2009-07-03Update Yoichi Yuasa's e-mail addressYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: Allow suspend and hibernation again on uniprocessor kernels.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Pavel Machek <pavel@ucw.cz>
2009-07-03MIPS: 64-bit: Fix o32 core dumpYong Zhang
If an o32 process generates a core dump on a 64 bit kernel, the core file will not be correctly recognized. This is because ELF_CORE_COPY_REGS and ELF_CORE_COPY_TASK_REGS are not correctly defined for o32 and will use the default register set which would be CONFIG_64BIT in asm/elf.h. So we'll switch to use the right register defines in this situation by checking for WANT_COMPAT_REG_H and use the right defines of ELF_CORE_COPY_REGS and ELF_CORE_COPY_TASK_REGS. [Ralf: made ELF_CORE_COPY_TASK_REGS() bullet-proof against funny arguments.] Signed-off-by: Yong Zhang <yong.zhang@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: BC47xx: Fix SSB irq setupmatthieu castet
The current ssb irq setup in ssb_mipscore_init has the problem that it configures some device on some irq without checking that the irq is not taken by an other device. For example in my case PCI host is on irq 0 and IPSEC on irq 3. The current code: - store in dev->irq that IPSEC irq is 3 + 2 - do a set_irq 0->3 on PCI host But now IPSEC irq is not routed anymore to the mips code and dev->irq is wrong. This causes a problem described in [1]. This patch tries to solve the problem by making set_irq configure the device we want to take the irq on the shared irq0. The previous example becomes: - store in dev->irq that IPSEC irq is 3 + 2 - do a set_irq 0->3 on PCI host: - irq 3 is already taken by IPSEC. do a set_irq 3->0 on IPSEC I also added some code to print the irq configuration after irq setup to allow easier debugging. And I add extra checking in ssb_mips_irq to report device without irq or device with not routed irq. [1] http://www.danm.de/files/src/bcm5365p/REPORTED_DEVICES Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Acked-by : Michael Buesch <mb@bu3sch.de> Tested-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: CMP: Update sync-r4k for current kernelTim Anderson
This revises the sync-4k so it will boot and operate since the removal of expirelo from the timer code. Signed-off-by: Tim Anderson <tanderson@mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: CMP: Move gcmp_probe to before the SMP opsTim Anderson
This is to move the gcmp_probe call to before the use of and selection of the smp_ops functions. This allows malta with 1004K to work. Signed-off-by: Tim Anderson <tanderson@mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: CMP: activate CMP supportTim Anderson
Most of the CMP support was added before, this mostly correct compile problems but adds a platform specific translation for the interrupt number based on cpu number. Signed-off-by: Tim Anderson <tanderson@mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: CMP: Extend IPI handling to CPU numberTim Anderson
This takes the current IPI interrupt assignment from the fix number of 4 to the number of CPUs defined in the system. Signed-off-by: Tim Anderson <tanderson@mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: CMP: Extend the GIC IPI interrupts beyond 32Tim Anderson
This patch extends the GIC interrupt handling beyond the current 32 bit range as well as extending the number of interrupts based on the number of CPUs. Signed-off-by: Tim Anderson <tanderson@mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: Define __arch_swab64 for all mips r2 cpusDavid Daney
Some CPUs implement mipsr2, but because they are a super-set of mips64r2 do not define CONFIG_CPU_MIPS64_R2. Cavium OCTEON falls into this category. We would still like to use the optimized implementation, so since we have already checked for CONFIG_CPU_MIPSR2, checking for CONFIG_64BIT instead of CONFIG_CPU_MIPS64_R2 is sufficient. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: Update VR41xx GPIO driver to use gpiolibYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yyuasa@linux.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: Hookup new syscalls sys_rt_tgsigqueueinfo and sys_perf_counter_open.David Daney
[Ralf: I fixed up the numbering in the comment in scall64-n32.S.] Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: Malta: Remove unnecessary function prototypesDmitri Vorobiev
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: MT: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: Add support for Texas Instruments AR7 System-on-a-ChipFlorian Fainelli
This patch adds support for the Texas Instruments AR7 System-on-a-Chip. It supports the TNETD7100, 7200 and 7300 versions of the SoC. Signed-off-by: Matteo Croce <matteo@openwrt.org> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Eugene Konev <ejka@openwrt.org> Signed-off-by: Nicolas Thill <nico@openwrt.org> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-02x86: add boundary check for 32bit res before expand e820 resource to alignmentYinghai Lu
fix hang with HIGHMEM_64G and 32bit resource. According to hpa and Linus, use (resource_size_t)-1 to fend off big ranges. Analyzed by hpa Reported-and-tested-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-02x86: fix power-of-2 round_up/round_down macrosLinus Torvalds
These macros had two bugs: - the type of the mask was not correctly expanded to the full size of the argument being expanded, resulting in possible loss of high bits when mixing types. - the alignment argument was evaluated twice, despite the macro looking like a fancy function (but it really does need to be a macro, since it works on arbitrary integer types) Noticed by Peter Anvin, and with a fix that is a modification of his suggestion (bug noticed by Yinghai Lu). Cc: Peter Anvin <hpa@zytor.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01FRV: Add basic performance counter supportDavid Howells
Add basic performance counter support to the FRV arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01FRV: Implement atomic64_tDavid Howells
Implement atomic64_t and its ops for FRV. Tested with the following patch: diff --git a/arch/frv/kernel/setup.c b/arch/frv/kernel/setup.c index 55e4fab..086d50d 100644 --- a/arch/frv/kernel/setup.c +++ b/arch/frv/kernel/setup.c @@ -746,6 +746,52 @@ static void __init parse_cmdline_early(char *cmdline) } /* end parse_cmdline_early() */ +static atomic64_t xxx; + +static void test_atomic64(void) +{ + atomic64_set(&xxx, 0x12300000023LL); + + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000023LL); + mb(); + if (atomic64_inc_return(&xxx) != 0x12300000024LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000024LL); + mb(); + if (atomic64_sub_return(0x36900000050LL, &xxx) != -0x2460000002cLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002cLL); + mb(); + if (atomic64_dec_return(&xxx) != -0x2460000002dLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002dLL); + mb(); + if (atomic64_add_return(0x36800000001LL, &xxx) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x123456789abcdefLL, 0x121ffffffd4LL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x121ffffffd4LL, 0x123456789abcdefLL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x123456789abcdefLL); + mb(); + if (atomic64_xchg(&xxx, 0xabcdef123456789LL) != 0x123456789abcdefLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0xabcdef123456789LL); + mb(); +} + /*****************************************************************************/ /* * @@ -845,6 +891,8 @@ void __init setup_arch(char **cmdline_p) // asm volatile("movgs %0,timerd" :: "r"(10000000)); // __set_HSR(0, __get_HSR(0) | HSR0_ETMD); + test_atomic64(); + } /* end setup_arch() */ #if 0 Note that this doesn't cover all the trivial wrappers, but does cover all the substantial implementations. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: LCDC dcache flush for deferred io sh: Fix compiler error and include the definition of IS_ERR_VALUE sh: re-add LCDC fbdev support to the Migo-R defconfig sh: fix se7724 ceu names sh: ms7724se: Enable sh_eth in defconfig. arch/sh/boards/mach-se/7206/io.c: Remove unnecessary semicolons sh: ms7724se: Add sh_eth support nommu: provide follow_pfn(). sh: Kill off unused DEBUG_BOOTMEM symbol. perf_counter tools: add cpu_relax()/rmb() definitions for sh. sh64: Hook up page fault events for software perf counters. sh: Hook up page fault events for software perf counters. sh: make set_perf_counter_pending() static inline. clocksource: sh_tmu: Make undefined TCOR behaviour less undefined.
2009-07-02sh: LCDC dcache flush for deferred ioPaul Mundt
Since writenotify on uncached vmas is unsupported in 2.6.31, live with cached framebuffer memory in the deferred io case for now and flush the dcache before forcing refresh. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Magnus damm <damm@igel.co.jp>
2009-07-02sh: Fix compiler error and include the definition of IS_ERR_VALUEMatt Fleming
When arch/sh/include/asm/syscall_32.h is included from a file that doesn't also include linux/err.h the following error is produced, In file included from /home/matt/src/kernels/sh-2.6/arch/sh/include/asm/syscall.h:5, from kernel/trace/trace_syscalls.c:3: /home/matt/src/kernels/sh-2.6/arch/sh/include/asm/syscall_32.h: In function 'syscall_get_error': /home/matt/src/kernels/sh-2.6/arch/sh/include/asm/syscall_32.h:28: error: implicit declaration of function 'IS_ERR_VALUE' make[2]: *** [kernel/trace/trace_syscalls.o] Error 1 make[1]: *** [kernel/trace] Error 2 make: *** [kernel] Error 2 Signed-off-by: Matt Fleming <matt@console-pimps.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-07-01kernel-doc: move ignoring kmemcheckRandy Dunlap
Somehow I managed to generate a diff that put these 2 lines into the wrong function: should have been in dump_struct() instead of in dump_enum(). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: mtd: nand: fix build failure and incorrect return from omap_wait() mtd: Use BLOCK_NIL consistently in NFTL/INFTL mtd: m25p80 timeout too short for worst-case m25p16 devices mtd: atmel_nand: Fix typo s/parititions/partitions/ mtd: cmdlineparts: Use 64-bit format when printing a debug message. mtd: maps: Remove BUS_ID_SIZE from integrator_flash jffs2: fix another potential leak on error path in scan.c
2009-07-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: invalidation reverse calls fuse: allow umask processing in userspace fuse: fix bad return value in fuse_file_poll() fuse: fix return value of fuse_dev_write()
2009-07-01Fix iommu address space allocationDavid Woodhouse
This fixes kernel.org bug #13584. The IOVA code attempted to optimise the insertion of new ranges into the rbtree, with the unfortunate result that some ranges just didn't get inserted into the tree at all. Then those ranges would be handed out more than once, and things kind of go downhill from there. Introduced after 2.6.25 by ddf02886cbe665d67ca750750196ea5bf524b10b ("PCI: iova RB tree setup tweak"). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: mark gross <mgross@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01Fix pci_unmap_addr() et al on i386.David Woodhouse
We can run a 32-bit kernel on boxes with an IOMMU, so we need pci_unmap_addr() etc. to work -- without it, drivers will leak mappings. To be honest, this whole thing looks like it's more pain than it's worth; I'm half inclined to remove the no-op #else case altogether. But this is the minimal fix, which just does the right thing if CONFIG_DMAR is set. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@kernel.org [ for 2.6.30 ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01elf: fix one check-after-useAmerigo Wang
Check before use it. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cfq-iosched: remove redundant check for NULL cfqq in cfq_set_request() blocK: Restore barrier support for md and probably other virtual devices. block: get rid of queue-private command filter block: Create bip slabs with embedded integrity vectors cfq-iosched: get rid of the need for __GFP_NOFAIL in cfq_find_alloc_queue() cfq-iosched: move cfqq initialization out of cfq_find_alloc_queue() Trivial typo fixes in Documentation/block/data-integrity.txt.
2009-07-01Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: use interruptible wait when duration is controlled by userspace. md/raid5: suspend shouldn't affect read requests. md: tidy up error paths in md_alloc md: fix error path when duplicate name is found on md device creation. md: avoid dereferencing NULL pointer when accessing suspend_* sysfs attributes. md: Use new topology calls to indicate alignment and I/O sizes
2009-07-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits) Revert "ipv4: arp announce, arp_proxy and windows ip conflict verification" igb: return PCI_ERS_RESULT_DISCONNECT on permanent error e1000e: io_error_detected callback should return PCI_ERS_RESULT_DISCONNECT e1000: return PCI_ERS_RESULT_DISCONNECT on permanent error e1000: fix unmap bug igb: fix unmap length bug ixgbe: fix unmap length bug ixgbe: Fix link capabilities during adapter resets ixgbe: Fix device capabilities of 82599 single speed fiber NICs. ixgbe: Fix SFP log messages usbnet: Remove private stats structure usbnet: Use netdev stats structure smsc95xx: Use netdev stats structure rndis_host: Use netdev stats structure net1080: Use netdev stats structure dm9601: Use netdev stats structure cdc_eem: Use netdev stats structure ipv4: Fix fib_trie rebalancing, part 3 bnx2x: Fix the behavior of ethtool when ONBOOT=no sctp: xmit sctp packet always return no route error ...
2009-07-01kmemleak: Fix scheduling-while-atomic bugIngo Molnar
One of the kmemleak changes caused the following scheduling-while-holding-the-tasklist-lock regression on x86: BUG: sleeping function called from invalid context at mm/kmemleak.c:795 in_atomic(): 1, irqs_disabled(): 0, pid: 1737, name: kmemleak 2 locks held by kmemleak/1737: #0: (scan_mutex){......}, at: [<c10c4376>] kmemleak_scan_thread+0x45/0x86 #1: (tasklist_lock){......}, at: [<c10c3bb4>] kmemleak_scan+0x1a9/0x39c Pid: 1737, comm: kmemleak Not tainted 2.6.31-rc1-tip #59266 Call Trace: [<c105ac0f>] ? __debug_show_held_locks+0x1e/0x20 [<c102e490>] __might_sleep+0x10a/0x111 [<c10c38d5>] scan_yield+0x17/0x3b [<c10c3970>] scan_block+0x39/0xd4 [<c10c3bc6>] kmemleak_scan+0x1bb/0x39c [<c10c4331>] ? kmemleak_scan_thread+0x0/0x86 [<c10c437b>] kmemleak_scan_thread+0x4a/0x86 [<c104d73e>] kthread+0x6e/0x73 [<c104d6d0>] ? kthread+0x0/0x73 [<c100959f>] kernel_thread_helper+0x7/0x10 kmemleak: 834 new suspected memory leaks (see /sys/kernel/debug/kmemleak) The bit causing it is highly dubious: static void scan_yield(void) { might_sleep(); if (time_is_before_eq_jiffies(next_scan_yield)) { schedule(); next_scan_yield = jiffies + jiffies_scan_yield; } } It called deep inside the codepath and in a conditional way, and that is what crapped up when one of the new scan_block() uses grew a tasklist_lock dependency. This minimal patch removes that yielding stuff and adds the proper cond_resched(). The background scanning thread could probably also be reniced to +10. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01cfq-iosched: remove redundant check for NULL cfqq in cfq_set_request()Shan Wei
With the changes for falling back to an oom_cfqq, we never fail to find/allocate a queue in cfq_get_queue(). So remove the check. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01blocK: Restore barrier support for md and probably other virtual devices.NeilBrown
The next_ordered flag is only meaningful for devices that use __make_request. So move the test against next_ordered out of generic code and in to __make_request Since this test was added, barriers have not worked on md or any devices that don't use __make_request and so don't bother to set next_ordered. (dm explicitly sets something other than QUEUE_ORDERED_NONE since commit 99360b4c18f7675b50d283301d46d755affe75fd but notes in the comments that it is otherwise meaningless). Cc: Ken Milmore <ken.milmore@googlemail.com> Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01block: get rid of queue-private command filterJens Axboe
The initial patches to support this through sysfs export were broken and have been if 0'ed out in any release. So lets just kill the code and reclaim some space in struct request_queue, if anyone would later like to fixup the sysfs bits, the git history can easily restore the removed bits. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01block: Create bip slabs with embedded integrity vectorsMartin K. Petersen
This patch restores stacking ability to the block layer integrity infrastructure by creating a set of dedicated bip slabs. Each bip slab has an embedded bio_vec array at the end. This cuts down on memory allocations and also simplifies the code compared to the original bvec version. Only the largest bip slab is backed by a mempool. The pool is contained in the bio_set so stacking drivers can ensure forward progress. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.(none)>
2009-07-01cfq-iosched: get rid of the need for __GFP_NOFAIL in cfq_find_alloc_queue()Jens Axboe
Setup an emergency fallback cfqq that we allocate at IO scheduler init time. If the slab allocation fails in cfq_find_alloc_queue(), we'll just punt IO to that cfqq instead. This ensures that cfq_find_alloc_queue() never fails without having to ensure free memory. On cfqq lookup, always try to allocate a new cfqq if the given cfq io context has the oom_cfqq assigned. This ensures that we only temporarily punt to this shared queue. Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01cfq-iosched: move cfqq initialization out of cfq_find_alloc_queue()Jens Axboe
We're going to be needing that init code outside of that function to get rid of the __GFP_NOFAIL in cfqq allocation. Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01Trivial typo fixes in Documentation/block/data-integrity.txt.Andre Noll
Signed-off-by: Andre Noll <maan@systemlinux.org> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01sh: re-add LCDC fbdev support to the Migo-R defconfigMagnus Damm
Re-add LCDC fbdev support to the Migo-R defconfig. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-07-01sh: fix se7724 ceu namesMagnus Damm
Use "ceu0" and "ceu1" as CEU names instead of "ceu". This fixes "memchunk" kernel command line selection on the solution engine 7724 board. With this patch applied use "memchunk.ceu0=1m" or "memchunk.ceu1=1m" on kernel command line to override physically memory size to one meg for CEU0 or CEU1. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-07-01md: use interruptible wait when duration is controlled by userspace.NeilBrown
User space can set various limits on an md array so that resync waits when it gets to a certain point, or so that I/O is blocked for a short while. When md is waiting against one of these limit, it should use an interruptible wait so as not to add to the load average, and so are not to trigger a warning if the wait goes on for too long. Signed-off-by: NeilBrown <neilb@suse.de>
2009-07-01md/raid5: suspend shouldn't affect read requests.NeilBrown
md allows write to regions on an array to be suspended temporarily. This allows user-space to participate is aspects of reshape. In particular, data can be copied with not risk of a race. We should not be blocking read requests though, so don't. Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-30Revert "ipv4: arp announce, arp_proxy and windows ip conflict verification"Eric W. Biederman
This reverts commit 73ce7b01b4496a5fbf9caf63033c874be692333f. After discovering that we don't listen to gratuitious arps in 2.6.30 I tracked the failure down to this commit. The patch makes absolutely no sense. RFC2131 RFC3927 and RFC5227. are all in agreement that an arp request with sip == 0 should be used for the probe (to prevent learning) and an arp request with sip == tip should be used for the gratitous announcement that people can learn from. It appears the author of the broken patch got those two cases confused and modified the code to drop all gratuitous arp traffic. Ouch! Cc: stable@kernel.org Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30igb: return PCI_ERS_RESULT_DISCONNECT on permanent errorAlexander Duyck
PCI drivers that implement the io_error_detected callback should return PCI_ERS_RESULT_DISCONNECT if the state passed in is pci_channel_io_perm_failure. This patch fixes the issue for igb. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30e1000e: io_error_detected callback should return PCI_ERS_RESULT_DISCONNECTMike Mason
on permanent failure PCI drivers that implement the io_error_detected callback should return PCI_ERS_RESULT_DISCONNECT if the state passed in is pci_channel_io_perm_failure. This state is not checked in many of the network drivers. This patch fixes the omission in the e1000e driver. Signed-off-by: Mike Mason <mmlnx@us.ibm.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30e1000: return PCI_ERS_RESULT_DISCONNECT on permanent errorAndre Detsch
PCI drivers that implement the io_error_detected callback should return PCI_ERS_RESULT_DISCONNECT if the state passed in is pci_channel_io_perm_failure. This state is not checked in many of the network drivers. The patch fixes the omission in the e1000 driver. Based on Mike Mason's similar patch for e1000e. Signed-off-by: Andre Detsch <adetsch@br.ibm.com> CC: Mike Mason <mmlnx@us.ibm.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30e1000: fix unmap bugJesse Brandeburg
as reported by kerneloops.org [ 121.781161] ------------[ cut here ]------------ [ 121.781171] WARNING: at lib/dma-debug.c:793 check_unmap+0x14e/0x577() [ 121.781173] Hardware name: S5520HC [ 121.781177] e1000 0000:0a:00.0: DMA-API: device driver tries to free DMA memory it has not allocated [device address=0x00000001d688b0fa] [size=1522 bytes] [ 121.781180] Modules linked in: e1000 mdio dca [last unloaded: ixgbe] [ 121.781187] Pid: 4793, comm: bash Tainted: P 2.6.30-master-06161113 #3 [ 121.781190] Call Trace: [ 121.781195] [<ffffffff8123056f>] ? check_unmap+0x14e/0x577 [ 121.781201] [<ffffffff81057a19>] warn_slowpath_common+0x77/0x8f [ 121.781205] [<ffffffff81057ae1>] warn_slowpath_fmt+0x9f/0xa1 [ 121.781212] [<ffffffff81477ce2>] ? _spin_lock_irqsave+0x3f/0x49 [ 121.781216] [<ffffffff8122fa97>] ? get_hash_bucket+0x28/0x33 [ 121.781220] [<ffffffff8123056f>] check_unmap+0x14e/0x577 [ 121.781225] [<ffffffff810e4f48>] ? check_bytes_and_report+0x38/0xcb [ 121.781230] [<ffffffff81230bbf>] debug_dma_unmap_page+0x80/0x92 [ 121.781234] [<ffffffff8122e549>] ? unmap_single+0x1a/0x4e [ 121.781239] [<ffffffff813901e1>] ? __kfree_skb+0x74/0x78 [ 121.781250] [<ffffffffa00662ef>] pci_unmap_single+0x64/0x6d [e1000] [ 121.781259] [<ffffffffa0066344>] e1000_clean_rx_ring+0x4c/0xbf [e1000] [ 121.781268] [<ffffffffa00663df>] e1000_clean_all_rx_rings+0x28/0x36 [e1000] [ 121.781277] [<ffffffffa0067464>] e1000_down+0x138/0x141 [e1000] [ 121.781286] [<ffffffffa00681c2>] __e1000_shutdown+0x6b/0x198 [e1000] [ 121.781296] [<ffffffffa0068405>] e1000_suspend+0x17/0x50 [e1000] [ 121.781301] [<ffffffff81237665>] pci_legacy_suspend+0x3b/0xbe [ 121.781305] [<ffffffff81237bc6>] pci_pm_suspend+0x3e/0xf1 [ 121.781310] [<ffffffff812eaf1c>] pm_op+0x57/0xde [ 121.781314] [<ffffffff812eb444>] dpm_suspend_start+0x31e/0x470 [ 121.781319] [<ffffffff810877da>] suspend_devices_and_enter+0x3e/0x1a2 [ 121.781323] [<ffffffff81087a0f>] enter_state+0xd1/0x127 [ 121.781327] [<ffffffff8108717a>] state_store+0xa7/0xc9 [ 121.781332] [<ffffffff81221843>] kobj_attr_store+0x17/0x19 [ 121.781336] [<ffffffff8113c01e>] sysfs_write_file+0xe5/0x121 [ 121.781341] [<ffffffff810ed165>] vfs_write+0xab/0x105 [ 121.781344] [<ffffffff810ed279>] sys_write+0x47/0x6d [ 121.781349] [<ffffffff81027aab>] system_call_fastpath+0x16/0x1b [ 121.781352] ---[ end trace 97bacaaac2ed7786 ]--- Fix is to correctly zero out internal ->dma value when unmapping and make sure never to unmap unless there specifically was a mapping done. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30igb: fix unmap length bugJesse Brandeburg
driver was mixing NET_IP_ALIGN count bytes in map/unmap calls unevenly. Only map the bytes that the hardware might dma into also fix unmap related bug where ->dma was not being cleared after unmap Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30ixgbe: fix unmap length bugJesse Brandeburg
This patch addresses three WARN_ON statements from DMA-API debug code ixgbe is mapping more than it unmaps, reduce the length of the map call and remove the "used once" local variable. found by Joerg Roedel <joerg.roedel@amd.com> in 2.6.30, so is a candidate for -stable. in addition, fix missing ->dma = 0 after unmap to prevent double free with pci_unmap_single and lastly, don't unmap (half) pages that aren't mapped. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> CC: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
