[ Upstream commit 6bb0d64c100091e131cd16710b62fda3319cd0af ]
The platform_get_irq() returns negative error codes. It can't actually
return zero.
Signed-off-by: Yu Zhe <yuzhe@nfschina.com>
Link: https://lore.kernel.org/r/20220825011844.8536-1-yuzhe@nfschina.com
Signed-off-by: Will Deacon <will@kernel.org>
[ Upstream commit 52267ce25f60f37ae40ccbca0b21328ebae5ae75 ]
In case the source port cannot be decoded, print the warning only once. This
still brings attention to the user and does not spam the logs at the same time.
Signed-off-by: Kurt Kanzenbach <kurt@linutronix.de>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Vladimir Oltean <olteanv@gmail.com>
Link: https://lore.kernel.org/r/20220830163448.8921-1-kurt@linutronix.de
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit 39c84b8e929dbd4f63be7e04bf1a2bcd92b44177 ]
Restrict the ucode loading check to avoid frontdoor loading error.
Signed-off-by: Chengming Gui <Jack.Gui@amd.com>
Reviewed-by: Hawking Zhang <Hawking.Zhang@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 478814a5584197fa1fb18377653626e3416e7cd6 ]
TCP_FIN_WAIT2 and TCP_LAST_ACK were not handled, the connection is closing
so we can ignore them and avoid printing the "unhandled state"
warning message.
[ 1298.852386] nvmet_tcp: queue 2 unhandled state 5
[ 1298.879112] nvmet_tcp: queue 7 unhandled state 5
[ 1298.884253] nvmet_tcp: queue 8 unhandled state 5
[ 1298.889475] nvmet_tcp: queue 9 unhandled state 5
v2: Do not call nvmet_tcp_schedule_release_queue(), just ignore
the fin_wait2 and last_ack states.
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Reviewed-by: Chaitanya Kulkarni <kch@nvidia.com>
[ Upstream commit 9c9c71168f7979f3798b61c65b4530fbfbcf19d1 ]
Add a new iforce_device entry to support the Boeder Force Feedback Wheel
device.
Signed-off-by: Greg Tulli <greg.iforce@gmail.com>
Link: https://lore.kernel.org/r/3256420-c8ac-31b-8499-3c488a9880fd@gmail.com
[ Upstream commit ffd7bdddaab193c38416fd5dd416d065517d266e ]
The rc code is 0 at the error path "status & CC2520_STATUS_TX_UNDERFLOW".
Assign rc code with '-EINVAL' at this error path to fix it.
Signed-off-by: Li Qiong <liqiong@nfschina.com>
Link: https://lore.kernel.org/r/20220829071259.18330-1-liqiong@nfschina.com
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
[ Upstream commit 303e6da99429510b1e4edf833afe90ac8542e747 ]
GPIO mockup debugfs is created in gpio_mockup_probe() but
forgot to remove when remove device. This patch add a devm
managed callback for removing them.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl>
[ Upstream commit 2ca1c94ce0b65a2ce7512b718f3d8a0fe6224bca ]
Commit d60cd06331a3 ("PM: ACPI: reboot: Use S5 for reboot") caused a
reboot hang on one Dell servers so the commit was reverted.
Someone managed to collect the AER log and it's caused by MSI:
[ 148.762067] ACPI: Preparing to enter system sleep state S5
[ 148.794638] {1}[Hardware Error]: Hardware error from APEI Generic Hardware Error Source: 5
[ 148.803731] {1}[Hardware Error]: event severity: recoverable
[ 148.810191] {1}[Hardware Error]: Error 0, type: fatal
[ 148.816088] {1}[Hardware Error]: section_type: PCIe error
[ 148.822391] {1}[Hardware Error]: port_type: 0, PCIe end point
[ 148.829026] {1}[Hardware Error]: version: 3.0
[ 148.834266] {1}[Hardware Error]: command: 0x0006, status: 0x0010
[ 148.841140] {1}[Hardware Error]: device_id: 0000:04:00.0
[ 148.847309] {1}[Hardware Error]: slot: 0
[ 148.852077] {1}[Hardware Error]: secondary_bus: 0x00
[ 148.857876] {1}[Hardware Error]: vendor_id: 0x14e4, device_id: 0x165f
[ 148.865145] {1}[Hardware Error]: class_code: 020000
[ 148.870845] {1}[Hardware Error]: aer_uncor_status: 0x00100000, aer_uncor_mask: 0x00010000
[ 148.879842] {1}[Hardware Error]: aer_uncor_severity: 0x000ef030
[ 148.886575] {1}[Hardware Error]: TLP Header: 40000001 0000030f 90028090 00000000
[ 148.894823] tg3 0000:04:00.0: AER: aer_status: 0x00100000, aer_mask: 0x00010000
[ 148.902795] tg3 0000:04:00.0: AER: [20] UnsupReq (First)
[ 148.910234] tg3 0000:04:00.0: AER: aer_layer=Transaction Layer, aer_agent=Requester ID
[ 148.918806] tg3 0000:04:00.0: AER: aer_uncor_severity: 0x000ef030
[ 148.925558] tg3 0000:04:00.0: AER: TLP Header: 40000001 0000030f 90028090 00000000
The MSI is probably raised by incoming packets, so power down the device
and disable bus mastering to stop the traffic, as user confirmed this
approach works.
In addition to that, be extra safe and cancel reset task if it's running.
Cc: Josef Bacik <josef@toxicpanda.com>
Link: https://lore.kernel.org/all/b8db79e6857c41dab4ef08bdf826ea7c47e3bafc.1615947283.git.josef@toxicpanda.com/
BugLink: https://bugs.launchpad.net/bugs/1917471
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Reviewed-by: Michael Chan <michael.chan@broadcom.com>
Link: https://lore.kernel.org/r/20220826002530.1153296-1-kai.heng.feng@canonical.com
[ Upstream commit e1fa076706209cc447d7a2abd0843a18277e5ef7 ]
There is a timing issue captured during ishtp client sending stress tests.
It was observed during stress tests that ISH firmware is getting out of
ordered messages. This is a rare scenario as the current set of ISH client
drivers don't send much data to firmware. But this may not be the case
going forward.
When message size is bigger than IPC MTU, ishtp splits the message into
fragments and uses serialized async method to send message fragments.
The call stack:
ishtp_cl_send_msg_ipc->ipc_tx_callback(first fregment)->
ishtp_send_msg(with callback)->write_ipc_to_queue->
write_ipc_from_queue->callback->ipc_tx_callback(next fregment)......
When an ipc write complete interrupt is received, driver also calls
write_ipc_from_queue->ipc_tx_callback in ISR to start sending of next fragment.
Through ipc_tx_callback uses spin_lock to protect message splitting, as the
serialized sending method will call back to ipc_tx_callback again, so it doesn't
put sending under spin_lock, it causes driver cannot guarantee all fragments
be sent in order.
Considering this scenario:
ipc_tx_callback just finished a fragment splitting, and not call ishtp_send_msg
yet, there is a write complete interrupt happens, then ISR->write_ipc_from_queue
->ipc_tx_callback->ishtp_send_msg->write_ipc_to_queue......
Because ISR has higher exec priority than normal thread, this causes the new
fragment be sent out before previous fragment. This disordered message causes
invalid message to firmware.
The solution is, to send fragments synchronously:
Use ishtp_write_message writing fragments into tx queue directly one by one,
instead of ishtp_send_msg only writing one fragment with completion callback.
As no completion callback be used, so change ipc_tx_callback to ipc_tx_send.
Signed-off-by: Even Xu <even.xu@intel.com>
Acked-by: Srinivas Pandruvada <srinivas.pandruvada@intel.com>
[ Upstream commit 94553f8a218540d676efbf3f7827ed493d1057cf ]
The double `like' is duplicated in the comment, remove one.
Signed-off-by: Jason Wang <wangborong@cdjrlc.com>
[ Upstream commit 767470209cedbe2cc72ba38d77c9f096d2c7694c ]
BMG160 has two interrupt pins to which interrupts can be freely mapped.
Correct the schema to express such case and fix warnings like:
qcom/msm8916-alcatel-idol347.dtb: gyroscope@68: interrupts: [[97, 1], [98, 1]] is too long
However the basic issue still persists - the interrupts should come in a
defined order.
Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@linaro.org>
Link: https://lore.kernel.org/r/20220805075503.16983-1-krzysztof.kozlowski@linaro.org
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
[ Upstream commit 174974d8463b77c2b4065e98513adb204e64de7d ]
If the previous thing cat'ing $debugfs/rd left the FIFO full, then
subsequent open could deadlock in rd_write() (because open is blocked,
not giving a chance for read() to consume any data in the FIFO). Also
it is generally a good idea to clear out old data from the FIFO.
Signed-off-by: Rob Clark <robdclark@chromium.org>
Patchwork: https://patchwork.freedesktop.org/patch/496706/
Link: https://lore.kernel.org/r/20220807160901.2353471-2-robdclark@gmail.com
[ Upstream commit 84b8e403435c8fb94b872309673764a447961e00 ]
The Surface Laptop Go 2 seems to have the same SAM client devices as the
Surface Laptop Go 1, so re-use its node group.
Signed-off-by: Maximilian Luz <luzmaximilian@gmail.com>
Link: https://lore.kernel.org/r/20220810140133.99087-1-luzmaximilian@gmail.com
[ Upstream commit 425fe4709c76e35f93f4c0e50240f0b61b2a2e54 ]
This controller is used by PinePhone and PinePhone Pro. Support for
the PinePhone Pro will be added in a later patch set.
Signed-off-by: Ondrej Jirman <megi@xff.cz>
Signed-off-by: Jarrah Gosbell <kernel@undef.tools>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Link: https://lore.kernel.org/r/20220809091200.290492-1-kernel@undef.tools
[ Upstream commit 0c5f6c0d8201a809a6585b07b6263e9db2c874a3 ]
The translation table copying code for kdump kernels is currently based
on the extended root/context entry formats of ECS mode defined in older
VT-d v2.5, and doesn't handle the scalable mode formats. This causes
the kexec capture kernel boot failure with DMAR faults if the IOMMU was
enabled in scalable mode by the previous kernel.
The ECS mode has already been deprecated by the VT-d spec since v3.0 and
Intel IOMMU driver doesn't support this mode as there's no real hardware
implementation. Hence this converts ECS checking in copying table code
into scalable mode.
The existing copying code consumes a bit in the context entry as a mark
of copied entry. It needs to work for the old format as well as for the
extended context entries. As it's hard to find such a common bit for both
legacy and scalable mode context entries. This replaces it with a per-
IOMMU bitmap.
Fixes: 7373a8cc38197 ("iommu/vt-d: Setup context and enable RID2PASID support")
Cc: stable@vger.kernel.org
Reported-by: Jerry Snitselaar <jsnitsel@redhat.com>
Tested-by: Wen Jin <wen.jin@intel.com>
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Link: https://lore.kernel.org/r/20220817011035.3250131-1-baolu.lu@linux.intel.com
Signed-off-by: Joerg Roedel <jroedel@suse.de>
[ Upstream commit 47311db8e8f33011d90dee76b39c8886120cdda4 ]
Users may have explicitly configured their tracefs permissions; we
shouldn't overwrite those just because a second mount appeared.
Only clobber if the options were provided at mount time.
Note: the previous behavior was especially surprising in the presence of
automounted /sys/kernel/debug/tracing/.
Existing behavior:
## Pre-existing status: tracefs is 0755.
# stat -c '%A' /sys/kernel/tracing/
drwxr-xr-x
## (Re)trigger the automount.
# umount /sys/kernel/debug/tracing
# stat -c '%A' /sys/kernel/debug/tracing/.
drwx------
## Unexpected: the automount changed mode for other mount instances.
drwx------
New behavior (after this change):
drwxr-xr-x
drwxr-xr-x
## Expected: the automount does not change other mount instances.
drwxr-xr-x
Link: https://lkml.kernel.org/r/20220826174353.2.Iab6e5ea57963d6deca5311b27fb7226790d44406@changeid
Fixes: 4282d60689d4f ("tracefs: Add new tracefs file system")
Signed-off-by: Brian Norris <briannorris@chromium.org>
Signed-off-by: Steven Rostedt (Google) <rostedt@goodmis.org>
[ Upstream commit 54c3931957f6a6194d5972eccc36d052964b2abe ]
Currently, The arguments passing to lockdep_hardirqs_{on,off} was fixed
in CALLER_ADDR0.
The function trace_hardirqs_on_caller should have been intended to use
caller_addr to represent the address that caller wants to be traced.
For example, lockdep log in riscv showing the last {enabled,disabled} at
__trace_hardirqs_{on,off} all the time(if called by):
[ 57.853175] hardirqs last enabled at (2519): __trace_hardirqs_on+0xc/0x14
[ 57.853848] hardirqs last disabled at (2520): __trace_hardirqs_off+0xc/0x14
After use trace_hardirqs_xx_caller, we can get more effective information:
[ 53.781428] hardirqs last enabled at (2595): restore_all+0xe/0x66
[ 53.782185] hardirqs last disabled at (2596): ret_from_exception+0xa/0x10
Link: https://lkml.kernel.org/r/20220901104515.135162-2-zouyipeng@huawei.com
Fixes: c3bc8fd637a96 ("tracing: Centralize preemptirq tracepoints and unify their usage")
Signed-off-by: Yipeng Zou <zouyipeng@huawei.com>
[ Upstream commit e87f4152e542610d0b4c6c8548964a68a59d2040 ]
Force-inline two stack helpers to fix the following objtool warnings:
vmlinux.o: warning: objtool: in_task_stack()+0xc: call to task_stack_page() leaves .noinstr.text section
vmlinux.o: warning: objtool: in_entry_stack()+0x10: call to cpu_entry_stack() leaves .noinstr.text section
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: https://lore.kernel.org/r/20220324183607.31717-2-bp@alien8.de
Stable-dep-of: 54c3931957f6 ("tracing: hold caller_addr to hardirq_{enable,disable}_ip")
[ Upstream commit ace1a98519270c586c0d4179419292df67441cd1 ]
Fix:
vmlinux.o: warning: objtool: __sev_es_nmi_complete()+0x8b: call to __phys_addr_nodebug() leaves .noinstr.text section
Link: https://lore.kernel.org/r/20220324183607.31717-4-bp@alien8.de
[ Upstream commit 8b023accc8df70e72f7704d29fead7ca914d6837 ]
While looking into a bug related to the compiler's handling of addresses
of labels, I noticed some uses of _THIS_IP_ seemed unused in lockdep.
Drive by cleanup.
-Wunused-parameter:
kernel/locking/lockdep.c:1383:22: warning: unused parameter 'ip'
kernel/locking/lockdep.c:4246:48: warning: unused parameter 'ip'
kernel/locking/lockdep.c:4844:19: warning: unused parameter 'ip'
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Acked-by: Waiman Long <longman@redhat.com>
Link: https://lore.kernel.org/r/20220314221909.2027027-1-ndesaulniers@google.com
[ Upstream commit 7f41d52ced9e1b7ed4ff8e1ae9cacbf46b64e6db ]
Min and max output ranges of regulators need to satisfy board
requirements not PMIC requirements. Thus adjust device tree to
cope with this.
Fixes: 7540629e2fc7 ("ARM: dts: at91: add sama7g5 SoC DT and sama7g5-ek")
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Link: https://lore.kernel.org/r/20220826083927.3107272-7-claudiu.beznea@microchip.com
[ Upstream commit 279d626d737486363233b9b99c30b5696c389b41 ]
Fix low limit for CPU regulator. Otherwise setting voltages lower than
1.125V will not be allowed (CPUFreq will not be allowed to set proper
voltages on proper frequencies).
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Link: https://lore.kernel.org/r/20220113144900.906370-7-claudiu.beznea@microchip.com
Stable-dep-of: 7f41d52ced9e ("ARM: dts: at91: sama7g5ek: specify proper regulator output ranges")
[ Upstream commit af7d78c957017f8b3a0986769f6f18e57f9362ea ]
Drop the "winbond,w25q16dw" compatible since it causes to set the
MODALIAS to w25q16dw which is not specified within spi-nor id table.
Fix this by use the common "jedec,spi-nor" compatible.
Fixes: 2125212785c9 ("ARM: dts: imx6qdl-kontron-samx6i: add Kontron SMARC SoM Support")
Signed-off-by: Marco Felsch <m.felsch@pengutronix.de>
[ Upstream commit ba9fe460dc2cfe90dc115b22af14dd3f13cffa0f ]
The node names should be generic and SPI NOR dtschema expects "flash".
Stable-dep-of: af7d78c95701 ("ARM: dts: imx6qdl-kontron-samx6i: fix spi-flash compatible")
commit 9946e39fe8d0a5da9eb947d8e40a7ef204ba016e upstream.
IRQ override isn't needed on modern AMD Zen systems.
There's an active low keyboard IRQ on AMD Ryzen 6000 and it will stay
this way on newer platforms. This IRQ override breaks keyboards for
almost all Ryzen 6000 laptops currently on the market.
Skip this IRQ override for all AMD Zen platforms because this IRQ
override is supposed to be a workaround for buggy ACPI DSDT and we can't
have a long list of all future AMD CPUs/Laptops in the kernel code.
If a device with buggy ACPI DSDT shows up, a separated list containing
just them should be created.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=216118
Suggested-by: Mario Limonciello <mario.limonciello@amd.com>
Signed-off-by: Chuanhong Guo <gch981213@gmail.com>
Acked-by: Mario Limonciello <mario.limonciello@amd.com>
Tested-by: XiaoYan Li <lxy.lixiaoyan@gmail.com>
commit 0ebeebcf59601bcfa0284f4bb7abdec051eb856d upstream.
Fixes the following WARN_ON
WARNING: CPU: 2 PID: 18678 at fs/nfs/inode.c:123 nfs_clear_inode+0x3b/0x50 [nfs]
Call Trace:
nfs4_evict_inode+0x57/0x70 [nfsv4]
evict+0xd1/0x180
dispose_list+0x48/0x60
evict_inodes+0x156/0x190
generic_shutdown_super+0x37/0x110
nfs_kill_super+0x1d/0x40 [nfs]
deactivate_locked_super+0x36/0xa0
Signed-off-by: Dave Wysochanski <dwysocha@redhat.com>
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
Link: https://lore.kernel.org/r/20220913140357.323297659@linuxfoundation.org
Tested-by: Bagas Sanjaya <bagasdotme@gmail.com>=20
Tested-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
Tested-by: Linux Kernel Functional Testing <lkft@linaro.org>
Tested-by: Ron Economos <re@w6rz.net>
Tested-by: Jon Hunter <jonathanh@nvidia.com>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit dc3005703f8cd893d325081c20b400e08377d9bb ]
Remove CONFIG_SOC_SAMA7 dependency to avoid having #ifdef preprocessor
directives in driver code (arch/arm/mach-at91/pm.c). This prepares the
code for next commits.
Link: https://lore.kernel.org/r/20220113144900.906370-2-claudiu.beznea@microchip.com
'/', filename)
commit 9d5f0c36438eeae7566ca383b2b673179e3cc613 upstream.
Its more intention revealing, and if we're interested in the odd cases
where this may end up truncating we can do debug checks at one
centralized place.
Motivation, of all the container builds, fedora rawhide started
complaining of:
util/machine.c: In function ‘machine__create_modules’:
util/machine.c:1419:50: error: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size between 0 and 4095 [-Werror=format-truncation=]
1419 | snprintf(path, sizeof(path), "%s/%s", dir_name, dent->d_name);
In file included from /usr/include/stdio.h:894,
from util/branch.h:9,
from util/callchain.h:8,
from util/machine.c:7:
In function ‘snprintf’,
inlined from ‘maps__set_modules_path_dir’ at util/machine.c:1419:3,
inlined from ‘machine__set_modules_path’ at util/machine.c:1473:9,
inlined from ‘machine__create_modules’ at util/machine.c:1519:7:
/usr/include/bits/stdio2.h:71:10: note: ‘__builtin___snprintf_chk’ output between 2 and 4352 bytes into a destination of size 4096
There are other places where we should use path__join(), but lets get rid of
this one first.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Ian Rogers <irogers@google.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Acked-by: Ian Rogers <irogers@google.com>
Link: Link: https://lore.kernel.org/r/YebZKjwgfdOz0lAs@kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Jisheng Zhang <jszhang@kernel.org>
commit 7cd70656d1285b79c001f041a017fcfee4292ff9 upstream.
Since this bridge is tied to the connector, it acts like a passthrough,
so concerning the output & input bus formats, either pass the bus formats from the
previous bridge or return fallback data like done in the bridge function:
drm_atomic_bridge_chain_select_bus_fmts() & select_bus_fmt_recursive.
This permits avoiding skipping the negociation if the remaining bridge chain has
all the bits in place.
Without this bus fmt negociation breaks on drm/meson HDMI pipeline when attaching
dw-hdmi with DRM_BRIDGE_ATTACH_NO_CONNECTOR, because the last bridge of the
display-connector doesn't implement buf fmt callbacks and MEDIA_BUS_FMT_FIXED
is used leading to select an unsupported default bus format from dw-hdmi.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20211020123947.2585572-2-narmstrong@baylibre.com
Cc: Stefan Agner <stefan@agner.ch>
commit e89d120c4b720e232cc6a94f0fcbd59c15d41489 upstream.
The AMU counter AMEVCNTR01 (constant counter) should increment at the same
rate as the system counter. On affected Cortex-A510 cores, AMEVCNTR01
increments incorrectly giving a significantly higher output value. This
results in inaccurate task scheduler utilization tracking and incorrect
feedback on CPU frequency.
Work around this problem by returning 0 when reading the affected counter
in key locations that results in disabling all users of this counter from
using it either for frequency invariance or as FFH reference counter. This
effect is the same to firmware disabling affected counters.
Details on how the two features are affected by this erratum:
- AMU counters will not be used for frequency invariance for affected
CPUs and CPUs in the same cpufreq policy. AMUs can still be used for
frequency invariance for unaffected CPUs in the system. Although
unlikely, if no alternative method can be found to support frequency
invariance for affected CPUs (cpufreq based or solution based on
platform counters) frequency invariance will be disabled. Please check
the chapter on frequency invariance at
Documentation/scheduler/sched-capacity.rst for details of its effect.
- Given that FFH can be used to fetch either the core or constant counter
values, restrictions are lifted regarding any of these counters
returning a valid (!0) value. Therefore FFH is considered supported
if there is a least one CPU that support AMUs, independent of any
counters being disabled or affected by this erratum. Clarifying
comments are now added to the cpc_ffh_supported(), cpu_read_constcnt()
and cpu_read_corecnt() functions.
The above is achieved through adding a new erratum: ARM64_ERRATUM_2457168.
Signed-off-by: Ionela Voinescu <ionela.voinescu@arm.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Will Deacon <will@kernel.org>
Cc: James Morse <james.morse@arm.com>
Link: https://lore.kernel.org/r/20220819103050.24211-1-ionela.voinescu@arm.com
commit 53fc7ad6edf210b497230ce74b61b322a202470c upstream.
The Intel IOMMU driver possibly selects between the first-level and the
second-level translation tables for DMA address translation. However,
the levels of page-table walks for the 4KB base page size are calculated
from the SAGAW field of the capability register, which is only valid for
the second-level page table. This causes the IOMMU driver to stop working
if the hardware (or the emulated IOMMU) advertises only first-level
translation capability and reports the SAGAW field as 0.
This solves the above problem by considering both the first level and the
second level when calculating the supported page table levels.
Fixes: b802d070a52a1 ("iommu/vt-d: Use iova over first level")
Link: https://lore.kernel.org/r/20220817023558.3253263-1-baolu.lu@linux.intel.com
commit c0a454b9044fdc99486853aa424e5b3be2107078 upstream.
GCC does not insert a `bti c` instruction at the beginning of a function
when it believes that all callers reach the function through a direct
branch[1]. Unfortunately the logic it uses to determine this is not
sufficiently robust, for example not taking account of functions being
placed in different sections which may be loaded separately, so we may
still see thunks being generated to these functions. If that happens,
the first instruction in the callee function will result in a Branch
Target Exception due to the missing landing pad.
While this has currently only been observed in the case of modules
having their main code loaded sufficiently far from their init section
to require thunks it could potentially happen for other cases so the
safest thing is to disable BTI for the kernel when building with an
affected toolchain.
[1]: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=106671
Reported-by: D Scott Phillips <scott@os.amperecomputing.com>
[Bits of the commit message are lifted from his report & workaround]
Signed-off-by: Mark Brown <broonie@kernel.org>
Link: https://lore.kernel.org/r/20220905142255.591990-1-broonie@kernel.org
Cc: <stable@vger.kernel.org> # v5.10+
This reverts commit add4bc9281e8704e5ab15616b429576c84f453a2.
On Mon, Sep 12, 2022 at 10:52:45AM +0100, Catalin Marinas wrote:
>I missed this (holidays) and it looks like it's in stable already. On
>its own it will likely break kasan_hw if used together with user-space
>MTE as this change relies on two previous commits:
>70c248aca9e7 ("mm: kasan: Skip unpoisoning of user pages")
>6d05141a3930 ("mm: kasan: Skip page unpoisoning only if __GFP_SKIP_KASAN_UNPOISON")
>The reason I did not cc stable is that there are other dependencies in
>this area. The potential issues without the above commits were rather
>theoretical, so take these patches rather as clean-ups/refactoring than
>fixes.
[ Upstream commit e43212e0f55dc2d6b15d6c174cc0a64b25fab5e7 ]
Configure ip-polling register to enable polling for all voltage monitor
channels.
This enables reading the voltage values for all inputs other than just
input 0.
Fixes: 9d823351a337 ("hwmon: Add hardware monitoring driver for Moortec MR75203 PVT controller")
Signed-off-by: Eliav Farber <farbere@amazon.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Link: https://lore.kernel.org/r/20220908152449.35457-7-farbere@amazon.com
[ Upstream commit 91a9e063cdcfca8fe642b078d6fae4ce49187975 ]
Fix voltage allocation and reading to support all channels in all VMs.
Prior to this change allocation and reading were done only for the first
channel in each VM.
This change counts the total number of channels for allocation, and takes
into account the channel offset when reading the sample data register.
Link: https://lore.kernel.org/r/20220908152449.35457-6-farbere@amazon.com
[ Upstream commit 227a3a2fc31d8e4bb9c88d4804e19530af245b1b ]
According to Moortec Embedded Voltage Monitor (MEVM) series 3 data
sheet, the minimum input signal is -100mv and maximum input signal
is +1000mv.
The equation used to convert the digital word to voltage uses mixed
types (*val signed and n unsigned), and on 64 bit machines also has
different size, since sizeof(u32) = 4 and sizeof(long) = 8.
So when measuring a negative input, n will be small enough, such that
PVT_N_CONST * n < PVT_R_CONST, and the result of
(PVT_N_CONST * n - PVT_R_CONST) will overflow to a very big positive
32 bit number. Then when storing the result in *val it will be the same
value just in 64 bit (instead of it representing a negative number which
will what happen when sizeof(long) = 4).
When -1023 <= (PVT_N_CONST * n - PVT_R_CONST) <= -1
dividing the number by 1024 should result of in 0, but because ">> 10"
is used, and the sign bit is used to fill the vacated bit positions, it
results in -1 (0xf...fffff) which is wrong.
This change fixes the sign problem and supports negative values by
casting n to long and replacing the shift right with div operation.
Link: https://lore.kernel.org/r/20220908152449.35457-5-farbere@amazon.com
sensors
[ Upstream commit bb9195bd6664d94d71647631593e09f705ff5edd ]
This issue is relevant when "intel,vm-map" is set in device-tree, and
defines a lower number of VMs than actually supported.
This change is needed for all places that use pvt->v_num or vm_num
later on in the code.
Link: https://lore.kernel.org/r/20220908152449.35457-4-farbere@amazon.com
[ Upstream commit 81114fc3d27bf5b06b2137d2fd2b63da656a8b90 ]
Bug - in case "intel,vm-map" is missing in device-tree ,'num' is set
to 0, and no voltage channel infos are allocated.
The reason num is set to 0 when "intel,vm-map" is missing is to set the
entire pvt->vm_idx[] with incremental channel numbers, but it didn't
take into consideration that same num is used later in devm_kcalloc().
If "intel,vm-map" does exist there is no need to set the unspecified
channels with incremental numbers, because the unspecified channels
can't be accessed in pvt_read_in() which is the only other place besides
the probe functions that uses pvt->vm_idx[].
This change fixes the bug by moving the incremental channel numbers
setting to be done only if "intel,vm-map" property is defined (starting
loop from 0), and removing 'num = 0'.
Link: https://lore.kernel.org/r/20220908152449.35457-3-farbere@amazon.com
[ Upstream commit 12dd19c159659ec9050f45dc8a2ff3c3917f4be3 ]
Crash dump always starts on CPU0. In case CPU0 is offline the
prefix page is not installed and the absolute zero lowcore is
used. However, struct lowcore::mcesad is never assigned and
stays zero. That leads to __machine_kdump() -> save_vx_regs()
call silently stores vector registers to the absolute lowcore
at 0x11b0 offset.
Fixes: a62bc0739253 ("s390/kdump: add support for vector extension")
Reviewed-by: Heiko Carstens <hca@linux.ibm.com>
Signed-off-by: Alexander Gordeev <agordeev@linux.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
[ Upstream commit 94a568ce32038d8ff9257004bb4632e60eb43a49 ]
We started using a 64 bit completion value. Unfortunately, we only
stored the low 32-bits, so a very large completion value would never
be matched in iommu_completion_wait().
Fixes: c69d89aff393 ("iommu/amd: Use 4K page for completion wait write-back semaphore")
Signed-off-by: John Sperbeck <jsperbeck@google.com>
Link: https://lore.kernel.org/r/20220801192229.3358786-1-jsperbeck@google.com
[ Upstream commit 3f0461613ebcdc8c4073e235053d06d5aa58750f ]
The second operand passed to slot_addr() is declared as int or unsigned int
in all call sites. The left-shift to get the offset of a slot can overflow
if swiotlb size is larger than 4G.
Convert the macro to an inline function and declare the second argument as
phys_addr_t to avoid the potential overflow.
Fixes: 26a7e094783d ("swiotlb: refactor swiotlb_tbl_map_single")
Signed-off-by: Chao Gao <chao.gao@intel.com>
Reviewed-by: Dongli Zhang <dongli.zhang@oracle.com>
[ Upstream commit 45bb006d3c924b1201ed43c87a96b437662dcaa8 ]
Fix HW rate limiting for ADQ.
Fallback to kernel queue selection for ADQ, as it is network stack
that decides which queue to use for transmit with ADQ configured.
Reset PF after creation of VMDq2 VSIs required for ADQ, as to
reprogram TX queue contexts in i40e_configure_tx_ring.
Without this patch PF would limit TX rate only according to TC0.
Fixes: a9ce82f744dc ("i40e: Enable 'channel' mode in mqprio for TC configs")
Signed-off-by: Przemyslaw Patynowski <przemyslawx.patynowski@intel.com>
Signed-off-by: Jan Sokolowski <jan.sokolowski@intel.com>
Tested-by: Bharathi Sreenivas <bharathi.sreenivas@intel.com>
Signed-off-by: Tony Nguyen <anthony.l.nguyen@intel.com>
[ Upstream commit 2313e69c84c024a85d017a60ae925085de47530a ]
Refactor bitwise checks for whether TC MQPRIO is enabled
into one single method for improved readability.
Stable-dep-of: 45bb006d3c92 ("i40e: Fix ADQ rate limiting for PF")
[ Upstream commit 1b620d539ccc18a1aca1613d9ff078115a7891a1 ]
Previously 'make ARCH=um headers' stopped because of missing
arch/um/include/uapi/asm/Kbuild.
The error is not shown since commit ed102bf2afed ("um: Fix W=1
missing-include-dirs warnings") added arch/um/include/uapi/asm/Kbuild.
Hard-code the unsupported architecture, so it works like before.
Fixes: ed102bf2afed ("um: Fix W=1 missing-include-dirs warnings")
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Acked-by: Richard Weinberger <richard@nod.at>
[ Upstream commit 35508d2424097f9b6a1a17aac94f702767035616 ]
The RTCCTRL reg of LS1C is obselete.
Writing this reg will cause system hang.
Fixes: 60219c563c9b6 ("MIPS: Add RTC support for Loongson1C board")
Signed-off-by: Yang Ling <gnaygnil@gmail.com>
Tested-by: Keguang Zhang <keguang.zhang@gmail.com>
Acked-by: Keguang Zhang <keguang.zhang@gmail.com>
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
commit 5c5c2baad2b55cc0a4b190266889959642298f79 upstream.
A recent change in clang strengthened its -Wbitfield-constant-conversion
to warn when 1 is assigned to a 1-bit signed integer bitfield, as it can
only be 0 or -1, not 1:
sound/soc/atmel/mchp-spdiftx.c:505:20: error: implicit truncation from 'int' to bit-field changes value from 1 to -1 [-Werror,-Wbitfield-constant-conversion]
dev->gclk_enabled = 1;
1 error generated.
The actual value of the field is never checked, just that it is not
zero, so there is not a real bug here. However, it is simple enough to
silence the warning by making the bitfield unsigned, which matches the
mchp-spdifrx driver.
Fixes: 06ca24e98e6b ("ASoC: mchp-spdiftx: add driver for S/PDIF TX Controller")
Link: https://github.com/ClangBuiltLinux/linux/issues/1686
Link: https://github.com/llvm/llvm-project/commit/82afc9b169a67e8b8a1862fb9c41a2cd974d6691
Signed-off-by: Nathan Chancellor <nathan@kernel.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Link: https://lore.kernel.org/r/20220810010809.2024482-1-nathan@kernel.org
commit 403fcb5118a0f4091001a537e76923031fb45eaf upstream.
Remove references to struct mchp_i2s_caps as they are not used.
Link: https://lore.kernel.org/r/20220727090814.2446111-3-claudiu.beznea@microchip.com
Cc: Nathan Chancellor <nathan@kernel.org>
commit 1f05f65bddd6958d25b133f886da49c1d4bff3fa upstream.
The tps23861 registers are little-endian, and regmap_read_bulk() does
not do byte order conversion. On BE machines, the bytes were swapped,
and the interpretation of the resistance value was incorrect.
To make it work on both big and little-endian machines, use
le16_to_cpu() to convert the resitance register to host byte order.
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
Fixes: fff7b8ab22554 ("hwmon: add Texas Instruments TPS23861 driver")
Link: https://lore.kernel.org/r/20220905142806.110598-1-mr.nuke.me@gmail.com
[ Upstream commit 82b2425fad2dd47204b3da589b679220f8aacc0e ]
Commit b91e5492f9d7ca89 ("perf record: Add a dummy event on hybrid
systems to collect metadata records") adds a dummy event on hybrid
systems to fix the symbol "unknown" issue when the workload is created
in a P-core but runs on an E-core. The added dummy event will cause
"perf script -F iregs" to fail. Dummy events do not have "iregs"
attribute set, so when we do evsel__check_attr, the "iregs" attribute
check will fail, so the issue happened.
The following commit [1] has fixed a similar issue by skipping the attr
check for the dummy event because it does not have any samples anyway. It
works okay for the normal mode, but the issue still happened when running
the test in the pipe mode. In the pipe mode, it calls process_attr() which
still checks the attr for the dummy event. This commit fixed the issue by
skipping the attr check for the dummy event in the API evsel__check_attr,
Otherwise, we have to patch everywhere when evsel__check_attr() is called.
Before:
#./perf record -o - --intr-regs=di,r8,dx,cx -e br_inst_retired.near_call:p -c 1000 --per-thread true 2>/dev/null|./perf script -F iregs |head -5
Samples for 'dummy:HG' event do not have IREGS attribute set. Cannot print 'iregs' field.
0x120 [0x90]: failed to process type: 64
After:
# ./perf record -o - --intr-regs=di,r8,dx,cx -e br_inst_retired.near_call:p -c 1000 --per-thread true 2>/dev/null|./perf script -F iregs |head -5
ABI:2 CX:0x55b8efa87000 DX:0x55b8efa7e000 DI:0xffffba5e625efbb0 R8:0xffff90e51f8ae100
ABI:2 CX:0x7f1dae1e4000 DX:0xd0 DI:0xffff90e18c675ac0 R8:0x71
ABI:2 CX:0xcc0 DX:0x1 DI:0xffff90e199880240 R8:0x0
ABI:2 CX:0xffff90e180dd7500 DX:0xffff90e180dd7500 DI:0xffff90e180043500 R8:0x1
ABI:2 CX:0x50 DX:0xffff90e18c583bd0 DI:0xffff90e1998803c0 R8:0x58
[1]https://lore.kernel.org/lkml/20220831124041.219925-1-jolsa@kernel.org/
Fixes: b91e5492f9d7ca89 ("perf record: Add a dummy event on hybrid systems to collect metadata records")
Suggested-by: Namhyung Kim <namhyung@kernel.org>
Signed-off-by: Xing Zhengjun <zhengjun.xing@linux.intel.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@intel.com>
Cc: Kan Liang <kan.liang@linux.intel.com>
Link: https://lore.kernel.org/r/20220908070030.3455164-1-zhengjun.xing@linux.intel.com
