The size of the field that contains the description block count is
only four bits instead of eight bits.
The first four bits are reserved but this might change and break.
Introduce the MACHINE_IS_LPAR flag for code that should only be
executed if Linux is running in an LPAR.
Remove a memset hack that relied on the internal layout of the
qdio_irq struct and move the per device statistics data into an own
cache line to avoid cache line bashing between the inbound and the
outbound queue tasklets. Also reduce the number of allocated queues
from 32 to 4 which is the current maximum. That saves a cache line
in struct qdio_irq.
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
Add counters for the number of processed SBALs. The numbers summarize
how many SBALs were processed at each queue scan and indicate the
utilization of the queue. Furthermore the number of unsuccessfull
queue scans, SBAL errors and the total number of processed
SBALs are accounted.
Also regroup struct qdio_q to move read-mostly and write-mostly data
into different cachelines.
Rename signal_processor* functions to sigp*.
Add raw variants of each version, so we can get rid of the hacks played
in smp code which establish temporary cpu logical mappings so they could
call the sigp functions.
Always reboot on logical cpu 0. This makes sure that the IPL cpu is
always the same and usually avoids strange numbering schemes between
physical and logical cpus.
Rename __LC_RESTART_PSW to __LC_RST_NEW_PSW, add a define for the
missing 32 bit variant and the missing old PSWs.
Remove support to be able to dump 31 bit systems with a 64 bit dumper.
This is mostly useless since no distro ships 31 bit kernels together
We also get rid of a bit of hacky code.
Drop support to compile the kernel with gcc versions older than 3.3.3.
This allows us to use the "Q" inline assembly contraint on some more
inline assemblies without duplicating a lot of complex code (e.g. __xchg
and __cmpxchg). The distinction for older gcc versions can be removed
which saves a few lines and simplifies the code.
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Some parts of cio do not shift PAGE_DEFAULT_KEY correctly and end up
with an incorrect key in their data structures.
Since the default key is zero this doesn't really matter. However if
somebody would use key-controlled protection for debugging purposes
it would be quite helpful if all of this would work as expected.
Also remove a stale declaration.
ccw_device_pm_restore: trigger subchannel event to better handle
changes to the subchannel device.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Callers of ccw_device_notify could not distinguish between a driver
who has no notifier registered and a driver who doesn't want to keep
a device after a certain event. Change this by adding proper return
codes.
Make the potentially long blocking wait_event's used by the cio
settle mechanism interruptible.
To fetch a pending channel report word (crw) we use a kernel
thread which triggers stcrw and sleeps on a semaphore. The s390
machine check handler uses crw_handle_channel_report to handle
one crw if needed.
This patch replaces the semaphore with a waitqueue (to block the
kernel thread) and an atomic_t (to count the number of pending
requests).
By this we achieve the ability to force this thread to check for
a pending crw (independent on when it is triggered by the machine
check handler) and wait for this action to finish.
This patch introduces a proc file cio_settle. A write request to
this file is blocked until all queued cio actions are handled.
This will allow userspace to wait for pending work affecting
device availability after changing cio_ignore or the hardware
configuration.
We used to maintain 2 singlethreaded workqueues for synchronization
and to trigger work from interrupt context. Since our latest cio
changes we only use one of these workqueues. So get rid of the
unused workqueue, rename the remaining one to "cio_work_q" and move
its ownership to the channel subsystem driver.
cu3088 layer for lcs and ctcm has been removed. Thus the reference
to cu3088 in this text is to be removed as well.
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
Same as on x86 and sparc, besides the fact that enabling the option
will just emit compile time warnings instead of errors.
Keeps allyesconfig kernels compiling.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (48 commits)
x86/PCI: Prevent mmconfig memory corruption
ACPI: Use GPE reference counting to support shared GPEs
x86/PCI: use host bridge _CRS info by default on 2008 and newer machines
PCI: augment bus resource table with a list
PCI: add pci_bus_for_each_resource(), remove direct bus->resource[] refs
PCI: read bridge windows before filling in subtractive decode resources
PCI: split up pci_read_bridge_bases()
PCIe PME: use pci_pcie_cap()
PCI PM: Run-time callbacks for PCI bus type
PCIe PME: use pci_is_pcie()
PCI / ACPI / PM: Platform support for PCI PME wake-up
ACPI / ACPICA: Multiple system notify handlers per device
ACPI / PM: Add more run-time wake-up fields
PCI PM: Make it possible to force using INTx for PCIe PME signaling
PCI PM: PCIe PME root port service driver
PCI PM: Add function for checking PME status of devices
PCI: mark is_pcie obsolete
PCI: set PCI_PREF_RANGE_TYPE_64 in pci_bridge_check_ranges
PCI: pciehp: second try to get big range for pcie devices
The five-second delay can be rather annoying, and makes the system
appear much less responsive when you connect a USB drive.
It's also not entirely clear that it is needed - the settling delay has
at least historically been an issue on some Apple iPods, for example,
and some devices have been reported to need even more than the old 5s
delay.
But before we penalize them all, let's see how bad it really is. Some
of the reasons for long delays seem to be actual historical kernel bugs
that should probably never have been papered over with a delay in the
first place (there's a Ubuntu bug report for 2.6.20 about a NULL pointer
dereference unless 'delay_use' is 8 or more, for example).
It also looks like some distros have already shipped with delay_use=0,
so the five second default may well be totally historical.
In other words: "Let's see if anybody screams".
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (41 commits)
of: remove undefined request_OF_resource & release_OF_resource
of/sparc: Remove sparc-local declaration of allnodes and devtree_lock
of: move definition of of_chosen into common code.
of: remove unused extern reference to devtree_lock
of: put default string compare and #a/s-cell values into common header
of/flattree: Don't assume HAVE_LMB
of: protect linux/of.h with CONFIG_OF
proc_devtree: fix THIS_MODULE without module.h
of: Remove old and misplaced function declarations
of/flattree: Make the kernel accept ePAPR style phandle information
of/flattree: endian-convert members of boot_param_header
of: assume big-endian properties, adding conversions where necessary
of: use __be32 for cell value accessors
of/flattree: use OF_ROOT_NODE_{SIZE,ADDR}_CELLS DEFAULT for fdt parsing
of/flattree: use callback to setup initrd from /chosen
proc_devtree: include linux/of.h
of: make set_node_proc_entry private to proc_devtree.c
of: include linux/proc_fs.h
of/flattree: merge early_init_dt_scan_memory() common code
of: add 'of_' prefix to machine_is_compatible()
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (31 commits)
spi: Correct SPI clock frequency setting in spi_mpc8xxx
spi/spi_s3c64xx.c: Fix continuation line formats
spi/dw_spi: Fix dw_spi_mmio to depend on HAVE_CLK
spi/dw_spi: Allow dw_spi.c to be a module
spi/dw_spi: mmio code style fixups
Memory-mapped dw_spi driver
spi/dw_spi: fix missing export of dw_spi_remove_host
spi/dw_spi: conditional transfer mode changes
spi/dw_spi: remove conditional from 'poll_transfer'.
spi/dw_spi: fixed a spelling typo in a warning message.
spi/dw_spi: add return value to empty mrst_spi_debugfs_init()
spi/dw_spi: enable platform specific chipselect.
spi/dw_spi: add a FIFO depth detection
spi/dw_spi: fix __init/__devinit section mismatch
spi: xilinx_spi: Fix up I/O routine wrapping bogosity.
spi/spi_imx: add device information by switching pr_debug() to dev_dbg()
spi: update MSIOF includes
spi/dw_spi: refine the IRQ mode working flow
spi/dw_spi: add a missed dw_spi_remove_host() in exit sequence
spi/dw_spi: bug fix in wait_till_not_busy()
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig:
kconfig: Simplify LSMOD= handling
kconfig: Add LSMOD=file to override the lsmod for localmodconfig
kconfig: Look in both /bin and /sbin for lsmod in streamline_config.pl
kconfig: Check for if conditions in Kconfig for localmodconfig
kconfig: Create include/generated for localmodconfig
* 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig:
kconfig: simplification of scripts/extract-ikconfig
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (41 commits)
HID: usbhid: initialize interface pointers early enough
HID: extend mask for BUTTON usage page
HID: hid-ntrig: Single touch mode tap
HID: hid-ntrig: multitouch cleanup and fix
HID: n-trig: remove unnecessary tool switching
HID: hid-ntrig add multi input quirk and clean up
HID: usbhid: introduce timeout for stuck ctrl/out URBs
HID: magicmouse: coding style and probe failure fixes
HID: remove MODULE_VERSION from new drivers
HID: fix up Kconfig entry for MagicMouse
HID: add a device driver for the Apple Magic Mouse.
HID: Export hid_register_report
HID: Support for MosArt multitouch panel
HID: add pressure support for the Stantum multitouch panel
HID: fixed bug in single-touch emulation on the stantum panel
HID: fix typo in error message
HID: add mapping for "AL Network Chat" usage
HID: use multi input quirk for TouchPack touchscreen
HID: make full-fledged hid-bus drivers properly selectable
HID: make Wacom modesetting failures non-fatal
'apple_magic_mouse' into for-linus
drivers/hid/Kconfig
commit ff097ddd4 (x86/PCI: MMCONFIG: manage pci_mmcfg_region as a
list, not a table) introduced a nasty memory corruption when
pci_mmcfg_list is empty.
pci_mmcfg_check_end_bus_number() dereferences pci_mmcfg_list.prev even
when the list is empty. The following write hits some variable near to
pci_mmcfg_list.
Further down a similar problem exists, where cfg->list.next is
dereferenced unconditionally and a comparison with some variable near
to pci_mmcfg_list happens.
Add a check for the last element into the for_each_entry() loop and
remove all the other crappy logic which is just a leftover of the old
array based code which was replaced by the list conversion.
Reported-by: Ingo Molnar <mingo@elte.hu>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: stable@kernel.org
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (44 commits)
Add MAINTAINERS entry for virtio_console
virtio: console: Fill ports' entire in_vq with buffers
virtio: console: Error out if we can't allocate buffers for control queue
virtio: console: Add ability to remove module
virtio: console: Ensure no memleaks in case of unused buffers
virtio: console: show error message if hvc_alloc fails for console ports
virtio: console: Add debugfs files for each port to expose debug info
virtio: console: Add ability to hot-unplug ports
virtio: console: Handle port hot-plug
virtio: console: Remove cached data on port close
virtio: console: Register with sysfs and create a 'name' attribute for ports
virtio: console: Ensure only one process can have a port open at a time
virtio: console: Add file operations to ports for open/read/write/poll
virtio: console: Associate each port with a char device
virtio: console: Prepare for writing to userspace buffers
virtio: console: Add a new MULTIPORT feature, support for generic ports
virtio: console: Introduce a send_buf function for a common path for sending data to host
virtio: console: Introduce function to hand off data from host to readers
virtio: console: Separate out find_vqs operation into a different function
virtio: console: Separate out console init into a new function
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
netlabel: fix export of SELinux categories > 127
This fixes corrupted CIPSO packets when SELinux categories greater than 127
are used. The bug occured on the second (and later) loops through the
while; the inner for loop through the ebitmap->maps array used the same
index as the NetLabel catmap->bitmap array, even though the NetLabel bitmap
is twice as long as the SELinux bitmap.
Signed-off-by: Joshua Roys <joshua.roys@gtri.gatech.edu>
Acked-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: James Morris <jmorris@namei.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
ahci: disable FPDMA auto-activate optimization on NVIDIA AHCI
Mike Cui reported that his system with an NVIDIA MCP79 (aka MCP7A)
chipset stopped working with 2.6.32. The problem appears to be that
2.6.32 now enables the FPDMA auto-activate optimization in the ahci
driver. The drive works fine with this enabled on an Intel AHCI so
this appears to be a chipset bug. Since MCP79 is a fairly recent
NVIDIA chipset and we don't have any info on whether any other NVIDIA
chipsets have this issue, disable FPDMA AA optimization on all NVIDIA
AHCI controllers for now.
Should address http://bugzilla.kernel.org/show_bug.cgi?id=14922
Signed-off-by: Robert Hancock <hancockrwd@gmail.com>
While-we-investigate-issue-this-patch-looks-good-to-me-by:
Prajakta Gudadhe <pgudadhe@nvidia.com>
To fix a bug and address the reviewers' comments regarding the ACPI
GPE refcounting patch, do the following additional changes:
o Remove the second argument of acpi_ev_enable_gpe(),
'write_to_hardware', because it is not necessary any more.
o Add the "bad parameter" test against 'type' in
acpi_enable_gpe() and acpi_disable_gpe().
o Make acpi_enable_gpe() only check 'status' for runtime GPEs if
acpi_ev_enable_gpe() was actually called.
o Make acpi_disable_gpe() return 'status' returned by
acpi_ev_disable_gpe() and fix a bug where ACPI_GPE_TYPE_WAKE
and ACPI_GPE_TYPE_RUNTIME were exchanged by mistake.
o Add comments explaining why acpi_set_gpe() is used by the ACPI EC
driver.
If radix_tree_preload is failed in ima_inode_alloc, we don't need
radix_tree_preload_end because kernel is alread preempt enabled
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6
* 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
parisc: Set PCI CLS early in boot.
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Fix broken sn2 build
Set the PCI CLS early in the boot process to prevent
device failures. In pcibios_set_master use the new
pci_cache_line_size instead of a hard-coded value.
Signed-off-by: Carlos O'Donell <carlos@codesourcery.com>
Reviewed-by: Grant Grundler <grundler@google.com>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Fix out_le32() macro
microblaze: Fix cache loop function for cache range
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
Revert "block: improve queue_should_plug() by looking at IO depths"
Trailing semicolon causes compilation involving out_le32() to fail.
Signed-off-by: Steven J. Magnani <steve@digidescorp.com>
I create wrong asm code but none test shows that this part of code is wrong.
I am not convinces that were good idea to create asm optimized macros
for caches. The reason is that there is not optimization with previous code
that's why make sense to add old code and do some benchmarking which
functions are faster.
I'm taking ownership of the virtio_console module; but I'll continue
feeding patches via Rusty.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
Instead of allocating just one buffer for a port's in_vq, fill
the entire in_vq with buffers so the host need not stall while
an application consumes the data and makes the buffer available
again for the host.
With MULTIPORT support, the control queue is an integral part of the
functioning of the device. If we can't get any buffers allocated, the
host won't be able to relay important information and the device may not
function as intended.
Ensure 'probe' doesn't succeed until the control queue has at least one
buffer allocated for its ivq.
Add the ability to remove the virtio_console module.
This aids debugging.
If unused data exists in in_vq, ensure we flush that first and then
detach unused buffers, which will ensure all buffers from the in_vq are
removed.
Also ensure we free the buffers after detaching them.
This is helpful in examining ports' state.
Remove port data; deregister from the hvc core if it's a console port.
