Replace occurences of the pci api by appropriate call to the dma api.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
@deprecated@
idexpression id;
position p;
pci_dma_supported@p ( id, ...)
pci_alloc_consistent@p ( id, ...)
@bad1@
idexpression id;
position deprecated.p;
...when != &id->dev
when != pci_get_drvdata ( id )
when != pci_enable_device ( id )
@depends on !bad1@
idexpression id;
expression direction;
- pci_dma_supported@p ( id,
+ dma_supported ( &id->dev,
+ , GFP_ATOMIC
- pci_alloc_consistent@p ( id,
+ dma_alloc_coherent ( &id->dev,
+ , GFP_ATOMIC
Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com>
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: Greg KH <greg@kroah.com>
err is only assigned to -EIO. Return that value at the end of fail
context.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
bh is initialized unconditionally in affs_remove_link()
bh is initialized unconditionally in affs_add_entry()
kmem_cache_alloc() returns void*.
Signed-off-by: Firo Yang <firogm@gmail.com>
Fix kernel gcov support for GCC 5.1. Similar to commit a992bf836f9
("gcov: add support for GCC 4.9"), this patch takes into account the
existence of a new gcov counter (see gcc's gcc/gcov-counter.def.)
Firstly, it increments GCOV_COUNTERS (to 10), which makes the data
structure struct gcov_info compatible with GCC 5.1.
Secondly, a corresponding counter function __gcov_merge_icall_topn (Top N
value tracking for indirect calls) is included in base.c with the other
gcov counters unused for kernel profiling.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Cc: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Yuan Pengfei <coolypf@qq.com>
Tested-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Commit f06e5153f4ae2e ("kernel/panic.c: add "crash_kexec_post_notifiers"
option for kdump after panic_notifers") introduced
"crash_kexec_post_notifiers" kernel boot option, which toggles wheather
panic() calls crash_kexec() before panic_notifiers and dump kmsg or after.
The problem is that the commit overlooks panic_on_oops kernel boot option.
If it is enabled, crash_kexec() is called directly without going through
panic() in oops path.
To fix this issue, this patch adds a check to "crash_kexec_post_notifiers"
in the condition of kexec_should_crash().
Also, put a comment in kexec_should_crash() to explain not obvious things
on this patch.
Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com>
Acked-by: Baoquan He <bhe@redhat.com>
Tested-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
Cc: Baoquan He <bhe@redhat.com>
is enabled
For compatibility with the behaviour before the commit f06e5153f4ae2e
("kernel/panic.c: add "crash_kexec_post_notifiers" option for kdump after
panic_notifers"), the 2nd crash_kexec() should be called only if
crash_kexec_post_notifiers is enabled.
Note that crash_kexec() returns immediately if kdump crash kernel is not
loaded, so in this case, this patch makes no functionality change, but the
point is to make it explicit, from the caller panic() side, that the 2nd
crash_kexec() does nothing.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
command-line.
Any parameter passed after '--' in the kernel command-line will not be
parsed by the kernel at all, instead it will be passed directly to init
process.
Currently the kernel appends elfcorehdr=<paddr> to the cmdline passed from
kexec load, and if this command-line is used to pass parameters to init
process this means that 'elfcorehdr' will not be parsed as a kernel
parameter at all which will be a problem for vmcore subsystem since it
will know nothing about the location of the ELF structure!
Prepending 'elfcorehdr' instead of appending it fixes this problem since
it ensures that it always comes before '--' and so it's always parsed as a
kernel command-line parameter.
Even with this patch things can still go wrong if 'CONFIG_CMDLINE' was
also used to embedd a command-line to the crash dump kernel and this
command-line contains '--' since the current behavior of the kernel is to
actually append the boot loader command-line to the embedded command-line.
Signed-off-by: KarimAllah Ahmed <karahmed@amazon.de>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Haren Myneni <hbabu@us.ibm.com>
Cc: Eric Biederman <ebiederm@xmission.com>
seq_open() stores its struct seq_file in file->private_data, thus it must
not be modified by user of seq_file.
Link: http://lkml.kernel.org/r/cover.1433193673.git.ydroneaud@opteya.com
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Since patch described below, from v2.6.15-rc1, seq_open() could use a
struct seq_file already allocated by the caller if the pointer to the
structure is stored in file->private_data before calling the function.
Commit 1abe77b0fc4b485927f1f798ae81a752677e1d05
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Mon Nov 7 17:15:34 2005 -0500
[PATCH] allow callers of seq_open do allocation themselves
Allow caller of seq_open() to kmalloc() seq_file + whatever else they
want and set ->private_data to it. seq_open() will then abstain from
doing allocation itself.
As there's no more use for such feature, as it could be easily replaced by
calls to seq_open_private() (see commit 39699037a5c9 ("[FS] seq_file:
Introduce the seq_open_private()")) and seq_release_private() (see
v2.6.0-test3), support for this uncommon feature can be removed from
seq_open().
A patchset to remove support for passing pre-allocated struct seq_file to
seq_open(). Such feature is undocumented and prone to error.
In particular, if seq_release() is used in release handler, it will
kfree() a pointer which was not allocated by seq_open().
So this patchset drops support for pre-allocated struct seq_file: it's
only of use in proc_namespace.c and can be easily replaced by using
seq_open_private()/seq_release_private().
Additionally, it documents the use of file->private_data to hold pointer
to struct seq_file by seq_open().
This patch (of 3):
Such behavior is only used by mounts_open_common().
In order to drop support for such uncommon feature, proc_mounts is
converted to use seq_open_private(), which take care of allocating the
proc_mounts structure, making it available through ->private in struct
seq_file.
Conversely, proc_mounts is converted to use seq_release_private(), in
order to release the private structure allocated by seq_open_private().
Then, ->private is used directly instead of proc_mounts() macro to access
to the proc_mounts structure.
Waiman Long reported that 24TB machines hit OOM during basic setup when
struct page initialisation was deferred. One approach is to initialise
memory on demand but it interferes with page allocator paths. This patch
creates dedicated threads to initialise memory before basic setup. It
then blocks on a rw_semaphore until completion as a wait_queue and counter
is overkill. This may be slower to boot but it's simplier overall and
also gets rid of a section mangling which existed so kswapd could do the
initialisation.
[akpm@linux-foundation.org: include rwsem.h, use DECLARE_RWSEM, fix comment, remove unneeded cast]
Cc: Waiman Long <waiman.long@hp.com
Cc: Nathan Zimmer <nzimmer@sgi.com>
Cc: Scott Norton <scott.norton@hp.com>
Tested-by: Daniel J Blueman <daniel@numascale.com>
mminit_verify_page_links() is an extremely paranoid check that was
introduced when memory initialisation was being heavily reworked.
Profiles indicated that up to 10% of parallel memory initialisation was
spent on checking this for every page. The cost could be reduced but in
practice this check only found problems very early during the
initialisation rewrite and has found nothing since. This patch removes an
expensive unnecessary check.
Tested-by: Nate Zimmer <nzimmer@sgi.com>
Tested-by: Waiman Long <waiman.long@hp.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Nate Zimmer <nzimmer@sgi.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
During parallel sturct page initialisation, ranges are checked for every
PFN unnecessarily which increases boot times. This patch alters when the
ranges are checked.
Parallel struct page frees pages one at a time. Try free pages as single
large pages where possible.
Subject says it all. Other architectures may enable on a case-by-case
basis after auditing early_pfn_to_nid and testing.
Deferred struct page initialisation is using pfn_to_page() on every PFN
unnecessarily. This patch minimises the number of lookups and scheduler
checks.
Only a subset of struct pages are initialised at the moment. When this
patch is applied kswapd initialise the remaining struct pages in parallel.
This should boot faster by spreading the work to multiple CPUs and
initialising data that is local to the CPU. The user-visible effect on
large machines is that free memory will appear to rapidly increase early
in the lifetime of the system until kswapd reports that all memory is
initialised in the kernel log. Once initialised there should be no other
user-visibile effects.
CONFIG_DEFERRED_STRUCT_PAGE_INIT is set
This patch initalises all low memory struct pages and 2G of the highest
zone on each node during memory initialisation if
CONFIG_DEFERRED_STRUCT_PAGE_INIT is set. That config option cannot be set
but will be available in a later patch. Parallel initialisation of struct
page depends on some features from memory hotplug and it is necessary to
alter alter section annotations.
early_pfn_in_nid() and meminit_pfn_in_nid() are small functions that are
unnecessarily visible outside memory initialisation. As well as
unnecessary visibility, it's unnecessary function call overhead when
initialising pages. This patch moves the helpers inline.
[akpm@linux-foundation.org: fix build]
[mhocko@suse.cz: fix build]
__early_pfn_to_nid() use static variables to cache recent lookups as
memblock lookups are very expensive but it assumes that memory
initialisation is single-threaded. Parallel initialisation of struct
pages will break that assumption so this patch makes __early_pfn_to_nid()
SMP-safe by requiring the caller to cache recent search information.
early_pfn_to_nid() keeps the same interface but is only safe to use early
in boot due to the use of a global static variable. meminit_pfn_in_nid()
is an SMP-safe version that callers must maintain their own state for.
__free_pages_bootmem prepares a page for release to the buddy allocator
and assumes that the struct page is initialised. Parallel initialisation
of struct pages defers initialisation and __free_pages_bootmem can be
called for struct pages that cannot yet map struct page to PFN. This
patch passes PFN to __free_pages_bootmem with no other functional change.
Currently each page struct is set as reserved upon initialization. This
patch leaves the reserved bit clear and only sets the reserved bit when it
is known the memory was allocated by the bootmem allocator. This makes it
easier to distinguish between uninitialised struct pages and reserved
struct pages in later patches.
Signed-off-by: Robin Holt <holt@sgi.com>
Signed-off-by: Nathan Zimmer <nzimmer@sgi.com>
Currently, memmap_init_zone() has all the smarts for initializing a single
page. A subset of this is required for parallel page initialisation and
so this patch breaks up the monolithic function in preparation.
Struct page initialisation had been identified as one of the reasons why
large machines take a long time to boot. Patches were posted a long time ago
to defer initialisation until they were first used. This was rejected on
the grounds it should not be necessary to hurt the fast paths. This series
reuses much of the work from that time but defers the initialisation of
memory to kswapd so that one thread per node initialises memory local to
that node.
After applying the series and setting the appropriate Kconfig variable I
see this in the boot log on a 64G machine
[ 7.383764] kswapd 0 initialised deferred memory in 188ms
[ 7.404253] kswapd 1 initialised deferred memory in 208ms
[ 7.411044] kswapd 3 initialised deferred memory in 216ms
[ 7.411551] kswapd 2 initialised deferred memory in 216ms
On a 1TB machine, I see
[ 8.406511] kswapd 3 initialised deferred memory in 1116ms
[ 8.428518] kswapd 1 initialised deferred memory in 1140ms
[ 8.435977] kswapd 0 initialised deferred memory in 1148ms
[ 8.437416] kswapd 2 initialised deferred memory in 1148ms
Once booted the machine appears to work as normal. Boot times were measured
from the time shutdown was called until ssh was available again. In the
64G case, the boot time savings are negligible. On the 1TB machine, the
savings were 16 seconds.
Nate Zimmer said:
: On an older 8 TB box with lots and lots of cpus the boot time, as
: measure from grub to login prompt, the boot time improved from 1484
: seconds to exactly 1000 seconds.
Waiman Long said:
: I ran a bootup timing test on a 12-TB 16-socket IvyBridge-EX system. From
: grub menu to ssh login, the bootup time was 453s before the patch and 265s
: after the patch - a saving of 188s (42%).
Daniel Blueman said:
: On a 7TB, 1728-core NumaConnect system with 108 NUMA nodes, we're seeing
: stock 4.0 boot in 7136s. This drops to 2159s, or a 70% reduction with
: this patchset. Non-temporal PMD init (https://lkml.org/lkml/2015/4/23/350)
: drops this to 1045s.
This patch (of 13):
As part of initializing struct page's in 2MiB chunks, we noticed that at
the end of free_all_bootmem(), there was nothing which had forced the
reserved/allocated 4KiB pages to be initialized.
This helper function will be used for that expansion.
Signed-off-by: Nate Zimmer <nzimmer@sgi.com>
Pull md updates from Neil Brown:
"A mixed bag
- a few bug fixes
- some performance improvement that decrease lock contention
- some clean-up
Nothing major"
* tag 'md/4.2' of git://neil.brown.name/md:
md: clear Blocked flag on failed devices when array is read-only.
md: unlock mddev_lock on an error path.
md: clear mddev->private when it has been freed.
md: fix a build warning
md/raid5: ignore released_stripes check
md/raid5: per hash value and exclusive wait_for_stripe
md/raid5: split wait_for_stripe and introduce wait_for_quiescent
wait: introduce wait_event_exclusive_cmd
md: convert to kstrto*()
md/raid10: make sync_request_write() call bio_copy_data()
This patch restores the slab creation sequence that was broken by commit
4066c33d0308f8 and also reverts the portions that introduced the
KMALLOC_LOOP_XXX macros. Those can never really work since the slab creation
is much more complex than just going from a minimum to a maximum number.
The latest upstream kernel boots cleanly on my machine with a 64 bit x86
configuration under KVM using either SLAB or SLUB.
Fixes: 4066c33d0308f8 ("support the slub_debug boot option")
Reported-by: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: Christoph Lameter <cl@linux.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm
Pull libnvdimm subsystem from Dan Williams:
"The libnvdimm sub-system introduces, in addition to the
libnvdimm-core, 4 drivers / enabling modules:
NFIT:
Instantiates an "nvdimm bus" with the core and registers memory
devices (NVDIMMs) enumerated by the ACPI 6.0 NFIT (NVDIMM Firmware
Interface table).
After registering NVDIMMs the NFIT driver then registers "region"
devices. A libnvdimm-region defines an access mode and the
boundaries of persistent memory media. A region may span multiple
NVDIMMs that are interleaved by the hardware memory controller. In
turn, a libnvdimm-region can be carved into a "namespace" device and
bound to the PMEM or BLK driver which will attach a Linux block
device (disk) interface to the memory.
PMEM:
Initially merged in v4.1 this driver for contiguous spans of
persistent memory address ranges is re-worked to drive
PMEM-namespaces emitted by the libnvdimm-core.
In this update the PMEM driver, on x86, gains the ability to assert
that writes to persistent memory have been flushed all the way
through the caches and buffers in the platform to persistent media.
See memcpy_to_pmem() and wmb_pmem().
BLK:
This new driver enables access to persistent memory media through
"Block Data Windows" as defined by the NFIT. The primary difference
of this driver to PMEM is that only a small window of persistent
memory is mapped into system address space at any given point in
time.
Per-NVDIMM windows are reprogrammed at run time, per-I/O, to access
different portions of the media. BLK-mode, by definition, does not
support DAX.
BTT:
This is a library, optionally consumed by either PMEM or BLK, that
converts a byte-accessible namespace into a disk with atomic sector
update semantics (prevents sector tearing on crash or power loss).
The sinister aspect of sector tearing is that most applications do
not know they have a atomic sector dependency. At least today's
disk's rarely ever tear sectors and if they do one almost certainly
gets a CRC error on access. NVDIMMs will always tear and always
silently. Until an application is audited to be robust in the
presence of sector-tearing the usage of BTT is recommended.
Thanks to: Ross Zwisler, Jeff Moyer, Vishal Verma, Christoph Hellwig,
Ingo Molnar, Neil Brown, Boaz Harrosh, Robert Elliott, Matthew Wilcox,
Andy Rudoff, Linda Knippers, Toshi Kani, Nicholas Moulin, Rafael
Wysocki, and Bob Moore"
* tag 'libnvdimm-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm: (33 commits)
arch, x86: pmem api for ensuring durability of persistent memory updates
libnvdimm: Add sysfs numa_node to NVDIMM devices
libnvdimm: Set numa_node to NVDIMM devices
acpi: Add acpi_map_pxm_to_online_node()
libnvdimm, nfit: handle unarmed dimms, mark namespaces read-only
pmem: flag pmem block devices as non-rotational
libnvdimm: enable iostat
pmem: make_request cleanups
libnvdimm, pmem: fix up max_hw_sectors
libnvdimm, blk: add support for blk integrity
libnvdimm, btt: add support for blk integrity
fs/block_dev.c: skip rw_page if bdev has integrity
libnvdimm: Non-Volatile Devices
tools/testing/nvdimm: libnvdimm unit test infrastructure
libnvdimm, nfit, nd_blk: driver for BLK-mode access persistent memory
nd_btt: atomic sector updates
libnvdimm: infrastructure for btt devices
libnvdimm: write blk label set
libnvdimm: write pmem label set
libnvdimm: blk labels and namespace instantiation
Pull dmaengine updates from Vinod Koul:
"This time we have support for few new devices, few new features and
odd fixes spread thru the subsystem.
New devices added:
- support for CSRatlas7 dma controller
- Allwinner H3(sun8i) controller
- TI DMA crossbar driver on DRA7x
- new pxa driver
New features added:
- memset support is bought back now that we have a user in xdmac controller
- interleaved transfers support different source and destination strides
- supporting DMA routers and configuration thru DT
- support for reusing descriptors
- xdmac memset and interleaved transfer support
- hdmac support for interleaved transfers
- omap-dma support for memcpy
Others:
- Constify platform_device_id
- mv_xor fixes and improvements"
* tag 'dmaengine-4.2-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (46 commits)
dmaengine: xgene: fix file permission
dmaengine: fsl-edma: clear pending interrupts on initialization
dmaengine: xdmac: Add memset support
Documentation: dmaengine: document DMA_CTRL_ACK
dmaengine: virt-dma: don't always free descriptor upon completion
dmaengine: Revert "drivers/dma: remove unused support for MEMSET operations"
dmaengine: hdmac: Implement interleaved transfers
dmaengine: Move icg helpers to global header
dmaengine: mv_xor: improve descriptors list handling and reduce locking
dmaengine: mv_xor: Enlarge descriptor pool size
dmaengine: mv_xor: add support for a38x command in descriptor mode
dmaengine: mv_xor: Rename function for consistent naming
dmaengine: mv_xor: bug fix for racing condition in descriptors cleanup
dmaengine: pl330: fix wording in mcbufsz message
dmaengine: sirf: add CSRatlas7 SoC support
dmaengine: xgene-dma: Fix "incorrect type in assignement" warnings
dmaengine: fix kernel-doc documentation
dmaengine: pxa_dma: add support for legacy transition
dmaengine: pxa_dma: add debug information
dmaengine: pxa: add pxa dmaengine driver
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull ia64 updates from Tony Luck:
"Pair of ia64 cleanups"
* tag 'please-pull-misc-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
ia64: Use setup_timer
ia64: export flush_icache_range for module use
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest
Pull kselftest update from Shuah Khan:
"This update adds two new test suites: futex and seccomp.
In addition, it includes fixes for bugs in timers, other tests, and
compile framework. It introduces new quicktest feature to enable
users to choose to run tests that complete in a short time"
* tag 'linux-kselftest-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest:
selftests: add quicktest support
selftests: add seccomp suite
selftest, x86: fix incorrect comment
tools selftests: Fix 'clean' target with make 3.81
selftests/futex: Add .gitignore
kselftest: Add exit code defines
selftests: Add futex tests to the top-level Makefile
selftests/futex: Increment ksft pass and fail counters
selftests/futex: Update Makefile to use lib.mk
selftests: Add futex functional tests
kselftests: timers: Check _ALARM clockids are supported before suspending
kselftests: timers: Ease alarmtimer-suspend unreasonable latency value
kselftests: timers: Increase delay between suspends in alarmtimer-suspend
selftests/exec: do not install subdir as it is already created
selftests/ftrace: install test.d
selftests: copy TEST_DIRS to INSTALL_PATH
Test compaction of mlocked memory
selftests/mount: output WARN messages when mount test skipped
selftests/timers: Make git ignore all binaries in timers test suite
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
Pull m68knommu updates from Greg Ungerer:
"Only a couple of small changes.
Improved the m68knommu MAINTAINERS entry to make it clearer which m68k
parts this applies to, and a print format clean up"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68k: improve m68knommu MAINTAINERS entry
m68k: Use vsprintf %pM extension
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml
Pull UML updates from Richard Weinberger:
- remove hppfs ("HonePot ProcFS")
- initial support for musl libc
- uaccess cleanup
- random cleanups and bug fixes all over the place
* 'for-linus-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml: (21 commits)
um: Don't pollute kernel namespace with uapi
um: Include sys/types.h for makedev(), major(), minor()
um: Do not use stdin and stdout identifiers for struct members
um: Do not use __ptr_t type for stack_t's .ss pointer
um: Fix mconsole dependency
um: Handle tracehook_report_syscall_entry() result
um: Remove copy&paste code from init.h
um: Stop abusing __KERNEL__
um: Catch unprotected user memory access
um: Fix warning in setup_signal_stack_si()
um: Rework uaccess code
um: Add uaccess.h to ldt.c
um: Add uaccess.h to syscalls_64.c
um: Add asm/elf.h to vma.c
um: Cleanup mem_32/64.c headers
um: Remove hppfs
um: Move syscall() declaration into os.h
um: kernel: ksyms: Export symbol syscall() for fixing modpost issue
um/os-Linux: Use char[] for syscall_stub declarations
um: Use char[] for linker script address declarations
Pull VFIO updates from Alex Williamson:
- fix race with device reference versus driver release (Alex Williamson)
- add reset hooks and Calxeda xgmac reset for vfio-platform (Eric Auger)
- enable vfio-platform for ARM64 (Eric Auger)
- tag Baptiste Reynal as vfio-platform sub-maintainer (Alex Williamson)
* tag 'vfio-v4.2-rc1' of git://github.com/awilliam/linux-vfio:
MAINTAINERS: Add vfio-platform sub-maintainer
VFIO: platform: enable ARM64 build
VFIO: platform: Calxeda xgmac reset module
VFIO: platform: populate the reset function on probe
VFIO: platform: add reset callback
VFIO: platform: add reset struct and lookup table
vfio/pci: Fix racy vfio_device_get_from_dev() call
Pull audit updates from Paul Moore:
"Four small audit patches for v4.2, all bug fixes. Only 10 lines of
change this time so very unremarkable, the patch subject lines pretty
much tell the whole story"
* 'upstream' of git://git.infradead.org/users/pcmoore/audit:
audit: Fix check of return value of strnlen_user()
audit: obsolete audit_context check is removed in audit_filter_rules()
audit: fix for typo in comment to function audit_log_link_denied()
lsm: rename duplicate labels in LSM_AUDIT_DATA_TASK audit message type
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"The main change in this kernel is Casey's generalized LSM stacking
work, which removes the hard-coding of Capabilities and Yama stacking,
allowing multiple arbitrary "small" LSMs to be stacked with a default
monolithic module (e.g. SELinux, Smack, AppArmor).
See
https://lwn.net/Articles/636056/
This will allow smaller, simpler LSMs to be incorporated into the
mainline kernel and arbitrarily stacked by users. Also, this is a
useful cleanup of the LSM code in its own right"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits)
tpm, tpm_crb: fix le64_to_cpu conversions in crb_acpi_add()
vTPM: set virtual device before passing to ibmvtpm_reset_crq
tpm_ibmvtpm: remove unneccessary message level.
ima: update builtin policies
ima: extend "mask" policy matching support
ima: add support for new "euid" policy condition
ima: fix ima_show_template_data_ascii()
Smack: freeing an error pointer in smk_write_revoke_subj()
selinux: fix setting of security labels on NFS
selinux: Remove unused permission definitions
selinux: enable genfscon labeling for sysfs and pstore files
selinux: enable per-file labeling for debugfs files.
selinux: update netlink socket classes
signals: don't abuse __flush_signals() in selinux_bprm_committed_creds()
selinux: Print 'sclass' as string when unrecognized netlink message occurs
Smack: allow multiple labels in onlycap
Smack: fix seq operations in smackfs
ima: pass iint to ima_add_violation()
ima: wrap event related data to the new ima_event_data structure
integrity: add validity checks for 'path' parameter
Pull MIPS updates from Ralf Baechle:
- Improvements to the tlb_dump code
- KVM fixes
- Add support for appended DTB
- Minor improvements to the R12000 support
- Various platform improvments for BCM47xx
- The usual pile of minor cleanups
- A number of BPF fixes and improvments
- Some improvments to the support for R3000 and DECstations
- Some improvments to the ATH79 platform support
- A major patchset for the JZ4740 SOC adding support for the CI20 platform
- Add support for the Pistachio SOC
- Minor BMIPS/BCM63xx platform support improvments.
- Avoid "SYNC 0" as memory barrier when unlocking spinlocks
- Add support for the XWR-1750 board.
- Paul's __cpuinit/__cpuinitdata cleanups.
- New Malta CPU board support large memory so enable ZONE_DMA32.
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (131 commits)
MIPS: spinlock: Adjust arch_spin_lock back-off time
MIPS: asmmacro: Ensure 64-bit FP registers are used with MSA
MIPS: BCM47xx: Simplify handling SPROM revisions
MIPS: Cobalt Don't use module_init in non-modular MTD registration.
MIPS: BCM47xx: Move NVRAM driver to the drivers/firmware/
MIPS: use for_each_sg()
MIPS: BCM47xx: Don't select BCMA_HOST_PCI
MIPS: BCM47xx: Add helper variable for storing NVRAM length
MIPS: IRQ/IP27: Move IRQ allocation API to platform code.
MIPS: Replace smp_mb with release barrier function in unlocks.
MIPS: i8259: DT support
MIPS: Malta: Basic DT plumbing
MIPS: include errno.h for ENODEV in mips-cm.h
MIPS: Define GCR_GIC_STATUS register fields
MIPS: BPF: Introduce BPF ASM helpers
MIPS: BPF: Use BPF register names to describe the ABI
MIPS: BPF: Move register definition to the BPF header
MIPS: net: BPF: Replace RSIZE with SZREG
MIPS: BPF: Free up some callee-saved registers
MIPS: Xtalk: Update xwidget.h with known Xtalk device numbers
Pull nfsd updates from Bruce Fields:
"A relatively quiet cycle, with a mix of cleanup and smaller bugfixes"
* 'for-4.2' of git://linux-nfs.org/~bfields/linux: (24 commits)
sunrpc: use sg_init_one() in krb5_rc4_setup_enc/seq_key()
nfsd: wrap too long lines in nfsd4_encode_read
nfsd: fput rd_file from XDR encode context
nfsd: take struct file setup fully into nfs4_preprocess_stateid_op
nfsd: refactor nfs4_preprocess_stateid_op
nfsd: clean up raparams handling
nfsd: use swap() in sort_pacl_range()
rpcrdma: Merge svcrdma and xprtrdma modules into one
svcrdma: Add a separate "max data segs macro for svcrdma
svcrdma: Replace GFP_KERNEL in a loop with GFP_NOFAIL
svcrdma: Keep rpcrdma_msg fields in network byte-order
svcrdma: Fix byte-swapping in svc_rdma_sendto.c
nfsd: Update callback sequnce id only CB_SEQUENCE success
nfsd: Reset cb_status in nfsd4_cb_prepare() at retrying
svcrdma: Remove svc_rdma_xdr_decode_deferred_req()
SUNRPC: Move EXPORT_SYMBOL for svc_process
uapi/nfs: Add NFSv4.1 ACL definitions
nfsd: Remove dead declarations
nfsd: work around a gcc-5.1 warning
nfsd: Checking for acl support does not require fetching any acls
git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2
Pull GFS2 updates from Bob Peterson:
"Here are the patches we've accumulated for GFS2 for the current
upstream merge window. We have a good mixture this time. Here are
some of the features:
- Fix a problem with RO mounts writing to the journal.
- Further improvements to quotas on GFS2.
- Added support for rename2 and RENAME_EXCHANGE on GFS2.
- Increase performance by making glock lru_list less of a bottleneck.
- Increase performance by avoiding unnecessary buffer_head releases.
- Increase performance by using average glock round trip time from all CPUs.
- Fixes for some compiler warnings and minor white space issues.
- Other misc bug fixes"
* tag 'gfs2-merge-window' of git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Don't brelse rgrp buffer_heads every allocation
GFS2: Don't add all glocks to the lru
gfs2: Don't support fallocate on jdata files
gfs2: s64 cast for negative quota value
gfs2: limit quota log messages
gfs2: fix quota updates on block boundaries
gfs2: fix shadow warning in gfs2_rbm_find()
gfs2: kerneldoc warning fixes
gfs2: convert simple_str to kstr
GFS2: make sure S_NOSEC flag isn't overwritten
GFS2: add support for rename2 and RENAME_EXCHANGE
gfs2: handle NULL rgd in set_rgrp_preferences
GFS2: inode.c: indent with TABs, not spaces
GFS2: mark the journal idle to fix ro mounts
GFS2: Average in only non-zero round-trip times for congestion stats
GFS2: Use average srttb value in congestion calculations
This reverts commit 2143c1965a761332ae417b22fd477b636e4f54ec.
This commit seems to be the cause of the following jbd2 assertion
failure:
kernel BUG at fs/jbd2/transaction.c:1325!
invalid opcode: 0000 [#1] SMP
Modules linked in: bnep bluetooth fuse ip6t_rpfilter ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 ...
CPU: 7 PID: 5509 Comm: gcc Not tainted 4.1.0-10944-g2a298679b411 #1
Hardware name: /DH87RL, BIOS RLH8710H.86A.0327.2014.0924.1645 09/24/2014
task: ffff8803bf866040 ti: ffff880308528000 task.ti: ffff880308528000
RIP: jbd2_journal_dirty_metadata+0x237/0x290
Call Trace:
__ext4_handle_dirty_metadata+0x43/0x1f0
ext4_handle_dirty_dirent_node+0xde/0x160
? jbd2_journal_get_write_access+0x36/0x50
ext4_delete_entry+0x112/0x160
? __ext4_journal_start_sb+0x52/0xb0
ext4_unlink+0xfa/0x260
vfs_unlink+0xec/0x190
do_unlinkat+0x24a/0x270
SyS_unlink+0x11/0x20
entry_SYSCALL_64_fastpath+0x12/0x6a
---[ end trace ae033ebde8d080b4 ]---
which is not easily reproducible (I've seen it just once, and then Ted
was able to reproduce it once). Revert it while Ted and Jan try to
figure out what is wrong.
Cc: Jan Kara <jack@suse.cz>
Acked-by: Theodore Ts'o <tytso@mit.edu>
Pull workqueue updates from Tejun Heo:
"Most of the changes are around implementing and fixing fallouts from
sysfs and internal interface to limit the CPUs available to all
unbound workqueues to help isolating CPUs. It needs more work as
ordered workqueues can roam unrestricted but still is a significant
improvement"
* 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: fix typos in comments
workqueue: move flush_scheduled_work() to workqueue.h
workqueue: remove the lock from wq_sysfs_prep_attrs()
workqueue: remove the declaration of copy_workqueue_attrs()
workqueue: ensure attrs changes are properly synchronized
workqueue: separate out and refactor the locking of applying attrs
workqueue: simplify wq_update_unbound_numa()
workqueue: wq_pool_mutex protects the attrs-installation
workqueue: fix a typo
workqueue: function name in the comment differs from the real function name
workqueue: fix trivial typo in Documentation/workqueue.txt
workqueue: Allow modifying low level unbound workqueue cpumask
workqueue: Create low-level unbound workqueues cpumask
workqueue: split apply_workqueue_attrs() into 3 stages
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
- threadgroup_lock got reorganized so that its users can pick the
actual locking mechanism to use. Its only user - cgroups - is
updated to use a percpu_rwsem instead of per-process rwsem.
This makes things a bit lighter on hot paths and allows cgroups to
perform and fail multi-task (a process) migrations atomically.
Multi-task migrations are used in several places including the
unified hierarchy.
- Delegation rule and documentation added to unified hierarchy. This
will likely be the last interface update from the cgroup core side
for unified hierarchy before lifting the devel mask.
- Some groundwork for the pids controller which is scheduled to be
merged in the coming devel cycle.
* 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: add delegation section to unified hierarchy documentation
cgroup: require write perm on common ancestor when moving processes on the default hierarchy
cgroup: separate out cgroup_procs_write_permission() from __cgroup_procs_write()
kernfs: make kernfs_get_inode() public
MAINTAINERS: add a cgroup core co-maintainer
cgroup: fix uninitialised iterator in for_each_subsys_which
cgroup: replace explicit ss_mask checking with for_each_subsys_which
cgroup: use bitmask to filter for_each_subsys
cgroup: add seq_file forward declaration for struct cftype
cgroup: simplify threadgroup locking
sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem
sched, cgroup: reorganize threadgroup locking
cgroup: switch to unsigned long for bitmasks
cgroup: reorganize include/linux/cgroup.h
cgroup: separate out include/linux/cgroup-defs.h
cgroup: fix some comment typos
Caused by commit 843735b788a4 ("power: axp288_charger: axp288 charger
driver") from the battery tree interacting with commit 046050f6e623
("extcon: Update the prototype of extcon_register_notifier() with enum
extcon") from the extcon tree.
git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf
Pull dma-buf updates from Sumit Semwal:
"Minor changes for 4.2
- add ref-counting for kernel modules as exporters
- minor code style fixes"
* tag 'dma-buf-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf:
dma-buf: Minor coding style fixes
dma-buf: add ref counting for module as exporter
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big USB patchset for 4.2-rc1. As is normal these days, the
majority of changes are in the gadget drivers, with a bunch of other
small driver changes.
All of these have been in linux-next with no reported issues"
* tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits)
usb: dwc3: Use ASCII space in Kconfig
usb: chipidea: add work-around for Marvell HSIC PHY startup
usb: chipidea: allow multiple instances to use default ci_default_pdata
dt-bindings: Consolidate ChipIdea USB ci13xxx bindings
phy: add Marvell HSIC 28nm PHY
phy: Add Marvell USB 2.0 OTG 28nm PHY
dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings
USB: ssb: use devm_kzalloc
USB: ssb: fix error handling in ssb_hcd_create_pdev()
usb: isp1760: check for null return from kzalloc
cdc-acm: Add support of ATOL FPrint fiscal printers
usb: chipidea: usbmisc_imx: Remove unneeded semicolon
USB: usbtmc: add device quirk for Rigol DS6104
USB: serial: mos7840: Use setup_timer
phy: twl4030-usb: add ABI documentation
phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function.
phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback.
phy: twl4030-usb: make runtime pm more reliable.
drivers:usb:fsl: Fix compilation error for fsl ehci drv
usb: renesas_usbhs: Don't disable the pipe if Control write status stage
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here's the tty and serial driver patches for 4.2-rc1.
A number of individual driver updates, some code cleanups, and other
minor things, full details in the shortlog.
All have been in linux-next for a while with no reported issues"
* tag 'tty-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (152 commits)
Doc: serial-rs485.txt: update RS485 driver interface
Doc: tty.txt: remove mention of the BKL
MAINTAINERS: tty: add serial docs directory
serial: sprd: check for NULL after calling devm_clk_get
serial: 8250_pci: Correct uartclk for xr17v35x expansion chips
serial: 8250_pci: Add support for 12 port Exar boards
serial: 8250_uniphier: add bindings document for UniPhier UART
serial: core: cleanup in uart_get_baud_rate()
serial: stm32-usart: Add STM32 USART Driver
tty/serial: kill off set_irq_flags usage
tty: move linux/gsmmux.h to uapi
doc: dt: add documentation for nxp,lpc1850-uart
serial: 8250: add LPC18xx/43xx UART driver
serial: 8250_uniphier: add UniPhier serial driver
serial: 8250_dw: support ACPI platforms with integrated DMA engine
serial: of_serial: check the return value of clk_prepare_enable()
serial: of_serial: use devm_clk_get() instead of clk_get()
serial: earlycon: Add support for big-endian MMIO accesses
serial: sirf: use hrtimer for data rx
serial: sirf: correct the fifo empty_bit
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big, really big, staging tree patches for 4.2-rc1.
Loads of stuff in here, almost all just coding style fixes / churn,
and a few new drivers as well, one of which I just disabled from the
build a few minutes ago due to way too many build warnings.
Other than the one "disable this driver" patch, all of these have been
in linux-next for quite a while with no reported issues"
* tag 'staging-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1163 commits)
staging: wilc1000: disable driver due to build warnings
Staging: rts5208: fix CHANGE_LINK_STATE value
Staging: sm750fb: ddk750_swi2c.c: Insert spaces before parenthesis
Staging: sm750fb: ddk750_swi2c.c: Place braces on correct lines
Staging: sm750fb: ddk750_swi2c.c: Insert spaces around operators
Staging: sm750fb: ddk750_swi2c.c: Replace spaces with tabs
Staging: sm750fb: ddk750_swi2c.h: Shorten lines to under 80 characters
Staging: sm750fb: ddk750_swi2c.h: Replace spaces with tabs
Staging: sm750fb: modedb.h: Shorten lines to under 80 characters
Staging: sm750fb: modedb.h: Replace spaces with tabs
staging: comedi: addi_apci_3120: rename 'this_board' variables
staging: comedi: addi_apci_1516: rename 'this_board' variables
staging: comedi: ni_atmio: cleanup ni_getboardtype()
staging: comedi: vmk80xx: sanity check context used to get the boardinfo
staging: comedi: vmk80xx: rename 'boardinfo' variables
staging: comedi: dt3000: rename 'this_board' variables
staging: comedi: adv_pci_dio: rename 'this_board' variables
staging: comedi: cb_pcidas64: rename 'thisboard' variables
staging: comedi: cb_pcidas: rename 'thisboard' variables
staging: comedi: me4000: rename 'thisboard' variables
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the driver core / firmware changes for 4.2-rc1.
A number of small changes all over the place in the driver core, and
in the firmware subsystem. Nothing really major, full details in the
shortlog. Some of it is a bit of churn, given that the platform
driver probing changes was found to not work well, so they were
reverted.
All of these have been in linux-next for a while with no reported
issues"
* tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits)
Revert "base/platform: Only insert MEM and IO resources"
Revert "base/platform: Continue on insert_resource() error"
Revert "of/platform: Use platform_device interface"
Revert "base/platform: Remove code duplication"
firmware: add missing kfree for work on async call
fs: sysfs: don't pass count == 0 to bin file readers
base:dd - Fix for typo in comment to function driver_deferred_probe_trigger().
firmware: use const for remaining firmware names
firmware: fix possible use after free on name on asynchronous request
firmware: check for file truncation on direct firmware loading
firmware: fix __getname() missing failure check
drivers: of/base: move of_init to driver_init
drivers/base: cacheinfo: fix annoying typo when DT nodes are absent
sysfs: disambiguate between "error code" and "failure" in comments
driver-core: fix build for !CONFIG_MODULES
driver-core: make __device_attach() static
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver pull request for 4.2-rc1.
Lots of mei, extcon, coresight, uio, mic, and other driver updates in
here. Full details in the shortlog. All of these have been in
linux-next for some time with no reported problems"
* tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits)
mei: me: wait for power gating exit confirmation
mei: reset flow control on the last client disconnection
MAINTAINERS: mei: add mei_cl_bus.h to maintained file list
misc: sram: sort and clean up included headers
misc: sram: move reserved block logic out of probe function
misc: sram: add private struct device and virt_base members
misc: sram: report correct SRAM pool size
misc: sram: bump error message level on unclean driver unbinding
misc: sram: fix device node reference leak on error
misc: sram: fix enabled clock leak on error path
misc: mic: Fix reported static checker warning
misc: mic: Fix randconfig build error by including errno.h
uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config
uio: pruss: Add CONFIG_HAS_IOMEM dependence
uio: pruss: Include <linux/sizes.h>
extcon: Redefine the unique id of supported external connectors without 'enum extcon' type
char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration().
Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion
parport: check exclusive access before register
w1: use correct lock on error in w1_seq_show()
