Currently we are inconsistent in when we decide to run the queue. Using
blk_mq_run_hw_queues() we check if the hctx has pending IO before
running it, but we don't do that from the individual queue run function,
blk_mq_run_hw_queue(). This results in a lot of extra and pointless
queue runs, potentially, on flush requests and (much worse) on tag
starvation situations. This is observable just looking at top output,
with lots of kworkers active. For the !async runs, it just adds to the
CPU overhead of blk-mq.
Move the has-pending check into the run function instead of having
callers do it.
It is possible that the pointer disk can be null and hence
we can get a null pointer deference when accessing disk->flags.
Add a null pointer check to avoid the dereference.
Detected by CoverityScan, CID#1461133 ("Explicit null dereferenced")
Fixes: 8ddcd653257c ("block: introduce GENHD_FL_HIDDEN")
guard_bio_eod() needs to look at the partition capacity, not just the
capacity of the whole device, when determining if truncation is
necessary.
[ 60.268688] attempt to access beyond end of device
[ 60.268690] unknown-block(9,1): rw=0, want=67103509, limit=67103506
[ 60.268693] buffer_io_error: 2 callbacks suppressed
[ 60.268696] Buffer I/O error on dev md1p7, logical block 4524305, async page read
Fixes: 74d46992e0d9 ("block: replace bi_bdev with a gendisk pointer and partitions index")
Cc: stable@vger.kernel.org # v4.13
Signed-off-by: Greg Edwards <gedwards@ddn.com>
Fixes: d004a5e7d4dd ("block: remove __bio_kmap_atomic")
We should be exposing the subsystem attributes like 'model' and
'subsysnqn' to sysfs to allow for easier identification of the
subsystem.
Signed-off-by: Hannes Reinecke <hare@suse.com>
When creating nvme multipath devices we should populate the 'slaves' and
'holders' directorys properly to aid userspace topology detection.
[hch: split from a larger patch, compile fix for CONFIG_NVME_MULTIPATH=n]
Reviewed-by: Keith Busch <keith.busch@intel.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
[hch: split from a larger patch]
We do this by adding a helper that returns the ns_head for a device that
can belong to either the per-controller or per-subsystem block device
nodes, and otherwise reuse all the existing code.
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
This patch adds native multipath support to the nvme driver. For each
namespace we create only single block device node, which can be used
to access that namespace through any of the controllers that refer to it.
The gendisk for each controllers path to the name space still exists
inside the kernel, but is hidden from userspace. The character device
nodes are still available on a per-controller basis. A new link from
the sysfs directory for the subsystem allows to find all controllers
for a given subsystem.
Currently we will always send I/O to the first available path, this will
be changed once the NVMe Asynchronous Namespace Access (ANA) TP is
ratified and implemented, at which point we will look at the ANA state
for each namespace. Another possibility that was prototyped is to
use the path that is closes to the submitting NUMA code, which will be
mostly interesting for PCI, but might also be useful for RDMA or FC
transports in the future. There is not plan to implement round robin
or I/O service time path selectors, as those are not scalable with
the performance rates provided by NVMe.
The multipath device will go away once all paths to it disappear,
any delay to keep it alive needs to be implemented at the controller
level.
Introduce a new struct nvme_ns_head that holds information about an actual
namespace, unlike struct nvme_ns, which only holds the per-controller
namespace information. For private namespaces there is a 1:1 relation of
the two, but for shared namespaces this lets us discover all the paths to
it. For now only the identifiers are moved to the new structure, but most
of the information in struct nvme_ns should eventually move over.
To allow lockless path lookup the list of nvme_ns structures per
nvme_ns_head is protected by SRCU, which requires freeing the nvme_ns
structure through call_srcu.
Reviewed-by: Javier González <javier@cnexlabs.com>
This allows us to manage the various uniqueue namespace identifiers
together instead needing various variables and arguments.
This adds a new nvme_subsystem structure so that we can track multiple
controllers that belong to a single subsystem. For now we only use it
to store the NQN, and to check that we don't have duplicate NQNs unless
the involved subsystems support multiple controllers.
Includes code originally from Hannes Reinecke to expose the subsystems
in sysfs.
Several block layer and NVMe core functions accept a combination
of BLK_MQ_REQ_* flags through the 'flags' argument but there is
no verification at compile time whether the right type of block
layer flags is passed. Make it possible for sparse to verify this.
This patch does not change any functionality.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Tested-by: Oleksandr Natalenko <oleksandr@natalenko.name>
Cc: linux-nvme@lists.infradead.org
Cc: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Ming Lei <ming.lei@redhat.com>
The contexts from which a SCSI device can be quiesced or resumed are:
* Writing into /sys/class/scsi_device/*/device/state.
* SCSI parallel (SPI) domain validation.
* The SCSI device power management methods. See also scsi_bus_pm_ops.
It is essential during suspend and resume that neither the filesystem
state nor the filesystem metadata in RAM changes. This is why while
the hibernation image is being written or restored that SCSI devices
are quiesced. The SCSI core quiesces devices through scsi_device_quiesce()
and scsi_device_resume(). In the SDEV_QUIESCE state execution of
non-preempt requests is deferred. This is realized by returning
BLKPREP_DEFER from inside scsi_prep_state_check() for quiesced SCSI
devices. Avoid that a full queue prevents power management requests
to be submitted by deferring allocation of non-preempt requests for
devices in the quiesced state. This patch has been tested by running
the following commands and by verifying that after each resume the
fio job was still running:
for ((i=0; i<10; i++)); do
cd /sys/block/md0/md &&
while true; do
[ "$(<sync_action)" = "idle" ] && echo check > sync_action
sleep 1
done
pids=($!)
for d in /sys/class/block/sd*[a-z]; do
bdev=${d#/sys/class/block/}
hcil=$(readlink "$d/device")
hcil=${hcil#../../../}
echo 4 > "$d/queue/nr_requests"
echo 1 > "/sys/class/scsi_device/$hcil/device/queue_depth"
fio --name="$bdev" --filename="/dev/$bdev" --buffered=0 --bs=512 \
--rw=randread --ioengine=libaio --numjobs=4 --iodepth=16 \
--iodepth_batch=1 --thread --loops=$((2**31)) &
pids+=($!)
done
sleep 1
echo "$(date) Hibernating ..." >>hibernate-test-log.txt
systemctl hibernate
sleep 10
kill "${pids[@]}"
echo idle > /sys/block/md0/md/sync_action
wait
echo "$(date) Done." >>hibernate-test-log.txt
done
Reported-by: Oleksandr Natalenko <oleksandr@natalenko.name>
References: "I/O hangs after resuming from suspend-to-ram" (https://marc.info/?l=linux-block&m=150340235201348).
Tested-by: Martin Steigerwald <martin@lichtvoll.de>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
This flag will be used in the next patch to let the block layer
core know whether or not a SCSI request queue has been quiesced.
A quiesced SCSI queue namely only processes RQF_PREEMPT requests.
requests
Convert blk_get_request(q, op, __GFP_RECLAIM) into
blk_get_request_flags(q, op, BLK_MQ_PREEMPT). This patch does not
Acked-by: David S. Miller <davem@davemloft.net> [ for IDE ]
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Set RQF_PREEMPT if BLK_MQ_REQ_PREEMPT is passed to
blk_get_request_flags().
A side effect of this patch is that the GFP mask that is passed to
several allocation functions in the legacy block layer is changed
from GFP_KERNEL into __GFP_DIRECT_RECLAIM.
This patch makes it possible to pause request allocation for
the legacy block layer by calling blk_mq_freeze_queue() and
blk_mq_unfreeze_queue().
Signed-off-by: Ming Lei <ming.lei@redhat.com>
[ bvanassche: Combined two patches into one, edited a comment and made sure
REQ_NOWAIT is handled properly in blk_old_get_request() ]
This patch attempts to make the case of hctx re-running on driver tag
failure more robust. Without this patch, it's pretty easy to trigger a
stall condition with shared tags. An example is using null_blk like
this:
modprobe null_blk queue_mode=2 nr_devices=4 shared_tags=1 submit_queues=1 hw_queue_depth=1
which sets up 4 devices, sharing the same tag set with a depth of 1.
Running a fio job ala:
[global]
bs=4k
rw=randread
norandommap
direct=1
ioengine=libaio
iodepth=4
[nullb0]
filename=/dev/nullb0
[nullb1]
filename=/dev/nullb1
[nullb2]
filename=/dev/nullb2
[nullb3]
filename=/dev/nullb3
will inevitably end with one or more threads being stuck waiting for a
scheduler tag. That IO is then stuck forever, until someone else
triggers a run of the queue.
Ensure that we always re-run the hardware queue, if the driver tag we
were waiting for got freed before we added our leftover request entries
back on the dispatch list.
Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com>
Tested-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Reviewed-by: Omar Sandoval <osandov@fb.com>
Much easier to just opencode this helper. Also use ARRAY_SIZE instead of
passing the inline bvec array size manually.
Reviewed-by: Sagi Grimberg <sagi@rimberg.me>
Currently the NVMe target stores the expexted data length in req->data_len
and uses that for data transfer decisions, but that does not take the
actual transfer length in the SGLs into account. So this adds a new
transfer_len field, into which the transport drivers store the actual
transfer length. We then check the two match before actually executing
the command.
The FC transport driver already had such a field, which is removed in
favour of the common one.
The 'remove_work' may be scheduled to run after nvme_remove()
returns since we can't simply cancel it in nvme_remove() for
avoiding deadlock. Once nvme_remove() returns, this module(nvme)
can be unloaded.
On the other hand, nvme_put_ctrl() calls ctr->ops->free_ctrl
which may point to nvme_pci_free_ctrl() in unloaded module.
This patch avoids this issue by queuing 'remove_work' via 'nvme_wq',
and flush this worqueue in nvme_exit() as suggested by Sagi.
Suggested-by: Sagi Grimberg <sagi@grimberg.me>
This will give udev a chance to observe and handle asynchronous event
notifications and clear the log to unmask future events of the same type.
The driver will create a change uevent of the asyncronuos event result
before submitting the next AEN request to the device if a completed AEN
event is of type error, smart, command set or vendor specific,
Signed-off-by: Keith Busch <keith.busch@intel.com>
Reviewed-by: Guan Junxiong <guanjunxiong@huawei.com>
Async event work is for core use only and should not be called directly
from drivers.
The driver can handle tracking only one AEN request, so this patch
removes handling for multiple ones.
Reviewed-by: James Smart <james.smart@broadcom.com>
This was being saved in a structure, but never used anywhere. The queue
size is obtained through other means, so there's no reason to duplicate
this without a user for it.
All the transports were unnecessarilly duplicating the AEN request
accounting. This patch defines everything in one place.
the status is either success or some status id and
we don't need a local variable for it.
Signed-off-by: Sagi Grimberg <sagi@grimberg.me>
We already allocated the buffer with kzalloc.
Avoid that removal of a request queue sporadically triggers the
following warning:
list_del corruption. next->prev should be ffff8807d649b970, but was 6b6b6b6b6b6b6b6b
WARNING: CPU: 3 PID: 342 at lib/list_debug.c:56 __list_del_entry_valid+0x92/0xa0
Call Trace:
process_one_work+0x11b/0x660
worker_thread+0x3d/0x3b0
kthread+0x129/0x140
ret_from_fork+0x27/0x40
Cc: Hannes Reinecke <hare@suse.com>
Fix print formatting, but keep the original output to prevent user
breakage as suggested by Joe Perches.
Signed-off-by: Javier González <javier@cnexlabs.com>
Copy subnqns using NVMF_NQN_SIZE as it is < 256
We have to put the driver tag if dispatch budget can't be got, otherwise
it might cause IO deadlock, especially in case that size of tags is very
small.
Fixes: de1482974080(blk-mq: introduce .get_budget and .put_budget in blk_mq_ops)
Use the obvious calling convention.
This helper doesn't buy us much over calling kmap_atomic directly.
In fact in the only caller it does a bit of useless work as the
caller already has the bvec at hand, and said caller would even
buggy for a multi-segment bio due to the use of this helper.
So just remove it.
There are no users of it anymore.
This reverts commit 358a3a6bccb74da9d63a26b2dd5f09f1e9970e0b.
We have cases that aren't covered 100% in the drivers, so for now
we have to retain the shared tag restart loops.
kthread() could bail out early before we initialize blkcg_css (if the
kthread is killed very early. Please see xchg() statement in kthread()),
which confuses free_kthread_struct. Instead of moving the blkcg_css
initialization early, we simply zero the whole 'self' data structure,
which doesn't sound much overhead.
Reported-by: syzbot <syzkaller@googlegroups.com>
Fixes: 05e3db95ebfc ("kthread: add a mechanism to store cgroup info")
Cc: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Shaohua Li <shli@fb.com>
small typos fixed in admin-cmd.c
Signed-off-by: Minwoo Im <minwoo.im.dev@gmail.com>
Reviewed-by: Max Gurtovoy <maxg@mellanox.com>
QP object is created using rdma_cm api, therefore the destruction
should use the same api for symmetry.
Signed-off-by: Max Gurtovoy <maxg@mellanox.com>
A NULL deref happens when nvmet_rdma_remove_one() is called more than once
(e.g. while connected via 2 ports).
The first call frees the queues related to the first ib_device but
doesn't remove them from the queue list.
While calling nvmet_rdma_remove_one() for the second ib_device it goes over
the full queue list again and we get the NULL deref.
Fixes: f1d4ef7d ("nvmet-rdma: register ib_client to not deadlock in device removal")
Signed-off-by: Israel Rukshin <israelr@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grmberg.me>
This patch calls the new nvme transport routine for dev_loss_tmo
whenever the SCSI fc transport calls the lldd to make a dynamic
change to a remote ports dev_loss_tmo.
Signed-off-by: James Smart <james.smart@broadcom.com>
In the lldd api, a lldd may unregister a remoteport (loss of connectivity
or driver unload) or localport (driver unload). The lldd must wait for the
remoteport_delete or localport_delete before completing its actions post
the unregister. The xxx_deletes currently occur only when the xxxport
structure is fully freed after all references are removed. Thus the lldd
may be held hostage until an app or in-kernel entity that has a namespace
open finally closes so the namespace can be removed, the controller
removed, thus the transport objects, thus the lldd.
This patch decouples the transport and os-facing objects from the lldd
and the remoteport and localport. There is a point in all deletions
where the transport will no longer interact with the lldd on behalf of
a controller. That point centers around the association established
with the target/subsystem. It will access the lldd whenever it attempts
to create an association and while the association is active. New
associations may only be created if the remoteport is live (thus the
localport is live). It will not access the lldd after deleting the
association.
Therefore, the patch tracks the count of active controllers - those with
associations being created or that are active - on a remoteport. It also
tracks the number of remoteports that have active controllers, on a
a localport. When a remoteport is unregistered, as soon as there are no
active controllers, the lldd's remoteport_delete may be called and the
lldd may continue. Similarly, when a localport is unregistered, as soon
as there are no remoteports with active controllers, the localport_delete
callback may be made. This significantly speeds up unregistration with
the lldd.
The transport objects continue in suspended status with reconnect timers
running, and upon expiration, normal ref-counting will occur and the
objects will be freed. The transport object may still be held hostage
by the application/kernel module, but that is acceptable.
With this change, the lldd may be fully unloaded and reloaded, and
if registrations occur prior to the timeouts, the nvme controller and
namespaces will resume normally as if a link bounce.
The localport resume was not updating the lldd ops structure. If the
lldd is unloaded and reloaded, the ops pointers will differ.
Additionally, as there are device references taken by the localport,
ensure that resume only resumes if the device matches as well.
The NVMe standard provides a command effects log page so the host may
be aware of special requirements it may need to do for a particular
command. For example, the command may need to run with IO quiesced to
prevent timeouts or undefined behavior, or it may change the logical block
formats that determine how the host needs to construct future commands.
This patch saves the nvme command effects log page if the controller
supports it, and performs appropriate actions before and after an admin
passthrough command is completed. If the controller does not support the
command effects log page, the driver will define the effects for known
opcodes. The nvme format and santize are the only commands in this patch
with known effects.
And fix the warning on a successful firmware log.
Update the check in nvme_setup_rw for missing metadata so that it is
together with the other metadata handling, does not contain impossible
to reach conditions and warns if we get an impossible requests for
a (non-PI) metadata-enabled namespace when CONFIG_BLK_DEV_INTEGRITY
is not set.
Also add a little helper that checks if a given metadata configuration
contains protection information
Reported-by: Javier González <jg@lightnvm.io>
Split out the code that applies the calculate value to a given disk/queue
into new helper that can be reused by the multipath code.
We don't need a frozen queue to update the chunk_size, which just is a
hint, and moving it a little earlier will allow for some better code
reuse with the multipath code.
