2008-05-20s390: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20SOUND: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20UIO: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20Power Supply: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Anton Vorontsov <cbou@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20LEDS: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20IB: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Reviewed-by: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20ide: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20fbdev: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20mm: bdi: fix race in bdi_class device creationGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_vargs(). Many thanks to Arthur Jones <ajones@riverbed.com> for reporting the bug, and testing patches out. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Arthur Jones <ajones@riverbed.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20Driver core: add device_create_vargs and device_create_drvdataGreg Kroah-Hartman
We want to have the drvdata field set properly when creating the device as sysfs callbacks can assume it is present and it can race the later setting of this field. So, create two new functions, deviec_create_vargs() and device_create_drvdata() that take this new field. device_create_drvdata() will go away in 2.6.27 as the drvdata field will just be moved to the device_create() call as it should be. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: prevent userspace from accessing shut down devices ieee1394: sbp2: use correct size of command descriptor block
2008-05-20Fix a deadlock in the bttv driverArjan van de Ven
vidiocgmbuf() does this: mutex_lock(&fh->cap.vb_lock); retval = videobuf_mmap_setup(&fh->cap, gbuffers, gbufsize, V4L2_MEMORY_MMAP); and videobuf_mmap_setup() then just does mutex_lock(&q->vb_lock); ret = __videobuf_mmap_setup(q, bcount, bsize, memory); mutex_unlock(&q->vb_lock); which is an obvious double-take deadlock. This patch fixes this by having vidiocgmbuf() just call the __videobuf_mmap_setup function instead. Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Reported-by: Koos Vriezen <koos.vriezen@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20firewire: prevent userspace from accessing shut down devicesJay Fenlason
If userspace ignores the POLLERR bit from poll(), and only attempts to read() the device when POLLIN is set, it can still make ioctl() calls on a device that has been removed from the system. The node_id and generation returned by GET_INFO will be outdated, but INITIATE_BUS_RESET would still cause a bus reset, and GET_CYCLE_TIMER will return data. And if you guess the correct generation to use, you can send requests to a different device on the bus, and get responses back. This patch prevents open, ioctl, compat_ioctl, and mmap against shutdown devices. Signed-off-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-05-20ieee1394: sbp2: use correct size of command descriptor blockStefan Richter
Boaz Harrosh wrote: > cmd->cmd_len is now guarantied to be set properly at all cases. > And some commands you want to support will not be set correctly > by COMMAND_SIZE(). Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: [ALSA] hda - Fix ASUS P5GD1 model [ALSA] hda - Fix ALC262 fujitsu model snd-pcsp: use HRTIMER_CB_SOFTIRQ
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: remove CVS keywords HID: Add iMON LCDs to blacklist HID: add Microchip PICKit 1 and PICkit 2 to blacklist HID: split Numlock emulation quirk from HID_QUIRK_APPLE_HAS_FN.
2008-05-20Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Update defconfigs for desktop/server systems [POWERPC] Fix mpc8377_mds.dts DMA nodes to match spec [POWERPC] Update arch/powerpc/boot/.gitignore [POWERPC] Remove generated files on make clean [POWERPC] powerpc/mm/hash_low_32.S: Remove CVS keyword [POWERPC] Update Cell MAINTAINERS entry, add spufs entry lmb: Fix compile warning
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes: [GFS2] Prefer strlcpy() over snprintf() [GFS2] Fix cast from unsigned int to s64 [GFS2] filesystem consistency error from do_strip
2008-05-20x86: strengthen 64-bit p?d_bad()Hugh Dickins
The x86_64 pgd_bad(), pud_bad(), pmd_bad() inlines have differed from their x86_32 counterparts in a couple of ways: they've been unnecessarily weak (e.g. letting 0 or 1 count as good), and were typed as unsigned long. Strengthen them and return int. The PAE pmd_bad was too weak before, allowing any junk in the upper half; but got strengthened by the patch correcting its ~PAGE_MASK to ~PTE_MASK. The PAE pud_bad already said ~PTE_MASK; and since it folds into pgd_bad, and we don't set the protection bits at that level, it'll do as is. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20xen: use PTE_MASK in pte_mfn()Jeremy Fitzhardinge
Use PTE_MASK to extract mfn from pte. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: use PTE_MASK rather than ad-hoc maskJeremy Fitzhardinge
Use ~PTE_MASK to extract the non-pfn parts of the pte (ie, the pte flags), rather than constructing an ad-hoc mask. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: clarify use of _PAGE_CHG_MASKJeremy Fitzhardinge
_PAGE_CHG_MASK is defined as the set of bits not updated by pte_modify(); specifically, the pfn itself, and the Accessed and Dirty bits (which are updated by hardware). Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: use PTE_MASK in pgtable_32.hJeremy Fitzhardinge
2008-05-20x86: use PTE_MASK in 32-bit PAEJeremy Fitzhardinge
Use PTE_MASK in 3-level pagetables (ie, 32-bit PAE). Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: rearrange __(VIRTUAL|PHYSICAL)_MASKJeremy Fitzhardinge
Put the definitions of __(VIRTUAL|PHYSICAL)_MASK before their uses. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: fix warning on 32-bit non-PAEJeremy Fitzhardinge
Fix the warning: include2/asm/pgtable.h: In function `pte_modify': include2/asm/pgtable.h:290: warning: left shift count >= width of type On 32-bit PAE the virtual and physical addresses are both 32-bits, so it ends up evaluating 1<<32. Do the shift as a 64-bit shift then cast to the appropriate size. This should all be done at compile time, and so have no effect on generated code. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20x86: define PTE_MASK in a universally useful wayJeremy Fitzhardinge
Define PTE_MASK so that it contains a meaningful value for all x86 pagetable configurations. Previously it was defined as a "long" which means that it was too short to cover a 32-bit PAE pte entry. It is now defined as a pteval_t, which is an integer type long enough to contain a full pte (or pmd, pud, pgd). This fixes an Xorg crash on 32-bit x86 with PAE due to corruption of the NX bit in mprotect due to the incorrect type/value of PTE_MASK reported by Hugh Dickins: "Yes, thanks Jeremy: I've checked that each stage builds and runs X on my boxes here, x86_32 and x86_32+PAE and x86_64. (So even 1/8 is enough to fix the PAT pte_modify issue, though 2/8 then fixes compiler warnings.)" Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20HID: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-05-20HID: Add iMON LCDs to blacklistDylan R Semler
The new iMON LCDs from SoundGraph need to be blacklisted from HID in order to be used by lirc. Signed-off-by: Dylan R Semler <dylan.semler@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-05-20HID: add Microchip PICKit 1 and PICkit 2 to blacklistXiaofan Chen
Microchip PICkit 1 and PICKit 2 USB Programmers are USB HID class of device but they are not real HID device. They are now supported by libusb based programs like the following programs. pk2 and pk2cmd Linux port: http://home.pacbell.net/theposts/picmicro/ usb_pickit: http://tfc.duke.free.fr/pickit.html usb_pickit original version: http://charm.cs.uiuc.edu/users/olawlor/projects/2003/microchip/ Therefore it ispreferred to blacklist them. Signed-off-by: Xiaofan Chen <xiaofanc@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-05-20HID: split Numlock emulation quirk from HID_QUIRK_APPLE_HAS_FN.Diego 'Flameeyes' Petteno
Since 2.6.25 the HID_QUIRK_APPLE_HAS_FN quirk is enabled even for non-laptop Apple keyboards of the Aluminium series. The USB version of these don't need Numlock emulation, like the laptop (and Aluminium Wireless) do, as they have a proper keypad. This patch splits the Numlock emulation for Apple keyboards in a different quirk flag, so that it can be enabled for all the keyboards but the Aluminium USB ones. If the Numlock emulation is enabled for Aluminium USB keyboards, the JKL and UIO keys become the numeric pad, and the rest of the keyboard is disabled, included the key used to disable Numlock. Additionally, these keyboard should not have a Numlock at all, as the Numlock key is instead replaced by the 'Clear' key as usual for Apple USB keyboards. Signed-off-by: Diego 'Flameeyes' Petteno <flameeyes@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-05-20[POWERPC] Update defconfigs for desktop/server systemsPaul Mackerras
2008-05-20[ALSA] hda - Fix ASUS P5GD1 modelTravis Place
Corrected the model assignment for the ASUS P5GD1 w/SPDIF after reports of surround sound not being possible. Signed-off-by: Travis Place <wishie@wishie.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-20[ALSA] hda - Fix ALC262 fujitsu modelTakashi Iwai
Fixed the speaker auto-mute with two laptop and docking headphones. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Tony Vroon <tony@linx.net>
2008-05-20snd-pcsp: use HRTIMER_CB_SOFTIRQStas Sergeev
Change HRTIMER_CB_IRQSAFE to HRTIMER_CB_SOFTIRQ, as suggested by Thomas Gleixner. That solves the lock dependancy reported in Bug #10701. That also allows to call hrtimer_start() directly, tasklet "stupid hack" removed. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-20Merge branch 'for-2.6.26' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into merge
2008-05-20[POWERPC] Fix mpc8377_mds.dts DMA nodes to match specKumar Gala
2008-05-20[POWERPC] Update arch/powerpc/boot/.gitignoreKumar Gala
* Add dtbImage.* * Added zImage.holly * Folded zImage.coff.lds into zImage.*lds * Removed some unused zImage.<foo> ignores Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-05-20[POWERPC] Remove generated files on make cleanKumar Gala
dtbImage.* and several zImage. targets get created but never cleaned up. Also, moved zImage to the clean-files line associated with all other image results (was previously duplicated). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-05-19Merge branch 'for-linus' of ↵tip-x86-numa-fixes-2008-05-26_08_53_MonLinus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: at91_mci: minor cleanup mmc: mmc host test driver mmc: Fix omap compile by replacing dev_name with dma_dev_name
2008-05-19Add maintainers for myri10ge driverBrice Goglin
Add a MAINTAINERS entry for the myri10ge driver. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-19Merge branch 'audit.b51' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b51' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] list_for_each_rcu must die: audit [patch 1/1] audit_send_reply(): fix error-path memory leak [PATCH] open sessionid permissions
2008-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] return to old errno choice in mkdir() et.al. [Patch] fs/binfmt_elf.c: fix wrong return values [PATCH] get rid of leak in compat_execve() [Patch] fs/binfmt_elf.c: fix a wrong free [PATCH] avoid multiplication overflows and signedness issues for max_fds [PATCH] dup_fd() part 4 - race fix [PATCH] dup_fd() - part 3 [PATCH] dup_fd() part 2 [PATCH] dup_fd() fixes, part 1 [PATCH] take init_files to fs/file.c
2008-05-19Merge branch 'for-2.6.26' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwboyer/powerpc-4xx * 'for-2.6.26' of git://git.kernel.org/pub/scm/linux/kernel/git/jwboyer/powerpc-4xx: [POWERPC] 4xx: Workaround for CHIP_11 Errata
2008-05-19MAINTAINERS needs further order fixingAlan Cox
2008-05-20[POWERPC] powerpc/mm/hash_low_32.S: Remove CVS keywordAdrian Bunk
This removes a CVS keyword that wasn't updated for a long time from a comment. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: Blackfin SPORTS UART Driver: converting BFIN->BLACKFIN Blackfin serial driver: add extra IRQ flag for 8250 serial driver 8250 Serial Driver: Added support for 8250-class UARTs in HV Sistemas H8606 board Blackfin arch: Fix bug - USB fails to build for BF524/BF526 Blackfin arch: update boards defconfig files Blackfin arch: IO Port functions to read/write unalligned memory Blackfin arch: enable a choice to provide 4M DMA memory Blackfin arch: cleanup the icplb/dcplb multiple hit checks Blackfin arch: Add workaround to read edge triggered GPIOs Blackfin arch: Sync channel defines with struct dma_register dma_io_base_addr. Blackfin arch: Check for Anomaly 05000182 [Blackfin] arch: rename bf5xx-flash to bfin-async-flash [Blackfin] arch: Blackfin checksum annotations
2008-05-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fix up restorer in debug_trap exception return path. sh: Make is_valid_bugaddr() more intelligent on nommu. sh: use the common ascii hex helpers sh: fix sh7785 master clock value sh: Fix up thread info pointer in syscall_badsys resume path. sh: Fix up optimized SH-4 memcpy on big endian. sh: disable initrd defaults in .empty_zero_page. sh: display boot params by default on entry.
2008-05-19Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (28 commits) drivers/ata: trim trailing whitespace Fixups to ATA ACPI hotplug libata: ignore SIMG4726 config pseudo device sata_sil24: don't use NCQ if marvell 4140 PMP is attached libata: don't schedule LPM action seperately during probing libata: make sure PMP notification is turned off during recovery libata: increase PMP register access timeout to 3s libata: ignore recovered PHY errors libata: kill hotplug related race condition libata: move reset freeze/thaw handling into ata_eh_reset() libata: reorganize ata_eh_reset() no reset method path libata: fix sata_link_hardreset() @online out parameter handling sata_promise: other cleanups sata_promise: mmio access cleanups sata_promise: fix irq clearing buglets ata: remove FIT() macro sata_mv: ensure empty request queue for FBS-NCQ EH sata_mv: cache main_irq_mask register in hpriv sata_mv: disregard masked irqs sata_mv: fix pmp drives not found ...
2008-05-20[POWERPC] Update Cell MAINTAINERS entry, add spufs entryArnd Bergmann
The MAINTAINERS file entry for the cell platform is outdated, even the name of the platform changed since the early days when it was initially submitted. The SPU file system is now maintained by Jeremy Kerr. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
