This adds an ADC driver for the STMPE device using the industrial
input/output interface. The driver supports raw reading of values.
The driver depends on the MFD STMPE driver. If the touchscreen
block is enabled too, only four of the 8 ADC channels are available.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
(cherry-picked from commit 9f3d084965a5544f096d4f769e274d4c2892079b)
This patch removes common ADC settings in favor to use
stmpe811_adc_common_init that is present in MFD. This is necessary in
preparation for the stmpe-adc driver, because those two drivers have
common settings for the ADC.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
(cherry-picked from 88f29d0f2c8f0d8097dfca9fc3619dfe893e0b15)
Move defines that are ADC related to the header of the overlying MFD,
so they can be used from multiple sub-devices.
(cherry-picked from 063755ab1d1c1127adc09703185967862584935b)
This patch reformats the parameter list for stmpe device in a
table-style so it is more clear to read.
Reviewed-by: Rob Herring <robh@kernel.org>
(cherry-picked from 270a60bcc8f23254d749987f3d2acb79ea5c599e)
This prepares the MFD for the STMPE ADC driver. This commit introduces
devicetree settings that are used by the ADC and adds an init function.
Common ADC settings that are shared with the touchscreen driver can now
reside in the overlying MFD.
(cherry-picked from commit 6377cfa3b857ced301f2079ac97de6c19057ab65)
This reverts commit 8a0cc368e527f1e977c2852aaa67b8d4c974a551.
In preparation to add the mainline version.
- increase trailing delay after VAG power down to reduce trailing pop;
- mute HP/LINE output before VAG power up.
Related to: #48500
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
- mute headphone on change of sound path;
- keeping VAG power if LINE_IN is muxed to HP leads to loud pops.
Remove VAG power keeping logic.
Related to: #48500
- set up parameters to read card registers via sysfs
- assign manually the source of charge pump ONLY if
automatic selection can't perform.
- change HP_ZCD_EN/ADC_ZCD_EN bits only in CHIP_ANA_CTRL register.
Related to: #48500
- adding mute/unmute controls for headphone and lineout allows
alsa-compatible sound players automatically unmute output
port to play music.
Related to: #48500
- define the SMALL_POP as a 1-bit mask, not value;
- properly set the SMALL_POP on device probing.
Related to: #48500
- add recovery mode for applicable i2c buses for
Colibri iMX7 module.
- fix the name of pinctrl set for i2c2 recovery mode;
Apalis/Colibri iMX6Q/D/DL modules.
Related to: #49059
Commit 41ec065fc5841 fixes ecspi sdma script type for spi1-4 only.
Commit df07101e1c4a2 sets wrong type of sdma script for SPI5.
The workaroud sdma script NOT work in SPBA bus, so return back
the correct sdma script type for spi5.
Related to: #48675
toradex_4.9-2.3.x-imx-next
4.9 2.3.x imx
This is the 4.9.166 stable release
I don't know where that mcp258x came from but it really is a mcp2515.
commit 6707ba0105a2d350710bc0a537a98f49eb4b895d upstream.
The way that 'strncat' is used here raised a warning in gcc-8:
drivers/net/wireless/ath/ath10k/wmi.c: In function 'ath10k_wmi_tpc_stats_final_disp_tables':
drivers/net/wireless/ath/ath10k/wmi.c:4649:4: error: 'strncat' output truncated before terminating nul copying as many bytes from a string as its length [-Werror=stringop-truncation]
Effectively, this is simply a strcat() but the use of strncat() suggests
some form of overflow check. Regardless of whether this might actually
overflow, using strlcat() instead of strncat() avoids the warning and
makes the code more robust.
Fixes: bc64d05220f3 ("ath10k: debugfs support to get final TPC stats for 10.4 variants")
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit f25a646fbe2051527ad9721853e892d13a99199e upstream.
Fix incorrect return value.
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
commit 5fb5caee92ba35a4a3baa61d45a78eb057e2c031 upstream.
Before this patch the enable signal was set before the PWM signal and
vice-versa on power off. This sequence is wrong, at least, it is on
the different panels datasheets that I checked, so I inverted the sequence
to follow the specs.
For reference the following panels have the mentioned sequence:
- N133HSE-EA1 (Innolux)
- N116BGE (Innolux)
- N156BGE-L21 (Innolux)
- B101EAN0 (Auo)
- B101AW03 (Auo)
- LTN101NT05 (Samsung)
- CLAA101WA01A (Chunghwa)
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Acked-by: Daniel Thompson <daniel.thompson@linaro.org>
Acked-by: Jingoo Han <jingoohan1@gmail.com>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
commit 36d46cdb43efea74043e29e2a62b13e9aca31452 upstream.
If we convert one large time values to rtc_time, in the original formula
'days * 86400' can be overflowed in 'unsigned int' type to make the formula
get one incorrect remain seconds value. Thus we can use div_s64_rem()
function to avoid this situation.
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
commit 83dc7e3dea76b77b6bcc289eb86c5b5c145e8dff upstream.
Since the command type of UTRD in UFS 2.1 specification is the same with
UFS 2.0. And it assumes the future UFS specification will follow the
same definition.
Signed-off-by: kehuanlin <kehuanlin@pinecone.net>
Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org>
commit 32fd87b3bbf5f7a045546401dfe2894dbbf4d8c3 upstream.
When cleaning up the configurations, make sure we only free the number
of configurations and interfaces that we could have allocated.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Cc: stable <stable@vger.kernel.org>
commit 3f3295709edea6268ff1609855f498035286af73 upstream.
The current int_sqrt() computation is sub-optimal for the case of small
@x. Which is the interesting case when we're going to do cumulative
distribution functions on idle times, which we assume to be a random
variable, where the target residency of the deepest idle state gives an
upper bound on the variable (5e6ns on recent Intel chips).
In the case of small @x, the compute loop:
while (m != 0) {
b = y + m;
y >>= 1;
if (x >= b) {
x -= b;
y += m;
m >>= 2;
can be reduced to:
while (m > x)
m >>= 2;
Because y==0, b==m and until x>=m y will remain 0.
And while this is computationally equivalent, it runs much faster
because there's less code, in particular less branches.
cycles: branches: branch-misses:
OLD:
hot: 45.109444 +- 0.044117 44.333392 +- 0.002254 0.018723 +- 0.000593
cold: 187.737379 +- 0.156678 44.333407 +- 0.002254 6.272844 +- 0.004305
PRE:
hot: 67.937492 +- 0.064124 66.999535 +- 0.000488 0.066720 +- 0.001113
cold: 232.004379 +- 0.332811 66.999527 +- 0.000488 6.914634 +- 0.006568
POST:
hot: 43.633557 +- 0.034373 45.333132 +- 0.002277 0.023529 +- 0.000681
cold: 207.438411 +- 0.125840 45.333132 +- 0.002277 6.976486 +- 0.004219
Averages computed over all values <128k using a LFSR to generate order.
Cold numbers have a LFSR based branch trace buffer 'confuser' ran between
each int_sqrt() invocation.
Link: http://lkml.kernel.org/r/20171020164644.876503355@infradead.org
Fixes: 30493cc9dddb ("lib/int_sqrt.c: optimize square root algorithm")
Suggested-by: Anshul Garg <aksgarg1989@gmail.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Joe Perches <joe@perches.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Michael Davidson <md@google.com>
commit 4350782570b919f254c1e083261a21c19fcaee90 upstream.
On Spreadtrum's serial device, nearly all of interrupts would be cleared
by hardware except timeout interrupt. This patch removed the operation
of clearing all interrupt in irq handler, instead added an if statement
to check if the timeout interrupt is supposed to be cleared.
Wrongly clearing timeout interrupt would lead to uart data stay in rx
fifo, that means the driver cannot read them out anymore.
Signed-off-by: Lanqing Liu <lanqing.liu@spreadtrum.com>
Signed-off-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com>
commit 6f44a0bacb79a03972c83759711832b382b1b8ac upstream.
In current die(), the irq is disabled for __die() handle, not
including the possible panic() handling. Since the log in __die()
can take several hundreds ms, new irq might come and interrupt
current die().
If the process calling die() holds some critical resource, and some
other process scheduled later also needs it, then it would deadlock.
The first panic will not be executed.
So here disable irq for the whole flow of die().
Signed-off-by: Qiao Zhou <qiaozhou@asrmicro.com>
commit 81be24d263dbeddaba35827036d6f6787a59c2c3 upstream.
It's not hard to trigger a bunch of d_invalidate() on the same
dentry in parallel. They end up fighting each other - any
dentry picked for removal by one will be skipped by the rest
and we'll go for the next iteration through the entire
subtree, even if everything is being skipped. Morevoer, we
immediately go back to scanning the subtree. The only thing
we really need is to dissolve all mounts in the subtree and
as soon as we've nothing left to do, we can just unhash the
dentry and bugger off.
commit e1dc9b08051a2c2e694edf48d1e704f07c7c143c upstream.
SPRD_TIMEOUT was 256, which is too small to wait until the status
switched to workable in a while loop, so that the earlycon could
not work correctly.
Signed-off-by: Wei Qiao <wei.qiao@spreadtrum.com>
commit 5ea8ea2cb7f1d0db15762c9b0bb9e7330425a071 upstream.
Per listen(fd, backlog) rules, there is really no point accepting a SYN,
sending a SYNACK, and dropping the following ACK packet if accept queue
is full, because application is not draining accept queue fast enough.
This behavior is fooling TCP clients that believe they established a
flow, while there is nothing at server side. They might then send about
10 MSS (if using IW10) that will be dropped anyway while server is under
stress.
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
commit b5a236c175b0d984552a5f7c9d35141024c2b261 upstream.
Recently we found the audio jack detection stop working after suspend
on many machines with Realtek codec. Sometimes the audio selection
dialogue didn't show up after users plugged headhphone/headset into
the headset jack, sometimes after uses plugged headphone/headset, then
click the sound icon on the upper-right corner of gnome-desktop, it
also showed the speaker rather than the headphone.
The root cause is that before suspend, the codec already call the
runtime_suspend since this codec is not used by any apps, then in
resume, it will not call runtime_resume for this codec. But for some
realtek codec (so far, alc236, alc255 and alc891) with the specific
BIOS, if it doesn't run runtime_resume after suspend, all codec
functions including jack detection stop working anymore.
This problem existed for a long time, but it was not exposed, that is
because when problem happens, if users play sound or open
sound-setting to check audio device, this will trigger calling to
runtime_resume (via snd_hda_power_up), then the codec starts working
again before users notice this problem.
Since we don't know how many codec and BIOS combinations have this
problem, to fix it, let the driver call runtime_resume for all codecs
in pm_resume, maybe for some codecs, this is not needed, but it is
harmless. After a codec is runtime resumed, if it is not used by any
apps, it will be runtime suspended soon and furthermore we don't run
suspend frequently, this change will not add much power consumption.
Fixes: cc72da7d4d06 ("ALSA: hda - Use standard runtime PM for codec power-save control")
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit 98081ca62cbac31fb0f7efaf90b2e7384ce22257 upstream.
Currently we deal with single codec and suspend codec callbacks for
all S3, S4 and runtime PM handling. But it turned out that we want
distinguish the call patterns sometimes, e.g. for applying some init
sequence only at probing and restoring from hibernate.
This patch slightly modifies the common PM callbacks for HD-audio
codec and stores the currently processed PM event in power_state of
the codec's device.power field, which is currently unused. The codec
callback can take a look at this event value and judges which purpose
it's being called.
commit 71492580571467fb7177aade19c18ce7486267f5 upstream.
Tetsuo Handa had reported he saw an incorrect "downgrading a read lock"
warning right after a previous lockdep warning. It is likely that the
previous warning turned off lock debugging causing the lockdep to have
inconsistency states leading to the lock downgrade warning.
Fix that by add a check for debug_locks at the beginning of
__lock_downgrade().
Debugged-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Reported-by: syzbot+53383ae265fb161ef488@syzkaller.appspotmail.com
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: https://lkml.kernel.org/r/1547093005-26085-1-git-send-email-longman@redhat.com
commit e20a2e9c42c9e4002d9e338d74e7819e88d77162 upstream.
When releasing socket, it is possible to enter hci_sock_release() and
hci_sock_dev_event(HCI_DEV_UNREG) at the same time in different thread.
The reference count of hdev should be decremented only once from one of
them but if storing hdev to local variable in hci_sock_release() before
detached from socket and setting to NULL in hci_sock_dev_event(),
hci_dev_put(hdev) is unexpectedly called twice. This is resolved by
referencing hdev from socket after bt_sock_unlink() in
hci_sock_release().
Reported-by: syzbot+fdc00003f4efff43bc5b@syzkaller.appspotmail.com
Signed-off-by: Myungho Jung <mhjungk@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit f45f3f753b0a3d739acda8e311b4f744d82dc52a upstream.
Control events can leak kernel memory since they do not fully zero the
event. The same code is present in both v4l2-ctrls.c and uvc_ctrl.c, so
fix both.
It appears that all other event code is properly zeroing the structure,
it's these two places.
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Reported-by: syzbot+4f021cf3697781dbd9fb@syzkaller.appspotmail.com
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
commit 674a2b27234d1b7afcb0a9162e81b2e53aeef217 upstream.
All indirect buffers get by ext4_find_shared() should be released no
mater the branch should be freed or not. But now, we forget to release
the lower depth indirect buffers when removing space from the same
higher depth indirect block. It will lead to buffer leak and futher
more, it may lead to quota information corruption when using old quota,
consider the following case.
- Create and mount an empty ext4 filesystem without extent and quota
features,
- quotacheck and enable the user & group quota,
- Create some files and write some data to them, and then punch hole
to some files of them, it may trigger the buffer leak problem
mentioned above.
- Disable quota and run quotacheck again, it will create two new
aquota files and write the checked quota information to them, which
probably may reuse the freed indirect block(the buffer and page
cache was not freed) as data block.
- Enable quota again, it will invoke
vfs_load_quota_inode()->invalidate_bdev() to try to clean unused
buffers and pagecache. Unfortunately, because of the buffer of quota
data block is still referenced, quota code cannot read the up to date
quota info from the device and lead to quota information corruption.
This problem can be reproduced by xfstests generic/231 on ext3 file
system or ext4 file system without extent and quota features.
This patch fix this problem by releasing the missing indirect buffers,
in ext4_ind_remove_space().
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@kernel.org
commit 372a03e01853f860560eade508794dd274e9b390 upstream.
Ext4 needs to serialize unaligned direct AIO because the zeroing of
partial blocks of two competing unaligned AIOs can result in data
corruption.
However it decides not to serialize if the potentially unaligned aio is
past i_size with the rationale that no pending writes are possible past
i_size. Unfortunately if the i_size is not block aligned and the second
unaligned write lands past i_size, but still into the same block, it has
the potential of corrupting the previous unaligned write to the same
block.
This is (very simplified) reproducer from Frank
// 41472 = (10 * 4096) + 512
// 37376 = 41472 - 4096
ftruncate(fd, 41472);
io_prep_pwrite(iocbs[0], fd, buf[0], 4096, 37376);
io_prep_pwrite(iocbs[1], fd, buf[1], 4096, 41472);
io_submit(io_ctx, 1, &iocbs[1]);
io_submit(io_ctx, 1, &iocbs[2]);
io_getevents(io_ctx, 2, 2, events, NULL);
Without this patch the 512B range from 40960 up to the start of the
second unaligned write (41472) is going to be zeroed overwriting the data
written by the first write. This is a data corruption.
00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00009200 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
0000a000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0000a200 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31
With this patch the data corruption is avoided because we will recognize
the unaligned_aio and wait for the unwritten extent conversion.
0000b200
Reported-by: Frank Sorenson <fsorenso@redhat.com>
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Fixes: e9e3bcecf44c ("ext4: serialize unaligned asynchronous DIO")
Cc: stable@vger.kernel.org
commit fa30dde38aa8628c73a6dded7cb0bba38c27b576 upstream.
We see the following NULL pointer dereference while running xfstests
generic/475:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
PGD 8000000c84bad067 P4D 8000000c84bad067 PUD c84e62067 PMD 0
Oops: 0000 [#1] SMP PTI
CPU: 7 PID: 9886 Comm: fsstress Kdump: loaded Not tainted 5.0.0-rc8 #10
RIP: 0010:ext4_do_update_inode+0x4ec/0x760
Call Trace:
? jbd2_journal_get_write_access+0x42/0x50
? __ext4_journal_get_write_access+0x2c/0x70
? ext4_truncate+0x186/0x3f0
ext4_mark_iloc_dirty+0x61/0x80
ext4_mark_inode_dirty+0x62/0x1b0
? unmap_mapping_pages+0x56/0x100
ext4_setattr+0x817/0x8b0
notify_change+0x1df/0x430
do_truncate+0x5e/0x90
? generic_permission+0x12b/0x1a0
This is triggered because the NULL pointer handle->h_transaction was
dereferenced in function ext4_update_inode_fsync_trans().
I found that the h_transaction was set to NULL in jbd2__journal_restart
but failed to attached to a new transaction while the journal is aborted.
Fix this by checking the handle before updating the inode.
Fixes: b436b9bef84d ("ext4: Wait for proper transaction commit on fsync")
Signed-off-by: Jiufei Xue <jiufei.xue@linux.alibaba.com>
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
commit 0c671812f152b628bd87c0af49da032cc2a2c319 upstream.
Objtool uses over 512k of stack, thanks to the hash table embedded in
the objtool_file struct. This causes an unnecessarily large stack
allocation and breaks users with low stack limits.
Move the struct off the stack.
Fixes: 042ba73fe7eb ("objtool: Add several performance improvements")
Reported-by: Vassili Karpov <moosotc@gmail.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/df92dcbc4b84b02ffa252f46876df125fb56e2d7.1552954176.git.jpoimboe@redhat.com
commit 5a07168d8d89b00fe1760120714378175b3ef992 upstream.
The futex code requires that the user space addresses of futexes are 32bit
aligned. sys_futex() checks this in futex_get_keys() but the robust list
code has no alignment check in place.
As a consequence the kernel crashes on architectures with strict alignment
requirements in handle_futex_death() when trying to cmpxchg() on an
unaligned futex address which was retrieved from the robust list.
[ tglx: Rewrote changelog, proper sizeof() based alignement check and add
comment ]
Fixes: 0771dfefc9e5 ("[PATCH] lightweight robust futexes: core")
Signed-off-by: Chen Jie <chenjie6@huawei.com>
Cc: <dvhart@infradead.org>
Cc: <peterz@infradead.org>
Cc: <zengweilin@huawei.com>
Link: https://lkml.kernel.org/r/1552621478-119787-1-git-send-email-chenjie6@huawei.com
commit 47c25036b60f27b86ab44b66a8861bcf81cde39b upstream.
Insert Branch instruction instead of NOP to make sure assembler don't
patch code in forbidden slot. In jump label function, it might
be possible to patch Control Transfer Instructions(CTIs) into
forbidden slot, which will generate Reserved Instruction exception
in MIPS release 6.
Signed-off-by: Archer Yan <ayan@wavecomp.com>
Reviewed-by: Paul Burton <paul.burton@mips.com>
[paul.burton@mips.com:
- Add MIPS prefix to subject.
- Mark for stable from v4.0, which introduced r6 support, onwards.]
Signed-off-by: Paul Burton <paul.burton@mips.com>
Cc: linux-mips@vger.kernel.org
Cc: stable@vger.kernel.org # v4.0+
commit 3f0a53bc6482fb09770982a8447981260ea258dc upstream.
This fixes booting with the combination of CONFIG_RELOCATABLE=y
and CONFIG_MIPS_ELF_APPENDED_DTB=y.
Sections that appear after the relocation table are not relocated
on system boot (except .bss, which has special handling).
With CONFIG_MIPS_ELF_APPENDED_DTB, the dtb is part of the
vmlinux ELF, so it must be relocated together with everything else.
Fixes: 069fd766271d ("MIPS: Reserve space for relocation table")
Signed-off-by: Yasha Cherikovsky <yasha.che3@gmail.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: James Hogan <jhogan@kernel.org>
Cc: linux-mips@linux-mips.org
Cc: stable@vger.kernel.org # v4.7+
commit 5f5f67da9781770df0403269bc57d7aae608fecd upstream.
Timekeeping IRQs from CS5536 MFGPT are routed to i8259, which then
triggers the "cascade" IRQ on MIPS CPU. Without IRQF_NO_SUSPEND in
cascade_irqaction, MFGPT interrupts will be masked in suspend mode,
and the machine would be unable to resume once suspended.
Previously, MIPS IRQs were not disabled properly, so the original
code appeared to work. Commit a3e6c1eff5 ("MIPS: IRQ: Fix disable_irq on
CPU IRQs") uncovers the bug. To fix it, add IRQF_NO_SUSPEND to
cascade_irqaction.
This commit is functionally identical to 0add9c2f1cff ("MIPS:
Loongson-3: Add IRQF_NO_SUSPEND to Cascade irqaction"), but it forgot
to apply the same fix to Loongson2.
Signed-off-by: Yifeng Li <tomli@tomli.me>
Cc: Jiaxun Yang <jiaxun.yang@flygoat.com>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: stable@vger.kernel.org # v3.19+
commit d3ca4651d05c0ff7259d087d8c949bcf3e14fb46 upstream.
When truncate(2) hits IO error when reading indirect extent block the
code just bugs with:
kernel BUG at linux-4.15.0/fs/udf/truncate.c:249!
Fix the problem by bailing out cleanly in case of IO error.
CC: stable@vger.kernel.org
Reported-by: jean-luc malet <jeanluc.malet@gmail.com>
commit bb229bbb3bf63d23128e851a1f3b85c083178fa1 upstream.
Because map updates are distributed lazily, an OSD may not know about
the new blacklist for quite some time after "osd blacklist add" command
is completed. This makes it possible for a blacklisted but still alive
client to overwrite a post-blacklist update, resulting in data
corruption.
Waiting for latest osdmap in ceph_monc_blacklist_add() and thus using
the post-blacklist epoch for all post-blacklist requests ensures that
all such requests "wait" for the blacklist to come into force on their
respective OSDs.
Fixes: 6305a3b41515 ("libceph: support for blacklisting clients")
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Jason Dillaman <dillaman@redhat.com>
