The timeout variant of the list:set type must reference the member sets.
However, its garbage collector runs at timer interrupt so the mutex
protection of the references is a no go. Therefore the reference protection
is converted to rwlock.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
- the timeout value was actually not set
- the garbage collector was broken
The variant is fixed, the tests to the ipset testsuite are added.
dev_ethtool_get_rx_csum() won't report rx checksumming when it's not
changeable and driver is converted to hw_features and friends. Fix this.
(dev->hw_features & NETIF_F_RXCSUM) check is dropped - if the
ethtool_ops->get_rx_csum is set, then driver is not coverted, yet.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
The documentation for the USB ethernet devices suggests that
only some devices are supposed to use usb0 as the network interface
name instead of eth0. The logic used there, and documented in
Kconfig for CDC is that eth0 will be used when the mac address
is a globally assigned one, but usb0 is used for the locally
managed range that is typically used on point-to-point links.
Unfortunately, this has caused a lot of pain on the smsc95xx
device that is used on the popular pandaboard without an
EEPROM to store the MAC address, which causes the driver to
call random_ether_address().
Obviously, there should be a proper MAC addressed assigned to
the device, and discussions are ongoing about how to solve
this, but this patch at least makes sure that the default
interface naming gets a little saner and matches what the
user can expect based on the documentation, including for
new devices.
The approach taken here is to flag whether a device might be a
point-to-point link with the new FLAG_POINTTOPOINT setting in
the usbnet driver_info. A driver can set both FLAG_POINTTOPOINT
and FLAG_ETHER if it is not sure (e.g. cdc_ether), or just one
of the two. The usbnet framework only looks at the MAC address
for device naming if both flags are set, otherwise it trusts the
flag.
Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Tested-by: Andy Green <andy.green@linaro.org>
Now we have CONFIG_ARCH_DMA_ADDR_T_64BIT. We can fix the hacky
dma_addr_t size test cleanly.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Commit 60d9f461a20ba59219fdcdc30cbf8e3a4ad3f625 ("appletalk: remove
the BKL") added a dereference of "sk" before checking for NULL in
atalk_release().
Guard the code block completely, rather than partially, with the
NULL check.
Reported-by: Dave Jones <davej@redhat.com>
We should reduce the number of reserved completion queues from the total
number of entries. Since the queue size is power of two, not reducing the
reserved entries, caused a double queue size, which may lead to allocation
failures in some cases.
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
In case of allocation failure, tried to use the promiscuous QP
entry that was previously freed.
Now freeing this entry only in case we will not put it back to the list
of promiscuous entries.
Reported-by: Dan Carpenter <error27@gmail.com>
use accumulates instead of acumulates.
Signed-off-by: Pan Weiping <panweiping3@gmail.com>
Like DCCP and other similar pieces of code, there are mechanisms
here to try allocating smaller hash tables if the allocation
fails. So pass in __GFP_NOWARN like the others do instead of
emitting a scary message.
Commits 01a16b21 (netlink: kill eff_cap from struct netlink_skb_parms)
and c53fa1ed (netlink: kill loginuid/sessionid/sid members from struct
netlink_skb_parms) removed some members from struct netlink_skb_parms
that depend on the current context, all netlink users are now required
to do synchronous message processing.
connector however queues received messages and processes them in a work
queue, which is not valid anymore. This patch converts connector to do
synchronous message processing by invoking the registered callback handler
directly from the netlink receive function.
In order to avoid invoking the callback with connector locks held, a
reference count is added to struct cn_callback_entry, the reference
is taken when finding a matching callback entry on the device's queue_list
and released after the callback handler has been invoked.
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
Daniel J Blueman reported a lockdep splat in trie_firstleaf(), caused by
RTNL being not locked before a call to fib_table_flush()
Reported-by: Daniel J Blueman <daniel.blueman@gmail.com>
Don't flap VCs when carrier state changes; higher-level protocols
can detect loss of connectivity and act accordingly. This is more
consistent with how other network interfaces work.
We no longer use release_vccs() so we can delete it.
release_vccs() was duplicated from net/atm/common.c; make the
corresponding function exported, since other code duplicates it
and could leverage it if it were public.
Signed-off-by: Philip A. Prindeville <philipp@redfish-solutions.com>
Omit pkt_hdr preamble when dumping transmitted packet as hex-dump;
we can pull this up because the frame has already been sent, and
dumping it is the last thing we do with it before freeing it.
Also include the size, vpi, and vci in the debug as is done on
receive.
Use "port" consistently instead of "device" intermittently.
Signed-off-by: Philip Prindeville <philipp@redfish-solutions.com>
Use VPI.VCI notation consistently throughout the module. This is the
one remaining place where the VCI is used before the VPI in any output.
We leak in some error paths of drivers/net/atlx/atl2.c:atl2_set_eeprom().
The memory allocated to 'eeprom_buff' is not freed when we return -EIO.
This patch fixes that up and also removes a pointless explicit cast.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
In case the device where is coming from the packet has TSO enabled,
we should not check the mtu size value as this one could be bigger
than the expected value.
This is the case for the macvlan driver when the lower device has
TSO enabled. The macvlan inherit this feature and forward the packets
without fragmenting them. Then the packets go through dev_forward_skb
and are dropped. This patch fix this by checking TSO is not enabled
when we want to check the mtu size.
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
This adds a driver for the CDC Ethernet part of this modem. The
device's ID is blacklisted in cdc_ether.c and is white-listed in
this new driver because of the quirks needed to make it useful.
The modem's firmware exposes a CDC ACM port for modem control and a
CDC Ethernet port for network data. The descriptors look fine but
both ports actually are some sort of multiplexers requiring non-
standard headers added/removed from every packet or they get
ignored. All information is based on a usb traffic log from a
Windows machine.
On the Verizon 4G network I've seen speeds up to 1.1MB/s so far with
this driver, a speed-o-meter site reports 16.2Mbps/10.5Mbps.
Userspace scripts are required to talk to the CDC ACM port.
Signed-off-by: Andrzej Zaborowski <balrogg@gmail.com>
The function phy_attach_direct attaches the phy and calls phy_init_hw.
phy_init_hw can fail, but the phy is still marked as attached. Successive
calls to phy_attach_direct will fail because the phy is busy.
[ 1.020000] eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:00, irq=-1)
[ 1.030000] eth1: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
[ 2.050000] Sending DHCP requests .
[ 3.020000] PHY: 1:00 - Link is Up - 100/Full
[ 5.110000] ..... timed out!
[ 87.660000] IP-Config: Reopening network devices...
[ 88.190000] FEC: MDIO read timeout
[ 88.190000] eth0: could not attach to PHY
[ 88.190000] IP-Config: Failed to open eth0
[ 88.210000] FEC: MDIO read timeout
[ 88.210000] eth1: could not attach to PHY
[ 88.210000] IP-Config: Failed to open eth1
[ 88.220000] IP-Config: No network devices available.
[ 88.220000] Freeing init memory: 6968K
starting network interfaces...
ip: RTNETLINK answers: File exists
[ 94.000000] net eth0: PHY already attached
[ 94.010000] eth0: could not attach to PHY
ip: SIOCSIFFLAGS: Device or resource busy
This patch adds phy_detach to clean up if phy_init_hw fails.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
"len = ntohs(ip6h->payload_len)" does not include the length of the ipv6
header itself, which the rest of this function assumes, though.
This leads to a length check less restrictive as it should be in the
following line for one thing. For another, it very likely leads to an
integer underrun when substracting the offset and therefore to a very
high new value of 'len' due to its unsignedness. This will ultimately
lead to the pskb_trim_rcsum() practically never being called, even in
the cases where it should.
Signed-off-by: Linus Lüssing <linus.luessing@web.de>
via-ircc has been passing a NULL pointer to DMA allocation functions,
which is completely invalid and results in a BUG on PowerPC. Now
that we always have the device pointer available, pass it in.
Reference: http://bugs.debian.org/619450
Reported-by: Andrew Buckeridge <andrewb@bgc.com.au>
Tested-by: Andrew Buckeridge <andrewb@bgc.com.au> [against 2.6.32]
via-ircc still maintains its own array of device pointers in Linux 2.4
style. Worse, it always uses index 0, so it will crash if there are
multiple suitable devices in the system.
My commit 6d55cb91a0020ac0 (gre: fix hard header destination
address checking) broke multicast.
The reason is that ip_gre used to get ipgre_header() calls with
zero destination if we have NOARP or multicast destination. Instead
the actual target was decided at ipgre_tunnel_xmit() time based on
per-protocol dissection.
Instead of allowing the "abuse" of ->header() calls with invalid
destination, this creates multicast mappings for ip_gre. This also
fixes "ip neigh show nud noarp" to display the proper multicast
mappings used by the gre device.
Reported-by: Doug Kehn <rdkehn@yahoo.com>
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
Acked-by: Doug Kehn <rdkehn@yahoo.com>
net/bridge/br_stp_if.c: In function ‘br_stp_recalculate_bridge_id’:
net/bridge/br_stp_if.c:216:3: warning: ‘return’ with no value, in function returning non-void
Signed-off-by: G.Balaji <balajig81@gmail.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
After commit a715dea3c8e9ef2771c534e05ee1d36f65987e64 ("net: Always
allocate at least 16 skb frags regardless of page size"), the value
of MAX_SKB_FRAGS can now take on either an "unsigned long" or an
"int" value.
This causes warnings like:
net/packet/af_packet.c: In function ‘tpacket_fill_skb’:
net/packet/af_packet.c:948: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 2 has type ‘int’
Fix by forcing the constant to be unsigned long, otherwise we have
a situation where the type of a system wide constant is variable.
If change_interface gets invoked during a firmware
restart, it may crash; prevent that from happening
by checking if ctx->vif is assigned.
Additionally, in my initial commit I forgot to set
the vif->p2p variable correctly, so fix that too.
Cc: stable@kernel.org [2.6.38+]
Some clients seem to rely upon the reception of BlockAckReqs to flush
their rx reorder buffer. In order to fix aggregation for these clients
carl9170 should set IEEE80211_TX_STAT_AMPDU_NO_BACK to generate a
BlockAckReq if the transmission of an AMPDU subframe fails.
This fixes aggregation problems with Intel 5100 Windows STAs (and maybe
others as well).
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
After new NetworkManager 0.8.996 changes, hardware scanning is causing
microcode errors as reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=683571
and sometimes kernel crashes:
https://bugzilla.redhat.com/show_bug.cgi?id=688252
Also with hw scan there are very bad performance on some systems
as reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=671366
Since Intel no longer supports 3945, there is no chance to get proper
firmware fixes, we need workaround problems by disable hardware scanning
by default.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
taken from staging/rt2860
0x0411,0x016f de37cd49b5a54facef174cf34496919857436e8f MelCo(Buffalo) WLI-UC-G301N
0x050d,0x825b 12840c63b0679f7fab88ea1cc26b52db8b574ce7 Belkin F5D8055
0x050d,0x935a 705059a670f3af2b37695e82de0ee58e75e656ed Belkin F6D4050 v1
0x050d,0x935b 5d92fe3387d086fc2f10426fbdb6b86d6cce5a47 Belkin F6D4050 v2
identifed from ralink driverss
0x0930,0x0a07 RT35xx TOSHIBA 2010_1215_RT3572_Linux_STA_v2.5.0.0.DPO
0x1d4d,0x0011 3072 Pegatron 2011_0107_RT3070_RT3370_Linux_STA_v2.5.0.1_DPO
Signed-off-by: Xose Vazquez Perez <xose.vazquez@gmail.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
Software scanning can be used for workaround some performance problems,
so do not deprecate it.
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (26 commits)
mmc: SDHI should depend on SUPERH || ARCH_SHMOBILE
mmc: tmio_mmc: Move some defines into a shared header
mmc: tmio: support aggressive clock gating
mmc: tmio: fix power-mode interpretation
mmc: tmio: remove work-around for unmasked SDIO interrupts
sh: fix SDHI IO address-range
ARM: mach-shmobile: fix SDHI IO address-range
mmc: tmio: only access registers above 0xff, if available
mfd: remove now redundant sh_mobile_sdhi.h header
sh: convert boards to use linux/mmc/sh_mobile_sdhi.h
ARM: mach-shmobile: convert boards to use linux/mmc/sh_mobile_sdhi.h
mmc: tmio: convert the SDHI MMC driver from MFD to a platform driver
sh: ecovec: use the CONFIG_MMC_TMIO symbols instead of MFD
mmc: tmio: split core functionality, DMA and MFD glue
mmc: tmio: use PIO for short transfers
mmc: tmio-mmc: Improve DMA stability on sh-mobile
mmc: fix mmc_app_send_scr() for dma transfer
mmc: sdhci-esdhc: enable esdhc on imx53
mmc: sdhci-esdhc: use writel/readl as general APIs
mmc: sdhci: add the abort CMDTYPE bits definition
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-frv
* 'frv' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-frv:
FRV: Use generic show_interrupts()
FRV: Convert genirq namespace
frv: Select GENERIC_HARDIRQS_NO_DEPRECATED
frv: Convert cpu irq_chip to new functions
frv: Convert mb93493 irq_chip to new functions
frv: Convert mb93093 irq_chip to new function
frv: Convert mb93091 irq_chip to new functions
frv: Fix typo from __do_IRQ overhaul
frv: Remove stale irq_chip.end
FRV: Do some cleanups
FRV: Missing node arg in alloc_thread_info_node() macro
NOMMU: implement access_remote_vm
NOMMU: support SMP dynamic percpu_alloc
NOMMU: percpu should use is_vmalloc_addr().
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/bug-fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: Use new irq_move functions
xen: Convert genirq namespace
xen: fix p2m section mismatches
xen/p2m: Allocate p2m tracking pages on override
xen-gntdev: unlock on error path in gntdev_mmap()
xen-gntdev: return -EFAULT on copy_to_user failure
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
watchdog: softdog.c: enhancement to optionally invoke panic instead of reboot on timer expiry
watchdog: fix nv_tco section mismatch
watchdog: sp5100_tco.c: Check if firmware has set correct value in tcobase.
watchdog: Convert release_resource to release_region/release_mem_region
watchdog: s3c2410_wdt.c: Convert release_resource to release_region/release_mem_region
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
amd64_edac: Fix potential memleak
* 'irq-final-for-linus-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (111 commits)
gpio: ab8500: Mark broken
genirq: Remove move_*irq leftovers
genirq: Remove compat code
drivers: Final irq namespace conversion
mn10300: Use generic show_interrupts()
mn10300: Cleanup irq_desc access
mn10300: Convert genirq namespace
frv: Use generic show_interrupts()
frv: Convert genirq namespace
m68k: Convert irq function namespace
xen: Cleanup genirq namespace
unicore32: Use generic show_interrupts()
This patch fixes information leakage to the userspace by initializing
the data buffer to zero.
Reported-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com>
[ Also removed the silly "* sizeof(u8)". If that isn't 1, we have way
deeper problems than a simple multiplication can fix. - Linus ]
We check the pointers together but at least one of them could be invalid
due to failed allocation. Since we cannot continue if either of the two
allocations has failed, exit early by freeing them both.
Cc: <stable@kernel.org> # 38.x
Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Fix the incorrect use of igrab() inside the i_lock in NFS and Ceph‥
If we are already holding the i_lock, we have a reference to the
inode so we can safely use ihold() to gain an extra reference. This
avoids hangs due to lock recursion on the i_lock now that the
inode_lock is gone and igrab() uses the i_lock itself.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Cc: linux-fsdevel@vger.kernel.org
Cc: Ryan Mallon <ryan@bluewatersys.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
xfrm: Restrict extended sequence numbers to esp
xfrm: Check for esn buffer len in xfrm_new_ae
xfrm: Assign esn pointers when cloning a state
xfrm: Move the test on replay window size into the replay check functions
netdev: bfin_mac: document TE setting in RMII modes
drivers net: Fix declaration ordering in inline functions.
cxgb3: Apply interrupt coalescing settings to all queues
net: Always allocate at least 16 skb frags regardless of page size
ipv4: Don't ip_rt_put() an error pointer in RAW sockets.
net: fix ethtool->set_flags not intended -EINVAL return value
mlx4_en: Fix loss of promiscuity
tg3: Fix inline keyword usage
tg3: use <linux/io.h> and <linux/uaccess.h> instead <asm/io.h> and <asm/uaccess.h>
net: use CHECKSUM_NONE instead of magic number
Net / jme: Do not use legacy PCI power management
myri10ge: small rx_done refactoring
bridge: notify applications if address of bridge device changes
ipv4: Fix IP timestamp option (IPOPT_TS_PRESPEC) handling in ip_options_echo()
can: c_can: Fix tx_bytes accounting
can: c_can_platform: fix irq check in probe
These functions take irq_data as an argument and avoid a redundant
lookup in the sparse irq case.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Converted with coccinelle.
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Fix section mismatch warnings:
set_phys_range_identity() is called by __init xen_set_identity(),
so also mark set_phys_range_identity() as __init.
then:
__early_alloc_p2m() is called set_phys_range_identity(), so also mark
__early_alloc_p2m() as __init.
WARNING: arch/x86/built-in.o(.text+0x7856): Section mismatch in reference from the function __early_alloc_p2m() to the function .init.text:extend_brk()
The function __early_alloc_p2m() references
the function __init extend_brk().
This is often because __early_alloc_p2m lacks a __init
annotation or the annotation of extend_brk is wrong.
WARNING: arch/x86/built-in.o(.text+0x7967): Section mismatch in reference from the function set_phys_range_identity() to the function .init.text:extend_brk()
The function set_phys_range_identity() references
This is often because set_phys_range_identity lacks a __init
[v2: Per Stephen Hemming recommonedation made __early_alloc_p2m static]
Convert to new function names. Converted with coccinelle.
All chips converted
