Big update of the sama5d2.dtsi file since many patches have reached te
mainline:
- add generated clocks
- enable crypto devices
- add flexcom devices
- add tdes device
- add sdmmc devices
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The second macb is present on all the sama5d4 SoCs. Let's add a node
reflecting it in the device tree.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
MMC data lines may be left floating if nothing is currently driving the
data lines, which is the case when mmc is in idle state, thus consuming
a useless extra amount of power. Add pullup on mmc2 data signals in the
same way it was previously done for mmc0 and mmc1.
Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Add regulator nodes of PMIC ACT8945A chip on the board.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Fix instances of "disable" instead of "disabled"
in the at91rm9200 dtsi.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
The PMC is not only used to drive the clocks but also has some registers
related to other functions. One of those is for example the USB gadget
bias.
Using a syscon allows to properly separate those functions.
Add device pin muxing for the sama5d2 Xplained board.
Add sama5d2 pin descriptions.
On at91sam9x5ek/at91sam9m10g45ek/sama5d3xek boards, we use the parallel
connection for ov2640. So we must set the hsync/vsync property (1 means
active high).
Otherwise, the connection would be seen as BT.656 or BT.1120.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Enable D8 led as now the pioD is available. D8 is the power led and is on by
default.
[nicolas.ferre@atmel.com: split the patch in 2]
As the EK board comes with a PDA 7" screen, add the touch buttons
and touchscreen for it.
Signed-off-by: Patrice Vilchez <patrice.vilchez@atmel.com>
[nicolas.ferre@atmel.com: add commit message]
The crypto modules will provide HW AES/TDES/SHA for any sama5d4 board. Enable
them by default.
As PMIC act8865 can disturb communication on i2c1, and as it should be setup
correctly then its i2c interface disabled by bootloader, we simply disregard it
in DT.
Acked-by: Wenyou Yang <wenyou.yang@atmel.com>
No device connect to i2c1, so remove it to keep it as disabled.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Correct the led labels in at91sam9n12ek.
Correcting the dma declaration for i2c1 dma.
Signed-off-by: Holger Busse <h.busse@kathrein-sachsen.de>
Fixes: 4cc7cdf35c5f ("ARM: at91/dt: add i2c1 declaration to sama5d4")
Cc: stable@vger.kernel.org # v4.1+
git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris
Pull CRIS updates from Jesper Nilsson:
"Mostly removal of old cruft of which we can use a generic version, or
fixes for code not commonly run in the cris port, but also additions
to enable some good debug"
* tag 'cris-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris: (25 commits)
CRISv10: delete unused lib/dmacopy.c
CRISv10: delete unused lib/old_checksum.c
CRIS: fix switch_mm() lockdep splat
CRISv32: enable LOCKDEP_SUPPORT
CRIS: add STACKTRACE_SUPPORT
CRISv32: annotate irq enable in idle loop
CRISv32: add support for irqflags tracing
CRIS: UAPI: use generic types.h
CRIS: UAPI: use generic shmbuf.h
CRIS: UAPI: use generic msgbuf.h
CRIS: UAPI: use generic socket.h
CRIS: UAPI: use generic sembuf.h
CRIS: UAPI: use generic sockios.h
CRIS: UAPI: use generic auxvec.h
CRIS: UAPI: use generic headers via Kbuild
CRIS: UAPI: fix elf.h export
CRIS: don't make asm/elf.h depend on asm/user.h
CRIS: UAPI: fix ptrace.h
CRISv32: Squash compile warnings for axisflashmap
CRISv32: Add GPIO driver to the default configs
rq_data_dir() returns either READ or WRITE (0 == READ, 1 == WRITE), not
a boolean value.
Now, admittedly the "!= 0" doesn't really change the value (0 stays as
zero, 1 stays as one), but it's not only redundant, it confuses gcc, and
causes gcc to warn about the construct
switch (rq_data_dir(req)) {
case READ:
case WRITE:
that we have in a few drivers.
Now, the gcc warning is silly and stupid (it seems to warn not about the
switch value having a different type from the case statements, but about
_any_ boolean switch value), but in this case the code itself is silly
and stupid too, so let's just change it, and get rid of warnings like
this:
drivers/block/hd.c: In function ‘hd_request’:
drivers/block/hd.c:630:11: warning: switch condition has boolean value [-Wswitch-bool]
The odd '!= 0' came in when "cmd_flags" got turned into a "u64" in
commit 5953316dbf90 ("block: make rq->cmd_flags be 64-bit") and is
presumably because the old code (that just did a logical 'and' with 1)
would then end up making the type of rq_data_dir() be u64 too.
But if we want to retain the old regular integer type, let's just cast
the result to 'int' rather than use that rather odd '!= 0'.
Fix up the writeback plugging introduced in commit d353d7587d02
("writeback: plug writeback at a high level") that then caused problems
due to the unplug happening with a spinlock held.
* writeback-plugging:
writeback: plug writeback in wb_writeback() and writeback_inodes_wb()
Revert "writeback: plug writeback at a high level"
We had to revert the pluggin in writeback_sb_inodes() because the
wb->list_lock is held, but we could easily plug at a higher level before
taking that lock, and unplug after releasing it. This does that.
Chris will run performance numbers, just to verify that this approach is
comparable to the alternative (we could just drop and re-take the lock
around the blk_finish_plug() rather than these two commits.
I'd have preferred waiting for actual performance numbers before picking
one approach over the other, but I don't want to release rc1 with the
known "sleeping function called from invalid context" issue, so I'll
pick this cleanup version for now. But if the numbers show that we
really want to plug just at the writeback_sb_inodes() level, and we
should just play ugly games with the spinlock, we'll switch to that.
Cc: Chris Mason <clm@fb.com>
Cc: Josef Bacik <jbacik@fb.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Jan Kara <jack@suse.cz>
I didn't notice this when merging the thermal code from Zhang, but his
merge (commit 5a924a07f882: "Merge branches 'thermal-core' and
'thermal-intel' of .git into next") of the thermal-core and
thermal-intel branches was wrong.
In thermal-core, commit 17e8351a7739 ("thermal: consistently use int for
temperatures") converted the thermal layer to use "int" for
temperatures.
But in parallel, in the thermal-intel branch commit d0a12625d2ff
("thermal: Add Intel PCH thermal driver") added support for the intel
PCH thermal sensor using the old interfaces that used "unsigned long"
pointers.
This resulted in warnings like this:
drivers/thermal/intel_pch_thermal.c:184:14: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
.get_temp = pch_thermal_get_temp,
drivers/thermal/intel_pch_thermal.c:184:14: note: (near initialization for ‘tzd_ops.get_temp’)
drivers/thermal/intel_pch_thermal.c:186:19: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
.get_trip_temp = pch_get_trip_temp,
drivers/thermal/intel_pch_thermal.c:186:19: note: (near initialization for ‘tzd_ops.get_trip_temp’)
This fixes it.
Merge fourth patch-bomb from Andrew Morton:
- sys_membarier syscall
- seq_file interface changes
- a few misc fixups
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
revert "ocfs2/dlm: use list_for_each_entry instead of list_for_each"
mm/early_ioremap: add explicit #include of asm/early_ioremap.h
fs/seq_file: convert int seq_vprint/seq_printf/etc... returns to void
selftests: enhance membarrier syscall test
selftests: add membarrier syscall test
sys_membarrier(): system-wide memory barrier (generic, x86)
MODSIGN: fix a compilation warning in extract-cert
Newer bitfiles needs the reduced clk even for SMP builds
Cc: <stable@vger.kernel.org> #4.2
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Pull NTB fixes from Jon Mason:
"NTB bug and documentation fixes, new device IDs, performance
improvements, and adding a mailing list to MAINTAINERS for NTB"
* tag 'ntb-4.3' of git://github.com/jonmason/ntb:
NTB: Fix range check on memory window index
NTB: Improve index handling in B2B MW workaround
NTB: Fix documentation for ntb_peer_db_clear.
NTB: Fix documentation for ntb_link_is_up
NTB: Use unique DMA channels for TX and RX
NTB: Remove dma_sync_wait from ntb_async_rx
NTB: Clean up QP stats info
NTB: Make the transport list in order of discovery
NTB: Add PCI Device IDs for Broadwell Xeon
NTB: Add flow control to the ntb_netdev
NTB: Add list to MAINTAINERS
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull more input updates from Dmitry Torokhov:
"Second round of updates for the input subsystem.
This introduces two brand new touchscreen drivers (Colibri and
imx6ul_tsc), some small driver fixes, and we are no longer report
errors from evdev_flush() as users do not really have a way of
handling errors, error codes that we were returning were not on the
list of errors supposed to be returned by close(), and errors were
causing issues with one of older versions of systemd"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: imx_keypad - remove obsolete comment
Input: touchscreen - add imx6ul_tsc driver support
Input: Add touchscreen support for Colibri VF50
Input: i8042 - lower log level for "no controller" message
Input: evdev - do not report errors form flush()
Input: elants_i2c - extend the calibration timeout to 12 seconds
Input: sparcspkr - fix module autoload for OF platform drivers
Input: regulator-haptic - fix module autoload for OF platform driver
Input: pwm-beeper - fix module autoload for OF platform driver
Input: ab8500-ponkey - Fix module autoload for OF platform driver
Input: cyttsp - remove unnecessary MODULE_ALIAS()
Input: elan_i2c - add ACPI ID "ELAN1000"
Pull more power management and ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups on top of the previous PM+ACPI
pull request (cpufreq core and drivers, cpuidle, generic power domains
framework). Some of them didn't make to that pull request and some
fix issues introduced by it.
The only really new thing is the support for suspend frequency in the
cpufreq-dt driver, but it is needed to fix an issue with Exynos
platforms.
Specifics:
- build fix for the new Mediatek MT8173 cpufreq driver (Guenter
Roeck).
- generic power domains framework fixes (power on error code path,
subdomain removal) and cleanup of a deprecated API user (Geert
Uytterhoeven, Jon Hunter, Ulf Hansson).
- cpufreq-dt driver fixes including two fixes for bugs related to the
new Operating Performance Points Device Tree bindings introduced
recently (Viresh Kumar).
- suspend frequency support for the cpufreq-dt driver (Bartlomiej
Zolnierkiewicz, Viresh Kumar).
- cpufreq core cleanups (Viresh Kumar).
- intel_pstate driver fixes (Chen Yu, Kristen Carlson Accardi).
- additional sanity check in the cpuidle core (Xunlei Pang).
- fix for a comment related to CPU power management (Lina Iyer)"
* tag 'pm+acpi-4.3-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
intel_pstate: fix PCT_TO_HWP macro
intel_pstate: Fix user input of min/max to legal policy region
PM / OPP: Return suspend_opp only if it is enabled
cpufreq-dt: add suspend frequency support
cpufreq: allow cpufreq_generic_suspend() to work without suspend frequency
PM / OPP: add dev_pm_opp_get_suspend_opp() helper
staging: board: Migrate away from __pm_genpd_name_add_device()
cpufreq: Use __func__ to print function's name
cpufreq: staticize cpufreq_cpu_get_raw()
PM / Domains: Ensure subdomain is not in use before removing
cpufreq: Add ARM_MT8173_CPUFREQ dependency on THERMAL
cpuidle/coupled: Add sanity check for safe_state_index
PM / Domains: Try power off masters in error path of __pm_genpd_poweron()
cpufreq: dt: Tolerance applies on both sides of target voltage
cpufreq: dt: Print error on failing to mark OPPs as shared
cpufreq: dt: Check OPP count before marking them shared
kernel/cpu_pm: fix cpu_cluster_pm_exit comment
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Here are the outstanding target-pending updates for v4.3-rc1.
Mostly bug-fixes and minor changes this round. The fallout from the
big v4.2-rc1 RCU conversion have (thus far) been minimal.
The highlights this round include:
- Move sense handling routines into scsi_common code (Sagi)
- Return ABORTED_COMMAND sense key for PI errors (Sagi)
- Add tpg_enabled_sendtargets attribute for disabled iscsi-target
discovery (David)
- Shrink target struct se_cmd by rearranging fields (Roland)
- Drop iSCSI use of mutex around max_cmd_sn increment (Roland)
- Replace iSCSI __kernel_sockaddr_storage with sockaddr_storage (Andy +
Chris)
- Honor fabric max_data_sg_nents I/O transfer limit (Arun + Himanshu +
nab)
- Fix EXTENDED_COPY >= v4.1 regression OOPsen (Alex + nab)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (37 commits)
target: use stringify.h instead of own definition
target/user: Fix UFLAG_UNKNOWN_OP handling
target: Remove no-op conditional
target/user: Remove unused variable
target: Fix max_cmd_sn increment w/o cmdsn mutex regressions
target: Attach EXTENDED_COPY local I/O descriptors to xcopy_pt_sess
target/qla2xxx: Honor max_data_sg_nents I/O transfer limit
target/iscsi: Replace __kernel_sockaddr_storage with sockaddr_storage
target/iscsi: Replace conn->login_ip with login_sockaddr
target/iscsi: Keep local_ip as the actual sockaddr
target/iscsi: Fix np_ip bracket issue by removing np_ip
target: Drop iSCSI use of mutex around max_cmd_sn increment
qla2xxx: Update tcm_qla2xxx module description to 24xx+
iscsi-target: Add tpg_enabled_sendtargets for disabled discovery
drivers: target: Drop unlikely before IS_ERR(_OR_NULL)
target: check DPO/FUA usage for COMPARE AND WRITE
target: Shrink struct se_cmd by rearranging fields
target: Remove cmd->se_ordered_id (unused except debug log lines)
target: add support for START_STOP_UNIT SCSI opcode
target: improve unsupported opcode message
Pull second round of SCSI updates from James Bottomley:
"There's one late arriving patch here (added today), fixing a build
issue which the scsi_dh patch set in here uncovered. Other than that,
everything has been incubated in -next and the checkers for a week.
The major pieces of this patch are a set patches facilitating better
integration between scsi and scsi_dh (the device handling layer used
by multi-path; all the dm parts are acked by Mike Snitzer).
This also includes driver updates for mp3sas, scsi_debug and an
assortment of bug fixes"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (50 commits)
scsi_dh: fix randconfig build error
scsi: fix scsi_error_handler vs. scsi_host_dev_release race
fcoe: Convert use of __constant_htons to htons
mpt2sas: setpci reset kernel oops fix
pm80xx: Don't override ts->stat on IO_OPEN_CNX_ERROR_HW_RESOURCE_BUSY
lpfc: Fix possible use-after-free and double free in lpfc_mbx_cmpl_rdp_page_a2()
bfa: Fix incorrect de-reference of pointer
bfa: Fix indentation
scsi_transport_sas: Remove check for SAS expander when querying bay/enclosure IDs.
scsi_debug: resp_request: remove unused variable
scsi_debug: fix REPORT LUNS Well Known LU
scsi_debug: schedule_resp fix input variable check
scsi_debug: make dump_sector static
scsi_debug: vfree is null safe so drop the check
scsi_debug: use SCSI_W_LUN_REPORT_LUNS instead of SAM2_WLUN_REPORT_LUNS;
scsi_debug: define pr_fmt() for consistent logging
mpt2sas: Refcount fw_events and fix unsafe list usage
mpt2sas: Refcount sas_device objects and fix unsafe list usage
scsi_dh: return SCSI_DH_NOTCONN in scsi_dh_activate()
scsi_dh: don't allow to detach device handlers at runtime
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"A series of patches that move part of the code used to allocate memory
from the media subsystem to the mm subsystem"
[ The mm parts have been acked by VM people, and the series was
apparently in -mm for a while - Linus ]
* tag 'media/v4.3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] drm/exynos: Convert g2d_userptr_get_dma_addr() to use get_vaddr_frames()
[media] media: vb2: Remove unused functions
[media] media: vb2: Convert vb2_dc_get_userptr() to use frame vector
[media] media: vb2: Convert vb2_vmalloc_get_userptr() to use frame vector
[media] media: vb2: Convert vb2_dma_sg_get_userptr() to use frame vector
[media] vb2: Provide helpers for mapping virtual addresses
[media] media: omap_vout: Convert omap_vout_uservirt_to_phys() to use get_vaddr_pfns()
[media] mm: Provide new get_vaddr_frames() helper
[media] vb2: Push mmap_sem down to memops
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac
Pull edac updates from Mauro Carvalho Chehab:
"Two EDAC fixes for Intel systems (Haswell and Ivy Bridge)"
* tag 'edac/v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac:
sb_edac: correctly fetch DIMM width on Ivy Bridge and Haswell
sb_edac: look harder for DDRIO on Haswell systems
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal updates from Zhang Rui:
- use int instead of unsigned long to represent temperature to avoid
bogus overheat detection when negative temperature reported. From
Sascha Hauer.
- export available thermal governors information to user space via
sysfs. From Wei Ni.
- introduce new thermal driver for Wildcat Point platform controller
hub, which uses PCH thermal sensor and associated critical and hot
trip points. From Tushar Dave.
- add suuport for Intel Skylake and Denlow platforms in powerclamp
driver.
- some small cleanups in thermal core.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
thermal: Add comment explaining test for critical temperature
thermal: Use IS_ENABLED instead of #ifdef
thermal: remove unnecessary call to thermal_zone_device_set_polling
thermal: trivial: fix typo in comment
thermal: consistently use int for temperatures
thermal: add available policies sysfs attribute
thermal/powerclamp: add cpu id for denlow platform
thermal/powerclamp: add cpu id for Skylake u/y
thermal/powerclamp: add cpu id for skylake h/s
Revert commit f83c7b5e9fd6 ("ocfs2/dlm: use list_for_each_entry instead
of list_for_each").
list_for_each_entry() will dereference its `pos' argument, which can be
NULL in dlm_process_recovery_data().
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Reported-by: Fengguang Wu <fengguang.wu@gmail.com>
Cc: Joseph Qi <joseph.qi@huawei.com>
Cc: Mark Fasheh <mfasheh@suse.de>
Commit 6b0f68e32ea8 ("mm: add utility for early copy from unmapped ram")
introduces a function copy_from_early_mem() into mm/early_ioremap.c
which itself calls early_memremap()/early_memunmap(). However, since
early_memunmap() has not been declared yet at this point in the .c file,
nor by any explicitly included header files, we are depending on a
transitive include of asm/early_ioremap.h to declare it, which is
fragile.
So instead, include this header explicitly.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Mark Salter <msalter@redhat.com>
The seq_<foo> function return values were frequently misused.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
All uses of these return values have been removed, so convert the
return types to void.
Miscellanea:
o Move seq_put_decimal_<type> and seq_escape prototypes closer the
other seq_vprintf prototypes
o Reorder seq_putc and seq_puts to return early on overflow
o Add argument names to seq_vprintf and seq_printf
o Update the seq_escape kernel-doc
o Convert a couple of leading spaces to tabs in seq_escape
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Mark Brown <broonie@kernel.org>
Cc: Joerg Roedel <jroedel@suse.de>
Update the membarrier syscall self-test to match the membarrier
interface. Extend coverage of the interface. Consider ENOSYS as a
"SKIP" test, since it is a valid configuration, but does not allow
testing the system call.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Pranith Kumar <bobby.prani@gmail.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
Add a self test for the membarrier system call.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Here is an implementation of a new system call, sys_membarrier(), which
executes a memory barrier on all threads running on the system. It is
implemented by calling synchronize_sched(). It can be used to
distribute the cost of user-space memory barriers asymmetrically by
transforming pairs of memory barriers into pairs consisting of
sys_membarrier() and a compiler barrier. For synchronization primitives
that distinguish between read-side and write-side (e.g. userspace RCU
[1], rwlocks), the read-side can be accelerated significantly by moving
the bulk of the memory barrier overhead to the write-side.
The existing applications of which I am aware that would be improved by
this system call are as follows:
* Through Userspace RCU library (http://urcu.so)
- DNS server (Knot DNS) https://www.knot-dns.cz/
- Network sniffer (http://netsniff-ng.org/)
- Distributed object storage (https://sheepdog.github.io/sheepdog/)
- User-space tracing (http://lttng.org)
- Network storage system (https://www.gluster.org/)
- Virtual routers (https://events.linuxfoundation.org/sites/events/files/slides/DPDK_RCU_0MQ.pdf)
- Financial software (https://lkml.org/lkml/2015/3/23/189)
Those projects use RCU in userspace to increase read-side speed and
scalability compared to locking. Especially in the case of RCU used by
libraries, sys_membarrier can speed up the read-side by moving the bulk of
the memory barrier cost to synchronize_rcu().
* Direct users of sys_membarrier
- core dotnet garbage collector (https://github.com/dotnet/coreclr/issues/198)
Microsoft core dotnet GC developers are planning to use the mprotect()
side-effect of issuing memory barriers through IPIs as a way to implement
Windows FlushProcessWriteBuffers() on Linux. They are referring to
sys_membarrier in their github thread, specifically stating that
sys_membarrier() is what they are looking for.
To explain the benefit of this scheme, let's introduce two example threads:
Thread A (non-frequent, e.g. executing liburcu synchronize_rcu())
Thread B (frequent, e.g. executing liburcu
rcu_read_lock()/rcu_read_unlock())
In a scheme where all smp_mb() in thread A are ordering memory accesses
with respect to smp_mb() present in Thread B, we can change each
smp_mb() within Thread A into calls to sys_membarrier() and each
smp_mb() within Thread B into compiler barriers "barrier()".
Before the change, we had, for each smp_mb() pairs:
Thread A Thread B
previous mem accesses previous mem accesses
smp_mb() smp_mb()
following mem accesses following mem accesses
After the change, these pairs become:
Thread A Thread B
prev mem accesses prev mem accesses
sys_membarrier() barrier()
follow mem accesses follow mem accesses
As we can see, there are two possible scenarios: either Thread B memory
accesses do not happen concurrently with Thread A accesses (1), or they
do (2).
1) Non-concurrent Thread A vs Thread B accesses:
Thread A Thread B
prev mem accesses
sys_membarrier()
follow mem accesses
prev mem accesses
barrier()
follow mem accesses
In this case, thread B accesses will be weakly ordered. This is OK,
because at that point, thread A is not particularly interested in
ordering them with respect to its own accesses.
2) Concurrent Thread A vs Thread B accesses
Thread A Thread B
In this case, thread B accesses, which are ensured to be in program
order thanks to the compiler barrier, will be "upgraded" to full
smp_mb() by synchronize_sched().
* Benchmarks
On Intel Xeon E5405 (8 cores)
(one thread is calling sys_membarrier, the other 7 threads are busy
looping)
1000 non-expedited sys_membarrier calls in 33s =3D 33 milliseconds/call.
* User-space user of this system call: Userspace RCU library
Both the signal-based and the sys_membarrier userspace RCU schemes
permit us to remove the memory barrier from the userspace RCU
rcu_read_lock() and rcu_read_unlock() primitives, thus significantly
accelerating them. These memory barriers are replaced by compiler
barriers on the read-side, and all matching memory barriers on the
write-side are turned into an invocation of a memory barrier on all
active threads in the process. By letting the kernel perform this
synchronization rather than dumbly sending a signal to every process
threads (as we currently do), we diminish the number of unnecessary wake
ups and only issue the memory barriers on active threads. Non-running
threads do not need to execute such barrier anyway, because these are
implied by the scheduler context switches.
Results in liburcu:
Operations in 10s, 6 readers, 2 writers:
memory barriers in reader: 1701557485 reads, 2202847 writes
signal-based scheme: 9830061167 reads, 6700 writes
sys_membarrier: 9952759104 reads, 425 writes
sys_membarrier (dyn. check): 7970328887 reads, 425 writes
The dynamic sys_membarrier availability check adds some overhead to
the read-side compared to the signal-based scheme, but besides that,
sys_membarrier slightly outperforms the signal-based scheme. However,
this non-expedited sys_membarrier implementation has a much slower grace
period than signal and memory barrier schemes.
Besides diminishing the number of wake-ups, one major advantage of the
membarrier system call over the signal-based scheme is that it does not
need to reserve a signal. This plays much more nicely with libraries,
and with processes injected into for tracing purposes, for which we
cannot expect that signals will be unused by the application.
An expedited version of this system call can be added later on to speed
up the grace period. Its implementation will likely depend on reading
the cpu_curr()->mm without holding each CPU's rq lock.
This patch adds the system call to x86 and to asm-generic.
[1] http://urcu.so
membarrier(2) man page:
MEMBARRIER(2) Linux Programmer's Manual MEMBARRIER(2)
NAME
membarrier - issue memory barriers on a set of threads
SYNOPSIS
#include <linux/membarrier.h>
int membarrier(int cmd, int flags);
DESCRIPTION
The cmd argument is one of the following:
MEMBARRIER_CMD_QUERY
Query the set of supported commands. It returns a bitmask of
supported commands.
MEMBARRIER_CMD_SHARED
Execute a memory barrier on all threads running on the system.
Upon return from system call, the caller thread is ensured that
all running threads have passed through a state where all memory
accesses to user-space addresses match program order between
entry to and return from the system call (non-running threads
are de facto in such a state). This covers threads from all pro=E2=80=90
cesses running on the system. This command returns 0.
The flags argument needs to be 0. For future extensions.
All memory accesses performed in program order from each targeted
thread is guaranteed to be ordered with respect to sys_membarrier(). If
we use the semantic "barrier()" to represent a compiler barrier forcing
memory accesses to be performed in program order across the barrier,
and smp_mb() to represent explicit memory barriers forcing full memory
ordering across the barrier, we have the following ordering table for
each pair of barrier(), sys_membarrier() and smp_mb():
The pair ordering is detailed as (O: ordered, X: not ordered):
barrier() smp_mb() sys_membarrier()
barrier() X X O
smp_mb() X O O
sys_membarrier() O O O
RETURN VALUE
On success, these system calls return zero. On error, -1 is returned,
and errno is set appropriately. For a given command, with flags
argument set to 0, this system call is guaranteed to always return the
same value until reboot.
ERRORS
ENOSYS System call is not implemented.
EINVAL Invalid arguments.
Linux 2015-04-15 MEMBARRIER(2)
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: Nicholas Miell <nmiell@comcast.net>
Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Fix the following warning when compiling extract-cert:
scripts/extract-cert.c: In function `write_cert':
scripts/extract-cert.c:89:2: warning: format not a string literal and no format arguments [-Wformat-security]
ERR(!i2d_X509_bio(wb, x509), cert_dst);
whereby the ERR() macro is taking cert_dst as the format string. "%s"
should be used as the format string as the path could contain special
characters.
Reported-by: Jim Davis <jim.epost@gmail.com>
Acked-by : David Woodhouse <david.woodhouse@intel.com>
Pull watchdog updates from Wim Van Sebroeck:
- new driver for NXP LPC18xx Watchdog Timer
- new driver for SAMA5D4 watchdog timer
- add support for MCP79 to nv_tco driver
- clean-up and improvement of the mpc8xxx watchdog driver
- improvements to gpio-wdt
- at91sam9_wdt clock improvements
... and other small fixes and improvements
* git://www.linux-watchdog.org/linux-watchdog: (25 commits)
Watchdog: Fix parent of watchdog_devices
watchdog: at91rm9200: Correct check for syscon_node_to_regmap() errors
watchdog: at91sam9: get and use slow clock
Documentation: dt: binding: atmel-sama5d4-wdt: for SAMA5D4 watchdog driver
watchdog: add a driver to support SAMA5D4 watchdog timer
watchdog: mpc8xxx: allow to compile for MPC512x
watchdog: mpc8xxx: use better error code when watchdog cannot be enabled
watchdog: mpc8xxx: use dynamic memory for device specific data
watchdog: mpc8xxx: use devm_ioremap_resource to map memory
watchdog: mpc8xxx: make use of of_device_get_match_data
watchdog: mpc8xxx: simplify registration
watchdog: mpc8xxx: remove dead code
watchdog: lpc18xx_wdt_get_timeleft() can be static
DT: watchdog: Add NXP LPC18xx Watchdog Timer binding documentation
watchdog: NXP LPC18xx Watchdog Timer Driver
watchdog: gpio-wdt: ping already at startup for always running devices
watchdog: gpio-wdt: be more strict about hw_algo matching
Documentation: watchdog: at91sam9_wdt: add clocks property
watchdog: booke_wdt: Use infrastructure to check timeout limits
watchdog: (nv_tco) add support for MCP79
This reverts commit d353d7587d02116b9732d5c06615aed75a4d3a47.
Doing the block layer plug/unplug inside writeback_sb_inodes() is
broken, because that function is actually called with a spinlock held:
wb->list_lock, as pointed out by Chris Mason.
Chris suggested just dropping and re-taking the spinlock around the
blk_finish_plug() call (the plgging itself can happen under the
spinlock), and that would technically work, but is just disgusting.
We do something fairly similar - but not quite as disgusting because we
at least have a better reason for it - in writeback_single_inode(), so
it's not like the caller can depend on the lock being held over the
call, but in this case there just isn't any good reason for that
"release and re-take the lock" pattern.
[ In general, we should really strive to avoid the "release and retake"
pattern for locks, because in the general case it can easily cause
subtle bugs when the caller caches any state around the call that
might be invalidated by dropping the lock even just temporarily. ]
But in this case, the plugging should be easy to just move up to the
callers before the spinlock is taken, which should even improve the
effectiveness of the plug. So there is really no good reason to play
games with locking here.
I'll send off a test-patch so that Dave Chinner can verify that that
plug movement works. In the meantime this just reverts the problematic
commit and adds a comment to the function so that we hopefully don't
make this mistake again.
Reported-by: Chris Mason <clm@fb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs cleanups and fixes from Chris Mason:
"These are small cleanups, and also some fixes for our async worker
thread initialization.
I was having some trouble testing these, but it ended up being a
combination of changing around my test servers and a shiny new
schedule while atomic from the new start/finish_plug in
writeback_sb_inodes().
That one only hits on btrfs raid5/6 or MD raid10, and if I wasn't
changing a bunch of things in my test setup at once it would have been
really clear. Fix for writeback_sb_inodes() on the way as well"
* 'for-linus-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: cleanup: remove unnecessary check before btrfs_free_path is called
btrfs: async_thread: Fix workqueue 'max_active' value when initializing
btrfs: Add raid56 support for updating num_tolerated_disk_barrier_failures in btrfs_balance
btrfs: Cleanup for btrfs_calc_num_tolerated_disk_barrier_failures
btrfs: Remove noused chunk_tree and chunk_objectid from scrub_enumerate_chunks and scrub_chunk
btrfs: Update out-of-date "skip parity stripe" comment
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph update from Sage Weil:
"There are a few fixes for snapshot behavior with CephFS and support
for the new keepalive protocol from Zheng, a libceph fix that affects
both RBD and CephFS, a few bug fixes and cleanups for RBD from Ilya,
and several small fixes and cleanups from Jianpeng and others"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: improve readahead for file holes
ceph: get inode size for each append write
libceph: check data_len in ->alloc_msg()
libceph: use keepalive2 to verify the mon session is alive
rbd: plug rbd_dev->header.object_prefix memory leak
rbd: fix double free on rbd_dev->header_name
libceph: set 'exists' flag for newly up osd
ceph: cleanup use of ceph_msg_get
ceph: no need to get parent inode in ceph_open
ceph: remove the useless judgement
ceph: remove redundant test of head->safe and silence static analysis warnings
ceph: fix queuing inode to mdsdir's snaprealm
libceph: rename con_work() to ceph_con_workfn()
libceph: Avoid holding the zero page on ceph_msgr_slab_init errors
libceph: remove the unused macro AES_KEY_SIZE
ceph: invalidate dirty pages after forced umount
ceph: EIO all operations after forced umount
git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2
Pull GFS2 updates from Bob Peterson:
"Here is a list of patches we've accumulated for GFS2 for the current
upstream merge window. This time we've only got six patches, many of
which are very small:
- three cleanups from Andreas Gruenbacher, including a nice cleanup
of the sequence file code for the sbstats debugfs file.
- a patch from Ben Hutchings that changes statistics variables from
signed to unsigned.
- two patches from me that increase GFS2's glock scalability by
switching from a conventional hash table to rhashtable"
* tag 'gfs2-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
gfs2: A minor "sbstats" cleanup
gfs2: Fix a typo in a comment
gfs2: Make statistics unsigned, suitable for use with do_div()
GFS2: Use resizable hash table for glocks
GFS2: Move glock superblock pointer to field gl_name
gfs2: Simplify the seq file code for "sbstats"
It looks like the Kconfig check that was meant to fix this (commit
fe9233fb6914a0eb20166c967e3020f7f0fba2c9 [SCSI] scsi_dh: fix kconfig related
build errors) was actually reversed, but no-one noticed until the new set of
patches which separated DM and SCSI_DH).
Fixes: fe9233fb6914a0eb20166c967e3020f7f0fba2c9
Tested-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"A collection of small fixes since the last update: the HD-audio quirks
as usual with a USB-audio fix and a trivial fix for the old sparc
driver"
* tag 'sound-fix-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: usb-audio: Change internal PCM order
ALSA: hda - Fix white noise on Dell M3800
ALSA: hda - Use ALC880_FIXUP_FUJITSU for FSC Amilo M1437
ALSA: hda - Enable headphone jack detect on old Fujitsu laptops
ALSA: sparc: amd7930: Fix module autoload for OF platform driver
ALSA: hda - Add some FIXUP quirks for white noise on Dell laptop.
Pull drm fixes from Dave Airlie:
"Just a bunch of fixes to squeeze in before -rc1:
- three nouveau regression fixes
- one qxl regression fix
- a bunch of i915 fixes
... and some core displayport/atomic fixes"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/nouveau/device: enable c800 quirk for tecra w50
drm/nouveau/clk/gt215: Unbreak engine pausing for GT21x/MCP7x
drm/nouveau/gr/nv04: fix big endian setting on gr context
drm/qxl: validate monitors config modes
drm/i915: Allow DSI dual link to be configured on any pipe
drm/i915: Don't try to use DDR DVFS on CHV when disabled in the BIOS
drm/i915: Fix CSR MMIO address check
drm/i915: Limit the number of loops for reading a split 64bit register
drm/i915: Fix broken mst get_hw_state.
drm/i915: Pass hpd_status_i915[] to intel_get_hpd_pins() in pre-g4x
uapi/drm/i915_drm.h: fix userspace compilation.
drm/i915: Always mark the object as dirty when used by the GPU
drm/dp: Add dp_aux_i2c_speed_khz module param to set the assume i2c bus speed
drm/dp: Adjust i2c-over-aux retry count based on message size and i2c bus speed
drm/dp: Define AUX_RETRY_INTERVAL as 500 us
drm/atomic: Fix bookkeeping with TEST_ONLY, v3.
