A fault vector on parisc needs to be 2K aligned. Furthermore the
checksum of the fault vector needs to sum up to 0 which is being
calculated and written at runtime.
Up to now we aligned both PA20 and PA11 fault vectors on the same 4K
page in order to easily write the checksum after having mapped the
kernel read-only (by mapping this page only as read-write).
But when we want to map the kernel text and data on huge pages this
makes things harder.
So, simplify it by aligning both fault vectors on 2K boundries and write
the checksum before we map the page read-only.
Signed-off-by: Helge Deller <deller@gmx.de>
Huge pages on parisc will have the same size as one pmd table, which
is on a 64bit kernel 2MB on a kernel with 4K kernel page sizes, and
on a 32bit kernel 4MB when used with 4K kernel pages.
Since parisc does not physically supports 2MB huge page sizes, emulate
it with two consecutive 1MB page sizes instead. Keeping the same huge
page size as one pmd will allow us to add transparent huge page support
later on.
Bit 21 in the pte flags was unused and will now be used to mark a page
as huge page (_PAGE_HPAGE_BIT).
Drop the MADV_xxK_PAGES flags, which were never used and were from a proposed
API which was never integrated into the generic Linux kernel code.
Cc: stable@vger.kernel.org
The definition of start_thread_som was planned to be used to execute
HP-UX SOM binaries. Since HP-UX compatibility was dropped with kernel 4.0
there is no need to carry it further.
The first pmd entry is marked with PxD_FLAG_ATTACHED instead of
_PAGE_GATEWAY.
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull memremap fix from Dan Williams:
"The new memremap() api introduced in the 4.3 cycle to unify/replace
ioremap_cache() and ioremap_wt() is mishandling the highmem case.
This patch has received a build success notification from a
0day-kbuild-robot run and has received an ack from Ard"
From the commit message:
"The impact of this bug is low for now since the pmem driver is the
only user of memremap(), but this is important to fix before more
conversions to memremap arrive in 4.4"
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
memremap: fix highmem support
Pull x86 fixes from Thomas Gleixner:
"This set of updates contains:
- Another bugfix for the pathologic vm86 machinery. Clear
thread.vm86 on fork to prevent corrupting the parent state. This
comes along with an update to the vm86 selftest case
- Fix another corner case in the ioapic setup code which causes a
boot crash on some oddball systems
- Fix the fallout from the dma allocation consolidation work, which
leads to a NULL pointer dereference when the allocation code is
called with a NULL device"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vm86: Set thread.vm86 to NULL on fork/clone
selftests/x86: Add a fork() to entry_from_vm86 to catch fork bugs
x86/ioapic: Prevent NULL pointer dereference in setup_ioapic_dest()
x86/dma-mapping: Fix arch_dma_alloc_attrs() oops with NULL dev
Pull timer fixes from Thomas Gleixner:
"The last round of minimalistic fixes for clocksource drivers:
- Prevent multiple shutdown of the sh_mtu2 clocksource
- Annotate a bunch of clocksource/schedclock functions with notrace
to prevent an annoying ftrace recursion issue"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
clocksource/drivers/sh_mtu2: Fix multiple shutdown call issue
clocksource/drivers/digicolor: Prevent ftrace recursion
clocksource/drivers/fsl_ftm_timer: Prevent ftrace recursion
clocksource/drivers/vf_pit_timer: Prevent ftrace recursion
clocksource/drivers/prima2: Prevent ftrace recursion
clocksource/drivers/samsung_pwm_timer: Prevent ftrace recursion
clocksource/drivers/pistachio: Prevent ftrace recursion
clocksource/drivers/arm_global_timer: Prevent ftrace recursion
Pull irq fixes from Thomas Gleixner:
"The last two one-liners for 4.3 from the irqchip space:
- Regression fix for armada SoC which addresses the fallout from the
set_irq_flags() cleanup
- Add the missing propagation of the irq_set_type() callback to the
parent interrupt controller of the tegra interrupt chip"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip/tegra: Propagate IRQ type setting to parent
irqchip/armada-370-xp: Fix regression by clearing IRQ_NOAUTOEN
Pull ARM SoC fixes from Olof Johansson:
"This should be our final batch of fixes for 4.3:
- A patch from Sudeep Holla that fixes annotation of wakeup sources
properly, old unused format seems to have spread through copying.
- Two patches from Tony for OMAP. One dealing with MUSB setup
problems due to runtime PM being enabled too early on the parent
device. The other fixes IRQ numbering for OMAP1"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
usb: musb: omap2430: Fix regression caused by driver core change
ARM: OMAP1: fix incorrect INT_DMA_LCD
ARM: dts: fix gpio-keys wakeup-source property
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is three essential bug fixes for various SCSI parts.
The only affected users are SCSI multi-path via device handler
(basically all the enterprise) and mvsas users. The dh bugs are an
async entanglement in boot resulting in a serious WARN_ON trip and a
use after free on remove leading to a crash with strict memory
accounting. The mvsas bug manifests as a null deref oops but only on
abort sequences; however, these can commonly occur with SATA attached
devices, hence the fix"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
scsi_dh: don't try to load a device handler during async probing
scsi_dh: fix use-after-free when removing scsi device
mvsas: Fix NULL pointer dereference in mvs_slot_task_free
Pull md bug fixes from Neil Brown:
"Two more bug fixes for md.
One bugfix for a list corruption in raid5 because of incorrect
locking.
Other for possible data corruption when a recovering device is failed,
removed, and re-added.
Both tagged for -stable"
* tag 'md/4.3-rc7-fixes' of git://neil.brown.name/md:
Revert "md: allow a partially recovered device to be hot-added to an array."
md/raid5: fix locking in handle_stripe_clean_event()
Pull drm fixes from Dave Airlie:
"Two drm atomic core fixes.
And two radeon patches needed to fix a backlight regression on some
older hardware"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm: Correct arguments to list_tail_add in create blob ioctl
drm: crtc: integer overflow in drm_property_create_blob()
drm/radeon: fix dpms when driver backlight control is disabled
drm/radeon: move bl encoder assignment into bl init
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph fix from Sage Weil:
"This sets the stable pages flag on the RBD block device when we have
CRCs enabled. (This is necessary since the default assumption for
block devices changed in 3.9)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
rbd: require stable pages if message data CRCs are enabled
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull overlayfs bug fixes from Miklos Szeredi:
"This contains fixes for bugs that appeared in earlier kernels (all are
marked for -stable)"
* 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ovl: free lower_mnt array in ovl_put_super
ovl: free stack of paths in ovl_fill_super
ovl: fix open in stacked overlay
ovl: fix dentry reference leak
ovl: use O_LARGEFILE in ovl_copy_up()
Pull networking fixes from David Miller:
1) Fix two regressions in ipv6 route lookups, particularly wrt output
interface specifications in the lookup key. From David Ahern.
2) Fix checks in ipv6 IPSEC tunnel pre-encap fragmentation, from
Herbert Xu.
3) Fix mis-advertisement of 1000BASE-T on bcm63xx_enet, from Simon
Arlott.
4) Some smsc phys misbehave with energy detect mode enabled, so add a
DT property and disable it on such switches. From Heiko Schocher.
5) Fix TSO corruption on TX in mv643xx_eth, from Philipp Kirchhofer.
6) Fix regression added by removal of openvswitch vport stats, from
James Morse.
7) Vendor Kconfig options should be bool, not tristate, from Andreas
Schwab.
8) Use non-_BH() net stats bump in tcp_xmit_probe_skb(), otherwise we
barf during TCP REPAIR operations.
9) Fix various bugs in openvswitch conntrack support, from Joe
Stringer.
10) Fix NETLINK_LIST_MEMBERSHIPS locking, from David Herrmann.
11) Don't have VSOCK do sock_put() in interrupt context, from Jorgen
Hansen.
12) Fix skb_realloc_headroom() failures properly in ISDN, from Karsten
Keil.
13) Add some device IDs to qmi_wwan, from Bjorn Mork.
14) Fix ovs egress tunnel information when using lwtunnel devices, from
Pravin B Shelar.
15) Add missing NETIF_F_FRAGLIST to macvtab feature list, from Jason
Wang.
16) Fix incorrect handling of throw routes when the result of the throw
cannot find a match, from Xin Long.
17) Protect ipv6 MTU calculations from wrap-around, from Hannes Frederic
Sowa.
18) Fix failed autonegotiation on KSZ9031 micrel PHYs, from Nathan
Sullivan.
19) Add missing memory barries in descriptor accesses or xgbe driver,
from Thomas Lendacky.
20) Fix release conditon test in pppoe_release(), from Guillaume Nault.
21) Fix gianfar bugs wrt filter configuration, from Claudiu Manoil.
22) Fix violations of RX buffer alignment in sh_eth driver, from Sergei
Shtylyov.
23) Fixing missing of_node_put() calls in various places around the
networking, from Julia Lawall.
24) Fix incorrect leaf now walking in ipv4 routing tree, from Alexander
Duyck.
25) RDS doesn't check pskb_pull()/pskb_trim() return values, from
Sowmini Varadhan.
26) Fix VLAN configuration in mlx4 driver, from Jack Morgenstein.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (79 commits)
ipv6: protect mtu calculation of wrap-around and infinite loop by rounding issues
Revert "Merge branch 'ipv6-overflow-arith'"
net/mlx4: Copy/set only sizeof struct mlx4_eqe bytes
net/mlx4_en: Explicitly set no vlan tags in WQE ctrl segment when no vlan is present
vhost: fix performance on LE hosts
bpf: sample: define aarch64 specific registers
amd-xgbe: Fix race between access of desc and desc index
RDS-TCP: Recover correctly from pskb_pull()/pksb_trim() failure in rds_tcp_data_recv
forcedeth: fix unilateral interrupt disabling in netpoll path
openvswitch: Fix skb leak using IPv6 defrag
ipv6: Export nf_ct_frag6_consume_orig()
openvswitch: Fix double-free on ip_defrag() errors
fib_trie: leaf_walk_rcu should not compute key if key is less than pn->key
net: mv643xx_eth: add missing of_node_put
ath6kl: add missing of_node_put
net: phy: mdio: add missing of_node_put
netdev/phy: add missing of_node_put
net: netcp: add missing of_node_put
net: thunderx: add missing of_node_put
ipv6: gre: support SIT encapsulation
thread.vm86 points to per-task information -- the pointer should not
be copied on clone.
Fixes: d4ce0f26c790 ("x86/vm86: Move fields from 'struct kernel_vm86_struct' to 'struct vm86'")
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Stas Sergeev <stsp@list.ru>
Link: http://lkml.kernel.org/r/71c5d6985d70ec8197c8d72f003823c81b7dcf99.1446270067.git.luto@kernel.org
Mere possession of vm86 state is strange. Make sure that nothing
gets corrupted if we fork after calling vm86().
Link: http://lkml.kernel.org/r/08f83295460a80e41dc5e3e81ec40d6844d316f5.1446270067.git.luto@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input layer fixes from Dmitry Torokhov:
- a change to the ALPS driver where we had limit the quirk for
trackstick handling from being active on all Dells to just a few
models
- a fix for a build dependency issue in the sur40 driver
- a small clock handling fixup in the LPC32xx touchscreen driver
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: alps - only the Dell Latitude D420/430/620/630 have separate stick button bits
Input: sur40 - add dependency on VIDEO_V4L2
Input: lpc32xx_ts - fix warnings caused by enabling unprepared clock
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fix from Bjorn Helgaas:
"Sorry for this last-minute update; it's been in -next for quite a
while, but I forgot about it until I started getting ready for the
merge window.
It's small and fixes a way a user could cause a panic via sysfs, so I
think it's worth getting it in v4.3.
NUMA:
- Prevent out of bounds access in sysfs numa_node override (Sasha Levin)"
* tag 'pci-v4.3-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Prevent out of bounds access in numa_node override
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Two omap regression fixes:
- Fix omap3 MUSB with DMA caused by driver core changes
- Fix LCD DMA interrupt number for omap1 that did not
get changed for sparse IRQ changes
* tag 'omap-for-v4.3/fixes-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
Arguments passed to list_add_tail were reversed resulting in deletion
of old blob property everytime the new one is added.
Fixes
commit e2f5d2ea479b9b2619965d43db70939589afe43a
Author: Daniel Stone <daniels@collabora.com>
Date: Fri May 22 13:34:51 2015 +0100
drm/mode: Add user blob-creation ioctl
Signed-off-by: Maneet Singh <mmaneetsingh@nvidia.com>
[seanpaul tweaked commit subject a little]
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Cc: stable@kernel.org # v4.2
Reviewed-by: Daniel Stone <daniels@collabora.com>
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Dave Airlie <airlied@gmail.com>
This reverts commit 7eb418851f3278de67126ea0c427641ab4792c57.
This commit is poorly justified, I can find not discusison in email,
and it clearly causes a problem.
If a device which is being recovered fails and is subsequently
re-added to an array, there could easily have been changes to the
array *before* the point where the recovery was up to. So the
recovery must start again from the beginning.
If a spare is being recovered and fails, then when it is re-added we
really should do a bitmap-based recovery up to the recovery-offset,
and then a full recovery from there. Before this reversion, we only
did the "full recovery from there" which is not corect. After this
reversion with will do a full recovery from the start, which is safer
but not ideal.
It will be left to a future patch to arrange the two different styles
of recovery.
Reported-and-tested-by: Nate Dailey <nate.dailey@stratus.com>
Signed-off-by: NeilBrown <neilb@suse.com>
Cc: stable@vger.kernel.org (3.14+)
Fixes: 7eb418851f32 ("md: allow a partially recovered device to be hot-added to an array.")
The size here comes from the user via the ioctl, it is a number between
1-u32max so the addition here could overflow on 32 bit systems.
Fixes: f453ba046074 ('DRM: add mode setting support')
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Will Deacon:
"Apologies for this being so late, but we've uncovered a few nasty
issues on arm64 which didn't settle down until yesterday and the fixes
all look suitable for 4.3. Of the four patches, three of them are
Cc'd to stable, with the remaining patch fixing an issue that only
took effect during the merge window.
Summary:
- Fix corruption in SWP emulation when STXR fails due to contention
- Fix MMU re-initialisation when resuming from a low-power state
- Fix stack unwinding code to match what ftrace expects
- Fix relocation code in the EFI stub when DRAM base is not 2MB aligned"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64/efi: do not assume DRAM base is aligned to 2 MB
Revert "ARM64: unwind: Fix PC calculation"
arm64: kernel: fix tcr_el1.t0sz restore on systems with extended idmap
arm64: compat: fix stxr failure case in SWP emulation
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull ia64 kcmp syscall from Tony Luck:
"Missed adding the kcmp() syscall a long time ago. Now it seems that
it is essential to build systemd"
* tag 'please-pull-syscalls' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
[IA64] Wire up kcmp syscall
After commit 566c09c53455 ("raid5: relieve lock contention in get_active_stripe()")
__find_stripe() is called under conf->hash_locks + hash.
But handle_stripe_clean_event() calls remove_hash() under
conf->device_lock.
Under some cirscumstances the hash chain can be circuited,
and we get an infinite loop with disabled interrupts and locked hash
lock in __find_stripe(). This leads to hard lockup on multiple CPUs
and following system crash.
I was able to reproduce this behavior on raid6 over 6 ssd disks.
The devices_handle_discard_safely option should be set to enable trim
support. The following script was used:
for i in `seq 1 32`; do
dd if=/dev/zero of=large$i bs=10M count=100 &
done
neilb: original was against a 3.x kernel. I forward-ported
to 4.3-rc. This verison is suitable for any kernel since
Commit: 59fc630b8b5f ("RAID5: batch adjacent full stripe write")
(v4.1+). I'll post a version for earlier kernels to stable.
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
Fixes: 566c09c53455 ("raid5: relieve lock contention in get_active_stripe()")
Cc: Shaohua Li <shli@kernel.org>
Cc: <stable@vger.kernel.org> # 3.13 - 4.2
rbd requires stable pages, as it performs a crc of the page data before
they are send to the OSDs.
But since kernel 3.9 (patch 1d1d1a767206fbe5d4c69493b7e6d2a8d08cc0a0
"mm: only enforce stable page writes if the backing device requires
it") it is not assumed anymore that block devices require stable pages.
This patch sets the necessary flag to get stable pages back for rbd.
In a ceph installation that provides multiple ext4 formatted rbd
devices "bad crc" messages appeared regularly (ca 1 message every 1-2
minutes on every OSD that provided the data for the rbd) in the
OSD-logs before this patch. After this patch this messages are pretty
much gone (only ca 1-2 / month / OSD).
Cc: stable@vger.kernel.org # 3.9+, needs backporting
Signed-off-by: Ronny Hegewald <Ronny.Hegewald@online.de>
[idryomov@gmail.com: require stable pages only in crc case, changelog]
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
into drm-fixes
regression fix for backlight on old laptops.
* 'drm-fixes-4.3' of git://people.freedesktop.org/~agd5f/linux:
The current arm64 Image relocation code in the UEFI stub assumes that
the dram_base argument it receives is always a multiple of 2 MB. In
reality, it is simply the lowest start address of all RAM entries in
the UEFI memory map, which means it could be any multiple of 4 KB.
Since the arm64 kernel Image needs to reside TEXT_OFFSET bytes beyond
a 2 MB aligned base, or it will fail to boot, make sure we round dram_base
to 2 MB before using it to calculate the relocation address.
Fixes: e38457c361b30c5a ("arm64: efi: prefer AllocatePages() over efi_low_alloc() for vmlinux")
Reported-by: Timur Tabi <timur@codeaurora.org>
Tested-by: Timur Tabi <timur@codeaurora.org>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
If driver backlight control is disabled, either by driver
parameter or default per-asic setting, revert to the old behavior.
Fixes a regression in commit:
4281f46ef839050d2ef60348f661eb463c21cc2e
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
So that the bl encoder will be null if the GPU does not
control the backlight.
issues
Raw sockets with hdrincl enabled can insert ipv6 extension headers
right into the data stream. In case we need to fragment those packets,
we reparse the options header to find the place where we can insert
the fragment header. If the extension headers exceed the link's MTU we
actually cannot make progress in such a case.
Instead of ending up in broken arithmetic or rounding towards 0 and
entering an endless loop in ip6_fragment, just prevent those cases by
aborting early and signal -EMSGSIZE to user space.
This is the second version of the patch which doesn't use the
overflow_usub function, which got reverted for now.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Dmitry Vyukov <dvyukov@google.com>
Linus dislikes these changes. To not hold up the net-merge let's revert
it for now and fix the bug like Linus suggested.
This reverts commit ec3661b42257d9a06cf0d318175623ac7a660113, reversing
changes made to c80dbe04612986fd6104b4a1be21681b113b5ac9.
systemd > 218 fails to compile on ia64 with:
error: ‘__NR_kcmp’ undeclared [1].
I've been told that this is because the kcmp syscall hasn't been wired up
for the ia64 arch [2].
The proposed patch thus wire up the kcmp syscall for the ia64 arch.
[1] https://bugs.gentoo.org/show_bug.cgi?id=560492
[2] https://bugs.gentoo.org/show_bug.cgi?id=560492#c17
Signed-off-by: Émeric MASCHINO <emeric.maschino@gmail.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Commit ddef08dd00f5 ("Driver core: wakeup the parent device before trying
probe") started automatically ensuring the parent device is enabled when
the child gets probed.
This however caused a regression for MUSB omap2430 interface as the
runtime PM for the parent device needs the child initialized to access
the MUSB hardware registers.
Let's delay the enabling of PM runtime for the parent until the child
has been properly initialized as suggested in an earlier patch by
Grygorii Strashko <grygorii.strashko@ti.com>.
In addition to delaying pm_runtime_enable, we now also need to make sure
the parent is enabled during omap2430_musb_init. We also want to propagate
an error from omap2430_runtime_resume if struct musb is not initialized.
Note that we use pm_runtime_put_noidle here for both the child and parent
to prevent an extra runtime_suspend/resume cycle.
Let's also add some comments to avoid confusion between the
two different devices.
Fixes: ddef08dd00f5 ("Driver core: wakeup the parent device before
trying probe")
Suggested-by: Grygorii Strashko <grygorii.strashko@ti.com>
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
This reverts commit e306dfd06fcb44d21c80acb8e5a88d55f3d1cf63.
With this patch applied, we were the only architecture making this sort
of adjustment to the PC calculation in the unwinder. This causes
problems for ftrace, where the PC values are matched against the
contents of the stack frames in the callchain and fail to match any
records after the address adjustment.
Whilst there has been some effort to change ftrace to workaround this,
those patches are not yet ready for mainline and, since we're the odd
architecture in this regard, let's just step in line with other
architectures (like arch/arm/) for now.
Commit dd006da21646 ("arm64: mm: increase VA range of identity map")
introduced a mechanism to extend the virtual memory map range
to support arm64 systems with system RAM located at very high offset,
where the identity mapping used to enable/disable the MMU requires
additional translation levels to map the physical memory at an equal
virtual offset.
The kernel detects at boot time the tcr_el1.t0sz value required by the
identity mapping and sets-up the tcr_el1.t0sz register field accordingly,
any time the identity map is required in the kernel (ie when enabling the
MMU).
After enabling the MMU, in the cold boot path the kernel resets the
tcr_el1.t0sz to its default value (ie the actual configuration value for
the system virtual address space) so that after enabling the MMU the
memory space translated by ttbr0_el1 is restored as expected.
also added code to set-up the tcr_el1.t0sz value when the kernel resumes
from low-power states with the MMU off through cpu_resume() in order to
effectively use the identity mapping to enable the MMU but failed to add
the code required to restore the tcr_el1.t0sz to its default value, when
the core returns to the kernel with the MMU enabled, so that the kernel
might end up running with tcr_el1.t0sz value set-up for the identity
mapping which can be lower than the value required by the actual virtual
address space, resulting in an erroneous set-up.
This patchs adds code in the resume path that restores the tcr_el1.t0sz
default value upon core resume, mirroring this way the cold boot path
behaviour therefore fixing the issue.
Fixes: dd006da21646 ("arm64: mm: increase VA range of identity map")
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: James Morse <james.morse@arm.com>
If the STXR instruction fails in the SWP emulation code, we leave *data
overwritten with the loaded value, therefore corrupting the data written
by a subsequent, successful attempt.
This patch re-jigs the code so that we only write back to *data once we
know that the update has happened.
Fixes: bd35a4adc413 ("arm64: Port SWP/SWPB emulation support from arm")
Reported-by: Shengjiu Wang <shengjiu.wang@freescale.com>
Reported-by: Vladimir Murzin <vladimir.murzin@arm.com>
Commit 685e2d08c54b ("ARM: OMAP1: Change interrupt numbering for
sparse IRQ") turned on SPARSE_IRQ on OMAP1, but forgot to change
the number of INT_DMA_LCD. This broke the boot at least on Nokia 770,
where the device hangs during framebuffer initialization.
Fix by defining INT_DMA_LCD like the other interrupts.
Cc: stable@vger.kernel.org # v4.2+
Fixes: 685e2d08c54b ("ARM: OMAP1: Change interrupt numbering for sparse IRQ")
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
On the r7s72100 Genmai board the MTU2 driver currently triggers a common
clock framework WARN_ON(enable_count) when disabling the clock due to
the MTU2 driver after recent callback rework may call ->set_state_shutdown()
multiple times. A similar issue was spotted for the TMU driver and fixed in:
452b132 clocksource/drivers/sh_tmu: Fix traceback spotted in -next
On r7s72100 Genmai v4.3-rc7 built with shmobile_defconfig spits out the
following during boot:
sh_mtu2 fcff0000.timer: ch0: used for clock events
WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:675 clk_core_disable+0x2c/0x6c()
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.3.0-rc7 #1
Hardware name: Generic R7S72100 (Flattened Device Tree)
Backtrace:
[<c00133d4>] (dump_backtrace) from [<c0013570>] (show_stack+0x18/0x1c)
[<c0013558>] (show_stack) from [<c01c7aac>] (dump_stack+0x74/0x90)
[<c01c7a38>] (dump_stack) from [<c00272fc>] (warn_slowpath_common+0x88/0xb4)
[<c0027274>] (warn_slowpath_common) from [<c0027400>] (warn_slowpath_null+0x24/0x2c)
[<c00273dc>] (warn_slowpath_null) from [<c03a9320>] (clk_core_disable+0x2c/0x6c)
[<c03a92f4>] (clk_core_disable) from [<c03aa0a0>] (clk_disable+0x40/0x4c)
[<c03aa060>] (clk_disable) from [<c0395d2c>] (sh_mtu2_disable+0x24/0x50)
[<c0395d08>] (sh_mtu2_disable) from [<c0395d6c>] (sh_mtu2_clock_event_shutdown+0x14/0x1c)
[<c0395d58>] (sh_mtu2_clock_event_shutdown) from [<c007d7d0>] (clockevents_switch_state+0xc8/0x114)
[<c007d708>] (clockevents_switch_state) from [<c007d834>] (clockevents_shutdown+0x18/0x28)
[<c007d81c>] (clockevents_shutdown) from [<c007dd58>] (clockevents_exchange_device+0x70/0x78)
[<c007dce8>] (clockevents_exchange_device) from [<c007e578>] (tick_check_new_device+0x88/0xe0)
[<c007e4f0>] (tick_check_new_device) from [<c007daf0>] (clockevents_register_device+0xac/0x120)
[<c007da44>] (clockevents_register_device) from [<c0395be8>] (sh_mtu2_probe+0x230/0x350)
[<c03959b8>] (sh_mtu2_probe) from [<c028b6f0>] (platform_drv_probe+0x50/0x98)
Reported-by: Chris Brandt <chris.brandt@renesas.com>
Fixes: 19a9ffb ("clockevents/drivers/sh_mtu2: Migrate to new 'set-state' interface")
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc fix from Michael Ellerman:
- powerpc/dma: dma_set_coherent_mask() should not be GPL only from Ben
* tag 'powerpc-4.3-6' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
When turning this from inline to an exported function I was a bit
over-eager and made it GPL only. This prevents the use of pretty much
all non-GPL PCI driver which is a bit over the top. Let's bring it
back in line with other architecture.
Fixes: 817820b0226a ("powerpc/iommu: Support "hybrid" iommu/direct DMA ops for coherent_mask < dma_mask")
Or Gerlitz says:
Mellanox mlx4 driver fixes for 4.3-rc7
Jack's fix is for a regression introduced in 4.3-rc1
Carol's fix addresses an issue which exists for while and
turns to beat us hard on PPC, please queue for -stable.
When doing memcpy/memset of EQEs, we should use sizeof struct
mlx4_eqe as the base size and not caps.eqe_size which could be bigger.
If caps.eqe_size is bigger than the struct mlx4_eqe then we corrupt
data in the master context.
When using a 64 byte stride, the memcpy copied over 63 bytes to the
slave_eq structure. This resulted in copying over the entire eqe of
interest, including its ownership bit -- and also 31 bytes of garbage
into the next WQE in the slave EQ -- which did NOT include the ownership
bit (and therefore had no impact).
However, once the stride is increased to 128, we are overwriting the
ownership bits of *three* eqes in the slave_eq struct. This results
in an incorrect ownership bit for those eqes, which causes the eq to
seem to be full. The issue therefore surfaced only once 128-byte EQEs
started being used in SRIOV and (overarchitectures that have 128/256
byte cache-lines such as PPC) - e.g after commit 77507aa249ae
"net/mlx4_core: Enable CQE/EQE stride support".
Fixes: 08ff32352d6f ('mlx4: 64-byte CQE/EQE support')
Signed-off-by: Carol L Soto <clsoto@linux.vnet.ibm.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
present
We do not set the ins_vlan field to zero when no vlan id is present in the packet.
Since WQEs in the TX ring are not zeroed out between uses, this oversight
could result in having vlan flags present in the WQE ctrl segment when no
vlan is preset.
Fixes: e38af4faf01d ('net/mlx4_en: Add support for hardware accelerated 802.1ad vlan')
Reported-by: Gideon Naim <gideonn@mellanox.com>
commit 2751c9882b947292fcfb084c4f604e01724af804 ("vhost: cross-endian
support for legacy devices") introduced a minor regression: even with
cross-endian disabled, and even on LE host, vhost_is_little_endian is
checking is_le flag so there's always a branch.
To fix, simply check virtio_legacy_is_little_endian first.
Cc: Greg Kurz <gkurz@linux.vnet.ibm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Greg Kurz <gkurz@linux.vnet.ibm.com>
Define aarch64 specific registers for building bpf samples correctly.
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Acked-by: Alexei Starovoitov <ast@kernel.org>
During Tx cleanup it's still possible for the descriptor data to be
read ahead of the descriptor index. A memory barrier is required between
the read of the descriptor index and the start of the Tx cleanup loop.
This allows a change to a lighter-weight barrier in the Tx transmit
routine just before updating the current descriptor index.
Since the memory barrier does result in extra overhead on arm64, keep
the previous change to not chase the current descriptor value. This
prevents the execution of the barrier for each loop performed.
Suggested-by: Alexander Duyck <alexander.duyck@gmail.com>
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
