Use the information now cached in the skbuff private data to avoid the need
to reparse a jumbo packet. We can find all the subpackets by dead
reckoning, so it's only necessary to note how many there are, whether the
last one is flagged as LAST_PACKET and whether any have the REQUEST_ACK
flag set.
This is necessary as once recvmsg() can see the packet, it can start
modifying it, such as doing in-place decryption.
Fixes: 248f219cb8bc ("rxrpc: Rewrite the data and ack handling code")
Improve the information stored about jumbo packets so that we don't need to
reparse them so much later.
Reviewed-by: Jeffrey Altman <jaltman@auristor.com>
When a Tx timestamp is requested, a pointer to the skb is stored in the
ravb_tstamp_skb struct. This was done without an skb_get. There exists
the possibility that the skb could be freed by ravb_tx_free (when
ravb_tx_free is called from ravb_start_xmit) before the timestamp was
processed, leading to a use-after-free bug.
Use skb_get when filling a ravb_tstamp_skb struct, and add appropriate
frees/consumes when a ravb_tstamp_skb struct is freed.
Fixes: c156633f1353 ("Renesas Ethernet AVB driver proper")
Signed-off-by: Tho Vu <tho.vu.wh@rvc.renesas.com>
Signed-off-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Pablo Neira Ayuso says:
flow_offload hardware priority fixes
This patchset contains two updates for the flow_offload users:
1) Pass the major tc priority to drivers so they do not have to
lshift it. This is a preparation patch for the fix coming in
patch #2.
2) Set the hardware priority from the netfilter basechain priority,
some drivers break when using the existing hardware priority
number that is set to zero.
v5: fix patch 2/2 to address a clang warning and to simplify
the priority mapping.
This patch adds initial support for offloading basechains using the
priority range from 1 to 65535. This is restricting the netfilter
priority range to 16-bit integer since this is what most drivers assume
so far from tc. It should be possible to extend this range of supported
priorities later on once drivers are updated to support for 32-bit
integer priorities.
tc transparently maps the software priority number to hardware. Update
it to pass the major priority which is what most drivers expect. Update
drivers too so they do not need to lshift the priority field of the
flow_cls_common_offload object. The stmmac driver is an exception, since
this code assumes the tc software priority is fine, therefore, lshift it
just to be conservative.
Acked-by: Jiri Pirko <jiri@mellanox.com>
In i2400m_barker_db_init(), 'options_orig' is allocated through kstrdup()
to hold the original command line options. Then, the options are parsed.
However, if an error occurs during the parsing process, 'options_orig' is
not deallocated, leading to a memory leak bug. To fix this issue, free
'options_orig' before returning the error.
Signed-off-by: Wenwen Wang <wenwen@cs.uga.edu>
The driver name gets exposed in sysfs under /sys/bus/pci/drivers
so it should look like other devices. Change it to be common
format (instead of "Cavium PTP").
This is a trivial fix that was observed by accident because
Debian kernels were building this driver into kernel (bug).
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
There's no need to wait until a completion is received to unmap
TX descriptor buffers that have been passed to the hypervisor.
Instead unmap it when the hypervisor call has completed. This patch
avoids the possibility that a buffer will not be unmapped because
a TX completion is lost or mishandled.
Reported-by: Abdul Haleem <abdhalee@linux.vnet.ibm.com>
Tested-by: Devesh K. Singh <devesh_singh@in.ibm.com>
Signed-off-by: Thomas Falcon <tlfalcon@linux.ibm.com>
Michael Chan says:
bnxt_en: Bug fixes.
2 Bug fixes related to 57500 shutdown sequence and doorbell sequence,
2 TC Flower bug fixes related to the setting of the flow direction,
1 NVRAM update bug fix, and a minor fix to suppress an unnecessary
error message. Please queue for -stable as well. Thanks.
FW expects the driver to provide unique flow reference handles
for Tx or Rx flows. When a Tx flow and an Rx flow end up sharing
a reference handle, flow offload does not seem to work.
This could happen in the case of 2 flows having their L2 fields
wildcarded but in different direction.
Fix to incorporate the flow direction as part of the L2 key
v2: Move the dir field to the end of the bnxt_tc_l2_key struct to
fix the warning reported by kbuild test robot <lkp@intel.com>.
There is existing code that initializes the structure using
nested initializer and will warn with the new u8 field added to
the beginning. The structure also packs nicer when this new u8 is
added to the end of the structure [MChan].
Fixes: abd43a13525d ("bnxt_en: Support for 64-bit flow handle.")
Signed-off-by: Somnath Kotur <somnath.kotur@broadcom.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
Direction of the flow is determined using src_fid. For an RX flow,
src_fid is PF's fid and for TX flow, src_fid is VF's fid. Direction
of the flow must be specified, when getting statistics for that flow.
Currently, for DECAP flow, direction is determined incorrectly, i.e.,
direction is initialized as TX for DECAP flow, instead of RX. Because
of which, stats are not reported for this DECAP flow, though it is
offloaded and there is traffic for that flow, resulting in flow age out.
This patch fixes the problem by determining the DECAP flow's direction
using correct fid. Set the flow direction in all cases for consistency
even if 64-bit flow handle is not used.
Signed-off-by: Venkat Duvvuru <venkatkumar.duvvuru@broadcom.com>
For newly added NVM parameters, older firmware may not have the support.
Suppress the error message to avoid the unncessary error message which is
triggered when devlink calls the driver during initialization.
Fixes: 782a624d00fa ("bnxt_en: Add bnxt_en initial params table and register it.")
Signed-off-by: Vasundhara Volam <vasundhara-v.volam@broadcom.com>
If FW returns FRAG_ERR in response error code, driver is resending the
command only when HWRM command returns success. Fix the code to resend
NVM_INSTALL_UPDATE command with DEFRAG install flags, if FW returns
FRAG_ERR in its response error code.
Fixes: cb4d1d626145 ("bnxt_en: Retry failed NVM_INSTALL_UPDATE with defragmentation flag enabled.")
When both RX buffers and RX aggregation buffers have to be
replenished at the end of NAPI, post the RX aggregation buffers first
before RX buffers. Otherwise, we may run into a situation where
there are only RX buffers without RX aggregation buffers for a split
second. This will cause the hardware to abort the RX packet and
report buffer errors, which will cause unnecessary cleanup by the
driver.
Ringing the Aggregation ring doorbell first before the RX ring doorbell
will prevent some of these buffer errors. Use the same sequence during
ring initialization as well.
Fixes: 697197e5a173 ("bnxt_en: Re-structure doorbells.")
During device shutdown, the VNIC clearing sequence needs to be modified
to free the VNIC first before freeing the RSS contexts. The current
code is doing the reverse and we can get mis-directed RX completions
to CP ring ID 0 when the RSS contexts are freed and zeroed. The clearing
of RSS contexts is not required with the new sequence.
Refactor the VNIC clearing logic into a new function bnxt_clear_vnic()
and do the chip specific VNIC clearing sequence.
Fixes: 7b3af4f75b81 ("bnxt_en: Add RSS support for 57500 chips.")
In kalmia_init_and_get_ethernet_addr(), 'usb_buf' is allocated through
kmalloc(). In the following execution, if the 'status' returned by
kalmia_send_init_packet() is not 0, 'usb_buf' is not deallocated, leading
to memory leaks. To fix this issue, add the 'out' label to free 'usb_buf'.
In cx82310_bind(), 'dev->partial_data' is allocated through kmalloc().
Then, the execution waits for the firmware to become ready. If the firmware
is not ready in time, the execution is terminated. However, the allocated
'dev->partial_data' is not deallocated on this path, leading to a memory
leak bug. To fix this issue, free 'dev->partial_data' before returning the
error.
Commit 04f05230c5c13 ("bnx2x: Remove configured vlans as
part of unload sequence."), introduced a regression in driver
that as a part of VF's reload flow, VLANs created on the VF
doesn't get re-configured in hardware as vlan metadata/info
was not getting cleared for the VFs which causes vlan PING to stop.
This patch clears the vlan metadata/info so that VLANs gets
re-configured back in the hardware in VF's reload flow and
PING/traffic continues for VLANs created over the VFs.
Fixes: 04f05230c5c13 ("bnx2x: Remove configured vlans as part of unload sequence.")
Signed-off-by: Manish Chopra <manishc@marvell.com>
Signed-off-by: Sudarsana Kalluru <skalluru@marvell.com>
Signed-off-by: Shahed Shaikh <shshaikh@marvell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
Johan Hedberg says:
pull request: bluetooth 2019-08-17
Here's a set of Bluetooth fixes for the 5.3-rc series:
- Multiple fixes for Qualcomm (btqca & hci_qca) drivers
- Minimum encryption key size debugfs setting (this is required for
Bluetooth Qualification)
- Fix hidp_send_message() to have a meaningful return value
For testing and qualification purposes it is useful to allow changing
the minimum encryption key size value that the host stack is going to
enforce. This adds a new debugfs setting min_encrypt_key_size to achieve
this functionality.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
This commit eliminates the use of the link 'stale_limit' & 'prev_from'
(besides the already removed - 'stale_cnt') variables in the detection
of repeated retransmit failures as there is no proper way to initialize
them to avoid a false detection, i.e. it is not really a retransmission
failure but due to a garbage values in the variables.
Instead, a jiffies variable will be added to individual skbs (like the
way we restrict the skb retransmissions) in order to mark the first skb
retransmit time. Later on, at the next retransmissions, the timestamp
will be checked to see if the skb in the link transmq is "too stale",
that is, the link tolerance time has passed, so that a link reset will
be ordered. Note, just checking on the first skb in the queue is fine
enough since it must be the oldest one.
A counter is also added to keep track the actual skb retransmissions'
number for later checking when the failure happens.
The downside of this approach is that the skb->cb[] buffer is about to
be exhausted, however it is always able to allocate another memory area
and keep a reference to it when needed.
Fixes: 77cf8edbc0e7 ("tipc: simplify stale link failure criteria")
Reported-by: Hoang Le <hoang.h.le@dektech.com.au>
Acked-by: Ying Xue <ying.xue@windriver.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
Signed-off-by: Tuong Lien <tuong.t.lien@dektech.com.au>
In lan78xx_probe(), a new urb is allocated through usb_alloc_urb() and
saved to 'dev->urb_intr'. However, in the following execution, if an error
occurs, 'dev->urb_intr' is not deallocated, leading to memory leaks. To fix
this issue, invoke usb_free_urb() to free the allocated urb before
returning from the function.
Update MAINTAINERS record to reflect the filename change.
The file was moved in commit 25e992a4603c ("r8169: rename
r8169.c to r8169_main.c")
Cc: Heiner Kallweit <hkallweit1@gmail.com>
Cc: nic_swsd@realtek.com
Cc: netdev@vger.kernel.org
Signed-off-by: Denis Efremov <efremov@linux.com>
Reviewed-by: Heiner Kallweit <hkallweit1@gmail.com>
Update MAINTAINERS to reflect that sysfs-bus-mdio was removed in
commit a6cd0d2d493a ("Documentation: net-sysfs: Remove duplicate
PHY device documentation") and sysfs-class-net-phydev was added in
commit 86f22d04dfb5 ("net: sysfs: Document PHY device sysfs
attributes").
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
David Howells says:
rxrpc: Fix local endpoint handling
Here's a pair of patches that fix two issues in the handling of local
endpoints (rxrpc_local structs):
(1) Use list_replace_init() rather than list_replace() if we're going to
unconditionally delete the replaced item later, lest the list get
corrupted.
(2) Don't access the rxrpc_local object after passing our ref to the
workqueue, not even to illuminate tracepoints, as the work function
may cause the object to be freed. We have to cache the information
beforehand.
Netfilter fixes for net
This patchset contains Netfilter fixes for net:
1) Extend selftest to cover flowtable with ipsec, from Florian Westphal.
2) Fix interaction of ipsec with flowtable, also from Florian.
3) User-after-free with bound set to rule that fails to load.
4) Adjust state and timeout for flows that expire.
5) Timeout update race with flows in teardown state.
6) Ensure conntrack id hash calculation use invariants as input,
from Dirk Morris.
7) Do not push flows into flowtable for TCP fin/rst packets.
packet_sendmsg() checks tx_ring.pg_vec to decide
if it must call tpacket_snd().
Problem is that the check is lockless, meaning another thread
can issue a concurrent setsockopt(PACKET_TX_RING ) to flip
tx_ring.pg_vec back to NULL.
Given that tpacket_snd() grabs pg_vec_lock mutex, we can
perform the check again to solve the race.
syzbot reported :
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 11429 Comm: syz-executor394 Not tainted 5.3.0-rc4+ #101
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:packet_lookup_frame+0x8d/0x270 net/packet/af_packet.c:474
Code: c1 ee 03 f7 73 0c 80 3c 0e 00 0f 85 cb 01 00 00 48 8b 0b 89 c0 4c 8d 24 c1 48 b8 00 00 00 00 00 fc ff df 4c 89 e1 48 c1 e9 03 <80> 3c 01 00 0f 85 94 01 00 00 48 8d 7b 10 4d 8b 3c 24 48 b8 00 00
RSP: 0018:ffff88809f82f7b8 EFLAGS: 00010246
RAX: dffffc0000000000 RBX: ffff8880a45c7030 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 1ffff110148b8e06 RDI: ffff8880a45c703c
RBP: ffff88809f82f7e8 R08: ffff888087aea200 R09: fffffbfff134ae50
R10: fffffbfff134ae4f R11: ffffffff89a5727f R12: 0000000000000000
R13: 0000000000000001 R14: ffff8880a45c6ac0 R15: 0000000000000000
FS: 00007fa04716f700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 00007fa04716edb8 CR3: 0000000091eb4000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
packet_current_frame net/packet/af_packet.c:487 [inline]
tpacket_snd net/packet/af_packet.c:2667 [inline]
packet_sendmsg+0x590/0x6250 net/packet/af_packet.c:2975
sock_sendmsg_nosec net/socket.c:637 [inline]
sock_sendmsg+0xd7/0x130 net/socket.c:657
___sys_sendmsg+0x3e2/0x920 net/socket.c:2311
__sys_sendmmsg+0x1bf/0x4d0 net/socket.c:2413
__do_sys_sendmmsg net/socket.c:2442 [inline]
__se_sys_sendmmsg net/socket.c:2439 [inline]
__x64_sys_sendmmsg+0x9d/0x100 net/socket.c:2439
do_syscall_64+0xfd/0x6a0 arch/x86/entry/common.c:296
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fixes: 69e3c75f4d54 ("net: TX_RING and packet mmap")
Reported-by: syzbot <syzkaller@googlegroups.com>
In myri10ge_probe(), myri10ge_alloc_slices() is invoked to allocate slices
related structures. Later on, myri10ge_request_irq() is used to get an irq.
However, if this process fails, the allocated slices related structures are
not deallocated, leading to memory leaks. To fix this issue, revise the
target label of the goto statement to 'abort_with_slices'.
The ctx->sk_write_space pointer is only set when TLS tx mode is enabled.
When running without TX mode its a null pointer but we still set the
sk sk_write_space pointer on close().
Fix the close path to only overwrite sk->sk_write_space when the current
pointer is to the tls_write_space function indicating the tls module should
clean it up properly as well.
Reported-by: Hillf Danton <hdanton@sina.com>
Cc: Ying Xue <ying.xue@windriver.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
Fixes: 57c722e932cfb ("net/tls: swap sk_write_space on close")
Signed-off-by: John Fastabend <john.fastabend@gmail.com>
Reviewed-by: Jakub Kicinski <jakub.kicinski@netronome.com>
If oct->fn_list.enable_io_queues() fails, no cleanup is executed, leading
to memory/resource leaks. To fix this issue, invoke
octeon_delete_instr_queue() before returning from the function.
git://git.kernel.org/pub/scm/linux/kernel/git/saeed/linux
Saeed Mahameed says:
Mellanox, mlx5 fixes 2019-08-15
This series introduces two fixes to mlx5 driver.
1) Eran fixes a compatibility issue with ethtool flash.
2) Maxim fixes a race in XSK wakeup flow.
Please pull and let me know if there is any problem.
Cited patch deleted ethtool flash device support, as ethtool core can
fallback into devlink flash callback. However, this is supported only if
there is a devlink port registered over the corresponding netdevice.
As mlx5e do not have devlink port support over native netdevice, it broke
the ability to flash device via ethtool.
This patch re-add the ethtool callback to avoid user functionality breakage
when trying to flash device via ethtool.
Fixes: 9c8bca2637b8 ("mlx5: Move firmware flash implementation to devlink")
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
Add a missing spinlock around XSKICOSQ usage at the activation stage,
because there is a race between a configuration change and the
application calling sendto().
Fixes: db05815b36cb ("net/mlx5e: Add XSK zero-copy support")
Signed-off-by: Maxim Mikityanskiy <maximmi@mellanox.com>
Reviewed-by: Tariq Toukan <tariqt@mellanox.com>
When running tcp_fastopen_backup_key.sh the following issue was seen in
a busybox environment.
./tcp_fastopen_backup_key.sh: line 33: [: -ne: unary operator expected
Shellcheck showed the following issue.
$ shellcheck tools/testing/selftests/net/tcp_fastopen_backup_key.sh
In tools/testing/selftests/net/tcp_fastopen_backup_key.sh line 33:
if [ $val -ne 0 ]; then
^-- SC2086: Double quote to prevent globbing and word splitting.
Rework to do a string comparison instead.
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
In blocked_fl_write(), 't' is not deallocated if bitmap_parse_user() fails,
leading to a memory leak bug. To fix this issue, free t before returning
the error.
Don't fall through to print error message when receive sleep indication
in HCI_IBS_RX_ASLEEP state, this is allowed behavior.
Signed-off-by: Rocky Liao <rjliao@codeaurora.org>
rxrpc_queue_local() attempts to queue the local endpoint it is given and
then, if successful, prints a trace line. The trace line includes the
current usage count - but we're not allowed to look at the local endpoint
at this point as we passed our ref on it to the workqueue.
Fix this by reading the usage count before queuing the work item.
Also fix the reading of local->debug_id for trace lines, which must be done
with the same consideration as reading the usage count.
Fixes: 09d2bf595db4 ("rxrpc: Add a tracepoint to track rxrpc_local refcounting")
Reported-by: syzbot+78e71c5bab4f76a6a719@syzkaller.appspotmail.com
When a local endpoint (struct rxrpc_local) ceases to be in use by any
AF_RXRPC sockets, it starts the process of being destroyed, but this
doesn't cause it to be removed from the namespace endpoint list immediately
as tearing it down isn't trivial and can't be done in softirq context, so
it gets deferred.
If a new socket comes along that wants to bind to the same endpoint, a new
rxrpc_local object will be allocated and rxrpc_lookup_local() will use
list_replace() to substitute the new one for the old.
Then, when the dying object gets to rxrpc_local_destroyer(), it is removed
unconditionally from whatever list it is on by calling list_del_init().
However, list_replace() doesn't reset the pointers in the replaced
list_head and so the list_del_init() will likely corrupt the local
endpoints list.
Fix this by using list_replace_init() instead.
Fixes: 730c5fd42c1e ("rxrpc: Fix local endpoint refcounting")
Reported-by: syzbot+193e29e9387ea5837f1d@syzkaller.appspotmail.com
TCP rst and fin packets do not qualify to place a flow into the
flowtable. Most likely there will be no more packets after connection
closure. Without this patch, this flow entry expires and connection
tracking picks up the entry in ESTABLISHED state using the fixup
timeout, which makes this look inconsistent to the user for a connection
that is actually already closed.
If the stream outq is not empty, need to kfree nstr_list.
Fixes: d570a59c5b5f ("sctp: only allow the out stream reset when the stream outq is empty")
Signed-off-by: zhengbin <zhengbin13@huawei.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Eric reported a syzbot warning:
BUG: KMSAN: uninit-value in nh_valid_get_del_req+0x6f1/0x8c0 net/ipv4/nexthop.c:1510
CPU: 0 PID: 11812 Comm: syz-executor444 Not tainted 5.3.0-rc3+ #17
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x191/0x1f0 lib/dump_stack.c:113
kmsan_report+0x162/0x2d0 mm/kmsan/kmsan_report.c:109
__msan_warning+0x75/0xe0 mm/kmsan/kmsan_instr.c:294
rtm_del_nexthop+0x1b1/0x610 net/ipv4/nexthop.c:1543
rtnetlink_rcv_msg+0x115a/0x1580 net/core/rtnetlink.c:5223
netlink_rcv_skb+0x431/0x620 net/netlink/af_netlink.c:2477
rtnetlink_rcv+0x50/0x60 net/core/rtnetlink.c:5241
netlink_unicast_kernel net/netlink/af_netlink.c:1302 [inline]
netlink_unicast+0xf6c/0x1050 net/netlink/af_netlink.c:1328
netlink_sendmsg+0x110f/0x1330 net/netlink/af_netlink.c:1917
sock_sendmsg net/socket.c:657 [inline]
___sys_sendmsg+0x14ff/0x1590 net/socket.c:2311
__sys_sendmmsg+0x53a/0xae0 net/socket.c:2413
__se_sys_sendmmsg+0xbd/0xe0 net/socket.c:2439
__x64_sys_sendmmsg+0x56/0x70 net/socket.c:2439
do_syscall_64+0xbc/0xf0 arch/x86/entry/common.c:297
entry_SYSCALL_64_after_hwframe+0x63/0xe7
The root cause is nlmsg_parse calling __nla_parse which means the
header struct size is not checked.
nlmsg_parse should be a wrapper around __nlmsg_parse with
NL_VALIDATE_STRICT for the validate argument very much like
nlmsg_parse_deprecated is for NL_VALIDATE_LIBERAL.
Fixes: 3de6440354465 ("netlink: re-add parse/validate functions in strict mode")
Reported-by: Eric Dumazet <edumazet@google.com>
Signed-off-by: David Ahern <dsahern@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
After configuring and restarting aneg we immediately try to read the
link status. On some systems the PHY may not yet have cleared the
"aneg complete" and "link up" bits, resulting in a false link-up
signal. See [0] for a report.
Clause 22 and 45 both require the PHY to keep the AN_RESTART
bit set until the PHY actually starts auto-negotiation.
Let's consider this in the generic functions for reading link status.
The commit marked as fixed is the first one where the patch applies
cleanly.
[0] https://marc.info/?t=156518400300003&r=1&w=2
Fixes: c1164bb1a631 ("net: phy: check PMAPMD link status only in genphy_c45_read_link")
Tested-by: Yonglong Liu <liuyonglong@huawei.com>
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
In mlx4_en_config_rss_steer(), 'rss_map->indir_qp' is allocated through
kzalloc(). After that, mlx4_qp_alloc() is invoked to configure RSS
indirection. However, if mlx4_qp_alloc() fails, the allocated
'rss_map->indir_qp' is not deallocated, leading to a memory leak bug.
To fix the above issue, add the 'qp_alloc_err' label to free
'rss_map->indir_qp'.
Fixes: 4931c6ef04b4 ("net/mlx4_en: Optimized single ring steering")
The ibm,mac-address-filters property defines the maximum number of
addresses the hypervisor's multicast filter list can support. It is
encoded as a big-endian integer in the OF device tree, but the virtual
ethernet driver does not convert it for use by little-endian systems.
As a result, the driver is not behaving as it should on affected systems
when a large number of multicast addresses are assigned to the device.
Reported-by: Hangbin Liu <liuhangbin@gmail.com>
Callbacks for a cmd reply run outside the protection of card->lock, to
allow for additional cmds to be issued & enqueued in parallel.
When qeth_send_control_data() bails out for a cmd without having
received a reply (eg. due to timeout), its callback may concurrently be
processing a reply that just arrived. In this case, the callback
potentially accesses a stale reply->reply_param area that eg. was
on-stack and has already been released.
To avoid this race, add some locking so that qeth_send_control_data()
can (1) wait for a concurrently running callback, and (2) zap any
pending callback that still wants to run.
Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com>
As the annotation says in sctp_do_8_2_transport_strike():
"If the transport error count is greater than the pf_retrans
threshold, and less than pathmaxrtx ..."
It should be transport->error_count checked with pathmaxrxt,
instead of asoc->pf_retrans.
Fixes: 5aa93bcf66f4 ("sctp: Implement quick failover draft from tsvwg")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Change ct id hash calculation to only use invariants.
Currently the ct id hash calculation is based on some fields that can
change in the lifetime on a conntrack entry in some corner cases. The
current hash uses the whole tuple which contains an hlist pointer which
will change when the conntrack is placed on the dying list resulting in
a ct id change.
This patch also removes the reply-side tuple and extension pointer from
the hash calculation so that the ct id will will not change from
initialization until confirmation.
Fixes: 3c79107631db1f7 ("netfilter: ctnetlink: don't use conntrack/expect object addresses as id")
Signed-off-by: Dirk Morris <dmorris@metaloft.com>
Acked-by: Florian Westphal <fw@strlen.de>
This driver does a funny dance disabling and re-enabling
RX and/or TX delays. In any of the RGMII-ID modes, it first
disables the delays, just to re-enable them again right
away. This looks like a needless exercise.
Just enable the respective delays when in any of the
relevant 'id' modes, and disable them otherwise.
Also, remove comments which don't add anything that can't be
seen by looking at the code.
Signed-off-by: André Draszik <git@andred.net>
CC: Andrew Lunn <andrew@lunn.ch>
CC: Florian Fainelli <f.fainelli@gmail.com>
CC: Heiner Kallweit <hkallweit1@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: netdev@vger.kernel.org
This patch will reset the download flag to default value
before retrieving the download mode type.
Fixes: 32646db8cc28 ("Bluetooth: btqca: inject command complete event during fw download")
Signed-off-by: Balakrishna Godavarthi <bgodavar@codeaurora.org>
Tested-by: Claire Chang <tientzu@chromium.org>
Reviewed-by: Claire Chang <tientzu@chromium.org>
