git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x
* 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x:
sh: sh7724: Add USBHS DMAEngine support
sh: ecovec: Add renesas_usbhs support
sh, exec: remove redundant set_fs(USER_DS)
drivers: sh: resume enabled clocks fix
dmaengine: shdma: SH_DMAC_MAX_CHANNELS message fix
sh: Fix up xchg/cmpxchg corruption with gUSA RB.
sh: Remove compressed kernel libgcc dependency.
sh: fix wrong icache/dcache address-array start addr in cache-debugfs.
* 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x:
ARM: mach-shmobile: mackerel: tidyup usbhs driver settings
ARM: mach-shmobile: Correct SCIF port types for SH7367.
ARM: mach-shmobile: sh73a0 gic_arch_extn.irq_set_wake() fix
ARM: mach-shmobile: Mackerel USB platform data update
ARM: mach-shmobile: AG5EVM SDHI1 platform data update
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x
* 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x:
fbdev: sh_mobile_hdmi: fix regression: statically enable RTPM
fbdev/atyfb: Fix 2 defined-but-not-used warnings
efifb: Fix call to wrong unregister function
video: s3c-fb: move enabling channel for window
video: s3c-fb: fix virtual resolution checking
video: s3c-fb: fix misleading kfree in remove function
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
SELinux: skip file_name_trans_write() when policy downgraded.
selinux: fix case of names with whitespace/multibytes on /selinux/create
Fix build by moving enum list outside of
#ifdef CONFIG_IIO_RING_BUFFER.
drivers/staging/iio/accel/adis16201_core.c:413: error: 'ADIS16201_SCAN_SUPPLY' undeclared here (not in a function)
drivers/staging/iio/accel/adis16201_core.c:417: error: 'ADIS16201_SCAN_TEMP' undeclared here (not in a function)
drivers/staging/iio/accel/adis16203_core.c:374: error: 'ADIS16203_SCAN_SUPPLY' undeclared here (not in a function)
drivers/staging/iio/accel/adis16203_core.c:378: error: 'ADIS16203_SCAN_AUX_ADC' undeclared here (not in a function)
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Cc: linux-iio@vger.kernel.org
We have some users of this function that date back to before the vma
list was doubly linked, and just are silly. These days, you can find
the previous vma by just following the vma->vm_prev pointer.
In some cases you don't need any find_vma() lookup at all, and in other
cases you're better off with the regular "find_vma()" that uses the vma
cache front-end lookup.
Some "find_vma_prev()" users are still valid, though. For example, in
the case of a stack that grows up, it can be the case that we don't find
any 'vma' at all (because we're looking up an address that is past the
last vma), and that the stack that we want to grow is the 'prev' vma.
But that kind of special case aside, we generally should prefer to use
'find_vma()'.
Noticed due to a totally unrelated POWER memory corruption bug that just
happened to hit in 'find_vma_prev()' and made me go "Hmm - why are we
using that function here?".
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: footbridge: fix clock event support
ARM: footbridge: fix debug macros
ARM: initrd: disable initrds outside of memory
ARM: extend Code: line by one 16-bit quantity for Thumb instructions
ARM: 6955/1: cmpxchg syscall should data abort if page not write
ARM: 6954/1: zImage: fix Thumb2 breakage
ARM: 6953/1: DT: don't try to access physical address zero
ARM: 6949/2: mach-u300: fix compilaton warning in IO accessors
Revert "ARM: 6944/1: mm: allow ASID 0 to be allocated to tasks"
Revert "ARM: 6943/1: mm: use TTBR1 instead of reserved context ID"
davinci: make PCM platform devices static
arm: davinci: Fix fallout from generic irq chip conversion
ARM: 6894/1: mmci: trigger card detect IRQs on falling and rising edges
ARM: 6952/1: fix lockdep warning of "unannotated irqs-off"
ARM: 6951/1: include .bss in memory layout information
ARM: 6948/1: Fix .size directives for __arm{7,9}tdmi_proc_info
ARM: 6947/2: mach-u300: fix compilation error in timer
ARM: 6946/1: vexpress: move v2m clock init to init_early
ARM: mx51/sdma: Check the chip revision in run-time
arm: mxs: include asm/processor.h for cpu_relax()
VM_STACK_INCOMPLETE_SETUP"
This reverts commit 7f81c8890c15a10f5220bebae3b6dfae4961962a.
It turns out that it's not actually a build-time check on x86-64 UML,
which does some seriously crazy stuff with VM_STACK_FLAGS.
The VM_STACK_FLAGS define depends on the arch-supplied
VM_STACK_DEFAULT_FLAGS value, and on x86-64 UML we have
arch/um/sys-x86_64/shared/sysdep/vm-flags.h:
#define VM_STACK_DEFAULT_FLAGS \
(test_thread_flag(TIF_IA32) ? vm_stack_flags32 : vm_stack_flags)
#define VM_STACK_DEFAULT_FLAGS vm_stack_flags
(yes, seriously: two different #define's for that thing, with the first
one being inside an "#ifdef TIF_IA32")
It's possible that it is UML that should just be fixed in this area, but
for now let's just undo the (very small) optimization.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Richard Weinberger <richard@nod.at>
Fix format and spelling.
Signed-off-by: Jörg Sommer <joerg@alea.gnuu.de>
Acked-by: Paul Menage <menage@google.com>
According to commit 676db4af0430 ("cgroupfs: create /sys/fs/cgroup to
mount cgroupfs on") the canonical mountpoint for the cgroup filesystem
is /sys/fs/cgroup. Hence, this should be used in the documentation.
Instead of listing the architectures that are supported by
kmemleak in Documentation/kmemleak.txt, just refer people to
the list of supported architecutures in lib/Kconfig.debug so
that Documentation/kmemleak.txt does not need more updates
for this.
Signed-off-by: Maxin B. John <maxin.john@gmail.com>
This patch updates the incomplete documentation concerning the printk
extended format specifiers.
Signed-off-by: Andrew Murray <amurray@mpc-data.co.uk>
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Check if lowest_mask is initialized in find_lowest_rq()
sched: Fix need_resched() when checking peempt
Fix several security issues in Alpha-specific syscalls. Untested, but
mostly trivial.
1. Signedness issue in osf_getdomainname allows copying out-of-bounds
kernel memory to userland.
2. Signedness issue in osf_sysinfo allows copying large amounts of
3. Typo (?) in osf_getsysinfo bounds minimum instead of maximum copy
size, allowing copying large amounts of kernel memory to userland.
4. Usage of user pointer in osf_wait4 while under KERNEL_DS allows
privilege escalation via writing return value of sys_wait4 to kernel
memory.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
CONFIG_PM_RUNTIME
Fixes this warning:
drivers/misc/apds990x.c: At top level:
drivers/misc/apds990x.c:613: warning: `apds990x_chip_on' defined but not used
Cc: Samu Onkalo <samu.p.onkalo@nokia.com>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Andrea Righi reported a case where an exiting task can race against
ksmd::scan_get_next_rmap_item (http://lkml.org/lkml/2011/6/1/742) easily
triggering a NULL pointer dereference in ksmd.
ksm_scan.mm_slot == &ksm_mm_head with only one registered mm
CPU 1 (__ksm_exit) CPU 2 (scan_get_next_rmap_item)
list_empty() is false
lock slot == &ksm_mm_head
list_del(slot->mm_list)
(list now empty)
unlock
lock
slot = list_entry(slot->mm_list.next)
(list is empty, so slot is still ksm_mm_head)
unlock
slot->mm == NULL ... Oops
Close this race by revalidating that the new slot is not simply the list
head again.
Andrea's test case:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/mman.h>
#define BUFSIZE getpagesize()
int main(int argc, char **argv)
void *ptr;
if (posix_memalign(&ptr, getpagesize(), BUFSIZE) < 0) {
perror("posix_memalign");
exit(1);
if (madvise(ptr, BUFSIZE, MADV_MERGEABLE) < 0) {
perror("madvise");
exit(1);
*(char *)NULL = 0;
return 0;
Reported-by: Andrea Righi <andrea@betterlinux.com>
Tested-by: Andrea Righi <andrea@betterlinux.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Cc: <stable@kernel.org>
RTC_CLASS is changed to bool, so 'm' is invalid.
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
If dmi_get_system_info() returns NULL, pch_uart_init_port() will
dereferencea a zero pointer.
This oops was observed on an Atom based board which has no BIOS, but
a bootloder which doesn't provide DMI data.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Cc: Greg KH <gregkh@suse.de>
When interrupts are delayed due to interrupt masking or due to other
interrupts being serviced the HPET periodic-emuation would fail. This
happened because given an interval t and a time for the current interrupt
m we would compute the next time as t + m. This works until we are
delayed for > t, in which case we would be writing a new value which is in
fact in the past.
This can be solved by computing the next time instead as (k * t) + m where
k is large enough to be in the future. The exact computation of k is
described in a comment to the code.
More detail:
Assuming an interval of 5 between each expected interrupt we have a normal
case of
t0: interrupt, read t0 from comparator, set next interrupt t0 + 5
t5: interrupt, read t5 from comparator, set next interrupt t5 + 5
t10: interrupt, read t10 from comparator, set next interrupt t10 + 5
So, what happens when the interrupt is serviced too late?
t11: delayed interrupt serviced, read t5 from comparator, set next
interrupt t5 + 5, which is in the past!
... counter loops ...
t10: Much much later, get the next interrupt.
This can happen either because we have interrupts masked for too long
(some stupid driver goes on a printk rampage) or just because we are
pushing the limits of the interval (too small a period), or both most
probably.
My solution is to read the main counter as well and set the next interrupt
to occur at the right interval, for example:
interrupt t15 as t10 has been missed.
t15: back on track.
Signed-off-by: Nils Carlson <nils.carlson@ericsson.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Clemens Ladisch <clemens@ladisch.de>
feature-removal-schedule.txt
Commit a77aea92010acf ("cgroup: remove the ns_cgroup") removed the
ns_cgroup but it forgot to remove the related doc in
feature-removal-schedule.txt.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
is asynchronous V2
Asynchronous compaction is used when promoting to huge pages. This is all
very nice but if there are a number of processes in compacting memory, a
large number of pages can be isolated. An "asynchronous" process can
stall for long periods of time as a result with a user reporting that
firefox can stall for 10s of seconds. This patch aborts asynchronous
compaction if too many pages are isolated as it's better to fail a
hugepage promotion than stall a process.
[minchan.kim@gmail.com: return COMPACT_PARTIAL for abort]
Reported-and-tested-by: Ury Stankevich <urykhy@gmail.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
It is unsafe to run page_count during the physical pfn scan because
compound_head could trip on a dangling pointer when reading
page->first_page if the compound page is being freed by another CPU.
[mgorman@suse.de: split out patch]
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
next zone
Compaction works with two scanners, a migration and a free scanner. When
the scanners crossover, migration within the zone is complete. The
location of the scanner is recorded on each cycle to avoid excesive
scanning.
When a zone is small and mostly reserved, it's very easy for the migration
scanner to be close to the end of the zone. Then the following situation
can occurs
o migration scanner isolates some pages near the end of the zone
o free scanner starts at the end of the zone but finds that the
migration scanner is already there
o free scanner gets reinitialised for the next cycle as
cc->migrate_pfn + pageblock_nr_pages
moving the free scanner into the next zone
o migration scanner moves into the next zone
When this happens, NR_ISOLATED accounting goes haywire because some of the
accounting happens against the wrong zone. One zones counter remains
positive while the other goes negative even though the overall global
count is accurate. This was reported on X86-32 with !SMP because !SMP
allows the negative counters to be visible. The fact that it is the bug
should theoritically be possible there.
fragmentation_index() returns -1000 when the allocation might succeed
This doesn't match the comment and code in compaction_suitable(). I
thought compaction_suitable should return COMPACT_PARTIAL in -1000
case, because in this case allocation could succeed depending on
watermarks.
The impact of this is that compaction starts and compact_finished() is
called which rechecks the watermarks and the free lists. It should have
the same result in that compaction should not start but is more expensive.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Pages isolated for migration are accounted with the vmstat counters
NR_ISOLATE_[ANON|FILE]. Callers of migrate_pages() are expected to
increment these counters when pages are isolated from the LRU. Once the
pages have been migrated, they are put back on the LRU or freed and the
isolated count is decremented.
Memory failure is not properly accounting for pages it isolates causing
the NR_ISOLATED counters to be negative. On SMP builds, this goes
unnoticed as negative counters are treated as 0 due to expected per-cpu
drift. On UP builds, the counter is treated by too_many_isolated() as a
large value causing processes to enter D state during page reclaim or
compaction. This patch accounts for pages isolated by memory failure
correctly.
[mel@csn.ul.ie: rewrote changelog]
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
CONFIG_CONSTRUCTORS controls support for running constructor functions at
kernel init time. According to commit b99b87f70c7785ab ("kernel:
constructor support"), gcov (CONFIG_GCOV_KERNEL) needs this. However,
CONFIG_CONSTRUCTORS currently defaults to y, with no option to disable it,
and CONFIG_GCOV_KERNEL depends on it. Instead, default it to n and have
CONFIG_GCOV_KERNEL select it, so that the normal case of
CONFIG_GCOV_KERNEL=n will result in CONFIG_CONSTRUCTORS=n.
Observed in the short list of =y values in a minimal kernel configuration.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
I shall maintain the legacy eeprom driver, until we finally get rid of it.
Based on Michal Hocko's comment.
We are not draining per cpu cached charges during soft limit reclaim
because background reclaim doesn't care about charges. It tries to free
some memory and charges will not give any.
Cached charges might influence only selection of the biggest soft limit
offender but as the call is done only after the selection has been already
done it makes no change.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
For performance, memory cgroup caches some "charge" from res_counter into
per cpu cache. This works well but because it's cache, it needs to be
flushed in some cases. Typical cases are
1. when someone hit limit.
2. when rmdir() is called and need to charges to be 0.
But "1" has problem.
Recently, with large SMP machines, we see many kworker runs because of
flushing memcg's cache. Bad things in implementation are that even if a
cpu contains a cache for memcg not related to a memcg which hits limit,
drain code is called.
This patch does
A) check percpu cache contains a useful data or not.
B) check other asynchronous percpu draining doesn't run.
C) don't call local cpu callback.
(*)This patch avoid changing the calling condition with hard-limit.
When I run "cat 1Gfile > /dev/null" under 300M limit memcg,
[Before]
13767 kamezawa 20 0 98.6m 424 416 D 10.0 0.0 0:00.61 cat
58 root 20 0 0 0 0 S 0.6 0.0 0:00.09 kworker/2:1
60 root 20 0 0 0 0 S 0.6 0.0 0:00.08 kworker/4:1
4 root 20 0 0 0 0 S 0.3 0.0 0:00.02 kworker/0:0
57 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/1:1
61 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/5:1
62 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/6:1
63 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/7:1
[After]
2676 root 20 0 98.6m 416 416 D 9.3 0.0 0:00.87 cat
2626 kamezawa 20 0 15192 1312 920 R 0.3 0.0 0:00.28 top
1 root 20 0 19384 1496 1204 S 0.0 0.0 0:00.66 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ksoftirqd/0
4 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0
[akpm@linux-foundation.org: make percpu_charge_mutex static, tweak comments]
Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Tested-by: Ying Han <yinghan@google.com>
Hierarchical reclaim doesn't swap out if memsw and resource limits are
thye same (memsw_is_minimum == true) because we would hit mem+swap limit
anyway (during hard limit reclaim).
If it comes to the soft limit we shouldn't consider memsw_is_minimum at
all because it doesn't make much sense. Either the soft limit is bellow
the hard limit and then we cannot hit mem+swap limit or the direct reclaim
takes a precedence.
The following crash was reported:
> Call Trace:
> [<ffffffff81139792>] mem_cgroup_from_task+0x15/0x17
> [<ffffffff8113a75a>] __mem_cgroup_try_charge+0x148/0x4b4
> [<ffffffff810493f3>] ? need_resched+0x23/0x2d
> [<ffffffff814cbf43>] ? preempt_schedule+0x46/0x4f
> [<ffffffff8113afe8>] mem_cgroup_charge_common+0x9a/0xce
> [<ffffffff8113b6d1>] mem_cgroup_newpage_charge+0x5d/0x5f
> [<ffffffff81134024>] khugepaged+0x5da/0xfaf
> [<ffffffff81078ea0>] ? __init_waitqueue_head+0x4b/0x4b
> [<ffffffff81133a4a>] ? add_mm_counter.constprop.5+0x13/0x13
> [<ffffffff81078625>] kthread+0xa8/0xb0
> [<ffffffff814d13e8>] ? sub_preempt_count+0xa1/0xb4
> [<ffffffff814d5664>] kernel_thread_helper+0x4/0x10
> [<ffffffff814ce858>] ? retint_restore_args+0x13/0x13
> [<ffffffff8107857d>] ? __init_kthread_worker+0x5a/0x5a
What happens is that khugepaged tries to charge a huge page against an mm
whose last possible owner has already exited, and the memory controller
crashes when the stale mm->owner is used to look up the cgroup to charge.
mm->owner has never been set to NULL with the last owner going away, but
nobody cared until khugepaged came along.
Even then it wasn't a problem because the final mmput() on an mm was
forced to acquire and release mmap_sem in write-mode, preventing an
exiting owner to go away while the mmap_sem was held, and until "692e0b3
mm: thp: optimize memcg charge in khugepaged", the memory cgroup charge
was protected by mmap_sem in read-mode.
Instead of going back to relying on the mmap_sem to enforce lifetime of a
task, this patch ensures that mm->owner is properly set to NULL when the
last possible owner is exiting, which the memory controller can handle
just fine.
[akpm@linux-foundation.org: tweak comments]
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Hugh Dickins <hughd@google.com>
Reported-by: Dave Jones <davej@redhat.com>
Commit 21a3c9646873 ("memcg: allocate memory cgroup structures in local
nodes") makes page_cgroup allocation as NUMA aware. But that caused a
problem https://bugzilla.kernel.org/show_bug.cgi?id=36192.
The problem was getting a NID from invalid struct pages, which was not
initialized because it was out-of-node, out of [node_start_pfn,
node_end_pfn)
Now, with sparsemem, page_cgroup_init scans pfn from 0 to max_pfn. But
this may scan a pfn which is not on any node and can access memmap which
is not initialized.
This makes page_cgroup_init() for SPARSEMEM node aware and remove a code
to get nid from page->flags. (Then, we'll use valid NID always.)
[akpm@linux-foundation.org: try to fix up comments]
Commit 406eb0c9ba76 ("memcg: add memory.numastat api for numa
statistics") adds memory.numa_stat file for memory cgroup. But the file
permissions are wrong.
[kamezawa@bluextal linux-2.6]$ ls -l /cgroup/memory/A/memory.numa_stat
---------- 1 root root 0 Jun 9 18:36 /cgroup/memory/A/memory.numa_stat
This patch fixes the permission as
[root@bluextal kamezawa]# ls -l /cgroup/memory/A/memory.numa_stat
-r--r--r-- 1 root root 0 Jun 10 16:49 /cgroup/memory/A/memory.numa_stat
Acked-by: Ying Han <yinghan@google.com>
Seems when a config option does not have a dependency of the menuconfig,
it messes the display of the rest configs, even if it's a hidden one.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
When 1GB hugepages are allocated on a system, free(1) reports less
available memory than what really is installed in the box. Also, if the
total size of hugepages allocated on a system is over half of the total
memory size, CommitLimit becomes a negative number.
The problem is that gigantic hugepages (order > MAX_ORDER) can only be
allocated at boot with bootmem, thus its frames are not accounted to
'totalram_pages'. However, they are accounted to hugetlb_total_pages()
What happens to turn CommitLimit into a negative number is this
calculation, in fs/proc/meminfo.c:
allowed = ((totalram_pages - hugetlb_total_pages())
* sysctl_overcommit_ratio / 100) + total_swap_pages;
A similar calculation occurs in __vm_enough_memory() in mm/mmap.c.
Also, every vm statistic which depends on 'totalram_pages' will render
confusing values, as if system were 'missing' some part of its memory.
Impact of this bug:
When gigantic hugepages are allocated and sysctl_overcommit_memory ==
OVERCOMMIT_NEVER. In a such situation, __vm_enough_memory() goes through
the mentioned 'allowed' calculation and might end up mistakenly returning
-ENOMEM, thus forcing the system to start reclaiming pages earlier than it
would be ususal, and this could cause detrimental impact to overall
system's performance, depending on the workload.
Besides the aforementioned scenario, I can only think of this causing
annoyances with memory reports from /proc/meminfo and free(1).
[akpm@linux-foundation.org: standardize comment layout]
Reported-by: Russ Anderson <rja@sgi.com>
Signed-off-by: Rafael Aquini <aquini@linux.com>
Acked-by: Russ Anderson <rja@sgi.com>
Cc: Christoph Lameter <cl@linux.com>
During memory hotplug we refresh zonelists when we online a page in a new
zone. It means that the node's zonelist is not initialized until pages
are onlined. So for example, "nid" passed by MEM_GOING_ONLINE notifier
will point to NODE_DATA(nid) which has no zone fallback list. Moreover,
if we hot-add cpu-only nodes, alloc_pages() will do no fallback.
This patch makes a zonelist when a new pgdata is available.
Note: in production, at fujitsu, memory should be onlined before cpu
and our server didn't have any memory-less nodes and had no problems.
But recent changes in MEM_GOING_ONLINE+page_cgroup
will access not initialized zonelist of node.
Anyway, there are memory-less node and we need some care.
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Remove calibrate_delay_direct()'s KERN_DEBUG printk related to bogomips
calculation as it appears when booting every core on setups with
'ignore_loglevel' which dmesg people scan for possible issues. As the
message doesn't show very useful information to the widest audience of
kernel boot message gazers, it should be removed.
Introduced by commit d2b463135f84 ("init/calibrate.c: fix for critical
bogoMIPS intermittent calculation failure").
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: Andrew Worsley <amworsley@gmail.com>
Cc: Phil Carmody <ext-phil.2.carmody@nokia.com>
On m68k (which doesn't support generic hardirqs yet):
drivers/w1/masters/ds1wm.c: In function `ds1wm_probe':
drivers/w1/masters/ds1wm.c: error: implicit declaration of function `irq_set_irq_type'
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Cc: Jean-Franois Dagenais <dagenaisj@sonatest.com>
Cc: Matt Reimer <mreimer@vpop.net>
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Add maintainers for the videobuf2 V4L2 driver framework.
Signed-off-by: Pawel Osciak <pawel@osciak.com>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Commit 4440673a95e6 ("leds: provide helper to register "leds-gpio"
devices") broke the display of the NEW_LEDS menu as it didn't depend on
NEW_LEDS and so made "LED drivers" and "LED Triggers" appear at the same
level as "LED Support" instead of below it as it was before 4440673a.
Moving LEDS_GPIO_REGISTER out of the menuconfig NEW_LEDS fixes this
unintended side effect.
Reported-by: Axel Lin <axel.lin@gmail.com>
We call led_classdev_unregister/led_classdev_register in
asic3_led_remove/asic3_led_probe, thus make LEDS_ASIC3 depend on
LEDS_CLASS.
This patch fixes below build error if LEDS_CLASS is not configured.
LD .tmp_vmlinux1
drivers/built-in.o: In function `asic3_led_remove':
clkdev.c:(.devexit.text+0x1860): undefined reference to `led_classdev_unregister'
drivers/built-in.o: In function `asic3_led_probe':
clkdev.c:(.devinit.text+0xcee8): undefined reference to `led_classdev_register'
make: *** [.tmp_vmlinux1] Error 1
Cc: Paul Parsons <lost.distance@yahoo.com>
Update my email address. Email will start to the old address bouncing
soon
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Balbir Singh <bsingharora@gmail.com>
The "hostname" tool falls back to setting the hostname to "localhost" if
/etc/hostname does not exist. Distribution init scripts have the same
fallback. However, if userspace never calls sethostname, such as when
booting with init=/bin/sh, or otherwise booting a minimal system without
the usual init scripts, the default hostname of "(none)" remains,
unhelpfully appearing in various places such as prompts ("root@(none):~#")
and logs. Furthermore, "(none)" doesn't typically resolve to anything
useful.
Make the default hostname configurable. This removes the need for the
standard fallback, provides a useful default for systems that never call
sethostname, and makes minimal systems that much more useful with less
configuration. Distributions could choose to use "localhost" here to
avoid the fallback, while embedded systems may wish to use a specific
target hostname.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: David Miller <davem@davemloft.net>
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: Kel Modderman <kel@otaku42.de>
BUILD_BUG_ON_ZERO and BUILD_BUG_ON_NULL must return values, even in the
CHECKER case otherwise various users of it become syntactically invalid.
Signed-off-by: Dr. David Alan Gilbert <linux@treblig.org>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Commit 56de7263fcf3 ("mm: compaction: direct compact when a high-order
allocation fails") introduced a check for cc->order == -1 in
compact_finished. We should continue compacting in that case because
the request came from userspace and there is no particular order to
compact for. Similar check has been added by 82478fb7 (mm: compaction:
prevent division-by-zero during user-requested compaction) for
compaction_suitable.
The check is, however, done after zone_watermark_ok which uses order as a
right hand argument for shifts. Not only watermark check is pointless if
we can break out without it but it also uses 1 << -1 which is not well
defined (at least from C standard). Let's move the -1 check above
zone_watermark_ok.
[minchan.kim@gmail.com> - caught compaction_suitable]
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hioryu@jp.fujitsu.com>
Running a ktest.pl test, I hit the following bug on x86_32:
WARNING: at arch/x86/mm/highmem_32.c:81 __kunmap_atomic+0x64/0xc1()
Hardware name:
Modules linked in:
Pid: 93, comm: sh Not tainted 2.6.39-test+ #1
Call Trace:
[<c04450da>] warn_slowpath_common+0x7c/0x91
[<c042f5df>] ? __kunmap_atomic+0x64/0xc1
[<c042f5df>] ? __kunmap_atomic+0x64/0xc1^M
[<c0445111>] warn_slowpath_null+0x22/0x24
[<c042f5df>] __kunmap_atomic+0x64/0xc1
[<c04d4a22>] unmap_vmas+0x43a/0x4e0
[<c04d9065>] exit_mmap+0x91/0xd2
[<c0443057>] mmput+0x43/0xad
[<c0448358>] exit_mm+0x111/0x119
[<c044855f>] do_exit+0x1ff/0x5fa
[<c0454ea2>] ? set_current_blocked+0x3c/0x40
[<c0454f24>] ? sigprocmask+0x7e/0x8e
[<c0448b55>] do_group_exit+0x65/0x88
[<c0448b90>] sys_exit_group+0x18/0x1c
[<c0c3915f>] sysenter_do_call+0x12/0x38
---[ end trace 8055f74ea3c0eb62 ]---
Running a ktest.pl git bisect, found the culprit: commit e303297e6c3a
("mm: extended batches for generic mmu_gather")
But although this was the commit triggering the bug, it was not the one
originally responsible for the bug. That was commit d16dfc550f53 ("mm:
mmu_gather rework").
The code in zap_pte_range() has something that looks like the following:
pte = pte_offset_map_lock(mm, pmd, addr, &ptl);
do {
} while (pte++, addr += PAGE_SIZE, addr != end);
pte_unmap_unlock(pte - 1, ptl);
The pte starts off pointing at the first element in the page table
directory that was returned by the pte_offset_map_lock(). When it's done
with the page, pte will be pointing to anything between the next entry and
the first entry of the next page inclusive. By doing a pte - 1, this puts
the pte back onto the original page, which is all that pte_unmap_unlock()
needs.
In most archs (64 bit), this is not an issue as the pte is ignored in the
pte_unmap_unlock(). But on 32 bit archs, where things may be kmapped, it
is essential that the pte passed to pte_unmap_unlock() resides on the same
page that was given by pte_offest_map_lock().
The problem came in d16dfc55 ("mm: mmu_gather rework") where it introduced
a "break;" from the while loop. This alone did not seem to easily trigger
the bug. But the modifications made by e303297e6 caused that "break;" to
be hit on the first iteration, before the pte++.
The pte not being incremented will now cause pte_unmap_unlock(pte - 1) to
be pointing to the previous page. This will cause the wrong page to be
unmapped, and also trigger the warning above.
The simple solution is to just save the pointer given by
pte_offset_map_lock() and use it in the unlock.
Fix the wrong `if' condition for the check if the requested timer is
available.
The bitmap avail is used to store if a timer is used already. test_bit()
is used to check if the requested timer is available. If a bit in the
avail bitmap is set it means that the timer is available.
The runtime effect would be that allocating a specific timer always fails
(versus telling cs5535_mfgpt_alloc_timer to allocate the first available
timer, which works).
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Acked-by: Andres Salomon <dilinger@queued.net>
