Use compare_ether_addr in bridge code.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Tejun Heo notes:
"I'm currently debugging this. The problem is that we are using the
generic dispatch queue directly in the noop sched and merging is NOT
allowed on dispatch queues but generic handling of last_merge tries
to merge requests. I'm still trying to verify this, so I'll be back
with results soon."
In the meantime, disable merging for noop by setting REQ_NOMERGE in
elevator_noop_add_request().
Eventually, we should add a noop_list and do the dispatching like in the
other io schedulers. Merging is still beneficial for noop (and it has
always done it).
Signed-off-by: Jens Axboe <axboe@suse.de>
Don't clear ->elevator_data on exit, if we are switching queues we are
overwriting the data of the new io scheduler.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
Manual #include fixups for clashes - there may be some unnecessary
The problem is that adbhid[]->input is NULL, so the kernel oopses with
a null pointer dereference as soon as a key is pressed.
A lot of power packed into a little patch.
This change eliminates the sharing between our controller-wide spinlock
and the SCSI core's Scsi_Host lock. As the locking in libata was
already highly compartmentalized, always referencing our own lock, and
never scsi_host::host_lock.
As a side effect, this change eliminates a deadlock from calling
scsi_finish_command() while inside our spinlock.
... namely, the change to the 2-argument pte_alloc_kernel.
Integrate ata_exec() and ata_tf_to_host() into their only caller,
ata_bus_edd().
Rename ata_tf_to_host_nolock() to ata_tf_to_host().
This makes locking a bit easier to review, and may help pave the way for
future changes.
We had a static memory_limit in prom.c, and then another one defined
in setup_64.c and used in numa.c, which resulted in the kernel crashing
when mem=xxx was given on the command line. This puts the declaration
in system.h and the definition in mem.c. This also moves the
definition of tce_alloc_start/end out of setup_64.c.
This patch removes duplicate directory scanning code from fs/fat/dir.c. The
two functions that share identical code are fat_readdirx() and
fat_search_long(). This patch also renames fat_readdirx to __fat_readdir().
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Now, vfat_rename() is using vfat_find() for sanity check. This removes that
sanity check, the cost of sanity check is too high.
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Combine a bit of redundant code between force_sig_info() and
force_sig_specific().
Signed-off-by: paulmck@us.ibm.com
This patch removes checks for ->si_code == SI_TIMER from send_signal,
specific_send_sig_info, __group_send_sig_info.
I think posix-timers.c used these functions some time ago, now it sends
signals via send_{,group_}sigqueue, so these hooks are unneeded.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
This patch simplifies some checks for magic siginfo values. It should not
change the behaviour in any way.
This patch replaces hardcoded SEND_SIG_xxx constants with
their symbolic names.
No changes in affected .o files.
- Use kzalloc() instead of kmalloc + memset.
- Clean/fix some printk's.
- Use NULL for pointers instead of 0.
- Combine hpet busy searching locations into a function call.
Signed-off-by: Randy Dunlap <randy_d_dunlap@linux.intel.com>
- Use HPET physical address to detect duplicates, not logical addresses.
Using logical (mapped) addresses fails to detect duplicates
because ioremap() returns a new mapped address each time.
- iounmap() regions when duplicate/busy areas are found.
Allow the ACPI HPET description table to use a resource type of FIXED_MEM32
for the HPET reource. Use the fixed resoure size of 1 KB for the HPET
resource as per the HPET spec.
Acked-by: Bob Picco <bob.picco@hp.com>
When booting, display the timer frequency in Hertz instead of as tick length
in nanoseconds. Apart from saving a local variable, this makes the message
more easily comprehensible.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Cc: Bob Picco <bob.picco@hp.com>
In the hpet_ioctl_common() function, devp->hd_hpets is already cached in the
hpetp variable, so we can use just that.
Fix two instances where a function would access the first HPET device instead
of the current one.
Clear the ht_opaque field in the hpet_register() function before searching for
a free timer to prevent the function from incorrectly assuming that the search
succeeded afterwards.
Fix a division by zero that happened when the HPET_INFO ioctl was called
before a timer frequency had been set.
Fix a wrong memory access in hpet_ioctl_common(). It was not possible to use
the HPET_INFO ioctl from kernel space because it always called copy_to_user().
Reads from an HPET register require a round trip to the south bridge and are
almost as slow as PCI reads. By caching the last value we've written to the
comparator register, we can eliminate all HPET reads from the fast path in the
emulated RTC interrupt handler.
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Make sure that the RTC timer is in non-periodic mode; some stupid BIOS might
have initialized it to periodic mode.
Furthermore, don't set the SETVAL bit in the config register. This wouldn't
have any effect unless the timer was in period mode (which it isn't), and then
the actual timer frequency would be half that of the desired one because
incrementing the comparator in the interrupt handler would be done after the
hardware has already incremented it itself.
When the emulated RTC interrupt is no longer needed, we better disable it;
otherwise, we get a spurious interrupt whenever the timer has rolled over and
reaches the same comparator value.
Having a superfluous interrupt every five minutes doesn't hurt much, but it's
bad style anyway. ;-)
Acked-by: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com>
Cc: Andi Kleen <ak@muc.de>
This patch adds support for shared HPET interrupts.
The driver previously acknowledged interrupts for both edge and level
interrupts, but didn't actually allow a shared interrupt in the latter case.
We use a new per-timer flag to save whether the timer's interrupt might be
shared, and use it to do the processing required for level interrupts only if
necessary.
It was only the RTC hardware that restricted interrupt frequencies to a power
of two. There is no reason to take over this restriction into the HPET
driver, so remove the offending check.
This patch removes several reads of a timer's config register that serve no
purpose whatsoever.
The variable hpet_ntimer is never read, so remove it.
On 32-bit architectures, the multiplication in the argument for
hpet_time_div() often overflows. In the typical case of a 14.32 MHz timer,
this happens when the desired frequency exceeds 61 Hz.
To avoid this multiplication, we can precompute and store the hardware
timer frequency, instead of the period, in the device structure, which
leaves us with a simple division when computing the number of timer ticks.
As a side effect, this also removes a theoretical bug where the timer
interpolator's frequency would be computed as a 32-bit value even if the
HPET frequency is greater than 2^32 Hz (the HPET spec allows up to 10 GHz).
Disallow setting an interrupt frequency of zero (which would result in a
division by zero), and disallow enabling the interrupt when the frequency
hasn't yet been set (which would use an interrupt period of zero).
Convert most of the remaining "Using plain integer as NULL pointer" sparse
warnings to use NULL. (Not duplicating patches that are already in -mm,
-bird, or -kj.)
Convert isdn driver struct initializer to use C99 syntax.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
