Some registers were not initialized in init, this causes them to be
uninitialized after suspend.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Commit dceef5d87 (drm/nouveau/fb: initialise vram controller as pfb
sub-object) moved some code around and introduced these null derefs.
pfb->ram is set to the new ram object outside of this ctor.
Reported-by: Ronald Uitermark <ronald645@gmail.com>
Tested-by: Ronald Uitermark <ronald645@gmail.com>
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Fixes some dmabuf object errors on nv50 chipset and below.
Cc: stable@vger.kernel.org [3.7+]
Never used to be required, but a recent change made it necessary.
Reported-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Looks like the rewrite in commit ebb945a94b ("drm/nouveau: port all
engines to new engine module format") missed that one little detail.
Op 24-07-13 17:55, Dan Carpenter schreef:
> Hello Maarten Lankhorst,
> This is a semi-automatic email about new static checker warnings.
> The patch 0108bc808107: "drm/nouveau: do not allow negative sizes for
> now" from Jul 7, 2013, leads to the following Smatch complaint:
> drivers/gpu/drm/nouveau/nouveau_bo.c:222 nouveau_bo_new()
> warn: variable dereferenced before check 'drm->client.base.vm' (see line 201)
> 200 int type = ttm_bo_type_device;
> 201 int max_size = INT_MAX & ~((1 << drm->client.base.vm->vmm->lpg_shift) - 1);
> New dereference.
> 202
> 203 if (size <= 0 || size > max_size) {
> 204 nv_warn(drm, "skipped size %x\n", (u32)size);
> 205 return -EINVAL;
> 206 }
> 207
> 208 if (sg)
> 209 type = ttm_bo_type_sg;
> 210
> 211 nvbo = kzalloc(sizeof(struct nouveau_bo), GFP_KERNEL);
> 212 if (!nvbo)
> 213 return -ENOMEM;
> 214 INIT_LIST_HEAD(&nvbo->head);
> 215 INIT_LIST_HEAD(&nvbo->entry);
> 216 INIT_LIST_HEAD(&nvbo->vma_list);
> 217 nvbo->tile_mode = tile_mode;
> 218 nvbo->tile_flags = tile_flags;
> 219 nvbo->bo.bdev = &drm->ttm.bdev;
> 220
> 221 nvbo->page_shift = 12;
> 222 if (drm->client.base.vm) {
> Old check.
> 223 if (!(flags & TTM_PL_FLAG_TT) && size > 256 * 1024)
> 224 nvbo->page_shift = drm->client.base.vm->vmm->lpg_shift;
> regards,
> dan carpenter
8<-----
Commit 0108bc808107: "drm/nouveau: do not allow negative sizes for now" broke
older nvidia gpu's that lack a vm. Add an explicit check to handle this.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Reported-by: konrad wilk <konrad.wilk@oracle.com>
Unused and irrelavant since the code move of DP training/linkcontrol interrupt
Signed-off-by: Emil Velikov <emil.l.velikov@gmail.com>
Commits 0a9e2b959 (drm/nvd0/disp: move HDA codec setup to core) and
a4feaf4ea (drm/nva3/disp: move hda codec handling to core) moved code
around but neglected to fill data up to 0x60 as before. This caused
/proc/asound/cardN/eld#3.0 to show eld_valid as 0. With this patch, that
file is again populated with the correct data.
See https://bugs.freedesktop.org/show_bug.cgi?id=67051
Reported-and-tested-by: Alex <alupu01@gmail.com>
object->engine is null, which leads to a null deref down the line
Fixes vgaswitcheroo on a card without display.
Since the original merge of nouveau to upstream kernel, we were assuming
that nv90 (and later) cards have 32 lines.
Based on mmio traces of the binary driver, as well as PBUS error messages
during read/write of the e070/e074 registers, we can conclude that nv92
has only 16 lines whereas nv94 (and later) cards have 32.
Reported-and-tested-by: David M. Lloyd <david.lloyd@redhat.com>
Cc: dri-devel@lists.freedesktop.org
Cc: Ben Skeggs <bskeggs@redhat.com>
Kernel panic caused by list corruption in ltcg seems to indicate a
concurrency issue.
Take mutex of pfb like nv50_ram_put() to eliminate concurrency.
V2: Separate critical section into separate function, avoid taking the
lock twice on NVC0
Signed-off-by: Roy Spliet <r.spliet@student.tudelft.nl>
The current logic is wrong since we send fw->size >> 8 to the
card. Rounding the size up by 0x100 and 0x1000 didn't seem to help,
the card still hung, so go back to what the blob does -- 0x40000.
The API allows up to 64-bits allocations, but size is handled as int
inside nouveau almost everywhere. Until this is fixed it's better to
prevent negative sizes.
The 256 kB before INT_MAX is paranoia, because of the large page
aligning below that could flip it above INT_MAX.
This prevents 100% cpu usage on fermi cards when the exit interrupt
from the secret scrubber is not acked.
The moves themselves were generally async to graphics previously, with
the exception that if the "main" channel is used to synchronise a
page flip at the same time, it can end up blocked for a noticable amount
of time for large buffer moves.
Not really critical, and there's better ways of handling this, but they
are all rather invasive, so this is fine for now.
Based on a patch by Maarten Lankhorst addressing the same issue.
Acked-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
calim didn't like 150 seconds timeout, so lower the timeout for him.
15 seconds should still be plenty.
This should no longer be required, and is harmful for framebuffer pinning.
Also add a warning if unpin causes the pin count to drop below 0.
Weren't critical previously, the buffers would go away anyway. But with
recent changes to core drm/ttm lockdep will get pissed off now, so let's
fix it.
b580c9e2b7ba5030a795aa2fb73b796523d65a78 introduced additional problems
while trying to solve issues that became apparent while porting to the
new reservation stuff.
The major problem was that the the previously mentioned patch took the
client mutex earlier than previously, but the pinning of new_bo can
can potentially cause a buffer move, which would result in attempting to
acquire the same mutex again.
This commit attempts to fix that "fix".
Thanks to Maarten for the tips on keeping lockdep happy and cooking :)
"drm/nve0-/gr: some new gpc registers can have multiple copies"
5ee86c4190f9e caused a regression for nvc0, because the bit indicating last
transfer has occured was no longer set, resulting in random system lockups.
This is the nva3 counterpart to commit beba44b17 (drm/nv84/disp: Fix
HDMI audio regression). The regression happened as a result of
refactoring in commit 8e9e3d2de (drm/nv84/disp: move hdmi control into
core).
Reported-and-tested-by: Max Baldwin <archerseven@gmail.com>
The commit
commit 476e84e126171d809f9c0b5d97137f5055f95ca8
Author: Ben Skeggs <bskeggs@redhat.com>
Date: Mon Feb 11 09:24:23 2013 +1000
drm/nv50-/disp: initial supervisor support for off-chip encoders
changed the write mask in one of the interrupt functions for on-chip encoders,
causing a regression in certain VGA dual-head setups. This commit reintroduces
the mask thus resolving the regression
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=66129
Reported-and-Tested-by: Yves-Alexis <corsac@debian.org>
Cc: stable@vger.kernel.org [3.9+]
CC: Ben Skeggs <bskeggs@redhat.com>
Page tables on nv50 take 48kB, which can be hard to allocate in one piece.
Let's use vmalloc.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
NVC1/NVD9 are the only chipsets that should have anything different
happen on them after this. We previously weren't doing these
register modifications, and NVIDIA do.
This can be generalised and used on GK104 (probably even GF117), but lets
just make it work for now.
GK110 exposes more than one, and needs to be dealt with in the ctxsw
ucode just like the TPC sets are.
Broadcast is at +0xe00.
Generated context verified to be the same for all supported chipsets.
drm-next
Adds 3 features that UMS had to the KMS driver.
dynamic resizing - resizing remote-viewer makes guest resize
multiple crtcs - remote-viewer can access > 1 crtc.
suspend/resume/hibernate: guests can do suspend/resume/hibernate now.
* 'qxl-next' of git://people.freedesktop.org/~airlied/linux:
qxl: use drm helper hotplug support
qxl: add suspend/resume/hibernate support.
qxl: add fb and ttm entry points for use by suspend/resume.
qxl: add ring prep code for s/r
qxl: prepare memslot code for suspend/resume
qxl: split monitors_config object creation out.
drm/qxl: set time on drawables from userspace
drm/qxl: add support for > 1 output
drm/qxl: make dynamic resizing work properly.
This uses the helper to deal with hotplug so fbdev gets included.
