On SMP guests, reads from the ring might bypass used index reads. This
causes guest crashes because host writes to used index to signal ring
data readiness. Fix this by inserting rmb before used ring reads.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Cc: stable@kernel.org
Commit f68d24082e22ccee3077d11aeb6dc5354f0ca7f1
in 2.6.32-rc1 broke requesting IRQs for per-VQ MSI-X vectors:
- vector number was used instead of the vector itself
- we try to request an IRQ for VQ which does not
have a callback handler
This is a regression that causes warnings in kernel log,
potentially lower performance as we need to scan vq list,
and might cause system failure if the interrupt
requested is in fact needed by another system.
This was not noticed earlier because in most cases
we were falling back on shared interrupt for all vqs.
The warnings often look like this:
virtio-pci 0000:00:03.0: irq 26 for MSI/MSI-X
virtio-pci 0000:00:03.0: irq 27 for MSI/MSI-X
virtio-pci 0000:00:03.0: irq 28 for MSI/MSI-X
IRQ handler type mismatch for IRQ 1
current handler: i8042
Pid: 2400, comm: modprobe Tainted: G W
2.6.32-rc3-11952-gf3ed8d8-dirty #1
Call Trace:
[<ffffffff81072aed>] ? __setup_irq+0x299/0x304
[<ffffffff81072ff3>] ? request_threaded_irq+0x144/0x1c1
[<ffffffff813455af>] ? vring_interrupt+0x0/0x30
[<ffffffff81346598>] ? vp_try_to_find_vqs+0x583/0x5c7
[<ffffffffa0015188>] ? skb_recv_done+0x0/0x34 [virtio_net]
[<ffffffff81346609>] ? vp_find_vqs+0x2d/0x83
[<ffffffff81345d00>] ? vp_get+0x3c/0x4e
[<ffffffffa0016373>] ? virtnet_probe+0x2f1/0x428 [virtio_net]
[<ffffffffa00150d8>] ? skb_xmit_done+0x0/0x39 [virtio_net]
[<ffffffff8110ab92>] ? sysfs_do_create_link+0xcb/0x116
[<ffffffff81345cc2>] ? vp_get_status+0x14/0x16
[<ffffffff81345464>] ? virtio_dev_probe+0xa9/0xc8
[<ffffffff8122b11c>] ? driver_probe_device+0x8d/0x128
[<ffffffff8122b206>] ? __driver_attach+0x4f/0x6f
[<ffffffff8122b1b7>] ? __driver_attach+0x0/0x6f
[<ffffffff8122a9f9>] ? bus_for_each_dev+0x43/0x74
[<ffffffff8122a374>] ? bus_add_driver+0xea/0x22d
[<ffffffff8122b4a3>] ? driver_register+0xa7/0x111
[<ffffffffa001a000>] ? init+0x0/0xc [virtio_net]
[<ffffffff81009051>] ? do_one_initcall+0x50/0x148
[<ffffffff8106e117>] ? sys_init_module+0xc5/0x21a
[<ffffffff8100af02>] ? system_call_fastpath+0x16/0x1b
Reported-by: Marcelo Tosatti <mtosatti@redhat.com>
Reported-by: Shirley Ma <xma@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
move virtrng_remove to .devexit.text
move virtballoon_remove to .devexit.text
virtio_blk: Revert serial number support
virtio: let header files include virtio_ids.h
virtio_blk: revert QUEUE_FLAG_VIRT addition
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits)
niu: VLAN_ETH_HLEN should be used to make sure that the whole MAC header was copied to the head buffer in the Vlan packets case
KS8851: Fix ks8851_set_rx_mode() for IFF_MULTICAST
KS8851: Fix MAC address write order
KS8851: Add soft reset at probe time
net: fix section mismatch in fec.c
net: Fix struct inet_timewait_sock bitfield annotation
tcp: Try to catch MSG_PEEK bug
net: Fix IP_MULTICAST_IF
bluetooth: static lock key fix
bluetooth: scheduling while atomic bug fix
tcp: fix TCP_DEFER_ACCEPT retrans calculation
tcp: reduce SYN-ACK retrans for TCP_DEFER_ACCEPT
tcp: accept socket after TCP_DEFER_ACCEPT period
Revert "tcp: fix tcp_defer_accept to consider the timeout"
AF_UNIX: Fix deadlock on connecting to shutdown socket
ethoc: clear only pending irqs
ethoc: inline regs access
vmxnet3: use dev_dbg, fix build for CONFIG_BLOCK=n
virtio_net: use dev_kfree_skb_any() in free_old_xmit_skbs()
be2net: fix support for PCI hot plug
The function virtrng_remove is used only wrapped by __devexit_p so define
it using __devexit.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
The function virtballoon_remove is used only wrapped by __devexit_p so
define it using __devexit.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
This reverts "Add serial number support for virtio_blk, V4a".
Turns out that virtio_pci, lguest and s/390 all have an 8 bit limit
on virtio config space, so noone could ever use this.
This is coming back later in a cleaner form.
Cc: john cooper <john.cooper@redhat.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Rusty,
commit 3ca4f5ca73057a617f9444a91022d7127041970a
virtio: add virtio IDs file
moved all device IDs into a single file. While the change itself is
a very good one, it can break userspace applications. For example
if a userspace tool wanted to get the ID of virtio_net it used to
include virtio_net.h. This does no longer work, since virtio_net.h
does not include virtio_ids.h.
This patch moves all "#include <linux/virtio_ids.h>" from the C
files into the header files, making the header files compatible with
the old ones.
In addition, this patch exports virtio_ids.h to userspace.
CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
It seems like the addition of QUEUE_FLAG_VIRT caueses major performance
regressions for Fedora users:
https://bugzilla.redhat.com/show_bug.cgi?id=509383
https://bugzilla.redhat.com/show_bug.cgi?id=505695
while I can't reproduce those extreme regressions myself I think the flag
is wrong.
Rationale:
QUEUE_FLAG_VIRT expands to QUEUE_FLAG_NONROT which casus the queue
unplugged immediately. This is not a good behaviour for at least
qemu and kvm where we do have significant overhead for every
I/O operations. Even with all the latested speeups (native AIO,
MSI support, zero copy) we can only get native speed for up to 128kb
I/O requests we already are down to 66% of native performance for 4kb
requests even on my laptop running the Intel X25-M SSD for which the
QUEUE_FLAG_NONROT was designed.
If we ever get virtio-blk overhead low enough that this flag makes
sense it should only be set based on a feature flag set by the host.
Signed-off-by: Joyce Yu <joyce.yu@sun.com>
* 'for-linus' of git://git.infradead.org/users/eparis/notify:
dnotify: ignore FS_EVENT_ON_CHILD
inotify: fix coalesce duplicate events into a single event in special case
inotify: deprecate the inotify kernel interface
fsnotify: do not set group for a mark before it is on the i_list
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: hp_sdc_rtc - fix test in hp_sdc_rtc_read_rt()
Input: atkbd - consolidate force release quirks for volume keys
Input: logips2pp - model 73 is actually TrackMan FX
Input: i8042 - add Sony Vaio VGN-FZ240E to the nomux list
Input: fix locking issue in /proc/bus/input/ handlers
Input: atkbd - postpone restoring LED/repeat rate at resume
Input: atkbd - restore resetting LED state at startup
Input: i8042 - make pnp_data_busted variable boolean instead of int
Input: synaptics - add another Protege M300 to rate blacklist
* 'kvm-updates/2.6.32' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: Prevent kvm_init from corrupting debugfs structures
KVM: MMU: fix pointer cast
KVM: use proper hrtimer function to retrieve expiration time
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm:
dm snapshot: allow chunk size to be less than page size
dm snapshot: use unsigned integer chunk size
dm snapshot: lock snapshot while supplying status
dm exception store: fix failed set_chunk_size error path
dm snapshot: require non zero chunk size by end of ctr
dm: dec_pending needs locking to save error value
dm: add missing del_gendisk to alloc_dev error path
dm log: userspace fix incorrect luid cast in userspace_ctr
dm snapshot: free exception store on init failure
dm snapshot: sort by chunk size to fix race
Increase TEST_SUSPEND_SECONDS to 10 so the warning in
suspend_test_finish() doesn't annoy the users of slower systems so much.
Also, make the warning print the suspend-resume cycle time, so that we
know why the warning actually triggered.
Patch prepared during the hacking session at the Kernel Summit in Tokyo.
This fixes a compile bug introduced in
6ef297f (ARM: 5720/1: Move MMCI header to amba include dir)
That commit moved arch/arm/include/asm/mach/mmc.h to
include/linux/amba/mmci.h. Just removing the include was enough.
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Bill Gatliff <bgat@billgatliff.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Pierre Ossman <drzeus@drzeus.cx>
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh/for-2.6.32' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: Kill off stray HAVE_FTRACE_SYSCALLS reference.
sh: Remove BKL from landisk gio.
sh: disabled cache handling fix.
sh: Fix up single page flushing to use PAGE_SIZE.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: aesni-intel - Fix irq_fpu_usable usage
crypto: padlock-sha - Fix stack alignment
Fix a (small) memory leak in one of the error paths of the NFS mount
options parsing code.
Regression introduced in 2.6.30 by commit a67d18f (NFS: load the
rpc/rdma transport module automatically).
Reported-by: Yinghai Lu <yinghai@kernel.org>
Reported-by: Pekka Enberg <penberg@cs.helsinki.fi>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
This patch fixes a null pointer exception in pipe_rdwr_open() which
generates the stack trace:
> Unable to handle kernel NULL pointer dereference at 0000000000000028 RIP:
> [<ffffffff802899a5>] pipe_rdwr_open+0x35/0x70
> [<ffffffff8028125c>] __dentry_open+0x13c/0x230
> [<ffffffff8028143d>] do_filp_open+0x2d/0x40
> [<ffffffff802814aa>] do_sys_open+0x5a/0x100
> [<ffffffff8021faf3>] sysenter_do_call+0x1b/0x67
The failure mode is triggered by an attempt to open an anonymous
pipe via /proc/pid/fd/* as exemplified by this script:
while : ; do
{ echo y ; sleep 1 ; } | { while read ; do echo z$REPLY; done ; } &
PID=$!
OUT=$(ps -efl | grep 'sleep 1' | grep -v grep |
{ read PID REST ; echo $PID; } )
OUT="${OUT%% *}"
DELAY=$((RANDOM * 1000 / 32768))
usleep $((DELAY * 1000 + RANDOM % 1000 ))
echo n > /proc/$OUT/fd/1 # Trigger defect
done
Note that the failure window is quite small and I could only
reliably reproduce the defect by inserting a small delay
in pipe_rdwr_open(). For example:
static int
pipe_rdwr_open(struct inode *inode, struct file *filp)
msleep(100);
mutex_lock(&inode->i_mutex);
Although the defect was observed in pipe_rdwr_open(), I think it
makes sense to replicate the change through all the pipe_*_open()
functions.
The core of the change is to verify that inode->i_pipe has not
been released before attempting to manipulate it. If inode->i_pipe
is no longer present, return ENOENT to indicate so.
The comment about potentially using atomic_t for i_pipe->readers
and i_pipe->writers has also been removed because it is no longer
relevant in this context. The inode->i_mutex lock must be used so
that inode->i_pipe can be dealt with correctly.
Signed-off-by: Earl Chew <earl_chew@agilent.com>
In ks8851_set_rx_mode() the case handling IFF_MULTICAST was also setting
the RXCR1_AE bit by accident. This meant that all unicast frames where
being accepted by the device. Remove RXCR1_AE from this case.
Note, RXCR1_AE was also masking a problem with setting the MAC address
properly, so needs to be applied after fixing the MAC write order.
Fixes a bug reported by Doong, Ping of Micrel. This version of the
patch avoids setting RXCR1_ME for all cases.
Signed-off-by: Ben Dooks <ben@simtec.co.uk>
The MAC address register was being written in the wrong order, so add
a new address macro to convert mac-address byte to register address and
a ks8851_wrreg8() function to write each byte without having to worry
about any difficult byte swapping.
Issue a full soft reset at probe time.
This was reported by Doong Ping of Micrel, but no explanation of why this
is necessary or what bug it is fixing. Add it as it does not seem to hurt
the current driver and ensures that the device is in a known state when we
start setting it up.
fec_enet_init is called by both fec_probe and fec_resume, so it
shouldn't be marked as __init.
Signed-off-by: Steven King <sfking@fdwdc.com>
Mask off FS_EVENT_ON_CHILD in dnotify_handle_event(). Otherwise, when there
is more than one watch on a directory and dnotify_should_send_event()
succeeds, events with FS_EVENT_ON_CHILD set will trigger all watches and cause
spurious events.
This case was overlooked in commit e42e2773.
#define _GNU_SOURCE
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <signal.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <string.h>
static void create_event(int s, siginfo_t* si, void* p)
printf("create\n");
static void delete_event(int s, siginfo_t* si, void* p)
printf("delete\n");
int main (void) {
struct sigaction action;
char *tmpdir, *file;
int fd1, fd2;
sigemptyset (&action.sa_mask);
action.sa_flags = SA_SIGINFO;
action.sa_sigaction = create_event;
sigaction (SIGRTMIN + 0, &action, NULL);
action.sa_sigaction = delete_event;
sigaction (SIGRTMIN + 1, &action, NULL);
# define TMPDIR "/tmp/test.XXXXXX"
tmpdir = malloc(strlen(TMPDIR) + 1);
strcpy(tmpdir, TMPDIR);
mkdtemp(tmpdir);
# define TMPFILE "/file"
file = malloc(strlen(tmpdir) + strlen(TMPFILE) + 1);
sprintf(file, "%s/%s", tmpdir, TMPFILE);
fd1 = open (tmpdir, O_RDONLY);
fcntl(fd1, F_SETSIG, SIGRTMIN);
fcntl(fd1, F_NOTIFY, DN_MULTISHOT | DN_CREATE);
fd2 = open (tmpdir, O_RDONLY);
fcntl(fd2, F_SETSIG, SIGRTMIN + 1);
fcntl(fd2, F_NOTIFY, DN_MULTISHOT | DN_DELETE);
if (fork()) {
/* This triggers a create event */
creat(file, 0600);
/* This triggers a create and delete event (!) */
unlink(file);
} else {
sleep(1);
rmdir(tmpdir);
return 0;
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 9e337b0f (net: annotate inet_timewait_sock bitfields)
added 4/8 bytes in struct inet_timewait_sock.
Fix this by declaring tw_ipv6_offset in the 'flags' bitfield
The 14 bits hole is named tw_pad to make it cleary apparent.
This patch tries to print out more information when we hit the
MSG_PEEK bug in tcp_recvmsg. It's been around since at least
2005 and it's about time that we finally fix it.
When renaming kernel_fpu_using to irq_fpu_usable, the semantics of the
function is changed too, from mesuring whether kernel is using FPU,
that is, the FPU is NOT available, to measuring whether FPU is usable,
that is, the FPU is available.
But the usage of irq_fpu_usable in aesni-intel_glue.c is not changed
accordingly. This patch fixes this.
Signed-off-by: Huang Ying <ying.huang@intel.com>
ipv4/ipv6 setsockopt(IP_MULTICAST_IF) have dubious __dev_get_by_index() calls.
This function should be called only with RTNL or dev_base_lock held, or reader
could see a corrupt hash chain and eventually enter an endless loop.
Fix is to call dev_get_by_index()/dev_put().
If this happens to be performance critical, we could define a new dev_exist_by_index()
function to avoid touching dev refcount.
When shutdown ppp connection, lockdep waring about non-static key
will happen, it is caused by the lock is not initialized properly
at that time.
Fix with tuning the lock/skb_queue_head init order
[ 94.339261] INFO: trying to register non-static key.
[ 94.342509] the code is fine but needs lockdep annotation.
[ 94.342509] turning off the locking correctness validator.
[ 94.342509] Pid: 0, comm: swapper Not tainted 2.6.31-mm1 #2
[ 94.342509] Call Trace:
[ 94.342509] [<c0248fbe>] register_lock_class+0x58/0x241
[ 94.342509] [<c024b5df>] ? __lock_acquire+0xb57/0xb73
[ 94.342509] [<c024ab34>] __lock_acquire+0xac/0xb73
[ 94.342509] [<c024b7fa>] ? lock_release_non_nested+0x17b/0x1de
[ 94.342509] [<c024b662>] lock_acquire+0x67/0x84
[ 94.342509] [<c04cd1eb>] ? skb_dequeue+0x15/0x41
[ 94.342509] [<c054a857>] _spin_lock_irqsave+0x2f/0x3f
[ 94.342509] [<c04cd1eb>] skb_dequeue+0x15/0x41
[ 94.342509] [<c054a648>] ? _read_unlock+0x1d/0x20
[ 94.342509] [<c04cd641>] skb_queue_purge+0x14/0x1b
[ 94.342509] [<fab94fdc>] l2cap_recv_frame+0xea1/0x115a [l2cap]
[ 94.342509] [<c0249c04>] ? mark_lock+0x1e/0x1c7
[ 94.342509] [<f8364963>] ? hci_rx_task+0xd2/0x1bc [bluetooth]
[ 94.342509] [<fab95346>] l2cap_recv_acldata+0xb1/0x1c6 [l2cap]
[ 94.342509] [<f8364997>] hci_rx_task+0x106/0x1bc [bluetooth]
[ 94.342509] [<fab95295>] ? l2cap_recv_acldata+0x0/0x1c6 [l2cap]
[ 94.342509] [<c02302c4>] tasklet_action+0x69/0xc1
[ 94.342509] [<c022fbef>] __do_softirq+0x94/0x11e
[ 94.342509] [<c022fcaf>] do_softirq+0x36/0x5a
[ 94.342509] [<c022fe14>] irq_exit+0x35/0x68
[ 94.342509] [<c0204ced>] do_IRQ+0x72/0x89
[ 94.342509] [<c02038ee>] common_interrupt+0x2e/0x34
[ 94.342509] [<c024007b>] ? pm_qos_add_requirement+0x63/0x9d
[ 94.342509] [<c038e8a5>] ? acpi_idle_enter_bm+0x209/0x238
[ 94.342509] [<c049d238>] cpuidle_idle_call+0x5c/0x94
[ 94.342509] [<c02023f8>] cpu_idle+0x4e/0x6f
[ 94.342509] [<c0534153>] rest_init+0x53/0x55
[ 94.342509] [<c0781894>] start_kernel+0x2f0/0x2f5
[ 94.342509] [<c0781091>] i386_start_kernel+0x91/0x96
Reported-by: Oliver Hartkopp <oliver@hartkopp.net>
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Tested-by: Oliver Hartkopp <oliver@hartkopp.net>
Due to driver core changes dev_set_drvdata will call kzalloc which should be
in might_sleep context, but hci_conn_add will be called in atomic context
Like dev_set_name move dev_set_drvdata to work queue function.
oops as following:
Oct 2 17:41:59 darkstar kernel: [ 438.001341] BUG: sleeping function called from invalid context at mm/slqb.c:1546
Oct 2 17:41:59 darkstar kernel: [ 438.001345] in_atomic(): 1, irqs_disabled(): 0, pid: 2133, name: sdptool
Oct 2 17:41:59 darkstar kernel: [ 438.001348] 2 locks held by sdptool/2133:
Oct 2 17:41:59 darkstar kernel: [ 438.001350] #0: (sk_lock-AF_BLUETOOTH-BTPROTO_L2CAP){+.+.+.}, at: [<faa1d2f5>] lock_sock+0xa/0xc [l2cap]
Oct 2 17:41:59 darkstar kernel: [ 438.001360] #1: (&hdev->lock){+.-.+.}, at: [<faa20e16>] l2cap_sock_connect+0x103/0x26b [l2cap]
Oct 2 17:41:59 darkstar kernel: [ 438.001371] Pid: 2133, comm: sdptool Not tainted 2.6.31-mm1 #2
Oct 2 17:41:59 darkstar kernel: [ 438.001373] Call Trace:
Oct 2 17:41:59 darkstar kernel: [ 438.001381] [<c022433f>] __might_sleep+0xde/0xe5
Oct 2 17:41:59 darkstar kernel: [ 438.001386] [<c0298843>] __kmalloc+0x4a/0x15a
Oct 2 17:41:59 darkstar kernel: [ 438.001392] [<c03f0065>] ? kzalloc+0xb/0xd
Oct 2 17:41:59 darkstar kernel: [ 438.001396] [<c03f0065>] kzalloc+0xb/0xd
Oct 2 17:41:59 darkstar kernel: [ 438.001400] [<c03f04ff>] device_private_init+0x15/0x3d
Oct 2 17:41:59 darkstar kernel: [ 438.001405] [<c03f24c5>] dev_set_drvdata+0x18/0x26
Oct 2 17:41:59 darkstar kernel: [ 438.001414] [<fa51fff7>] hci_conn_init_sysfs+0x40/0xd9 [bluetooth]
Oct 2 17:41:59 darkstar kernel: [ 438.001422] [<fa51cdc0>] ? hci_conn_add+0x128/0x186 [bluetooth]
Oct 2 17:41:59 darkstar kernel: [ 438.001429] [<fa51ce0f>] hci_conn_add+0x177/0x186 [bluetooth]
Oct 2 17:41:59 darkstar kernel: [ 438.001437] [<fa51cf8a>] hci_connect+0x3c/0xfb [bluetooth]
Oct 2 17:41:59 darkstar kernel: [ 438.001442] [<faa20e87>] l2cap_sock_connect+0x174/0x26b [l2cap]
Oct 2 17:41:59 darkstar kernel: [ 438.001448] [<c04c8df5>] sys_connect+0x60/0x7a
Oct 2 17:41:59 darkstar kernel: [ 438.001453] [<c024b703>] ? lock_release_non_nested+0x84/0x1de
Oct 2 17:41:59 darkstar kernel: [ 438.001458] [<c028804b>] ? might_fault+0x47/0x81
Oct 2 17:41:59 darkstar kernel: [ 438.001462] [<c028804b>] ? might_fault+0x47/0x81
Oct 2 17:41:59 darkstar kernel: [ 438.001468] [<c033361f>] ? __copy_from_user_ll+0x11/0xce
Oct 2 17:41:59 darkstar kernel: [ 438.001472] [<c04c9419>] sys_socketcall+0x82/0x17b
Oct 2 17:41:59 darkstar kernel: [ 438.001477] [<c020329d>] syscall_call+0x7/0xb
Fix TCP_DEFER_ACCEPT conversion between seconds and
retransmission to match the TCP SYN-ACK retransmission periods
because the time is converted to such retransmissions. The old
algorithm selects one more retransmission in some cases. Allow
up to 255 retransmissions.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Change SYN-ACK retransmitting code for the TCP_DEFER_ACCEPT
users to not retransmit SYN-ACKs during the deferring period if
ACK from client was received. The goal is to reduce traffic
during the deferring period. When the period is finished
we continue with sending SYN-ACKs (at least one) but this time
any traffic from client will change the request to established
socket allowing application to terminate it properly.
Also, do not drop acked request if sending of SYN-ACK fails.
Willy Tarreau and many other folks in recent years
were concerned what happens when the TCP_DEFER_ACCEPT period
expires for clients which sent ACK packet. They prefer clients
that actively resend ACK on our SYN-ACK retransmissions to be
converted from open requests to sockets and queued to the
listener for accepting after the deferring period is finished.
Then application server can decide to wait longer for data
or to properly terminate the connection with FIN if read()
returns EAGAIN which is an indication for accepting after
the deferring period. This change still can have side effects
for applications that expect always to see data on the accepted
socket. Others can be prepared to work in both modes (with or
without TCP_DEFER_ACCEPT period) and their data processing can
ignore the read=EAGAIN notification and to allocate resources for
clients which proved to have no data to send during the deferring
period. OTOH, servers that use TCP_DEFER_ACCEPT=1 as flag (not
as a timeout) to wait for data will notice clients that didn't
send data for 3 seconds but that still resend ACKs.
Thanks to Willy Tarreau for the initial idea and to
Eric Dumazet for the review and testing the change.
This reverts commit 6d01a026b7d3009a418326bdcf313503a314f1ea.
Julian Anastasov, Willy Tarreau and Eric Dumazet have come up
with a more correct way to deal with this.
I found a deadlock bug in UNIX domain socket, which makes able to DoS
attack against the local machine by non-root users.
How to reproduce:
1. Make a listening AF_UNIX/SOCK_STREAM socket with an abstruct
namespace(*), and shutdown(2) it.
2. Repeat connect(2)ing to the listening socket from the other sockets
until the connection backlog is full-filled.
3. connect(2) takes the CPU forever. If every core is taken, the
system hangs.
PoC code: (Run as many times as cores on SMP machines.)
int main(void)
int ret;
int csd;
int lsd;
struct sockaddr_un sun;
/* make an abstruct name address (*) */
memset(&sun, 0, sizeof(sun));
sun.sun_family = PF_UNIX;
sprintf(&sun.sun_path[1], "%d", getpid());
/* create the listening socket and shutdown */
lsd = socket(AF_UNIX, SOCK_STREAM, 0);
bind(lsd, (struct sockaddr *)&sun, sizeof(sun));
listen(lsd, 1);
shutdown(lsd, SHUT_RDWR);
/* connect loop */
alarm(15); /* forcely exit the loop after 15 sec */
for (;;) {
csd = socket(AF_UNIX, SOCK_STREAM, 0);
ret = connect(csd, (struct sockaddr *)&sun, sizeof(sun));
if (-1 == ret) {
perror("connect()");
break;
puts("Connection OK");
return 0;
(*) Make sun_path[0] = 0 to use the abstruct namespace.
If a file-based socket is used, the system doesn't deadlock because
of context switches in the file system layer.
Why this happens:
Error checks between unix_socket_connect() and unix_wait_for_peer() are
inconsistent. The former calls the latter to wait until the backlog is
processed. Despite the latter returns without doing anything when the
socket is shutdown, the former doesn't check the shutdown state and
just retries calling the latter forever.
Patch:
The patch below adds shutdown check into unix_socket_connect(), so
connect(2) to the shutdown socket will return -ECONREFUSED.
Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama.qu@hitachi.com>
Signed-off-by: Masanori Yoshida <masanori.yoshida.tv@hitachi.com>
This patch fixed the problem of dropped packets due to lost of
interrupt requests. We should only clear what was pending at the
moment we read the irq source reg.
If we do rename a dir entry, like this:
rename("/tmp/ino7UrgoJ.rename1", "/tmp/ino7UrgoJ.rename2")
rename("/tmp/ino7UrgoJ.rename2", "/tmp/ino7UrgoJ")
The duplicate events should be coalesced into a single event. But those two
events do not be coalesced into a single event, due to some bad check in
event_compare(). It can not match the two NULL inodes as the same event.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
In 2.6.33 there will be no users of the inotify interface. Mark it for
removal as fsnotify is more generic and is easier to use.
fsnotify_add_mark is supposed to add a mark to the g_list and i_list and to
set the group and inode for the mark. fsnotify_destroy_mark_by_entry uses
the fact that ->group != NULL to know if this group should be destroyed or
if it's already been done.
But fsnotify_add_mark sets the group and inode before it actually adds the
mark to the i_list and g_list. This can result in a race in inotify, it
requires 3 threads.
sys_inotify_add_watch("file") sys_inotify_add_watch("file") sys_inotify_rm_watch([a])
inotify_update_watch()
inotify_new_watch()
inotify_add_to_idr()
^--- returns wd = [a]
inotfiy_update_watch()
inotify_new_watch()
fsnotify_add_mark()
^--- returns wd = [b]
returns to userspace;
inotify_idr_find([a])
^--- gives us the pointer from task 1
fsnotify_add_mark()
^--- this is going to set the mark->group and mark->inode fields, but will
return -EEXIST because of the race with [b].
fsnotify_destroy_mark()
^--- since ->group != NULL we call back
into inotify_freeing_mark() which calls
inotify_remove_from_idr([a])
since fsnotify_add_mark() failed we call:
inotify_remove_from_idr([a]) <------WHOOPS it's not in the idr, this could
have been any entry added later!
The fix is to make sure we don't set mark->group until we are sure the mark is
on the inode and fsnotify_add_mark will return success.
If left unsigned the hp_sdc_rtc_read_i8042timer() return value will not
be checked correctly.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Some machines share same key list for volume up/down release key quirks,
use only one key list.
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Reported-and-tested-by: Harald Dunkel <harald.dunkel@t-online.de>
On this model, when KBD is in active multiplexing mode, acknowledgements
to reset and get ID commands issued on KBD port sometimes are delivered
to AUX3 port (touchpad) which messes up device detection. Legacy KBC
mode works fine and since there are no external PS/2 ports on this laptop
and no support for docking station we can safely disable active MUX mode.
Tested-by: Carlos R. Mafra <crmafra2@gmail.com>
vmxnet3 was using dprintk() for debugging output. This was
defined in <linux/dst.h> and was the only thing that was
used from that header file. This caused compile errors
when CONFIG_BLOCK was not enabled due to bio* and BIO*
uses in the header file, so change this driver to use
dev_dbg() for debugging output.
include/linux/dst.h:520: error: dereferencing pointer to incomplete type
include/linux/dst.h:520: error: 'BIO_POOL_BITS' undeclared (first use in this function)
include/linux/dst.h:521: error: dereferencing pointer to incomplete type
include/linux/dst.h:522: error: dereferencing pointer to incomplete type
include/linux/dst.h:525: error: dereferencing pointer to incomplete type
make[4]: *** [drivers/net/vmxnet3/vmxnet3_drv.o] Error 1
Signed-off-by: Bhavesh Davda <bhavesh@vmware.com>
Allow the snapshot chunk size to be smaller than the page size
The code is now capable of handling this due to some previous
fixes and enhancements.
As the page size varies between computers, prior to this patch,
the chunk size of a snapshot dictated which machines could read it:
Snapshots created on one machine might not be readable on another.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Reviewed-by: Mike Snitzer <snitzer@redhat.com>
Reviewed-by: Jonathan Brassow <jbrassow@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Use unsigned integer chunk size.
Maximum chunk size is 512kB, there won't ever be need to use 4GB chunk size,
so the number can be 32-bit. This fixes compiler failure on 32-bit systems
with large block devices.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
This patch locks the snapshot when returning status. It fixes a race
when it could return an invalid number of free chunks if someone
was simultaneously modifying it.
Properly close the device if failing because of an invalid chunk size.
