So that we can profile code even in a local_irq_disable() section,
only write 14 (instead of 15) into the %pil register to disable IRQs.
This allows PIL level 15 to serve as a pseudo NMI.
Stephen Rothwell pointed out that pcmcia can't be enabled on sparc64.
There is an empty non-prompt PCMCIA explicit entry in
arch/sparc/Kconfig but that doesn't do anything.
32-bit sparc needs a small hack to make this work, since it doesn't
use the generic IRQ layer yes. We have to provide a dummy definition
of probe_irq_mask(), since this is used by the yenta socket driver.
Add a sysctl to tweak the RSS limit used to decide when to grow
the TSB for an address space.
In order to avoid expensive divides and multiplies only simply
positive and negative powers of two are supported.
The function computed takes the number of TSB translations that will
fit at one time in the TSB of a given size, and either adds or
subtracts a percentage of entries. This final value is the
RSS limit.
See tsb_size_to_rss_limit().
- move all sparc64/mm/ files to arch/sparc/mm/
- commonly named files are named _64.c
- add files to sparc/mm/Makefile preserving link order
- delete now unused sparc64/mm/Makefile
- sparc64 now finds mm/ in sparc
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
- rename files where sparc64 has similar files to _32.c
- Restructure Makefile
- Sneak in -Werror as we have for sparc64
A simple:
diff arch/sparc64/oprofile/init.c arch/sparc/oprofile/init.c
diff arch/sparc64/oprofile/Makefile arch/sparc/oprofile/Makefile
revealed that the directories were equal.
So let sparc64 point to the sparc version and drop the sparc64 oprofile dir
Move relavent files to sparc/math-emu and
adjust path/include accordingly.
Add _32 to filenames to make them 32 bit unique
- Drop unused assignment from Makefile
- Replace EXTRA_CFLAGS with ccflags-y
- Delete unused file
BITS will be used to simplify unified Makefiles
Merge all of sparc64 Kconfig to sparc Kconfig.
The merge was checked by:
- visual inspection in menuconfig
- result of allnoconfig, allmodconfig, allyesconfig was checked before and after
- result of a number of randconfig was checked before and after
scripts/diffconfig was used to check if the config differed before and after
The validity of the test was checked by on purpose introducing
a few bugs - and they were all caught by first run.
To align with sparc64 add a "Bus options" menu
This has the additiona advantage that all
bus options are kept together
This is what we use in sparc64 - make sparc equal
We already has the proper definition in place in param.h.
So use the common Kconfig.hz file
We have it in drivers/char/Kconfig
There is no need to ask twice
moved a few config entries inside a menu so we
do not clutter the first screen up with a lot of detailed
config options.
The structure now remotely resemble the structure for i386
Mode declaration of SPARC up in the top
to match the structure of sparc64 Kconfig
Let sparc and sparc64 use the same Kconfig.debug
The kernel always executes in the TSO memory model now,
so none of this stuff is necessary any more.
With helpful feedback from Nick Piggin.
The fact of the matter is, all UltraSPARC-III and later chips only
implement TSO. They don't implement PSO and RMO memory models at all.
Only the Ultra-I and Ultra-II family chips implement RMO and they are
only helped marginally by using this setting when executing kernel
code.
The big plus to doing this is that we can eliminate all of the non-Sync
memory barriers in the kernel except for the ones used in the optimized
memcpy/memset code (these use block load and store operations which
have their own memory ordering rules).
It only uses of_platform_bus_type.
Use common functions instead of inlining and duplicating logic
over and over to handle the SBUS vs. EBUS cases.
Before:
715 568 16 1299 513 arch/sparc64/kernel/auxio.o
After:
631 568 16 1215 4bf arch/sparc64/kernel/auxio.o
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6
Copy the FPU state to the task's thread_info->fpregs for the VIS emulation
functions to access.
Signed-off-by: Hong H. Pham <hong.pham@windriver.com>
This patch fixes some bugs in VIS emulation that cause the GCC test
failure
FAIL: gcc.target/sparc/pdist-3.c execution test
for both 32-bit and 64-bit testing on hardware lacking these
instructions. The emulation code for the pdist instruction uses
RS1(insn) for both source registers rs1 and rs2, which is obviously
wrong and leads to the instruction doing nothing (the observed
problem), and further inspection of the code shows that RS1 uses a
shift of 24 and RD a shift of 25, which clearly cannot both be right;
examining SPARC documentation indicates the correct shift for RS1 is
14.
This patch fixes the bug if single-stepping over the affected
instruction in the debugger, but not if the testcase is run
standalone. For that, Wind River has another patch I hope they will
send as a followup to this patch submission.
Signed-off-by: Joseph Myers <joseph@codesourcery.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: fix setting of max_segment_size and seg_boundary mask
block: internal dequeue shouldn't start timer
block: set disk->node_id before it's being used
When block layer fails to map iov, it calls bio_unmap_user to undo
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
powerpc/83xx: Fix MCU support merge issue in mpc8349emitx.dts
powerpc: Fix dma_map_sg() cache flushing on non coherent platforms
* 'for-2.6.28' of git://linux-nfs.org/~bfields/linux:
NLM: client-side nlm_lookup_host() should avoid matching on srcaddr
nfsd: use of unitialized list head on error exit in nfs4recover.c
Add a reference to sunrpc in svc_addsock
nfsd: clean up grace period on early exit
The code used '&= 0x00002000' when it tried to set the TCO_EN bit, which
obviously didn't set that bit at all, but instead just reset all the
other bits in the SMI_EN register.
This bug seemingly caused various random behavior, with Frans Pop
reporting that X.org just silently hung at startup and Rafael Wysocki
reports the fan spinning with full speed.
See
http://lkml.org/lkml/2008/12/3/178
http://bugzilla.kernel.org/show_bug.cgi?id=12162
The problem seems to have been triggered by "[WATCHDOG] iTCO_wdt :
problem with rebooting on new ICH9 based motherboards" (commit
7cd5b08be3c489df11b559fef210b81133764ad4), but the bogus code existed
before that too (in the "supermicro_old_pre_stop()" function), it just
apparently never showed up due to different logic.
In that commit the broken code got moved around and now gets executed
much more.
Reported-by: Rafael J. Wysocki <rjw@sisk.pl>
Tested-by: Frans Pop <elendil@planet.nl>
Cc: Wim Van Sebroeck <wim@iguana.be>
bitops_64.h includes the generic one; pretty sure 32 should too.
(Found by using __fls in generic code and breaking sparc defconfig build:
thanks Stephen and linux-next!)
Just found the merge issue in 442746989d92afc125040e0f29b33602ad94da99
("powerpc/83xx: Add support for MCU microcontroller in .dts files"):
the commit adds the MCU controller node into the DMA node, which is
wrong because the MCU sits on the I2C bus. Fix this by moving the MCU
node into the I2C controller node.
The original patch[1] was OK though. ;-)
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Fix setting of max_segment_size and seg_boundary mask for stacked md/dm
devices.
When stacking devices (LVM over MD over SCSI) some of the request queue
parameters are not set up correctly in some cases by default, namely
max_segment_size and and seg_boundary mask.
If you create MD device over SCSI, these attributes are zeroed.
Problem become when there is over this mapping next device-mapper mapping
- queue attributes are set in DM this way:
request_queue max_segment_size seg_boundary_mask
SCSI 65536 0xffffffff
MD RAID1 0 0
LVM 65536 -1 (64bit)
Unfortunately bio_add_page (resp. bio_phys_segments) calculates number of
physical segments according to these parameters.
During the generic_make_request() is segment cout recalculated and can
increase bio->bi_phys_segments count over the allowed limit. (After
bio_clone() in stack operation.)
Thi is specially problem in CCISS driver, where it produce OOPS here
BUG_ON(creq->nr_phys_segments > MAXSGENTRIES);
(MAXSEGENTRIES is 31 by default.)
Sometimes even this command is enough to cause oops:
dd iflag=direct if=/dev/<vg>/<lv> of=/dev/null bs=128000 count=10
This command generates bios with 250 sectors, allocated in 32 4k-pages
(last page uses only 1024 bytes).
For LVM layer, it allocates bio with 31 segments (still OK for CCISS),
unfortunatelly on lower layer it is recalculated to 32 segments and this
violates CCISS restriction and triggers BUG_ON().
The patch tries to fix it by:
* initializing attributes above in queue request constructor
blk_queue_make_request()
* make sure that blk_queue_stack_limits() inherits setting
(DM uses its own function to set the limits because it
blk_queue_stack_limits() was introduced later. It should probably switch
to use generic stack limit function too.)
* sets the default seg_boundary value in one place (blkdev.h)
* use this mask as default in DM (instead of -1, which differs in 64bit)
Bugs related to this:
https://bugzilla.redhat.com/show_bug.cgi?id=471639
http://bugzilla.kernel.org/show_bug.cgi?id=8672
Signed-off-by: Milan Broz <mbroz@redhat.com>
Reviewed-by: Alasdair G Kergon <agk@redhat.com>
Cc: Neil Brown <neilb@suse.de>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Mike Miller <mike.miller@hp.com>
blkdev_dequeue_request() and elv_dequeue_request() are equivalent and
both start the timeout timer. Barrier code dequeues the original
barrier request but doesn't passes the request itself to lower level
driver, only broken down proxy requests; however, as the original
barrier code goes through the same dequeue path and timeout timer is
started on it. If barrier sequence takes long enough, this timer
expires but the low level driver has no idea about this request and
oops follows.
Timeout timer shouldn't have been started on the original barrier
request as it never goes through actual IO. This patch unexports
elv_dequeue_request(), which has no external user anyway, and makes it
operate on elevator proper w/o adding the timer and make
blkdev_dequeue_request() call elv_dequeue_request() and add timer.
Internal users which don't pass the request to driver - barrier code
and end_that_request_last() - are converted to use
elv_dequeue_request().
Cc: Mike Anderson <andmike@linux.vnet.ibm.com>
disk->node_id will be refered in allocating in disk_expand_part_tbl, so we
should set it before disk->node_id is refered.
Signed-off-by: Cheng Renquan <crquan@gmail.com>
mapping. Which is good if pages were mapped - but if they were provided
by someone else and just copied then bad things happen - pages are
released once here, and once by caller, leading to user triggerable BUG
at include/linux/mm.h:246.
Signed-off-by: Petr Vandrovec <petr@vandrovec.name>
>The SPARC64 kernel code for PTRACE_SETFPREGS64 appears to be an exact copy
>of that for PTRACE_GETFPREGS64. This means that gdbserver and native
>64-bit GDB cannot set floating-point registers.
It looks like a simple typo.
On PowerPC 4xx or other non cache-coherent platforms, we lost the
appropriate cache flushing in dma_map_sg() when merging the 32 and
64-bit DMA code (commit 4fc665b88a79a45bae8bbf3a05563c27c7337c3d,
"powerpc: Merge 32 and 64-bit dma code"). This restores it.
Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
[WATCHDOG] hpwdt: Fix kdump when using hpwdt
[WATCHDOG] hpwdt: set the mapped BIOS address space as executable
[WATCHDOG] iTCO_wdt: add PCI ID's for ICH9 & ICH10 chipsets
[WATCHDOG] iTCO_wdt : correct status clearing
[WATCHDOG] iTCO_wdt : problem with rebooting on new ICH9 based motherboards
[WATCHDOG] fix mtx1_wdt compilation failure
* 'linux-next' of git://git.infradead.org/ubifs-2.6:
UBIFS: pre-allocate bulk-read buffer
UBIFS: do not allocate too much
UBIFS: do not print scary memory allocation warnings
UBIFS: allow for gaps when dirtying the LPT
UBIFS: fix compilation warnings
MAINTAINERS: change UBI/UBIFS git tree URLs
UBIFS: endian handling fixes and annotations
UBIFS: remove printk
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm
* 'kvm-updates/2.6.28' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm:
KVM: MMU: avoid creation of unreachable pages in the shadow
KVM: ppc: stop leaking host memory on VM exit
KVM: MMU: fix sync of ptes addressed at owner pagetable
KVM: ia64: Fix: Use correct calling convention for PAL_VPS_RESUME_HANDLER
KVM: ia64: Fix incorrect kbuild CFLAGS override
KVM: VMX: Fix interrupt loss during race with NMI
KVM: s390: Fix problem state handling in guest sigp handler
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc64: Fix offset calculation in compute_size()
rtc: rtc-starfire fixes
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
MAINTAINERS: add netdev to ATM
ATM: horizon, fix hrz_probe fail path
pppol2tp: Add missing sock_put() in pppol2tp_release()
net: Fix soft lockups/OOM issues w/ unix garbage collector
macvlan: don't broadcast PAUSE frames to macvlan devices
Phonet: fix oops in phonet_address_del() on non-Phonet device
netfilter: ctnetlink: fix GFP_KERNEL allocation under spinlock
sungem: Fix PCS_MIICTRL register write in gem_init_phy().
net: make skb_truesize_bug() call WARN()
net: hp-plus uses eip_poll
net/wireless/reg.c: fix bad WARN_ON in if statement
ath5k: disable beacon filter when station is not associated
ath5k: fix Security issue in DebugFS part of ath5k
ath9k: correct expected max RX buffer size
ath9k: Fix SW-IOMMU bounce buffer starvation
mac80211 : Fix setting ad-hoc mode and non-ibss channel
iwlagn: fix DMA sync
phylib: Add Vitesse VSC8221 SGMII PHY
rose: zero length frame filtering in af_rose.c
bridge: netfilter: fix update_pmtu crash with GRE
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: Update defconfigs for 2.6.28-rc7
macfb: Do not overflow fb_fix_screeninfo.id
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
alim15x3: fix sparse warning
ide: remove dead code from drive_is_ready()
ide: fix build for DEBUG_PM
ide: respect current DMA setting during resume
ide: add SAMSUNG SP0822N with firmware WA100-10 to ivb_list[]
amd74xx: workaround unreliable AltStatus register for nVidia controllers
ide: fix the ide_release_lock imbalance
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] stex: switch to block timeout
[SCSI] make scsi_eh_try_stu use block timeout
[SCSI] megaraid_sas: switch to block timeout
[SCSI] ibmvscsi: switch to block timeout
[SCSI] aacraid: switch to block timeout
[SCSI] zfcp: prevent double decrement on host_busy while being busy
[SCSI] zfcp: fix deadlock between wq triggered port scan and ERP
[SCSI] zfcp: eliminate race between validation and locking
[SCSI] zfcp: verify for correct rport state before scanning for SCSI devs
[SCSI] zfcp: returning an ERR_PTR where a NULL value is expected
[SCSI] zfcp: Fix opening of wka ports
[SCSI] zfcp: fix remote port status check
[SCSI] fc_transport: fix old bug on bitflag definitions
[SCSI] Fix hang in starved list processing
This fixes the MN10300 kernel module linking to match the toolchain. RELA
relocs don't use the value at the location being relocated. This has been
working because the tools always leave the value at the target location
cleared.
Signed-off-by: Mark Salter <msalter@redhat.com>
If xpc.ko and gru.ko are both statically linked into the kernel, then
xpc_init() can get called before gru_init() and make a call to one of the
gru's exported functions before the gru has initialized itself. The end
result is a NULL dereference.
Signed-off-by: Dean Nelson <dcn@sgi.com>
In the CONFIG_SMP case the irq_choose_cpu() code was returning back
a logical cpu id not the physical id. We were writing that directly
into the HW register.
We need to be calling get_hard_smp_processor_id() so irq_choose_cpu()
always returns a physical cpu id.
Count the insertion of new pages in the statistics used to drive the
pageout scanning code. This should help the kernel quickly evict
streaming file IO.
We count on the fact that new file pages start on the inactive file LRU
and new anonymous pages start on the active anon list. This means
streaming file IO will increment the recent scanned file statistic, while
leaving the recent rotated file statistic alone, driving pageout scanning
to the file LRUs.
Pageout activity does its own list manipulation.
Signed-off-by: Rik van Riel <riel@redhat.com>
Tested-by: Gene Heskett <gene.heskett@gmail.com>
