This reverts commit b6d547791fd3ef4ccc89ad2556ab01045640aef7.
The panel self refresh clearly isn't stable yet, and causes my laptop
(Haswell ULT in a Sony Vaio Pro) to have the screen lock up. Maybe it
doesn't ever get out of self-refresh, or maybe there are gremlins in the
machine that get unhappy. Regardless, it's broken, and it gets
reverted.
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Pull ARM SoC defconfig updates from Olof Johansson:
"We broke this out in a separate branch since some defconfigs now are
shared between maintainers, and having them merged in through separate
topics (drivers/soc/etc) is a recipe for conflicts.
Most of this is removal of two defconfigs:
- Kirkwood, now folded into mvebu/multi_v5
- Renesas genmai, removed platform
- major defconfig refresh for exynos
- various updates on the other multi-defconfigs and others (tegra,
socfpga, shmobile):
* tag 'defconfig-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits)
ARM: multi_v7_defconfig: Enable TI PIPE3 PHY driver
ARM: config: enable ARCH_HIX5HD2
ARM: multi_v7_defconfig: Enable MiPHY365x - ST's Generic (SATA & PCIe) PHY
ARM: multi_v7_defconfig: Enable ST's (S)ATA driver
ARM: multi_v7_defconfig: add ST Keyscan driver
ARM: update multi_v7_defconfig for STI
ARM: multi_v7_defconfig: Configure in ST's Thermal Controller
ARM: exynos_defconfig: Update exynos_defconfig
ARM: shmobile: defconfig: Remove MACH_GENMAI
ARM: mvebu: update mvebu_v7_defconfig with cpufreq support
ARM: mvebu: defconfig: enable cpuidle support in mvebu_v7_defconfig
ARM: shmobile: genmai: remove defconfig
ARM: socfpga: Update socfpga_defconfig
ARM: Kirkwood: Remove kirkwood_defconfig
ARM: mvebu: enable Armada 375 network driver in mvebu_v7_defconfig
ARM: shmobile: Enable R-Car Gen 2 PCIe in shmobile_defconfig
ARM: mvebu: add devtmpfs to mvebu_v5_defconfig
ARM: mvebu: add appended DTB support in mvebu_v5_defconfig
ARM: multi_v7: enable igb, stmpe, lm95245, pwm leds
ARM: multi_v7_defconfig: Enable ST's I2C driver
Pull ARM SoC driver changes from Olof Johansson:
"A handful of driver-related changes. We've had a bunch of them going
in through other branches as well, so it's only a part of what we
really have this release.
Larger pieces are:
- Removal of a now unused PWM driver for atmel
[ This includes AVR32 changes that have been appropriately acked ]
- Performance counter support for the arm CCN interconnect
- OMAP mailbox driver cleanups and consolidation
- PCI and SATA PHY drivers for SPEAr 13xx platforms
- Redefinition (with backwards compatibility!) of PCI DT bindings for
Tegra to better model regulators/power"
Note: this merge also fixes up the semantic conflict with the new
calling convention for devm_phy_create(), see commit f0ed817638b5 ("phy:
core: Let node ptr of PHY point to PHY and not of PHY provider") that
came in through Greg's USB tree.
Semantic merge patch by Stephen Rothwell <sfr@canb.auug.org.au> through
the next tree.
* tag 'drivers-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits)
bus: arm-ccn: Fix error handling at event allocation
mailbox/omap: add a parent structure for every IP instance
mailbox/omap: remove the private mailbox structure
mailbox/omap: consolidate OMAP mailbox driver
mailbox/omap: simplify the fifo assignment by using macros
mailbox/omap: remove omap_mbox_type_t from mailbox ops
mailbox/omap: remove OMAP1 mailbox driver
mailbox/omap: use devm_* interfaces
bus: ARM CCN: add PERF_EVENTS dependency
bus: ARM CCN PMU driver
PCI: spear: Remove spear13xx_pcie_remove()
PCI: spear: Fix Section mismatch compilation warning for probe()
ARM: tegra: Remove legacy PCIe power supply properties
PCI: tegra: Remove deprecated power supply properties
PCI: tegra: Implement accurate power supply scheme
ARM: SPEAr13xx: Update defconfigs
ARM: SPEAr13xx: Add pcie and miphy DT nodes
ARM: SPEAr13xx: Add bindings and dt node for misc block
ARM: SPEAr13xx: Fix static mapping table
phy: Add drivers for PCIe and SATA phy on SPEAr13xx
Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
Pull ARM SoC board changes from Olof Johansson:
"This is the smallest board branch we have ever had. Most of this is a
few cleanups for board code for Renesas shmobile, with a bit of legacy
driver support added. This is strongly trending in the right
direction now"
* tag 'boards-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: shmobile: Enable R-Car Gen2 CMA code in board files
ARM: shmobile: armadillo800eva reference: Spelling s/ED/LED/
ARM: shmobile: armadillo800eva legacy: Add LED support
ARM: shmobile: lager-reference: Remove workarounds for core clock issues
ARM: shmobile: koelsch-reference: Remove workarounds for core clock issues
Pull ARM SoC platform changes from Olof Johansson:
"This is the bulk of new SoC enablement and other platform changes for
3.17:
- Samsung S5PV210 has been converted to DT and multiplatform
- Clock drivers and bindings for some of the lower-end i.MX 1/2
platforms
- Kirkwood, one of the popular Marvell platforms, is folded into the
mvebu platform code, removing mach-kirkwood
- Hwmod data for TI AM43xx and DRA7 platforms
- More additions of Renesas shmobile platform support
- Removal of plat-samsung contents that can be removed with S5PV210
being multiplatform/DT-enabled and the other two old platforms
being removed
New platforms (most with only basic support right now):
- Hisilicon X5HD2 settop box chipset is introduced
- Mediatek MT6589 (mobile chipset) is introduced
- Broadcom BCM7xxx settop box chipset is introduced
+ as usual a lot other pieces all over the platform code"
* tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits)
ARM: hisi: remove smp from machine descriptor
power: reset: move hisilicon reboot code
ARM: dts: Add hix5hd2-dkb dts file.
ARM: debug: Rename Hi3716 to HIX5HD2
ARM: hisi: enable hix5hd2 SoC
ARM: hisi: add ARCH_HISI
MAINTAINERS: add entry for Broadcom ARM STB architecture
ARM: brcmstb: select GISB arbiter and interrupt drivers
ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs
ARM: configs: enable SMP in bcm_defconfig
ARM: add SMP support for Broadcom mobile SoCs
Documentation: arm: misc updates to Marvell EBU SoC status
Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC
ARM: mvebu: fix build without platforms selected
ARM: mvebu: add cpuidle support for Armada 38x
ARM: mvebu: add cpuidle support for Armada 370
cpuidle: mvebu: add Armada 38x support
cpuidle: mvebu: add Armada 370 support
cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7
ARM: mvebu: export the SCU address
Pull ARM SoC cleanups from Olof Johansson:
"This merge window brings a good size of cleanups on various platforms.
Among the bigger ones:
- Removal of Samsung s5pc100 and s5p64xx platforms. Both of these
have lacked active support for quite a while, and after asking
around nobody showed interest in keeping them around. If needed,
they could be resurrected in the future but it's more likely that
we would prefer reintroduction of them as DT and
multiplatform-enabled platforms instead.
- OMAP4 controller code register define diet. They defined a lot of
registers that were never actually used, etc.
- Move of some of the Tegra platform code (PMC, APBIO, fuse,
powergate) to drivers/soc so it can be shared with 64-bit code.
This also converts them over to traditional driver models where
possible.
- Removal of legacy gpio-samsung driver, since the last users have
been removed (moved to pinctrl)
Plus a bunch of smaller changes for various platforms that sort of
dissapear in the diffstat for the above. clps711x cleanups, shmobile
header file refactoring/moves for multiplatform friendliness, some
misc cleanups, etc"
* tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits)
drivers: CCI: Correct use of ! and &
video: clcd-versatile: Depend on ARM
video: fix up versatile CLCD helper move
MAINTAINERS: Add sdhci-st file to ARCH/STI architecture
ARM: EXYNOS: Fix build breakge with PM_SLEEP=n
MAINTAINERS: Remove Kirkwood
ARM: tegra: Convert PMC to a driver
soc/tegra: fuse: Set up in early initcall
ARM: tegra: Always lock the CPU reset vector
ARM: tegra: Setup CPU hotplug in a pure initcall
soc/tegra: Implement runtime check for Tegra SoCs
soc/tegra: fuse: fix dummy functions
soc/tegra: fuse: move APB DMA into Tegra20 fuse driver
soc/tegra: Add efuse and apbmisc bindings
soc/tegra: Add efuse driver for Tegra
ARM: tegra: move fuse exports to soc/tegra/fuse.h
ARM: tegra: export apb dma readl/writel
ARM: tegra: Use a function to get the chip ID
ARM: tegra: Sort includes alphabetically
ARM: tegra: Move includes to include/soc/tegra
git://anongit.freedesktop.org/drm-intel
Pull intel drm fixes from Daniel Vetter:
"So I heard that proper pull requests have a revert on top ;-) So here
we go with my usual mid-merge-window pile of fixes.
[ Ed. This revert thing had better not become the "in" thing ]
Big fix is the duct-tape for ring init on g4x platforms, we seem to
have found the magic again to make those machines as happy as before
(not perfect though unfortunately, but that was never the case).
Otherwise fixes all over:
- tune down some overzealous debug output
- VDD power sequencing fix after resume
- bunch of dsi fixes for baytrail among them hw state checker
de-noising
- bunch of error state capture fixes for bdw
- misc tiny fixes/workarounds for various platforms
Last minute rebase was to kick out two patches that shouldn't have
been in here - they're for the state checker, so 0 functional code
affected.
Jani's back from vacation, so he'll take over -fixes from here"
* tag 'drm-intel-fixes-2014-08-08' of git://anongit.freedesktop.org/drm-intel: (21 commits)
Revert "drm/i915: Enable semaphores on BDW"
drm/i915: read HEAD register back in init_ring_common() to enforce ordering
drm/i915: Fix crash when failing to parse MIPI VBT
drm/i915: Bring GPU Freq to min while suspending.
drm/i915: Fix DEIER and GTIER collecting for BDW.
drm/i915: Don't accumulate hangcheck score on forward progress
drm/i915: Add the WaCsStallBeforeStateCacheInvalidate:bdw workaround.
drm/i915: Refactor Broadwell PIPE_CONTROL emission into a helper.
drm/i915: Fix threshold for choosing 32 vs. 64 precisions for VLV DDL values
drm/i915: Fix drain latency precision multipler for VLV
drm/i915: Collect gtier properly on HSW.
drm/i915: Tune down MCH_SSKPD values warning
drm/i915: Tune done rc6 enabling output
drm/i915: Don't require dev->struct_mutex in psr_match_conditions
drm/i915: Fix error state collecting
drm/i915: fix VDD state tracking after system resume
drm/i915: Add correct hw/sw config check for DSI encoder
drm/i915: factor out intel_edp_panel_vdd_sanitize
drm/i915: wait for all DSI FIFOs to be empty
drm/i915: work around warning in i915_gem_gtt
This reverts commit 521e62e49a42661a4ee0102644517dbe2f100a23.
Although POST_SYNC brought a bit of stability to Semaphores on BDW
it didn't solved all issues and some hungs can still occour when
semaphores are enabled on BDW. Also some sloweness can be found on some
igt tests, althoguth it apparently doesn't affect real workloads.
Besides that, no real performance gain was found on our tests with different
and even multiple workloads.
Let's disable it again for now. At least until we are sure it is safe
to re-enable it.
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Withtout this, ring initialization fails reliabily during resume with
[drm:init_ring_common] *ERROR* render ring initialization failed ctl 0001f001 head ffffff8804 tail 00000000 start 000e4000
This is not a complete fix, but it is verified to make the ring
initialization failures during resume much less likely.
We were not able to root-cause this bug (likely HW-specific to Gen4 chips)
yet. This is therefore used as a ducttape before problem is fully
understood and proper fix created, so that people don't suffer from
completely unusable systems in the meantime.
The discussion and debugging is happening at
https://bugs.freedesktop.org/show_bug.cgi?id=76554
Cc: stable@vger.kernel.org
This particular nasty presented itself while trying to register the
intelfb device (intel_fbdev.c). During the process of registering the device
the driver will disable the crtc via i9xx_crtc_disable. These will
also disable the panel using the generic mipi panel functions in
dsi_mod_vbt_generic.c. The stale MIPI generic data sequence pointers would
cause a crash within those functions. However, all of this is happening
while console_lock is held from do_register_framebuffer inside fbcon.c. Which
means that you got kernel log and just the device appearing to reboot/hang for
no apparent reason.
The fault started from the FB_EVENT_FB_REGISTERED event using the
fb_notifier_call_chain call in fbcon.c.
This regression has been introduced in
commit d3b542fcfc72d7724585e3fd2c5e75351bc3df47
Author: Shobhit Kumar <shobhit.kumar@intel.com>
Date: Mon Apr 14 11:00:34 2014 +0530
drm/i915: Add parsing support for new MIPI blocks in VBT
Cc: Shobhit Kumar <shobhit.kumar@intel.com>
Signed-off-by: Rafael Barbalho <rafael.barbalho@intel.com>
Reviewed-by: Shobhit Kumar <shobhit.kumar@intel.com>
[danvet: Add regression citation.]
Pull DRM updates from Dave Airlie:
"Like all good pull reqs this ends with a revert, so it must mean we
tested it,
[ Ed. That's _one_ way of looking at it ]
This pull is missing nouveau, Ben has been stuck trying to track down
a very longstanding bug that revealed itself due to some other
changes. I've asked him to send you a direct pull request for nouveau
once he cleans things up. I'm away until Monday so don't want to
delay things, you can make a decision on that when he sends it, I have
my phone so I can ack things just not really merge much.
It has one trivial conflict with your tree in armada_drv.c, and also
the pull request contains some component changes that are already in
your tree, the base tree from Russell went via Greg's tree already,
but some stuff still shows up in here that doesn't when I merge my
tree into yours.
Otherwise all pretty standard graphics fare, one new driver and
changes all over the place.
New drivers:
- sti kms driver for STMicroelectronics chipsets stih416 and stih407.
core:
- lots of cleanups to the drm core
- DP MST helper code merged
- universal cursor planes.
- render nodes enabled by default
panel:
- better panel interfaces
- new panel support
- non-continuous cock advertising ability
ttm:
- shrinker fixes
i915:
- hopefully ditched UMS support
- runtime pm fixes
- psr tracking and locking - now enabled by default
- userptr fixes
- backlight brightness fixes
- MST support merged
- runtime PM for dpms
- primary planes locking fixes
- gen8 hw semaphore support
- fbc fixes
- runtime PM on SOix sleep state hw.
- mmio base page flipping
- lots of vlv/chv fixes.
radeon:
- Hawaii fixes
- display scalar support for non-fixed mode displays
- new firmware format support
- dpm on more asics by default
- GPUVM improvements
- uncached and wc GTT buffers
- BOs > visible VRAM
exynos:
- i80 interface support
- module auto-loading
- ipp driver consolidated.
armada:
- irq handling in crtc layer only
- crtc renumbering
- add component support
- DT interaction changes.
tegra:
- load as module fixes
- eDP bpp and sync polarity fixed
- DSI non-continuous clock mode support
- better support for importing buffers from nouveau
msm:
- mdp5/adq8084 v1.3 hw enablement
- devicetree clk changse
- ifc6410 board working
tda998x:
- component support
- DT documentation update
vmwgfx:
- fix compat shader namespace"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (551 commits)
Revert "drm: drop redundant drm_file->is_master"
drm/panel: simple: Use devm_gpiod_get_optional()
drm/dsi: Replace upcasting macro by function
drm/panel: ld9040: Replace upcasting macro by function
drm/exynos: dp: Modify driver to support drm_panel
drm/exynos: Move DP setup into commit()
drm/panel: simple: Add AUO B133HTN01 panel support
drm/panel: simple: Support delays in panel functions
drm/panel: simple: Add proper definition for prepare and unprepare
drm/panel: s6e8aa0: Add proper definition for prepare and unprepare
drm/panel: ld9040: Add proper definition for prepare and unprepare
drm/tegra: Add support for panel prepare and unprepare routines
drm/exynos: dsi: Add support for panel prepare and unprepare routines
drm/exynos: dpi: Add support for panel prepare and unprepare routines
drm/panel: simple: Add dummy prepare and unprepare routines
drm/panel: s6e8aa0: Add dummy prepare and unprepare routines
drm/panel: ld9040: Add dummy prepare and unprepare routines
drm/panel: Provide convenience wrapper for .get_modes()
drm/panel: add .prepare() and .unprepare() functions
drm/panel: simple: Remove simple-panel compatible
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED updates from Bryan Wu:
"This cycle we got:
- a fix of attribute-creation race for the whole leds subsystem
- new drivers (HID:GT683R, leds-ipaq-micro)
- other fixing and clean up"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (23 commits)
leds: ipaq-micro: fix sparse non static symbol warning
leds: add driver for the iPAQ micro
Documentation: dts: tcs6507: Fix wrong statement about #gpio-cells
leds: convert blink timer to workqueue
leds:pca963x: Update for PCA9635 and correct statement about MODE2 OUTDRV default
leds:pca963x: Always initialize MODE2 register
leds:pca963x: Add support for PCA9635 LED driver chip
HID: gt683r: move mode attribute to led-class devices
HID: gt683r: fix race condition
HID: add support for MSI GT683R led panels
leds: lp55xx-common: fix attribute-creation race
leds: lp55xx-common: fix sysfs entry leak
input: lm8323: fix attribute-creation race
leds: wm831x-status: fix attribute-creation race
leds: ss4200: fix attribute-creation race
leds: ns2: fix attribute-creation race
leds: netxbig: fix attribute-creation race
leds: max8997: fix attribute-creation race
leds: lm3642: fix attribute-creation race
leds: lm355x: fix attribute-creation race
git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight
Pull backlight changes from Lee Jones:
Changes to existing drivers:
- remove get brightness implementations in via-pmu-backlight
samsung-q10 aat2870_bl ams369fg06 bd6107 gpio_backlight ld9040
lp855x_bl lp8788_bl lv5207lp pandora_bl pwm_bl s6e63m0 tps65217_bl
aty128fb atyfb_base radeon_backlight s6e8ax0 nv_backlight
riva/fbdev
- improve error handling in jornada720_lcd
- make use of new 'get optional' GPIO command in pwm_bl
- fix sparse warning in ipaq_micro_bl
New drivers/supported devices:
- new driver for iPAQ"
* tag 'backlight-for-linus-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight:
backlight: ipaq_micro: Fix sparse non static symbol warning
backlight: Add driver for iPAQ micro backlight
backlight: pwm-backlight: Use devm_gpiod_get_optional()
backlight: jornada720: Minimise code duplication and handle errors better
backlight: Show brightness even if get_brightness is not implemented
backlight: Remove trivial get_brightness implementations
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pinctrl updates from Linus Walleij:
"This is the bulk pin control changes for the v3.17 merge development
cycle:
- get rid of the .disable() callback from the driver callback vtable.
This callback was abused and counterintuitive since a pin or group
of pins can be said to always be in some setting, and never really
disabled. We now only enable a certain muxing, and move between
some certain muxings, we never "disable" a mux setting
- some janitorial moving the MSM, Samsung and Nomadik and drivers to
their own subdirectories for a clearer view in the subsystem. This
will continue
- kill off the use of the return value from gpiochip_remove(), this
will be done in parallel in the GPIO subsystem and hopefully not
trigger too many unchecked return value warnings before we get rid
of this altogether
- a huge set of changes and improvements to the Allwinner sunxi
drivers especially for their latest A23 and A31 SoCs, and some
ground work for the new sun8i platform family
- a large set of Rockchip driver improvements adding support for the
RK3288 SoC
- advances in migration of older Freescale platforms to pin control,
especially i.MX1
- Samsung and Exynos improvements
- support for the Qualcomm MSM8960 SoC
- use the gpiolib irqchip helpers for the ST SPEAr and Intel Baytrail
drivers
- a bunch of nice janitorial work done with cppcheck"
* tag 'pinctrl-v3.17-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (61 commits)
pinctrl: baytrail: Convert to use gpiolib irqchip
pinctrl: sunxi: number gpio ranges starting from 0
pinctrl: sunxi: use gpiolib API to mark a GPIO used as an IRQ
pinctrl: rockchip: add drive-strength control for rk3288
pinctrl: rockchip: add separate type for rk3288
pinctrl: rockchip: set is_generic in pinconf_ops
pinctrl: msm: drop negativity check on unsigned value
pinctrl: remove all usage of gpio_remove ret val in driver/pinctl
pinctrl: qcom: Make muxing of gpio function explicit
pinctrl: nomadik: move all Nomadik drivers to subdir
pinctrl: samsung: Group all drivers in a sub-dir
sh-pfc: sh73a0: Introduce the use of devm_regulator_register
sh-pfc: Add renesas,pfc-r8a7791 to binding documentation
pinctrl: msm: move all qualcomm drivers to subdir
pinctrl: msm: Add msm8960 definitions
pinctrl: samsung: Allow pin value to be initialized using pinfunc
pinctrl: samsung: Allow grouping multiple pinmux/pinconf nodes
pinctrl: exynos: Consolidate irq_chips of GPIO and WKUP EINTs
pinctrl: samsung: Handle GPIO request and free using pinctrl helpers
pinctrl: samsung: Decouple direction setting from pinctrl
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD update from Lee Jones:
"Changes to existing drivers:
- checkpatch fixes throughout the subsystem
- use Regmap to handle IRQs in max77686, extcon-max77693 and
mc13xxx-core
- use DMA in rtsx_pcr
- restrict building on unsupported architectures on timberdale,
cs5535
- SPI hardening in cros_ec_spi
- more robust error handing in asic3, cros_ec, ab8500-debugfs,
max77686 and pcf50633-core
- reorder PM runtime and regulator handing during shutdown in arizona
- enable wakeup in cros_ec_spi
- unused variable/code clean-up in pm8921-core, cros_ec, htc-i2cpld,
tps65912-spi, wm5110-tables and ab8500-debugfs
- add regulator handing into suspend() in sec-core
- remove pointless wrapper functions in extcon-max77693 and
i2c-cros-ec-tunnel
- use cross-architecture friendly data sizes in stmpe-i2c, arizona,
max77686 and tps65910
- devicetree documentation updates throughout
- provide power management support in max77686
- few OF clean-ups in max77686
- use manged resources in tps6105x
- add support for s2mpu02 to sec-core
- add support for Allwinner A32 to sun6i-prcm
- add support for Maxim 77802 in max77686
- add support for DA9063 AD in da9063
- new driver for Intel PMICs (generic) and specifically Crystal Cove
(Re-)moved drivers ==
- move out keyboard functionality cros_ec ==> input/keyboard/cros_ec_keyb"
* tag 'mfd-for-linus-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (101 commits)
MAINTAINERS: Update MFD repo location
mfd: omap-usb-host: Fix improper mask use.
mfd: arizona: Only free the CTRLIF_ERR IRQ if we requested it
mfd: arizona: Add missing handling for ISRC3 under/overclocked
mfd: wm5110: Add new interrupt register definitions
mfd: arizona: Rename thermal shutdown interrupt
mfd: wm5110: Add in the output done interrupts
mfd: wm5110: Remove non-existant interrupts
mfd: tps65912-spi: Remove unused variable
mfd: htc-i2cpld: Remove unused code
mfd: da9063: Add support for AD silicon variant
mfd: arizona: Map MICVDD from extcon device to the Arizona core
mfd: arizona: Add MICVDD to mapped regulators for wm8997
mfd: max77686: Ensure device type IDs are architecture agnostic
mfd: max77686: Add Maxim 77802 PMIC support
mfd: tps6105x: Use managed resources when allocating memory
mfd: wm8997-tables: Suppress 'line over 80 chars' warnings
mfd: kempld-core: Correct a variety of checkpatch warnings
mfd: ipaq-micro: Fix coding style errors/warnings reported by checkpatch
mfd: si476x-cmd: Remedy checkpatch style complains
Merging in the few fixes we had also received, no need to keep those in
a separate branch.
* next/fixes-non-critical:
ARM: omap2+: gpmc-nand: Use dynamic platform_device_alloc()
omap16xx: Removes fixme no longer needed in ocpi_enable()
ARM: dts: OMAP5: Add device nodes for ABB
ARM: omap2+: usb-tusb6010.c: Cleaning up variable is set more than once
This reverts commit 48ba813701eb14b3008edefef4a0789b328e278c.
Thanks to Chris:
"drm_file->is_master is not synomous with having drm_file->master ==
drm_file->minor->master. This is because drm_file->master is the same
for all drm_files of the same generation and so when there is a master,
every drm_file believes itself to be the master. Confusion ensues and
things go pear shaped when one file is closed and there is no master
anymore."
drivers/gpu/drm/drm_drv.c
drivers/gpu/drm/drm_stub.c
Pull second round of KVM changes from Paolo Bonzini:
"Here are the PPC and ARM changes for KVM, which I separated because
they had small conflicts (respectively within KVM documentation, and
with 3.16-rc changes). Since they were all within the subsystem, I
took care of them.
Stephen Rothwell reported some snags in PPC builds, but they are all
fixed now; the latest linux-next report was clean.
New features for ARM include:
- KVM VGIC v2 emulation on GICv3 hardware
- Big-Endian support for arm/arm64 (guest and host)
- Debug Architecture support for arm64 (arm32 is on Christoffer's todo list)
And for PPC:
- Book3S: Good number of LE host fixes, enable HV on LE
- Book3S HV: Add in-guest debug support
This release drops support for KVM on the PPC440. As a result, the
PPC merge removes more lines than it adds. :)
I also included an x86 change, since Davidlohr tied it to an
independent bug report and the reporter quickly provided a Tested-by;
there was no reason to wait for -rc2"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (122 commits)
KVM: Move more code under CONFIG_HAVE_KVM_IRQFD
KVM: nVMX: fix "acknowledge interrupt on exit" when APICv is in use
KVM: nVMX: Fix nested vmexit ack intr before load vmcs01
KVM: PPC: Enable IRQFD support for the XICS interrupt controller
KVM: Give IRQFD its own separate enabling Kconfig option
KVM: Move irq notifier implementation into eventfd.c
KVM: Move all accesses to kvm::irq_routing into irqchip.c
KVM: irqchip: Provide and use accessors for irq routing table
KVM: Don't keep reference to irq routing table in irqfd struct
KVM: PPC: drop duplicate tracepoint
arm64: KVM: fix 64bit CP15 VM access for 32bit guests
KVM: arm64: GICv3: mandate page-aligned GICV region
arm64: KVM: GICv3: move system register access to msr_s/mrs_s
KVM: PPC: PR: Handle FSCR feature deselects
KVM: PPC: HV: Remove generic instruction emulation
KVM: PPC: BOOKEHV: rename e500hv_spr to bookehv_spr
KVM: PPC: Remove DCR handling
KVM: PPC: Expose helper functions for data/inst faults
KVM: PPC: Separate loadstore emulation from priv emulation
KVM: PPC: Handle magic page in kvmppc_ld/st
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen updates from David Vrabel:
- remove unused V2 grant table support
- note that Konrad is xen-blkkback/front maintainer
- add 'xen_nopv' option to disable PV extentions for x86 HVM guests
- misc minor cleanups
* tag 'stable/for-linus-3.17-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen-pciback: Document the 'quirks' sysfs file
xen/pciback: Fix error return code in xen_pcibk_attach()
xen/events: drop negativity check of unsigned parameter
xen/setup: Remove Identity Map Debug Message
xen/events/fifo: remove a unecessary use of BM()
xen/events/fifo: ensure all bitops are properly aligned even on x86
xen/events/fifo: reset control block and local HEADs on resume
xen/arm: use BUG_ON
xen/grant-table: remove support for V2 tables
x86/xen: safely map and unmap grant frames when in atomic context
MAINTAINERS: Make me the Xen block subsystem (front and back) maintainer
xen: Introduce 'xen_nopv' to disable PV extensions for HVM guests.
Pull microblaze updates from Michal Simek:
- add new syscall and fix comment
- fix udelay implementation
- fix libgcc for modules
* tag 'microblaze-3.17-rc1' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Change libgcc-style functions from lib-y to obj-y
microblaze: Wire-up renameat2 syscall
microblaze: Add syscall number comment
microblaze: delay.h fix udelay and ndelay for 8 bit args
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32
Pull avr32 fix from Hans-Christian Egtvedt.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32:
avr32: fix error return code
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"This is the powerpc new goodies for 3.17. The short story:
The biggest bit is Michael removing all of pre-POWER4 processor
support from the 64-bit kernel. POWER3 and rs64. This gets rid of a
ton of old cruft that has been bitrotting in a long while. It was
broken for quite a few versions already and nobody noticed. Nobody
uses those machines anymore. While at it, he cleaned up a bunch of
old dusty cabinets, getting rid of a skeletton or two.
Then, we have some base VFIO support for KVM, which allows assigning
of PCI devices to KVM guests, support for large 64-bit BARs on
"powernv" platforms, support for HMI (Hardware Management Interrupts)
on those same platforms, some sparse-vmemmap improvements (for memory
hotplug),
There is the usual batch of Freescale embedded updates (summary in the
merge commit) and fixes here or there, I think that's it for the
highlights"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (102 commits)
powerpc/eeh: Export eeh_iommu_group_to_pe()
powerpc/eeh: Add missing #ifdef CONFIG_IOMMU_API
powerpc: Reduce scariness of interrupt frames in stack traces
powerpc: start loop at section start of start in vmemmap_populated()
powerpc: implement vmemmap_free()
powerpc: implement vmemmap_remove_mapping() for BOOK3S
powerpc: implement vmemmap_list_free()
powerpc: Fail remap_4k_pfn() if PFN doesn't fit inside PTE
powerpc/book3s: Fix endianess issue for HMI handling on napping cpus.
powerpc/book3s: handle HMIs for cpus in nap mode.
powerpc/powernv: Invoke opal call to handle hmi.
powerpc/book3s: Add basic infrastructure to handle HMI in Linux.
powerpc/iommu: Fix comments with it_page_shift
powerpc/powernv: Handle compound PE in config accessors
powerpc/powernv: Handle compound PE for EEH
powerpc/powernv: Split ioda_eeh_get_state()
powerpc/powernv: Allow to freeze PE
powerpc/powernv: Enable M64 aperatus for PHB3
powerpc/eeh: Aux PE data for error log
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for 3.17. It contains:
- misc Cavium Octeon, BCM47xx, BCM63xx and Alchemy updates
- MIPS ptrace updates and cleanups
- various fixes that will also go to -stable
- a number of cleanups and small non-critical fixes.
- NUMA support for the Loongson 3.
- more support for MSA
- support for MAAR
- various FP enhancements and fixes"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits)
MIPS: jz4740: remove unnecessary null test before debugfs_remove
MIPS: Octeon: remove unnecessary null test before debugfs_remove_recursive
MIPS: ZBOOT: implement stack protector in compressed boot phase
MIPS: mipsreg: remove duplicate MIPS_CONF4_FTLBSETS_SHIFT
MIPS: Bonito64: remove a duplicate define
MIPS: Malta: initialise MAARs
MIPS: Initialise MAARs
MIPS: detect presence of MAARs
MIPS: define MAAR register accessors & bits
MIPS: mark MSA experimental
MIPS: Don't build MSA support unless it can be used
MIPS: consistently clear MSA flags when starting & copying threads
MIPS: 16 byte align MSA vector context
MIPS: disable preemption whilst initialising MSA
MIPS: ensure MSA gets disabled during boot
MIPS: fix read_msa_* & write_msa_* functions on non-MSA toolchains
MIPS: fix MSA context for tasks which don't use FP first
MIPS: init upper 64b of vector registers when MSA is first used
MIPS: save/disable MSA in lose_fpu
MIPS: preserve scalar FP CSR when switching vector context
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"Mostly cleanups and bug-fixes, with two exceptions.
The first is lazy flushing of I/O-TLBs for PCI to improve performance,
the second is software dirty bits in the pmd for the madvise-free
implementation"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (24 commits)
s390/locking: Reenable optimistic spinning
s390/mm: implement dirty bits for large segment table entries
KVM: s390/mm: Fix page table locking vs. split pmd lock
s390/dasd: fix camel case
s390/3215: fix hanging console issue
s390/irq: improve displayed interrupt order in /proc/interrupts
s390/seccomp: fix error return for filtered system calls
s390/pci: introduce lazy IOTLB flushing for DMA unmap
dasd: fix error recovery for alias devices during format
dasd: fix list_del corruption during format
dasd: fix unresponsive device during format
dasd: use aliases for formatted devices during format
s390/pci: fix kmsg component
s390/kdump: Return NOTIFY_OK for all actions other than MEM_GOING_OFFLINE
s390/watchdog: Fix module name in Kconfig help text
s390/dasd: replace seq_printf by seq_puts
s390/dasd: replace pr_warning by pr_warn
s390/dasd: Move EXPORT_SYMBOL after function/variable
s390/dasd: remove unnecessary null test before debugfs_remove
s390/zfcp: use qdio buffer helpers
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
We might be leaving the PGU Frequency (and thus vnn) high during the suspend.
Flusing the delayed work queue should take care of this.
Signed-off-by: Deepak S <deepak.s@linux.intel.com>
BDW has many other Display Engine interrupts and GT interrupts registers.
Collecting it properly on gpu_error_state.
On debugfs all was properly listed already but besides we were also listing old
DEIER and GTIER that doesn't exist on BDW anymore. This was causing
unclaimed register messages
v2: Fix small issues of first version and don't read DEIER regs when pipe's
power well is disabled
v3: bikeshed accepted: use enum pipe pipe instead of int i for pipe interection
v4: Ben notice previous version was checking for display_power_enabled without
using propper locks. Using _unlocked version isn't reliable and we cannot
get this registers when power well is off. So let's avoid getting all DE_IER
per pipe for now. If someone think this is an useful information it can be
added later.
v5: Ben: put back debugfs stuff that might be coverred by pm_get and use
gen >= 8 trying to predict future.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=81701
Cc: Ben Widawsky <ben@bwidawsk.net>
Cc: Paulo Zanoni <paulo.r.zanoni@intel.com>
Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
Reviewed-by: (v3) Paulo Zanoni <paulo.r.zanoni@intel.com>
If the actual head has progressed forward inside a batch (request),
don't accumulate hangcheck score.
As the hangcheck score in increased only by acthd jumping backwards,
the result is that we only declare an active batch as stuck if it is
trapped inside a loop. Or that the looping will dominate the batch
progression so that it overcomes the bonus that forward progress gives.
v2: Improved commit message (Chris Wilson)
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
[danvet: s/active_loop/active (loop)/ as requested by Chris.]
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
On Broadwell, any PIPE_CONTROL with the "State Cache Invalidate" bit set
must be preceded by a PIPE_CONTROL with the "CS Stall" bit set.
Documented on the BSpec 3D workarounds page.
Reviewed-by: Rafael Barbalho <rafael.barbalho@intel.com>
Signed-off-by: Kenneth Graunke <kenneth@whitecape.org>
[vsyrjala: add chv w/a note too]
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
We'll want to reuse this for a workaround.
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
[danvet: Rmove now unused int.]
git://anongit.freedesktop.org/tegra/linux into drm-next
drm/tegra: Changes for v3.17-rc1
Mostly some cleanup all over the place. Pitch alignment limitations of
the display controller are now honored and job submission is 64-bit
safe.
The SOR output (used for eDP) properly configures sync signal polarities
according to the display mode rather than hard-coding them to some value
and the number of bits per color is now taken from the panel rather than
hard-coded to properly support 24-bit vs. 18-bit panels.
The DSI controller now properly supports non-continuous clock mode.
GEM objects can now have their flags and tiling mode modified via IOCTLs
to allow buffers imported from Nouveau to be properly displayed. Newer
generations of the Tegra display controller can also detile block linear
buffers at scan-out time.
Finally the driver now properly exports MODULE_DEVICE_TABLEs to allow it
to be automatically loaded when built as a module.
* tag 'drm/tegra/for-3.17-rc1' of git://anongit.freedesktop.org/tegra/linux:
drm/tegra: add MODULE_DEVICE_TABLEs
drm/tegra: dc - Reset controller on driver remove
drm/tegra: Properly align stride for framebuffers
drm/tegra: sor - Configure proper sync polarities
drm/tegra: sor - Use bits-per-color from panel
drm/tegra: Make job submission 64-bit safe
drm/tegra: Allow non-authenticated processes to create buffer objects
drm/tegra: Add SET/GET_FLAGS IOCTLs
drm/tegra: Add SET/GET_TILING IOCTLs
drm/tegra: Implement more tiling modes
drm/tegra: dsi - Handle non-continuous clock flag
drm/tegra: sor - missing unlock on error
drm/panel: Changes for v3.17-rc1
Panels can now be more finely controlled via .prepare() and .unprepare()
callbacks in addition to .enable() and .disable(). New kerneldoc details
what they are supposed to do and when they should be called.
The simple panel driver gained support for a couple of new panels and it
is now possible to specify additional delays during power up and power
down sequences if panels require it.
DSI devices can now advertise that they support non-continuous clock
mode which will allow DSI host controllers to disable the high speed
clock after transmissions to save power.
* tag 'drm/panel/for-3.17-rc1' of git://anongit.freedesktop.org/tegra/linux: (30 commits)
drm/panel: simple: Add Innolux N116BGE panel support
The DDL registers can hold 7bit numbers. Make the most of those seven
bits by adjusting the threshold where we switch between the 64 vs. 32
precision multipliers.
Also we compute 'entries' to make the decision about precision, and then
we recompute the same value to calculate the actual drain latency. Just
use the already calculate 'entries' there.
Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
GTIER and DEIER doesn't have same interface on HSW so this "or" operation
makes the information provided useless.
v2: since we have gtier variable already let's split for everybody
and avoid the strange | op.
Also avoid overriding the value that was set for vlv. In this case I
believe that we should reorganize the whole function, but I'll respect
the comment that ask to not touch the order and let this organization
work to be done later.
v3: moving VLV check to the right place.
Users often can't do anything about this since their vendors stopped
providing BIOS updates. Also we seem to be able to hack around it
with increased latency values, and thus far the only reports have
been for screens with really high resolutions. So tune it down to a
level where only developers can see it.
Also drop some of the end-user fluff.
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Power users spot this and then get adventurous and try to adjust
module driver options. Nothing good ever came out of that, so
hide it better.
Since I've reworked psr support to no longer require x-tiling we don't
check any state protected by the Giant GEM Lock. So drop that check.
Also boo for lockdep_assert_held for not yelling when lockdep is
disabled.
Cc: Paulo Zanoni <przanoni@gmail.com>
Reported-by: Paulo Zanoni <przanoni@gmail.com>
Acked-by: Paulo Zanoni <przanoni@gmail.com>
Fix signal_offset when recording semaphore state on BDW.
Just like during booting the BIOS can leave the VDD bit enabled after
system resume. So apply the same state sanitization there too. This
fixes a problem where after resume the port power domain refcount gets
unbalanced.
v2:
- unchanged
v3:
- call edp sanitizing from the encoder reset handler (Daniel)
Reported-and-tested-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Signed-off-by: Imre Deak <imre.deak@intel.com>
Check in vlv_crtc_clock_get if DPLL is enabled before calling dpio read.
It will not be enabled for DSI and avoid dpio read WARN dumps.
Absence of ->get_config was causing other WARN dumps as well. Update
dpll_hw_state as well correctly
v2: Address review comments by Daniel
- Check if DPLL is enabled rather than checking pipe output type
- set adjusted_mode->flags to 0 in compute_config rather than using
pipe_config->quirks
- Add helper function in intel_dsi_pll.c and use that in intel_dsi.c
- updated dpll_hw_state correctly
- Updated commit message and title
v3: Address review comments by Imre
- Proper masking of P1, M1 fields while computing divisors
- assert in case of bpp mismatch
- guard for divide by 0 while computing pclk
- Use ARRAY_SIZE instead of direct calculation
Signed-off-by: Shobhit Kumar <shobhit.kumar@intel.com>
Reviewed-by: Imre Deak <imre.deak@intel.com>
This will be needed by an upcoming patch too that needs to sanitize the
VDD state during resume. The additional async disabling is only needed
for the resume path, here it doesn't make a difference since we enable
VDD right after the sanitize call.
v2:
- don't set intel_dp ptr for non-eDP encoders (Ville)
Ensure that the DSI packets for a particular sequence are completely
sent before going ahead in the enabling or disabling of the panel
Gcc warns that addr might be used uninitialized. It may not, but I see
why gcc gets confused.
Additionally, hiding code with side-effects inside WARN_ON() argument
seems uncool, so I moved it outside.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
[danvet: Add obligatory /* shuts up gcc */ comment.]
Use the new devm_gpiod_get_optional() to simplify the probe code.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Merge incoming from Andrew Morton:
- Various misc things.
- arch/sh updates.
- Part of ocfs2. Review is slow.
- Slab updates.
- Most of -mm.
- printk updates.
- lib/ updates.
- checkpatch updates.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (226 commits)
checkpatch: update $declaration_macros, add uninitialized_var
checkpatch: warn on missing spaces in broken up quoted
checkpatch: fix false positives for --strict "space after cast" test
checkpatch: fix false positive MISSING_BREAK warnings with --file
checkpatch: add test for native c90 types in unusual order
checkpatch: add signed generic types
checkpatch: add short int to c variable types
checkpatch: add for_each tests to indentation and brace tests
checkpatch: fix brace style misuses of else and while
checkpatch: add --fix option for a couple OPEN_BRACE misuses
checkpatch: use the correct indentation for which()
checkpatch: add fix_insert_line and fix_delete_line helpers
checkpatch: add ability to insert and delete lines to patch/file
checkpatch: add an index variable for fixed lines
checkpatch: warn on break after goto or return with same tab indentation
checkpatch: emit a warning on file add/move/delete
checkpatch: add test for commit id formatting style in commit log
checkpatch: emit fewer kmalloc_array/kcalloc conversion warnings
checkpatch: improve "no space after cast" test
checkpatch: allow multiple const * types
Pull networking fixes from David Miller:
"This fixes the most immediate fallout from yesterday's networking
merge:
1) sock_tx_timestamp() must not clear the passed in tx_flags, but
rather add to them. Fix from Eric Dumazet.
2) The hyperv driver sendbuf region increase needs to be decreased
slightly to handle older backends. From KY Srinivasan.
3) Fix RCU lockdep splats in netlink diag after recent hashing
changes, from Thomas Graf.
4) The new IPV6_FLOWLABEL was given a socket option number that
overlapped with an existing IP6 tables one, breaking ip6_tables.
Fixed by Pablo Neira Ayuso"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
netlink: hold nl_sock_hash_lock during diag dump
tcp: md5: check md5 signature without socket lock
net: fix USB network driver config option.
net: reallocate new socket option number for IPV6_AUTOFLOWLABEL
vmxnet3: fix decimal printf format specifiers prefixed with 0x
net-timestamp: cumulative tcp timestamping fixes
hyperv: Adjust the size of sendbuf region to support ws2008r2
cxgb4: Fix for SR-IOV VF initialization
net-timestamp: sock_tx_timestamp() fix
Pull trivial tree changes from Jiri Kosina:
"Summer edition of trivial tree updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits)
doc: fix two typos in watchdog-api.txt
irq-gic: remove file name from heading comment
MAINTAINERS: Add miscdevice.h to file list for char/misc drivers.
scsi: mvsas: mv_sas.c: Fix for possible null pointer dereference
doc: replace "practise" with "practice" in Documentation
befs: remove check for CONFIG_BEFS_RW
scsi: doc: fix 'SCSI_NCR_SETUP_MASTER_PARITY'
drivers/usb/phy/phy.c: remove a leading space
mfd: fix comment
cpuidle: fix comment
doc: hpfall.c: fix missing null-terminate after strncpy call
usb: doc: hotplug.txt code typos
kbuild: fix comment in Makefile.modinst
SH: add proper prompt to SH_MAGIC_PANEL_R2_VERSION
ARM: msm: Remove MSM_SCM
crypto: Remove MPILIB_EXTRA
doc: CN: remove dead link, kerneltrap.org no longer works
media: update reference, kerneltrap.org no longer works
hexagon: update reference, kerneltrap.org no longer works
doc: LSM: update reference, kerneltrap.org no longer works
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
"Some highlights:
- hid-sony improvements of Sixaxis device support by Antonio Ospite
- hid-hyperv driven devices can now be used as wakeup source, by
Dexuan Cui
- hid-lenovo driver is now more generic and supports more devices, by
Jamie Lentin
- hid-huion now supports wider range of tablets, by Nikolai
Kondrashov
- other various unsorted fixes and device ID additions"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (30 commits)
HID: hyperv: register as a wakeup source
HID: sony: Default initialize all elements of the LED max_brightness array to 1
HID: huion: Fix sparse warnings
HID: usbhid: Use flag HID_DISCONNECTED when a usb device is removed
HID: ignore jabra gn9350e
HID: cp2112: add I2C mode
HID: use multi input quirk for 22b9:2968
HID: rmi: only bind the hid-rmi driver to the mouse interface of composite USB devices
HID: rmi: check that report ids exist in the report_id_hash before accessing their size
HID: lenovo: Add support for Compact (BT|USB) keyboard
HID: lenovo: Don't call function in condition, show error codes
HID: lenovo: Prepare support for adding other devices
HID: lenovo: Rename hid-lenovo-tpkbd to hid-lenovo
HID: huion: Handle tablets with UC-Logic vendor ID
HID: huion: Switch to generating report descriptor
HID: huion: Don't ignore other interfaces
HID: huion: Use "tablet" instead of specific model
HID: add quirk for 0x04d9:0xa096 device
HID: i2c-hid: call the hid driver's suspend and resume callbacks
HID: rmi: change logging level of log messages related to unexpected reports
