possible for the iSER RC connection to break because of RNR NAK /
retry errors. To fix this, rely on the flags bits in the login
request to have FFP (0x3) in the lower nibble as a marker for the
final login request, and post an initial chunk of receive buffers
before sending that login request instead of after getting the login
response.
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
commit 48752f6513012a1b078da08b145d5c40a644f058 upstream.
Add VF spoof check to IFLA policy. The original patch I submitted to
add the spoof checking feature to rtnl failed to add the proper policy
rule that identifies the data type and len. This patch corrects that
oversight. No bugs have been reported against this but it may cause
some problem for the netlink message parsing that uses the policy
table.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Tested-by: Sibai Li <sibai.li@intel.com>
commit 62ebeed8d00aef75eac4fd6c161cae75a41965ca upstream.
This makes it possible to reload driver if insmod has failed due to
missing firmware.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
commit 41c7f7424259ff11009449f87c95656f69f9b186 upstream.
Currently, the RTC code does not disable the alarm in the hardware.
This means that after a sequence such as the one below (the files are in the
RTC sysfs), the box will boot up after 2 minutes even though we've
asked for the alarm to be turned off.
# echo $((`cat since_epoch`)+120) > wakealarm
# echo 0 > wakealarm
# poweroff
Fix this by disabling the alarm when there are no timers to run.
The original version of this patch was reverted. This version
disables the irq directly instead of setting a disabled timer
in the future.
Cc: John Stultz <john.stultz@linaro.org>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
[Merged in the second revision from Rabin]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 540b60e24f3f4781d80e47122f0c4486a03375b8 upstream.
We do not want a bitwise AND between boolean operands
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Link: http://lkml.kernel.org/r/20120309135912.GA2114@dhcp-26-207.brq.redhat.com
commit a09b659cd68c10ec6a30cb91ebd2c327fcd5bfe5 upstream.
In 2008, commit 0c5d1eb77a8be ("genirq: record trigger type") modified the
way set_irq_type() handles the 'no trigger' condition. However, this has
an adverse effect on PCMCIA support on Intel StrongARM and probably PXA
platforms.
PCMCIA has several status signals on the socket which can trigger
interrupts; some of these status signals depend on the card's mode
(whether it is configured in memory or IO mode). For example, cards have
a 'Ready/IRQ' signal: in memory mode, this provides an indication to
PCMCIA that the card has finished its power up initialization. In IO
mode, it provides the device interrupt signal. Other status signals
switch between on-board battery status and loud speaker output.
In classical PCMCIA implementations, where you have a specific socket
controller, the controller provides a method to mask interrupts from the
socket, and importantly ignore any state transitions on the pins which
correspond with interrupts once masked. This masking prevents unwanted
events caused by the removal and application of socket power being
forwarded.
However, on platforms where there is no socket controller, the PCMCIA
status and interrupt signals are routed to standard edge-triggered GPIOs.
These GPIOs can be configured to interrupt on rising edge, falling edge,
or never. This is where the problems start.
Edge triggered interrupts are required to record events while disabled via
the usual methods of {free,request,disable,enable}_irq() to prevent
problems with dropped interrupts (eg, the 8390 driver uses disable_irq()
to defer the delivery of interrupts). As a result, these interfaces can
not be used to implement the desired behaviour.
The side effect of this is that if the 'Ready/IRQ' GPIO is disabled via
disable_irq() on suspend, and enabled via enable_irq() after resume, we
will record the state transitions caused by powering events as valid
interrupts, and foward them to the card driver, which may attempt to
access a card which is not powered up.
This leads delays resume while drivers spin in their interrupt handlers,
and complaints from drivers before they realize what's happened.
Moreover, in the case of the 'Ready/IRQ' signal, this is requested and
freed by the card driver itself; the PCMCIA core has no idea whether the
interrupt is requested, and, therefore, whether a call to disable_irq()
would be valid. (We tried this around 2.4.17 / 2.5.1 kernel era, and
ended up throwing it out because of this problem.)
Therefore, it was decided back in around 2002 to disable the edge
triggering instead, resulting in all state transitions on the GPIO being
ignored. That's what we actually need the hardware to do.
The commit above changes this behaviour; it explicitly prevents the 'no
trigger' state being selected.
The reason that request_irq() does not accept the 'no trigger' state is
for compatibility with existing drivers which do not provide their desired
triggering configuration. The set_irq_type() function is 'new' and not
used by non-trigger aware drivers.
Therefore, revert this change, and restore previously working platforms
back to their former state.
Cc: linux@arm.linux.org.uk
commit 7b60a18da393ed70db043a777fd9e6d5363077c4 upstream.
The queue handling in the udev daemon assumes that the events are
ordered.
Before this patch uevent_seqnum is incremented under sequence_lock,
than an event is send uner uevent_sock_mutex. I want to say that code
contained a window between incrementing seqnum and sending an event.
This patch locks uevent_sock_mutex before incrementing uevent_seqnum.
v2: delete sequence_lock, uevent_seqnum is protected by uevent_sock_mutex
v3: unlock the mutex before the goto exit
Thanks for Kay for the comments.
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Tested-By: Kay Sievers <kay.sievers@vrfy.org>
commit a078c6d0e6288fad6d83fb6d5edd91ddb7b6ab33 upstream.
'long secs' is passed as divisor to div_s64, which accepts a 32bit
divisor. On 64bit machines that value is trimmed back from 8 bytes
back to 4, causing a divide by zero when the number is bigger than
(1 << 32) - 1 and all 32 lower bits are 0.
Use div64_long() instead.
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Cc: johnstul@us.ibm.com
Link: http://lkml.kernel.org/r/1331829374-31543-2-git-send-email-levinsasha928@gmail.com
commit f910381a55cdaa097030291f272f6e6e4380c39a upstream.
Add a div64_long macro which is used to devide a 64bit number by a long (which
can be 4 bytes on 32bit systems and 8 bytes on 64bit systems).
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Link: http://lkml.kernel.org/r/1331829374-31543-1-git-send-email-levinsasha928@gmail.com
commit 342bbf3fee2fa9a18147e74b2e3c4229a4564912 upstream.
If we only monitor while associated, the following
can happen:
- we're associated, and the queue stuck check
runs, setting the queue "touch" time to X
- we disassociate, stopping the monitoring,
which leaves the time set to X
- almost 2s later, we associate, and enqueue
a frame
- before the frame is transmitted, we monitor
for stuck queues, and find the time set to
X, although it is now later than X + 2000ms,
so we decide that the queue is stuck and
erroneously restart the device
It happens more with P2P because there we can
go between associated/unassociated frequently.
Reported-by: Ben Cahill <ben.m.cahill@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
commit a9b89e2567c743483e6354f64d7a7e3a8c101e9e upstream.
Driver rtl8192ce when used with the RTL8188CE device would start at about
20 Mbps on a 54 Mbps connection, but quickly drop to 1 Mbps. One of the
symptoms is that the AP would need to retransmit each packet 4 of 5 times
before the driver would acknowledge it. Recovery is possible only by
unloading and reloading the driver. This problem was reported at
https://bugzilla.redhat.com/show_bug.cgi?id=770207.
The problem is due to a missing update of the gain setting.
Signed-off-by: Jingjun Wu <jingjun_wu@realsil.com.cn>
commit ebecdcc12fed5d3c81853dea61a0a78a5aefab52 upstream.
When driver rtl8192cu is used with the debug level set to 3 or greater,
the result is "sleeping function called from invalid context" due to
an rcu_read_lock() call in the DM refresh routine in driver rtl8192c.
This lock is not necessary as the USB driver does not use the struct
being protected, thus the lock is set only when a PCI interface is
active.
This bug is reported in https://bugzilla.kernel.org/show_bug.cgi?id=42775.
Reported-by: Ronald Wahl <ronald.wahl@raritan.com>
Tested-by: Ronald Wahl <ronald.wahl@raritan.com>
Cc: Ronald Wahl <ronald.wahl@raritan.com>
commit 7f66c2f93e5779625c10d262c84537427a2673ca upstream.
Handle previous allocation failures when freeing device memory
Signed-off-by: Simon Graham <simon.graham@virtualcomputer.com>
commit 76a92be537f1c8c259e393632301446257ca3ea9 upstream.
In https://bugzilla.redhat.com/show_bug.cgi?id=771656, a kernel bug was
triggered due to a failed skb allocation that was not checked. This event
lead to an audit of all memory allocations in the complete rtlwifi family
of drivers. This patch fixes the rest.
commit d42a179b941a9e4cc6cf41d0f3cbadd75fc48a89 upstream.
This is an RT3070 based device.
Reported-by: Mikhail Kryshen <mikhail@kryshen.net>
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
commit 093ea2d3a766cb8a4c4de57efec6c0a127a58792 upstream.
A MCS7820 device supports two serial ports and a MCS7840 device supports
four serial ports. Both devices use the same driver, but the attach function
in driver was unable to correctly handle the port numbers for MCS7820
device. This problem has been fixed in this patch and this fix has been
verified on x86 Linux kernel 3.2.9 with both MCS7820 and MCS7840 devices.
Signed-off-by: Donald Lee <donald@asix.com.tw>
commit a5360a53a7ccad5ed9ccef210b94fef13c6e5529 upstream.
This patch updates the cp210x driver to support CP210x multiple
interface devices devices from Silicon Labs. The existing driver
always sends control requests to interface 0, which is hardcoded in
the usb_control_msg function calls. This only allows for single
interface devices to be used, and causes a bug when using ports on an
interface other than 0 in the multiple interface devices.
Here are the changes included in this patch:
- Updated the device list to contain the Silicon Labs factory default
VID/PID for multiple interface CP210x devices
- Created a cp210x_port_private struct created for each port on
startup, this struct holds the interface number
- Added a cp210x_release function to clean up the cp210x_port_private
memory created on startup
- Modified usb_get_config and usb_set_config to get a pointer to the
cp210x_port_private struct, and use the interface number there in the
usb_control_message wIndex param
Signed-off-by: Preston Fick <preston.fick@silabs.com>
