In the original code if the copy_from_user() fails in rds_rdma_pages()
then the error handling fails and we get a stack trace from kmalloc().
The mod->mbhdlr[] array has BFI_MC_MAX elements.
Move 'synced' and 'global_use' fields before 'refcount', to shrinks
struct netdev_hw_addr by 8 bytes (on 64bit arches).
gro can be enabled by default on bonding devices.
Actual support depends on the lower devices.
One can still use ethtool to switch off GRO if needed.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
The ethtool utility does not set masks for flow parameters that are
not specified, so if both value and mask are 0 then this must be
treated as equivalent to a mask with all bits set. Currently that is
done in the only driver that implements RX n-tuple filtering, ixgbe.
Move it to the ethtool core.
previously, if a vlan master device was moved from one network namespace
to another, all 802.1q and macvlan slaves were deleted.
we can use dev->reg_state to figure out whether dev_change_net_namespace
is happening, since that won't set dev->reg_state NETREG_UNREGISTERING.
so, this changes 8021q and macvlan to ignore NETDEV_UNREGISTER when
reg_state is not NETREG_UNREGISTERING.
Signed-off-by: David Lamparter <equinox@diac24.net>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
Acked-by: Patrick McHardy <kaber@trash.net>
Use one memset() to reset all TDES01 fields instead
of one by one to reduce number of instructions.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Add a limit when perform the DMA reset procedure
so, in case of problems (i.e. PHY reset failed) the
Kernel won't hang on the stmmac DMA initialisation
blocking the Kernels execution.
The first version of the driver had hard-coded the logic
for handling the checksum offloading.
This was designed according to the chips included in
the STM platforms where:
o MAC10/100 supports no COE at all.
o GMAC fully supports RX/TX COE.
This is not good for other chip configurations where,
for example, the mac10/100 supports the tx csum in HW
or when the GMAC has no IPC.
Thanks to Johannes Stezenbach; he provided me a first
draft of this patch that only reviewed the IPC for the
GMAC devices.
This patch also helps on SPEAr platforms where the
MAC10/100 can perform the TX csum in HW.
Thanks to Deepak SIKRI for his support on this.
In the end, GMAC devices for STM platforms have
a bugged Jumbo frame support that needs to have
the Tx COE disabled for oversized frames (due to
limited buffer sizes). This information is also
passed through the driver's platform structure.
Signed-off-by: Johannes Stezenbach <js@sig21.net>
Signed-off-by: Deepak SIKRI <deepak.sikri@st.com>
This patch adds the CSR Clock range selection.
Original patch from Johannes Stezenbach fixed the CSR
in the stmmac_mdio. We agreed to provide this through
the platform instead of.
Also thanks to Johannes for having tested it on ARM.
To be able to switch on GRO on a device, ethtool_set_gro() checks this
device provides a get_rx_csum() method.
Some devices dont provide this method, while they do support RX
checksumming.
This patch allows bonding to support GRO :
ethtool -K bond0 gro on
Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com>
Don't compare flash and file fw version. Allow to load
old fw from file than flashed fw.
If file fw is present, don't skip fw re-intialization.
LRO + GRO + vlan rx accleration support, performance increases
around 20% and cpu utilization reduces around 70% on vlan interface.
GRO support + vlan rx accleration, boost around 9%
performance and reduces 25% of cpu utilization on vlan
interface.
Implemented vlan rx accleration in driver.
This helps in increasing significant performance and
reduces cpu utilization with GRO and LRO.
Eric Dumazet:
"Its a bit strange you use dev_kfree_skb_any(skb) here."
"We run in NAPI mode, so you can use dev_kfree_skb()."
Amit:
Done. Using dev_kfree_skb();
This was previously reported as a security issue due to leakage of
uninitialized stack memory. Jeff Mahoney pointed out that this is
incorrect since the copied data is from a union (rather than a struct).
Therefore, this patch is only under consideration for the sake of
correctness, and is not security relevant.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Acked-by: Grant Grundler <grundler@parisc-linux.org>
commit ab95bfe01 (net: replace hooks in __netif_receive_skb) added
rx_handler at wrong place, between two cache line aligned objects,
creating a big hole (a full cache line)
Move rx_handler and rx_handler_data before rx_queue, filling existing
hole.
Move master field in the cache line(s) used in receive path.
This saves 64 bytes (or L1_CACHE_BYTES), and avoids two possible
cache misses in receive path.
As RTNL is held while doing tunnels inserts and deletes, we can remove
ip6_tnl_lock spinlock. My initial RCU conversion was conservative and
converted the rwlock to spinlock, with no RTNL requirement.
Use appropriate rcu annotations and modern lockdep checks as well.
rcu_dereference_raw() now needs to know the type of its argument.
Currently vlan devices don't have GRO by default as none of the Ethernet
drivers add NETIF_F_GRO to their vlan_features.
As GRO is a software feature add GRO to dev->vlan_features in
register_netdevice() and let vlan_dev_init() take care that it gets
enabled only when dev->features has NETIF_F_GRO too.
Signed-off-by: Brandon Philips <bphilips@suse.de>
This patch removes the unconditional return in the end of the
function check_sqs()
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
The driver has supported GRO for a while, but it was not enabled
by default.
dev->ip_ptr is protected by rtnl and rcu.
Yet some places dont use appropriate primitives and/or locking rules.
net/phonet/socket.c: In function ‘pn_res_seq_show’:
net/phonet/socket.c:726: warning: format ‘%02X’ expects type ‘unsigned int’, but argument 3 has type ‘long int’
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
I wish we could use something cleaner, such as bind(). But that would
not work since resource subscription is orthogonal/in addition to the
normal object ID allocated via bind(). This is similar to multicasting
which also uses ioctl()'s.
When both destination device and object are nul, Phonet routes the
packet according to the resource field. In fact, this is the most
common pattern when sending Phonet "request" packets. In this case,
the packet is delivered to whichever endpoint (socket) has
registered the resource.
This adds a new table so that Linux processes can register their
Phonet sockets to Phonet resources, if they have adequate privileges.
(Namespace support is not implemented at the moment.)
Closing a pipe endpoint is not normally allowed by the Phonet pipe,
other than as a side after-effect of removing the pipe between two
endpoints. But there is no way to prevent Linux userspace processes
from being killed or suffering from bugs, so this can still happen.
We might as well forcefully close Phonet pipe endpoints then.
The cellular modem supports only a few existing pipes at a time. So we
really should not leak them. This change instructs the modem to destroy
the pipe if either of the pipe's endpoint (Linux socket) is closed too
early.
The use of the big kernel lock in misdn is completely
bogus, so let's just remove it.
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: netdev@vger.kernel.org
The isdn4linux driver uses the big kernel lock only
to serialize access to a few fields in its own
modem_info structure.
The easiest replacement is a driver-wide mutex.
More fine-grained locking would be more appropriate
here, but likely harder to implement.
There may be applications trying to seek
on the irnet character device, so we should
use noop_llseek to avoid returning an error
when the default llseek changes to no_llseek.
Cc: Samuel Ortiz <samuel@sortiz.org>
ipip6_lock spinlock. My initial RCU conversion was conservative and
ipgre_lock spinlock. My initial RCU conversion was conservative and
ipip_lock spinlock. My initial RCU conversion was conservative and
We sometime want to dereference an rcu protected pointer while
holding RTNL. Use a macro to hide all lockdep details.
struct ethtool_rawip4_spec and struct ethtool_ether_spec are neither
commented nor used by any driver, so remove them. Adjust padding in
the user-visible unions that included these structures.
Fix references to struct ethtool_rawip4_spec in
ethtool_get_rx_ntuple(), which should use struct ethtool_usrip4_spec.
struct ethtool_usrip4_spec cannot hold IPv6 host addresses and there
is no separate structure that can, so remove ETH_RX_NFC_IP6 and the
reference to it in niu.
There are now several interfaces within the ethtool API for getting
and setting RX flow filtering and hashing behaviour, most of which are
poorly documented. This adds kernel-doc comments for all these
interfaces, based on the existing incomplete comments and on the
initial implementations.
The tg3's phy routines define temporary variables in many locations
within the same routine. This patch unifies all temporary variables
into one location.
Reviewed-by: Benjamin Li <benli@broadcom.com>
Reviewed-by: Michael Chan <mchan@broadcom.com>
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
This patch eases stack pressure by dynamically allocating the memory
used to temporarily store VPD data.
This patch converts the driver to prefer the skb_is_gso_v6() helper over
the explicit inlined version.
Now that each NAPI instance has its own producer ring, it no longer
makes sense to keep the producer ring structure external. This patch
migrates the producer ring struct to tg3_napi and pivots the code to the
new implementation.
TG3_IRQ_MAX_VECS should be seen as the maximum number of vectors that
any device could be expected to use. tp->irq_max represents the maximum
number of vectors the current device can use. This patch clarifies the
semantics of the code to match the above description.
This patch adjusts the driver to use the tg3_start_xmit_dma_bug()
transmit routine for all revisions of 5717 asic rev devices and then
allows the driver to attach to B0 and later devices.
NCSI firmware does not accept APE events. It relies on a "driver state"
location in shared memory to tell it what the driver's current state is.
This patch pivots the code to use the new driver state scheme.
It was recently discovered that enabling TSS can lockup the device.
This patch disables the feature until a suitable workaround can be
found.
