Do a tcl state flush before accessing tcl vector space. This fixes some
more problems with flickering (bug #6637). drm may not be appropriate
place for this, since doing that flush there might both be overkill and
insufficient in some cases. However, it's hard to figure out when that
flush is needed, so this has to suffice. There does not seem to be a
performance penalty associated with it.
Signed-off-by: Dave Airlie <airlied@linux.ie>
Prevent possible null dereference due to misplaced ;
Signed-off-by: Dave Jones <davej@redhat.com>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: (258 commits)
[libata] conversion to new debug scheme, part 1 of $N
[PATCH] libata: Add ata_scsi_dev_disabled
[libata] Add host lock to struct ata_port
[PATCH] libata: implement per-dev EH action mask eh_info->dev_action[]
[PATCH] libata-dev: move the CDB-intr DMA blacklisting
[PATCH] ahci: disable NCQ support on vt8251
[libata] ahci: add JMicron PCI IDs
[libata] sata_nv: add PCI IDs
[libata] ahci: Add NVIDIA PCI IDs.
[PATCH] libata: convert several bmdma-style controllers to new EH, take #3
[PATCH] sata_via: convert to new EH, take #3
[libata] sata_nv: s/spin_lock_irqsave/spin_lock/ in irq handler
[PATCH] sata_nv: add hotplug support
[PATCH] sata_nv: convert to new EH
[PATCH] sata_nv: better irq handlers
[PATCH] sata_nv: simplify constants
[PATCH] sata_nv: kill struct nv_host_desc and nv_host
[PATCH] sata_nv: kill not-working hotplug code
[libata] Update docs to reflect current driver API
[PATCH] libata: add host_set->next for legacy two host_sets case, take #3
arch/ia64/kernel/acpi.c got forgotten when include/acpi/actbl.h
got a cleanup.
Signed-off-by: Tony Luck <tony.luck@intel.com>
My bad.
Signed-off-by: Nicolas Pitre <nico@cam.org>
Update hypfs for dhowells API changes.
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Ingo Oeser <ioe-lkml@rameria.de>
Cc: Joern Engel <joern@wohnheim.fh-wedel.de>
Cc: Michael Holzheu <holzheu@de.ibm.com>
drivers/cpufreq/cpufreq_ondemand.c: In function 'do_dbs_timer':
drivers/cpufreq/cpufreq_ondemand.c:374: warning: implicit declaration of function 'lock_cpu_hotplug'
drivers/cpufreq/cpufreq_ondemand.c:381: warning: implicit declaration of function 'unlock_cpu_hotplug'
drivers/cpufreq/cpufreq_conservative.c: In function 'do_dbs_timer':
drivers/cpufreq/cpufreq_conservative.c:425: warning: implicit declaration of function 'lock_cpu_hotplug'
drivers/cpufreq/cpufreq_conservative.c:432: warning: implicit declaration of function 'unlock_cpu_hotplug'
Cc: Dave Jones <davej@codemonkey.org.uk>
Do a safer check for when to enable DMA. Currently we enable ISA DMA
for cases that do not need it, resulting in OOM conditions when ZONE_DMA
runs out of space.
Signed-off-by: Jens Axboe <axboe@suse.de>
They all duplicate macros to check for empty root and/or node, and
clearing a node. So put those in rbtree.h.
Otherwise we could be racing with truncate/mapping removal.
Problem found/fixed by Nick Piggin <npiggin@suse.de>, logic rewritten
by me.
- Remember to set ->last_sector so that the cfq_choose_req() logic
works correctly.
- Remove redundant call to cfq_choose_req()
This is a collection of patches that greatly improve CFQ performance
in some circumstances.
- Change the idling logic to only kick in after a request is done and we
are deciding what to do. Before the idling included the request service
time, so it was hard to adjust. Now it's true think/idle time.
- Take advantage of TCQ/NCQ/queueing for seeky sync workloads, but keep
it in control for sync and sequential (or close to) workloads.
- Expire queues immediately and move on to other busy queues, if we are
not going to idle after the current one finishes.
- Don't rearm idle timer if there are no busy queues. Just leave the
system idle.
Patch originally from Vasily Tarasov <vtaras@sw.ru>
If you set io-priority of process 1 using sys_ioprio_set system call by
another process 2 (like ionice do), then cfq_init_prio_data() function
sets priority of process 2 (current) on queue of process 1 and clears
the flag, that designates change of ioprio. So the process 1 will work
like with priority of process 2.
I propose not to call cfq_init_prio_data() on io-priority change, but
only mark queue as queue with changed prority. Every time when new
request comes cfq-scheduler checks for this flag and atomaticaly changes
priority of queue to new value.
This saves 8 bytes of data in 64-bit archs.
The IDE power management can just use the ->end_io_data member to store
it's data.
A process flag to indicate whether we are doing sync io is incredibly
ugly. It also causes performance problems when one does a lot of async
io and then proceeds to sync it. Part of the io will go out as async,
and the other part as sync. This causes a disconnect between the
previously submitted io and the synced io. For io schedulers such as CFQ,
this will cause us lost merges and suboptimal behaviour in scheduling.
Remove PF_SYNCWRITE completely from the fsync/msync paths, and let
the O_DIRECT path just directly indicate that the writes are sync
by using WRITE_SYNC instead.
We cannot update them if the user changes nr_requests, so don't
set it in the first place. The gains are pretty questionable as
well. The batching loss has been shown to decrease throughput.
We already drop the refcount in elevator_exit(), and as
we're setting 'e' to NULL, we'll never take that branch anyway.
Finally, as 'e' is a local var that isn't referenced afterwards,
setting it to NULL is pointless.
The queue lock can be taken from interrupts so it must always be taken with
irq disabling primitives. Some primitives already verify this.
blk_start_queue() is called under this lock, so interrupts must be
disabled.
Also document this requirement clearly in blk_init_queue(), where the queue
spinlock is set.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Use hlist instead of list_head for request hashtable in deadline-iosched
and as-iosched. It also can remove the flag to know hashed or unhashed.
Signed-off-by: Akinobu Mita <mita@miraclelinux.com>
block/as-iosched.c | 45 +++++++++++++++++++--------------------------
block/deadline-iosched.c | 39 ++++++++++++++++-----------------------
2 files changed, 35 insertions(+), 49 deletions(-)
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[NET]: Require CAP_NET_ADMIN to create tuntap devices.
[NET]: fix net-core kernel-doc
[TCP]: Move inclusion of <linux/dmaengine.h> to correct place in <linux/tcp.h>
[IPSEC]: Handle GSO packets
[NET]: Added GSO toggle
[NET]: Add software TSOv4
[NET]: Add generic segmentation offload
[NET]: Merge TSO/UFO fields in sk_buff
[NET]: Prevent transmission after dev_deactivate
[IPV6] ADDRCONF: Fix default source address selection without CONFIG_IPV6_PRIVACY
[IPV6]: Fix source address selection.
[NET]: Avoid allocating skb in skb_pad
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (65 commits)
ACPI: suppress power button event on S3 resume
ACPI: resolve merge conflict between sem2mutex and processor_perflib.c
ACPI: use for_each_possible_cpu() instead of for_each_cpu()
ACPI: delete newly added debugging macros in processor_perflib.c
ACPI: UP build fix for bugzilla-5737
Enable P-state software coordination via _PDC
P-state software coordination for speedstep-centrino
P-state software coordination for acpi-cpufreq
P-state software coordination for ACPI core
ACPI: create acpi_thermal_resume()
ACPI: create acpi_fan_suspend()/acpi_fan_resume()
ACPI: pass pm_message_t from acpi_device_suspend() to root_suspend()
ACPI: create acpi_device_suspend()/acpi_device_resume()
ACPI: replace spin_lock_irq with mutex for ec poll mode
ACPI: Allow a WAN module enable/disable on a Thinkpad X60.
sem2mutex: acpi, acpi_link_lock
ACPI: delete unused acpi_bus_drivers_lock
sem2mutex: drivers/acpi/processor_perflib.c
ACPI add ia64 exports to build acpi_memhotplug as a module
ACPI: asus_acpi_init(): propagate correct return value
Manual resolve of conflicts in:
arch/i386/kernel/cpu/cpufreq/acpi-cpufreq.c
arch/i386/kernel/cpu/cpufreq/speedstep-centrino.c
include/acpi/processor.h
Update the sparse documentation to omit the -Wbitwise flag example (as it
is now passed by default), and document the kernel defines to enable
endianness checking.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
While writing a version of losetup, I ran into the problem that the loop
device was returning total garbage.
It turns out the problem was that this losetup was only issuing the
LOOP_SET_FD ioctl and not issuing a subsequent LOOP_SET_STATUS ioctl. This
losetup didn't have any special status to set, so it left out the call.
The deeper cause is that loop_set_fd sets the transfer function to NULL,
which causes no transfer to happen lo_do_transfer.
This patch fixes the problem by setting transfer to transfer_none in
loop_set_fd.
Sometimes partitions claim to be larger than the reported capacity of a
disk device. This patch makes the kernel warn about those partitions.
We still permit these patitions to be used. Quoting Andries Brouwer
<Andries.Brouwer@cwi.nl>:
Case 1: The kernel is mistaken about the size of the disk. (There are
commands to clip a disk to a certain capacity, there are jumpers to tell a
disk that it should report a certain capacity etc. Usually this is because
of BIOS bugs. In bad cases the machine will crash in the BIOS and hence fail
to boot if the disk reports full capacity.) In such cases actually accessing
the blocks of the partition may work fine, or may work fine after running an
unclip utility. I wrote "setmax" some years ago precisely for this reason.
Case 2: There was a messy partition table (maybe just a rounding error) but
the actual filesystem on the partition is contained in the physical disk.
Now using the filesystem goes without problem.
Case 3: Both partition and filesystem extend beyond the end of the disk. In
forensic or debugging situations one often uses a copy of the start of a
disk. Now access beyond the end gives an expected I/O error.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Signed-off-by: Stephen Cameron <steve.cameron@hp.com>
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com>
Split the checkpoint list of the transaction into two lists. In the first
list we keep the buffers that need to be submitted for IO. In the second
list are kept buffers that were already submitted and we just have to wait
for the IO to complete. This should simplify a handling of checkpoint
lists a bit and can eventually be also a performance gain.
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: "Stephen C. Tweedie" <sct@redhat.com>
Mark a few non-exported functions static.
Signed-off-by: Peter Hagervall <hager@cs.umu.se>
Cc: Paul Fulghum <paulkf@microgate.com>
Correct the return type of handle_IRQ_event() (inconsistency noticed during
Xen development), and remove redundant declarations. The return type
adjustment required breaking out the definition of irqreturn_t into a
separate header, in order to satisfy current include order dependencies.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata.hirokazu@renesas.com>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
This patch fixes a NULL dereference spotted by the Coverity checker.
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Add a chapter on typedefs, copied from an email from Linus to lkml on Feb.
3, 2006. (Subject: Re: [RFC][PATCH 1/5] Virtualization/containers:
startup)
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
When CONFIG_BASE_SAMLL=1, cascade() in may enter the infinite loop.
Because of CONFIG_BASE_SMALL=1(TVR_BITS=6 and TVN_BITS=4), the list
base->tv5 may cascade into base->tv5. So, the kernel enters the infinite
loop in the function cascade().
I created a test module to verify this bug, and a patch to fix it.
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/timer.h>
#if 0
#include <linux/kdb.h>
#else
#define kdb_printf printk
#endif
#define TVN_BITS (CONFIG_BASE_SMALL ? 4 : 6)
#define TVR_BITS (CONFIG_BASE_SMALL ? 6 : 8)
#define TVN_SIZE (1 << TVN_BITS)
#define TVR_SIZE (1 << TVR_BITS)
#define TVN_MASK (TVN_SIZE - 1)
#define TVR_MASK (TVR_SIZE - 1)
#define TV_SIZE(N) (N*TVN_BITS + TVR_BITS)
struct timer_list timer0;
struct timer_list dummy_timer1;
struct timer_list dummy_timer2;
void dummy_timer_fun(unsigned long data) {
unsigned long j=0;
void check_timer_base(unsigned long data)
kdb_printf("check_timer_base %08x\n",jiffies);
mod_timer(&timer0,(jiffies & (~0xFFF)) + 0x1FFF);
int init_module(void)
init_timer(&timer0);
timer0.data = (unsigned long)0;
timer0.function = check_timer_base;
mod_timer(&timer0,jiffies+1);
init_timer(&dummy_timer1);
dummy_timer1.data = (unsigned long)0;
dummy_timer1.function = dummy_timer_fun;
init_timer(&dummy_timer2);
dummy_timer2.data = (unsigned long)0;
dummy_timer2.function = dummy_timer_fun;
j=jiffies;
j&=(~((1<<TV_SIZE(3))-1));
j+=(1<<TV_SIZE(3));
j+=(1<<TV_SIZE(4));
kdb_printf("mod_timer %08x\n",j);
mod_timer(&dummy_timer1, j );
mod_timer(&dummy_timer2, j );
return 0;
void cleanup_module()
del_timer_sync(&timer0);
del_timer_sync(&dummy_timer1);
del_timer_sync(&dummy_timer2);
(Cleanups from Oleg)
[oleg@tv-sign.ru: use list_replace_init()]
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Matt Mackall <mpm@selenic.com>
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
list_splice_init(list, head) does unneeded job if it is known that
list_empty(head) == 1. We can use list_replace_init() instead.
list_replace() is similar to list_replace_rcu(), but unlike
list_replace_rcu() it
could be used when list_empty(old) == 1
doesn't use barriers
Cc: Alexey Dobriyan <adobriyan@gmail.com>
There are three different IO cards which an SGI IOC4 controller may find
itself on. One of these variants does not bring out the IDE and serial
signals, so we need to disable attaching the corresponding IOC4 subdrivers
to such cards.
Cleans up message clutter emitted during device probing.
Signed-off-by: Brent Casavant <bcasavan@sgi.com>
Fix one audit kernel-doc description (one parameter was missing).
Add audit*.c interfaces to DocBook.
Add BSD accounting interfaces to DocBook.
Remove synchronize_kernel() (deprecated 2-APR-2005 in
http://lkml.org/lkml/2005/4/3/11) and makes the RCU API inaccessible to
non-GPL Linux kernel modules (as was announced more than one year ago in
http://lkml.org/lkml/2005/4/3/8). Tested on x86 and ppc64.
Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com>
kernel/sys.c doesn't have anything in it relying on linux/init.h -
remove the include.
Signed-off-by: Jes Sorensen <jes@sgi.com>
Provide a checklist of techniques to aid kernel patch submitters in
producing healthy patches and in lessening a burden on maintainers.
If invalidate_mapping_pages is called to invalidate a very large mapping
(e.g. a very large block device) and if the only active page in that
device is near the end (or at least, at a very large index), such as, say,
the superblock of an md array, and if that page happens to be locked when
invalidate_mapping_pages is called, then
pagevec_lookup will return this page and
as it is locked, 'next' will be incremented and pagevec_lookup
will be called again. and again. and again.
while we count from 0 upto a very large number.
We should really always set 'next' to 'page->index+1' before going around
the loop again, not just if the page isn't locked.
Cc: "Steinar H. Gunderson" <sgunderson@bigfoot.com>
Signed-off-by: Neil Brown <neilb@suse.de>
Cc: Greg KH <greg@kroah.com>
Put the connector exports at the functions so people can see them in context.
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Switch an open-coded strstrip() to use the new API.
Acked-by: Corey Minyard <minyard@acm.org>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Add a new strstrip() function to lib/string.c for removing leading and
trailing whitespace from a string.
Acked-by: Ingo Oeser <ioe-lkml@rameria.de>
Acked-by: Joern Engel <joern@wohnheim.fh-wedel.de>
Cc: Corey Minyard <minyard@acm.org>
Acked-by: Michael Holzheu <HOLZHEU@de.ibm.com>
Change the license on the process event structure passed between kernel and
userspace.
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Acked-by: Guillaume Thouvenin <guillaume.thouvenin@bull.net>
Acked-by: Nguyen Anh Quynh <aquynh@gmail.com>
Move connector header include to precisely where it's needed.
Remove unused time.h header file as well. This was leftover from previous
iterations of the process events patches.
Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net>
Cc: Nguyen Anh Quynh <aquynh@gmail.com>
