2007-07-16AFS: implement file lockingDavid Howells
Implement file locking for AFS. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Char: n_hdlc, allow RESTARTSYS retval of tty writeJiri Slaby
Acked-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Reduce cpuset.c write_lock_irq() to read_lock()Paul Menage
cpuset.c:update_nodemask() uses a write_lock_irq() on tasklist_lock to block concurrent forks; a read_lock() suffices and is less intrusive. Signed-off-by: Paul Menage<menage@google.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16RTC: Ratelimit "lost interrupts" messageBen Collins
We gets lots of these when the kernel is running on a hypervisor. Zach says "a guest kernel trying to get high frequency RTC will also be inaccurate, and inevitably will have unhidable interrupt lateness." Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16vdso: print fatal signalsIngo Molnar
Add the print-fatal-signals=1 boot option and the /proc/sys/kernel/print-fatal-signals runtime switch. This feature prints some minimal information about userspace segfaults to the kernel console. This is useful to find early bootup bugs where userspace debugging is very hard. Defaults to off. [akpm@linux-foundation.org: Don't add new sysctl numbers] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16procfs directory entry cleanupChangli Gao
Function proc_register() will assign proc_dir_operations and proc_dir_inode_operations to ent's members proc_fops and proc_iops correctly if ent is a directory. So the early assignment isn't necessary. Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Only send SIGXFSZ when exceeding rlimits.Micah Cowan
Some users have been having problems with utilities like cp or dd dumping core when they try to copy a file that's too large for the destination filesystem (typically, > 4gb). Apparently, some defunct standards required SIGXFSZ to be sent in such circumstances, but SUS only requires/allows it for when a written file exceeds the process's resource limits. I'd like to limit SIGXFSZs to the bare minimum required by SUS. Patch sent per http://lkml.org/lkml/2007/4/10/302 Signed-off-by: Micah Cowan <micahcowan@ubuntu.com> Acked-by: Alan Cox <alan@redhat.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16rocket.c: fix unchecked mutex_lock_interruptible()Satyam Sharma
Check the return of mutex_lock_interruptible() in drivers/char/rocket.c and return ERESTARTSYS if we were interrupted. Signed-off-by: Satyam Sharma <satyam.sharma@gmail.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16PIE randomizationJan Kratochvil
This patch is using mmap()'s randomization functionality in such a way that it maps the main executable of (specially compiled/linked -pie/-fpie) ET_DYN binaries onto a random address (in cases in which mmap() is allowed to perform a randomization). Origin of this patch is in exec-shield (http://people.redhat.com/mingo/exec-shield/) [jkosina@suse.cz: pie randomization: fix BAD_ADDR macro] Signed-off-by: Jan Kratochvil <honza@jikos.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Introduce CONFIG_VIRT_TO_BUSStephen Rothwell
Make some offending drivers depend on it and set CONFIG_ARCH_NO_VIRT_TO_BUS for ppc64 so that we don't build those drivers. This gets PowerPC allmodconfig and allyesconfig much closer to building. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16mpu401 warning fixesAndrew Morton
Fix these: sound/oss/mpu401.c: In function 'attach_mpu401': sound/oss/mpu401.c:1006: warning: cast to pointer from integer of different size sound/oss/mpu401.c:1115: warning: cast to pointer from integer of different size sound/oss/mpu401.c: In function 'unload_mpu401': sound/oss/mpu401.c:1230: warning: cast to pointer from integer of different size by making it implement the request_irq()/free_irq() cookies correctly. Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16isofs: fix up CodingStyleDave Jones
fs/isofs/* had a bunch of CodingStyle issues. * Indentation was a mix of spaces and tabs * "int * foo" instead of "int *foo" * "while ( foo )" instead of "while (foo)" * if (foo) blah; on one line instead of two * Missing printk KERN_ levels * lots of trailing whitespace * lines >80 columns changed to wrap. * Unnecessary prototype removed by shuffling code order in C file. Should be no functional changes other than slight size increase due to printk changes. Further improvement possible, but this is a start.. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16edd: switch to pci_get based APIAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Update zilog timeoutThiemo Seufer
Update zilog timeout, thanks Peter Fuerst. Signed-off-by: Thiemo Seufer <ths@networkno.de> Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Peter Fuerst <pf@net.alphadv.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fix compiler warnings in acorn.cDenver Gingerich
warning: 'adfs_partition' defined but not used warning: 'riscix_partition' defined but not used warning: 'linux_partition' defined but not used Signed-off-by: Denver Gingerich <denver@ossguy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16drivers/block/z2ram: Remove TRUE/FALSE definesRichard Knutsson
Remove defines of TRUE and FALSE * not used in the file * the file is not included somewhere else Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Remove unnecessary includes of spinlock.h under include/linuxRobert P. J. Day
Remove the obviously unnecessary includes of <linux/spinlock.h> under the include/linux/ directory, and fix the couple errors that are introduced as a result of that. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fat: gcc 4.3 warning fixOGAWA Hirofumi
This patch fixes the following warnings. fs/fat/dir.c: In function 'fat_parse_long': include/linux/msdos_fs.h:294: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds The ->name is defined as "name[8], ext[3]", but fat_checksum() uses those as name[11]. There is no actual problem, but it's not a good manner. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make NFS client use seq_list_xxx helpersPavel Emelianov
This includes /proc/fs/nfsfs/servers and /proc/fs/nfsfs/volumes entries. Both need to show the header and use the list_head. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make /proc/self/mounts(tats) use seq_list_xxx helpersPavel Emelianov
One more simple and stupid switching to the new API. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make /proc/tty/drivers use seq_list_xxx helpersPavel Emelianov
Simple and stupid like some previous ones. Just use new API. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make /proc/modules use seq_list_xxx helpersPavel Emelianov
Here there is not need even in .show callback altering. The original code passes list_head in *v. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make /proc/misc use seq_list_xxx helpersPavel Emelianov
Simple and stupid - just use the helpers. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make crypto API use seq_list_xxx helpersPavel Emelianov
Simple and stupid - just use the same code from another place in the kernel. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make AFS use seq_list_xxx helpersPavel Emelianov
These proc files show some header before dumping the list, so the seq_list_start_head() is used. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16percpu_counters: use for_each_online_cpu()Andrew Morton
Now that we have implemented hotunplug-time counter spilling, percpu_counter_sum() only needs to look at online CPUs. Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16percpu_counters(): use cpu notifiersAndrew Morton
per-cpu counters presently must iterate over all possible CPUs in the exhaustive percpu_counter_sum(). But it can be much better to only iterate over the presently-online CPUs. To do this, we must arrange for an offlined CPU's count to be spilled into the counter's central count. We can do this for all percpu_counters in the machine by linking them into a single global list and walking that list at CPU_DEAD time. (I hope. Might have race windows in which the percpu_counter_sum() count is inaccurate?) Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16vxfs warning fixesAndrew Morton
gcc-4.3: fs/freevxfs/vxfs_lookup.c: In function 'vxfs_find_entry': fs/freevxfs/vxfs_lookup.c:139: warning: cast from pointer to integer of different size fs/freevxfs/vxfs_lookup.c: In function 'vxfs_readdir': fs/freevxfs/vxfs_lookup.c:294: warning: cast from pointer to integer of different size Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fuse warning fixAndrew Morton
gcc-4.3: fs/fuse/dir.c: In function 'parse_dirfile': fs/fuse/dir.c:833: warning: cast from pointer to integer of different size fs/fuse/dir.c:835: warning: cast from pointer to integer of different size [miklos@szeredi.hu: use offsetof] Acked-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use mutexes instead of semaphores in I2O driverMatthias Kaehlcke
The I2O driver uses two semaphores as mutexes. Use the mutex API instead of the (binary) semaphores. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16cpu hotplug: fix ksoftirqd termination on cpu hotplug with naughty realtime ↵Satoru Takeuchi
process Fix ksoftirqd termination on cpu hotplug with naughty real time process. Assuming the following case: - Try to hot remove CPU2 from CPU1. - There is a real time process on CPU2, and that process doesn't sleep at all. - That rt process and ksoftirqd/2 is migrated to the CPU0 Then ksoftirqd/2 can't stop becasue that rt process runs everlastingly on CPU0, and CPU1 waiting the ksoftirqd/2's termination hangs up. To fix this problem, set the priority of ksoftirqd/2 to max one before kthread_stop(). [akpm@linux-foundation.org: fix warning] Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Fix stop_machine_run problem with naughty real time processSatoru Takeuchi
stop_machine_run() does its work on "kstopmachine" thread having max priority. However that thread get such priority after woken up. Therefore, in the following case ... - "kstopmachine" try to run on CPU1 - There is a real time process which doesn't relinquish CPU time voluntary on CPU1 ... "kstopmachine" can't start to run and the CPU on which stop_machine_run() is runing hangs up. To fix this problem, call sched_setscheduler() before waking up that thread. Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16UDF: check for allocated memory for inode dataCyrill Gorcunov
This patch adds checking for granted memory while filling up inode data to prevent possible NULL pointer usage. If there is not enough memory to fill inode data we just mark it as "bad". Also some whitespace cleanup. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Prevent an O_NDELAY writer from blocking when a tty write is blocked by the ↵Alan Cox
tty atomic writer mutex Without this a tty write could block if a previous blocking tty write was in progress on the same tty and blocked by a line discipline or hardware event. Originally found and reported by Dave Johnson. Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Dave Johnson <djohnson+linux-kernel@sw.starentnetworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16UDF: check for allocated memory for data of new inodesCyrill Gorcunov
Add checking for granted memory for inode data at the moment of its creation. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use boot based time for uptime in /procTomas Janousek
Commit 411187fb05cd11676b0979d9fbf3291db69dbce2 caused uptime not to increase during suspend. This may cause confusion so I restore the old behaviour by using the boot based time instead of monotonic for uptime. Signed-off-by: Tomas Janousek <tjanouse@redhat.com> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use boot based time for process start time and boot time in /procTomas Janousek
Commit 411187fb05cd11676b0979d9fbf3291db69dbce2 caused boot time to move and process start times to become invalid after suspend. Using boot based time for those restores the old behaviour and fixes the issue. [akpm@linux-foundation.org: little cleanup] Signed-off-by: Tomas Janousek <tjanouse@redhat.com> Cc: Tomas Smetana <tsmetana@redhat.com> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Introduce boot based timeTomas Janousek
The commits 411187fb05cd11676b0979d9fbf3291db69dbce2 (GTOD: persistent clock support) c1d370e167d66b10bca3b602d3740405469383de (i386: use GTOD persistent clock support) changed the monotonic time so that it no longer jumps after resume, but it's not possible to use it for boot time and process start time calculations then. Also, the uptime no longer increases during suspend. I add a variable to track the wall_to_monotonic changes, a function to get the real boot time and a function to get the boot based time from the monotonic one. [akpm@linux-foundation.org: remove exports, add comment] Signed-off-by: Tomas Janousek <tjanouse@redhat.com> Cc: Tomas Smetana <tsmetana@redhat.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16use no_pci_devices() in pci/search.cAndrew Morton
We have an API function for this now. Cc: Zhang Yanmin <yanmin.zhang@intel.com> Cc: Greg KH <greg@kroah.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fix jvc cdrom drive lockupZhang, Yanmin
Before calling init_hwif_default, ide_unregister gets lock ide_lock and disables irq. init_hwif_default calls ide_default_io_base which calls pci_get_device and later pci_get_subsys tries to apply for semaphore pci_bus_sem and goes to sleep. Mostly, pci_get_device should be called when irq is turned on. ide_default_io_base just needs find if list pci_devices is empty. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: Greg KH <greg@kroah.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects: W1Jan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects: PNPJan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects: parportJan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects: I2OJan Engelhardt
2007-07-16Use menuconfig objects: crypto hwJan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Michael Buesch <mb@bu3sch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects: connectorJan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects II - TPMJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Kylene Hall <kjhall@us.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects II - TelephonyJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects II - oprofileJan Engelhardt
Make a "menuconfig" out of the Kconfig objects "menu, ..., endmenu", so that the user can disable all the options in that menu at once instead of having to disable each option separately. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Philippe Elie <phil.el@wanadoo.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use menuconfig objects II - module menuJan Engelhardt
Change menuconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without entering its menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
