2024-02-22Merge tag 'v5.15.139' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.139 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: drivers/clk/imx/clk-imx8mq.c
2024-02-22Merge commit v5.15.138+reverts into fslc-5.15-2.2.x-imxMax Krummenacher
Revert the following commits in stable before merging, the sources have been heavely modified by NXP. d4c8bf5635c4b rpmsg: Fix possible refcount leak in rpmsg_register_device_override() a82e0fda8a2f8 rpmsg: glink: Release driver_override bfd4a664ddfbe rpmsg: Fix calling device_lock() on non-initialized device 2e76b4f6218c4 rpmsg: Fix kfree() of static memory on setting driver_override 5c0da71871d3a rpmsg: Constify local variable in field store macro Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: drivers/misc/pci_endpoint_test.c
2024-02-22Revert "rpmsg: Constify local variable in field store macro"Max Krummenacher
This reverts commit 5c0da71871d3ac3f96d37067bf1a0ba9c25c2c72. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Revert "rpmsg: Fix kfree() of static memory on setting driver_override"Max Krummenacher
This reverts commit 2e76b4f6218c4db3ff00eb15d94d72f371736de4. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Revert "rpmsg: Fix calling device_lock() on non-initialized device"Max Krummenacher
This reverts commit bfd4a664ddfbe12f008efb0b0ab6bf25a8ab2538. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Revert "rpmsg: glink: Release driver_override"Max Krummenacher
This reverts commit a82e0fda8a2f8561a6a6681e8b3557e60cad17da. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Revert "rpmsg: Fix possible refcount leak in rpmsg_register_device_override()"Max Krummenacher
This reverts commit d4c8bf5635c4bedaf2470761ced1f502b2d5434e. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.137' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.137 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.136' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.136 stable release Conflicts: Documentation/security/keys/trusted-encrypted.rst security/keys/trusted-keys/trusted_core.c Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge tag 'v5.15.135' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.135 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge tag 'v5.15.134' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.134 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge tag 'v5.15.133' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.133 stable release Conflicts: drivers/perf/fsl_imx8_ddr_perf.c Used the stable fix Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge commit v5.4.132 into fslc-5.15-2.2.x-imxMax Krummenacher
Revert the following commits before merging, the sources have been heavely modified by NXP. 5a86ca588b3f9 Revert "perf/imx_ddr: don't enable counter0 if none of 4 counters are used" 56ad67babb7fb Revert "usb: phy: mxs: fix getting wrong state with mxs_phy_is_otg_host()" 50b3a42d82f07 Revert "USB: core: Unite old scheme and new scheme descriptor reads" cdcf46014f5ca Revert "USB: core: Change usb_get_device_descriptor() API" 2f2af6028f201 Revert "USB: core: Fix race by not overwriting udev->descriptor in hub_port_init()" 9e168d3268f89 Revert "USB: core: Fix oversight in SuperSpeed initialization" 7e95107f9b664 Revert "PCI: dwc: Add start_link/stop_link inlines" d0bec10a7f796 Revert "PCI: layerscape: Add the endpoint linkup notifier support" aaf9dc6089bc3 Revert "PCI: layerscape: Add workaround for lost link capabilities during reset" Conflicts: arch/arm/boot/dts/imx6qdl.dtsi arch/arm/boot/dts/imx6sx.dtsi Keep stable node name changes drivers/gpu/drm/bridge/adv7511/adv7511_drv.c Keep stable code change drivers/media/i2c/ov5640.c Keep stable code change Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge tag 'v5.15.131' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.131 stable release
2024-02-21Merge tag 'v5.15.130' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.130 stable release
2024-02-20MGS-7215 [#imx-3183] 0034-CL694252-KERNEL-SPACE-6.4.11_22Q2_NXP-IMX-3189-fix-tYuan Tian
6.4.11_22Q2_NXP: IMX-3189: fix the build error caused by conflicting types of "_QuerySignal" with gcc13.1. Signed-off-by: IPD_SCM <IPD_SCM@verisilicon.com> Signed-off-by: Yuan Tian <yuan.tian@nxp.com> Upstream-Status: Inappropriate [other] Upstream does not have the propriatery Vivante driver. Cherry picked from NXP downstream commit 9b70e0e11b04c18545093bd6d172762f65709365. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "perf/imx_ddr: don't enable counter0 if none of 4 counters are used"Max Krummenacher
This reverts commit c7802ff51adce9ae2e8392b926943342549de38c. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "usb: phy: mxs: fix getting wrong state with mxs_phy_is_otg_host()"Max Krummenacher
This reverts commit 484ddaa90b7e8b40b0a479dfc24f0a1b9cd70e7d. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "USB: core: Unite old scheme and new scheme descriptor reads"Max Krummenacher
This reverts commit 56c49a3328e988c82981f4d098be22695d46fcf3. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "USB: core: Change usb_get_device_descriptor() API"Max Krummenacher
This reverts commit eda9a296658203b1cc07d777c19c8c9eac6d0d17. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "USB: core: Fix race by not overwriting udev->descriptor in ↵Max Krummenacher
hub_port_init()" This reverts commit 7fe9d87996062f5eb0ca476ad0257f79bf43aaf5. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "USB: core: Fix oversight in SuperSpeed initialization"Max Krummenacher
This reverts commit 7e3ddbea87a92979fda4a9ddac37f423cb5a9d8a. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "PCI: dwc: Add start_link/stop_link inlines"Max Krummenacher
This reverts commit 69c712389e1f5e6761fc27fe39a36ca56b0c560c. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "PCI: layerscape: Add the endpoint linkup notifier support"Max Krummenacher
This reverts commit 4be323c73797bcebd0f9d1642e4705c13c3749d2. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "PCI: layerscape: Add workaround for lost link capabilities during reset"Max Krummenacher
This reverts commit cefcb002c5c9bc107daee807e25636a9afc7aba7. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-19Merge branch 'lf-5.15.y' into fslc-5.15-2.2.x-imxMax Krummenacher
Merge tag lf-5.15.71-2.2.2 with reverted upstream (sound/) commits 339ba37942c9d 6f668d2cbd2e2 d62dd3e291e06 416f4b7624040 1c23070f17c59 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-19Revert "ASoC: ops: Check for negative values before reading them"Max Krummenacher
This reverts commit 1c23070f17c5934e31db5c2dda79c681eedea538.
2024-02-19Revert "ASoC: ops: Fix bounds check for _sx controls"Max Krummenacher
This reverts commit 416f4b76240400260aaf0c4200565d63f49290d7.
2024-02-19Revert "ASoC: ops: Check bounds for second channel in snd_soc_put_volsw_sx()"Max Krummenacher
This reverts commit d62dd3e291e061d66e088401e32f1119bcfdc7f3.
2024-02-19Revert "ASoC: ops: Clarify snd_soc_info_volsw_sx()"Max Krummenacher
This reverts commit 6f668d2cbd2e2b87a3f347070704714453383712.
2024-02-19Revert "ASoC: ops: Remove unneeded delay.h inclusion"Max Krummenacher
This reverts commit 339ba37942c9de7aeb7647b6a225c49cc3d7e0dc.
2023-11-20Linux 5.15.139Greg Kroah-Hartman
Link: https://lore.kernel.org/r/20231115203548.387164783@linuxfoundation.org Tested-by: SeongJae Park <sj@kernel.org> Tested-by: Linux Kernel Functional Testing <lkft@linaro.org> Tested-by: Allen Pais <apais@linux.microsoft.com> Tested-by: Ron Economos <re@w6rz.net> Tested-by: Harshit Mogalapalli <harshit.m.mogalapalli@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2023-11-20btrfs: use u64 for buffer sizes in the tree search ioctlsFilipe Manana
[ Upstream commit dec96fc2dcb59723e041416b8dc53e011b4bfc2e ] In the tree search v2 ioctl we use the type size_t, which is an unsigned long, to track the buffer size in the local variable 'buf_size'. An unsigned long is 32 bits wide on a 32 bits architecture. The buffer size defined in struct btrfs_ioctl_search_args_v2 is a u64, so when we later try to copy the local variable 'buf_size' to the argument struct, when the search returns -EOVERFLOW, we copy only 32 bits which will be a problem on big endian systems. Fix this by using a u64 type for the buffer sizes, not only at btrfs_ioctl_tree_search_v2(), but also everywhere down the call chain so that we can use the u64 at btrfs_ioctl_tree_search_v2(). Fixes: cc68a8a5a433 ("btrfs: new ioctl TREE_SEARCH_V2") Reported-by: Dan Carpenter <dan.carpenter@linaro.org> Link: https://lore.kernel.org/linux-btrfs/ce6f4bd6-9453-4ffe-ba00-cee35495e10f@moroto.mountain/ Signed-off-by: Filipe Manana <fdmanana@suse.com> Reviewed-by: David Sterba <dsterba@suse.com> Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20Revert "mmc: core: Capture correct oemid-bits for eMMC cards"Dominique Martinet
commit 421b605edb1ce611dee06cf6fd9a1c1f2fd85ad0 upstream. This reverts commit 84ee19bffc9306128cd0f1c650e89767079efeff. The commit above made quirks with an OEMID fail to be applied, as they were checking card->cid.oemid for the full 16 bits defined in MMC_FIXUP macros but the field would only contain the bottom 8 bits. eMMC v5.1A might have bogus values in OEMID's higher bits so another fix will be made, but it has been decided to revert this until that is ready. Fixes: 84ee19bffc93 ("mmc: core: Capture correct oemid-bits for eMMC cards") Link: https://lkml.kernel.org/r/ZToJsSLHr8RnuTHz@codewreck.org Link: https://lkml.kernel.org/r/CAPDyKFqkKibcXnwjnhc3+W1iJBHLeqQ9BpcZrSwhW2u9K2oUtg@mail.gmail.com Signed-off-by: Dominique Martinet <dominique.martinet@atmark-techno.com> Cc: stable@vger.kernel.org Cc: Alex Fetters <Alex.Fetters@garmin.com> Reviewed-by: Avri Altman <avri.altman@wdc.com> Link: https://lore.kernel.org/r/20231103004220.1666641-1-asmadeus@codewreck.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2023-11-20tracing/kprobes: Fix the order of argument descriptionsYujie Liu
[ Upstream commit f032c53bea6d2057c14553832d846be2f151cfb2 ] The order of descriptions should be consistent with the argument list of the function, so "kretprobe" should be the second one. int __kprobe_event_gen_cmd_start(struct dynevent_cmd *cmd, bool kretprobe, const char *name, const char *loc, ...) Link: https://lore.kernel.org/all/20231031041305.3363712-1-yujie.liu@intel.com/ Fixes: 2a588dd1d5d6 ("tracing: Add kprobe event command generation functions") Suggested-by: Mukesh Ojha <quic_mojha@quicinc.com> Signed-off-by: Yujie Liu <yujie.liu@intel.com> Reviewed-by: Mukesh Ojha <quic_mojha@quicinc.com> Signed-off-by: Masami Hiramatsu (Google) <mhiramat@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20fbdev: fsl-diu-fb: mark wr_reg_wa() staticArnd Bergmann
[ Upstream commit a5035c81847430dfa3482807b07325f29e9e8c09 ] wr_reg_wa() is not an appropriate name for a global function, and doesn't need to be global anyway, so mark it static and avoid the warning: drivers/video/fbdev/fsl-diu-fb.c:493:6: error: no previous prototype for 'wr_reg_wa' [-Werror=missing-prototypes] Fixes: 0d9dab39fbbe ("powerpc/5121: fsl-diu-fb: fix issue with re-enabling DIU area descriptor") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20fbdev: imsttfb: fix a resource leak in probeDan Carpenter
[ Upstream commit aba6ab57a910ad4b940c2024d15f2cdbf5b7f76b ] I've re-written the error handling but the bug is that if init_imstt() fails we need to call iounmap(par->cmap_regs). Fixes: c75f5a550610 ("fbdev: imsttfb: Fix use after free bug in imsttfb_probe") Signed-off-by: Dan Carpenter <dan.carpenter@linaro.org> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20fbdev: imsttfb: Fix error path of imsttfb_probe()Helge Deller
[ Upstream commit 518ecb6a209f6ff678aeadf9f2bf870c0982ca85 ] Release ressources when init_imstt() returns failure. Signed-off-by: Helge Deller <deller@gmx.de> Stable-dep-of: aba6ab57a910 ("fbdev: imsttfb: fix a resource leak in probe") Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20spi: spi-zynq-qspi: add spi-mem to driver kconfig dependenciesAmit Kumar Mahapatra
[ Upstream commit c2ded280a4b1b7bd93e53670528504be08d24967 ] Zynq QSPI driver has been converted to use spi-mem framework so add spi-mem to driver kconfig dependencies. Fixes: 67dca5e580f1 ("spi: spi-mem: Add support for Zynq QSPI controller") Signed-off-by: Amit Kumar Mahapatra <amit.kumar-mahapatra@amd.com> Signed-off-by: Radhey Shyam Pandey <radhey.shyam.pandey@amd.com> Link: https://lore.kernel.org/r/1699037031-702858-1-git-send-email-radhey.shyam.pandey@amd.com Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20ASoC: hdmi-codec: register hpd callback on component probeJerome Brunet
[ Upstream commit 15be353d55f9e12e34f9a819f51eb41fdef5eda8 ] The HDMI hotplug callback to the hdmi-codec is currently registered when jack is set. The hotplug not only serves to report the ASoC jack state but also to get the ELD. It should be registered when the component probes instead, so it does not depend on the card driver registering a jack for the HDMI to properly report the ELD. Fixes: 25ce4f2b3593 ("ASoC: hdmi-codec: Get ELD in before reporting plugged event") Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Link: https://lore.kernel.org/r/20231106104013.704356-1-jbrunet@baylibre.com Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20drm/syncobj: fix DRM_SYNCOBJ_WAIT_FLAGS_WAIT_AVAILABLEErik Kurzinger
[ Upstream commit 101c9f637efa1655f55876644d4439e552267527 ] If DRM_IOCTL_SYNCOBJ_TIMELINE_WAIT is invoked with the DRM_SYNCOBJ_WAIT_FLAGS_WAIT_AVAILABLE flag set but no fence has yet been submitted for the given timeline point the call will fail immediately with EINVAL. This does not match the intended behavior where the call should wait until the fence has been submitted (or the timeout expires). The following small example program illustrates the issue. It should wait for 5 seconds and then print ETIME, but instead it terminates right away after printing EINVAL. #include <stdio.h> #include <fcntl.h> #include <time.h> #include <errno.h> #include <xf86drm.h> int main(void) { int fd = open("/dev/dri/card0", O_RDWR); uint32_t syncobj; drmSyncobjCreate(fd, 0, &syncobj); struct timespec ts; clock_gettime(CLOCK_MONOTONIC, &ts); uint64_t point = 1; if (drmSyncobjTimelineWait(fd, &syncobj, &point, 1, ts.tv_sec * 1000000000 + ts.tv_nsec + 5000000000, // 5s DRM_SYNCOBJ_WAIT_FLAGS_WAIT_AVAILABLE, NULL)) { printf("drmSyncobjTimelineWait failed %d\n", errno); } } Fixes: 01d6c3578379 ("drm/syncobj: add support for timeline point wait v8") Signed-off-by: Erik Kurzinger <ekurzinger@nvidia.com> Reviewed by: Simon Ser <contact@emersion.fd> Signed-off-by: Simon Ser <contact@emersion.fr> Link: https://patchwork.freedesktop.org/patch/msgid/1fac96f1-2f3f-f9f9-4eb0-340f27a8f6c0@nvidia.com Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20netfilter: nat: fix ipv6 nat redirect with mapped and scoped addressesFlorian Westphal
[ Upstream commit 80abbe8a8263106fe45a4f293b92b5c74cc9cc8a ] The ipv6 redirect target was derived from the ipv4 one, i.e. its identical to a 'dnat' with the first (primary) address assigned to the network interface. The code has been moved around to make it usable from nf_tables too, but its still the same as it was back when this was added in 2012. IPv6, however, has different types of addresses, if the 'wrong' address comes first the redirection does not work. In Daniels case, the addresses are: inet6 ::ffff:192 ... inet6 2a01: ... ... so the function attempts to redirect to the mapped address. Add more checks before the address is deemed correct: 1. If the packets' daddr is scoped, search for a scoped address too 2. skip tentative addresses 3. skip mapped addresses Use the first address that appears to match our needs. Reported-by: Daniel Huhardeaux <tech@tootai.net> Closes: https://lore.kernel.org/netfilter/71be06b8-6aa0-4cf9-9e0b-e2839b01b22f@tootai.net/ Fixes: 115e23ac78f8 ("netfilter: ip6tables: add REDIRECT target") Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20netfilter: nft_redir: use `struct nf_nat_range2` throughout and deduplicate ↵Jeremy Sowden
eval call-backs [ Upstream commit 6f56ad1b92328997e1b1792047099df6f8d7acb5 ] `nf_nat_redirect_ipv4` takes a `struct nf_nat_ipv4_multi_range_compat`, but converts it internally to a `struct nf_nat_range2`. Change the function to take the latter, factor out the code now shared with `nf_nat_redirect_ipv6`, move the conversion to the xt_REDIRECT module, and update the ipv4 range initialization in the nft_redir module. Replace a bare hex constant for 127.0.0.1 with a macro. Remove `WARN_ON`. `nf_nat_setup_info` calls `nf_ct_is_confirmed`: /* Can't setup nat info for confirmed ct. */ if (nf_ct_is_confirmed(ct)) return NF_ACCEPT; This means that `ct` cannot be null or the kernel will crash, and implies that `ctinfo` is `IP_CT_NEW` or `IP_CT_RELATED`. nft_redir has separate ipv4 and ipv6 call-backs which share much of their code, and an inet one switch containing a switch that calls one of the others based on the family of the packet. Merge the ipv4 and ipv6 ones into the inet one in order to get rid of the duplicate code. Const-qualify the `priv` pointer since we don't need to write through it. Assign `priv->flags` to the range instead of OR-ing it in. Set the `NF_NAT_RANGE_PROTO_SPECIFIED` flag once during init, rather than on every eval. Signed-off-by: Jeremy Sowden <jeremy@azazel.net> Signed-off-by: Florian Westphal <fw@strlen.de> Stable-dep-of: 80abbe8a8263 ("netfilter: nat: fix ipv6 nat redirect with mapped and scoped addresses") Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20netfilter: xt_recent: fix (increase) ipv6 literal buffer lengthMaciej Żenczykowski
[ Upstream commit 7b308feb4fd2d1c06919445c65c8fbf8e9fd1781 ] in6_pton() supports 'low-32-bit dot-decimal representation' (this is useful with DNS64/NAT64 networks for example): # echo +aaaa:bbbb:cccc:dddd:eeee:ffff:1.2.3.4 > /proc/self/net/xt_recent/DEFAULT # cat /proc/self/net/xt_recent/DEFAULT src=aaaa:bbbb:cccc:dddd:eeee:ffff:0102:0304 ttl: 0 last_seen: 9733848829 oldest_pkt: 1 9733848829 but the provided buffer is too short: # echo +aaaa:bbbb:cccc:dddd:eeee:ffff:255.255.255.255 > /proc/self/net/xt_recent/DEFAULT -bash: echo: write error: Invalid argument Fixes: 079aa88fe717 ("netfilter: xt_recent: IPv6 support") Signed-off-by: Maciej Żenczykowski <zenczykowski@gmail.com> Reviewed-by: Simon Horman <horms@kernel.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20i2c: iproc: handle invalid slave stateRoman Bacik
[ Upstream commit ba15a14399c262f91ce30c19fcbdc952262dd1be ] Add the code to handle an invalid state when both bits S_RX_EVENT (indicating a transaction) and S_START_BUSY (indicating the end of transaction - transition of START_BUSY from 1 to 0) are set in the interrupt status register during a slave read. Signed-off-by: Roman Bacik <roman.bacik@broadcom.com> Fixes: 1ca1b4516088 ("i2c: iproc: handle Master aborted error") Acked-by: Ray Jui <ray.jui@broadcom.com> Signed-off-by: Wolfram Sang <wsa@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20r8169: respect userspace disabling IFF_MULTICASTHeiner Kallweit
[ Upstream commit 8999ce4cfc87e61b4143ec2e7b93d8e92e11fa7f ] So far we ignore the setting of IFF_MULTICAST. Fix this and clear bit AcceptMulticast if IFF_MULTICAST isn't set. Note: Based on the implementations I've seen it doesn't seem to be 100% clear what a driver is supposed to do if IFF_ALLMULTI is set but IFF_MULTICAST is not. This patch is based on the understanding that IFF_MULTICAST has precedence. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com> Link: https://lore.kernel.org/r/4a57ba02-d52d-4369-9f14-3565e6c1f7dc@gmail.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20blk-core: use pr_warn_ratelimited() in bio_check_ro()Yu Kuai
[ Upstream commit 1b0a151c10a6d823f033023b9fdd9af72a89591b ] If one of the underlying disks of raid or dm is set to read-only, then each io will generate new log, which will cause message storm. This environment is indeed problematic, however we can't make sure our naive custormer won't do this, hence use pr_warn_ratelimited() to prevent message storm in this case. Signed-off-by: Yu Kuai <yukuai3@huawei.com> Fixes: 57e95e4670d1 ("block: fix and cleanup bio_check_ro") Signed-off-by: Ye Bin <yebin10@huawei.com> Link: https://lore.kernel.org/r/20231107111247.2157820-1-yukuai1@huaweicloud.com Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20block: remove unneeded return value of bio_check_ro()Miaohe Lin
[ Upstream commit bdb7d420c6f6d2618d4c907cd7742c3195c425e2 ] bio_check_ro() always return false now. Remove this unneeded return value and cleanup the sole caller. No functional change intended. Signed-off-by: Miaohe Lin <linmiaohe@huawei.com> Link: https://lore.kernel.org/r/20220905102754.1942-1-linmiaohe@huawei.com Signed-off-by: Jens Axboe <axboe@kernel.dk> Stable-dep-of: 1b0a151c10a6 ("blk-core: use pr_warn_ratelimited() in bio_check_ro()") Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20tg3: power down device only on SYSTEM_POWER_OFFGeorge Shuklin
[ Upstream commit 9fc3bc7643341dc5be7d269f3d3dbe441d8d7ac3 ] Dell R650xs servers hangs on reboot if tg3 driver calls tg3_power_down. This happens only if network adapters (BCM5720 for R650xs) were initialized using SNP (e.g. by booting ipxe.efi). The actual problem is on Dell side, but this fix allows servers to come back alive after reboot. Signed-off-by: George Shuklin <george.shuklin@gmail.com> Fixes: 2ca1c94ce0b6 ("tg3: Disable tg3 device on system reboot to avoid triggering AER") Reviewed-by: Pavan Chebbi <pavan.chebbi@broadcom.com> Reviewed-by: Michael Chan <michael.chan@broadcom.com> Link: https://lore.kernel.org/r/20231103115029.83273-1-george.shuklin@gmail.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2023-11-20net/smc: put sk reference if close work was canceledD. Wythe
[ Upstream commit aa96fbd6d78d9770323b21e2c92bd38821be8852 ] Note that we always hold a reference to sock when attempting to submit close_work. Therefore, if we have successfully canceled close_work from pending, we MUST release that reference to avoid potential leaks. Fixes: 42bfba9eaa33 ("net/smc: immediate termination for SMCD link groups") Signed-off-by: D. Wythe <alibuda@linux.alibaba.com> Reviewed-by: Dust Li <dust.li@linux.alibaba.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
