2006-07-21[SPARC64]: Fix more of_device layer IRQ bugs, and correct PROMREG_MAX.David S. Miller
Sabre and Psycho PCI controllers can have partial interrupt-map properties, meaning that on-board devices don't match up to any entries. Instead, they are fully specified from the beginning and we should pass them directly to the IRQ translator as-is. Also, fill in the necessary translator slots for the "graphics" and "expansion UPA" interrupts on Sabre, Psycho, and SYSIO SBUS. Increase PROMREG_MAX to 24, as seen on SUNW,ffb devices. Finally, prevent accidentally writing past the end of the of_device struct resource[] and irqs[] arrays. Spit out a log message when we ignore some entries because there are too many of them. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (38 commits) [SCSI] More buffer->request_buffer changes [SCSI] mptfusion: bump version to 3.04.01 [SCSI] mptfusion: misc fix's [SCSI] mptfusion: firmware download boot fix's [SCSI] mptfusion: task abort fix's [SCSI] mptfusion: sas nexus loss support [SCSI] mptfusion: sas loginfo update [SCSI] mptfusion: mptctl panic when loading [SCSI] mptfusion: sas enclosures with smart drive [SCSI] NCR_D700: misc fixes (section and argument ordering) [SCSI] scsi_debug: must_check fixes [SCSI] scsi_transport_sas: kill the use of channel [SCSI] scsi_transport_sas: add expander backlink [SCSI] hide EH backup data outside the scsi_cmnd [SCSI] ibmvscsi: handle inactive SCSI target during probe [SCSI] ibmvscsi: allocate lpevents for ibmvscsi on iseries [SCSI] aic7[9x]xx: Remove last vestiges of reverse_scan [SCSI] aha152x: stop poking at saved scsi_cmnd members [SCSI] st.c: Improve sense output [SCSI] lpfc 8.1.7: Change version number to 8.1.7 ...
2006-07-21Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] sysfs_create_xxx return values. [S390] .align 4096 statements in head.S [S390] get_clock inline assembly. [S390] channel measurement interval display. [S390] xpram module parameter parsing - take 2. [S390] Fix gcc warning about unused return values.
2006-07-21Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: [PATCH] spidernet: rework tx queue handling [PATCH] spidernet: bug fix for init code [PATCH] sky2: NAPI poll fix [NET] ethtool: fix oops by testing correct struct member e1000: bump version to 7.1.9-k4 e1000: fix panic on large frame receive when mtu=default e1000: remove CRC bytes from measured packet length e1000: Redo netpoll fix to address community concerns
2006-07-18[S390] sysfs_create_xxx return values.Heiko Carstens
Take return values of sysfs_create_group & friends into account. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-18[S390] .align 4096 statements in head.SHeiko Carstens
SLES9 binutils don't like .align 4096 statements in head.S. Work around this by using .org statements. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-17[PATCH] spidernet: rework tx queue handlingJens Osterkamp
With this patch TX queue descriptors are not chained per default any more. The pointer to next descriptor is set only when next descriptor is prepaired for transfer. Also the mechanism of checking wether Spider is ready has been changed: it checks not for CARDOWNED flag in status of previous descriptor but for a TXDMAENABLED flag in Spider's register. Signed-off-by: Maxim Shchetynin <maxim@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-17[PATCH] spidernet: bug fix for init codeJens Osterkamp
We want to intitialize addr instead of data register first. Signed-off-by: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-17[PATCH] sky2: NAPI poll fixStephen Hemminger
When sky2 driver gets lots of received packets at once, it can get stuck. The NAPI poll routine gets called back to keep going, but since no IRQ bits are set it doesn't make progress. Increase version, since this is serious enough problem that I want to be able to tell new from old problems. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-17Merge branch 'upstream-fixes-jgarzik' of ↵Jeff Garzik
git://lost.foo-projects.org/~ahkok/git/netdev-2.6 into upstream-fixes
2006-07-17[NET] ethtool: fix oops by testing correct struct memberJeff Garzik
Noticed by Willy Tarreau. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-17[S390] get_clock inline assembly.Andreas Krebbel
Add missing volatile to the get_clock / get_cycles inline assemblies to avoid that consecutive calls get optimized away. Signed-off-by: Andreas Krebbel <krebbel1@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-17[S390] channel measurement interval display.Cornelia Huck
Display avg_sample_interval in nanoseconds, like it is documented. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-17[S390] xpram module parameter parsing - take 2.Heiko Carstens
Don't use memparse since the default size modifier is 'k'. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-17[S390] Fix gcc warning about unused return values.Heiko Carstens
2006-07-16[libata] ata_piix: correct 'invalid MAP value' typo-caused errorJeff Garzik
2006-07-16[libata] ata_piix: minor cleanups noticed in prior patch runJeff Garzik
* delete unused PIIX_FLAG_COMBINED* * port_enable should be u16 rather than u32 Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-16[libata] ata_piix: attempt to fix ICH8 supportJeff Garzik
Take into account the fact that ICH8 changed the register layout of the MAP and PCS register bits. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-16[libata] ata_piix: Consolidate PCS register writingJeff Garzik
Prior to this patch, the driver would do this for each port: read 8-bit PCS write 8-bit PCS read 8-bit PCS write 8-bit PCS In the field, flaky behavior has been observed related to this register. In particular, these overzealous register writes can cause misdetection problems. Update to do the following once (not once per port) at boot: read 16-bit PCS if needs changing, write 16-bit PCS And thereafter, we only perform a 'read 16-bit PCS' per port. This should eliminate all PCS writes in many cases, and be more friendly in the cases where we do need to enable ports. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-16[PATCH] ata_piix: add host_set private structureTejun Heo
Add host_set private structure piix_host_priv. Currently the only field is ->map which used to be stored directly at host_set->private_data. This change allows more host_set private fields to be added. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-15Linux 2.6.18-rc2v2.6.18-rc2Linus Torvalds
Finishing up for the kernel summit. Ottawa, here I come. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: JFS: commit_mutex cleanups
2006-07-15[PATCH] UML - fix utsname build breakageJeff Dike
Some -mm-only material leaked into a patch destined for mainline, and I didn't notice. This was the replacement of system_utsname with utsname() that's required by the uts namespace patch. This patch reverts those changes (which are correct in -mm) so that mainline UML builds again. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-15Don't allow chmod() on the /proc/<pid>/ filesLinus Torvalds
This just turns off chmod() on the /proc/<pid>/ files, since there is no good reason to allow it, and had we disallowed it originally, the nasty /proc race exploit wouldn't have been possible. The other patches already fixed the problem chmod() could cause, so this is really just some final mop-up.. This particular version is based off a patch by Eugene and Marcel which had much better naming than my original equivalent one. Signed-off-by: Eugene Teo <eteo@redhat.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-15Mark /proc MS_NOSUID and MS_NOEXECLinus Torvalds
Not that we really need this any more, but at the same time there's no reason not to do this. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-15[PATCH] sch_htb compile fix.Dave Jones
net/sched/sch_htb.c: In function 'htb_change_class': net/sched/sch_htb.c:1605: error: expected ';' before 'do_gettimeofday' Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14Merge master.kernel.org:/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/herbert/crypto-2.6: [CRYPTO] padlock: Fix alignment after aes_ctx rearrange
2006-07-14Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64] Fix PSYCHO PCI controler init. [SPARC64] psycho: Fix pbm->name handling in pbm_register_toplevel_resources() [SERIAL] sunsab: Fix significant typo in sab_probe() [SERIAL] sunsu: Report keyboard and mouse ports in kernel log. [SPARC64]: Make sure IRQs are disabled properly during early boot.
2006-07-14Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [VLAN]: __vlan_hwaccel_rx can use the faster ether_compare_addr [PKT_SCHED] HTB: initialize upper bound properly [IPV4]: Clear skb cb on IP input [NET]: Update frag_list in pskb_trim
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] remove set_wmb - doc updateSteven Rostedt
This patch removes the reference to set_wmb from memory-barriers.txt since it shouldn't be used. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] Remove down_write() from taskstats code invoked on the exit() pathShailabh Nagar
In send_cpu_listeners(), which is called on the exit path, a down_write() was protecting operations like skb_clone() and genlmsg_unicast() that do GFP_KERNEL allocations. If the oom-killer decides to kill tasks to satisfy the allocations,the exit of those tasks could block on the same semphore. The down_write() was only needed to allow removal of invalid listeners from the listener list. The patch converts the down_write to a down_read and defers the removal to a separate critical region. This ensures that even if the oom-killer is called, no other task's exit is blocked as it can still acquire another down_read. Thanks to Andrew Morton & Herbert Xu for pointing out the oom related pitfalls, and to Chandra Seetharaman for suggesting this fix instead of using something more complex like RCU. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task delay accounting taskstats interface: control exit data ↵Shailabh Nagar
through cpumasks On systems with a large number of cpus, with even a modest rate of tasks exiting per cpu, the volume of taskstats data sent on thread exit can overflow a userspace listener's buffers. One approach to avoiding overflow is to allow listeners to get data for a limited and specific set of cpus. By scaling the number of listeners and/or the cpus they monitor, userspace can handle the statistical data overload more gracefully. In this patch, each listener registers to listen to a specific set of cpus by specifying a cpumask. The interest is recorded per-cpu. When a task exits on a cpu, its taskstats data is unicast to each listener interested in that cpu. Thanks to Andrew Morton for pointing out the various scalability and general concerns of previous attempts and for suggesting this design. [akpm@osdl.org: build fix] Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task delay accounting: avoid send without listenersShailabh Nagar
Don't send taskstats (per-pid or per-tgid) on thread exit when no one is listening for such data. Currently the taskstats interface allocates a structure, fills it in and calls netlink to send out per-pid and per-tgid stats regardless of whether a userspace listener for the data exists (netlink layer would check for that and avoid the multicast). As a result of this patch, the check for the no-listener case is performed early, avoiding the redundant allocation and filling up of the taskstats structures. Signed-off-by: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per task delay accounting taskstats interface: documentation fixShailabh Nagar
Change documentation and example program to reflect the flow control issues being addressed by the cpumask changes. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] delay accounting taskstats interface send tgid onceShailabh Nagar
Send per-tgid data only once during exit of a thread group instead of once with each member thread exit. Currently, when a thread exits, besides its per-tid data, the per-tgid data of its thread group is also sent out, if its thread group is non-empty. The per-tgid data sent consists of the sum of per-tid stats for all *remaining* threads of the thread group. This patch modifies this sending in two ways: - the per-tgid data is sent only when the last thread of a thread group exits. This cuts down heavily on the overhead of sending/receiving per-tgid data, especially when other exploiters of the taskstats interface aren't interested in per-tgid stats - the semantics of the per-tgid data sent are changed. Instead of being the sum of per-tid data for remaining threads, the value now sent is the true total accumalated statistics for all threads that are/were part of the thread group. The patch also addresses a minor issue where failure of one accounting subsystem to fill in the taskstats structure was causing the send of taskstats to not be sent at all. The patch has been tested for stability and run cerberus for over 4 hours on an SMP. [akpm@osdl.org: bugfixes] Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: /proc export of aggregated block I/O delaysShailabh Nagar
Export I/O delays seen by a task through /proc/<tgid>/stats for use in top etc. Note that delays for I/O done for swapping in pages (swapin I/O) is clubbed together with all other I/O here (this is not the case in the netlink interface where the swapin I/O is kept distinct) [akpm@osdl.org: printk warning fix] Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: documentationShailabh Nagar
Some documentation for delay accounting. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: delay accounting usage of taskstats interfaceShailabh Nagar
Usage of taskstats interface by delay accounting. Signed-off-by: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: taskstats interfaceShailabh Nagar
Create a "taskstats" interface based on generic netlink (NETLINK_GENERIC family), for getting statistics of tasks and thread groups during their lifetime and when they exit. The interface is intended for use by multiple accounting packages though it is being created in the context of delay accounting. This patch creates the interface without populating the fields of the data that is sent to the user in response to a command or upon the exit of a task. Each accounting package interested in using taskstats has to provide an additional patch to add its stats to the common structure. [akpm@osdl.org: cleanups, Kconfig fix] Signed-off-by: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: utilities for genetlink usageBalbir Singh
Two utilities for simplifying usage of NETLINK_GENERIC interface. Signed-off-by: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: cpu delay collection via schedstatsChandra Seetharaman
Make the task-related schedstats functions callable by delay accounting even if schedstats collection isn't turned on. This removes the dependency of delay accounting on schedstats. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: sync block I/O and swapin delay collectionShailabh Nagar
Unlike earlier iterations of the delay accounting patches, now delays are only collected for the actual I/O waits rather than try and cover the delays seen in I/O submission paths. Account separately for block I/O delays incurred as a result of swapin page faults whose frequency can be affected by the task/process' rss limit. Hence swapin delays can act as feedback for rss limit changes independent of I/O priority changes. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: setupShailabh Nagar
Initialization code related to collection of per-task "delay" statistics which measure how long it had to wait for cpu, sync block io, swapping etc. The collection of statistics and the interface are in other patches. This patch sets up the data structures and allows the statistics collection to be disabled through a kernel boot parameter. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] list_is_last utilityShailabh Nagar
Add another list utility function to check for last element in a list. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] mbxfb: Add framebuffer driver for the Intel 2700GMike Rapoport
Add frame buffer driver for the 2700G LCD controller present on CompuLab CM-X270 computer module. [adaplas] - Add more informative help text to Kconfig - Make DEBUG a Kconfig option as FB_MBX_DEBUG - Remove #include mbxdebug.c, this is frowned upon - Remove redundant casts - Arrange #include's alphabetically - Trivial whitespace Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] Fix security check for joint context= and fscontext= mount optionsEric Paris
After some discussion on the actual meaning of the filesystem class security check in try context mount it was determined that the checks for the context= mount options were not correct if fscontext mount option had already been used. When labeling the superblock we should be checking relabel_from and relabel_to. But if the superblock has already been labeled (with fscontext) then context= is actually labeling the inodes, and so we should be checking relabel_from and associate. This patch fixes which checks are called depending on the mount options. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] let the the lockdep options depend on DEBUG_KERNELAdrian Bunk
The lockdep options should depend on DEBUG_KERNEL since: - they are kernel debugging options and - they do otherwise break the DEBUG_KERNEL menu structure Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] tpm_tis: use resource_size_tKylene Jo Hall
Fix the start and len variables that should be using the new resource_size_t. Signed_off_by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] tpm: Add force device probe optionKylene Jo Hall
Some machine manufacturers are not sticking to the TCG specifications and including an ACPI DSDT entry for the TPM which allows PNP discovery of the device. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
