This is the same change for imx6sx clock driver as "ARM: imx6q: add BYPASS
support for PLL clocks" for imx6q. The difference is that only anaclk1
is available on imx6sx.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This is the same change for imx6sl clock driver as "ARM: imx6q: add BYPASS
is available on imx6sl.
The imx6q clock driver currently hard-codes all PLL clocks to source
from OSC24M without BYPASS support. The patch adds the missing lvds_in
clock which is mutually exclusive with lvds_gate, and implements BYPASS
and BYPASS_CLK_SRC selection for PLL clocks as per Figure 10-3. Primary
Clock Generation in IMX6DQRM, i.e. both BYPASS_CLK_SRC and BYPASS bits
are implemented as mux clocks, and ENABLE bit of PLL clocks is
implemented as a gate clock after BYPASS mux.
There are a couple of gate clocks are mutually exclusive on i.MX6, i.e.
LVDSCLK1_IBEN and LVDSCLK1_OBEN. They cannot be enabled simultaneously.
This patches adds an exclusive gate clock type specifically for such
case. The clock driver will need to call imx_clk_gate_exclusive() to
register a gate clock with parameter exclusive_mask indicating the mask
of gate bits which are mutually exclusive to this gate clock.
Right now, it only handles the exclusive gate clocks which are defined
in a single hardware register, which is the case we're running into
today. But it can be extended to handle exclusive gate clocks defined
in different registers later if needed.
Each SSI has "ssi", "ssi_ipg" clocks, and they share same gate bits.
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
ASRC has "asrc", "asrc_ipg", "asrc_mem" clocks, and they share
the same gate bits.
The parent clocks of IMX6SL_CLK_PXP_AXI_SEL and IMX6SL_CLK_EPDC_AXI_SEL
clocks are not the same. So split the epdc_pxp_sels into two different
clock selections 'pxp_axi_sels' and 'epdc_axi_sels'.
Signed-off-by: Fancy Fang <chen.fang@freescale.com>
Signed-off-by: Robby Cai <R63905@freescale.com>
There are three clock for ESAI, esai_extal, esai_ipg, esai_mem. Rename
'esai' to 'esai_extal', 'esai_ahb' to 'esai_mem', and add 'esai_ipg'.
Make the clock for ESAI more clear and align them with imx6sx.
PLL5 is well suited for being the parent of IMX6SL_CLK_LCDIF_PIX_SEL and
PLL2_PFD for IMX6SL_CLK_LCDIF_AXI_SEL.
Currently csi_lcdif_sels[] is a shared array for the providing the possible
clock parents for csi and lcdif blocks.
This is not correct, as csi and lcdif do not share the same clock parents.
Introduce csi_sels[] for the csi and lcdif_axi_sels[] for the lcdif clocks in
order to describe the parents correctly.
This commit adds PLL7 which is required for USBPHY1. It also adds
the USB PHY and USB Controller clocks and the gates to enable them.
Acked-by: Jingchang Lu <jingchang.lu@freescale.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Add cpufreq support for i.MX6SX, using common
i.MX6Q cpufreq driver.
Signed-off-by: Anson Huang <b20788@freescale.com>
At the end of the boot process, the clock framework might disable
required main PLL's. So far, this was no issue since drivers
requested clocks, which are descended of the main PLL's (e.g.
pll1_pfd1, which provides the system clock).
To archive the full 500MHz system clock, DDR clock need to be a
descendant of PLL2 rather than PLL1 (DDRC_CLK_SEL set to 0). The
bootloader sets up the clocks accordingly before making use of
DDR at all. However, in Linux, there is no driver using PLL2,
which lead to PLL2 being disabled by the clock framework.
With this patch, we make sure that the main system clock and the
DDR clock are initially enabled and are kept enabled.
This patch adds basic devicetree support for i.MX1 based SoCs.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Add more revision support for the new i.MX6DQ tape-out (TO1.5). This
TO1.5 is the Rev 1.3 as documented in i.MX6DQ data sheet, because TO1.3
and TO1.4 are never revealed.
Signed-off-by: Jason Liu <r64343@freescale.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
All the current support of mach-mxt_td60 board can be converted to devicetree.
Remove the board file.
Cc: Alan Carvalho de Assis <acassis@gmail.com>
mx1ads.c can be replaced with devicetree equivalent: imx1-ads.dts,
so remove the board file.
This was added by:
Commit 8128c4f36 ("ARM: dts: vf610-twr: Add simple-card support.")
This useless property may cause some confusions for users.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
With commit c716483c3db1 ("ARM: 8122/1: smp_scu: enable SCU standby
support"), the STANDBY bit of SCU is handled by core function
scu_enable(). So imx_scu_standby_enable() can be removed now.
pcm970-baseboard.c and mach-pcm038.c can be replaced with their
devicetree equivalents: imx27-phytec-phycore-rdk.dts and
imx27-phytec-phycore-som.dtsi respectively, so remove the board files.
eukrea_mbimx27-baseboard.c and mach-cpuimx27.c can be replaced with their
devicetree equivalents: imx27-eukrea-mbimxsd27-baseboard.dts and
imx27-eukrea-cpuimx27.dtsi respectively, so remove the board files.
Acked-by: Eric Bénard <eric@eukrea.com>
The iomux function declarations are in headers only accessible in this
directory. Thus those can't be used in any module. None of the
objects in this directory is tristate. Neither can the header be included
in out-of-tree modules.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Pull Xtensa updates from Chris Zankel:
"Xtensa improvements for 3.17:
- support highmem on cores with aliasing data cache. Enable highmem
on kc705 by default
- simplify addition of new core variants (no need to modify Kconfig /
Makefiles)
- improve robustness of unaligned access handler and its interaction
with window overflow/underflow exception handlers
- deprecate atomic and spill registers syscalls
- clean up Kconfig: remove orphan MATH_EMULATION, sort 'select'
statements
- wire up renameat2 syscall.
Various fixes:
- fix address checks in dma_{alloc,free}_coherent (runtime BUG)
- fix access to THREAD_RA/THREAD_SP/THREAD_DS (debug build breakage)
- fix TLBTEMP_BASE_2 region handling in fast_second_level_miss
(runtime unrecoverable exception)
- fix a6 and a7 handling in fast_syscall_xtensa (runtime userspace
register clobbering)
- fix kernel/user jump out of fast_unaligned (potential runtime
unrecoverabl exception)
- replace termios IOCTL code definitions with constants (userspace
build breakage)"
* tag 'xtensa-20140830' of git://github.com/czankel/xtensa-linux: (25 commits)
xtensa: deprecate fast_xtensa and fast_spill_registers syscalls
xtensa: don't allow overflow/underflow on unaligned stack
xtensa: fix a6 and a7 handling in fast_syscall_xtensa
xtensa: allow single-stepping through unaligned load/store
xtensa: move invalid unaligned instruction handler closer to its users
xtensa: make fast_unaligned store restartable
xtensa: add double exception fixup handler for fast_unaligned
xtensa: fix kernel/user jump out of fast_unaligned
xtensa: configure kc705 for highmem
xtensa: support highmem in aliasing cache flushing code
xtensa: support aliasing cache in kmap
xtensa: support aliasing cache in k[un]map_atomic
xtensa: implement clear_user_highpage and copy_user_highpage
xtensa: fix TLBTEMP_BASE_2 region handling in fast_second_level_miss
xtensa: allow fixmap and kmap span more than one page table
xtensa: make fixmap region addressing grow with index
xtensa: fix access to THREAD_RA/THREAD_SP/THREAD_DS
xtensa: add renameat2 syscall
xtensa: fix address checks in dma_{alloc,free}_coherent
xtensa: replace IOCTL code definitions with constants
unicore32 builds fail with
arch/unicore32/kernel/signal.c: In function ‘setup_frame’:
arch/unicore32/kernel/signal.c:257: error: ‘usig’ undeclared (first use in this function)
arch/unicore32/kernel/signal.c:279: error: ‘usig’ undeclared (first use in this function)
arch/unicore32/kernel/signal.c: In function ‘handle_signal’:
arch/unicore32/kernel/signal.c:306: warning: unused variable ‘tsk’
arch/unicore32/kernel/signal.c: In function ‘do_signal’:
arch/unicore32/kernel/signal.c:376: error: implicit declaration of function ‘get_signsl’
make[1]: *** [arch/unicore32/kernel/signal.o] Error 1
make: *** [arch/unicore32/kernel/signal.o] Error 2
Bisect points to commit 649671c90eaf ("unicore32: Use get_signal()
signal_setup_done()").
This code never even compiled. Reverting the patch does not work, since
previously used functions no longer exist, so try to fix it up. Compile
tested only.
Fixes: 649671c90eaf ("unicore32: Use get_signal() signal_setup_done()")
Cc: Richard Weinberger <richard@nod.at>
Pull ARM fixes from Russell King:
"Various assorted fixes:
- a couple of patches from Mark Rutland to resolve an errata with
Cortex-A15 CPUs.
- fix cpuidle for the CPU part ID changes in the last merge window
- add support for a relocation which ARM binutils is generating in
some circumstances"
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: 8130/1: cpuidle/cpuidle-big_little: fix reading cpu id part number
ARM: 8129/1: errata: work around Cortex-A15 erratum 830321 using dummy strex
ARM: 8128/1: abort: don't clear the exclusive monitors
ARM: 8127/1: module: add support for R_ARM_TARGET1 relocations
Pull ARM SoC fixes from Olof Johansson:
"Here's the weekly batch of fixes from arm-soc.
The delta is a largeish negative delta, due to revert of SMP support
for Broadcom's STB SoC -- it was accidentally merged before some
issues had been addressed, so they will make a new attempt for 3.18.
I didn't see a need for a full revert of the whole platform due to
this, we're keeping the rest enabled.
The rest is mostly:
- a handful of DT fixes for i.MX (Hummingboard/Cubox-i in particular)
- some MTD/NAND fixes for OMAP
- minor DT fixes for shmobile
- warning fix for UP builds on vexpress/spc
There's also a couple of patches that wires up hwmod on TI's DRA7 SoC
so it can boot. Drivers and the rest had landed for 3.17, and it's
small and isolated so it made sense to pick up now even if it's not a
bugfix"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
vexpress/spc: fix a build warning on array bounds
ARM: DRA7: hwmod: Add dra74x and dra72x specific ocp interface lists
ARM: DRA7: Add support for soc_is_dra74x() and soc_is_dra72x() variants
MAINTAINERS: catch special Rockchip code locations
ARM: dts: microsom-ar8035: MDIO pad must be set open drain
ARM: dts: omap54xx-clocks: Fix the l3 and l4 clock rates
ARM: brcmstb: revert SMP support
ARM: OMAP2+: hwmod: Rearm wake-up interrupts for DT when MUSB is idled
ARM: dts: Enable UART wake-up events for beagleboard
ARM: dts: Remove twl6030 clk32g "regulator"
ARM: OMAP2+: omap_device: remove warning that clk alias already exists
ARM: OMAP: fix %d confusingly prefixed with 0x in format string
ARM: dts: DRA7: fix interrupt-cells for GPIO
mtd: nand: omap: Fix 1-bit Hamming code scheme, omap_calculate_ecc()
ARM: dts: omap3430-sdp: Revert to using software ECC for NAND
ARM: OMAP2+: GPMC: Support Software ECC scheme via DT
mtd: nand: omap: Revert to using software ECC by default
ARM: dts: hummingboard/cubox-i: change SPDIF output to be more descriptive
ARM: dts: hummingboard/cubox-i: add USB OC pinctrl configuration
ARM: shmobile: r8a7791: add missing 0x0100 for SDCKCR
With ARCH_VEXPRESS_SPC option, kernel build has the following
warning:
arch/arm/mach-vexpress/spc.c: In function ‘ve_spc_clk_init’:
arch/arm/mach-vexpress/spc.c:431:38: warning: array subscript is below array bounds [-Warray-bounds]
struct ve_spc_opp *opps = info->opps[cluster];
since 'cluster' maybe '-1' in UP system. This patch does a active
checking to fix this issue.
Signed-off-by: Alex Shi <alex.shi@linaro.org>
Acked-by: Pawel Moll <pawel.moll@arm.com>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into fixes
Pull "ARM: OMAP2+: DRA72x/DRA74x basic support" from Tony Lindgren:
Add basic subarchitecture support for the DRA72x and DRA74x. These
are OMAP2+ derivative SoCs. This should be low-risk to existing OMAP
platforms.
Basic build, boot, and PM test logs are available here:
http://www.pwsan.com/omap/testlogs/hwmod-a-early-v3.17-rc/20140827194314/
* tag 'for-v3.17-rc/omap-dra72x-d74x-support-a' of git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending:
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi bugfixes from Mark Brown:
"A smattering of bug fixes for the SPI subsystem, all in driver code
which has seen active work recently and none of them with any great
global impact.
There's also a new ACPI ID for the pxa2xx driver which required no
code changes and the addition of kerneldoc for some structure fields
that were missing it and generating warnings during documentation
builds as a result"
* tag 'spi-v3.17-rc3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi: sh-msiof: Fix transmit-only DMA transfers
spi/rockchip: Avoid accidentally turning off the clock
spi: dw: fix kernel crash due to NULL pointer dereference
spi: dw-pci: fix bug when regs left uninitialized
spi: davinci: fix SPI_NO_CS functionality
spi/rockchip: fixup incorrect dma direction setting
spi/pxa2xx: Add ACPI ID for Intel Braswell
spi: spi-au1550: fix build failure
spi: rspi: Fix leaking of unused DMA descriptors
spi: sh-msiof: Fix leaking of unused DMA descriptors
spi: Add missing kerneldoc bits
spi/omap-mcspi: Fix the spi task hangs waiting dma_rx
spi: Bug fixes for v3.17
global impact.
There's also a new ACPI ID for the pxa2xx driver which required no code
changes and the addition of kerneldoc for some structure fields that
were missing it and generating warnings during documentation builds as a
result.
# gpg: Signature made Sun 31 Aug 2014 13:19:12 BST using RSA key ID 7EA229BD
# gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>"
# gpg: aka "Mark Brown <broonie@debian.org>"
# gpg: aka "Mark Brown <broonie@kernel.org>"
# gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>"
# gpg: aka "Mark Brown <broonie@linaro.org>"
# gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
Fix tx/rx mixup, which broke transmit-only transfers.
Introduced by commit 4240305f7cbdc7782aa8bc40cc702775d9ac0839
("spi: sh-msiof: Fix leaking of unused DMA descriptors").
Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Pull file locking bugfx from Jeff Layton:
"Just a bugfix for a bug that crept in to v3.15. It's in a rather rare
error path, and I'm not aware of anyone having hit it, but it's worth
fixing for v3.17"
* tag 'locks-v3.17-3' of git://git.samba.org/jlayton/linux:
locks: pass correct "before" pointer to locks_unlink_lock in generic_add_lease
'spi/fix/doc', 'spi/fix/dw', 'spi/fix/omap-mcspi', 'spi/fix/pxa2xx', 'spi/fix/rockchip' and 'spi/fix/rspi' into spi-linus
Pull x86 fixes from Peter Anvin:
"One patch to avoid assigning interrupts we don't actually have on
non-PC platforms, and two patches that addresses bugs in the new
IOAPIC assignment code"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, irq, PCI: Keep IRQ assignment for runtime power management
x86: irq: Fix bug in setting IOAPIC pin attributes
x86: Fix non-PC platform kernel crash on boot due to NULL dereference
Pull ACPI and power management fixes from Rafael Wysocki:
- Fix for an ACPI regression related to the handling of fixed events
that caused netlink routines to be (incorrectly) run in interrupt
context from Lan Tianyu
- Fix for an ACPI EC driver regression on Acer Aspire V5-573G that
caused AC/battery plug/unplug and video brightness change
notifications to be delayed on that machine from Lv Zheng
- Fix for an ACPI device enumeration regression that caused ACPI driver
probe to fail for some devices where it succeeded before (Rafael J
Wysocki)
- intel_pstate driver fix to prevent it from printing an information
message for every CPU in the system on every boot from Andi Kleen
- s5pv210 cpufreq driver fix to remove an __init annotation from a
routine that in fact can be called at any time after init too from
Mark Brown
- New Intel Braswell device ID for the ACPI LPSS (Low-Power Subsystem)
driver from Alan Cox
- New Intel Braswell CPU ID for intel_pstate from Mika Westerberg
* tag 'pm+acpi-3.17-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpufreq: s5pv210: Remove spurious __init annotation
cpufreq: intel_pstate: Add CPU ID for Braswell processor
intel_pstate: Turn per cpu printk into pr_debug
ACPI / LPSS: Add ACPI IDs for Intel Braswell
ACPI / EC: Add support to disallow QR_EC to be issued before completing previous QR_EC
ACPI / EC: Add support to disallow QR_EC to be issued when SCI_EVT isn't set
ACPI: Run fixed event device notifications in process context
ACPI / scan: Allow ACPI drivers to bind to PNP device objects
Merge patches from Andrew Morton:
"22 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (22 commits)
kexec: purgatory: add clean-up for purgatory directory
Documentation/kdump/kdump.txt: add ARM description
flush_icache_range: export symbol to fix build errors
tools: selftests: fix build issue with make kselftests target
ocfs2: quorum: add a log for node not fenced
ocfs2: o2net: set tcp user timeout to max value
ocfs2: o2net: don't shutdown connection when idle timeout
ocfs2: do not write error flag to user structure we cannot copy from/to
x86/purgatory: use approprate -m64/-32 build flag for arch/x86/purgatory
drivers/rtc/rtc-s5m.c: re-add support for devices without irq specified
xattr: fix check for simultaneous glibc header inclusion
kexec: remove CONFIG_KEXEC dependency on crypto
kexec: create a new config option CONFIG_KEXEC_FILE for new syscall
x86,mm: fix pte_special versus pte_numa
hugetlb_cgroup: use lockdep_assert_held rather than spin_is_locked
mm/zpool: use prefixed module loading
zram: fix incorrect stat with failed_reads
lib: turn CONFIG_STACKTRACE into an actual option.
mm: actually clear pmd_numa before invalidating
memblock, memhotplug: fix wrong type in memblock_find_in_range_node().
Without this patch the kexec-purgatory.c and purgatory.ro files are not
removed after make mrproper.
Signed-off-by: Michael Welling <mwelling@ieee.org>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Add arm specific parts to kdump kernel documentation.
Signed-off-by: Hu Keping <hukeping@huawei.com>
Cc: Haren Myneni <hbabu@us.ibm.com>
Cc: Rob Landley <rob@landley.net>
Fix building errors occuring due to a missing export of
flush_icache_range() in
kisskb.ellerman.id.au/kisskb/buildresult/11677809/
ERROR: "flush_icache_range" [drivers/misc/lkdtm.ko] undefined!
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Chris Zankel <chris@zankel.net>
Acked-by: Max Filippov <jcmvbkbc@gmail.com> [xtensa]
Cc: Noam Camus <noamc@ezchip.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Acked-by: Zhigang Lu <zlu@tilera.com> [tile]
Cc: Kirill Tkhai <tkhai@yandex.ru>
Fix the typo of ARCH when running 'make kselftests'. Change the 'X86'
to 'x86'. Test by compilation.
Signed-off-by: Phong Tran <tranmanphong@gmail.com>
Cc: David Herrmann <dh.herrmann@gmail.com>
Cc: Shuah Khan <shuah.kh@samsung.com>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
For debug use, we can see from the log whether the fence decision is
made and why it is not fenced.
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Srinivas Eeda <srinivas.eeda@oracle.com>
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
Cc: Joseph Qi <joseph.qi@huawei.com>
When tcp retransmit timeout(15mins), the connection will be closed.
Pending messages may be lost during this time. So we set tcp user
timeout to override the retransmit timeout to the max value. This is OK
for ocfs2 since we have disk heartbeat, if peer crash, the disk
heartbeat will timeout and it will be evicted, if disk heartbeat not
timeout and connection idle for a long time, then this means the cluster
enters split-brain state, since fence can't happen, we'd better keep the
connection and wait network recover.
This patch series is to fix a possible message lost bug in ocfs2 when
network go bad. This bug will cause ocfs2 hung forever even network
become good again.
The messages may lost in this case. After the tcp connection is
established between two nodes, an idle timer will be set to check its
state periodically, if no messages are received during this time, idle
timer will timeout, it will shutdown the connection and try to
reconnect, so pending messages in tcp queues will be lost. This
messages may be from dlm. Dlm may get hung in this case. This may
cause the whole ocfs2 cluster hung.
This is very possible to happen when network state goes bad. Do the
reconnect is useless, it will fail if network state is still bad. Just
waiting there for network recovering may be a good idea, it will not
lost messages and some node will be fenced until cluster goes into
split-brain state, for this case, Tcp user timeout is used to override
the tcp retransmit timeout. It will timeout after 25 days, user should
have notice this through the provided log and fix the network, if they
don't, ocfs2 will fall back to original reconnect way.
This patch (of 3):
Some messages in the tcp queue maybe lost if we shutdown the connection
and reconnect when idle timeout. If packets lost and reconnect success,
then the ocfs2 cluster maybe hung.
To fix this, we can leave the connection there and do the fence decision
when idle timeout, if network recover before fence dicision is made, the
connection survive without lost any messages.
This bug can be saw when network state go bad. It may cause ocfs2 hung
forever if some packets lost. With this fix, ocfs2 will recover from
hung if network becomes good again.
If we failed to copy from the structure, writing back the flags leaks 31
bits of kernel memory (the rest of the ir_flags field).
In any case, if we cannot copy from/to the structure, why should we
expect putting just the flags to work?
Also make sure ocfs2_info_handle_freeinode() returns the right error
code if the copy_to_user() fails.
Fixes: ddee5cdb70e6 ('Ocfs2: Add new OCFS2_IOC_INFO ioctl for ocfs2 v8.')
Acked-by: Mark Fasheh <mfasheh@suse.com>
Thomas reported that build of x86_64 kernel was failing for him. He is
using 32bit tool chain.
Problem is that while compiling purgatory, I have not specified -m64
flag. And 32bit tool chain must be assuming -m32 by default.
Following is error message.
(mini) [~/work/linux-2.6] make
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config/kernel.release
UPD include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
UPD include/generated/utsrelease.h
CC arch/x86/purgatory/purgatory.o
arch/x86/purgatory/purgatory.c:1:0: error: code model 'large' not supported in
the 32 bit mode
Fix it by explicitly passing appropriate -m64/-m32 build flag for
purgatory.
Reported-by: Thomas Glanzmann <thomas@glanzmann.de>
Tested-by: Thomas Glanzmann <thomas@glanzmann.de>
Suggested-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
The rtc-s5m driver used to support devices without irq specified in the
past. Re-add this support.
The patch fixes boot for Insignal's Exynos4412 based Origen board.
Error messages before the patch:
Unable to handle kernel NULL pointer dereference at virtual address 00000094
pgd = c0004000
[00000094] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.16.0-next-20140804-00008-ga59480f-dirty #701
task: ea80f000 ti: ea882000 task.ti: ea882000
PC is at regmap_irq_get_virq+0x0/0x28
LR is at s5m_rtc_probe+0xdc/0x310
pc : [<c02574fc>] lr : [<c02de75c>] psr: 80000153
sp : ea883e48 ip : 00000000 fp : 00000000
r10: 0000000c r9 : c05de7ac r8 : eaabc600
r7 : eaa6b4d0 r6 : c0439e8c r5 : eaabc610 r4 : eab30e50
r3 : 00000000 r2 : 00000000 r1 : 0000000c r0 : 00000000
Flags: Nzcv IRQs on FIQs off Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 4000404a DAC: 00000015
Process swapper/0 (pid: 1, stack limit = 0xea882240)
Backtrace:
regmap_irq_get_virq
s5m_rtc_probe
platform_drv_probe
driver_probe_device
__driver_attach
bus_for_each_dev
bus_add_driver
driver_register
do_one_initcall
kernel_init_freeable
kernel_init
---[ end trace a954d7f019122700 ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
The guard was introduced in commit ea1a8217b06b ("xattr: guard against
simultaneous glibc header inclusion") but it is using #ifdef to check
for a define that is either set to 1 or 0. Fix it to use #if instead.
* Without this patch:
$ { echo "#include <sys/xattr.h>"; echo "#include <linux/xattr.h>"; } | gcc -E -Iinclude/uapi - >/dev/null
include/uapi/linux/xattr.h:19:0: warning: "XATTR_CREATE" redefined [enabled by default]
#define XATTR_CREATE 0x1 /* set value, fail if attr already exists */
/usr/include/x86_64-linux-gnu/sys/xattr.h:32:0: note: this is the location of the previous definition
#define XATTR_CREATE XATTR_CREATE
* With this patch:
(no warnings)
Signed-off-by: Filipe Brandenburger <filbranden@google.com>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Cc: Allan McRae <allan@archlinux.org>
Cc: <stable@vger.kernel.org>
