2011-08-12Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: replace xfs_buf_geterror() with bp->b_error xfs: Check the return value of xfs_buf_read() for NULL "xfs: fix error handling for synchronous writes" revisited xfs: set cursor in xfs_ail_splice() even when AIL was empty xfs: Remove the macro XFS_BUFTARG_NAME xfs: Remove the macro XFS_BUF_TARGET xfs: Remove the macro XFS_BUF_SET_TARGET Replace the macro XFS_BUF_ISPINNED with helper xfs_buf_ispinned xfs: Remove the macro XFS_BUF_SET_PTR xfs: Remove the macro XFS_BUF_PTR xfs: Remove macro XFS_BUF_SET_START xfs: Remove macro XFS_BUF_HOLD xfs: Remove macro XFS_BUF_BUSY and family xfs: Remove the macro XFS_BUF_ERROR and family xfs: Remove the macro XFS_BUF_BFLAGS
2011-08-12Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (32 commits) ARM: mmp: Change the way we use timer 0 as clockevent timer. ARM: mmp: Switch to using timer 1 as clocksource timer. ARM: mmp: Also start timer 1 on boot. ARM: pxa168/gplugd: free correct GPIO ARM: pxa168/gplugd: get rid of mfp-gplugd.h ARM: pxa: fix logic error in PJ4 iWMMXt handling mach-sa1100: fix PCI build problem omap: timer: Set dmtimer used as clocksource in autoreload mode OMAP3: am3517crane: remove NULL board_mux from board file arm: mach-omap2: mux: use kstrdup() arch:arm:plat-omap:iovmm: remove unused variable 'va' Update Nook Color machine 3284 to common Encore name am3505/3517: Various platform defines for UART4 OMAP: hwmod: fix build break on non-OMAP4 multi-OMAP2 builds OMAP: Fix linking error in twl-common.c for OMAP2/3/4 only builds iMX: Fix build for iMX53 ARM: mx5: board-cpuimx51.c fixup irq_to_gpio() usage OMAP2+: PM: SmartReflex: use put_sync_suspend for IRQ-safe disabling OMAP3: beagle: don't touch omap_device internals OMAP1: enable GENERIC_IRQ_CHIP ...
2011-08-12xfs: replace xfs_buf_geterror() with bp->b_errorChandra Seetharaman
Since we just checked bp for NULL, it is ok to replace xfs_buf_geterror() with bp->b_error in these places. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: Check the return value of xfs_buf_read() for NULLChandra Seetharaman
Check the return value of xfs_buf_read() for NULL and return ENOMEM if it is NULL. This is necessary in a few spots to avoid subsequent code blindly dereferencing the null buffer pointer. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12Merge branch 'fixes' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into fixes
2011-08-12Merge branch 'fix' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into fixes
2011-08-12Merge branch 'imx-fixes-for-arnd' of ↵Arnd Bergmann
git://git.pengutronix.de/git/imx/linux-2.6 into fixes
2011-08-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits) e1000e: increase driver version number e1000e: alternate MAC address update e1000e: do not disable receiver on 82574/82583 e1000e: alternate MAC address does not work on device id 0x1060 PCnet: Fix section mismatch bnx2x: disable dcb on 578xx since not supported yet bnx2x: properly clean indirect addresses bnx2x: prevent race between undi_unload and load flows bnx2x: fix select_queue when FCoE is disabled bnx2x: init FCOE FP only once ipv4: some rt_iif -> rt_route_iif conversions net/bridge/netfilter/ebtables.c: use available error handling code net/netlabel/netlabel_kapi.c: add missing cleanup code net/irda: sh_sir: tidyup compile warning net/irda: sh_sir: add missing header net/irda: sh_irda: add missing header slcan: ldisc generated skbs are received in softirq context scm: Capture the full credentials of the scm sender tcp: initialize variable ecn_ok in syncookies path drivers/net/wireless/wl1251: add missing kfree ...
2011-08-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: Don't do hypervisor calls on non-sun4v in DS driver.
2011-08-11Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2011-08-11sparc: Don't do hypervisor calls on non-sun4v in DS driver.David S. Miller
Reported-by: Pieter-Paul Giesberts <pieterpg@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11pnfs: Automatically select blocks & objects layoutsBoaz Harrosh
Just like files-layout, blocks & objects layouts are part of the NFS 4.1 protocol and should be automatically selected if NFS_4_1 is selected. The small problem is that these depend on other Kernel support being present, while files only depends on NFS itself. This patch removes from the user choice the presence of objects and blocks layout. But makes sure these are selected only if the depended subsystems are present in the Kernel. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Peng Tao <peng_tao@emc.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11ext4: Properly count journal credits for long symlinksEric Sandeen
Commit df5e6223407e ("ext4: fix deadlock in ext4_symlink() in ENOSPC conditions") recalculated the number of credits needed for a long symlink, in the process of splitting it into two transactions. However, the first credit calculation under-counted because if selinux is enabled, credits are needed to create the selinux xattr as well. Overrunning the reservation will result in an OOPS in jbd2_journal_dirty_metadata() due to this assert: J_ASSERT_JH(jh, handle->h_buffer_credits > 0); Fix this by increasing the reservation size. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11ext3: Properly count journal credits for long symlinksEric Sandeen
Commit ae54870a1dc9 ("ext3: Fix lock inversion in ext3_symlink()") recalculated the number of credits needed for a long symlink, in the process of splitting it into two transactions. However, the first credit calculation under-counted because if selinux is enabled, credits are needed to create the selinux xattr as well. Overrunning the reservation will result in an OOPS in journal_dirty_metadata() due to this assert: J_ASSERT_JH(jh, handle->h_buffer_credits > 0); Fix this by increasing the reservation size. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11e1000e: increase driver version numberBruce Allan
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-11e1000e: alternate MAC address updateBruce Allan
If word 0x37 in the EEPROM is 0xFFFF _or_ 0x0000, then there is no alternate MAC address in the EEPROM. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-11e1000e: do not disable receiver on 82574/82583Bruce Allan
Due to a hardware erratum, the receiver on 82574 and 82583 should not be stopped once it has been started. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-11e1000e: alternate MAC address does not work on device id 0x1060Bruce Allan
This issue is present all the way back to 2.6.34 kernels. CC: <stable@kernel.org> Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeffrey Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-11move RLIMIT_NPROC check from set_user() to do_execve_common()Vasiliy Kulikov
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC check in set_user() to check for NPROC exceeding via setuid() and similar functions. Before the check there was a possibility to greatly exceed the allowed number of processes by an unprivileged user if the program relied on rlimit only. But the check created new security threat: many poorly written programs simply don't check setuid() return code and believe it cannot fail if executed with root privileges. So, the check is removed in this patch because of too often privilege escalations related to buggy programs. The NPROC can still be enforced in the common code flow of daemons spawning user processes. Most of daemons do fork()+setuid()+execve(). The check introduced in execve() (1) enforces the same limit as in setuid() and (2) doesn't create similar security issues. Neil Brown suggested to track what specific process has exceeded the limit by setting PF_NPROC_EXCEEDED process flag. With the change only this process would fail on execve(), and other processes' execve() behaviour is not changed. Solar Designer suggested to re-check whether NPROC limit is still exceeded at the moment of execve(). If the process was sleeping for days between set*uid() and execve(), and the NPROC counter step down under the limit, the defered execve() failure because NPROC limit was exceeded days ago would be unexpected. If the limit is not exceeded anymore, we clear the flag on successful calls to execve() and fork(). The flag is also cleared on successful calls to set_user() as the limit was exceeded for the previous user, not the current one. Similar check was introduced in -ow patches (without the process flag). v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user(). Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2011-08-11Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf symbols: Check '/tmp/perf-' symbol file ownership perf sched: Usage leftover from trace -> script rename perf sched: Do not delete session object prematurely perf tools: Check $HOME/.perfconfig ownership perf, x86: Add model 45 SandyBridge support perf tools: Add support to install perf python extension perf tools: do not look at ./config for configuration perf tools: Make clean leaves some files perf lock: Dropping unsupported ':r' modifier perf probe: Fix coredump introduced by probe module option jump label: Reduce the cycle count by changing the link order perf report: Use ui__warning in some more places perf python: Add PERF_RECORD_{LOST,READ,SAMPLE} routine tables perf evlist: Introduce 'disable' method trace events: Update version number reference to new 3.x scheme for EVENT_POWER_TRACING_DEPRECATED perf buildid-cache: Zero out buffer of filenames when adding/removing buildid
2011-08-11MAINTAINERS: Update linus' git repositoryTracey Dent
Change to new git tree - (git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git). Signed-off-by: Tracey Dent <tdent48227@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11Revert "EDAC: Correct Kconfig dependencies"Linus Torvalds
This reverts commit af9d220bac41dc3201893e1601cc7c44f7da4498. It turns out that one was meant to be applied on top of the edac.git tree in -next that has more i7core_edac changes, but that wasn't clear in the original email. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11NFS41: make PNFS_BLOCK selectablePeng Tao
PNFS_BLOCK needs BLK_DEV_DM/MD, which is not a dependency for other pnfs layout drivers. Seperate it out so others can still build when BLK_DEV_DM/MD is not enabled. Also change select to depends on to avoid build failures. Reported-and-tested-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Peng Tao <peng_tao@emc.com> Acked-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11PCnet: Fix section mismatchRalf Baechle
Building MIPS mtx1_defconfig results in: MODPOST 735 modules WARNING: drivers/net/pcnet32.o(.devinit.text+0x11ec): Section mismatch in reference from the function pcnet32_probe_vlbus.constprop.22() to the variable .init.data:pcnet32_portlist The function __devinit pcnet32_probe_vlbus.constprop.22() references a variable __initdata pcnet32_portlist. If pcnet32_portlist is only used by pcnet32_probe_vlbus.constprop.22 then annotate pcnet32_portlist with a matching annotation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11bnx2x: disable dcb on 578xx since not supported yetDmitry Kravkov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11bnx2x: properly clean indirect addressesDmitry Kravkov
2011-08-11bnx2x: prevent race between undi_unload and load flowsDmitry Kravkov
2011-08-11bnx2x: fix select_queue when FCoE is disabledVladislav Zolotarov
2011-08-11bnx2x: init FCOE FP only onceVladislav Zolotarov
2011-08-11ipv4: some rt_iif -> rt_route_iif conversionsJulian Anastasov
As rt_iif represents input device even for packets coming from loopback with output route, it is not an unique key specific to input routes. Now rt_route_iif has such role, it was fl.iif in 2.6.38, so better to change the checks at some places to save CPU cycles and to restore 2.6.38 semantics. compare_keys: - input routes: only rt_route_iif matters, rt_iif is same - output routes: only rt_oif matters, rt_iif is not used for matching in __ip_route_output_key - now we are back to 2.6.38 state ip_route_input_common: - matching rt_route_iif implies input route - compared to 2.6.38 we eliminated one rth->fl.oif check because it was not needed even for 2.6.38 compare_hash_inputs: Only the change here is not an optimization, it has effect only for output routes. I assume I'm restoring the original intention to ignore oif, it was using fl.iif - now we are back to 2.6.38 state Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11net/bridge/netfilter/ebtables.c: use available error handling codeJulia Lawall
Free the locally allocated table and newinfo as done in adjacent error handling code. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11net/netlabel/netlabel_kapi.c: add missing cleanup codeJulia Lawall
Call cipso_v4_doi_putdef in the case of the failure of the allocation of entry. Reverse the order of the error handling code at the end of the function and insert more labels in order to reduce the number of unnecessary calls to kfree. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11net/irda: sh_sir: tidyup compile warningKuninori Morimoto
This patch tidyup below warning ${LINUX}/drivers/net/irda/sh_sir.c:514:6: warning: 'val' may be used uninitialized in this function Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11net/irda: sh_sir: add missing headerKuninori Morimoto
This patch fixup below build error on sh_sir sh_sir.c: In function 'sh_sir_write': sh_sir.c:127:2: error: implicit declaration of function 'iowrite16' sh_sir.c: In function 'sh_sir_read': sh_sir.c:132:2: error: implicit declaration of function 'ioread16' sh_sir.c: At top level: sh_sir.c:561:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'sh_sir_irq' sh_sir.c: In function 'sh_sir_probe': sh_sir.c:727:2: error: implicit declaration of function 'ioremap_nocache' sh_sir.c:727:16: warning: assignment makes pointer from integer without a cast sh_sir.c:762:2: error: implicit declaration of function 'request_irq' sh_sir.c:762:23: error: 'sh_sir_irq' undeclared (first use in this function) sh_sir.c:762:23: note: each undeclared identifier is reported only once for each function it appears in sh_sir.c:762:35: error: 'IRQF_DISABLED' undeclared (first use in this function) sh_sir.c:776:2: error: implicit declaration of function 'iounmap' sh_sir.c: At top level: sh_sir.c:436:13: warning: 'sh_sir_clear_all_err' defined but not used sh_sir.c:474:12: warning: 'sh_sir_is_which_phase' defined but not used sh_sir.c:490:13: warning: 'sh_sir_tx' defined but not used sh_sir.c:540:13: warning: 'sh_sir_rx' defined but not used Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11net/irda: sh_irda: add missing headerKuninori Morimoto
This patch fixup below build error on sh_irda sh_irda.c: In function 'sh_irda_write': sh_irda.c:174: error: implicit declaration of function 'iowrite16' sh_irda.c: In function 'sh_irda_read': sh_irda.c:184: error: implicit declaration of function 'ioread16' sh_irda.c: At top level: sh_irda.c:492: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'sh_irda_irq' sh_irda.c: In function 'sh_irda_probe': sh_irda.c:776: error: implicit declaration of function 'ioremap_nocache' sh_irda.c:776: warning: assignment makes pointer from integer without a cast sh_irda.c:811: error: implicit declaration of function 'request_irq' sh_irda.c:811: error: 'sh_irda_irq' undeclared (first use in this function) sh_irda.c:811: error: (Each undeclared identifier is reported only once sh_irda.c:811: error: for each function it appears in.) sh_irda.c:811: error: 'IRQF_DISABLED' undeclared (first use in this function) sh_irda.c:825: error: implicit declaration of function 'iounmap' Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11slcan: ldisc generated skbs are received in softirq contextOliver Hartkopp
As this discussion pointed out http://marc.info/?l=linux-netdev&m=131257225602375 netdevices that are based on serial line disciplines should use netif_rx_ni() when pushing received socketbuffers into the netdev rx queue. Following commit 614851601c121b1320a35757ab88292d6272f906 ("slip: fix NOHZ local_softirq_pending 08 warning") this patch updates the slcan driver accordingly. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> CC: Matvejchikov Ilya <matvejchikov@gmail.com> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11scm: Capture the full credentials of the scm senderTim Chen
This patch corrects an erroneous update of credential's gid with uid introduced in commit 257b5358b32f17 since 2.6.36. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-10tcp: initialize variable ecn_ok in syncookies pathMike Waychison
Using a gcc 4.4.3, warnings are emitted for a possibly uninitialized use of ecn_ok. This can happen if cookie_check_timestamp() returns due to not having seen a timestamp. Defaulting to ecn off seems like a reasonable thing to do in this case, so initialized ecn_ok to false. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11ARM: mmp: Change the way we use timer 0 as clockevent timer.Lennert Buytenhek
Instead of setting up a match interrupt for 'current_time + delta' on ->set_next_event(), program timer 0 to count down from 'delta - 1' and trigger an interrupt when it reaches zero. Signed-off-by: Lennert Buytenhek <buytenh@laptop.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-08-11ARM: mmp: Switch to using timer 1 as clocksource timer.Lennert Buytenhek
2011-08-11ARM: mmp: Also start timer 1 on boot.Lennert Buytenhek
Currently, arch-mmp/time.c uses timer 0 both as a clocksource timer and as a clockevent timer, the latter by setting up a comparator interrupt to match on 'current_time + delta'. This is problematic if delta is small enough, as that can lead to 'current_time + delta' already being in the past when comparator setup has finished, leading to the requested event not triggering. As there is also a silicon issue that requires stopping a timer's counter while writing to one of its match registers, we'll switch to using two separate timers -- timer 0 as clockevent timer, which we'll start and stop on every invocation of ->set_next_event(), and timer 1 as clocksource timer, which will be free-running. This first patch enables timer 1 on boot, so that we can use it as clocksource timer. Signed-off-by: Lennert Buytenhek <buytenh@laptop.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-08-11ARM: pxa168/gplugd: free correct GPIOTanmay Upadhyay
Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-08-11ARM: pxa168/gplugd: get rid of mfp-gplugd.hTanmay Upadhyay
Move definitions from mfp-gplugd.h to mfp-pxa168.h as they aren't gplugD specific. Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-08-11ARM: pxa: fix logic error in PJ4 iWMMXt handlingLennert Buytenhek
This got added in: commit ef6c84454f8567d4968c210d7d194fb711ed3739 Author: Haojian Zhuang <haojian.zhuang@marvell.com> Date: Wed Nov 24 11:54:25 2010 +0800 ARM: pxa: add iwmmx support for PJ4 which does: - mrc p15, 0, r2, c15, c1, 0 - orr r2, r2, #0x3 @ enable access to CP0 and CP1 - mcr p15, 0, r2, c15, c1, 0 + @ enable access to CP0 and CP1 + XSC(mrc p15, 0, r2, c15, c1, 0) + XSC(orr r2, r2, #0x3) + XSC(mcr p15, 0, r2, c15, c1, 0) but then later does: - mrc p15, 0, r4, c15, c1, 0 - orr r4, r4, #0x3 @ enable access to CP0 and CP1 - mcr p15, 0, r4, c15, c1, 0 + @ enable access to CP0 and CP1 + XSC(mrc p15, 0, r4, c15, c1, 0) + XSC(orr r4, r4, #0xf) + XSC(mcr p15, 0, r4, c15, c1, 0) Signed-off-by: Lennert Buytenhek <buytenh@laptop.org> Acked-by Haojian <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-08-10Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: drop experimental status for ARM_PATCH_PHYS_VIRT ARM: 7008/1: alignment: Make SIGBUS sent to userspace POSIXly correct ARM: 7007/1: alignment: Prevent ignoring of faults with ARMv6 unaligned access model ARM: 7010/1: mm: fix invalid loop for poison_init_mem ARM: 7005/1: freshen up mm/proc-arm946.S dmaengine: PL08x: Fix trivial build error ARM: Fix build error for SMP=n builds
2011-08-10"xfs: fix error handling for synchronous writes" revisitedAjeet Yadav
xfs: fix for hang during synchronous buffer write error If removed storage while synchronous buffer write underway, "xfslogd" hangs. Detailed log http://oss.sgi.com/archives/xfs/2011-07/msg00740.html Related work bfc60177f8ab509bc225becbb58f7e53a0e33e81 "xfs: fix error handling for synchronous writes" Given that xfs_bwrite actually does the shutdown already after waiting for the b_iodone completion and given that we actually found that calling xfs_force_shutdown from inside xfs_buf_iodone_callbacks was a major contributor the problem it better to drop this call. Signed-off-by: Ajeet Yadav <ajeet.yadav.77@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-10Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Really fix build without CONFIG_PCI powerpc: Fix build without CONFIG_PCI powerpc/4xx: Fix build of PCI code on 405 powerpc/pseries: Simplify vpa deregistration functions powerpc/pseries: Cleanup VPA registration and deregistration errors powerpc/pseries: Fix kexec on recent firmware versions MAINTAINERS: change maintainership of mpc5xxx powerpc: Make KVM_GUEST default to n powerpc/kvm: Fix build errors with older toolchains powerpc: Lack of ibm,io-events not that important! powerpc: Move kdump default base address to half RMO size on 64bit powerpc/perf: Disable pagefaults during callchain stack read ppc: Remove duplicate definition of PV_POWER7 powerpc: pseries: Fix kexec on machines with more than 4TB of RAM powerpc: Jump label misalignment causes oops at boot powerpc: Clean up some panic messages in prom_init powerpc: Fix device tree claim code powerpc: Return the_cpu_ spec from identify_cpu powerpc: mtspr/mtmsr should take an unsigned long
2011-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6: Ecryptfs: Add mount option to check uid of device being mounted = expect uid eCryptfs: Fix payload_len unitialized variable warning eCryptfs: fix compile error eCryptfs: Return error when lower file pointer is NULL
2011-08-10drivers/net/wireless/wl1251: add missing kfreeJulia Lawall
In each case, the kfree already at the end of the function is also needed in the error case. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @exists@ local idexpression x; statement S,S1; expression E; identifier fl; expression *ptr != NULL; @@ x = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S <... when != x when != if (...) { <+...kfree(x)...+> } when any when != true x == NULL x->fl ...> ( if (x == NULL) S1 | if (...) { ... when != x when forall ( return \(0\|<+...x...+>\|ptr\); | * return ...; ) } ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
