The queue info in struct ieee80211_tx_status is never used.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
The callback takes a ieee80211_tx_queue_stats with a contained
array of ieee80211_tx_queue_stats_data, remove the former, rename
the latter to ieee80211_tx_queue_stats and make tx_stats() take
the array directly.
This patch renames iwl-4965.h to iwl-dev.h
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
This patch renames iwl-4965-commands to iwl-commands.h
This patch adds nic config handler for 5000 HW Family
This patch adds implementation for eeprom check version
handler for 5000 HW
This patch udpates the byte count of the frame in the registers of the
scheduler.
This patch also moves two defines in iwl-4965.h to a more appropriate
area in the file.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This patch fills the needed handlers for shared memory for
iwl 5000 family
Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com>
This patch adds values fo CSR_HW_REV for 5000 HW family
This patch use new defines for antennas
This patch adds support for run time calibrations for the 5000 family HW.
Those calibrations are sensitivity calibration, and chain noise calibration.
This patch upadtes the CT-Kill value for 5000 series.
Signed-off-by: Assaf Krauss <assaf.krauss@intel.com>
This patch adds iwl 5000 HW parameters
This patch adds eeprom handlers and values for 5000 HW family
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
This patch makes use of iwl4965_set_pwr_src in 5000 HW family
This patch adds apm_init handler for 5000 HW family
This patch adds handler framework for 5000 family HW
This patch adds initial support for recognizing the iwl 5000 family of NICs
ID
This patch wraps nic hw configuration in a iwl core handler
This patch remove settings of APMG_PS_CTRL_VAL_RESET_REQ
from 4965 this should be used only for 3945
This patch moves hw_rx_handler_setup to iwl-4965.c
This patch change CSR49_ to CSR_ for values used in
other HW
This patch moves verify_ucode functions to iwl-core.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Add missing kernel-doc variables for structures/functions.
Add some helper macro's to help determining the
the timeout for USB register access.
Use the rt2x00 queue enumeration as much as possible,
removing the usage of the mac80211 queue numbering
wherever it is possible.
This makes it easier for mac80211 to change it queue
identification scheme without having to deal with
big changes in the rt2x00 code.
A lot more is needed to support mixed interfaces then just this flag,
such things need new redesigns in rt2x00lib to actually make it happen.
So far there doesn't exist a Ralink chipset that can handle it, so
we might as well remove the flag for now and see what should be done
whenever a device appears that can handle it.
If the driver has set the set_rts_threshold() callback function
to mac80211 it is capable of generating RTS and CTS-to-self frames
inside the hardware and rt2x00lib doesn't have to create them
in software.
Only rt2800pci and rt2800usb support this feature.
This patch removes the IRQ-disable from mac_suspend.
The main advantage of this is to get rid of the IRQ-sync call in mac_suspend.
We need to remove the MAC suspend bit from the IRQ service mask, as otherwise
the IRQ handler would race with us.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
This patch remove SCD definitions form iwl-3945-hw.h
The values from iwl-prph.h are used
This patch moves Flow Handlers define to a new file iwl-fh.h
This patch cleans unnecessary includes in iwl-sta.[hc]
This patch does the following:
1 - moving init_drv from handler to regular function call
2 - move the init driver flow from iwl4965 to iwlcore, thus unify it to all
iwl family as a single flow
3 - move some general purpose functions from iwl4965 to iwlcore
This patch cleans up and renames some of the SCD registers.
It move SCD definitions into iwl-prhp.h file
Main changes:
1. no need to re-calculate expected_tpt when only toggling antenna
2. changing the code to be more strict on input and status of variables
3. enhanced debug prints
4. move to search table only if improving tpt
(don't move if SR is improved but tpt is not)
Signed-off-by: Guy Cohen <guy.cohen@intel.com>
1. Fixing support for tx in antenna C
2. Enable stay_in_column expiration after 2 seconds
This patch moves TX/RX constants in 4969 headers
This patch add support for toggeling of A/B/C and AB/BC/AC
antennas
This patch does following changes
1. rs_get_expected_tpt_table: changed get to set
2. changed IWL_DEBUG_HT to IWL_DEBUG_RATE as appropriate
3. changed rs_get_supported_rates to be returning value function
1. Merge TLC fixes from AP support code
2. Remove struct iwl4965_rate
3. Misc code restructuring
This patch generalize the use of shared memory, as size of this memory is
now allocated and freed by handlers, and also changes the location of those
actions for better resource management
This patch move eeprom version checking into pci probe stage
This patch add iwl_hw_detect function to iwl core
This patch add apm init handler to iwlcore handler
1. This patch restructures rate scale algorithm to support
SISO, MIMO2, MIMO3
2. It adds support for detailed valid TX and RX antennas settings
3. It removes few unesfull antenna definitions
This patch cleans up the scan flow. This patch cleans up the insertion of
the HT IE in the probe request.
This patch adds consistent DMA masks for 64 bit
This patch fixes the configuration of CT-Kill.
