Add the new fcoe_transport.c file that implements basic fcoe transport
interface. Eventually, the sysfs entries to create/destroy/enable/disable
an FCoE instance will be coming to the fcoe transport layer, who does a
look-up to find the corresponding transport provide and pass the corresponding
action over to the identified provider.
The fcoe.ko will become the default fcoe transport provider that can support
FCoE on any given netdev interfaces, as the Open-FCoE.org's default software
FCoE HBA solution. Any vendor specific FCoE HBA driver that is built on top
of Open-FCoE's kernel stack of libfc & libfcoe as well as the user land tool
of fcoe-utils can easily plug-in and start running FCoE on their network
interfaces. The fcoe.ko will be converted to act as the default provider if
no vendor specific transport provider is found, as it is always added to the
very end of the list of attached transports.
Signed-off-by: Yi Zou <yi.zou@intel.com>
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
Signed-off-by: Robert Love <robert.w.love@intel.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
add the fcoe_transport struct to the common libfcoe.h header so all fcoe
transport provides can use it to attach itself as an fcoe transport. This
is the header part, and the next patch will be the transport code itself.
libfcoe kernel module debug macros will used by the fcoe transport code
as well when later it gets added.
selection logic.
Problem:
In case of exchange responder case, EMA selection was defaulted to the
last EMA from EMA list (lport.ema_list). If exchange ID is selected
from offload pool and not setup DDP, resulting into incorrect
selection of EMA, and eventually dropping the packet because unable to
find exchange.
Fix:
Enhanced the exchange ID selection (depending upon request type and
exchange responder) Made necessary enhancement in EMA selection
algorithm.
Signed-off-by: Kiran Patil <kiran.patil@intel.com>
Target modules using lport->tt.seq_assign() get a hold on the
exchange but have no way of releasing it. Add that.
Signed-off-by: Joe Eykholt <jeykholt@cisco.com>
This patch removes the use of the Scsi_Host's host_lock
within fc_queuecommand. It also removes the DEF_SCSI_QCMD
usage so that libfc has fully moved on to the new
queuecommand interface.
Tested-by: Ross Brattain <ross.b.brattain@intel.com>
Reviewed-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
When sending an outgoing PRLI as an initiator, get the parameters
from registered providers so that they all get a chance to decide
on roles.
The passive provider is called last, and could override the
initiator role.
When an SCST provider is registered, it needs to know what
local ports are available for configuration as targets.
Add a notifier chain that is invoked when any local port
that is added or deleted.
Maintain a global list of local ports and add an
interator function that calls a given function for
every existing local port. This is used when first
loading a provider.
The target provider needs a per-instance lookup table
or other way to lookup sessions quickly without going through
a linear list or serializing too much.
Add a simple void * array indexed by FC-4 type to the fc_lport.
Committed-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
Add a method for setting handler for incoming exchange.
For multi-sequence exchanges, this allows the target driver
to add a response handler for handling subsequent sequences,
and exchange manager resets.
The new function is called fc_seq_set_resp().
Allow FC-4 provider modules to hook into libfc, mostly for targets.
This should allow any FC-4 module to handle PRLI requests and maintain
process-association states.
Each provider registers its ops with libfc and then will be called for
any incoming PRLI for that FC-4 type on any instance. The provider
can decide whether to handle that particular instance using any method
it likes, such as ACLs or other configuration information.
A count is kept of the number of successful PRLIs from the remote port.
Providers are called back with an implicit PRLO when the remote port
is about to be deleted or has been reset.
fc_lport_recv_req() now sends incoming FC-4 requests to FC-4 providers,
and there is a built-in provider always registered for handling
incoming ELS requests.
The call to provider recv() routines uses rcu_read_lock()
so that providers aren't removed during the call. That lock is very
cheap and shouldn't affect any performance on ELS requests.
Providers can rely on the RCU lock to protect a session lookup as well.
Fix sparse warning for non-ANSI function declaration.
Declare workqueue structs as static.
Cc: Robert Love <robert.w.love@intel.com>
Allowing FCoE LOGO followed by CVL in this case prevents
FIP login back to the FCF and then keeps lport offline,
only FIP LOGO and CLV needs to be processed while in
FIP mode, therefore this patch drops FCoE LOGO in FIP mode.
Added fcoe_filter_frames() to filter out above mentioned LOGO
in fcoe rx path along with other existing filtering in code
for bad CRC frames. Adding separate fcoe_filter_frames function
helped with better code indentations and if needed then same
will allow adding more filters at one place in future.
This LOGO drop is added after FCP frames passed up to avoid
any additional checks on fast path for this.
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
vports are not grabbing module references but are
releasing them. This causes the module reference count
to decrement too many times and it wraps around past 0.
The solution is to do a module_put() in
fcoe_interface_release() so that the reference is only
released when the fcoe_interface is released. There is a
one-to-one relationship between the N_Port and the
fcoe_interface, so the module reference will only be
dropped when the N_Port is destroyed
To create symetry in the code this patch moves the
try_module_get() call into fcoe_interface_create(). This
means that only the N_Port will grab a reference to the
module when its corresponding fcoe_interface is created.
This patch also makes it so that the fcoe_interface_create()
routine encodes any error codes in the fcoe_interface
pointer returned. This way its caller, fcoe_create(), can
return an accurate error code.
Signed-off-by: Venkata Siva Vijayendra Bhamidipati <vbhamidi@cisco.com>
Fix memory leak arising due to incorrect freeing of allocated memory
for vnic stats when unregistering a vnic.
Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com>
If we goto out, then it tries to call kfree_skb() on an ERR_PTR which
will oops. Just return directly.
This patch makes it so that we only have one call to
fc_rport_error. This patch does not completely
consolidate return statements, there is still one return
used when not calling fc_rport_error, but alternative
solutions made the code more confusing.
[ Patch modified by Robert Love ]
[ Patch title and commit message edited by Robert Love
to make it more relevant ]
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Here ticks_left is added to record the result of
wait_for_completion_timeout().
[ Patch title and description edited by Robert Love
to make it more descriptive ]
FC_XID_UNKNOWN
The fsp's xfer_ddp is used as indication of the exchange id for the DDPed
I/O. We should always initialize it as FC_XID_UNKNOWN for a newly allocated
fsp, otherwise the fsp allocated in fc_fcp, i.e., not from queuecommand like
LUN RESET that is not doing DDP may still think DDP is setup for it since xid
0 is valid and goes on to call fc_fcp_ddp_done() in fc_fcp_resp() from
fc_tm_done(). So, set xfer_ddp as FC_XID_UNKNOWN in fc_fcp_pkt_alloc() now.
Also removes the setting of fsp->lp as it's already done when fsp is allocated.
Classify severity of I/O errors for target, nexus, and
transport errors.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Acked-by: Jens Axboe <jaxboe@fusionio.com>
DM now has more information about the nature of the underlying storage
failure. Path failure is avoided if a request failed due to a target
error. Instead the target error is immediately passed up the stack.
Discard requests that fail due to non-target errors may now be retried.
Errors restricted to the path will be retried or returned if no
paths are available, irregarding the no_path_retry setting.
Acked-by: Alasdair G Kergon <agk@redhat.com>
Instead of just passing 'EIO' for any I/O error we should be
notifying the upper layers with more details about the cause
of this error.
Update the possible I/O errors to:
- ENOLINK: Link failure between host and target
- EIO: Retryable I/O error
- EREMOTEIO: Non-retryable I/O error
- EBADE: I/O error restricted to the I_T_L nexus
'Retryable' in this context means that an I/O error _might_ be
restricted to the I_T_L nexus (vulgo: path), so retrying on another
nexus / path might succeed.
'Non-retryable' in general refers to a target failure, so this
error will always be generated regardless of the I_T_L nexus
it was send on.
I/O errors restricted to the I_T_L nexus might be retried
on another nexus / path, but they should _not_ be queued
if no paths are available.
The use of blk_execute_rq_nowait() implies __blk_put_request() is needed
in start_stop_endio() rather than blk_put_request() --
blk_finish_request() is called with queue lock already held.
dma_alloc_coherent()
The ioc->sgl[i].iov_len value is supplied by the ioctl caller, and can be
zero in some cases. Assume that's valid and continue without error.
Fixes (multiple individual reports of the same problem for quite a while):
http://marc.info/?l=linux-ide&m=128941801715301
http://bugs.debian.org/604627
http://www.mail-archive.com/linux-poweredge@dell.com/msg02575.html
megasas: Failed to alloc kernel SGL buffer for IOCTL
and
[ 69.162538] ------------[ cut here ]------------
[ 69.162806] kernel BUG at /build/buildd/linux-2.6.32/lib/swiotlb.c:368!
[ 69.163134] invalid opcode: 0000 [#1] SMP
[ 69.163570] last sysfs file: /sys/devices/system/cpu/cpu3/cache/index2/shared_cpu_map
[ 69.163975] CPU 0
[ 69.164227] Modules linked in: fbcon tileblit font bitblit softcursor vga16fb vgastate ioatdma radeon ttm drm_kms_helper shpchp drm i2c_algo_bit lp parport floppy pata_jmicron megaraid_sas igb dca
[ 69.167419] Pid: 1206, comm: smartctl Tainted: G W 2.6.32-25-server #45-Ubuntu X8DTN
[ 69.167843] RIP: 0010:[<ffffffff812c4dc5>] [<ffffffff812c4dc5>] map_single+0x255/0x260
[ 69.168370] RSP: 0018:ffff88081c0ebc58 EFLAGS: 00010246
[ 69.168655] RAX: 000000000003bffc RBX: 00000000ffffffff RCX: 0000000000000002
[ 69.169000] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88001dffe000
[ 69.169346] RBP: ffff88081c0ebcb8 R08: 0000000000000000 R09: ffff880000030840
[ 69.169691] R10: 0000000000100000 R11: 0000000000000000 R12: 0000000000000000
[ 69.170036] R13: 00000000ffffffff R14: 0000000000000001 R15: 0000000000200000
[ 69.170382] FS: 00007fb8de189720(0000) GS:ffff88001de00000(0000) knlGS:0000000000000000
[ 69.170794] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 69.171094] CR2: 00007fb8dd59237c CR3: 000000081a790000 CR4: 00000000000006f0
[ 69.171439] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 69.171784] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 69.172130] Process smartctl (pid: 1206, threadinfo ffff88081c0ea000, task ffff88081a760000)
[ 69.194513] Stack:
[ 69.205788] 0000000000000034 00000002817e3390 0000000000000000 ffff88081c0ebe00
[ 69.217739] <0> 0000000000000000 000000000003bffc 0000000000000000 0000000000000000
[ 69.241250] <0> 0000000000000000 00000000ffffffff ffff88081c5b4080 ffff88081c0ebe00
[ 69.277310] Call Trace:
[ 69.289278] [<ffffffff812c52ac>] swiotlb_alloc_coherent+0xec/0x130
[ 69.301118] [<ffffffff81038b31>] x86_swiotlb_alloc_coherent+0x61/0x70
[ 69.313045] [<ffffffffa002d0ce>] megasas_mgmt_fw_ioctl+0x1ae/0x690 [megaraid_sas]
[ 69.336399] [<ffffffffa002d748>] megasas_mgmt_ioctl_fw+0x198/0x240 [megaraid_sas]
[ 69.359346] [<ffffffffa002f695>] megasas_mgmt_ioctl+0x35/0x50 [megaraid_sas]
[ 69.370902] [<ffffffff81153b12>] vfs_ioctl+0x22/0xa0
[ 69.382322] [<ffffffff8115da2a>] ? alloc_fd+0x10a/0x150
[ 69.393622] [<ffffffff81153cb1>] do_vfs_ioctl+0x81/0x410
[ 69.404696] [<ffffffff8155cc13>] ? do_page_fault+0x153/0x3b0
[ 69.415761] [<ffffffff811540c1>] sys_ioctl+0x81/0xa0
[ 69.426640] [<ffffffff810121b2>] system_call_fastpath+0x16/0x1b
[ 69.437491] Code: fe ff ff 48 8b 3d 74 38 76 00 41 bf 00 00 20 00 e8 51 f5 d7 ff 83 e0 ff 48 05 ff 07 00 00 48 c1 e8 0b 48 89 45 c8 e9 13 fe ff ff <0f> 0b eb fe 0f 1f 80 00 00 00 00 55 48 89 e5 48 83 ec 20 4c 89
[ 69.478216] RIP [<ffffffff812c4dc5>] map_single+0x255/0x260
[ 69.489668] RSP <ffff88081c0ebc58>
[ 69.500975] ---[ end trace 6a2181b634e2abc7 ]---
Reported-by: Bokhan Artem <aptem@ngs.ru>
Reported by: Marc-Christian Petersen <m.c.p@gmx.de>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Cc: "Benz, Michael" <Michael.Benz@lsi.com>
pm8001 manages its own list of pending works and cancel them on device
free. It is unnecessarily complex and has a race condition - the
works are canceled but not synced, so the work could still be running
during and after the data structures are freed.
This patch simplifies workqueue usage.
* A driver specific workqueue pm8001_wq is created to serve these
work items.
* To avoid confusion, the "queue" suffixes are dropped from work items
and functions.
* Delayed queueing was never used. pm8001_work now uses work_struct
instead.
* The driver no longer keeps track of pending works. All pm8001_works
are queued to pm8001_wq and the workqueue is flushed as necessary.
flush_scheduled_work() usage is removed during conversion.
Acked-by: Jack Wang <jack_wang@usish.com>
Simple conversions to drop flush_scheduled_work() usages in
drivers/scsi. More involved ones will be done in separate patches.
* NCR5380, megaraid_sas: cancel_delayed_work() +
flush_scheduled_work() -> cancel_delayed_work_sync().
* mpt2sas_scsih: drop unnecessary flush_scheduled_work().
* arcmsr_hba, ipr, pmcraid: flush the used work explicitly instead of
using flush_scheduled_work().
As discussed in a thread on this list titled:
"RFC: short reads on block devices"
this patch adds recommendations for LLDs to set resid
when there might be uncertainty about how much data
has been returned by a device.
This patch inline and attached] is against scsi-misc-2.6.git
Signed-off-by: Douglas Gilbert <dgilbert@interlog.com>
Since sg-read is a bidi operation, it is a gain to convert
a single sg entry into a regular read. Better do this in the
generic layer then force each caller to do so.
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Originally, libata required the illusion that it could access the sata
control register. Now, however, it can run perfectly well without
them, so remove the dummy routines from libsas which tried to emulate
them (but only ended up causing confusion).
Instead of using a config option for debugging, just dump the
messages with KERN_DEBUG.
ATAPI check condition needs to be treated the same as a success or
protocol return. The register returns from the PACKET command are all
correctly positioned in the device to host register FIS and so we
should collect them properly. Right at the moment this doesn't matter
because libata sends a request sense always for ATAPI errors, but if
it ever checked the registers, we should have the correct contents
just in case.
tables.
Previously we were using strncmp in order to avoid having to include
whitespace in the devlist, but this means "HSV1000" matches a device
list entry that says "HSV100", which is wrong. This patch changes
scsi_dh.c to use scsi_devinfo's matching functions instead, since they
handle these cases correctly.
For scsi_dh.c to use devinfo lists, we have to be able to remove entries
before rmmod.
fixed the connection problem when the private iscsi ipv4 address is
provisioned on the interface.
Signed-off-by: Karen Xie <kxie@chelsio.com>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Steffen will take over the zfcp maintainer work. Update the
MAINTAINERS entry accordingly.
Acked-by: Steffen Maier <maier@linux.vnet.ibm.com>
Acked-by: Swen Schillig <swen@vnet.ibm.com>
Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com>
A 'kfree(karg)' is missing in a failure path in
mptctl.c::mptctl_getiocinfo() which can cause a memory leak.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com>
The nopout's reserved field was not being initialized to zero
before being reused. Stale CDB values from previous SCSI cmds
of the same BHS offset was the cause of the disconnection
initiated by the Lefthand target.
Signed-off-by: Eddie Wai <eddie.wai@broadcom.com>
Remove gl_skb from cxgbi_ddp_info as it is only used by cxgb3i.
There is no need to set ulpmode on the tx skbs if no digest is enabled.
memset arg64 to zero in the passthrough ioctls to avoid leaking contents
of kernel stack memory to userland via uninitialized padding fields
inserted by the compiler for alignment reasons.
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
unknown
hpsa_add_msa2xxx_enclosure_device()
Thanks to Scott Teel for noticing this.
Need to take the lock while accessing the register to check to
see if config table changes have taken effect.
This is to prevent hpsa from resetting older boards
which the cciss driver may be controlling.
This is to conserve memory in a memory-limited kdump scenario
and use the doorbell reset method if available (which doesn't
lock up the controller if you properly save and restore all
the PCI registers that you're supposed to.)
